2. IMU Application Instructions-Basic Application
2.1 STM32F103-Serial Port Application Routines
This routine utilizes the STM32F103C8T6 chip development board, referred to as STM32 for demonstration convenience.
Preparation of the following products is required: a Win10/Win11 computer, an IMU module (with wired data interface), a micro-USB data cable, a CH340 module, and several DuPont cables.
2.1.1 Preparation
Connect the STM32’s serial port 1 to the CH340 module, and insert the CH340 module into the USB port of the Win10 computer. Connect the STM32’s serial port 2 to the serial port interface of the IMU module.
Use the micro-USB data cable to power the STM32 by connecting it to the STM32 and the USB port of the computer.
  • Wiring Instructions
STM32 IMU
VCC ——> VCC
GND ——> GND
PA10 <—— TXD
2.1.2 Case Development
Wiring Instructions:
	Usart1Init(115200);
	Usart2Init(9600);
Read and print the data of the IMU module.
	while (1)
		CmdProcess();
		if(s_cDataUpdate)
			for(i = 0; i < 3; i++)
				fAcc[i] = sReg[AX+i] / 32768.0f * 16.0f;
				fGyro[i] = sReg[GX+i] / 32768.0f * 2000.0f;
			if(sReg[TEMP] - sReg[Roll] > 10 | sReg[Roll] - sReg[TEMP] > 10)
				fAngle[0] = sReg[Roll] / 32768.0f * 180.0f;
				fAngle_tmp = fAngle[0];
			else   fAngle[0] = fAngle_tmp;
			for(i = 1; i<3;i++)
				fAngle[i] = sReg[Roll+i] / 32768.0f * 180.0f;
			if(s_cDataUpdate & ACC_UPDATE)
				printf("acc:%.3f %.3f %.3f\r\n", fAcc[0], fAcc[1], fAcc[2]);
				s_cDataUpdate &= ~ACC_UPDATE;
			if(s_cDataUpdate & GYRO_UPDATE)
				printf("gyro:%.3f %.3f %.3f\r\n", fGyro[0], fGyro[1], fGyro[2]);
				s_cDataUpdate &= ~GYRO_UPDATE;
			if(s_cDataUpdate & ANGLE_UPDATE)
				printf("angle:%.3f %.3f %.3f\r\n", fAngle[0], fAngle[1], fAngle[2]);
				s_cDataUpdate &= ~ANGLE_UPDATE;
			if(s_cDataUpdate & MAG_UPDATE)
				printf("mag:%d %d %d\r\n", sReg[HX], sReg[HY], sReg[HZ]);
				s_cDataUpdate &= ~MAG_UPDATE;
2.1.3 Program Outcome
After downloading the program and connecting to the STM32, open the serial port assistant (with configuration parameters shown in the figure below). You will observe continuous printing of data from the IMU module. When we alter the attitude of the IMU module, the data will also change accordingly.
2.2 STM32F407-Serial Port Application Routine
This routine utilizes the STM32F407C8T6 chip development board, referred to as STM32 for demonstration convenience.
2.2.1 Preparation
Connect the STM32’s serial port to the USB port of the computer. Connect the STM32’s serial port 2 to the serial port interface of the IMU module.
  • Wiring instructions
STM32 IMU
5V ——> 5V
GND —–> GND
PA3 <—— TXD
2.2.2 Case Development
Please refer to the information section for the specific source code.
This routine sets the baud rate for serial port printing to 115200 bps and the baud rate for connecting to the IMU module to 9600. The baud rate of STM32 serial port 2 can be adjusted based on the baud rate of the IMU module.
void MX_USART1_UART_Init(void)
  /* USER CODE BEGIN USART1_Init 0 */
  /* USER CODE END USART1_Init 0 */
  /* USER CODE BEGIN USART1_Init 1 */
  /* USER CODE END USART1_Init 1 */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
void MX_USART2_UART_Init(void)
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 9600;
  while (1)
    CmdProcess();
    if(s_cDataUpdate)
        for(i = 1; i<3;i++)
2.2.3 Program Outcome
After downloading the program and connecting to the STM32, open the serial port assistant (with configuration parameters shown in the figure below). You will observe continuous printing of data from the IMU module. As we change the attitude of the IMU module, the data will also change accordingly.
