3. RosRobot Controller Program Analysis
3.1 RRC Program Architecture Analysis
3.1.1 Project Architecture Diagram
The project structure analysis diagram is a functional architecture diagram of the robot car. It outlines the main source code files that the robot car will use. As the original image is too long, it would take up a lot of space. You can refer to the “RRC Project Structure Diagram.png” file in the current folder for comparison. The contents of the files involved are located in the “Appendix” folder.
3.1.2 Architecture Analysis
The RRC program mainly consists of four main parts: Peripherals, Chassis, Porting, and System.
Next, each part will be explained.
Peripherals
Peripherals involves the software initialization and execution functions of the relevant components on the STM32 main control board, including:
Button (button.c): This file is used to implement hardware-independent button detection. The callback function for button presses is defined here. It enables implementing button detection functionality across different hardware platforms using the same code, requiring only a specific implementation for reading button states. It also supports various button events.
LED (led.c): This file contains hardware- and system-independent code for LED functionality. It defines parameters, functions, and tasks related to LED operation.
PWM Interface (pwm_servo.c): This file contains hardware-independent code for PWM servo control. It provides an interface to control PWM servos, allowing them to move to specific positions within specified time frames and enabling deviation correction.
Chassis
The Chassis folder contains implementations of kinematic algorithms for different types of chassis (velocity, acceleration, turning radius), including:
Differential Chassis (differential_chassis.c): Implementation of kinematic code for a differential drive chassis. The main functions to focus on are diff_chassis_move and set_velocity_radius.
Mecanum Chassis (mecanum_chassis.c): Implementation of kinematic code for a mecanum drive chassis. The main functions to focus on are mecanum_chassis_set_velocity, mecanum_chassis_set_xy, and set_velocity_radius.
Ackermann Chassis (ackermann_chassis.c): Implementation of kinematic code for an Ackermann drive chassis. The main functions to focus on are ackermann_velocity_difference, ackermann_chassis_move, and set_velocity_radius.
Porting
Porting involves the implementation functions for the interfaces of components on the STM32 main control board and related sensor accessories that can be mounted. When calling these functions later on, particular attention can be paid to the “hiwonder/Porting” folder.
LED (led_porting.c): Example and interface for controlling onboard LED lights. The main functions to focus on are:
leds_init: Used to initialize LED-related memory and variables.
led_set_pin: Used to set the state of the LED lights (on/off).
Button (button_porting.c): Example and interface for controlling onboard buttons. The main functions to focus on are:
buttons_init: Used to initialize button-related memory and variables.
button_timer_callback: This is a timer callback function used for periodically scanning the state of the buttons.
Buzzer (buzzer_porting.c): Example and interface for controlling the onboard buzzer. The main functions to focus on are:
buzzers_init: Used to initialize buzzer-related memory and variables.
buzzer1_set_pwm: Buzzer PWM setting interface used to set the PWM frequency of the buzzer.
Odometer (imu_porting.c): Interface file for MPU6050, retrieving the three-axis angular values of the IMU odometer. The main functions to focus on are:
imus_init: Used to initialize the IIC address of MPU6050 and related parameters.
imu_task_entry: IMU task entry function. In the loop, it waits for a semaphore, then updates the IMU data, retrieves acceleration and gyroscope data, and sends these data packets.
LCD Screen (lcd_porting.c): Interface file for the LCD screen. The main functions to focus on are:
lcds_init: Initialization function for the LCD screen. Used to initialize parameters such as screen dimensions, write frequency, and sleep frequency.
lcd1_spi_write: Writing content to the LCD screen.
Motor Driver (motor_porting.c): Used to drive the motors for rotation.
motors_init: Initialization function for the motors. Used to initialize parameters such as PID parameters and rotation speed limits.
set_motor_param: Writing PID parameters for the motors.
PWM (pwm_servo_porting.c): Used for controlling PWM servos.
pwm_servos_init: Initialization function for the PWM interface. This function initializes four PWM servo objects and configures a timer to generate PWM signals. Each servo object has a corresponding write function associated with it. These functions send PWM signals to the physical pins of the servo, thereby controlling its rotation.
pwm_servo1_write_pin: Control function for PWM servo 1.
SBUS Receiver Protocol (sbus_porting.c): Used for receiving the SBUS protocol.
sbus_init: Initializes SBUS-related memory and variables and starts SBUS reception.
sbus_dma_receive_event_callback: SBUS reception event callback function. Refer to the code comments for specific details.
Bluetooth (bluetooth_porting.c): Used for implementing the Bluetooth serial protocol transmission and reception interface.
bluetooth_task_entry: Bluetooth task entry function, executed using FreeRTOS. In the loop, it waits for the Bluetooth to send an idle semaphore, retrieves data from the Bluetooth data transmission queue, and sends data using DMA.
bluetooth_dma_rx_event_callback(UART_HandleTypeDef *huart, uint16_t length): Bluetooth reception event callback function.
bluetooth_dma_tx_complete_callback(UART_HandleTypeDef *huart): Callback function for Bluetooth DMA transmission completion.
Interface porting and memory space definition (lwmem_porting.c): Definition of memory space addresses.
Array of lwmem_region_t structures: Each structure defines a memory region. The first region starts at address 0x10000000 with a size of 64KB, used for RAM on the microcontroller. The second region is lwmem_ram, defined earlier, with a size of 38KB. The last item { NULL, 0 } serves as the end marker for the array.
Chassis Control Interface (chassis_porting.c): Used for controlling chassis movement. It defines objects for five different types of mobile chassis, provided for user selection. When using it, users can choose the appropriate chassis for control.
chassis_init: Initializes the chassis.
set_chassis_type: Selects the type of chassis.
u8g2 (u8g2_porting.c): Used for driving OLED screens with the u8g2 library. It serves as the OLED screen driver interface.
u8g2_init: Initializes the u8g2 object, registers relevant driver interfaces, and initializes the screen.
u8x8_gpio_and_delay: This function provides GPIO and delay operations for the u8g2 library.
u8x8_byte_hw_i2c: This function is a hardware-level interface of the u8g2 library used for implementing I2C communication with the OLED screen.
System
The “System” folder contains system files responsible for initiating various tasks and other component-related initializations. It is mainly divided into four parts: battery detection, gamepad buttons, lvgl interface data, and main application logic.
Battery Detection (battery_handle.c): Used for detecting battery voltage, calculating actual voltage, and sending low voltage alerts.
battery_check_timer_callback function: Key aspects include how to handle and report battery voltage, as well as how to respond to low voltage situations. This function covers several key functionalities: 1. Reading and filtering battery voltage. 2. Periodically sending battery voltage to GUI or Bluetooth. 3. Low battery alerts.
Gamepad Buttons (gamepad_handle.c): Used for receiving button messages from PS2 gamepads and sending message handles.
USBH_HID_EventCallback function: Callback function for handling gamepad detection events. It connects and controls the gamepad.
A_T_C(int8_t analog_x, int8_t analog_y) function: This function interprets the position of the analog joystick based on its x and y values. It handles and interprets USB HID events, translating analog joystick movements from the gamepad into specific character directions.
LVGL (gui_handle.c): Used for updating data, information, and display content in the LVGL interface.
update_sbus_view function: Displays SBUS protocol messages.
lvgl_timer_callback function: Callback function for LVGL events.
gui_task_entry function (compiled only when ENABLE_LVGL is true): The main loop waits for and processes events in the message queue. Depending on the event type, it can update battery voltage display or handle other LVGL tasks.
Main Application Logic (app.c): The startup file for the main application program.
This typically contains major task entry functions, tasks created in FreeRTOS, and message queue tasks. This program describes the main application logic of a robot, involving hardware initialization, configuration, and response to button events.
Note: Before making any modifications to the program, be sure to back up the original factory program. Avoid making direct modifications to the source code files to prevent any accidental parameter changes that may lead to robot malfunctions and become irreparable!!!
3.2 RRC LED and Buzzer Source Code Analysis
3.2.1 Program Logic
This chapter mainly focuses on controlling the LEDs on the STM32 main control board, including turning them on, off, and making them blink.
3.2.2 Hardware Connection
The hardware connection diagram is as below:
3.2.3 Program Download
The example for this section is ‘rosrobotcontrollerm4_LED_demo’.
For specific instructions on how to download the program, refer to the document: ‘2. STM32 Development Fundamentals/2.3 Project Compilation and Download’.
3.2.4 Program Outcome
Wait for 3 seconds for the LED to turn on, then another 3 seconds for it to turn off. Afterward, wait 3 seconds for the LED to start blinking (off for 200ms, on for 200ms). After blinking for 3 seconds, the LED will turn off.
3.2.5 State Machine Configuration
Use STM32CubeMX to check the information on software timers and state machines. In the ‘Pinout & Configuration’ section, go to ‘FreeRTOS’ and open ‘Timers and Semaphores’. You will find the details of ‘led_task_handler’ there.
The current application is in Hiwonder/Peripherals/led.c
3.2.6 Source Code Analysis
The source code for this course is located in the same folder as this tutorial document, mainly analyzing the files Hiwonder/System/app.c and Hiwonder/Peripherals/led.c.
LED Functionality Implementation
#include "cmsis_os2.h"
#include "led.h"
#include "lwmem_porting.h"
#include "global.h"
/* Hardware initialization declaration */
void leds_init(void); // LED
/* User entry function */
void app_task_entry(void *argument)
/* Declare external handles */
// LED control handle
extern osTimerId_t led_timerHandle;
leds_init(); // LED initialization
// Start LED timer
osTimerStart(led_timerHandle, LED_TASK_PERIOD);
osDelay(1000); // Delay for 1 second before turning on
led_on(leds[0]); // Turn on the LED
osDelay(3000); // Delay for 3 seconds before turning off
led_off(leds[0]); // Turn off the LED
osDelay(3000);
led_flash(leds[0],200,200,0); // LED blinking (off for 200ms, on for 200ms)
osDelay(3000);
// Loop: In an RTOS task loop, there must be osDelay or other system blocking functions; otherwise, it will cause system abnormalities
for(;;) {
printf("led_testing\r\n");
osDelay(1000);
Above is the App.c file, where app_task_entry() serves as the user’s entry function. The main programming flow is as follows:
An externally defined variable led_timerHandle is used as the timer handle.
The leds_init function is called to initialize the LEDs.
Then, the osTimerStart function is used to start the timer, passing LED_TASK_PERIOD as the timer’s working interval. This enables the LED control function to be called in the timer interrupt.
First, the LED timer is started, waiting for 3 seconds for the LED to turn on.
Then, waiting for another 3 seconds for the LED to turn off. Subsequently, waiting for 3 seconds to begin LED blinking (off for 200ms, on for 200ms).
After 3 seconds of LED blinking, the light goes off.
The program uses a timer to control the blinking of the LED, and delay functions are used to control the on/off time of the LED and the number of blinks.
Control LED On, Off and Blinking
int led_on(LEDObjectTypeDef *self)
LEDCtrlTypeDef ctrl_structure = {
.ticks_on = 1,
.ticks_off = 0,
.repeat = 0,
return self->put_ctrl_block(self, &ctrl_structure);
int led_off(LEDObjectTypeDef *self)
.ticks_on = 0,
.ticks_off = 0,
.repeat = 0,
int led_flash(LEDObjectTypeDef *self, uint32_t ticks_on, uint32_t ticks_off, uint32_t repeat)
.ticks_on = ticks_on,
.ticks_off = ticks_off,
.repeat = repeat,
void led_object_init(LEDObjectTypeDef *self)
self->stage = LED_STAGE_IDLE;
Above is the LED.c file, which constructs an LED object and provides three methods to control the LED:
The led_on() function is a structure for turning the LED on.
The led_off() function is a structure for turning the LED off.
The led_flash() function is a structure for making the LED blink.
The led_object_init(LEDObjectTypeDef *self) function initializes the LED object. In this function, the state of the state machine is set to LED_STAGE_IDLE.
3.4 RRC ADC Power Supply Voltage Detection
3.4.1 Program Description
This section primarily involves using the built-in ADC circuit in the STM32 main control board to read the battery voltage and output the voltage value via the serial port.
3.4.2 Hardware Connection
Connect the USB to serial port 1 and the other end to a PC. The hardware connection diagram is as follows:
3.4.3 Program Download
The example for this section is “rosrobotcontrollerm4_ADC_battery”. For specific download methods, refer to the document: “2. STM32 Development Fundamentals/2.3 Project Compilation and Download”.
3.4.4 Program Outcome
Open the serial assistant (located in “Appendix”), find the serial port connected to the development board (it may not necessarily be COM4, select based on actual conditions), and set it as follows:
Baud Rate: 115200
Data Bits: 8
Parity: None
Stop Bits: 1
Display Encoding Format: UTF-8
After opening the serial port, you will see continuously refreshed data, where the data following “battery” is the battery voltage.
3.4.5 Pin Configuration
Use the STM32CubeMX software to view pin information. During program operation, the ADC conversion function of the pin will be enabled. The corresponding chip pin is: PB0
3.4.6 Source Code Analysis
The source code for this course is located in the same folder as this tutorial document, mainly analyzing the Hiwonder/System/app.c and Hiwonder/System/battery_handle.c files.
Voltage Print Output
#include "cmsis_os2.h" #include "lwmem_porting.h" #include "global.h" #include "adc.h" /* User entry function */ void app_task_entry(void *argument) { // Declare external variables // This variable is a global variable defined in the battery_handle.c file, storing the battery voltage detected and converted by ADC extern float battery_volt; /* Global variable for battery voltage, unit: mV */ /* Declare external handles */ // Battery monitoring handle extern osTimerId_t battery_check_timerHandle; // Start the battery monitoring timer for real-time battery monitoring osTimerStart(battery_check_timerHandle, BATTERY_TASK_PERIOD); // Start ADC channel HAL_ADC_Start(&hadc1); // Create a buffer to store the string char msg[10] = ""; // Loop: In an RTOS task loop, there must be osDelay or other system blocking functions; otherwise, it will cause system abnormalities for(;;) { // Convert the floating-point number to a string before printing here // Because the microcontroller's processing of floating-point number printing is relatively limited // To ensure system robustness, convert it to a string first and then print sprintf(msg , "%3.3f" , battery_volt/1000); printf("battery: %s V\n",msg); // UART print output // Delay for 500ms osDelay(500); } }
The App.c file includes the user entry function app_task_entry(). The main programming flow is as follows:
Start the battery monitoring timer, which detects once every 50ms.
Then start the ADC conversion channel.
Finally, continuously print the battery voltage value.
The external variable battery_volt stores the measured battery voltage value. Therefore, by reading this value, you can obtain the voltage.
Reading Battery Voltage
void battery_check_timer_callback(void *argument) { if(adc_value[0] != 0 && adc_value[0] != 4095) { // Filter out invalid readings /* 1210.0 is the internal reference voltage value. With 100k + 10k resistor voltage division, the actual voltage is 11 times the measured voltage */ float volt = 1210.0f / ((float)adc_value[0]) * ((float)adc_value[1]) * 11.0f ; volt = volt > 20000 ? 0 : volt; // Check if it is consistent with the actual voltage (the actual battery voltage used by the car will not exceed 20V) battery_volt = battery_volt == 0 ? volt : battery_volt * 0.95f + volt * 0.05f; // Perform difference calibration } HAL_ADC_Start_DMA(&hadc1, (uint32_t*)adc_value, 2); // Start the next voltage detection }
The battery_handle.c file contains the battery_check_timer_callback() function, which is the callback function for the battery monitoring timer and is entered every 50ms to read the voltage value. The ADC value read will be stored in the adc_value array. The program flow is as follows:
First, check if adc_value[] is an error read value.
If the read value is correct, calculate and convert the value to a voltage value and store it in the global variable battery_volt.
If incorrect, do nothing.
Start a new ADC value reading.
The HAL_ADC_Start_DMA() function enables the DMA method for ADC reading:
HAL_StatusTypeDef HAL_ADC_Start_DMA ( ADC_HandleTypeDef* hadc,
uint32_t* pData , uint32_t Length )
Parameter 1: ADC handle
Parameter 2: Storage address of the ADC value
Parameter 3: Size of the ADC data
This function allows the ADC value to be automatically stored in the storage address without needing the CPU.
3.5 RRC QMI8658 Accelerometer and Gyroscope Source Code Analysis
3.5.1 Program Description
This chapter focuses on reading data from the built-in MPU6050 on the STM32 development board, calculating the current attitude of the board, and outputting the data via the serial port and displaying it on the OLED.
3.5.2 Hardware Connection
Connect the OLED display to the main control board via I2C expansion interface. The hardware connection diagram is as follows:
3.5.3 Program Download
The example for this section is “rosrobotcontrollerm4_IMU”.
3.5.4 Program Outcome
After downloading the program, press the RESET button to see the real-time attitude data of the development board displayed on the OLED screen.
After reset, the data displayed for the three axes is basically zero (with some minor errors), as shown below:
For forward and backward tilting, mainly the Roll data changes.
For left and right tilting, mainly the Pitch data changes.
For plane rotation, mainly the Yaw data changes.
3.5.5 Pin Configuration
View the pin information through stm32cubemx software. The MCU communicates with the IMU using I2C, and the IMU sends interrupt signals for the MCU to collect IMU data.
The corresponding I2C chip pins are PB10 and PB11; the interrupt pin is PB12.
3.5.6 Source Code Analysis
The source code for this section is located in the “Appendix” folder. The main program framework is designed as follows:
Analyze interrupts through the Application/User/Core/stm32f4xx_it.c file
Analyze the display task through the Hiwonder/System/app.c file
Analyze the IMU reading task through the Hiwonder/Porting/imu_porting.c file
The analysis is divided into three parts:
External interrupt handling
Loop reading task
Loop display task
External Interrupt
In the Application/User/Core/stm32f4xx_it.c file, the EXTI15_10_IRQHandler() function handles the external interrupt. Before IMU module provides a new set of data for host computer to read, it sends a signal (a voltage level change) through one of its INT pins to trigger the interrupt.
The main controller enables external interrupts on the pin connected to the IMU to detect voltage level changes, thereby monitoring the IMU data transmission status. When an external interrupt is triggered, it unblocks the flag indicating IMU data readiness (i.e., the semaphore IMU_data_readyHandle in the RTOS), as shown below:
* @brief This function handles EXTI line[15:10] interrupts.
void EXTI15_10_IRQHandler(void)
/* USER CODE BEGIN EXTI15_10_IRQn 0 */
extern osSemaphoreId_t IMU_data_readyHandle;
if(__HAL_GPIO_EXTI_GET_IT(IMU_ITR_Pin) != RESET) { // Check if it is the IMU interrupt pin signal
__HAL_GPIO_EXTI_CLEAR_IT(IMU_ITR_Pin); // Clear the IMU interrupt pin signal
// Release the semaphore
osSemaphoreRelease(IMU_data_readyHandle);
/* USER CODE END EXTI15_10_IRQn 0 */
/* USER CODE BEGIN EXTI15_10_IRQn 1 */
/* USER CODE END EXTI15_10_IRQn 1 */
IMU Reading Task
The reading task first calls begin() to initialize the IMU and its parameters. After that, it enters a loop to continuously wait for and read IMU data.
void imu_task_entry(void *argument)
// Declare external handles for IMU
extern osMutexId_t oled_mutexHandle;
// Declare array for storing attitude data
float rpy[3];
if(begin() == 0)
printf("qmi8658_init fail");
}else{
printf("qmi8658_init success");
osDelay(100);
PacketReportIMU_Raw_TypeDef report;
for(;;) {
// Wait for the semaphore sent by the IMU interrupt; if not received, block and wait indefinitely (osWaitForever)
osSemaphoreAcquire(IMU_data_readyHandle, osWaitForever);
// Get Euler angles
//GetEulerAngles(&rpy[0],&rpy[1],&rpy[2]);
//printf("%f,%f,%f\r\n",rpy[0],rpy[1],rpy[2]);
read_xyz(report.array.accel_array,report.array.gyro_array);
The osSemaphoreAcquire() function in the RTOS system acquires the semaphore:
Parameter 1: Semaphore handle (here, the IMU semaphore handle)
Parameter 2: Timeout duration (ms), with osWaitForever meaning to wait indefinitely.
If there is no semaphore in the queue, the function waits and executes other tasks. When a semaphore is available, it retrieves it and continues running the subsequent program.
The GetEulerAngles() function is called to read the IMU’s Euler angle data, which is then stored into the rpy array.
IMU Data Display Task
This task prints the data stored in the IMU object to the serial port and displays it on the OLED. The program flow is as follows:
Initialize the OLED;
Loop:
The real-time Euler angle data stored in the rpy array is displayed on the OLED screen and also printed to the serial port using printf.
Delay for 150ms;
//Initialize OLED and u8g2 library
u8g2_init();
//Define array to store attitude data
//Define a character array
static char msg[16];
//Set u8g2 font display
u8g2_SetFontMode(u8g2, 1);
u8g2_SetFontDirection(u8g2, 0);
u8g2_SetFont(u8g2, u8g2_font_victoriabold8_8r);
for(;;) {
//Clear OLED buffer
u8g2_ClearBuffer(u8g2);
//rpy[0] stores the data of Roll
//Convert float to string and store it in the msg array
sprintf(msg, "Pitch :%3.2f", FusionRadiansToDegrees(rpy[0]));
//Print the data via UART
printf("%s\r\n",msg);
//Write the data to the OLED buffer starting from position (0,9)
u8g2_DrawStr(u8g2, 0, 9, msg);
//rpy[1] stores the data of Pitch
sprintf(msg, "Roll :%3.2f", FusionRadiansToDegrees(rpy[1]));
//Write the data to the OLED buffer starting from position (0,20)
u8g2_DrawStr(u8g2, 0, 20, msg);
//rpy[2] stores the data of Yaw
sprintf(msg, "Yaw :%3.2f", FusionRadiansToDegrees(rpy[2]));
//Write the data to the OLED buffer starting from position (0,31)
u8g2_DrawStr(u8g2, 0, 31, msg);
//Send the data from OLED buffer to OLED module to refresh the screen
u8g2_SendBuffer(u8g2);
//Delay for 150 ms
osDelay(150);
As described above, in the “IMU reading task,” each time the semaphore changes, the real-time IMU data is immediately read and stored into the global rpy array. Therefore, in the current task, it is sufficient to continuously output the three elements of the rpy array (Euler angles) via the OLED display and serial port to represent the real-time attitude data.
Since refreshing the OLED screen takes time, a delay is required in each loop cycle to ensure proper display of the current data and smooth screen updates.
3.6 RRC PWM Servo Control Principle and Source Code Analysis
3.6.1 PWM Servo Description
A servo is a common motor drive device used to control the position, speed, and acceleration in a mechanical system. It typically consists of a motor, a control circuit, and a feedback system.
In terms of type, servos can be categorized into analog servos, PWM (pulse width modulation) servos, and bus servos. This section mainly focuses on PWM servos.
PWM servos use pulse width modulation signals to control the angular position of the servo. In simple terms, a PWM servo controls the angular position by varying the pulse width of the signal. The range of the pulse width determines the extreme angular positions of the servo, while the period of the control signal determines the refresh frequency of the signal. By adjusting the duration of the pulse width, precise control of the servo position can be achieved.
PWM achieves a level state between 0 and 1, meaning that when PWM is output, the voltage can be any value between 0 and 3.3V/5V.
When using PWM control, it is essential to know two parameters of the object being controlled:
Its PWM frequency (corresponding to the timer cycle)
Its operating pulse width (corresponding to the PWM duty cycle)
The control signal enters the signal modulation chip from the receiver channel to obtain a DC bias voltage. Inside, a reference circuit generates a reference signal with a period of 20ms and a width of 1.5ms. The obtained DC bias voltage is compared with the voltage of the potentiometer to produce a voltage difference output. Finally, the positive and negative outputs of the voltage difference are sent to the motor driver chip to determine the motor’s forward and reverse rotation. When the motor speed is constant, the potentiometer is driven to rotate through the cascade reduction gear, ensuring the voltage difference becomes zero, and the motor stops rotating.
3.6.2 Wiring Method:
Required Stuffs:
stm32 controller
LD-1501MG digital servo
Connection Instructions
The diagram below shows the reserved interfaces J1 and J2 provided by the STM32 main control board for the PWM servo.
The enlarged detail image below shows the reserved connection ports J1 and J2, highlighted in the red box. There are three types of connections: signal line (S), power supply (+5V), and ground (−), as indicated in the green box.
Connect the servo’s 3-pin cable to the corresponding J2 or J1 interface, as shown below:
The connection method is as follows:
White -> Signal line (S)
Red -> Power supply (+5V)
Black -> Ground (−)
Connect to J2
Connect to J1
The STM32 main control board can be powered by our 7.4V lithium battery pack. For detailed connection instructions, please refer to “3.6.7 Usage and Precautions of LiPo Batteries” in the current document path.
Attention: The servo motor must be connected according to the positions shown in the document diagram. Avoid connecting it incorrectly or mistakenly to prevent burning out the motor. Our company will not take any responsibility!!!
3.6.3 Program Burning
The sample program can be found in ‘3.6 RRC PWM Servo Control Example/rosrobotcontrollerm4_pwmServo’. For the steps and precautions required for programming burning, please refer to ‘2. STM32 Development Fundamentals/2.3 Project Compilation and Download’ document. Simply compile the ‘rosrobotcontrollerm4_pwmServo’ program located in the current document path to generate the hex file and proceed with the burning process.
3.6.4 Program Outcome
Based on the set PWM servo pulse width values, the servo rotates to the corresponding angles, as shown in the following diagram:
3.6.5 Code Analysis
Header File
File location: Hiwonder/Peripherals
Object PWMServoObjectTypeDef:
typedef struct PWMServoObject PWMServoObjectTypeDef;
Calling the PWM control object generated by the PWMServoObject structure.
