1. Digital Tube Module Manual
1.1 Digital Tube Module
1.1.1 Sensor Introduction
LED digital tube is a 4-digit red LED digital tube used to display numbers, decimal points and some special characters. It features a compact, user-friendly design for displaying sensor values like speed, time, score, temperature, and distance in robotics projects.
1.1.2 Working Principle
It has 4 digital tubes, each of which has 8 LED lights. By controlling these 8 lights, you can make a digital tube display numbers, decimal points and part of the letters.
1.2 Notice
  1. Do not exceed the rated voltage range during use.
  2. Handle with care during use.
1.3 Specifications
For more information, you may refer to “Digital tube sensor schematic
1.3.1 Pin Instruction
Pin Instruction
5V Power Input
GND Ground
DIN Data Input
CLK Clock input
1.3.2 Specifications
Digital Tube Sensor
Parameter
Specification
Power Supply
DC 5V
Communication
Dual Digital Control
Indicator Light (PWR) Description
The PWR LED lights up when powered.
Connector Type
5264-4AW
Product Dimensions
50mmx20mm
Modular installation, compatible with Lego series.
Four red LEDs, each including a decimal point
Adjustable display brightness
1.3.3 Project Outcome
By using the TM1640 chip to set the LED matrix in the four digital tubes to achieve the effect of displaying numbers, decimal points and some letters.
And the final effect of the digital tube is: “1234” are displayed on the four-digit digital tube.