2.3 STM32-IIC Application Routine
This routine employs the STM32F103C8T6 chip development board, referred to as STM32 for demonstration convenience.
The following products are required for preparation: a Win10/Win11 computer, an IMU module (with wired data interface), a micro-USB data cable, a CH340 module, and some DuPont cables.
2.3.1 Preparation
Power the STM32 by connecting the micro-USB data cable to the STM32 and the USB port of the computer.
2.3.2 Case Development
Please refer to the specific source code provided in the information.
In this example, the baud rate has been set to 115200 bps. Note that this baud rate refers to the baud rate of the STM32 serial port, not the baud rate of the IMU module.
	Usart1Init(115200);
Another important parameter to note is the I2C address of the IMU module, which is defaulted to 0x50. If you modify the address to another value, please remember to update this parameter accordingly.
	IIC_Init();
	WitInit(WIT_PROTOCOL_I2C, 0x50);
The code loops to read and print data from the IMU module.
	while (1)
		WitReadReg(AX, 12);
		delay_ms(500);
		CmdProcess();
		if (s_cDataUpdate)
			for (i = 0; i < 3; i++)
				fAcc[i] = sReg[AX + i] / 32768.0f * 16.0f;
				fGyro[i] = sReg[GX + i] / 32768.0f * 2000.0f;
				fAngle[i] = sReg[Roll + i] / 32768.0f * 180.0f;
			if (s_cDataUpdate & ACC_UPDATE)
			if (s_cDataUpdate & GYRO_UPDATE)
			if (s_cDataUpdate & ANGLE_UPDATE)
			if (s_cDataUpdate & MAG_UPDATE)
2.3.3 Program Outcome
After downloading the program and connecting to the STM32, open the serial port assistant with the configuration parameters shown in the figure below. You will observe continuous printing of data from the IMU module. As we change the attitude of the IMU module, the data will also change accordingly.
2.4 Raspberry Pi-USB Application Routines
Products required for preparation: a Win10 or Win11 computer, an IMU module, a Type-C data cable, and a Raspberry Pi development kit.
2.4.1 Preparation
  • Hardware Connection
Connect the IMU module to the USB port of the Raspberry Pi using Type-C data cable.
  • Install Serial Port Driver Library
If the serial port driver library is not installed in Python 3, please execute the following command to install it:
pip3 install pyserial
To verify the installation, enter the command to check whether the serial port driver library is installed. Successful installation will list pyserial along with its version number.
pip3 list | grep pyserial
2.4.2 Case Development
If more than one USB device is connected, ensure to verify the USB device number of the IMU module and adjust the port value accordingly. The baud rate for USB communication has been set to baud=9600 in the program. Adjust the baud value as per the baud rate of the IMU module.
    port = '/dev/ttyUSB0' # USB serial port
    baud = 9600   # Same baud rate as the INERTIAL navigation module
    ser = serial.Serial(port, baud, timeout=0.5)
    print("Serial is Opened:", ser.is_open)
    while(1):
        datahex = ser.read(33)
        DueData(datahex)
Enter the command to identify the serial port number after plugging and unplugging the USB data cable. The serial port number is typically ttyUSB0. If the port number differs from the one specified in the imu_usb.py program, make the necessary adjustments. The symbol for ttyUSB0 indicates the port number.
ls /dev/ttyUSB*
Upon plugging in the USB, confirm that the serial port number is ttyUSB0.
When unplugged, no serial number will be displayed.
2.4.3 Program Outcome
To incorporate the imu_usb.py file into the system, follow these steps:
(1) Import the imu_usb.py file into the system.
(2) Open the terminal.
(3) Navigate to the directory where the imu_usb.py file is located.
(4) Execute the following command:
python3 imu_usb.py
This will initiate the printing of data from the IMU module in the terminal. As the attitude of the IMU module changes, the data displayed will update accordingly.
2.5 Jetson Nano-USB Application Routines
You need to prepare the following items: Win10 computer, inertia module, Type-C cable, Jetson Nano development kit.
2.5.1 Preparation
Connect the inertia module to the USB port of Jetson Nano using Type-C data cable.
  • Install Serial Driver Library
Run the command to check whether the serial driver library is installed. If the serial driver library is installed, the word pyserial and its version will be printed.
If the serial driver library is not installed, please run the following command:
2.5.2 Case Development
Please refer to the source code provided in the specific information for the code.