PWMServoObject Structure:
* @brief PWM Servo Object Structure
struct PWMServoObject {
int id; /**< @brief Servo ID */
int offset; /**< @brief Servo Offset */
int target_duty; /**< @brief Target Pulse Width */
int current_duty; /**< @brief Current Pulse Width */
int duty_raw; /**< @brief Actual Pulse Width to be written into the timer, including offset, i.e., current_duty + offset */
/* Variables needed for speed control */
uint32_t duration; /**< @brief Time for the servo to move from current angle to specified angle, i.e., control speed, unit: ms */
float duty_inc; /**< @brief Pulse width increment for each position update */
int inc_times; /**< @brief Number of increments needed */
bool is_running; /**< @brief Whether the servo is in motion */
bool duty_changed; /**< @brief Whether the pulse width has been changed */
/* External provided, hardware abstraction interface */
void (*write_pin)(uint32_t new_state); /**< @brief IO Pin Level Setting */
This structure is used to configure PWM control objects.
Parameters:
offset: Servo offset
target_duty: Target pulse width
current_duty: Current pulse width
duty_raw: Raw pulse width, the width finally written into the timer
Duration: Time for the servo to move from the current angle to the specified angle, controlling the speed
duty_inc: Pulse width increment for each position update
inc_times: Number of increments needed
is_running: Whether the servo is in the process of rotation
duty_changed: Whether the pulse width has been changed
Function write_pin:
This function is used for setting the IO port level. After initialization, this function will be used to set the 0-3 PWM servos.
It has the parameter ‘new_state’ representing the current pin’s high or low level.
Declare function pwm_servo_object_init:
* @brief Initialize Servo Object
* @param object Pointer to the servo object to be initialized
* @retval None
void pwm_servo_object_init(PWMServoObjectTypeDef *object);
This function initializes the PWM servo object. Instantiation requires initializing the servo object pointer.
Declare function pwm_servo_duty_compare:
* @brief Servo Pulse Width Control
* @details Calculate pulse width change and the pulse width required for current speed to realize control, need to be called every 50ms
* @param self Pointer to the servo object to be controlled
* @retval None
void pwm_servo_duty_compare(PWMServoObjectTypeDef *self);
This function controls the PWM servo pulse width, calculates the pulse width change and the pulse width required for the current speed, and implements control. It needs to be called every 50ms and requires setting the servo object pointer for control.
Declare function pwm_servo_set_position:
* @brief Set Servo Angle
* @details Used to set the angle of the servo, actually just set a few internal variables of the servo object, the servo will not be controlled immediately. The actual servo control is calculated and controlled by pwm_servo_duty_compare
* @param duty New pulse width of the servo, an integer between 500~2500
* @param duration
* @retval None
void pwm_servo_set_position(PWMServoObjectTypeDef *self, uint32_t duty, uint32_t duration);
Set the angle of the PWM servo. Actually, it only sets several internal variables of the servo object and does not immediately control the servo. The actual servo control is calculated and controlled by pwm_servo_duty_compare.
Declare function pwm_servo_set_offset:
* @brief Set Servo Offset
* @param offset New servo offset
* @retval None
void pwm_servo_set_offset(PWMServoObjectTypeDef *self, int offset);
Set the offset of the PWM servo, requiring the servo object pointer for control.
Function pwm_servo_duty_compare:
void pwm_servo_object_init(PWMServoObjectTypeDef *obj)
memset(obj, 0, sizeof(PWMServoObjectTypeDef));
obj->current_duty = 1500; /* Default position */
obj->duty_raw = 1500; /* Default actual pulse width */
void pwm_servo_duty_compare(PWMServoObjectTypeDef *self) // Pulse Width Change Comparison and Speed Control
// Recalculate servo control parameters according to the newly set target
if(self->duty_changed) {
self->duty_changed = false;
self->inc_times = self->duration / 20; // Calculate the number of increments needed
if(self->target_duty > self->current_duty) { /* Calculate the total position change */
self->duty_inc = (float)(self->target_duty - self->current_duty);
} else {
self->duty_inc = (float)(self->current_duty - self->target_duty);
self->duty_inc /= (float)self->inc_times; /* Calculate position increment per control cycle */
self->is_running = true; // Servo starts to move
// Need to control the servo to move to reach the new position
if(self->is_running) {
--self->inc_times;
if(self->inc_times == 0) {
self->current_duty = self->target_duty; // For the last increment, directly assign the set value to the current value to ensure the final position is correct
self->is_running = false; // Reach the set position, servo stops moving
} else {
self->current_duty = self->target_duty + (int)(self->duty_inc * self->inc_times);
self->duty_raw = self->current_duty + self->offset; // Motion should include servo offset
This function is used for controlling pulse width change comparison and speed control.
Parameters: PWMServoObjectTypeDef instantiated object that needs to be controlled.
Firstly, it calculates the control parameters of the servo according to the newly set target. Then, it controls the servo to gradually rotate to the corresponding new position based on the newly set position. Finally, when the last increment occurs, the new position will be assigned to the current position, ensuring the final position is correct.
Function: pwm_servo_set_position:
duration = duration < 20 ? 20 : (duration > 30000 ? 30000 : duration); /* Limit the shortest/longest movement time */
duty = duty > 2500 ? 2500 : (duty < 500 ? 500 : duty); /* Limit the maximum/minimum pulse width */
self->target_duty = duty;
self->duration = duration;
self->duty_changed = true; /* Mark that the target position has changed, let pwm_servo_duty_compare calculate new motion parameters */
This function is used to set the rotation position of the servo.
Parameters: PWMServoObjectTypeDef instantiated object that needs to be controlled, rotation position (pulse width), required time.
Firstly, it is necessary to limit the duration of the movement as well as the maximum and minimum values of the pulse width. Then, assign the corresponding rotation position and time, as well as the switch to control the servo rotation, to the parameters corresponding to the instantiated PWMServoObjectTypeDef object.
Function pwm_servo_set_offset:
offset = offset < -100 ? -100 : (offset > 100 ? 100 : offset); /* Limit the minimum/maximum offset, different servos have different limits */
self->offset = offset;
This function is used to set the offset of the servo.
Parameters: PWMServoObjectTypeDef instantiated object that needs to be controlled, PWM servo offset.
Here, the magnitude limit of the offset will be set. When the servo rotates, this parameter will be used for adjustment.
Function pwm_servo_object_init:
This function is the initialization function for the PWM servo PWMServoObjectTypeDef instantiated object.
Firstly, new memory is allocated for initialization, and then the initial position of the PWM servo is set.
Initialization
File location: Hiwonder/Porting
Instantiation of PWM servo objects:
PWMServoObjectTypeDef *pwm_servos[4];
Instantiate objects of the PWMServoObjectTypeDef structure for PWM servos 1-4.
Setting servo:
static void pwm_servo1_write_pin(uint32_t new_state)
HAL_GPIO_WritePin(PWM_SERVO_1_GPIO_Port, PWM_SERVO_1_Pin, (GPIO_PinState)new_state);
static void pwm_servo2_write_pin(uint32_t new_state)
HAL_GPIO_WritePin(PWM_SERVO_2_GPIO_Port, PWM_SERVO_2_Pin, (GPIO_PinState)new_state);
static void pwm_servo3_write_pin(uint32_t new_state)
HAL_GPIO_WritePin(PWM_SERVO_3_GPIO_Port, PWM_SERVO_3_Pin, (GPIO_PinState)new_state);
static void pwm_servo4_write_pin(uint32_t new_state)
HAL_GPIO_WritePin(PWM_SERVO_4_GPIO_Port, PWM_SERVO_4_Pin, (GPIO_PinState)new_state);
Here, four functions are used to configure the interfaces of four PWM servos. They call HAL_GPIO_WritePin to set the port number, pin, and high or low level for each PWM servo.
Parameter: new_state represents the current pin’s high or low level.
PWM servo initialization:
void pwm_servos_init(void)
for(int i = 0; i < 4; ++i) {
pwm_servos[i] = LWMEM_CCM_MALLOC(sizeof(PWMServoObjectTypeDef));
pwm_servo_object_init(pwm_servos[i]); // Initialize memory for PWM servo objects
pwm_servos[0]->write_pin = pwm_servo1_write_pin;
pwm_servos[1]->write_pin = pwm_servo2_write_pin;
pwm_servos[2]->write_pin = pwm_servo3_write_pin;
pwm_servos[3]->write_pin = pwm_servo4_write_pin;
__HAL_TIM_SET_COUNTER(&htim13, 0);
__HAL_TIM_CLEAR_FLAG(&htim13, TIM_FLAG_UPDATE);
__HAL_TIM_CLEAR_FLAG(&htim13, TIM_FLAG_CC1);
__HAL_TIM_ENABLE_IT(&htim13, TIM_IT_UPDATE);
__HAL_TIM_ENABLE_IT(&htim13, TIM_IT_CC1);
__HAL_TIM_ENABLE(&htim13);
This function is used for initializing PWM servos.
Firstly, it initializes the memory of existing PWM objects and resets them to their initial positions.
Then, it assigns the function for setting servo levels to the write_pin function of the PWM servo object.
Finally, it sets up the timer.
3.6.6 LD-1501MG Digital Servo
Product Introduction
When use LD-1501MG Digital Servo, signal terminal sends a PWM signal with a period of 20ms. It controls servo angle by adjusting pulse width. The pulse width is available from 500 to 2500μs corresponding to angle from 0°to 180° .
This servo featuring high control accuracy, excellent linearity, fast respond and strong torque is usually applicable in joint design of various bionic robots.
Specification Instruction
1. Specification
| Working Voltage | DC 6-8.4V |
| No-load current | 100mA |
| Stall Current | 2.4~3A |
| Control Method | PWM |
| PWM Pulse Width Range | The pulse width from 500 to 2500μs corresponds to anglefrom 0 to180° |
| Pulse Period | 20ms |
| Rotate Speed | 0.16sec/60° (DC 7.4V) |
| Stall Torque | 13kg.cm (DC 6V) 15kg.cm (DC 6.5V)17kg.cm (DC 7.4V) |
| Rotate Range | 0~ 180° |
| Servo Accuracy | 0.3° |
| Servo Wire | 30cm |
| Gear Material | Metal Gear |
| Dimension | 54.38mm20.04mm45.5mm |
| Weight | 61g |
| Application | All kinds of bionic robot joints |
2. Servo Dimension Drawing
Unit:mm
3. Port Instruction
| PIN | PIN Instruction |
| White Wire | Signal Wire |
| Red Wire | Positive pole of power supply |
| Black Wire | Ground Wire |
Project
Using the sensor with UNO controller to help you get quick experience.
1. Preparation
1 UNO Controller *1
2 LD-1501MG Digital Servo *1
3 USB Cable *1
4 Male to Male Dupont line *3
2 .Wiring diagram
Take connecting servo to UNO controller with male-to-male Dupond line as example.
3. Project Process
Step 1: Download and install Ard uino IDE on your computer.
Step 2: Connect LD-1501MG digital servo to UNO board as the picture shown above.
Step 3: Connect UNO board to computer with USB cable. After opening Arduino IDE, please paste “**5. Example code”**in “File/New” .
Step 4: Select suitable demo board and port, then compile and upload the program.
4. Project Outcome
After the code is uploaded successfully, servo rotates within range from 0°to 180°.
5. Example Code
/*******LD-1501MG Digital Servo Testing Program*******
* Arduino Type:Arduino UNO
int servopin=8;
int pulsewidth;
int val;
void servo(int myangle)
pulsewidth=map(myangle,0, 180,500,2500);
digitalWrite(servopin,HIGH);
delayMicroseconds(pulsewidth);
digitalWrite(servopin,LOW);
delay(20-pulsewidth/1000);
void setup()
pinMode(servopin,OUTPUT);
void loop()
servo(0);
delay(1000);
servo(180);
delay(1000);
Q&A
Q1: Why servo failed to display after uploading?
A: Please check the wiring. Signal terminal of the servo need to be connected to D8 port of UNO controller.
Q2: How should we supply UNO controller power?
A: We connect black DC plug to a external power as well as supply UNO board and servo power. The power voltage of UNO controller ranges from DC 7 to 12V and the working voltage of UNO board ranges from DC 6 to 8.4V.
Therefore, the provided power voltage is required to meet two demands above so that the voltage should range from DC 7 to 8.4V.
Precautions
When connecting the battery leads, do not connect them directly to the lithium battery without connecting them to the control board! Avoid contact between positive and negative terminals to prevent short circuits!
When connecting the battery leads to the control board, ensure the red end connects to the positive terminal and the black end to the negative terminal, and do not reverse them!
The battery leads are designed to prevent reverse insertion. Do not force them into the battery to avoid damaging the interface.
Please use the charger provided with the lithium battery for charging.
When the charger is connected to the battery without connecting to the power source, the indicator light is green.
Store the battery in a cool, dry environment to prevent shortening its lifespan due to overheating or moisture.
Do not strike, throw, or step on the battery.
Avoid using the battery in environments with strong static electricity or magnetic fields, as this can damage the battery’s safety protection mechanism.
Do not use metal objects to connect the positive and negative terminals of the battery.
Do not plug the battery into a power outlet.
Battery Connection Method
Taking the example of powering with a 7.4V 3500mA battery:
Take out the power connection cable and the Hiwonder Car Controller.
Loosen the screw on the power interface of the controller.
After loosening, connect the red wire of the power connection cable to the ‘+’ terminal and the black wire to the ‘-’ terminal of the controller’s power interface (be extremely careful not to reverse the polarity, as it may damage the control board).
Once connected, tighten the screw securely.
Take out the 7.4V lithium battery.
Connect the power connection cable from the lithium battery to the controller’s power connection cable, ensuring a ‘red to red, black to black’ connection (here, a reverse-insertion prevention design is used, so do not force it; if it doesn’t fit, try rotating it to another side).
Charging Method
Connect the DC plug of the battery to the dedicated charger plug provided in the kit, as shown in the figure below:
Then, plug the charger into the socket. Users can check the indicator lights on the charger to understand the charging status. Red indicates charging, while green indicates charging is complete.
Note: Please unplug the battery charger in time to avoid overcharging.
3.7 Servo Motion Speed Control and Source Code Analysis
3.7.1 PWM Servo Description
3.7.2 Wiring Method:
Required Stuffs:
stm32 controller
Black -> Ground (−)
3.7.3 Program Download
The sample program is ‘rosrobotcontrollerm4_pwmServo_speed’.
After downloading the program (refer to ‘2. STM32 Development Fundamentals/2.3 Project Compilation and Download’ for details on how to download the program), you need to press the RESET button to reset the microcontroller, which will then start executing the new program.
3.7.4 Program Outcome
After pressing reset, the servo will first initialize to 90°, then move to 0°, and finally rotate to 180° at a speed of 60 degrees per second.
3.7.5 Source Code Analysis
This program is only for speed control. For detailed PWM servo control routines, please refer to ‘3.6 RRC PWM Servo Control Principle and Source Code Analysis’.
#define HOLDER_MIN 500
#define HOLDER_MAX 2500
void pwm_servos_init(void);
uint32_t time = 3000; // Movement time (ms)
pwm_servos_init(); // Initialize PWM servo controller
osDelay(500); // Wait for 0.5 seconds to ensure the servo controller is initialized
// The setting range of the servo corresponds to [500, 2500], which maps to [0°, 180°]
pwm_servo_set_position(pwm_servos[0], HOLDER_MIN, 500); // Set the initial position of the servo to 0° (HOLDER_MIN)
osDelay(500); // Wait for 0.5 seconds to ensure the servo has finished moving
// Set the target position of the servo to 180° (HOLDER_MAX) with a duration of time (ms); thus, the rotation speed is (180° - 0°) / time
pwm_servo_set_position(pwm_servos[0], HOLDER_MAX, time);
osDelay(time); // Delay for the duration of time to ensure the servo has finished moving
for(;;){
printf("PWM_servo_speed_test\r\n");
osDelay(1000); //!!! A delay is mandatory; otherwise, the RTOS system will malfunction !!!
The program is located in the app.c file under /Hiwonder/System.
The pwm_servo_set_position() function controls the rotation of the servo. The required parameters are defined as follows:
Parameter 1: Servo object
Parameter 2: Target angle of the servo
Parameter 3: Movement time
The rotation speed can be obtained by dividing the rotation angle by the movement time. The program logic is as follows:
①Initialize the servo
②Set the servo to a known initial angle
③Delay to allow the servo to complete the movement. The delay time must be greater than or equal to the movement time of the servo, otherwise, the servo cannot reach the target position.
④Move the servo to the target angle and specify the movement time.
⑤Delay to allow the servo to complete the movement.
The servo movement speed can be calculated by dividing the known angle difference by the movement time.
3.8 RRC Bus Servo Control and Source Code Analysis
3.8.1 Bus Servo ID Writing and Source Code Analysis
Servo Description
It is an automatic control system composed of a DC motor, reduction gears, a sensor, and control circuitry, which specifies the rotation angle of the output shaft by sending signals.
Differences between a servo and a motor:
A servo generally has a maximum rotation angle, while a DC motor rotates continuously. Therefore, a servo can only rotate within a certain angle and cannot rotate continuously like a DC motor. A regular DC motor cannot provide feedback on its rotation angle, whereas a servo can. (Digital servos can switch between servo mode and motor mode.)
Serial Bus Servo
A regular DC motor typically rotates continuously to provide power, while a servo is used to control the rotation of an object to a specific angle.
A bus servo is a derivative of a digital servo that communicates via an asynchronous serial bus, meaning it can be controlled by sending and receiving command packets, forming a closed-loop control system. Due to this feature, bus servos can be daisy-chained, making wiring simpler and reducing the use of serial ports. Because of this, when connecting bus servos, each servo’s ID must be set in advance, or they cannot be individually controlled.
Bus servos use high-precision potentiometers internally, and unlike PWM servos, they can provide feedback on position, temperature, voltage, and other information. Their accuracy and linearity are excellent, resulting in more stable robot operation and significantly extending the servo’s lifespan.
Additionally, before assembling the servo, it must be set to its midpoint position. The servo midpoint refers to its initial position, considered the “zero point” from which it rotates to positive and negative angles. Therefore, the servo must be adjusted to the midpoint before being installed onto the servo horn.
This is because, during rotation, the moving parts drive the potentiometer. The software assumes the midpoint as the “zero point”; otherwise, the potentiometer might enter a “blind spot,” causing the entire component to malfunction. Consequently, when using the robot, the specified angles may not be achieved, or the corresponding action sets may not match.
Procedure
We notice that the program defaults to setting the bus servo ID as 1, but this ID can be changed to other numbers.
We can change the ID number to 5.
After recompiling and burning the program, connect the servo debugging board to the computer’s serial port. Open the Bus Servo Terminal software
, select the communication port, for example, COM15, click on parameter settings, and upon reading, it will show the ID number as 5, indicating that the ID has been successfully set.
5ms ———- 180 degrees
Code Analysis
File locations: Hiwonder/app.c
/* Hardware Initialization */
serial_servo_set_id(0xFE, 1); //Set bus ID to 1
serial_servo_set_position(1, HOLDER_MIN, 1000); //When the bus servo ID is 1, the servo rotates to position 500, executing for 1 second
serial_servo_stop(1); //Program Stop
File locations: The function serial_servo_set_id() in Hiwonder/serial_servo.c is used to change the ID of a specific servo from old_id to new_id. The servo ID is sent to the servo via a serial data frame (defined by the array buf[]).
void serial_servo_set_id(uint8_t old_id, uint8_t new_id) {
uint8_t buf[7];
buf[0] = SERIAL_SERVO_FRAME_HEADER;
buf[1] = SERIAL_SERVO_FRAME_HEADER;
buf[2] = old_id;
buf[3] = 4;
buf[4] = SERIAL_SERVO_ID_WRITE;
buf[5] = new_id;
buf[6] = CheckSum(buf);
SerialWrite(buf, 7);
The function serial_servo_set_position() is used to set the position and duration of motion for the servo. Specific position and duration information is sent to the servo via a serial data frame (defined by the array buffer[]).
void serial_servo_set_position(uint8_t servo_id, uint16_t position, uint16_t duration)
if (servo_id > 31) { //Servo ID cannot exceed 31, can be modified according to the corresponding control board
return;
uint8_t buffer[10];
position = position > 1000 ? 1000 : position;
buffer[0] = SERIAL_SERVO_FRAME_HEADER;
buffer[1] = SERIAL_SERVO_FRAME_HEADER;
buffer[2] = servo_id;
buffer[3] = 7;
buffer[4] = SERIAL_SERVO_MOVE_TIME_WRITE;
buffer[5] = GET_LOW_BYTE(position);
buffer[6] = GET_HIGH_BYTE(position);
buffer[7] = GET_LOW_BYTE(duration);
buffer[8] = GET_HIGH_BYTE(duration);
buffer[9] = CheckSum(buffer);
SerialWrite(buffer, 10);
The serial_servo_stop() function is designed to send a command to stop the servo via the serial port.
Execution process:
(1) Define a buffer to store the sent data frame.
(2) Fill the content of the data frame: frame header, servo ID, data length, stop servo, checksum, and finally send the data frame via the serial port.
void serial_servo_stop(uint8_t servo_id) {
uint8_t buffer[10];
buffer[3] = 6;
buffer[4] = SERIAL_SERVO_MOVE_STOP;
buffer[5] = CheckSum(buffer);
SerialWrite(buffer, 6);
3.8.2 RRC Bus Servo Simple Rotation and Source Code Analysis
Servo Description
It’s an automatic control system consisting of a DC motor, reduction gear set, sensor, and control circuitry, which specifies the rotation angle of the output shaft by sending signals.
Servos generally have a maximum rotation angle; DC motors rotate in full circles. Therefore, servos can only rotate within a certain angle and cannot rotate continuously like DC motors. Regular DC motors cannot provide feedback on their rotation angle, while servos can. (Digital servos can switch between servo mode and motor mode.)
Serial Bus Servo
Regular DC motors typically rotate in full circles to provide power, while servos are used to control the rotation of an object to a specific angle.
Bus servos are derivatives of digital servos that communicate via an asynchronous serial bus, meaning control is achieved through the sending and receiving of instruction packets, representing a closed-loop control system. Due to this feature, bus servos can be daisy-chained, simplifying wiring and reducing serial port usage. Consequently, when connecting bus servos, it’s necessary to set the ID for each servo beforehand; otherwise, it would be impossible to differentiate between them during control.
Bus servos internally utilize high-precision potentiometers. Compared to PWM servo control, they not only have the ability to provide feedback on position, temperature, voltage, and other information, but also exhibit excellent accuracy and linearity. This makes robot operation more stable and significantly extends the lifespan of servos.
Additionally, before assembling servos, it’s essential to perform a midpoint operation. The midpoint of the servo refers to its initial position, which serves as the “zero point” for positive and negative angle rotations. Therefore, servos should be adjusted to the midpoint before installation onto servo horns.
This is because, during servo rotation, the moving parts drive the potentiometer. The software assumes the midpoint as the “zero point”; otherwise, the potentiometer might enter a “blind spot,” causing the entire component to malfunction. Consequently, when using the robot, the specified angles may not be achieved, or the corresponding action sets may not match.
Program Outcome
We rotated the servo counterclockwise by 90 degrees, then returned it to 0 degrees, and finally stopped the servo.
Code Analysis
File location: Hiwonder/app.c. This file implements the simple angle rotation of the servo and sets the position and duration of the servo’s movement.
/* User Entry Function */
serial_servo_set_position(1, HOLDER_MIN, 1000); //Move the servo to position 500, with a movement time of 1000 milliseconds
//serial_servo_set_position(3, HOLDER_MAX, 1000);//Move the servo to position 2500, with a movement time of 1000 milliseconds
osDelay(1000);
serial_servo_set_position(1, 0, 1000);
serial_servo_set_position(3, 0, 1000);
osDelay(1500);//The program stops after 1.5 seconds
// printf("Current servo ID is: %d\n", serial_servo_set_id);
serial_servo_stop(1);//
The function serial_servo_set_position() is used to set the position and duration of movement for the servo. Specific position and duration information is sent to the servo via a serial data frame (defined by the array buffer[]). The execution process of the function is as follows:
If the target position is greater than 1000, it is set to 1000.
Fill the content of the data frame: frame header, servo ID, buffer[3] setting data length, set the position and movement duration of the servo.
Store the low byte and high byte of the target position in buffer[5] and buffer[6], and store the low byte and high byte of the movement duration in buffer[7] and buffer[8]. Calculate the checksum, and finally send the data frame via the serial port.
void serial_servo_set_position(uint8_t servo_id, uint16_t position, uint16_t duration) { if (servo_id > 31) { //Servo ID cannot exceed 31, can be modified according to the corresponding control board return; } uint8_t buffer[10]; position = position > 1000 ? 1000 : position; buffer[0] = SERIAL_SERVO_FRAME_HEADER; buffer[1] = SERIAL_SERVO_FRAME_HEADER; buffer[2] = servo_id; buffer[3] = 7; buffer[4] = SERIAL_SERVO_MOVE_TIME_WRITE; buffer[5] = GET_LOW_BYTE(position); buffer[6] = GET_HIGH_BYTE(position); buffer[7] = GET_LOW_BYTE(duration); buffer[8] = GET_HIGH_BYTE(duration); buffer[9] = CheckSum(buffer); SerialWrite(buffer, 10); }
The serial_servo_stop() function is designed to send a command to stop the servo via the serial port. The execution process is as follows:
Fill the content of the data frame: frame header, servo ID, data length, stop the servo, calculate the checksum, and finally send the data frame via the serial port.
void serial_servo_stop(uint8_t servo_id) { uint8_t buffer[10]; buffer[0] = SERIAL_SERVO_FRAME_HEADER; buffer[1] = SERIAL_SERVO_FRAME_HEADER; buffer[2] = servo_id; buffer[3] = 6; buffer[4] = SERIAL_SERVO_MOVE_STOP; buffer[5] = CheckSum(buffer); SerialWrite(buffer, 6); }
3.8.3 Hiwonder Bus Servo Communication Protocol
Summary
Using asynchronous serial bus communication method, theoretically, up to 253 robot servos can be connected into chain through the bus, you can unify control them through the UART asynchronous serial interfaces. Each servo can be set to a different node address, multiple servos can be unified or controlled independently. Communicating with the user’s host computer software(controller or PC) through the asynchronous serial interface, you can set its parameters, function control. Sending instructions to servo through the asynchronous serial interface, the servo can be set to the motor control mode or position control mode. In the motor control mode, servo can be used as a DC reduction motor with adjustable speed; In the position control mode, servo has 0-240 degrees of rotation range with Plus ± 30 ° deviation adjustable range, in this range with precise position control performance, speed adjustable.
