12. AI Large Model Course
12.1 Large Models Basic Courses
12.1.1 Large Language Model Courses
  • Basic Concept
  • Features
  • Working Principle
  • Application Scenarios
(1) Text Generation
(2) Text Classification
(3) Machine Translation
(4) Question-Answering Systems
① Copy the following URL: https://platform.openai.com/docs/overview
To proceed with this section, you will need to register on the appropriate website and obtain the API key for the large model (please refer to the file Large Language Model Deployment. Additionally, ensure that the images to be used in this section are imported.
(1) Environment Configuration
sudo apt install vim
sudo apt install gedit
sudo apt install python3 python3-pip python3-all-dev python3-pyaudio portaudio19-dev libsndfile1
① In this section, locate the Source Code folder within the same directory as this tutorial document.
② Using the MobaXterm remote connection tool (as outlined in the 5.5 Remote Access and File Transfer tutorial), drag the folder into the root directory of the main controller. The software installation package can be found in the Remote Access and File Transfer directory.
③ Next, execute the command to navigate to the speech_pkg directory:
cd ~/large_models/speech_pkg/
⑤ Then, use the command in the terminal to navigate to the speech directory.
⑥ Run the command to list the files in the speech directory.
jetson_nano 3.6
jetson_orin 3.10
rpi5 3.11
rpi5_docker 3.8
cd jetson_orin/
⑨ Enter the command to copy the speech.so file to the parent directory.
cp -r speech.so ..
cd ../..
pip3 install .
pip3 install openai -U
(3) Key Configuration
cd ~/large_models
vim config.py
③ Once the file is open, configure the OpenAI and OpenRouter keys by filling in the llm_api_key and vllm_api_key parameters, respectively (you can obtain these keys from the Large Language Model Deployment .
For instance, copy the key created in Section 1.2 of this chapter and paste it into the appropriate field. To paste the key, place the cursor between the quotation marks, hold the “Shift” key, right-click, and select “Paste” (Note: Do not mix keys from different models, as this may cause the functionality to malfunction).
(4) Running the Demo Program
python3 openai_llm_demo.py
Before starting this section, make sure you have completed the API key configuration outlined in the file Large Language Model Accessing.
cd large_models/
To proceed with this section, ensure that you have completed the API key configuration as described in the file Large Language Model Accessing.
cd large_models/
python3 openai_llm_er_demo.py
(4) In this program, we send two emotional expressions to the model: the first is an expression of sadness, “So Sad.” After the model responds, we then send an expression of happiness, “Ha Ha,” and observe how the model reacts.
12.1.2 Large Speech Model Courses
A Speech Large Model (LSM) refers to a machine learning model that uses deep learning techniques to process and understand speech data. These models can be applied in a variety of tasks, such as speech recognition, speech synthesis, speech translation, and emotional analysis of speech. The design and training of these models typically require large amounts of speech data and substantial computational resources, which is why they are referred to as “large models.”
Their advantages include:
Phrase-Level Speech Recognition: With the expansion of data and advancements in algorithms, speech recognition systems gradually gained the ability to recognize longer phrases, such as “Please turn on my computer.”
Processing Methods
Model Complexity
Recognition Capability
Training Data Requirements
Automatic Speech Recognition (ASR)
Text-to-Speech (TTS)
Speech Enhancement and Noise Reduction
(1) Device Overview
WonderEchoPro
Introduction
WonderEcho Pro, also known as the AI Voice Interaction Box, is equipped with a high-performance noise-canceling microphone and a high-fidelity speaker. It utilizes a USB-to-audio module, making it plug-and-play with no drivers required, and is compatible with multiple operating systems for both playback and recording.
Integrating various voice processing technologies, WonderEcho Pro features advanced noise suppression algorithms that effectively filter background noise from the environment. It supports a complete voice interaction process—from wake-up to recognition and response. With its modular design, each functional component (e.g., wake word detection, sound detection, speech recognition, and synthesis) can be developed and tested independently.
