1. Knob Sensor Manual
1.1 Knob Sensor Description
1.1.1 Sensor Introduction
This knob sensor can be used with various modules to achieve different functions, such as controlling fan speed or adjusting light brightness. The sensor board features a user-friendly rotation arrow mark design.
1.1.2 Working Principle
The sensor consists of a simple potentiometer. By adjusting the knob, the resistance value is changed within a certain range, thereby changing the output voltage. When using the sensor: Connect the 5V and GND pins to a DC 5V power supply and the ADC pin outputs 0–5V voltage.
1.2 Notice
  1. Do not exceed the rated voltage range during use.
  2. Do not use materials that transmit visible light or infrared light as test objects.
  3. Avoid strong light exposure and do not block the light reaching the sensor during use.
  4. Do not operate the sensor in humid environments.
  5. Parameters such as sensitivity and trigger delay should be configured according to the specific application scenario. During testing, sensitivity can be adjusted to accommodate different light intensities and ensure stable sensor performance.
1.3 Specifications
For more information, you may refer to “Knob sensor schematic”
1.3.1 Pin Instruction
Pin Instruction
5V Power Input
GND Ground
ADC The sensor output pin outputs an analog level, and the analog level depends on the knob's angular position. For example, if the ADC has a 10-bit sampling accuracy and an Arduino UNO is used, the analog level range is 0-1023. At this point, if the knob is rotated clockwise, the output analog level increases accordingly.
NC None
1.3.2 Specifications
Light Sensor
Parameter Specification
Power Supply DC 5V
Operating Current 5mA
Indicator Light (PWR) Description The PWR LED lights up when powered.
Connector Type 5264-4AW
Product Dimensions 50mmx20mm
Modular installation, compatible with Lego series.
1.4 Project Outcome
Rotate the potentiometer on the sensor to see the data change on the monitor. Rotate the knob clockwise to increase the displayed value; rotate it counterclockwise to decrease the value.