Half-duplex UART asynchronous serial interface which conforms to the protocol can communicate with the servo and control servo in different ways.
UART Interface schematic diagram
Servo uses the program code to perform the timing control to the UART asynchronous serial interface, realizes the half-work asynchronous serial bus communication, the communication baud rate is 115200bps, and the interface is simple, the protocol is simplified. In your own designed controller, the UART interface for communication with the servo must be handled as shown below.
Command Packet
Command packet format Table 1:
| Header | ID number | Data Length | Command | Parameter | Checksum |
| 0x55 0x55 | ID | Length | Cmd | Prm 1... Prm N | Checksum |
Header: Two consecutive 0x55 are received indicating the arrival of data packets.
ID:Each servo has an ID number. ID number ranges from 0 ~ 253, converted to hexadecimal 0x00 ~ 0xFD.
Broadcast ID: ID No. 254 (0xFE) is the broadcast ID. If the ID number issued by the controller is 254 (0xFE), all servos will receive instructions, but they all do not return the response message, (except for reading the servo ID number, Please refer to the following instructions for detailed instructions) to prevent bus conflict.
Length(data): Equal to the length of the data that is to be sent (including its own one byte). That is, the length of the data plus 3 is equal to the length of this command packet, from the header to the checksum.
Command: Control the various instructions of servo, such as position, speed control.
Parameter: In addition to commands, parameter are control informations that need to add.
Checksum: The calculation method is as follows:
Checksum=~(ID+ Length+Cmd+ Prm1+…PrmN)If the numbers in the brackets are calculated and exceeded 255,Then take the lowest one byte, “~” means Negation.
Command type
There are two kinds of commands, write command and read command. Write command: normally, it followed by parameters, write the parameters of the corresponding function into the servo to complete a certain action.
Read command: normally, it will not followed by parameters, when the servo received “read command”, it will return the corresponding data immediately , the returned command value with parameters is the same as the “read command” value that sent to the servo. So the PC software must immediately prepare to change itself to “read condition” after it sends the reading command.
The following table is command that the PC software send to servos.
| Command name | Command value | Length |
| SERVO_MOVE_TIME_WRITE | 1 | 7 |
| SERVO_MOVE_TIME_READ | 2 | 3 |
| SERVO_MOVE_TIME_WAIT_WRITE | 7 | 7 |
| SERVO_MOVE_TIME_WAIT_READ | 8 | 3 |
| SERVO_MOVE_START | 11 | 3 |
| SERVO_MOVE_STOP | 12 | 3 |
| SERVO_ID_WRITE | 13 | 4 |
| SERVO_ID_READ | 14 | 3 |
| SERVO_ANGLE_OFFSET_ADJUST | 17 | 4 |
| SERVO_ANGLE_OFFSET_WRITE | 18 | 3 |
| SERVO_ANGLE_OFFSET_READ | 19 | 3 |
| SERVO_ANGLE_LIMIT_WRITE | 20 | 7 |
| SERVO_ANGLE_LIMIT_READ | 21 | 3 |
| SERVO_VIN_LIMIT_WRITE | 22 | 7 |
| SERVO_VIN_LIMIT_READ | 23 | 3 |
| SERVO_TEMP_MAX_LIMIT_WRITE | 24 | 4 |
| SERVO_TEMP_MAX_LIMIT_READ | 25 | 3 |
| SERVO_TEMP_READ | 26 | 3 |
| SERVO_VIN_READ | 27 | 3 |
| SERVO_POS_READ | 28 | 3 |
| SERVO_OR_MOTOR_MODE_WRITE | 29 | 7 |
| SERVO_OR_MOTOR_MODE_READ | 30 | 3 |
| SERVO_LOAD_OR_UNLOAD_WRITE | 31 | 4 |
| SERVO_LOAD_OR_UNLOAD_READ | 32 | 3 |
| SERVO_LED_CTRL_WRITE | 33 | 4 |
| SERVO_LED_CTRL_READ | 34 | 3 |
| SERVO_LED_ERROR_WRITE | 35 | 4 |
| SERVO_LED_ERROR_READ | 36 | 3 |
Command name:Just for easy identification, the user can also set according to their own habits. Command name suffix “_WRITE” which represents write command, and the suffix “_READ” represents read command.
Command value: That is, the command Cmd in command packet of Table 1
Length: that is the length(data length) in table 1
1. Command name: SERVO_MOVE_TIME_WRITE Command value:1 Length: 7
Parameter 1: lower 8 bits of angle value
Parameter 2: higher 8 bits of angle value.range 0~1000. corresponding to the servo angle of 0 ~ 240 ° , that means the minimum angle of the servo can be varied is 0.24 degree.
Parameter 3: lower 8 bits of time value
Parameter 4: higher 8 bits of time value. the range of time is 0~30000ms.
When the command is sent to servo, the servo will be rotated from current angle to parameter angle at uniform speed within parameter time. After the command reaches servo, servo will rotate immediately.
2. Command name: SERVO_MOVE_TIME_READ Command value: 2 Length: 3
Read the angle and time value which sent by SERVO_MOVE_TIME_WRITE t o the servo
For the details of the command packet that the servo returns to host computer, please refer to the description of Table 4 below.
3. Command name: SERVO_MOVE_TIME_WAIT_WRITE Command value: 7 Length : 7
Parameter1: lower 8 bits of preset angle
Parameter2: higher 8 bits of preset angle. range 0~1000. corresponding to the servo angle of 0 ~ 240 ° . that means the minimum angle of the servo can be varied is 0.24 degree.
Parameter3: lower 8 bits of preset time
Parameter3: higher 8 bits of preset time. the range of time is 0~30000ms.
The function of this command is similar to this
“SERVO_MOVE_TIME_WRITE” command in the first point. But the difference is that the servo will not immediately turn when the command arrives at the servo,the servo will be rotated from current angle to parameter angle at unifor m speed within parameter time until the command name SERVO_MOVE_ST ART sent to servo(command value of 11), then the servo will be rotated from current angle to setting angle at uniform speed within setting time.
4. Command name: SERVO_MOVE_TIME_WAIT_READ Command value: 8 Length: 3
Read the preset angle and preset time value which sent by SERVO_MOVE_TIME_WAIT_WRITE to the servo.
For the details of the command packet that the servo returns to host computer, please refer to the description of Table 3 below.
5. Command name: SERVO_MOVE_START Command value: 11 Length: 3
With the use of command SERVO_MOVE_TIME_WAIT_WRITE, described in point 3.
6. Command name: SERVO_MOVE_STOP Command value: 12 Length: 3
When the command arrives at the servo, it will stop running immediately if the servo is rotating, and stop at the current angle position.
7. Command name: SERVO_ID_WRITE Command value: 13 Length: 4
Parameter 1: The servo ID, range 0 ~ 253, defaults to 1. The command will re-write the ID value to the servo and save it even when power-down.
8. Command name: SERVO_ID_READ Command value: 14 Length: 3
Read servo ID, For the details of the command package that the servo returns to host computer,please refer to the description of Table 4 below.
9. Command name: SERVO_ANGLE_OFFSET_ADJUST Command value: 17 Length: 4
Parameter 1: servo deviation, range -125~ 125, The corresponding angle of -30 ° ~ 30 ° , when this command reach to the servo, the servo will immediately rotate to adjust the deviation.
Note 1:The adjusted deviation value is not saved when power-down by this command, if you want to save please refer to point 10.
Note 2: Because the parameter is “signed char” type of data, and the command packets to be sent are “unsigned char” type of data, so before sending, parameters are forcibly converted to “unsigned char” data and then put them in command packet.
10. Command name: SERVO_ANGLE_OFFSET_WRITE Command value: 18 Length: 3
Save the deviation value, and support “power-down save” . The adjustment of the deviation is stated in point 9
11. Command name: SERVO_ANGLE_OFFSET_READ Command value: 9 Length: 7
Read the deviation value set by the servo,
12. Command name: SERVO_ANGLE_LIMIT_WRITE Command value: 20 Length: 7
Parameter 1: lower 8 bits of minimum angle
Parameter 2: higher 8 bits of minimum angle, range 0~1000
Parameter 3: lower 8 bits of maximum angle
Parameter 4: higher 8 bits of maximum angle, range 0~1000
And the minimum angle value should always be less than the maximum angle value. The command is sent to the servo, and the rotation angle of the servo will be limited between the minimum and maximum angle. And the angle limit value supports ‘power-down save’ .
13. Command name: SERVO_ANGLE_LIMIT_READ Command value: 21 Length: 3
Read the angle limit value of the servo, for the details of the instruction packet that the servo returns to host computer, please refer to the description of Table 4 below.
14. Command name: SERVO_VIN_LIMIT_WRITE Command value: 22 Length: 7
Parameter 1: lower 8 bits of minimum input voltage
Parameter 2: higher 8 bits of minimum input voltage, range 4500~12000mv
Parameter 3: lower 8 bits of maximum input voltage
Parameter 4: higher 8 bits of maximum input voltage, range 4500~12000mv And the minimum input voltage should always be less than the maximum input voltage. The command is sent to the servo, and the input voltage of the servo will be limited between the minimum and the maximum. If the servo is out of range, the led will flash and alarm (if an LED alarm is set). In order to protect the servo, the motor will be in the unloaded power situation, and the servo will not output torque and the input limited voltage value supports for power-down save.
15. Command name: SERVO_VIN_LIMIT_READ Command value: 23 Length: 3
16. Command name: SERVO_TEMP_MAX_LIMIT_WRITE Command value: 24 Length: 4
Parameter 1: The maximum temperature limit inside the servo range
50~100°C, the default value is 85°C, if the internal temperature of the servo exceeds this value the led will flash and alarm (if an LED alarm is set). In order to protect the servo, the motor will be in the unloaded power situation, and the servo will not output torque until the temperature below this value of the servo, then it will once again enter the working state.and this value supports for power-down save.
17. Command name: SERVO_TEMP_MAX_LIMIT_READ Command value: 25 Length: 3
Read the maximum temperature limit value inside the servo, for the details of the command package that the servo returns to host computer, please refer to the description of Table 4 below.
18. Command name: SERVO_TEMP_READ Command value: 26 Length: 3
Read the Real-time temperature inside the servo, for the details of the instruction packet that the servo returns to host computer, please refer to the description of Table 4 below.
19. Command name: SERVO_VIN_READ Command value: 27 Length: 3
Read the current input voltage inside the servo, for the details of the instruction packet that the servo returns to host computer, please refer to the description of Table 4 below.
20. Command name: SERVO_POS_READ Command value: 28 Length: 3
Read the current angle value of the servo, for the details of the instruction packet that the servo returns to host computer, please refer to the description of Table 4 below.
21. Command name: SERVO_OR_MOTOR_MODE_WRITE Command value: 29 Length: 7
Parameter 1: Servo mode, range 0 or 1, 0 for position control mode, 1 for motor control mode, default 0,
Parameter 2: null value
Parameter 3: lower 8 bits of rotation speed value
Parameter 4: higher 8 bits of rotation speed value. range -1000~1000,
Only in the motor control mode is valid, control the motor speed, the value of the negative value represents the reverse, positive value represents the forward rotation. Write mode and speed do not support power-down save.
Note: Since the rotation speed is the “signed short int” type of data, it is forced to convert the data to “unsigned short int “type of data before sending the command packet.
22. Command name: SERVO_OR_MOTOR_MODE_READ Command value: 30 Length: 3
Read the relative values of the servo, for the details of the command package that the servo returns to host computer, please refer to the description of Table 4 below.
23. Command name: SERVO_LOAD_OR_UNLOAD_WRITE Command value: 31 Length: 4
Parameter 1: Whether the internal motor of the servo is unloaded power-down or not, the range 0 or 1, 0 represents the unloading power down, and the servo has no torque output. 1 represents the loaded motor, then the servo has a torque output, the default value is 0.
24. Command name: SERVO_LOAD_OR_UNLOAD_READ Command value: 32 Length: 3
Read the state of the internal motor of the servo. for the details of the command package that the servo returns to host computer, please refer to the description of Table 4 below.
25. Command name: SERVO_LED_CTRL_WRITE Command value: 33 Length: 4
Parameter 1: LED light/off state, the range 0 or 1, 0 represents that the LED is always on. 1 represents the LED off, the default 0, and support power-down save.
26. Command name: SERVO_LED_CTRL_READ Command value: 34 Length3
Read the state of the LED light. For the details of the command packet that the servo returns to host computer, please refer to the description of Table 4 below.
27. Command name: SERVO_LED_ERROR_WRITE Command value: 35 Length: 4
Parameter 1: what faults will cause LED flashing alarm value, range 0~7
There are three types of faults that cause the LED to flash and alarm, regardless of whether the LED is in or off. The first fault is that internal temperature of the servo exceeds the maximum temperature limit (this value is set at point 16). The second fault is that the servo input voltage exceeds the limit value (this value is set at 14 points). The third one is when locked-rotor occurred.
This value corresponds to the fault alarm relationship as shown below:
| 0 | No alarm |
| 1 | Over temperature |
| 2 | Over voltage |
| 3 | Over temperature and over voltage |
| 4 | Locked-rotor |
| 5 | Over temperature and stalled |
| 6 | Over voltage and stalled |
| 7 | Over temperature , over voltage and stalled |
28. Command name: SERVO_LED_ERROR_READ command value: 36 Length: 3
Read the servo fault alarm value. For the details of the command packet that the servo returns to host computer, please refer to the description of Table 4 below.
Table4
| Command name | Command value | length |
| SERVO_MOVE_TIME_READ | 2 | 7 |
| SERVO_MOVE_TIME_WAIT_READ | 8 | 7 |
| SERVO_ID_READ | 14 | 4 |
| SERVO_ANGLE_OFFSET_READ | 19 | 4 |
| SERVO_ANGLE_LIMIT_READ | 21 | 7 |
| SERVO_VIN_LIMIT_READ | 23 | 7 |
| SERVO_TEMP_MAX_LIMIT_READ | 25 | 4 |
| SERVO_TEMP_READ | 26 | 4 |
| SERVO_VIN_READ | 27 | 5 |
| SERVO_POS_READ | 28 | 5 |
| SERVO_OR_MOTOR_MODE_READ | 30 | 7 |
| SERVO_LOAD_OR_UNLOAD_READ | 32 | 4 |
| SERVO_LED_CTRL_READ | 34 | 4 |
| SERVO_LED_ERROR_READ | 36 | 4 |
Table 4 is the command that servo return to the host computer, these commands will only return when host computer send a read command to servo, what’s more, the returned command value is consistent with the read command that the host computer sent to servo. the difference is that the returned value has parameters. The format of the returned data command packet is the same as the command package that the host computer sent to servo, as in Table 1.
1.Command name: SERVO_MOVE_TIME_READ Command value: 2Length: 7
Parameter 2: higher 8 bits of angle, range 0~1000
Parameter 4: higher 8 bits of time value, range 0~30000ms
2. Command name: SERVO_MOVE_TIME_READ Command value: 8 Length: 7
Parameter 1: lower 8 bits of preset angle value
Parameter 2: higher 8 bits of preset angle, range 0~1000
Parameter 3: lower 8 bits of preset time value
Parameter 4: higher 8 bits of preset time value, range 0~30000ms
3. Command name: SERVO_ID_READ Command value: 14 Length: 4
Parameter 1: servo ID value, default value is 1
Description: ID read is a little bit special compared with other read commands , if the command packet ID is broadcast ID:254 (0xFE), the servo will return the response information, and other read commands will not return the response message when ID is broadcast ID. The purpose of this design is to inquiry the servo ID number via broadcast ID without knowing the ID number of the servo, but the limit is that the bus can only access a servo, or it will return data caused bus conflict.
4. Command name: SERVO_ANGLE_OFFSET_READ Command value: 19 Length: 4
Parameter 1: The deviation set by the servo, range-125~125, default value is 0
5. Command name: SERVO_ANGLE_LIMIT_READ Command value: 21 Length: 7
Parameter 1: lower 8 bits of minimum angle value
Parameter 3: lower 8 bits of maximum angle value
Parameter 4: higher 8 bits of maximum angle value, range 0~1000,The default value is 0, the maximum angle is 1000
6. Command name: SERVO_VIN_LIMIT_READ Command value: 23 Length: 7
Parameter 1: lower 8 bits of input voltage value
Parameter 2: higher 8 bits of input voltage value ,range 6500~10000mv
Parameter 3: lower 8 bits of maximum input voltage value
Parameter 4: higher 8 bits of maximum input voltage value,range
6500~12000mv,The default value is 6500v, the maximum voltage is 12000
7. Command name: SERVO_TEMP_MAX_LIMIT_READ Command value: 25 Length: 4
Parameter 1: The maximum temperature limit inside the servo, range 50~100°C, default value is 85°C
8. Command name: SERVO_TEMP_READ Command value: 26 Length: 4
Parameter 1: The current temperature inside the servo, no default value
9. Command name: SERVO_VIN_READ Command value: 27 Length: 5
Parameter 1: lower 8 bits of current input voltage value
Parameter 2: higher 8 bits of current input voltage value, no default
10. Command name SERVO_POS_READ Command value: 28 Length: 5
Parameter 1: lower 8 bits of current servo position value
Parameter 2: higher 8 bits of current servo position value, no default
Description: Returned the angular position value need to be converted to the “signed short int” type of data, because the read angle may be negative
11. Command name: SERVO_OR_MOTOR_MODE_READ Command value:30 Length: 7
Parameter 1: The current mode of the servo, 0 for the position control mode, 1 for the motor control mode, the default 0
Parameter 2: Null, set to 0
Parameter 4: higher 8 bits of rotation speed value ,range-1000~1000,Only valid in the motor control mode , control the motor speed, the negative value represents the reverse, positive value represents the forward.
12. Command name: SERVO_LOAD_OR_UNLOAD_READ Command value:32 Length: 4
Parameter 1: Whether the internal motor of the servo is unloaded power-down or not, range 0 or 1, 0 represents the unloading power down, and now servo has no torque output. 1 represents the loaded motor, then the servo has a torque output, the default value of 0.
13. Command name: SERVO_LED_CTRL_READ Command value: 34 Length: 4
Parameter 1: LED light /off state, the range 0 or 1, 0 represents that the LED is always on. 1 represents LED is always off, the default 0.
14. Command name: SERVO_LED_ERROR_READ Command value: 36 Length: 4
Parameter 1: What faults in the servo cause LED flash and alarm, range 0~7. The corresponding relation between the numerical value and the fault is shown in table 3.
3.9 RRC Brushed DC Motor Program Analysis
3.9.1 Preface
The DC motors available in the market are mainly divided into two types: brushless motors and brushed motors. This chapter focuses on explaining brushed DC motors.
Brushed Motors:
In brushed DC motors, current flows through the armature coil, generating a magnetic field that interacts with the magnetic field of the permanent magnet, causing the motor to rotate. The following diagram illustrates the working model of a brushed DC motor.
Components: Permanent magnet, armature coil, brushes, bearings. Speed control principle: By changing the voltage of the power supply, the force on the rotor coil will also change, thereby changing the motor speed.
Commutation principle: Changing the direction of current in the coil can achieve motor commutation.
Brushless Motors:
Working principle: The stator of a brushless DC motor is a coil winding armature, and the rotor is a permanent magnet. The real-time position of the motor rotor is detected, and then different phase currents are applied to the motor according to the rotor position, so that the stator generates a uniformly changing rotational magnetic field, allowing the motor to follow the magnetic field and rotate.
In the previous section, we learned about the principle of brushed DC motors. In this chapter, we will learn about the source code of brushed DC motors. To do this, we need to prepare STM32CubeIDE or Keil5, and a brushed DC motor.
3.9.2 Program Storage Path
The example routine for this particular content is named “Motor_Demo”:
Program path: Motor_Demo\motor_porting.c
STM32CubeMX path: Motor_Demo\Motor_Demo.ioc
3.9.3 Configure the Timer
In STM32CubeIDE, open the STM32CubeMX Configurator. In the Peripherals section, locate TIM1 and enable it. Then, in the Configuration tab, set TIM1 for PWM Generation CH3 and CH4. This will be used for generating PWM signals.
Next, in the STM32CubeMX Configurator, go to TIM1 Configuration. In the PWM Generation Channel 3 and PWM Generation Channel 4 sections, set the appropriate PWM frequency and duty cycle. Click OK to save the settings.
Click on Project > Generate Code to generate the initialization code.
3.9.4 Clock configuration
3.9.5 Program Source Code Analysis
Program Structure Diagram
Initialize Motor Timer
void motor_init(void) { /* Motor control */ __HAL_TIM_SET_COUNTER(&htim1, 0); /* Clear timer counter */ __HAL_TIM_ENABLE(&htim1); /* Start PWM signal generation timer */ __HAL_TIM_MOE_ENABLE(&htim1); /* Enable PWM signal output */ }
Reset the counter of the TIM1 timer using the __HAL_TIM_SET_COUNTER() function.
Start the TIM1 timer counting using the __HAL_TIM_ENABLE() function.
Enable the Main Output Enable (MOE) of the TIM1 timer to enable PWM signal output using the __HAL_TIM_MOE_ENABLE() function.
Control Motor Speed and Direction
void motor1_set_pulse(int speed) { if(speed > 0) { /* Forward rotation */ __HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_3, 0); __HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_4, speed); } else if(speed < 0) { /* Reverse rotation */ __HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_4, 0); __HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_3, -speed); } else { /* Stop */ __HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_3, 0); __HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_4, 0); } HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_3); HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_4); }
The function motor1_set_pulse() controls a DC motor by adjusting the duty cycle of the PWM signal, thereby controlling the motor’s rotation speed and direction.
If the value of ‘speed’ is greater than 0, the motor will rotate forward. The function sets the duty cycle of TIM_CHANNEL_3 to 0 and sets the duty cycle of TIM_CHANNEL_4 to ‘speed’.
If the value of ‘speed’ is less than 0, the motor will rotate backward. The function sets the duty cycle of TIM_CHANNEL_4 to 0 and sets the duty cycle of TIM_CHANNEL_3 to the absolute value of ‘speed’.
If the value of ‘speed’ is equal to 0, the motor will stop. The function sets the duty cycle of both TIM_CHANNEL_3 and TIM_CHANNEL_4 to 0.
Finally, the function starts the generation of PWM signals on TIM_CHANNEL_3 and TIM_CHANNEL_4.
Call in the Main Function
while (1) {
printf("counter:%lld, speed:%0.3fr/s\r\n", motor1.counter, motor1.rps);
HAL_Delay(100);
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
Within the while loop in the main function, there is a call to the motor1 motor structure object declaration. Here, motor1.rps and motor1.counter respectively represent the number of revolutions per second of the motor and the current count value obtained by the motor’s counter.
* @brief Encoder Motor Object Structure
struct EncoderMotorObject {
int64_t counter; /**< @brief Total count value, 64-bit is considered not to overflow */
int64_t overflow_num; /**< @brief Overflow count */
int32_t ticks_overflow; /**< @brief Count overflow value */
float tps; /**< @brief Ticks per second, counter frequency */
float rps; /**< @brief Revolutions per second, output shaft speed in revolutions per second */
int32_t ticks_per_circle; /**< @brief Number of counts generated per revolution of the motor output shaft, fill in according to the actual motor situation */
The following is the structure definition for the encoder motor object. You can refer to the comments for detailed information.
3.10 RRC DC Brushed Motor AB Quadrature Encoder Principles and Source Code Analysis
3.10.1 Preface
DC gear motor is a high-torque, high-load motor available in 8V and 12V variants, equipped with an encoder. This chapter focuses on controlling the operation of the JGA27-310 DC gear motor (referred to as the 310 motor) using an STM32 main control board.
Principle of AB quadrature encoder:
The rotary quadrature encoder is a digital IC (integrated circuit), so it uses binary code. Square waves indicate digital signals in high (1) and low (0) states.
The operation of the encoder under 5V (using 5V as an example) power supply is illustrated in the above diagram, where the lines show low 0V (ground) and high 5V states.
Velocity determination: The number of pulses per revolution of the disk depends on the number of marks on its surface. This principle is the basic definition of encoder resolution. Therefore, two output signals represent the number of pulses in a specific time period. Using these values, the control system can determine angular velocity, distance, and acceleration.
Direction determination:
Two pins are placed sequentially. Thus, when simultaneously viewing the two waveform lines, you will notice a slight offset. Output channels A and B are specifically positioned on the disk at a certain distance, causing them to have a 90-degree phase offset on the waveform. The cycle is also divided into 4 equal parts.
If the encoder moves forward (clockwise), line A is at the highest point (1), and channel B is at the lowest point (0). This results in combinations like 1 and 0, followed by 11, 00, and so on.
Starting from the same point in different directions (counterclockwise), you will see that this line will first be at the highest point (11), followed by combinations like 01, 00, and so on.
3.10.2 Hardware Connection
Required materials: 7.4V lithium battery pack, STM32 main control board, 310 motor.
The hardware connection diagram is as shown below:
Wiring method: Connect the 7.4V lithium battery and the DC power line of the STM32 main control board, then connect the 310 motor to the corresponding motor interface of the STM32 main control board according to the diagram.
3.10.3 Program Download
The example routine for this content is named “EncoderMotor_PID_Demo”:
Specific instructions for program download can be found in “2. STM32 Development Fundamentals / 2.3 Project Compilation and Download” of the document. Simply replace the hex file mentioned in the document with the hex file generated from this example routine (EncoderMotor_PID_Demo.hex) for downloading.
3.10.4 Program Outcome
After powering on the STM32 control board, the motor rotates slowly for a period of time, then rotates quickly for another period of time, cycling repeatedly between these two operating states.
3.10.5 PIN Configuration
Using STM32CubeMX software to view pin information, during program execution, the external interrupt function will enable TIM5 timer loading. According to the diagram below, the corresponding chip pins are: PA0 and PA1.
3.10.6 Source Code Analysis
The program source code for this course is located in the “Encoder_Demo” folder. The program framework is designed based on the functionality as shown in the diagram below, with the main analysis conducted in the main.c file.
The program is divided into three parts: timer initialization, motor initialization, and motor speed acquisition.
By initializing the timer and motor, and acquiring the motor speed, the program verifies whether the AB phase control direction of the motor is correctly connected.
