2. Configuration and Usage in ROS
2.1 Virtual Machine Installation & Image Import
2.1.1 Installing VMware
A virtual machine allows you to run a different operating system within your current one. In this guide, we’ll use VMware Workstation as an example. Here’s how to get it set up:
(1) Go to the following path: 4.Appendix->Virtual Machine Image->VM Software and extract the installation package to your local computer.
(2) Open the extracted folder and double-click the executable file (with the .exe extension) to launch the installer.
(3) Simply follow the prompts or reference the provided images to complete the installation.
2.1.3 Virtual Machine Image Installation
(1) Locate the following folder in the same directory as this document: Appendix->Virtual Machine Image->ubuntu_ros1_melodic
If you need to import the Ubuntu 22.04 + ROS2 version, use this path instead: Appendix->Virtual Machine Image->ubuntu_ros2_humble
(2) Double-click the virtual machine installer executable (using the ROS1 version as an example).
(3) Enter a name for the virtual machine (you can define it yourself) and choose an installation path.
(4) Once the import is complete, click “Power on this virtual machine” to start using the installed image.
2.2 Depth Camera Configuration & Usage in ROS1
2.2.1 Preparation
Before getting started, please make sure VMware is installed and the ROS1 Melodic (Ubuntu 18.04) image has been imported and set up. You can refer to 2.1 Virtual Machine Installation & Image Import for detailed steps.
2.2.2 Importing the Depth Camera Package and Setting Up the Environment
Importing the Package
(1) Start the ROS1 virtual machine using VMware.
(2) Find the depth camera package file located in the same directory as this document: package->aurora930_ros1_x86_64.zip.
Creating a Workspace
(1) Click the terminal icon
on the left side of the system interface to open a new command-line terminal.
(2) In the terminal, enter the following command to create a new workspace and its src directory:
mkdir -p ~/ros_ws/src
Compiling the Package
(1) In the terminal, enter the following command to unzip the package into the src folder of your workspace:
unzip aurora930_ro1_x86_64.zip -d ~/ros_ws/src/
(2) Navigate to the workspace directory:
cd ~/ros_ws/
(3) Compile the package with the following command:
catkin_make -DSTREAM_SDK_TYPE=AURORA930
(4) After a successful build, open the bash environment configuration file:
gedit ~/.bashrc
(5) At the end of the file, add the following line to include the compiled workspace environment in your system’s bash session:
source /home/ubuntu/ros_ws/devel/setup.bash
(6) Press Ctrl + S to save the file, then close the text editor.
(7) Return to the terminal and reload the bash configuration to apply the changes:
Installing Udev Rules
Make sure your virtual machine is connected to the internet during this step.
(1) In the same terminal from the previous step, run the following command to navigate to the scripts directory:
cd ~/ros_ws/src/aurora930_ro1_x86_64/ext/deptrum-stream-aurora900-linux -x86_64-v1.1.4-16.04/scripts
(2) Run the following script to install the necessary environment dependencies for the depth camera:
sudo bash install_dependency.sh
(3) Then, execute the following command to write the udev rules into the system:
sudo bash setup_udev_rules.sh
(4) Once all the above steps are complete, you can close the terminal.
At this point, the environment setup and package import for the depth camera are successfully completed.
2.2.3 Start the Depth Camera
Connect the depth camera to the PC.
When you find the Aurora 930 device in the removable devices list, the connection is successful.
on the left side of the desktop to open a new terminal window, then run the following command to start the depth camera driver:
roslaunch deptrum-ros-driver-aurora930 driver_aurora930.launch
(2) Open another new terminal window following the same steps as above.
(3) In the new terminal, run the following command to launch RViz and view the depth camera’s image data:
roslaunch deptrum-ros-driver-aurora930 viewer_aurora930.launch
(4) Once the program starts, the interface should appear as shown in the illustration below.
(5) The IR (infrared) image and RGB image will also be displayed in the window.
(6) Click on depth in the interface to visualize the depth map.
(7) The center area of the interface shows the depth point cloud data.
2.3 Depth Camera Configuration & Usage in ROS2
2.3.1 Preparation
Before getting started, please make sure VMware is installed and the ROS2 humble (ubuntu22.04) image has been imported and set up. You can refer to 2.1 Virtual Machine Installation & Image Import for detailed steps.
2.3.2 Importing the Depth Camera Package and Setting Up the Environment
Copy the file deptrum-ros-driver-aurora930-x86_64.tar.gz from the package directory to the home directory inside the virtual machine.
mkdir -p deptrum_ws/src
(1) Extract the camera package to the deptrum_ws->src directory:
tar -xzvf deptrum-ros-driver-aurora930-x86_64-0.2.10-source.tar.gz -C ~/deptrum_ws/src/
(2) Install ROS 2 and the ament_cmake build tool:
sudo apt install ros-humble-ament-cmake
(3) Source the ROS 2 environment variables:
source /opt/ros/humble/setup.bash
(4) Navigate to the deptrum_ws workspace and build the package:
cd ~/deptrum_ws/ && colcon build --cmake-args -DSTREAM_SDK_TYPE=AURORA930
(5) After a successful build, open the .bashrc file to configure the environment:
gedit ~/.bashrc
Add the ROS 2 environment variables and the depth camera package setup to your .bashrc file to ensure the environment is automatically loaded in future terminal sessions.
source /home/ubuntu/deptrum_ws/install/local_setup.bash
(6) Press Ctrl + S to save the file, then close the editor.
(7) Return to the terminal and run the following command to reload the environment and verify that it’s been properly configured:
Installing Udev Rules and Connecting the Camera
(1) Run the script to add the udev rules for the camera. When prompted, enter the Ubuntu password:
sudo sh ~/deptrum_ws/src/deptrum-ros-driver/ext/deptrum-stream-aurora900-linux-x86_64-v1.1.19-18.04/scripts/setup_udev_rules.sh
(2) Plug in the Deptrum camera and verify that it is properly connected.
2.3.3 Start the Depth Camera
on the left side of the desktop to open a new terminal window, then launch the depth camera package with the following command:
ros2 launch deptrum-ros-driver-aurora930 aurora930_launch.py
(2) Open another terminal window to continue.
(3) Then, run the following command to visualize the depth camera output in RViz:
ros2 launch deptrum-ros-driver-aurora930 viewer930_launch.py
(4) The image in the left respectively indicates:
(5) The center of the interface displays the depth point cloud visualization.
