1. Infrared Obstacle Avoidance Sensor Manual
1.1 Infrared Obstacle Avoidance Sensor Description
1.1.1 Sensor Introduction
The infrared obstacle avoidance sensor is used for detecting obstacle ahead. It has an infrared transmitting tube and an infrared receiving tube. Once the sensor encounters an obstacle, the infrared light will be reflected back and received by the receiving tube. It is widely used for automatic obstacle avoidance in smart cars and robotics.
1.1.2 Working Principle
When the infrared receiving tube does not receive infrared light, the signal terminal OUT will output a high-level signal; when it receives infrared light, the signal terminal OUT will output a low-level signal.
During operation, you can determine whether there is an obstacle ahead by reading the status of the sensor’s OUT signal pin. In addition, the sensor is equipped with a miniature potentiometer, which can be rotated to adjust the detection range. If you adjust the potentiometer to the threshold between ON and OFF, the sensor will achieve its maximum detection distance.
1.2 Notice
Do not exceed the rated voltage range during use.
Do not use materials that transmit visible light or infrared light as test objects.
Avoid strong light exposure and do not block the light on the test object during use.
Do not operate the sensor in humid environments.
1.3 Specifications
For more information of this chip, you may refer to “Infrared obstacle avoidance sensor schematic”
1.3.1 Pin Instruction
| Pin | Instruction |
| 5V | Power Input |
| GND | Ground |
| OUT | When no obstacle is detected, the output remains HIGH (1).
When an obstacle is detected, the output switches to LOW (0). The Detection range is adjustable. |
| NC | None |
1.3.2 Specifications
| 1.Infrared Obstacle Avoidance Sensor | |
| Parameter | Specification |
| Working Voltage | DC 5V |
| Operating Current | 40mA |
| Detection Range | 2~ 25cm |
| LED1 Description | Lights up when an obstacle is detected. |
| Detection Range Adjustment Method | Adjustable via miniature potentiometer |
| Connector Type | 5264-4AW |
| Dimensions | 50mm×20mm |
| Modular installation, compatible with Lego series. | |
1.4 Project Outcome
Place an object in front of the infrared obstacle avoidance sensor. When no obstacle is detected, LED1 on the sensor will be OFF, and the serial monitor will display 1. When an obstacle is detected, LED1 will turn ON, and the serial monitor will display 0.