Initialize Timer
In the main function of the main.c file, three timers are initialized as shown in the diagram below: timers 1, 5, and 6 are configured with parameters. You can also refer to the tim.c file for details. These three timers have been configured through the interface in the STM32CubeMX software (it is recommended to use STM32CubeMX software for a more intuitive view).
Timer 1
Timer 5
Timer 6
Motor Initialization
Before controlling the motor operation, it is necessary to initialize the relevant parameters of the motor in the main function located in the main.c file.
* @brief Motor initialization
* @details Initialize motor-related memory and timers
* @retval None.
encoder_motor_object_init(&motor1); /* Initialize structure */
motor1.ticks_overflow = 60000;
motor1.set_pulse = motor1_set_pulse;
* Replace with the macro definition of the corresponding motor model parameters here.
* Model parameters are in the encoder_motor.h file
motor1.rps_limit = MOTOR_JGB520_RPS_LIMIT;
motor1.ticks_per_circle = MOTOR_JGB520_TICKS_PER_CIRCLE; /* Set the total number of pulses generated per revolution of the motor, used to calculate the rotation speed converted to revolutions per second */
motor1.pid_controller.kp = MOTOR_JGB520_PID_KP;
motor1.pid_controller.ki = MOTOR_JGB520_PID_KI;
motor1.pid_controller.kd = MOTOR_JGB520_PID_KD;
/* Motor control */
/* Encoder */
__HAL_TIM_SET_COUNTER(&htim5, 0); /* Clear timer counter */
__HAL_TIM_CLEAR_IT(&htim5, TIM_IT_UPDATE); /* Clear update interrupt flag */
__HAL_TIM_SET_AUTORELOAD(&htim5, motor1.ticks_overflow); /* Set count overflow value, which can be set via CubeMX */
__HAL_TIM_ENABLE_IT(&htim5, TIM_IT_UPDATE); /* Enable update interrupt for count overflow calculation */
__HAL_TIM_ENABLE(&htim5); /* Start timer */
HAL_TIM_Encoder_Start(&htim5, TIM_CHANNEL_ALL); /* Start timer encoder mode */
/* Timer */
/* Need to calculate encoder values every 10ms to get speed */
__HAL_TIM_SET_PRESCALER(&htim6, 83); /* TIM6 is connected to APB1, clock is 84MHz, 84 division == 1MHz */
__HAL_TIM_SET_AUTORELOAD(&htim6, 10000); /* 1MHz == 1us/cycle, 10000us == 10ms, generate an update interrupt every 10ms */
__HAL_TIM_SET_COUNTER(&htim6, 0); /* Clear count */
__HAL_TIM_CLEAR_IT(&htim6, TIM_IT_UPDATE); /* Clear update interrupt */
__HAL_TIM_ENABLE_IT(&htim6, TIM_IT_UPDATE); /* Enable update interrupt */
__HAL_TIM_ENABLE(&htim6); /* Start timer */
From the above diagram, it can be observed that:
The initialized structure (encoder_motor_object_init):
The parameters of motor1’s structure are shown in the diagram, and the specific parameter contents can be referred to in the annotations. In the entire program, the parameter to pay attention to is rps, which is used to calculate the motor speed obtained.
* @brief Encoder motor object structure
struct EncoderMotorObject{
int64_t counter; /**< @brief Total count value, 64-bit (considered non-overflow) */
float tps; /**< @brief ticks per second (counter frequency) */
float rps; /**< @brief revolutions per second (output shaft speed, revolutions per second) */
int current_pulse; /**< @brief Current output PWM value, signed to correspond to forward/reverse rotation */
PID_ControllerTypeDef pid_controller; /**< @brief PID controller */
/** Porting (portable hardware interface) **/
int32_t ticks_per_circle; /**< @brief Number of counts generated per rotation of the motor output shaft, filled in according to the actual motor conditions */
Using Timer 1 to generate PWM signals, as shown in the diagram below:
/* Motor control */
Using TIM5 to control the encoder of the encoder motor for acquisition and startup, as shown below:
/* Encoder */
__HAL_TIM_SET_AUTORELOAD(&htim5, motor1.ticks_overflow); /* Set count overflow value; can be set via CubeMX */
Using TIM6 to calculate the encoder value once to obtain the speed, as shown below:
/* Timer */
/* Need to calculate encoder values every 10ms to obtain speed */
__HAL_TIM_SET_PRESCALER(&htim6, 83); /* TIM6 is connected to APB1, clock is 84MHz, 84 prescaler == 1MHz */
Speed Obtaining
Using a while loop to obtain the motor speed and print it via serial port:
while (1) {
printf("counter:%11d, speed:%0.3f r/s\r\n", motor1.counter, motor1.rps);
HAL_Delay(100);
From the above diagram, it can be seen that the motor speed can be obtained through the motor.rps parameter. By printing the current motor rotation speed via serial port, it is possible to verify the accuracy of the motor’s AB phase data. To ensure that the motor speed is not lost due to being too fast, a 100-millisecond delay is implemented using the HAL_Delay function.
Note: The main focus of the source code analysis is on the key structure of the DC motor drive program. This helps users quickly understand the structure and content of the code. Users can refer to the code and corresponding comments for detailed learning and reference.
3.11 RRC DC Brushed Motor PID Control and Source Code Analysis
3.11.1 Preface
This chapter mainly focuses on PID algorithm control of DC geared motors via the STM32 main control board. Through hardware connections and program downloads, the written code is burnt onto the STM32 main control board via a data connection cable to control the motor’s movement. The final section analyzes the source code of the PID control algorithm.
3.11.2 Hardware Connection
The encoder motor is connected close to the USB-HOST port, with a RESET button nearby. The Type-C interface below is for serial port logging, connecting to the computer end to observe the printed data. The physical connection diagram is as follows:
3.11.3 Program Download
The example routine for this section is called ‘EncoderMotor_PID_Demo’.
After downloading the program (specific downloading instructions can be found in “2. STM32 Development Fundamentals/2.3 Project Compilation and Download”), press the RESET button to reset the microcontroller for the new program to start executing.
3.11.4 Program Outcome
After powering on the STM32 control board, the motor runs in both slow and fast states. When viewed from top to bottom, the motor rotates counterclockwise, first at a speed of 1 r/s (rotations per second) for 10 seconds, then at a speed of 0.5 r/s for another 10 seconds, repeating this cycle.
Open the serial assistant (located in “Appendix”), find the serial port connected to the development board (may not necessarily be COM4, choose the appropriate COM based on actual connection), and configure it as shown below:
Baud Rate = 115200;
Data Bits = 8;
Parity = None;
Stop Bits = 1;
Display Encoding = UTF-8.
Then, you can open the serial port.
The middle box in the figure displays the data received by the microcontroller through the serial port. The data after ‘set’ indicates the set speed (r/s), while the data after ‘actual’ represents the motor’s current speed calculated by the encoder. You may observe a slight deviation between the actual and preset speeds, which is normal.
3.11.5 PIN Info Configuration
From the circuit schematic, it can be determined that PE13 and PE14 are used as the motor drive pins for Motor1, while PA0 and PA1 are used as the encoder pins for Motor1. The schematic is as follows:
3.11.6 Source Code Analysis
The source code for this lesson is located in the same folder as this tutorial document, mainly for analysis of the following files:
Application/User/Core/main.c,
Hiwonder/motor_porting.c, and
Hiwonder/encoder_motor.c.
PID Principle
The encoder is a sensor used to measure the position of a motor. Its principle involves detecting changes in the sensor’s magnetic field during motor rotation to determine the motor’s position. As the motor rotates, the encoder outputs a binary code representing the current motor position.
PID control is a commonly used closed-loop control algorithm for controlling the speed or position of a motor. The PID controller consists of three parts:
Proportional (P): The proportional part controls the output based on the difference between the motor position and the target position.
Integral (I): The integral part adjusts the output based on the cumulative difference in position.
Derivative (D): The derivative part adjusts the output based on the rate of change in position.
In motor PID control, the encoder is used to measure the actual motor position. The PID controller calculates based on the difference between the target position and the actual position, and outputs a control signal to control the motor’s movement. The PID controller can adjust the control signal based on changes in the actual position to better control the motor’s movement.
For more information on PID principles, refer to “3. RosRobot Controller Program Analysis/3.11 RRC DC Brushed Motor PID Control and Source Code Analysis/PID Basic Learning.”
Code Analysis
In the main.c file located in the Application/User/Core folder, the main() function serves as the entry point of the project.
1. Basic Configuration Initialization
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_USART1_UART_Init();
MX_TIM1_Init();
MX_TIM5_Init();
MX_TIM6_Init();
/* Initialize interrupts */
MX_NVIC_Init();
/* USER CODE BEGIN 2 */
The diagram illustrates the initialization process including system clock initialization (SystemClock_Config), GPIO initialization (MX_GPIO_Init), UART initialization (MX_USART_UART_Init), timer 1, 5, and 6 initialization (MX_TIM1_Init, MX_TIM5_Init, MX_TIM6_Init), and interrupt initialization (MX_NVIC_Init). To delve into specific details, you can select the corresponding function and press ‘F12’ to enter the function body and review the comments provided.
2. Motor Initialization
/* Motor Initialization!!! Note: The motor parameters in this function need to be replaced with the corresponding motor parameters!!! */
motor_init();
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1) {
encoder_motor_set_speed(&motor1, 1.0); /* Set target speed to 1.0 */
for(int i = 0; i < 100; ++i) {
printf("set:%0.3f, actual:%0.3f r/s\r\n", motor1.pid_controller.set_point, motor1.rps);
HAL_Delay(100);
encoder_motor_set_speed(&motor1, 0.5); /* Set target speed to 0.5 */
HAL_Delay(100);
/* USER CODE END 3 */
The diagram above shows the motor initialization function, which is located in the motor_porting.c file in the Hiwonder folder. The specific function is as depicted in the following diagram:
encoder_motor_object_init(&motor1); /* Initialize the structure */
motor1.rps_limit = MOTOR_DEFAULT_RPS_LIMIT;
motor1.ticks_per_circle = MOTOR_DEFAULT_TICKS_PER_CIRCLE; /* Set the total number of pulses generated per motor revolution, used to calculate the speed conversion to revolutions per second */
motor1.pid_controller.kp = MOTOR_DEFAULT_PID_KP;
motor1.pid_controller.ki = MOTOR_DEFAULT_PID_KI;
motor1.pid_controller.kd = MOTOR_DEFAULT_PID_KD;
Initialize the motor structure, then set the parameters corresponding to the motor structure (here, parameters need to be set according to the motor model; simply find the corresponding motor parameters in the encoder_motor.h file and replace the parameters here).
/* Encoder */
HAL_TIM_SET_COUNTER(&htim5, 0); /* Clear timer count */
HAL_TIM_SET_AUTORELOAD(&htim5, motor1.ticks_overflow); /* Reset the count overflow value, can be set via CubeMX */
/* Timer */
/* Need to calculate encoder value every 10ms to get speed */
HAL_TIM_SET_PRESCALER(&htim6, 83); /* TIM6 is connected to APB1, clock is 84MHz, 84 division = 1MHz */
HAL_TIM_SET_AUTORELOAD(&htim6, 10000); /* 1MHz --> 1us/cycle, 10000us == 10ms, generate an update interrupt every 10ms */
HAL_TIM_SET_COUNTER(&htim6, 0); /* Clear counter */
Start the motor control timer TIM1, set and start the encoder timer TIM5, then configure and start the speed calculation timer TIM6.
3. Motor Loop Control
Within the loop{
Set the motor speed to 1.0 r/s;
Loop 10 times, printing data each time, with a delay of 100ms between iterations;
Set the motor speed to 0.5 r/s;
The specific program is as below:
motor_init();
/* Infinite loop */
while (1) {
HAL_Delay(100);
HAL_Delay(100);
The printed data: the data after ‘set’ represents the set speed (r/s), while the data after ‘actual’ represents the current motor speed calculated by the encoder.
4. Timer
The function of Timer 6 is to calculate motor speed and update PID parameters. It generates an update interrupt every 10ms. The update interrupt function is as follows (located in the motor_porting.c file in the Hiwonder folder):
* @brief Timer 6 interrupt handler function
* @retval None.
void TIM6_DAC_IRQHandler(void)
if(__HAL_TIM_GET_FLAG(&htim6, TIM_FLAG_UPDATE) != RESET) { /* Timer update interrupt */
__HAL_TIM_CLEAR_FLAG(&htim6, TIM_FLAG_UPDATE); /* Clear update interrupt flag */
encoder_update(&motor1, 0.01, __HAL_TIM_GET_COUNTER(&htim5)); /* Update and calculate motor speed */
encoder_motor_control(&motor1, 0.01); /* Update PID speed control */
encoder_update() is the function responsible for calculating the updated motor speed based on the encoder count. Its specific implementation is as follows (located in the encoder_motor.c file in the Hiwonder folder):
* @brief Encoder motor speed measurement update
* @details
* @param self Pointer to the encoder motor object
* @param period Time interval from the last update to the current update (update period), unit: sec
* @param counter Current count value of the encoder
* @retval None.
void encoder_update(EncoderMotorObjectTypeDef *self, float period, int64_t counter)
counter = counter + self->overflow_num * self->ticks_overflow; /* Total count value; 60000 is based on the actually set timer overflow value */
int delta_count = counter - self->counter;
self->counter = counter; /* Store the new count value */
self->tps = (float)delta_count / period * 0.9f + self->tps * 0.1f; /* Calculate pulse frequency */
self->rps = self->tps / self->ticks_per_circle; /* Calculate rotation speed, unit: rps (revolutions per second) */
encoder_motor_control() is the function for updating the encoder motor speed control. It first updates the PID parameters, corrects the output PWM, and generates a new PWM signal. Its specific implementation is as follows (located in the encoder_motor.c file in the Hiwonder folder)
* @brief Encoder motor speed control task
* @details Encoder motor speed PID control task, which needs to be scheduled periodically to complete PID control updates
* @retval None.
void encoder_motor_control(EncoderMotorObjectTypeDef *self, float period)
float pulse = 0;
pid_controller_update(&self->pid_controller, self->rps, period); /* Update the PID controller */
pulse = self->current_pulse + self->pid_controller.output; /* Calculate the new PWM value */
/* Limit the output PWM value; the limit is determined by the timer settings. In this example, the timer's duty cycle of 0-100 corresponds to 0-1000 */
pulse = pulse > 1000 ? 1000 : pulse;
pulse = pulse < -1000 ? -1000 : pulse;
/* Set the new PWM value and limit the minimum PWM value; if the PWM is too small, the motor will only hum without moving */
self->set_pulse(self, pulse > -250 && pulse < 250 ? 0 : pulse);
self->current_pulse = pulse; /* Record the new PWM value */
The PID_controller_update function, pid_controller_update(), is the core of PID control, specifically speed PID control.
It first calculates the error ‘err’, then calculates the proportional, integral, and derivative values based on time. Next, it calculates the correction value for the output, and finally updates the error parameters.
The specific code implementation is shown in the diagram below.
void pid_controller_update(PID_ControllerTypeDef *self, float actual, float time_delta) {
float err = self->set_point - actual;
float proportion = err - self->previous_0_err;
float integral = err * time_delta;
float derivative = (err - 2 * self->previous_1_err + self->previous_0_err) / time_delta;
self->output = (self->kp * err) + (self->ki * integral) + (self->kd * derivative);
self->previous_1_err = self->previous_0_err;
self->previous_0_err = err;
In this context:
- ‘err’ represents the error between the current target value and the actual value.
- ‘proportion’ is the difference between the current error and the previous error, used for calculating the derivative.
- ‘integral’ accumulates the time without friction, used in combination with the derivative for calculation.
- ‘derivative’ represents the derivative parameter.
- Finally, the function stores the result in the ‘output’ field of the PID_ControllerTypeDef structure.”
3.12 RRC PS2 Controller USB Receiver Signal Processing Explanation and Source Code Analysis
3.12.1 PS2 Controller USB Receiver Signal Processing Principles
In the previous course “Wireless Controller Usage,” you should have learned the basic operation of the controller. In this lesson, we will learn about the working process of the PS2 controller, the principle of how the USB receiver receives the controller signal, and the working process of the STM32.
Program Flow
The flow process of the PS2 controller sending information to the USB receiver, and then the USB receiver sending the data to the STM32 for processing:
The PS2 controller sends commands wirelessly to the USB receiver.
The USB receiver’s job is to receive the controller’s commands.
The USB receiver first needs to establish a connection with the PS2 controller. Once connected, it transmits the received commands from the PS2 controller to the STM32.
The STM32 decodes the received information and executes corresponding operations based on the decoded information (e.g., making a car move forward). The car will then perform this operation.
Source Code Path
The source code for this section is located at “Appendix/Programs/PS2 Controller Signal Processing” under “Hiwonder/System” in “gampad_handle.c” and “app.c”. You can also use Keil5 (refer to previous content for installation details) to open the project file. This can be found under “Appendix/Programs/PS2 Controller Signal Processing” in the “MDK-ARM” section on the left side of “Hiwonder/System”.
Working Principle Analysis
1. PS2 Controller Command Sending Process
The controller sends information via DI, DO (data lines): When you operate the controller, such as pressing a button, the button information is encoded into an electrical signal and sent out through the data lines.
2. Working Process of USB Receiver and STM32
The USB receiver transmits the electrical signal received from the controller over differential signals on a pair of data lines (D+ and D-), then sends it to the STM32 for decoding.
STM32 Decoding Operation: The STM32 reads the electrical signal on the data lines and converts these electrical signals into binary data. The STM32 decodes this data into specific commands based on the PS2 protocol rules, such as “press the X button”. Then, it executes the corresponding operation, such as “move the car forward when the X button is pressed.”
3. Knowledge Expansion
PS2 Protocol:
Data Format: Data is sent in bytes (8 bits). Each byte includes a start bit (low level), 8 data bits (sent from the least significant bit first), a parity bit, and a stop bit (high level).
Clock and Data Lines: The controller generates the clock signal and reads or writes data on the data line. The clock signal frequency is usually 250kHz, so the data transmission rate is 250kbps.
Handshake Process: Before each data exchange, the host and controller perform a handshake. The host first sends a command byte to the controller, and the controller responds with one or more data bytes.
Commands and Data: Common commands include request status (0x01) and read data (0x42). The controller’s response data includes button status and analog joystick values.
USB Protocol:
USB is a universal serial bus standard used for device connection, communication, and power supply. In the USB protocol, data is serially transmitted over a pair of data lines (D+ and D-) using differential signals. Here are the basic principles of USB data reception:
Data Encapsulation and Serial Transmission: The sending device encapsulates the data into a series of packets and sends these packets serially over the D+ and D- lines. The data packet format includes synchronization sequences, data payload, checksum, etc.
Differential Reception: The receiving device receives data by measuring the voltage difference between the D+ and D- lines. The USB interface has strong resistance to power noise and external interference due to the use of differential signals.
Packet Parsing and Checksum: The receiving device reassembles the received serial data into packets, then parses and checks them. If the packet checksum does not match the data payload, the receiving device can request the sending device to resend the data packet.
3.12.2 PS2 Controller USB Receiver Reception and Processing Source Code Analysis
Preface
In the previous lesson, we learned about the analysis of the principles behind the reception and processing of PS2 controller USB receivers. In this lesson, we will continue from where we left off and conduct a source code analysis based on the principles covered in the previous session.
The source code implemented in this section is located in the ‘3.12 RRC PS2 Controller USB Receiver Reception and Processing Routine/ rosrobotcontrollerm4_motor_ps2’ of Hiwonder/System’s ‘gampad_handle.c’ and ‘usbh_hid_gamepad.h’. To open the project files, use Keil5 (for specific installation instructions, please refer to the previous content).
Define the Relevant Structures for USB HID Gamepad
1. HID_GAMEPAsD_Info_TypeDef Structure
typedef struct {
uint16_t buttons;
uint8_t hat;
int8_t lx;
int8_t ly;
int8_t rx;
int8_t ry;
} HID_GAMEPAD_Info_TypeDef;
Defined a set of buttons, a switch, as well as the X and Y coordinates of the left and right joysticks.
2. SBH_HID_GamepadInit and USBH_HID_GetGamepadInfo Function
USBH_StatusTypeDef USBH_HID_GamepadInit(USBH_HandleTypeDef *phost);
HID_GAMEPAD_Info_TypeDef USBH_HID_GetGamepadInfo(USBH_HandleTypeDef *phost);
USBH_HID_GamepadInit is used to initialize data related to the gamepad.
USBH_HID_GetGamepadInfo is used to retrieve information about the gamepad.
3. Defined Masks Representing Each Button on the Gamepad
#define GAMEPAD_BUTTON_MASK_L2 0x0001u
#define GAMEPAD_BUTTON_MASK_R2 0x0002u
#define GAMEPAD_BUTTON_MASK_SELECT 0x0004u
#define GAMEPAD_BUTTON_MASK_START 0x0008u
#define GAMEPAD_BUTTON_MASK_L3 0x0020u
#define GAMEPAD_BUTTON_MASK_R3 0x0040u
#define GAMEPAD_BUTTON_MASK_CROSS 0x0100u
#define GAMEPAD_BUTTON_MASK_CIRCLE 0x0200u
#define GAMEPAD_BUTTON_MASK_SQUARE 0x0800u
#define GAMEPAD_BUTTON_MASK_TRIANGLE 0x01000u
#define GAMEPAD_BUTTON_MASK_L1 0x0400u
#define GAMEPAD_BUTTON_MASK_R1 0x8000u
#define GAMEPAD_GET_BUTTON(gi, km) (((gi)->buttons & km) ? true : false)
Defined masks representing various buttons on the gamepad, such as L2, R2, SELECT, START, and others.
GAMEPAD_GET_BUTTON is a macro used to check if a given button in the gamepad information is pressed.
1. Import Header File
#include "usbh_core.h"
#include "usbh_hid.h"
#include "usbh_hid_gamepad.h"
#include "cmsis_os2.h"
#define ATC_THRESHOLD 60
USB host (usb_host.h and usbh_core.h).
Handling functions for HID devices (usbh_hid.h and usbh_hid_gamepad.h).
As well as the message queue of the CMSIS-RTOS operating system (cmsis_os2.h).
ATC_THRESHOLD defines the threshold for analog joysticks, used to determine if joystick movement exceeds the set threshold.
2. A_T_C Function
static char A_T_C(int8_t analog_x, int8_t analog_y);
This is used to handle inputs from analog joysticks, returning a character representing the direction based on the joystick’s x and y coordinates.
It checks if the x coordinate exceeds the set threshold, then checks if the y coordinate exceeds the set threshold, and finally returns a character representing the direction based on the results of these two coordinates.
3. USBH_HID_EventCallback Function
void USBH_HID_EventCallback(USBH_HandleTypeDef *phost)
extern osMessageQueueId_t moving_ctrl_queueHandle;
static HID_GAMEPAD_Info_TypeDef last_info;
static char last_direction_msg = 'I';
static char last_button = 'R';
USBH_HID_EventCallback is a callback function of the USB host library.
This function is called when the status of a USB device changes. Within the function, different processing is performed based on the type of device.
If the device type is a gamepad (0xFF), it retrieves information from the gamepad and processes the status of joysticks and buttons. The processing results are then sent to the message queue.
4. USBH_HID_GetDeviceType(phost)
switch(USBH_HID_GetDeviceType(phost)) {
case 0xFF: {/* Gamepad data */
HID_GAMEPAD_Info_TypeDef *info = USBH_HID_GetGamepadInfo(phost);
if(info == NULL) {
break;
This program checks the type of device.
The function retrieves the current connected device type using USBH_HID_GetDeviceType(phost).
If a gamepad’s information is obtained using USBH_HID_GetGamepadInfo(phost), it proceeds to the next step of processing if the device type is 0xFF (gamepad); otherwise, it exits.
5. Check info->hat Status
char direction_msg = ' ';
if(info->hat & 0x08) {
direction_msg = (((info->hat & 0x07) + 1) & 0x07) + 0x41;
osMessageQueuePut(moving_ctrl_queueHandle, &direction_msg, 0, 0);
} else {
if(last_info.hat != info->hat) { /* Send release signal only once when released */
} else {
direction_msg = A_T_C(info->lx, info->ly);
if(direction_msg != 'I') {
} else {
if(last_direction_msg != 'I') { /* Send release signal only once when released */
last_direction_msg = direction_msg;
This segment of the program is used to handle the gamepad’s directional keys:
By checking the status of info->hat, it determines whether the gamepad’s directional keys are pressed. If pressed, it converts the status of the directional keys into a character and sends this character to the message queue.
6. A_T_C(info->lx, info->ly) Function
char button = A_T_C(info->rx, info->ry);
The above image shows a portion of the program for the gamepad’s joysticks.
The function A_T_C(info->lx, info->ly) is called to convert the x and y coordinates of the joystick into a character representing the direction. If the joystick is not moved, the returned character will be ‘I’, and in this case, there is no need to send a message to the message queue. If the joystick is moved, the character representing the direction is sent to the message queue (as shown below).
char result = 'I';
if(analog_x < -ATC_THRESHOLD) {
if(analog_y < -ATC_THRESHOLD) {
result = 'D';
} else if(analog_y > ATC_THRESHOLD) {
result = 'B';
} else {
result = 'C';
} else if(analog_x > ATC_THRESHOLD) {
result = 'F';
result = 'H';
} else {
result = 'G';
} else {
result = 'E';
result = 'A';
} else {
result = 'I';
return result;
7. last_button Handles Gamepad Buttons
if(((last_button != 'I' && button == 'I') || button != 'I')) {
char msg = button - 'A' + 'J';
osMessageQueuePut(moving_ctrl_queueHandle, &msg, 0, 0);
last_button = button;
if(GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_CIRCLE)) {
osMessageQueuePut(moving_ctrl_queueHandle, "p", 0, 0);
if(GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_SQUARE)) {
osMessageQueuePut(moving_ctrl_queueHandle, "n", 0, 0);
/* Triggered when pressed */
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_TRIANGLE) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_TRIANGLE)) {
osMessageQueuePut(moving_ctrl_queueHandle, "j", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_CROSS) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_CROSS)) {
osMessageQueuePut(moving_ctrl_queueHandle, "h", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_SELECT) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_SELECT)) {
osMessageQueuePut(moving_ctrl_queueHandle, "T", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_START) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_START)) {
osMessageQueuePut(moving_ctrl_queueHandle, "S", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_L1) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_L1)) {
osMessageQueuePut(moving_ctrl_queueHandle, "g", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_L2) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_L2)) {
osMessageQueuePut(moving_ctrl_queueHandle, "b", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_L3) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_L3)) {
osMessageQueuePut(moving_ctrl_queueHandle, "c", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_R1) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_R1)) {
osMessageQueuePut(moving_ctrl_queueHandle, "d", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_R2) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_R2)) {
osMessageQueuePut(moving_ctrl_queueHandle, "m", 0, 0);
if(!GAMEPAD_GET_BUTTON(&last_info, GAMEPAD_BUTTON_MASK_R3) && GAMEPAD_GET_BUTTON(info, GAMEPAD_BUTTON_MASK_R3)) {
osMessageQueuePut(moving_ctrl_queueHandle, "f", 0, 0);
memcpy(&last_info, info, sizeof(HID_GAMEPAD_Info_TypeDef));
break;
default:
break;
The above image shows a portion of the program for the gamepad buttons.