If multiple USB devices are connected, please verify and confirm the USB device number assigned to the inertial navigation module, and adjust the port value accordingly in the program. The program has been configured with a baud rate of 9600 for USB communication. Adjust the baud value to match the baud rate of the inertial navigation module as needed.
    while(1):
        DueData(datahex)
Execute the command to list the available serial port devices. Then, disconnect the USB cable to identify the assigned serial port number. In this scenario, the serial port number is identified as ttyUSB1.
ll /dev/ttyUSB*
Update the symbol representing ttyUSB1 in the imu_usb.py program accordingly.
2.5.3 Program Outcome
To integrate the imu_usb.py file into your system, follow these steps:
(3) Navigate to the directory containing the imu_usb.py file.
python3 imu_usb.py
This will initiate continuous printing of data from the inertial navigation module in the terminal. As the attitude of the inertial navigation module changes, the displayed data will update accordingly.
2.6 Arduino-Serial Port Application Routines
This procedure utilizes the Arduino UNO development board. For the sake of clarity, the following references to hardware and components will be made with regards to Arduino.
Required items for preparation include: a Windows 10/11 computer, an IMU module (with wired data interface), and several DuPont cables.
2.6.1 Preparation
Connect the Arduino programming cable to the computer. Then, link the Arduino’s serial port to the serial port interface of the IMU module.
  • Instructions for wiring
Arduino IMU
5V ——> 5V
GND ——> GND
IO7 <—— TXD
IO6 <—— RXD
2.6.2 Case Development
This script configures the baud rate for serial port printing to 115200 bps and sets the baud rate for connecting to the IMU module to 9600. You can adjust the baud rate of the Arduino serial port to match the baud rate of the IMU module.
  IMU_Serial.begin(9600);
  Serial.begin(115200);
The script reads and prints data from the IMU module.
  while(len--)
    WitSerialDataIn((char)IMU_Serial.read());
  if(AutoScanSensor())
    CmdProcess();
    if(s_cDataUpdate)
      for(i = 1; i<3;i++)
        Serial.print("acc: ");
        Serial.print(fAcc[0]);
        Serial.print(" ");
        Serial.print(fAcc[1]);
        Serial.print(" ");
        Serial.println(fAcc[2]);
        Serial.print("gyro: ");
        Serial.print(fGyro[0]);
        Serial.print(" ");
        Serial.print(fGyro[1]);
        Serial.print(" ");
        Serial.println(fGyro[2]);
2.6.3 Program Outcome
After uploading the program to the Arduino board, launch the serial port monitor from the toolbar (as illustrated below). Ensure that the baud rate is set to 115200. You’ll observe continuous printing of IMU module data. As you manipulate the attitude of the IMU module, the data will dynamically update.
2.7 Arduino-IIC Application Routines
This procedure utilizes the Arduino UNO development board. For demonstration purposes, the term “Arduino” will be used.
Required items for preparation include: a Windows 10/11 computer, an IMU module (with a wired data interface), a type-C data cable, and several DuPont cables.
2.7.1 Preparation
Connect the Arduino programming cable to the computer. Then, interface the Arduino with the I2C interface of the IMU module.
  • Here are the wiring instructions
Arduino IMU
GND ——> GND
D6 ——> SDA
D7 ——> SCL
2.7.2 Case Development
In this example, the baud rate has been configured to 115200 bps. It’s essential to note that this baud rate refers to the baud rate used by the Arduino serial port, not the baud rate of the IMU module.
Another important consideration is the I2C address of the IMU module. The default address is typically set to 0x50. If you have modified the address to something else, ensure to update this parameter accordingly in the code.
  IIC_Init();
Read and print the data of the IMU module in a loop.
void loop() {
  float fAcc[3], fGyro[3], fAngle[3];
  int i;
  WitReadReg(AX, 12);
  delay(500);
  CmdProcess();
  if (s_cDataUpdate)
      Serial.print(" ");
      Serial.print(" ");
2.7.3 Program Outcome
Once you have uploaded the program to the Arduino, open the serial port monitor from the toolbar (as depicted in the figure below). Ensure that the baud rate is set to 115200. You will observe continuous printing of data from the IMU module. As you adjust the attitude of the IMU module, the displayed data will dynamically update.
