3.1 Getting Started
3.1.1 Wiring Instruction
When wiring, connect the digital tube’s 5V, GND, DIN (GPIO 24), and CLK (GPIO 22) pins to the corresponding pins on the Raspberry Pi.
  • If the battery is not connected to the cables, do not connect the cable ends directly together. Doing so may cause a short circuit and damage the system.
Install VNC software on PC. You can find it under Appendix-> Remote Desktop Connection Tool. For the detailed operations of VNC, please refer to the same directory.
Drag the program and SDK library files into the Raspberry Pi system image. For demonstration, the files are placed on the Desktop in this example.
Open the terminal and enter the following command to navigate to the program directory:
sudo chmod a+x Sensor_Demo/
3.2 Test Case
Program to display the number “1234” on the seven-segment display module.
3.2.1 Program Download
  1. Open the terminal and enter the following command to navigate to the program directory and press Enter.
cd Desktop/Sensor_Demo/
  1. Run the program by entering:
python3 DigitalDisplay.py
3.2.2 Project Outcome
The four-digit display shows the numbers “1234.”
3.2.3 Program Brief Analysis
  • Import Libraries
import tm1640 as tm
Import the required libraries, including system, delay, and digital tube libraries.
Place the tm1640.py library file in the Raspberry Pi, in the same folder as the program.
  • Main Program
# Character pattern data (字模数据)
data = {'0':0x3f,'1':0x06,'2':0x5b,'3':0x4f,'4':0x66,'5':0x6d,'6':0x7d,'7':0x07,'8':0x7f,'9':0x6f}
    while(1):
        tm.display_buf = (data['1'],data['2'],data['3'],data['4'])
        tm.update_display()
Set the font data from 0 to 9 and print “1234” on the digital tube.