For each button on the gamepad, it checks whether it is pressed. If a button is pressed, it sends the character representing that button to the message queue. Then, it executes the function associated with that command.
Finally, the function copies the current gamepad information to last_info for use in the next call.
3.13 RRC Flight Control SBUS Reception Principle and Source Code Analysis
3.13.1 Program Logic
This chapter mainly focuses on receiving instructions from the remote control for aircraft models, controlling the movement of the vehicle, and the rotation of the pan tilt.
3.13.2 Hardware Connection
The hardware connection diagram of the flight controller receiver is as follows:
3.13.3 Program Download
The example routine for this section is ‘3.13 RRC Flight Control SBUS Reception Routines/ (Corresponding Car Model)/RosRobotCOntrollerM4_SBUS_AirplaneSystem’. You need to burn the program according to the corresponding chassis type.
3.13.4 Program Outcome
After the development board is powered on, the flight controller receiver will slowly flash once per second when no remote control is connected;
Pressing the small button on the flight controller receiver will activate the pairing mode, indicated by rapid flashing four times per second;
Next, turn on the switch of the remote control. When the indicator light on the remote control remains solid, the connection is successful.
①: Power switch. Short press to turn on, long press to turn off;
②: Button 1, with three positions. Default to the middle position. Press once downward to trigger a single beep from the buzzer; press upward to activate intermittent beeping of the buzzer, with no action in the middle position;
③: Button 2, with two positions. Press upward to enable left and right translation control of the vehicle using the left joystick (this function applies only to Mecanum wheel vehicles, not to other types); press downward to control left and right turns or spins of the vehicle using the left joystick;
④: Button 3, with two positions. Press upward to lock the gimbal in the center position, preventing rotation control with the right joystick; press downward to enable gimbal selection control with the right joystick;
⑤: Button 4, with three positions, controlling the vehicle speed. Default position is the middle gear. Press upward once and release to increase the vehicle speed by one gear; press downward once and release to decrease the vehicle speed by one gear;
⑥: Left joystick: Controls the vehicle to move straight forward and backward, turn left and right, or spin. Also controls forward and left/right turning, as well as backward left/right turning. Left/right movement mode is controlled by button 2;
⑦: Right joystick: Controls gimbal rotation. Left/right movement controls gimbal rotation left and right, while forward/backward movement controls gimbal pitch and rotation.
⑧⑨: Adjust the joystick centering parameters. When adjusted, it will emit a long beep. (!!! Users should not adjust it casually!!!).
⑩: Configure the remote control mode. Start from the left and move to the middle position for the first dial, then downward for the following dials. (!!! Incorrect configuration may cause confusion in remote control operation!!!).
3.13.5 PIN Info Configuration
The flight controller receiver communicates with the development board via the SBUS protocol, similar to the UART protocol, and only requires data reception. By using STM32CubeMX software to view pin information, according to the diagram below, the corresponding chip pin is PD2.
3.13.6 Source Code Analysis
The program source code for this session is located in ‘3.13 RRC Flight Control SBUS Reception Principle and Source Code Analysis / RosRobotControllerM4_SBUS_AirplaneSystem’. The program framework is designed according to the functionality as shown in the diagram below. The analysis mainly focuses on the ‘Hiwonder/Misc/sbus.c’ file and the ‘Hiwonder/Porting/sbus_porting.c’ file.
The content is divided into three parts: Interrupt Event Callback Handling, SBUS Reception Processing Task, and Motion Control Task.
The SBUS reception utilizes the hardware UART5 port. In the main.c file, UART5 is enabled.
The sbus_dma_receive_event_callback() function in the sbus_porting.c file serves as the interrupt event callback function for UART5. It receives data from UART5 and pushes it into the custom data storage buffer subs1_rx_dma_buffers[]. The code is as shown in the diagram below:
static void sbus_dma_receive_event_callback(UART_HandleTypeDef *huart, uint16_t length)
uint32_t cur_index = sbus1_rx_dma_buffer_index; /* Get the index number of the current DMA buffer */
sbus1_rx_dma_buffer_index ^= 1;
if(length < SBUS_RX_DMA_BUFFER_SIZE) {
// Terminate reception
HAL_UART_AbortReceive(&huart5);
// Receive data in DMA mode
HAL_UARTEx_ReceiveToIdle_DMA( &huart5,
(uint8_t*)subs1_rx_dma_buffers[sbus1_rx_dma_buffer_index],
SBUS_RX_DMA_BUFFER_SIZE);
lwrb_write(sbus1_rx_fifo, subs1_rx_dma_buffers[cur_index], length); /* Write the received data to the FIFO ring buffer */
if(lwrb_get_full(sbus1_rx_fifo) >= 25) { /* The size of each SBUS frame is 25 bytes; parse once whenever the size exceeds 25 bytes */
osSemaphoreRelease(sbus_data_ready_01_Handle); /* Set the SBUS data ready semaphore */
1. SBUS Reception Processing Task
The sbus_rx_task_entry() function in the sbus_porting.c file is the entry point for the SBUS reception task. The code logic is as follows:
Initialize SBUS
Terminate the UART, set up and register the callback event for data reception
Loop:
① Wait for data reception. If no data is received, go back to step 2) to reset; if data is received, continue;
② Attempt to parse the data. If parsing is successful, process the data; if parsing fails, move to the next received byte and start parsing again;
The specific function is as below:
void sbus_rx_task_entry(void *argument)
// SBUS receive buffer
static uint8_t buf_temp[32];
// Initialize SBUS
sbus_init();
/* Start reception */
// Jump label
start_sbus_receive:
// Abort UART data reception to prevent data issues
HAL_UART_RegisterRxEventCallback(&huart5, sbus_dma_receive_event_callback); /* Register receive event callback */
/* Use ReceiveToIdle_DMA for reception; this function will interrupt when the DMA buffer is full or when reception is idle, and trigger the receive event callback */
/* Parsing loop */
for(;;) {
if(osSemaphoreAcquire(sbus_data_ready_01_Handle, 1000) != osOK) { /* Wait for data ready */
goto start_sbus_receive; // Jump to start_sbus_receive label
for(;;) {
memset(buf_temp, 0, 25); // Clear the buffer
if(lwrb_peek(sbus1_rx_fifo, 0, buf_temp, 25) == 25) { /* Read 25 bytes from the buffer */
if(sbus_decode_frame(buf_temp, sbus1_status) == 0) { /* Attempt parsing until there are insufficient bytes */
lwrb_skip(sbus1_rx_fifo, 25); // Discard the read data
if(sbus1_status->signal_loss == false) // If connected
// sbus_print_status(sbus1_status); // Print each data of the remote controller
deal_SbusData(sbus1_status); // Data processing function
} else { // If parsing fails, skip to the next byte and continue parsing
lwrb_skip(sbus1_rx_fifo, 1);
} else {
break;
2. Flight Controller Data Processing Function
After the SBUS reception task parses the data, it passes the values to the flight controller data processing function deal_SbusData(). This function converts the changing values into corresponding motion control command values (these command values are the same as those for gamepad control and Bluetooth control) and sends them to the motion control function through a queue.
(1)Process the Joystick Value
The midpoint value of the joystick is 992, with a range of [192, 1792]. The joystick has two data points: one for horizontal and one for vertical movement. When the vertical joystick value is greater than 1400 or less than 600, it is considered to be tilted left or right, requiring the vehicle to perform the corresponding movement. The corresponding motion command is then sent to the moving_ctrl_queueHandle queue using the osMessageQueuePut() function. Upon receiving the command, the motion control task will control the vehicle accordingly.
/* Aerial model data processing function */
static void deal_SbusData( SBusStatusObjectTypeDef *status )
// Externally declare motion control queue handle
{// Left joystick
static char direction_msg_l = 'I';
static char last_direction_msg_l = 'I';
// Map the position of the left joystick
direction_msg_l = A_T_C(status->channels[3], status->channels[2]);
if(direction_msg_l != 'I') { // If not a stop signal
// Determine the mode selected by switch 2 (translation or spin) and select the signal
if( direction_msg_l == 'C')
// The center value of the joystick is 992, with a range of [992-800, 992+800]
// If the switch has 2 positions, there are only two values: 192 and 1792; for 3 positions, the values are 192, 992, 1792.
direction_msg_l = status->channels[5] > 992 ? direction_msg_l : 'l';
if( direction_msg_l == 'G')
direction_msg_l = status->channels[5] > 992 ? direction_msg_l : 'p';
osMessageQueuePut(moving_ctrl_queueHandle, &direction_msg_l, 0, 0); // Send control signal to the queue
} else {
if(last_direction_msg_l != 'I') { /* Send the release signal only once when released */
// Record this value
last_direction_msg_l = direction_msg_l;
There are two types of toggles. One is a two-position toggle: toggling up receives a value of 192, toggling down receives a value of 1792. The other is a three-position toggle: toggling up receives a value of 192, the middle position is 992, and toggling down receives a value of 1792.
The right joystick controls the pan-tilt movement, and toggle switch three provides a mode selection for pan-tilt centering lock. If toggled up, it activates the centering lock mode, skipping the processing of the right joystick values. If toggled down, it activates the joystick control mode, and the right joystick values are processed. The corresponding pan-tilt control command is then sent to the moving_ctrl_queueHandle queue using the osMessageQueuePut() function.
static char direction_msg_r = 'I';
static char last_direction_msg_r = 'I';
if( status->channels[6] < 992 ) // Return to center lock - Switch 3 controls gimbal center lock/unlock
if( 'f' != last_direction_msg_r )
// Send center return command once to prevent joystick from controlling gimbal rotation, achieving lock effect
direction_msg_r = 'f';
last_direction_msg_r = direction_msg_r;
osMessageQueuePut(moving_ctrl_queueHandle, &direction_msg_r, 0, 0);
}else{ // If gimbal is not locked
{// Right joystick
static uint8_t send_count = 0;
// Convert joystick position signals
direction_msg_r = A_T_C(status->channels[0], status->channels[1]);
if(direction_msg_r != 'I') {
send_count++;
// Reduce sending frequency to within 20 signals per second for better servo control
if( 4 == send_count )
send_count = 0;
// Map signal from J to R
direction_msg_r = direction_msg_r - 'A' + 'J';
} else {
if(last_direction_msg_r != 'I') { /* Send release signal only once when released */
send_count++;
// Count to 4 before sending due to high signal frequency
send_count = 0;
(2)Processing Toggle Values
When toggle one is flipped up (value of 192), the buzzer sounds once every 100 counts to create an intermittent beeping effect. When toggle one is flipped down, it beeps once and stores the current value. If the stored value matches the current value, it indicates that the beep has already sounded once, so the beep action command should be skipped.
static char msg_l = 'R';
static int16_t last_data_1 = 992;
if( status->channels[4] > 1400 ) // Switch 1 is currently toggled down
if(last_data_1 < 1400 ) // If the last state was not toggled down, the buzzer beeps once
msg_l = 'S'; //
osMessageQueuePut(moving_ctrl_queueHandle, &msg_l, 0, 0);
last_data_1 = status->channels[4]; // Remember the current switch value
}else if( status->channels[4] < 600 ) // Switch 1 is currently toggled up
{ // The buzzer beeps intermittently
send_count++;
if( 100 == send_count )
send_count = 0;
msg_l = 'S'; //
}else{ // Otherwise (if in the middle position), no action
When toggle four is flipped up and then returned to the middle, it should increase the speed by one level and send an acceleration command. When toggle four is flipped down and then returned to the middle, it should decrease the speed by one level and send a deceleration command. To eliminate mechanical jitter that causes data errors when the toggle returns to the middle position, a 20-count check is performed to ensure stable acceleration and deceleration functionality.
if( status->channels[4] > 1400 ) // Switch 1 currently pushed down
if(last_data_1 < 1400 ) // If last time wasn't pushed down, buzzer beeps once
msg_l = 'S'; //
last_data_1 = status->channels[4]; // Remember current switch value
}else if( status->channels[4] < 600 ) // Switch 1 currently pushed up
{ // Buzzer beeps intermittently
send_count++;
send_count = 0;
msg_l = 'S'; //
}else{ // If in middle position, no action
static int16_t last_data_4 = 992;
if( status->channels[7] > 1600 ) // Switch 4 currently pushed down
if(last_data_4 < 1600 ) // If last time wasn't pushed down, send deceleration signal once
msg_l = 'n'; // Decelerate
last_data_4 = status->channels[7]; // Remember current switch value
}else if( status->channels[7] < 300 ) // Switch 4 currently pushed up
if(last_data_4 > 300 ) // If last time wasn't pushed up, send acceleration signal once
msg_l = 'j'; // Accelerate
static uint8_t count = 0;
count++;
if( 20 < count ) // Debouncing
count = 0;
3. Motion Control Task
The app_task_entry() function in the app.c file is the entry point for the motion control task.
Its content is the same as that of the gamepad remote control. Please refer to
‘Lesson 12 RRC PS2 Controller USB Receiver Signal Processing Explanation and Source Code Analysis”
3.14 RRC Communication Protocol with the Host Computer Analysis
3.14.1 Description
This chapter mainly analyzes the communication protocol between the RRC development board and the host computer (ROS package), laying the foundation for subsequent learning about the host computer.
3.14.2 Communication Protocol
Common instruction examples can be found in: Common Communication Instruction Examples
Instructions are written in hexadecimal. If you are not familiar with the calculation method, you can refer to: Using a calculator tool for hexadecimal conversion. For converting negative numbers and floating-point numbers to hexadecimal, please search for online tutorials.
Instruction format:
| Frame Header | Function Code | Data Length | Parameter | Checksum |
| 0xAA 0x55 | (uint8_t)Function | (uint8_t)Length | Data | (uint8_t) CRC |
Frame Header: Continuous reception of 0xAA, 0x55 indicates the arrival of a data packet.
Function Code: Used to indicate the purpose of an information frame.
Data Length: Number of parameters.
Parameters: Additional control information other than function instructions.
Checksum: Verifies the correctness of the data using CRC checksum method (CRC calculation of Function, Length, and Data values, taking the lower 8 bits).
User-Initiated Data Transmission to the Control Board Section
The development board already has a dedicated UART to USB circuit, so communication only requires connecting the UART3 port to the host computer using a data cable.
1. LED control: Instruction name PACKET_FUNC_LED, value 1
| 0xAA 0x55 | PACKET_FUNC_LED | 7 | Parameter 1: (uint8_t)led_id Parameter 2: (uint16_t)light-on duration(ms) Parameter 3: (uint16_t)light-off duration(ms) Parameter 4: (uint16_t)number of cycles |
CRC |
Example:
(1) Control the LED to blink 5 times, with each cycle having the light on for 100ms and off for 100ms:
| 0xAA 0x55 | PACKET_FUNC_LED | 7 | Parameter 1: 0x01 (1) Parameter 2: 0x64 0x00 (100) Parameter 3: 0x64 0x00 (100) Parameter 4: 0x05 0x00 (5) |
CRC |
Note: This is little-endian mode. For example, the uint32_t value 5 (decimal) is written as 0x00 0x05. In little-endian mode, the least significant byte comes first, so when sending data, it should be written as 0x05 0x00.
(2) Control the LED to blink 10 times, with each cycle having the light on for 500ms and off for 300ms
| 0xAA 0x55 | PACKET_FUNC_LED | 7 | Parameter 1:0x01 (1) Parameter 2:0xF4 0x01 (500) Parameter 3:0x2C 0x01 (300) Parameter 4:0x0A 0x00 (10) |
CRC |
2. Buzzer control: Instruction name PACKET_FUNC_BUZZER, value 2
| 0xAA 0x55 | PACKET_FUNC_BUZZER | 8 | Parameter 1: (uint16_t)frequency (Hz) Parameter 2: (uint16_t)beeping duration(ms) Parameter 3: (uint16_t)no-beeping duration(ms) Parameter 4: (uint16_t)number of cycles |
CRC |
Example:
(1) Control the buzzer to sound 5 times, with a frequency of 1400Hz, each lasting for 100ms followed by a 100ms pause
| 0xAA 0x55 | PACKET_FUNC_BUZZER | 8 | Parameter 1:0x78 0x05 (1400) Parameter 2:0x64 0x00 (100) Parameter 3:0x64 0x00 (100) Parameter 4:0x05 0x00 (5) |
CRC |
(2) Control the buzzer to sound 10 times, with a frequency of 1000Hz, each lasting for 500ms followed by a 300ms pause.
| 0xAA 0x55 | PACKET_FUNC_BUZZER | 8 | Parameter 1:0xE8 0x03 (1000) Parameter 2:0xF4 0x01 (500) Parameter 3:0x2C 0x01 (300) Parameter 4:0x0A 0x00 (10) |
CRC |
3. Encoder motor control: Instruction name PACKET_FUNC_MOTOR, value 3
(1) Control Single Motor
| 0xAA 0x55 | PACKET_FUNC_MOTOR | 6 | Parameter 1: (uint8_t)0x00 (subcommand) Parameter 2: (uint8_t)motor_id Parameter 3: (float)speed value (positive and negative) |
CRC |
(Note: float type is 4 bytes)
Example: Control motor 1 to rotate at -1r/s speed:
| 0xAA 0x55 | PACKET_FUNC_MOTOR | 6 | Parameter 1:0x00Parameter 2:0x01 Parameter 3:0x00 0x00 0x80 0xBF (-1) |
CRC |
(2) Control Multiple Motors
| 0xAA 0x55 | PACKET_FUNC_MOTOR | 5N+2 | Parameter 1: (uint8_t)0x01 (subcommand) Parameter 2: (uint8_t)motor quantity Parameter 3: (uint8_t)motor_id_1 Parameter 4: (float)speed _1······ Parameter 2N+1: (uint8_t)motor_id_N Parameter 2N+2: (float)speed _N (Format reference parameters 3, 4) |
CRC |
Example:
Control motor 1 and motor 2 to rotate at speeds of -1r/s and 2r/s respectively:
| 0xAA 0x55 | PACKET_FUNC_MOTOR | 12 | Parameter 1:0x01 (subcommand) Parameter 2:0x02 Parameter 3:0x01 Parameter 4:0x00 0x00 0x80 0xBF (-1) Parameter 5:0x02 Parameter 6:0x00 0x00 0x00 0x40 (+2) |
CRC |
(3) Control Single Motor to Stop
| 0xAA 0x55 | PACKET_FUNC_MOTOR | 2 | Parameter 1: (uint8_t)0x02 (subcommand) Parameter 2: (uint8_t)motor_id |
CRC |
Example:
Control motor 1 to stop:
| 0xAA 0x55 | PACKET_FUNC_MOTOR | 2 | Parameter 1:0x02 (subcommand) Parameter 2:0x01 |
CRC |
(4) Control several motors to stop:
| 0xAA 0x55 | PACKET_FUNC_MOTOR | 2 | Parameter 1: (uint8_t)0x03 (subcommand) Parameter 2: (uint8_t)motor mask |
CRC |
Example:
Control motor 0 and motor 2 to stop:
| 0xAA 0x55 | PACKET_FUNC_MOTOR | 2 | Parameter 1:0x03 (mode) Parameter 2:0x05 (Binary 00000101) |
CRC |
4. PWM servo control:instruction name PACKET_FUNC_PWM_SERVO,value 4
(1) Control several PWM servos
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 3N+3 | Parameter 1: (uint8_t)0x01 (subcommand) Parameter 2: (uint16_t)motion time(ms) Parameter 3: (uint8_t)servo_id_1 Parameter 4: (uint16_t)pulse width······ Parameter 2N+1: (uint8_t)servo_id_N Parameter 2N+2: (uint16_t)pulse width |
CRC |
Example: Control servo 1 and servo 2 to rotate to 90° and 180° respectively, corresponding to pulse widths of 1500 and 2500, within 2 seconds:
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 9 | Parameter 1:0x01 (subcommand) Parameter 2:0xD0 0x07 (2000) Parameter 3:0x01 (1) Parameter 4:0xDC 0x05 (1500) Parameter 5:0x02 (2) Parameter 6:0xC4 0x09 (2500) |
CRC |
(2) Control single PWM servo
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 6 | Parameter 1: (uint8_t)0x03 (subcommand) Parameter 2: (uint16_t)motion time(ms) Parameter 3: (uint8_t)servo_id Parameter 4: (uint16_t)pulse width |
CRC |
The pulse width ranges from [500, 2500], corresponding to [0°, 180°].
Example:
Control servo 1 to rotate to the 90° position within 1 second, with a pulse width of 1500:
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 6 | Parameter 1:0x03 (subcommand) Parameter 2:0xE8 0x03 (1000) Parameter 3:0x01 (1) Parameter 4:0xDC 0x05 (1500) |
CRC |
(3) Read PWM servo position
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 2 | Parameter 1: (uint8_t)0x05 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the command to read the position, the control board will send the position data of the corresponding PWM servo with the ID to the host computer.
(4) Set PWM Servo Deviation
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 3 | Parameter 1: (uint8_t)0x07 (subcommand) Parameter 2: (uint8_t)servo_id Parameter 3: (uint8_t)deviation parameter (Convert to int8_t type, valid range is -100 to +100) |
CRC |
Example:
Set the offset of servo 2 to +10
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 3 | Parameter 1:0x07 (subcommand) Parameter 2:0x02 (2) Parameter 3:0x0A (10) |
CRC |
(5) Read PWM Servo Deviation
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 2 | Parameter 1: (uint8_t)0x09 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the command to read the position, the control board will send the offset data of the corresponding PWM servo with the ID to the host computer.
5. Serial bus servo control: Instruction name PACKET_FUNC_BUS_SERVO,value 5
(1) Control serial bus servo to move
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 3N+4 | Parameter 1: (uint8_t)0x01 (subcommand) Parameter 2: (uint16_t)motion time(ms) Parameter 3: (uint8_t)servo quantity Parameter 4: (uint8_t)servo_id_1 Parameter 5: (uint16_t)Pulse width······ Parameter 2N+1: (uint8_t)servo_id_N Parameter 2N+2: (uint16_t)Pulse width |
CRC |
Example:
Control bus servo 1 and servo 2 to rotate to 200° and 240° respectively, corresponding to pulse widths of 833 and 1000, within 1 second:
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 10 | Parameter 1:0x01 (subcommand) Parameter 2:0xE8 0x03 (1000) Parameter 3:0x02 (2) Parameter 4:0x01 (1) Parameter 5:0x41 0x03 (833) Parameter 4:0x02 (2) Parameter 5:0xE8 0x03 (1000) |
CRC |
(2) Read position command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x05 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the command to read the position, the control board will send the position data of the corresponding bus servo with the ID to the host computer.
(3) Read the input voltage command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x07 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the command to read the input voltage, the control board will send the input voltage data of the corresponding bus servo with the ID to the host computer.
(4) Read temperature command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x09 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the command to read the temperature, the control board will send the temperature data of the corresponding bus servo with the ID to the host computer.
(5) Motor power-off command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x0B (subcommand) Parameter2: (uint8_t)servo_id |
CRC |
After sending the command to unload power, the control board will unload the power of the corresponding bus servo with the ID.
(6) Motor power-on command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x0C (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the command to load power, the control board will load power to the corresponding bus servo with the ID.
(7) ID writing command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 3 | Parameter1: (uint8_t)0x10 (subcommand) Parameter 2: (uint8_t)servo_id Parameter3: (uint8_t)save_id |
CRC |
After sending the ID write command, the control board will overwrite the ID number of the corresponding bus servo.
(8) ID reading command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter1: (uint8_t)0x12 (subcommand) Parameter2: (uint8_t)0xFE (Broadcast Query) |
CRC |
After sending the ID read command, the control board will upload the ID number of the bus servo to the host computer.
Note: There can only be one bus servo here. Otherwise, multiple bus servos returning data simultaneously will cause bus conflicts.
(9) Deviation adjusting command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 3 | Parameter 1: (uint8_t)0x20 (subcommand) Parameter 2: (uint8_t)servo_id Parameter 3: (uint8_t)deviation adjustment value |
CRC |
After sending the offset adjustment command, the control board will set the offset value of the corresponding bus servo with the value of parameter 3.
(10) Deviation reading command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x22 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the offset read command, the control board will read the offset value of the corresponding bus servo and upload it to the host computer.
(11) Deviation saving command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x24 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the offset save command, the control board will enable the corresponding bus servo with the ID to save its current offset value.
(12) Position limit setting command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 6 | Parameter 1: (uint8_t)0x30 (subcommand) Parameter 2: (uint8_t)servo_id Parameter 3: (uint16_t)lower limit Parameter 4: (uint16_t)higher limit |
CRC |
The numerical range of the limit is [0, 1000].
After sending the position limit setting command, the control board will set the limit parameters for the corresponding ID of the bus servo.
(13) Position limit reading command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x32 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the position limit read command, the control board will upload the limit parameters of the corresponding bus servo to the host computer.
(14) Voltage Limit Setting Command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 6 | Parameter 1: (uint8_t)0x34 (subcommand) Parameter 2: (uint8_t)servo_id Parameter 3: (uint16_t)lower limit Parameter 4: (uint16_t)higher limit |
CRC |
The low voltage limit value should be greater than 4500, and the high voltage limit value should be less than 14000.
After sending the voltage limit setting command, the control board will set the voltage limit parameters for the corresponding ID of the bus servo.
(15) Voltage limit reading command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x36 (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the voltage limit read command, the control board will upload the voltage limit parameters of the corresponding bus servo to the host computer.
(16) Temperature limit setting command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 3 | Parameter 1: (uint8_t)0x38 (subcommand) Parameter 2: (uint8_t)servo_id Parameter 3: (uint8_t)high temperature threshold |
CRC |
The parameter value for the high-temperature threshold should be less than 100.
After sending the temperature limit setting command, the control board will set the high-temperature threshold parameter for the corresponding ID of the bus servo.
(17) Temperature limit reading command
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 2 | Parameter 1: (uint8_t)0x3A (subcommand) Parameter 2: (uint8_t)servo_id |
CRC |
After sending the temperature limit setting command, the control board will upload the high-temperature threshold parameter of the corresponding bus servo to the host computer.
2.2 Data sent by the control board to the user
1. Bus Servo Data Upload: Command name PACKET_FUNC_BUS_SERVO, value 5
(1) Serial bus servo position upload
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 5 | Parameter 1: (uint8_t)servo_id Parameter 2: (uint8_t)0x05 (subcommand) Parameter 3: (int8_t)Was the read successful? (0:success;-1:fail) Parameter 4: (int16_t)servo position |
CRC |
When a read command is received, the corresponding servo’s position parameter is read and uploaded to the host computer.
Example:
The angle of servo 5 is uploaded as 30°, corresponding to a pulse width of 833:
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 5 | Parameter 1:0x05 (5) Parameter 2:0x05 (subcommand) Parameter 3:0x00 (0) Parameter 4:0x41 0x03 (833) |
CRC |
(2) Bus Servo Voltage Upload
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 5 | Parameter 1: (uint8_t)servo_id Parameter 2: (uint8_t)0x07 (subcommand) Parameter 3: (int8_t)Was the read successful? (0:success;-1:fail)Parameter 4: (uint16_t) servo voltage |
CRC |
When a read command is received, the voltage parameter of the corresponding servo is read and uploaded to the host computer.
(3) Bus Servo Temperature Upload
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 4 | Parameter 1: (uint8_t)servo_id Parameter 2: (uint8_t)0x09 (subcommand) Parameter 3: (int8_t)Was the reading successful (0:success;-1:fail) Parameter 4: (uint8_t)servo temperature |
CRC |
When a read command is received, the temperature parameter of the corresponding servo is read and uploaded to the host computer.
(4) Serial Bus Servo ID Upload
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 4 | Parameter 1: (uint8_t)0xFE (broadcast command) Parameter 2: (uint8_t)0x12 (subcommand) Parameter 3: (int8_t)Was the reading successful (0:success;-1:fail) Parameter 4: (uint8_t)read servo_id |
CRC |
When a read command is received, the ID number of the servo is read and uploaded to the host computer.
(5) Serial Bus Servo Deviation Parameter Upload
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 4 | Parameter 1: (uint8_t)0xFE (previous broadcast command) Parameter 2: (uint8_t)0x22 (subcommand) Parameter 3: (int8_t)Was the reading successful (0:success;-1:fail) Parameter 4: (uint8_t)servo deviation |
CRC |
When a read command is received, the deviation parameter of the corresponding servo is read and uploaded to the host computer.
(6) Bus Servo Position Limit Parameter Upload
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 7 | Parameter 1: (uint8_t)servo_id Parameter 2: (uint8_t)0x32 (subcommand) Parameter 3: (int8_t)Was the reading successful (0:success;-1:fail) Parameter 4: (uint16_t)lower limitParameter 5: (uint16_t)higher limit |
CRC |
When a read command is received, the position limit parameters of the corresponding servo are read and uploaded to the host computer.
(7) Serial Bus Servo Voltage Limit Parameter Upload
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 7 | Parameter 1: (uint8_t)servo_id Parameter 2: (uint8_t)0x36 (subcommand) Parameter 3: (int8_t)Was the reading successful (0:success;-1:fail) Parameter 4: (uint16_t)lower limit Parameter 5: (uint16_t)higher limit |
CRC |
When a read command is received, the voltage limit parameters of the corresponding servo are read and uploaded to the host computer.
(8) Bus Servo Temperature Limit Parameter Upload
| 0xAA 0x55 | PACKET_FUNC_BUS_SERVO | 4 | Parameter 1: (uint8_t)servo_id Parameter 2: (uint8_t)0x3A (subcommand) Parameter 3: (int8_t)Was the reading successful (0:success;-1:fail) Parameter 4: (uint8_t)temperature limit |
CRC |
When a read command is received, the temperature limit parameters of the corresponding servo are read and uploaded to the host computer.
2. Upload Button Message: Instruction Name PACKET_FUNC_KEY, Value 6
| 0xAA 0x55 | PACKET_FUNC_KEY | 2 | Parameter 1:(uint8_t) button_id Parameter 2:(uint8_t) button event |
CRC |
Partial button event callback values are as follows:
BUTTON_EVENT_PRESSED = 0x01, /* Button pressed /
BUTTON_EVENT_LONGPRESS = 0x02, / Button long pressed /
BUTTON_EVENT_CLICK = 0x20, / Button clicked /
BUTTON_EVENT_DOUBLE_CLICK = 0x40, / Button double-clicked */
Example:
Send a message indicating that button 1 is pressed:
| 0xAA 0x55 | PACKET_FUNC_KEY | 2 | Parameter 1:0x01 Parameter 2:0x01 |
CRC |
3. Upload IMU Data: Command Name PACKET_FUNC_IMU, Value 7
| 0xAA 0x55 | PACKET_FUNC_IMU | 24 | Parameter 1:(float) accel_x data Parameter 2:(float) accel_y data Parameter 3:(float) accel_z data Parameter 4:(float) gyro_x data Parameter 5:(float) gyro_y data Parameter 6:(float) gyro_z data |
CRC |
4. Upload Gamepad Data: Command Name PACKET_FUNC_GAMEPAD, Value 8
| 0xAA 0x55 | PACKET_FUNC_IMU | 7 | Parameter 1:(uint16_t) button Parameter 2:(uint8_t) hat value Parameter 3:(int8_t) left joystick x value Parameter 4:(int8_t) left joystick y value Parameter 5:(int8_t) right joystick x value Parameter 6:(int8_t) right joystick y value |
CRC |
5. Upload SBUS model aircraft remote control data: Command name PACKET_FUNC_SBUS, value 9
| 0xAA 0x55 | PACKET_FUNC_SBUS | 36 | Parameter 1:(int16_t[16])16 channel values Parameter 2:(uint8_t)ch17 Parameter 3:(uint8_t)ch18 Parameter 4:(uint8_t)signal_loss Parameter 5:(uint8_t)fail_safe |
CRC |
The data for all 16 channels of the model aircraft’s joysticks and switches are contained in parameter 1.
6. PWM servo control: Command name PACKET_FUNC_PWM_SERVO, value 4
(1) PWM servo position upload
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 4 | Parameter 1:(uint8_t)servo_id Parameter 2:(uint8_t)0x05 (subcommand) Parameter 3:(uint16_t)pulse width |
CRC |
Upon receiving the read command, read the pulse width of the corresponding servo and upload it to the host computer.
(2) PWM servo deviation upload
| 0xAA 0x55 | PACKET_FUNC_PWM_SERVO | 3 | Parameter 1:(uint8_t)servo_id Parameter 2:(uint8_t)0x05 (subcommand) Parameter 3:(int8_t)servo deviation |
CRC |
3.14.3 Common Communication Protocol Examples
Preparation:
Open the serial port assistant, connect via type-C to UART2, set the baud rate to 1000000, and select HEX (hexadecimal transmission).
Examples:
Control the buzzer to sound 5 times, at a frequency of 1400Hz, each time for 100ms and stop for 100ms:
AA 55 02 08 78 05 64 00 64 00 05 00 F0
Control the buzzer to sound 10 times, at a frequency of 1000Hz, each time for 500ms and stop for 300ms:
AA 55 02 08 E8 03 F4 01 2C 01 0A 00 8B
Control the LED light to flash 10 times, each time on for 500ms and off for 300ms:
AA 55 01 07 01 F4 01 2C 01 0A 00 04
Control the LED light to flash 5 times, each time on for 100ms and off for 100ms:
AA 55 01 07 01 64 00 64 00 05 00 37
Single motor control movement: Control motor 1 to rotate at -1r/s speed:
AA 55 03 06 00 01 00 00 80 BF DA
AA 55 03 02 02 01 08
Control motor 1 and motor 2 to rotate at -1r/s and 2r/s respectively:
AA 55 03 0C 01 02 01 00 00 80 BF 02 00 00 00 40 FB
Control motors 0 and 2 to stop:
AA 55 03 02 03 05 AD
Control servo 1 and servo 2 to rotate to 90° and 180° respectively, corresponding to pulse widths of 1500, 2500, 2s:
AA 55 03 09 01 D0 07 01 DC 05 02 C4 09 83
Control PWM servo 1 to move to 1000:
AA 55 04 06 03 e8 03 01 e8 03 e4
Set PWM servo deviation: Set the deviation of servo 2 to +10:
AA 55 03 03 07 02 0A 53
Control bus servo rotation: Control bus servo No. 1 and No. 2 to 200° and 240° respectively, the corresponding pulse widths are 833 and 1000, and it takes 1s:
AA 55 05 0A 01 E8 03 02 01 41 03 02 E8 03 9F
Control the bus servo to rotate: Control bus servo No. 1 and No. 2 to rotate to 0°, the corresponding pulse width is 0, and the time is 1s:
AA 55 05 0A 01 E8 03 02 01 00 00 02 00 00 D2
Control the bus servo with ID 1 to power off:
AA 55 05 02 0B 01 B3
Control the bus servo with ID 1 to power on:
AA 55 05 02 0C 01 DD
Change the ID of the bus servo with ID 1 to 2:
AA 55 05 03 10 01 02 68
3.14.4 Expansion—Using the Calculator Tool for Base Conversion
Using the Windows Calculator for Base Conversion:
①:Open the Start menu, search for Calculator, and open it.
②:Click on the Open Navigation button in the top left corner, and select Programmer.
③:Four bases are available for selection. Choose one base, input a value, and the equivalent values in the other three bases will be displayed.
3.15 RRC Communication with the Host Computer - Sending Processing Source Code Analysis
3.15.1 Instructions for Modifying Host Computer Routine (MUST READ!!!)
To adapt to different types of chassis, the source code needs to be modified with the type parameter values and low voltage alarm thresholds!!!
Since the RRC communication routine with the host computer is compatible with multiple chassis types, only the code of this routine needs to be modified.
If the type parameters are not modified, the motors may become uncontrolled!!!
If the low voltage alarm threshold is not modified, low voltage warnings cannot be correctly executed!!!
Change Chassis Type
Open the app.c file under the Hiwonder/System folder, and replace it with the corresponding chassis type value.
Optional type macro definitions
CHASSIS_TYPE_JETAUTO —— Mecanum-wheel chassis
CHASSIS_TYPE_JETTANK —— Big continuous track chassis
CHASSIS_TYPE_TI4WD —— Four-wheel differential chassis
CHASSIS_TYPE_TANKBLACK —— Small continuous track chassis
Revise Voltage Alarm Threshold
Open the global_conf.h file under the Hiwonder/System folder.
If the battery voltage is 12V, choose 9600; if it is 8V, choose 6300.
Configuration for an 8V battery is as follows:
Configuration for a 12V battery is as follows:
//#define BATTERY_LOW_ALARM_THRESHOLD 6300 /* Low voltage alarm threshold, unit: millivolt */
#define BATTERY_LOW_ALARM_THRESHOLD 9600
3.15.2 Program Logic
This section mainly analyzes the source code for sending communication between the RRC development board and the host computer.
3.15.3 Hardware Connection
The hardware connection diagram is shown below:
3.15.4 Program Download
The example for this section is “RosRobotControllerM4-armclang.
3.15.5 Program Outcome
After porting the ROS package, you can call the host computer interface to receive messages from the car chassis bus servo, button messages, IMU messages, gamepad messages, and SBUS model remote control messages.
3.15.6 Pin Configuration
The development board’s microcontroller uses UART3 serial port, converted to USB signal to communicate with the host computer through a conversion circuit. Pin information can be viewed in the stm32cubemx software. The corresponding chip pins are: PD8 and PD9.
3.15.7 Source Code Analysis
The program source code for this course is located in “RRC and Host Computer Communication Routine” . The program framework is designed as shown below.
The messages sent by the development board to the host computer are divided into five categories: bus servo messages, button messages, IMU messages, gamepad messages, and SBUS model remote control messages.
Button Message Upload
Each button action corresponds to a button event. When a button event is triggered, the corresponding button event message is uploaded to the host computer. In Hiwonder/System/app.c, the button_event_callback() function handles the event callback for buttons 1 and 2. When a button action changes, it enters this callback function, stores the button ID and its triggered event in the report structure, and uploads the button message to the host computer via the packet_transmit() function.
void button_event_callback(ButtonObjectTypeDef *button, ButtonEventIDEnum event)
PacketReportKeyEventTypeDef report = {
.key_id = button->id,
.event = (uint8_t)(int)event,
packet_transmit(&packet_controller, PACKET_FUNC_KEY, &report, sizeof(PacketReportKeyEventTypeDef));
if(event == BUTTON_EVENT_CLICK) {
buzzer_didi(buzzers[0], 2000, 50, 50, 1);
By enabling the commented-out printf function, compiling, and burning the program, you can see the button ID and event type values sent to the host computer in the serial port.
IMU Message Upload
After the IMU issues an interrupt, the microcontroller reads its current value and uploads it to the host computer. In the Hiwonder/Porting/imu_porting.c file, the imu_task_entry() function is responsible for reading IMU data. When this task reaches the osSemaphoreAcquire() function, it waits for a semaphore signal from the interrupt. Once the IMU issues an interrupt, the microcontroller interrupt sends a semaphore signal. When osSemaphoreAcquire() receives the signal, it continues executing the program, reads the IMU data, and uploads the message to the host computer via the packet_transmit() function. In the Application/User/Core/stm32f4xx_it.c file, the IMU interrupt triggers the following microcontroller interrupt to send a semaphore signal.
void EXTI15_10_IRQHandler(void)
/* USER CODE BEGIN EXTI15_10_IRQn 0 */
extern osSemaphoreId_t IMU_data_readyHandle;
if(__HAL_GPIO_EXTI_GET_IT(IMU_ITR_Pin) != RESET) { // Check if it's IMU interrupt pin signal
__HAL_GPIO_EXTI_CLEAR_IT(IMU_ITR_Pin); // Clear IMU interrupt pin signal
// Release semaphore
osSemaphoreRelease(IMU_data_readyHandle);
/* USER CODE END EXTI15_10_IRQn 0 */
/* USER CODE BEGIN EXTI15_10_IRQn 1 */
/* USER CODE END EXTI15_10_IRQn 1 */
The reading task is as below:
void imu_task_entry(void *argument)
extern osSemaphoreId_t mpu6050_data_readyHandle;
imus_init();
imus[0]->reset(imus[0]);
PacketReportIMU_Raw_TypeDef report;
for(;;) {
osSemaphoreAcquire(mpu6050_data_readyHandle, osWaitForever);
imus[0]->update(imus[0]);
imus[0]->get_accel(imus[0], report.array.accel_array);
imus[0]->get_gyro(imus[0], report.array.gyro_array);
// printf("accel:%d,%d,%d\n", (int16_t)report.array.accel_array[0],
// (int16_t)report.array.accel_array[1],
// (int16_t)report.array.accel_array[2]);
// printf("gyro:%d,%d,%d\n", (int16_t)report.array.gyro_array[0],
// (int16_t)report.array.gyro_array[1],
// (int16_t)report.array.gyro_array[2]);
packet_transmit( &packet_controller,
PACKET_FUNC_IMU,
&report,
sizeof(PacketReportIMU_Raw_TypeDef));
By enabling the commented-out printf function, compiling, and burning the program, you can see the IMU attitude values sent to the host computer in the serial port.
Note: The IMU sends data at a high frequency. It is best to turn off IMU printing when testing other messages to avoid interference.
Handle Message Upload
When the gamepad receiver is plugged in, it continuously triggers the gamepad data reception task and uploads the received gamepad data. In the Hiwonder/System/gamepad_handle.c file, the USBH_HID_EventCallback() function handles the event callback for gamepad data reception. The program logic is as follows:
When the microcontroller receives gamepad data, it enters this event callback function once.
The
USBH_HID_GetGamepadInfo()function assigns the retrieved gamepad data structure to the info pointer.The content of info is assigned to the report structure for sending.
The gamepad data is uploaded to the host computer via the packet_transmit() function.
void USBH_HID_EventCallback(USBH_HandleTypeDef *phost) { extern osMessageQueueId_t moving_ctrl_queueHandle; static HID_GAMEPAD_Info_TypeDef last_info; static char last_direction_msg = 'I'; static char last_button = 'R'; switch(USBH_HID_GetDeviceType(phost)) { case 0xFF: {/* Handle data */ HID_GAMEPAD_Info_TypeDef *info = USBH_HID_GetGamepadInfo(phost); if(info == NULL) { break; } PacketReportGamepadTypeDef report; report.buttons = info->buttons; report.hat = info->hat; report.lx = info->lx; report.ly = info->ly; report.rx = info->rx; report.ry = info->ry; packet_transmit(&packet_controller, PACKET_FUNC_GAMEPAD, &report, sizeof(PacketReportGamepadTypeDef)); memcpy(&last_info, info, sizeof(HID_GAMEPAD_Info_TypeDef)); break; } default: break; } }
packet_transmit() Function Source Code Analysis
In the Hiwonder/Misc/packet.c file, the packet_transmit() function is defined as follows:
int packet_transmit(struct PacketController *self, uint8_t func, void* data, size_t data_len)
struct PacketRawFrame *p = packet_serialize(func, data, data_len);
if(NULL != p) {
return self->send_packet(self, p);
return -2;
Parameter 1: Protocol controller object
Parameter 2: Function code
Parameter 3: Data to be sent
Parameter 4: Length of the data
/* Externally exposed variables */
struct PacketController packet_controller; /* Protocol controller instance */
enum PACKET_FUNCTION {
PACKET_FUNC_SYS = 0,
PACKET_FUNC_LED,
PACKET_FUNC_BUZZER,
PACKET_FUNC_MOTOR,
PACKET_FUNC_KEY,
PACKET_FUNC_IMU,
PACKET_FUNC_SBUS,
PACKET_FUNC_NONE,
When sending data, you only need to pass in the default protocol controller object, defined in the Hiwonder/Porting/packet_porting.c file. The function codes are defined in the packet.h file, with nine available function codes. Detailed information can be found in “3.14 RRC Communication Protocol with the Host Computer Analysis”
The
packet_serialize()function combines the function code, data, and data length into a protocol structure and returns it. Thepacket_serialize()function process is as follows:
(1) Create a structure variable and assign it to pointer p.
(2) Sequentially assign the protocol header, data length, function code, data, and CRC checksum to p.
(3) Return the structure pointed to by p.
struct PacketRawFrame* packet_serialize(uint8_t func, void* data_raw, size_t data_len)
struct PacketRawFrame *p = LWMEM_RAM_MALLOC(data_len + 6);
if(NULL != p) {
p->start_byte1 = PROTO_CONST_STARTBYTE1;
p->start_byte2 = PROTO_CONST_STARTBYTE2;
p->data_length = data_len;
p->function = func;
memcpy(p->data_and_checksum, data_raw, data_len);
uint8_t checksum = checksum_crc8(&p->function, data_len + 2);
p->data_and_checksum[data_len] = checksum;
return p;
The
send_packet()structure member function uploads the assembled protocol data. The send_packet() function sends the data to the packet_tx queue.static int send_packet(struct PacketController *self, struct PacketRawFrame *frame) { return osMessageQueuePut(packet_tx_queueHandle, &frame, 0, 10); }
The packet_tx_task_entry() protocol packet sending task function, defined in packet_porting.c, completes the data transmission to the host computer.
void packet_tx_task_entry(void *argument)
for(;;) {
/* Wait for send idle signal */
osSemaphoreAcquire(packet_tx_idleHandle, osWaitForever);
/* Retrieve data from send queue */
osStatus_t status = osMessageQueueGet( packet_tx_queueHandle,
&packet_controller.tx_dma_buffer,
NULL,
osWaitForever);
if(osOK == status) {
/* Register DMA transmission complete callback */
HAL_UART_RegisterCallback( &huart3,
HAL_UART_TX_COMPLETE_CB_ID,
packet_dma_transmit_finished);
/* Trigger DMA transmission */
HAL_UART_Transmit_DMA( &huart3,
(uint8_t*)packet_controller.tx_dma_buffer,
packet_controller.tx_dma_buffer->data_length + 5);
The protocol data is sent via the UART serial port to the conversion circuit, which converts the data to USB format and sends it to the host computer.
This completes the entire protocol sending process.
3.16 RRC and Host Computer Communication Receiving Processing Source Code Analysis
3.16.1 Instructions for Modifying Host Computer Routine (MUST READ!!!)
Change Chassis Type
// #define BATTERY_LOW_ALARM_THRESHOLD 6300 /* Low voltage alarm threshold, unit: millivolt */
3.16.2 Program Logic
This section mainly analyzes the source code for receiving and processing communication between the RRC development board and the host computer.
3.16.3 Hardware Connection
The hardware connection diagram is as below:
3.16.4 Program Download
The example for this section is “RosRobotControllerM4-armclang”.
3.16.5 Program Outcome
After porting the ROS package, you can control the car’s LED lights on and off, activate the buzzer, rotate the encoder motors, rotate PWM servos, and rotate bus servos by calling the host computer interface.
3.16.6 PIN Info Configuration
The development board’s microcontroller uses UART3 serial port, which communicates with the host computer via a conversion circuit to USB signal. In STM32CubeMX software, you can view pin information. According to the diagram below, the corresponding chip pins are: PD8 and PD9.
3.16.7 Source Code
The program source code for this session is located in ‘3.16 RRC and Host Computer Communication Receiving Processing Source Code Analysis’. The program framework is designed according to the functionality, as shown in the diagram below.
The messages sent by the host computer to control the development board are divided into five categories: LED control messages, buzzer control messages, encoder motor control messages, PWM servo control messages, and bus servo control messages.
Reception of LED Control Messages
The packet_led_handle() function in the Hiwonder/System/packet_handle.c file is the callback function for handling LED serial commands. Upon receiving LED control messages, it enters this callback function to execute LED control. The specific program is shown in the diagram below:
static void packet_led_handle(struct PacketRawFrame *frame)
LedCommandTypeDef *cmd = (LedCommandTypeDef*)frame->data_and_checksum;
uint8_t led_id = cmd->led_id - 1;
if(led_id < 1) { /* IDs all start from 1 */
led_flash(leds[led_id], cmd->on_time, cmd->off_time, cmd->repeat);
The parameter frame of packet_led_handle() is a pointer parameter used to store the control information sent by the host computer. This data is strictly stored according to the LED control structure LedCommandTypeDef. Therefore, the data stored in the frame can be directly converted into the LED control structure to obtain the correct control parameters. The program flow is as follows:
Convert the data into the LED control structure.
Check if the LED ID number is correct:
If correct, use the structure data to control the LED change.
If incorrect, skip directly.
The definition of the LED control structure LedCommandTypeDef is as follows:
typedef struct {
uint8_t led_id;
uint16_t on_time;
uint16_t off_time;
uint16_t repeat;
} LedCommandTypeDef;
For specific parameter details, please refer to the LED control section in the ‘3.14 RRC Communication Protocol with the Host Computer Analysis’ document.
Reception of Buzzer Control Messages
The packet_buzzer_handle() function in the Hiwonder/System/packet_handle.c file is the callback function for handling buzzer serial commands. Upon receiving a buzzer control message, it enters this callback function to execute buzzer control. The specific program is shown in the diagram below:
static void packet_buzzer_handle(struct PacketRawFrame *frame)
BuzzerCommandTypeDef *cmd = (BuzzerCommandTypeDef*)frame->data_and_checksum;
buzzer_didi(buzzers[0], cmd->freq, cmd->on_time, cmd->off_time, cmd->repeat);
The parameter ‘frame’ is strictly stored according to the BuzzerCommandTypeDef buzzer control structure, so converting the data stored in ‘frame’ directly into the buzzer control structure retrieves the correct control parameters. The program flow is as follows:
①:Convert the data into the buzzer control structure.
②:Use the structure data to control the buzzer activation.
The definition of the BuzzerCommandTypeDef buzzer control structure is as follows:
typedef struct {
uint16_t freq;
uint16_t on_time;
uint16_t off_time;
uint16_t repeat;
} BuzzerCommandTypeDef;
For specific parameter details, please refer to the buzzer control section in the ‘3.14 RRC Communication Protocol with the Host Computer Analysis’ document.
Reception of Encoder Motor Control Messages
The packet_motor_handle() function in the Hiwonder/System/packet_handle.c file is the callback function for handling encoder motor serial commands. Upon receiving an encoder motor control message, it enters this callback function to execute encoder motor control. The specific program is shown in the diagram below:
static void packet_motor_handle(struct PacketRawFrame *frame)
switch(frame->data_and_checksum[0]) {
case 0: {
MotorSingalCtrlCommandTypeDef *mscc = (MotorSingalCtrlCommandTypeDef *)frame->data_and_checksum;
motors[mscc->motor_id]->pid_controller.set_point = mscc->speed;
break;
case 1: {
MotorMutilCtrlCommandTypeDef *mmcc = NULL;
mmcc = (MotorMutilCtrlCommandTypeDef *)frame->data_and_checksum;
for(int i = 0; i < mmcc->motor_num; ++i) {
motors[mmcc->element[i].motor_id]->pid_controller.set_point = mmcc->element[i].speed;
break;
case 2: {
MotorSingalStopCommandTypeDef *mssc = (MotorSingalStopCommandTypeDef *)frame->data_and_checksum;
motors[mssc->motor_id]->pid_controller.set_point = 0;
break;
case 3: {
MotorMultiStopCommandTypeDef *mmsc = (MotorMultiStopCommandTypeDef *)frame->data_and_checksum;
for(int i = 0; i < 4; ++i) {
if(mmsc->motor_mask & (0x01 << i)) {
motors[i]->pid_controller.set_point = 0;
break;
default:
break;
To streamline the control of encoder motors, the first control data represents the sub-command for motor control. There are a total of 4 sub-commands, each corresponding to a specific structure and functionality as follows:
(MotorSingalCtrlCommandTypeDef) Single motor movement
(MotorMutilCtrlCommandTypeDef) Multiple motor movement
(MotorSingalStopCommandTypeDef) Single motor stop
(MotorMultiStopCommandTypeDef) Multiple motor stop functions
The parameter frame is strictly stored according to the corresponding structure of encoder motor control based on each sub-command. Therefore, converting the data stored in frame directly into the corresponding encoder motor control structure retrieves the correct control parameters. The program flow is as follows:
①:Read the first data to determine which sub-function it corresponds to.
②:Enter the specified sub-function section and convert the incoming data into the corresponding sub-function structure parameters.
③:Use the structure parameters to control the movement of the encoder motor.
The definitions of various structures for encoder motor control are as follows:
typedef struct {
uint8_t cmd;
uint8_t motor_id;
float speed;
} MotorSingalCtrlCommandTypeDef;
typedef struct {
uint8_t cmd;
uint8_t motor_num;
struct {
uint8_t motor_id;
float speed;
} element[];
} MotorMutilCtrlCommandTypeDef;
typedef struct {
uint8_t cmd;
uint8_t motor_id;
} MotorSingalStopCommandTypeDef;
typedef struct {
uint8_t cmd;
uint8_t motor_mask;
} MotorMultiStopCommandTypeDef;
For specific parameter details, please refer to the encoder motor control section in the ‘3.14 Analysis of RRC and Host Computer Communication Protocol’ document.
Reception of Bus Servo Control Messages
The packet_serial_servo_handle() function in the Hiwonder/System/packet_handle.c file serves as the callback function for handling bus servo serial commands. Upon receiving a bus servo control message, the program enters this callback function to execute bus servo control. The specific program is illustrated in the diagram below:
static void packet_serial_servo_handle(struct PacketRawFrame *frame)
PacketReportSerialServoTypeDef report;
case 0x01: { /* Servo control */
SerialServoSetPositionCommandTypeDef *cmd = (SerialServoSetPositionCommandTypeDef *)frame->data_and_checksum;
for(int i = 0; i < cmd->servo_num; i++) {
serial_servo_set_position(cmd->elements[i].servo_id,
cmd->elements[i].position,
cmd->duration);
break;
Bus servos have multiple sub-commands corresponding to different sub-functions, with the first control data representing the sub-command for motor control.
The parameter frame is strictly stored according to the control structure corresponding to the bus servo sub-function. If it’s a sub-command for controlling motion, it’s stored according to the SerialServoSetPositionCommandTypeDef structure to store control parameters. By directly converting the data stored in frame into the bus servo control structure, the correct control parameters can be obtained. The program flow is as follows:
1. Read the first data to determine which sub-function it corresponds to.
2. Enter the specified sub-function section and convert the incoming data into the corresponding sub-function structure parameters.
3. Use the structure parameters to control the movement of the bus servo.
The definition of the bus servo control structure SerialServoSetPositionCommandTypeDef is as follows:
// Serial Servo Basic Members
typedef struct {
uint8_t cmd;
uint8_t servo_id;
} SerialServoCommandTypeDef;
// Serial Servo
typedef struct {
SerialServoCommandTypeDef base;
uint16_t duration;
struct {
uint8_t servo_id;
uint16_t position;
} elements[];
} SerialServoSetPositionCommandTypeDef;
For specific parameter details, please refer to the bus servo control section in the ‘3.14 RRC Communication Protocol with the Host Computer Analysis’ document.
Source Code Analysis of Serial Protocol Reception Task
The packet_rx_task_entry() function in the Hiwonder/Porting/packet_porting.c file serves as the entry point for the serial protocol reception task. This task handles messages received from the serial port and executes control. The program logic is as follows:
①:Initialize and clear the semaphore in the queue.
②:Register the callback function packet_uart_error_callblack() for handling serial port receive error events.
③:Register callback functions corresponding to serial port message function codes with the message controller.
④:Start the hardware reception of the serial port and register the message processing callback function.
⑤:Loop for receiving and processing:
(1) Wait to acquire the semaphore. When a message is received, a semaphore is sent in the interrupt, which can be obtained here.
(2) Process the message and control the car functions.
The reception task program is as below:
void packet_rx_task_entry(void *argument)
osSemaphoreAcquire(packet_rx_not_emptyHandle, 0); /* By default, the semaphore is non-zero; clear it first */
__HAL_UNLOCK(&huart3);
packet_start_recv();
for(;;) {
osSemaphoreAcquire(packet_rx_not_emptyHandle, osWaitForever); /* Wait for receive buffer to be non-empty */
packet_recv(&packet_controller);
Among them, the packet_dma_receive_event_callback() function prevents serial port failure due to startup issues by restarting when a serial port error occurs. The function is defined as follows:
static void packet_uart_error_callback(UART_HandleTypeDef *huart)
HAL_UART_AbortReceive(&huart3);
/* Register Receive Event Callback */
HAL_UART_RegisterRxEventCallback( &huart3,
packet_dma_receive_event_callback);
/* Set Receive to DMA Mode */
HAL_UARTEx_ReceiveToIdle_DMA( &huart3,
packet_controller.rx_dma_buffer[packet_controller.rx_dma_buffer_index],
PACKET_RX_DMA_BUFFER_SIZE);
The packet_handle_init() function registers the callback functions for the corresponding function codes. The function is defined as follows:
void packet_handle_init(void)
packet_register_callback(&packet_controller, PACKET_FUNC_LED, packet_led_handle);
packet_register_callback(&packet_controller, PACKET_FUNC_BUZZER, packet_buzzer_handle);
packet_register_callback(&packet_controller, PACKET_FUNC_MOTOR, packet_motor_handle);
packet_register_callback(&packet_controller, PACKET_FUNC_BUS_SERVO, packet_serial_servo_handle);
The packet_start_recv() function starts the serial port reception hardware and registers the interrupt handling callback function. The function is defined as follows:
void packet_start_recv(void)
HAL_UART_RegisterCallback(&huart3, HAL_UART_ERROR_CB_ID, packet_uart_error_callblack);
HAL_UART_RegisterRxEventCallback(&huart3, packet_dma_receive_event_callback); /* Register receive event callback */
HAL_UARTEx_ReceiveToIdle_DMA(&huart3, packet_controller.rx_dma_buffers[packet_controller.rx_dma_buffer_index], PACKET_RX_DMA_BUFFER_SIZE);
The packet_dma_receive_event_callback() function is triggered during an interrupt. It pushes the received data into the data buffer and sends a semaphore to start the processing program in the reception task. The function is defined as follows:
static void packet_dma_receive_event_callback(UART_HandleTypeDef *huart, uint16_t length)
int cur_index = packet_controller.rx_dma_buffer_index; /* Get the index number of the current DMA buffer */
packet_controller.rx_dma_buffer_index ^= 1;
lwrb_write(packet_controller.rx_fifo, packet_controller.rx_dma_buffers[cur_index], length); /* Write the received data to the FIFO ring buffer */
osSemaphoreRelease(packet_rx_not_emptyHandle); /* Set the receive buffer non-empty signal */
The received data is ultimately processed in the packet_recv() function within the reception task. The packet_recv() function handles the serial protocol by analyzing the received serial data. After parsing the correct data, it calls the callback function for the corresponding function code to process the control message in the data segment. The program code is as follows:
void packet_recv(struct PacketController *self)
uint8_t data[PACKET_PARSE_BUFFER_SIZE];
size_t available = lwrb_get_full(self->rx_fifo);
size_t readed_len = 0;
uint8_t crc = 0;
while(available > 0) {
available = available > PACKET_PARSE_BUFFER_SIZE ? PACKET_PARSE_BUFFER_SIZE : available;
readed_len = lwrb_read(self->rx_fifo, data, available);
for(int i = 0; i < readed_len; ++i) {
//printf("%0.2X ", data[i]);
switch(self->state) {
case PACKET_CONTROLLER_STATE_STARTBYTE1: /* Process Frame Header Marker 1 */
self->state = PROTO_CONST_STARTBYTE1 == data[i] ?
PACKET_CONTROLLER_STATE_STARTBYTE2 :
PACKET_CONTROLLER_STATE_STARTBYTE1;
break;
case PACKET_CONTROLLER_STATE_STARTBYTE2: /* Process Frame Header Marker 2 */
self->state = PROTO_CONST_STARTBYTE2 == data[i] ?
PACKET_CONTROLLER_STATE_FUNCTION :
break;
case PACKET_CONTROLLER_STATE_FUNCTION: /* Process Frame Function Code */
self->state = PACKET_FUNC_NONE > data[i] ?
PACKET_CONTROLLER_STATE_STARTBYTE1 :
PACKET_CONTROLLER_STATE_LENGTH;
if(PACKET_CONTROLLER_STATE_LENGTH == self->state) {
self->frame.function = data[i];
break;
case PACKET_CONTROLLER_STATE_LENGTH: /* Process Frame Data Length */
self->frame.data_length = data[i];
self->state = (0 == self->frame.data_length) ?
PACKET_CONTROLLER_STATE_CHECKSUM :
PACKET_CONTROLLER_STATE_DATA;
self->data_index = 0;
break;
case PACKET_CONTROLLER_STATE_DATA: /* Process Frame Data */
self->frame.data_and_checksum[self->data_index] = data[i];
++self->data_index;
if(self->data_index >= self->frame.data_length) {
self->state = PACKET_CONTROLLER_STATE_CHECKSUM;
break;
case PACKET_CONTROLLER_STATE_CHECKSUM: /* Process Checksum */
self->frame.data_and_checksum[self->frame.data_length] = data[i];
crc = checksum_crc8((uint8_t*)&self->frame.function, self->frame.data_length + 2);
/* Checksum Failed, Skip Execution */
if(crc == self->frame.data_and_checksum[self->frame.data_length]) {
if(NULL != self->handles[self->frame.function]) {
if(self->handles[self->frame.function] != NULL) {
self->handles[self->frame.function](&self->frame);
memset(&self->frame, 0, sizeof(struct PacketRawFrame));
self->state = PACKET_CONTROLLER_STATE_STARTBYTE1;
break;
default:
break;
In the checksum verification segment of the above program, the callback function for the corresponding function code is called, achieving the host computer control functionality. The code snippet is shown below:
3.17 RRC Bluetooth Control Reception and Processing Source Code Analysis
3.17.1 Program Logic
This section mainly covers controlling the car’s movement and pan-tilt servo rotation via the app’s Bluetooth.
3.17.2 Hardware Connection
Correctly insert the Bluetooth module into the car control board. The installation position and orientation are shown in the diagram below:
3.17.3 Program Download
The example for this section is ‘rosrobotcontrollerm4_app_ctl’.
3.17.4 APP Usage
The car supports Bluetooth control via the app, allowing you to control its movement in three modes: button remote control, gravity sensing, and joystick remote control. The movement speed is measured in mm/s (millimeters per second). You can control the speed of the car chassis, and each press of the acceleration or deceleration button increases or decreases the speed by 50 mm/s. Additionally, you can control the rotation and centering of the pan-tilt on the car.
Bluetooth App Use Instructions
1. Bluetooth App Interface Introduction
The top left corner provides a detailed introduction to the app.
connected, the Bluetooth icon flashes, and the battery voltage is not displayed.
The left section is for selecting the car’s movement control mode and control interface.
The top right section is for controlling the two-degree-of-freedom gimbal. The joystick controls the left and right rotation of the gimbal, while the buttons control the gimbal’s tilt and centering functions.
The middle right section displays the phone’s gravity sensor values for monitoring the car’s gravity sensing mode.
The bottom right section has the acceleration and deceleration buttons for the car. Each press increases or decreases the car’s speed by 50 mm/s.
The app offers three control modes: button mode, gravity sensing mode, and joystick mode:
(1) Button Mode: This mode allows the car to move forward, backward, rotate left, turn left forward, rotate right, turn right forward, stop, move left, and move right (refer to the previous diagram).
(2) Gravity Sensing Mode: The movements are the same as in button mode, but the car is controlled by tilting the phone. Focus on the gravity sensor values. When the X-axis value is less than -3, the car moves forward; when it is greater than 3, the car moves backward. When the Y-axis value is less than -3, the car moves left; when it is greater than 3, the car moves right.
(3) Joystick Mode: This mode adds two more movements compared to button mode, allowing for upper left, upper right, lower left, and lower right turns, corresponding to wide turns in each direction.
Whether the car can perform a spinning motion depends on its structure. Mecanum wheel cars and tracked cars can spin, while Ackermann steering cars and four-wheel differential cars can only turn. Only Mecanum wheel cars can perform lateral movements; the other cars will not respond to the lateral movement buttons.
2. Turn on the car’s power, and then turn on Bluetooth and the app on your phone.
Important:
Please ensure the Bluetooth module is properly connected to the RRC control board before powering it on. This is necessary for the RRC to correctly initialize its Bluetooth functionality.
If the Bluetooth module is connected after the board is powered on, the RRC will not emit a beep upon successful Bluetooth connection, and the mobile app will not be able to control the RRC as expected.
If you must connect the Bluetooth module after powering on, please press the onboard RST button to reset the program and enable normal operation.
When not connected, the light on the Bluetooth module will flash.
Once the car’s Bluetooth is connected, the indicator light on the Bluetooth module will remain solid, and the buzzer will beep once.
3. Click on the Bluetooth icon in the top right corner of the app to search for and connect to the car’s Bluetooth, enabling control of the car’s movement.
Turn on Bluetooth on your phone. Open the app and click on the Bluetooth icon in the top right corner. Once you find the car’s Bluetooth, click to connect. Once connected, the indicator light on the car’s Bluetooth module will remain solid, and the car’s battery voltage will be displayed in the top right corner of the app.
3.17.5 PIN Info Configuration
By checking the pin information using STM32CubeMX software, you can find that the communication between the Bluetooth module and the microcontroller is through UART communication. The corresponding chip pins are: PD6 and PD5.
3.17.6 Source Code Analysis
Control Diagram
As shown in the diagram above, the process is as follows:
The mobile app sends signals to the Bluetooth module, which communicates with the microcontroller via UART.
When the Bluetooth receives information, it triggers a Bluetooth interrupt, receives the Bluetooth information, and sends it to the motor control task through an RTOS queue, thereby controlling the car’s movement.
After the battery voltage is periodically detected, the voltage data is sent to the Bluetooth transmission task through a queue. The Bluetooth transmission task sends the data to the Bluetooth module via UART, and then the Bluetooth module sends the information to the mobile app, displaying it in the top right corner of the app.
Code Analysis
Analysis of the Code for UART Interrupt Reception of Bluetooth Module Data:
In the ‘bluetooth_porting.c’ file under the ‘Hiwonder/Porting’ project folder, the Bluetooth receive interrupt event callback function is registered.
In the ‘bluetooth_porting.c’ file, the bluetooth_dma_rx_event_callback() callback function sends the information received from the Bluetooth module through the ‘moving_ctrl’ queue to the motor control task.
The motor control task receives and controls the motor movement.
/* User Entry Function */
void app_task_entry(void *argument)
/* Declare External Handles */
// Buzzer Handle
extern osTimerId_t buzzer_timerHandle;
// Battery Monitoring Handle
extern osTimerId_t battery_check_timerHandle;
// Motion Control Queue Handle
// The gamepad signal is pushed in the USBH_HID_EventCallback() callback function in gamepad_handle.c
// Retrieve it in the user entry function to control the car's movement
/* Hardware Initialization */
motors_init(); // Motor Initialization
pwm_servos_init(); // Gimbal Servo Initialization
buzzers_init(); // Buzzer Initialization
// Start the buzzer timer to operate in the interrupt, and call the interface function later
// Parameter 1: Timer Handle, Parameter 2: Timer Working Interval (ms)
osTimerStart(buzzer_timerHandle, BUZZER_TASK_PERIOD);
// Start the battery health timer to monitor the battery in real time
osTimerStart(battery_check_timerHandle, BATTERY_TASK_PERIOD);
char msg = '\0';
uint8_t msg_prio;
// Initialize the motion control queue (Parameter: Queue Handle)
osMessageQueueReset(moving_ctrl_queueHandle);
// Initialize Chassis Motor Motion Parameters
chassis_init();
// Select Chassis Type
// Note: For four-wheel differential chassis, use CHASSIS_TYPE_TI4WD !!!
set_chassis_type(CHASSIS_TYPE_TI4WD);
The ‘app_task_entry()’ function in the ‘app.c’ file under the ‘Hiwonder/System’ project folder is the entry function for the motor control task.
Within the for loop, it waits for information from the ‘moving_ctrl’ queue. If there is information available, it passes it to the chassis control function to control the movement of the car.
uint8_t msg_prio;
// Initialize the motion control queue (Parameter: Queue handle)
// Initialize chassis motor motion parameters
chassis_init();
// Select chassis type
// Note: For four-wheel differential chassis, use CHASSIS_TYPE_TI4WD!!!
// Loop: In an RTOS task loop, there must be osDelay or other system blocking functions, otherwise it will cause system exceptions
for(;;) {
// Receive information from the motion control queue. If the acquisition exceeds 100ms, it is considered unsuccessful, stop the motor, and skip this loop
// osMessageQueueGet() retrieves messages from the queue
// Parameter 1: Message queue handle
// Parameter 2: Address of the object to be placed (here is the address of char type)
// Parameter 3: Message priority
// Parameter 4: Timeout setting (can set the waiting acquisition time)
if(osMessageQueueGet(moving_ctrl_queueHandle, &msg, &msg_prio, 100) != osOK) {
chassis->stop(chassis);
continue;
printf("msg: %c\r\n", msg); // Debug print
ti4wd_control(msg); // Chassis control function
Battery Voltage Timed Monitoring
In the ‘app_task_entry()’ function in the ‘app.c’ file under the ‘Hiwonder/System’ project folder, a timer is started to check the voltage every 50ms.
The ‘battery_check_timer_callback()’ function in the ‘battery_handle.c’ file under the ‘Hiwonder/System’ project folder is the callback function for the timer. It runs every time the 50ms interval is reached.
This function first checks if the ADC sampling value is correct. If it is, it converts it into a battery voltage value and continues sampling. Then, it checks if the number of detections has reached (1 * 1000 / BATTERY_TASK_PERIOD) times (i.e., 200 times, totaling 1 second). When the time is up, it sends the battery data once to the ‘bluetooth_tx’ queue.”
void battery_check_timer_callback(void *argument)
if(adc_value[0] != 0 && adc_value[0] != 4095) {
/* 1210.0 is the internal reference voltage value, 100k + 10k resistor voltage division, the actual voltage is 11 times the measured voltage */
float volt = 1210.0f / ((float)adc_value[0]) * ((float)adc_value[1]) * 11.0f;
volt = volt > 20000 ? 0 : volt;
battery_volt = battery_volt == 0 ? volt : battery_volt * 0.95f + volt * 0.05f;
printf("%d\r\n", adc_value[0]);
HAL_ADC_Start_DMA(&hadc1, (uint32_t*)adc_value, 2);
#if ENABLE_BLUETOOTH&&ENABLE_BLUETOOTH_BATTERY_REPORT
static int battery_report_count = 0;
battery_report_count++;
if(battery_report_count > (int)(1 * 1000 / BATTERY_TASK_PERIOD)) { /* Periodically send Bluetooth voltage report */
char msg[8];
sprintf(&msg[1], "V%dV", (int)(battery_volt + 0.5f)); /* Organize Bluetooth battery message */
printf("%s\r\n", &msg[1]);
msg[0] = strlen(&msg[1]);
osMessageQueuePut(bluetooth_tx_queueHandle, msg, 0, 0); /* Push into send queue */
#endif
Bluetooth Sending Task
In the ‘bluetooth_porting.c’ file under the ‘Hiwonder/Porting’ project folder, the ‘bluetooth_task_entry()’ function is the entry function for the Bluetooth transmission task.
Within the for loop, it waits for idle signals (time when the microcontroller is not processing other tasks). If there is idle time, it retrieves the battery data from the ‘bluetooth_tx’ queue. Then, it checks if the UART is ready. If it is, it sends the battery message to the Bluetooth module.
* @brief Bluetooth Task Entry
* @param argument Reserved
* @retval void
void bluetooth_task_entry(void *argument)
/* Receive processing relies on receive interrupt trigger, no task is used
Use ReceiveToIdle_DMA for reception, this function will interrupt when DMA buffer is full or when reception is idle and trigger receive event callback
The processing of received data is completed in the callback in the receive event callback
HAL_UART_RegisterRxEventCallback(&huart2, bluetooth_dma_rx_event_callback); /* Register receive event callback */
HAL_UARTEx_ReceiveToIdle_DMA(&huart2, rx_dma_buffers[buffer_index], BLUETOOTH_DMA_BUFFER_SIZE); /* Start reception */
/* Send processing, triggered by queue */
uint8_t tx_buffer[8];
for(;;) {
osSemaphoreAcquire(bluetooth_tx_idleHandle, osWaitForever); /* Wait for send idle signal */
osStatus_t status = osMessageQueueGet(bluetooth_tx_queueHandle, tx_buffer, NULL, osWaitForever);
HAL_UART_RegisterCallback(&huart2, HAL_UART_TX_COMPLETE_CB_ID, bluetooth_dma_tx_complete_callback);
/* The first byte of the message is the length of the data to be sent, and the data to be sent starts from the second byte */
HAL_UART_Transmit_DMA(&huart2, &tx_buffer[1], tx_buffer[0] > 7 ? 7 : tx_buffer[0]); /* Trigger DMA transmission */
Appendix:
The Bluetooth Secondary Development Control Protocol Table is as follows:
| Character | Contained Info |
| A | Go forward |
| B | Turn left with a wide curve |
| C | Turn left |
| D | Turn left with a wide curve to the rear left |
| E | Reverse |
| F | Turn right with a wide curve to the rear right |
| G | Turn right |
| H | Turn right with a wide curve to the front right |
| I | Chassis stop |
| J | Pan-tilt downward rotation |
| K | |
| L | Pan-tilt rotation to the left |
| M | |
| N | Pan-tilt rotation upwards |
| O | |
| P | Pan-tilt rotation to the right |
| Q | |
| R | Pan-tilt reset |
| f | One short beep from the buzzer |
| S | Speed up by one level |
| j | Slow down by one level |
| n | Left lateral movement (only available for Mecanum wheel chassis) |
| l | Right lateral movement (only available for Mecanum wheel chassis) |
| p | Phone receives battery voltage, with the character 'V' as a delimiter, and the battery voltage string in between |
| VxxxV | Pan-tilt reset |
Examples:
Need continuous forward movement of the car chassis: The phone Bluetooth sends the character ‘A’ to the Bluetooth module at a frequency of 10 times per second. When the transmission stops, the car chassis stops moving.
Need the buzzer to beep once: The phone Bluetooth sends the character ‘S’ to the Bluetooth module, and the buzzer beeps once.
Need the pan-tilt to rotate left: The phone Bluetooth sends the character ‘L’ to the Bluetooth module at a frequency of 10 times per second. When the transmission stops, the pan-tilt stops rotating.
Need to increase the speed of the car chassis by one level: The phone Bluetooth sends the character ‘j’ to the Bluetooth module, and the speed of the car chassis increases by one level.
Phone Bluetooth receives the battery voltage of the car chassis: If the phone Bluetooth receives the string “V7400V”, it means the current battery voltage is 7400mV, or 7.4V.
3.18 RCC SPI LCD Screen Driver Principles and Source Code Analysis
3.18.1 LCD Parameter Description
Physical Diagram
| Size | 0.96 inch | Display area | 10.8X21696(mm) |
| Operating voltage | 3.3V | Physical dimension | 24*30(mm) |
| Module weight | 5g | Connector type | SPI port |
| Control chip | ST7335 | Number of PIN | 7PIN |
| Displayed color | 65K full-color | Operating temperature | -20°C~70°C |
| Material | The brand new IPS color screen features colors that are more vibrant compared to regular TET LCD screens. | ||
| Resolution | The display orientation of 80*160 can be adjusted, supporting both landscape and portrait modes | ||
| Pin definition | 1> GND (power ground); 2> VCC (power positive 3.3~5V); 3> SCL (SPI clock line) 4> SDA (SPI data line); 5> RES (OLED reset - OLED needs to be reset once after powering on) 6> DC (SPI data/command selection pin) 7> BLK (LCD backlight control - the default can be left floating at a low level to turn off the backlight) |
Size & Structure
Use Instructions
For information on how to use the LCD, please refer to: “3.19 RCC LVGL Introduction and Source Code Analysis”.
3.18.2 Principle
The ST7735 is an SPI-driven LCD screen, which sends register commands and display data to operate the LCD via SPI. The timing diagram of the ST7735S chip is shown below. From the diagram, it can be observed that: When CSX is at a high level, data transmission starts by pulling it low, simultaneously SCL is pulled low, SDA starts transmitting data, then SCK is pulled high. This sequence repeats 8 times, after which CS is pulled high, indicating the completion of data writing.
3.18.3 Physical Image of the Module
The physical images of the ST7735S LCD screen are shown in the following two pictures:
Pin connection rules (a total of 8 pins are connected to):
| Wire Name | Corresponding Pin or Function |
| GND | GND |
| VCC | 3.3V |
| SCL | SPI clock wire |
| SDA | SPI data writing |
| RES | Reset pin |
| DC | Command mode and data mode switching bit, low level for command mode, high level for data mode |
| CS | SPI Chip Select (CS) |
| BLK | Backlight, high level for brightness, low level for off |
The wiring positions on the STM32 development board are as shown in the diagram below:
Connect the LCD module to the position indicated by the red box in the diagram above. After connecting, it should appear as shown in the diagram below:
Content Expansion:
SPI stands for Serial Peripheral Interface, which was first introduced by Motorola as a synchronous serial transmission protocol. It is also a serial peripheral chip extension interface for microcontrollers. SPI is a high-speed, full-duplex, synchronous communication bus, allowing data to be sent and received at the same time. SPI does not define a speed limit and typically achieves speeds of up to or even exceeding 10 Mbps.
3.18.4 Source Code Analysis
After understanding the driving principles of the LCD screen, you can design the program structure diagram accordingly (as shown in section 2.1), and then write code for experimental testing. This section will design a program to display different colors on the LCD screen.
Program Structure
The program structure diagram is shown in the figure below:
From the diagram, it can be seen that when driving the LCD screen, it is necessary to initialize the LCD screen according to the LCD principle first, then enable the LCD screen before the program execution, and finally write functions based on the designed effects.
The following content involves the program located in the folder ‘RosRobotControllerM4_LCD’ in the current directory, under the section titled ‘RCC SPI LCD Screen Driver Example’ The program can be opened and viewed using Keil5 software.
#include "cmsis_os2.h"
#include "lwmem_porting.h"
#include "global.h"
#include "lvgl.h"
#include "lv_port_disp.h"
#include "global.h"
#include "adc.h"
void lcds_init(void); // LCD screen initialization
// Initialize LCD screen parameters
lcds_init();
// Refresh LCD screen
lcd->reset(lcd);
for(;;) {
// Enable LCD screen
lcd->display_on(lcd);
// Set LCD screen color
lcd->set_fill_image(lcd,ST7735_RED);
printf("LCD_simple_show_test\r\n");
1. Initialize screen
Before powering on the screen, it’s necessary to initialize the parameters of the LCD screen, which are located in the “Hiwonder/System/app.c” file. The function is as shown below:
lcds_init();
The image below illustrates the content of the lcd_init function:
ST7735objectTypeDef *st7735 = LWMEM_CCM_MALLOC(sizeof(ST7735objectTypeDef));
st7735_object_init(st7735);
st7735->base.height = 80;
st7735->base.width = 160;
st7735->x_offset = 1;
st7735->y_offset = 26;
st7735->set_backlight = lcd1_set_backlight;
st7735->set_dc_cs = lcd1_set_dc_cs;
st7735->set_res = lcd1_set_res;
st7735->spi_write = lcd1_spi_write;
st7735->sleep_ms = DelayMs;
st7735->set_dc_cs(st7735, 1, 1);
lcd = (DisplayObjectTypeDef*)st7735;
st7735 is an instantiation of a structure object st7735s, with the following parameters:
base.height represents the height, set to 80 pixels.
base.width represents the width, set to 160 pixels.
base.x_offset represents the offset in the x-direction.
base.y_offset represents the offset in the y-direction.
set_backlight sets the background contrast of the LCD screen.
set_dc_cs sets the data/command and chip select pins interface (ST7735ObjectTypeDef *self, uint32_t new_dc, uint32_t new_cs).
set_res similarly sets the data/command and chip select pins interface (ST7735ObjectTypeDef *self, uint32_t new_res).
sleep_ms represents a delay interface, indicating a time delay event, measured in milliseconds.
The final statement lcd = (DisplayObjectTypeDef*)st7735 represents the conversion of st7735 into DisplayObjectTypeDef, which is the base class inside the ST7735ObjectTypeDef structure. This facilitates subsequent program writing.
2. Enable the LCD screen
The function to enable the LCD screen is display_on. For specific implementation details, refer to the “Hiwonder/Peripherals/display_st7735.c” file.
static void export_st7735_reset(DisplayObjectTypeDef *self_base)
ST7735ObjectTypeDef *self = (ST7735ObjectTypeDef*)self_base;
self->set_backlight(self, 100);
st7735_hard_reset(self);
//st7735_soft_reset(self);
write_command(self, 0x11); //Sleep out
self->sleep_ms(self, 50); //Delay 120ms
3. Set and Display Color
After enabling the LCD screen, you can use it to display colors. The function for displaying colors can also be found in the app.c file in the Hiwonder/System directory:
The image above shows that within the for loop, the color of the LCD screen is set to ST7735_RED (red). After programming, the effect is as shown below:
Similarly, changing the function ST7735_RED to ST7735_BLUE (blue) yields the effect shown in the image below:
For more color settings, you can refer to the display_st7735.h file in the Hiwonder/Peripherals directory (the definition section is shown below). Simply change the second parameter of the set_fill_image function.
#define ST7735_BLACK 0x0000 // Black
#define ST7735_BLUE 0x001F // Blue
#define ST7735_RED 0xF800 // Red
#define ST7735_GREEN 0x07E0 // Green
#define ST7735_CYAN 0x07FF // Cyan
#define ST7735_MAGENTA 0xF81F // Magenta
#define ST7735_YELLOW 0xFFE0 // Yellow
#define ST7735_WHITE 0xFFFF // White
3.19.1 Introduction
LVGL is a free and open-source graphics library, often considered a lightweight display framework, providing all the necessary features to create embedded graphical user interfaces, including easy-to-use graphical elements, good visual effects, and low memory consumption. It is written in C language, follows the MIT license, and can be freely used and modified. LVGL supports various operating systems such as Linux, Windows, RTOS, etc., and can also run on development boards. LVGL also supports various display drivers and touchscreen drivers, making it compatible with displays of different sizes and resolutions. LVGL (Graphics Library) features lightweight, multifunctional, flexible, and portable characteristics, and it is also compatible with the C++ programming language.
3.19.2 Source Code Analysis
Source Code Structure
According to the LVGL official website’s downloaded archive (located at: “3.19 RCC LVGL Introduction and Source Code Analysis/RCC LVGL Source Code and Porting Routines/Source Code and Projects to be Ported”), proceed with program design after porting.
Source Code Structure Analysis
The upcoming program analysis will be based on the “rosrobotcontrollerm4_LVGL” project file located in “2.19 RCC LVGL Introduction and Source Code Analysis / Ported Example”. Users can refer to it for comparison.
1. Porting:
The “Porting” folder contains three C files and their corresponding header files.
Among them, lv_port_disp.c and its corresponding header file are commonly used, which contain the driver functions for driving the LVGL screen. The main functions to pay attention to inside are as follows:
lv_port_disp_init:
void lv_port_disp_init(void)
Selects the graphic buffer mode, whether to use one buffer, two buffers, or three buffers. Here, only one buffer is used.
Initializes the display driver structure.
* Initialize your display
disp_init();
Sets the screen resolution size, for example, in this case, the screen is 80x160 pixels (width x height).
disp_drv.hor_res = 160;
disp_drv.ver_res = 80;
Specifies the refresh call function. Here, the default disp_flush() function from the official example is used. This function needs to be written and completed by the user, primarily for drawing functions on the screen.
/*Used to copy the buffer's content to the display*/
disp_drv.flush_cb = disp_flush;
Sets the screen display buffer mode. Here, draw_buf_dsc_1 is chosen for low power consumption. It’s recommended to keep the default setting.
/* Example for 1) */
static lv_disp_buf_t draw_buf_dsc_1;
static lv_color_t draw_buf_1[LV_HOR_RES_MAX * 10]; /*A buffer for 10 rows*/
lv_disp_buf_init(&draw_buf_dsc_1, draw_buf_1, NULL, LV_HOR_RES_MAX * 10); /*Initialize the display buffer*/
Another important function is the refresh function (disp_flush):
/* Flush the content of the internal buffer the specific area on the display
* You can use DMA or any hardware acceleration to do this operation in the background but
* 'lv_disp_flush_ready()' has to be called when finished. */
static void disp_flush(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p)
/*The most simple case (but also the slowest) to put all pixels to the screen one-by-one*/
int32_t x;
int32_t y;
for(y = area->y1; y <= area->y2; y++) {
for(x = area->x1; x <= area->x2; x++) {
/* Put a pixel to the display. For example: */
/* put_px(x, y, *color_p)*/
color_p++;
/* IMPORTANT!!!
* Inform the graphics library that you are ready with the flushing*/
lv_disp_flush_ready(disp_drv);
This function directly provides the screen drawing interface to LVGL, allowing for the direct scanning, refreshing, and filling of individual pixels on the screen.
The lv_port_fs file is related to the file system, providing functions for reading and writing to files. Users can refer to the comments associated with each function for understanding and learning. These functions mainly include file opening, reading, writing, and closing operations.
static void *fs_open(lv_fs_drv_t *drv, const char *path, lv_fs_mode_t mode);
static lv_fs_res_t fs_close(lv_fs_drv_t *drv, void *file_p);
static lv_fs_res_t fs_read(lv_fs_drv_t *drv, void *file_p, void *buf, uint32_t btr, uint32_t *br);
static lv_fs_res_t fs_write(lv_fs_drv_t *drv, void *file_p, const void *buf, uint32_t btw, uint32_t *bw);
static lv_fs_res_t fs_seek(lv_fs_drv_t *drv, void *file_p, uint32_t pos, lv_fs_whence_t whence);
static lv_fs_res_t fs_size(lv_fs_drv_t *drv, void *file_p, uint32_t *size_p);
static lv_fs_res_t fs_tell(lv_fs_drv_t *drv, void *file_p, uint32_t *pos_p);
static void *fs_dir_open(lv_fs_drv_t *drv, const char *path);
static lv_fs_res_t fs_dir_read(lv_fs_drv_t *drv, static char *rddir_p, char *fn);
static lv_fs_res_t fs_dir_close(lv_fs_drv_t *drv, void *rddir_p);
The lv_port_indev file is related to touch screen drivers. When the screen has touch functionality, the functions inside can be called for use. For example:
static void touchpad_init(void);
static void touchpad_read(lv_indev_drv_t *indev_drv, lv_indev_data_t *data);
static bool touchpad_is_pressed(void);
static void touchpad_get_xy(lv_coord_t *x, lv_coord_t *y);
touchpad_init(void): Initializes the touchpad of the screen.touchpad_read(): Reads touch signals.touchpad_is_pressed(void): Reads press signals.touchpad_get_xy(): Retrieves the x and y coordinates of the touch position.
static void mouse_init(void);
static void mouse_read(lv_indev_drv_t *indev_drv, lv_indev_data_t *data);
static bool mouse_is_pressed(void);
static void mouse_get_xy(lv_coord_t *x, lv_coord_t *y);
static void keypad_init(void);
static void keypad_read(lv_indev_drv_t *indev_drv, lv_indev_data_t *data);
static uint32_t keypad_get_key(void);
static void encoder_init(void);
static void encoder_read(lv_indev_drv_t *indev_drv, lv_indev_data_t *data);
static void encoder_handler(void);
Similarly, the file includes functions for mouse and keyboard operations.
Control source code src file:
The src folder contains many source files of the LVGL library, including:
core: This folder contains core files of LVGL, covering many built-in initialization and driver settings. Users can call corresponding functions according to their needs.
draw: This folder deals with screen font style settings. When users need to adjust the style of their interface, they can refer to the functions in this folder for customization.
extra: This folder contains complex widgets created from other widgets, or modifications to existing widgets with special events, styles, or animations. Users can explore the contents for additional functionalities that can be used as LVGL plugins.
font: This folder contains various font styles for users to customize and beautify their interfaces. It’s important to choose fonts based on the memory size of the screen.
gpu: When the screen has a GPU driver, the contents of this folder can be called for settings.
hal: This folder provides hardware-accelerated interfaces for GPU acceleration. Users can refer to implementations in lv_port_disp.c for CPU-based hardware acceleration.
misc: This folder contains miscellaneous functionalities, such as image rotation and stretching. Users can explore the source files in this folder for function calls related to image styling.
Widgets: This folder contains pre-configured widget styles, such as sliders, buttons, and text areas.
Configuration file lv_conf.h:
This file contains macro definitions related to screen configuration, used for settings.
1. Define maximum LCD screen resolution
LV_HOR_RES_MAX is used to set the horizontal length of the LCD screen, and LV_VER_RES_MAX is used to set the vertical length of the LCD screen.
2. Define color depth
The values of the LV_COLOR_DEPTH configuration item correspond to 1, 8, 16, 32, representing the formats as follows: 1 byte per pixel, RGB233, RGB565, ARGB8888, respectively. It is usually set to 16.
3. Enable anti-aliasing feature
There’s only one configuration item related to this feature, which is LV_ANTIALIAS. Its default value is 1, meaning anti-aliasing is enabled by default. When set to 0, anti-aliasing is disabled. In practical projects, it’s generally enabled, so that elements like text, lines, and arcs in our UI interface won’t exhibit jagged edges.
4. Define the refresh period of the screen
The only related configuration item for this feature is LV_DISP_DEF_REFR_PERIOD, which has a default value of 30ms. If this value is set too large, it may lead to stuttering. On the other hand, setting it too small may waste performance. It’s generally fine to stick with the default value without worrying too much.
5. Define the Polling Period of the Input Device
This function is associated with 1 configuration item, which is LV_INDEV_DEF_READ_PERIOD. Its default value is 30ms, meaning that the input device (such as a keyboard, touchscreen, etc.) is sampled every 30ms to check its status.
6. Definition of Drag Threshold
Associated with this feature is 1 configuration item, LV_INDEV_DEF_DRAG_LIMIT, with a default value of 10 pixels. This means that dragging more than 10 pixels while holding down is considered a valid drag action.
7. Definition of Long Press Event Trigger Time
The relevant configuration item for this feature is LV_INDEV_DEF_LONG_PRESS_TIME, with a default value of 400ms. This indicates that holding down a control for more than 400ms will trigger its long press event.
8. Definition of Long Press Repeat Event Trigger Time
The related configuration item for this feature is LV_INDEV_DEF_LONG_PRESS_REP_TIME, with a default value of 100ms. This means that after triggering a control’s long press event, holding it down for more than 100ms will trigger its long press repeat event.
9. Enablement of Image Alpha Transparency Feature
Associated with this feature is 1 configuration item, LV_IMG_CF_ALPHA, with a default value of 1, indicating the enabling of alpha transparency feature. A value of 0 indicates disabling.
10. Explicit Definition of Memory Alignment Size
The configuration item LV_ATTRIBUTE_MEM_ALIGN is related to this feature, with a default value of empty. This is because when the compiler optimizes using -Os, it may result in our data not being aligned to 4 or 8 bytes. In such cases, we can explicitly define byte alignment.
11. Enablement of LittlevGL’s Built-in Themes
The related configuration items for this feature are 9 in total, namely:
LV_THEME_LIVE_UPDATE,
LV_USE_THEME_TEMPL,
LV_USE_THEME_DEFAULT,
LV_USE_THEME_ALIEN,
LV_USE_THEME_NIGHT,
LV_USE_THEME_MONO,
LV_USE_THEME_MATERIAL,
LV_USE_THEME_ZEN,
LV_USE_THEME_NEMO
In which, LV_THEME_LIVE_UPDATE is used to determine whether to allow switching theme styles during runtime, while the other 8 configuration options indicate whether to enable the corresponding 8 theme styles.
12. Enable Built-in Fonts in LittlevGL
LV_FONT_ROBOTO_12,
LV_FONT_ROBOTO_16,
LV_FONT_ROBOTO_22,
LV_FONT_ROBOTO_28,
LV_FONT_UNSCII_8
There are 5 related configuration options for this feature, corresponding to Roboto fonts in sizes 12, 16, 22, and 28, and the Unscii font in size 8. Each font includes ASCII characters and some icon fonts (Symbols), all of which are 4 bits per pixel anti-aliased fonts. Setting to 1 enables them, while setting to 0 disables them.
13. Define the Text Encoding Method
There is one related configuration option, LV_TXT_ENC, with two possible values: LV_TXT_ENC_UTF8 (default) and LV_TXT_ENC_ASCII. When displaying Chinese or other non-ASCII characters, LV_TXT_ENC_UTF8 must be set, and the code editor must also be set to the corresponding UTF-8 encoding.
3.19.3 Porting Method
When users need to develop their own projects, they can follow the steps below to port lvgl into their project. The specific steps are as follows:
Create a new folder named “Lvgl” in the newly created project file. The name can be customized.
Here, a project file is provided for users to simulate testing (located in: “3.19 RCC LVGL Introduction and Source Code AnalysisRCC LVGL Source Code and Porting Routines/Source Code and Projects to be Ported”).
Copy the ‘src’ folder, ‘lv_conf_template’, ‘lvgl’ files inside the ‘lvgl_configuration’ directory under the current directory ‘3.19 RCC LVGL Introduction and Source Code Analysis/RCC LVGL Source Code and Porting Routines/Source Code and Projects to be Ported’, as well as the ‘example/Porting’ folder, into the ‘Lvgl’ folder as shown in the figure below:
Change the folder and folder name
(1) Rename the configuration file ‘lv_conf_template.h’ to ‘lv_conf.h’.
(2) Rename the files under ‘examples/porting’ as well, removing the ‘_template’ suffix
Adding Lvgl to the project:
Open the project file with Keil5 (located in the MDK-ARM folder), then click on
to configure
Add the Lvgl source code by including all the .c files from the ‘src’ directory into the project. Exclude the ‘draw’ folder from the ‘src’ directory, except for the contents of the ‘sw’ folder.
Also, add the source files from ‘Lvgl/Porting’ to the project:
Then, include the configuration files. These two files are located inside the ‘Lvgl’ folder. When adding them, select ‘all files’ to view them.
Include header files and relevant macro definitions, configure the compilation settings, and click on the magic wand icon at the top of the Keil5 software, as shown in the figure below:
Set macro definitions by filling in the following content in the ‘Define’ section, separated by English commas:
USE_HAL_DRIVER,STM32F407xx,
LV_CONF_INCLUDE_SIMPLE,
LV_LVGL_H_INCLUDE_SIMPLE,
NDEBUG
Then include the header files (Include Paths): Add the ‘Lvgl’ folder.”
Set character matching recognition (–locale=english), and similarly, set the compilation mode to C99:
Back to the software interface, click on the ‘Lvgl/porting.c’ folder, as shown in the figure below:
Modify ‘#if 0’ to ‘#if 1’ in the ‘lv_port_disp.c’ file,
Change ‘#include lv_port_disp_template.h’ to ‘#include lv_port_disp.h’,
If there are red wavy lines and error messages, disregard them,
Then set the macro definitions for width and length according to your screen’s resolution:
#define MY_DISP_HOR_RES (160)
#define MY_DISP_VER_RES (80)
#define LV_VER_RES_MAX 60
Click-on the compilation button for compilation:
Wait for the compilation to be completed:
If no errors occur (warnings can be ignored), it indicates that the compilation is complete, and lvgl has been successfully integrated into the project.
Note: lvgl8 requires Keil5 version 5.38 or higher with armclang to compile correctly. Here, it is advisable to use lvgl7 for compilation as much as possible.
3.20 Introduction and Use of GUI Guider Interface Development Tool
3.20.1 Introduction
GUI Guider is an upper computer GUI design tool developed by NXP for LVGL. It allows designing LVGL GUI pages by dragging and dropping controls, speeding up GUI design. The designed GUI pages can be simulated and run on a PC. Once the design is confirmed, C code can be generated and integrated into STM32 project.
3.20.2 Use Method
Software Installation
Open the ‘Software’ folder in the current directory, then double-click to open it. Select ‘Simplified Chinese’ and click ‘OK’:
Next, click ‘Agree’:
It’s recommended to change the installation directory to the D drive path, then click ‘Install’:
Wait for the installation to complete:
After installation, uncheck the box and click ‘Finish’:
Once all steps are completed in order, you should see the Gui-Guidier software icon on your desktop, indicating successful installation.
Note: To avoid installation failure, please follow the above installation steps in sequence during the installation process!!!
Use Method
Double-click ‘GUI-Guider-1.5.1-GA’
to open the software. The initial interface is in English. Users can adjust it to Chinese for easier project creation in the future.Click ‘Create a new project’ on the interface:
Select the LVGL version. Here, choose version V7.10.1. After selecting, click ‘Next’:
Note: lvgl8 requires Keil 5.38 or higher with armclang to compile correctly.
Select ‘Simulator’, then click ‘Simulator’, and finally click ‘Next’ to proceed to the next step.
To quickly experience how to import GUI programs into the LCD screen, choose the pre-edited sample provided by the software (select the first one here).
Select ‘ButtonCounter’ and click ‘Next’.
Enter your project name. In this case, set it as ‘new_project’. Then browse for the project path you want to create. It’s recommended to use an English path. Finally, click ‘Create’.
!!! Note: A prompt box may appear at the bottom stating ‘java version cannot be identified’. Click ‘OK’ here, then proceed to ‘3.1 Java Environment Installation and Check’ to configure the environment and resolve this issue before continuing with the next steps!!!
Click on the language settings in the upper right corner and set it to Chinese. This will switch the interface language to Chinese.
After confirming the design of your interface, click on this button option in the upper right corner of the software interface to generate the code.
If the warning bar shown in the following image appears, select ‘Do not remind me again’ and then click ‘OK’ to proceed.
If you see a prompt like this at the bottom of the interface, it means the program generation is complete!!!
Two folders (custom and generated) will be generated in the project directory previously selected.
Note: If any unknown issues arise during the installation process, you can refer to section 3. Common Problems for assistance. If the issue persists, feel free to contact our after-sales personnel.
3.20.3 FAQ:
Open the ‘openjdk-20.0.1_windows-x64_bin’ folder in the software, copy it to your computer, ensuring it’s in an English path (it’s recommended to extract it to ‘C:\Program Files\openjdk-20.0.1_windows-x64_bin’).
After extraction, add environment variables. Press the ‘Win’ key, and search for ‘Environment Variables’.
Then click on ‘Advanced’, followed by ‘Environment Variables’, and add the Java extraction location to the environment variables.
Select ‘Path’ in the Administrator user variables, then click ‘Edit’.
Click on ‘New’, then add the paths from points 2, 3, and 4 in the figure below to the options, and finally click ‘OK’ to return to the previous level interface.
Similarly, in the ‘System Variables’, select ‘Path’, then click ‘Edit’:
Similarly, click ‘New’, then add the paths from points 2, 3, and 4 in the figure below to the environment variables, and finally click ‘OK’.
Close the Environment Variables window, then press the ‘Win’ key, type ‘cmd’, and open the Command Prompt:
Enter ‘java -version’ for version verification. If the content shown in the image below appears, it indicates that the Java environment has been added to the system environment, and you can return to Gui-Guider for project editing.
3.21 RCC LCD Screen System Status Display Source Code Analysis
3.21.1 Introduction
Based on the content of the previous sections, this subsection will use the RCC main control board to drive the ST7735 display screen to show a real-time voltage display using a pre-made interface system.
3.21.2 Source Code Analysis
The source code is located in the “3.21 RCC LCD Screen System Status Display Routine/RosRobotControllerM4_LCD_battery” directory within the current document. Open it with Keil5 software for reference.
Program Structure Diagram
The program’s structure diagram designed according to the task’s effect is shown below:
Based on the program structure diagram, the source code is analyzed as follows:
UI objects
After designing the interface with the GUI-Guider software, load the generated files into the project. The program is located in the “Hiwonder/LVGL_UI” folder within the gui_guider.h header file.
lv_obj_t *screen_empty;
bool screen_empty_del;
lv_obj_t *screen_startup;
bool screen_startup_del;
lv_obj_t *screen_startup_img_1;
lv_obj_t *screen_sys;
bool screen_sys_del;
lv_obj_t *screen_sys_cont_1;
lv_obj_t *screen_sys_label_volt;
lv_obj_t *volt_label;
lv_obj_t *screen_sys_label_ssid;
lv_obj_t *screen_sys_title;
lv_obj_t *screen_imu;
Task Function
The gui_task_entry() function in the gui_handle.c file under the Hiwonder/System directory is the user’s GUI display task function.
1. UI Initialization
In this subsection’s project files, within the Hiwonder/System folder, the gui_task_entry function is the entry function for the FreeRTOS tasks. This project uses gui_task_entry as the entry point for the project and is also the starting function for the program’s execution.
void gui_task_entry(void *arg)
Initialize message handlers; two handlers are used for LVGL’s active messages, and a timer handler is used to refresh the LVGL library’s display:
extern osMessageQueueId_t lvgl_event_queueHandle;
extern osTimerId_t lvgl_timerHandle;
The figure below shows the initialization function for LVGL-related configurations, where setup_scr_screen_sys(&guider_ui) is the initialization function for the system interface displaying the battery level.
lv_init();
lv_port_disp_init();
setup_ui(&guider_ui);
setup_scr_screen_startup(&guider_ui);
setup_scr_screen_sys(&guider_ui);
In the setup_scr_screen_sys(&guider_ui) function, the result content displayed after battery detection is included. Double-click this function, and press F12 to enter the function:
//Write codes for screen_sys_label_volt
ui->screen_sys_label_volt = lv_label_create(ui->screen_sys, NULL);
osMessageQueueId_t bluetooth_tx_queueHandle;
char battery[100] = {0}; // Variable put into message queue
uint8_t msg_prio = 0; // Priority of the message to be put, set to high
osMessageQueueGet(bluetooth_tx_queueHandle, &battery, &msg_prio, osWaitForever);
char msg_show[100] = "Voltage";
strcat(msg_show, battery);
lv_label_set_text(ui->screen_sys_label_volt, msg_show);
lv_label_set_long_mode(ui->screen_sys_label_volt, LV_LABEL_LONG_BREAK);
lv_label_set_align(ui->screen_sys_label_volt, LV_LABEL_ALIGN_CENTER);
The figure above shows the code part for obtaining the battery handle, where bluetoothe_txt_queueHandle is the battery queue handle, defined as a global variable in the battery_handle.c file within the Hiwonder/System folder, as shown below:
#if ENABLE_BLUETOOTH&&ENABLE_BLUETOOTH_BATTERY_REPORT /* Included when Bluetooth voltage report is enabled */
extern osMessageQueueId_t bluetooth_tx_queueHandle; /* Bluetooth data send queue */
#endif
The osMessageQueueGet function is the message retrieval function, and battery is the voltage output value (converted to char type for display in the function);
osMessageQueueGet(bluetooth_tx_queueHandle, &battery, &msg_prio, osWaitForever); // Get battery info from Bluetooth send queue
Then lv_label_set_text is the text display function, screen_syslabel_volt is the space for displaying the highlighted content, and msg_show is the content to be displayed.
2. Task Sending
Finally, use the lv_event_send function to send the layout interface screen_sys to the system interface for display.
lv_event_send(guider_ui.screen_sys, LV_EVENT_CLICKED, NULL); // Send system screen event
Here, LV_EVENT_CLICKED is the click event, and NULL is the system user’s data. Since this is in the task function, it is left empty here.