Features and Specifications
① Built-in microphone and speaker interface, supporting both audio input and output
② Driver-free, plug-and-play functionality compatible with Windows, macOS, Linux, Android, and more
③ Standard USB 2.0 interface
④ Control interface: USB
⑤ Voice chip model: CL1302
⑥ Speaker output: 3.0W per channel (4Ω BTL)
⑦ Power supply voltage: 5V
6-Microphone Circular Array
Introduction
(2) Recording and Playback Test
Connection Illustration and Detection
Recording Test
① Next, open a new terminal window and enter the following command to check the available recording devices. Note that the -l option is a lowercase “L”. You should see the card number (card) listed—for example, card 0. This is just an example; please refer to your actual query result.
arecord -l
② Then, use the following command to start recording. Replace the red-marked card number (hw:0,0) with the actual number you found in the previous step:
③ This will create a test.wav audio file in the current directory.
④ You can record a short 5-second sample, then press Ctrl + C to stop the recording.
Playback Test
① After the recording is complete, you can check whether the audio file was successfully created by listing the contents of the current directory:
② If test.wav appears in the list, the recording was successful. To play back the recording, use the following command:
aplay test.wav
  • Voice Wake-Up
(1) WonderEcho Pro Wake-Up
Device Check
To proceed, we need to identify the USB device name assigned to the connected WonderEcho Pro or Circular Microphone Array (hereafter referred to as the voice device). Please follow the steps below carefully.
  • First, disconnect the voice device, then open a terminal and run the following command:
ll /dev | grep USB
  • Next, reconnect the voice device to the USB port on your main board and run the same command again:
ll /dev | grep USB
  • You should now see a newly listed USB port, such as ttyCH341USB1. Please take note of this device name—it may vary depending on the main controller being used.
Wake-Up Test
vim wakeup_demo.py
Press “i” to enter edit mode and make the necessary changes as shown below (update the port number accordingly and adjust comments as needed).
Once the changes are complete, press ESC, then type “:wq” and press Enter to save and exit the editor.
② Next, return to the system interface and run the wake-up demo using the command below. Speak the wake word “HELLO HIWONDER” clearly toward the WonderEcho Pro voice device. If the output includes “keyword detect”, it indicates that the firmware has been successfully flashed and the wake word is functioning correctly.
Device Check
For Jetson users, connect to the Jetson system using the NoMachine remote access tool. Once connected, check the desktop interface. If the 6-Microphone Circular Array icon appears on the left side of the desktop, it indicates the device has been successfully recognized.
Wake-Up Test
② Press “i” to enter edit mode.
③ Update the port to match the device port number you previously identified. Comment out the WonderEcho Pro configuration (add “#” at the beginning of the corresponding line), and uncomment the line using the circular microphone array on line 11 as the input device (see red box in the referenced image).
④ Press ESC to return to command mode, then type “:wq” and press Enter to save and exit.
(3) Brief Program Overview
This is a Python-based wake word detection script that utilizes the speech module to process audio input and detect a specific wake word (e.g., HELLO_HIWONDER).
Importing Required Modules
from speech import awake
port = '/dev/ttyUSB0'
# kws = awake.CircleMic(port)
try:  # If a fan is present, it's recommended to turn it off before detection to reduce interference(如果有风扇,检测前推荐关掉减少干扰)
except:
Main Wake Word Detection Loop
print('start...')
Main Program Logic
            print('hello hiwonder')
        time.sleep(0.02)
        except:
(4) Extended Functionality
vim wakeup_demo.py
② Press “i” to enter INSERT mode (you’ll see – INSERT – at the bottom of the screen). Locate the line print(‘hello hiwonder’), and modify it to print(‘hello’).
i
③ Press ESC, then type “:wq” and press Enter to save and exit.
python3 wakeup_demo.py
  • Speech Recognition
(2) How It Works
Before proceeding, refer to the course 12.1.1 Large Language Model Courses to obtain your API key, and make sure to add it into the configuration file (config).
(4) Experiment Steps
① Power on the device and connect to it using MobaXterm. (For detailed instructions, please refer to Remote Connection Tools and Instructions.)
cd large_models/
③ Open the configuration file to input your API Key by entering the command below. Press “i” to enter INSERT mode and enter your API Key. Once finished, press Esc, type “:wq”, and hit Enter to save and exit.
vim config.py
python3 openai_asr_demo.py
(5) Function Realization
(6) Brief Program Analysis
Module Import
from config import *
from speech import speech
Define ASR Class
# whisper-1 fast than gpt-4o-transcribe
Speech Recognition Functionality
print('start talking...')
print(asr.asr())
(7) Function Extension
vim openai_asr_demo.py
② Press the “i” key to enter INSERT mode, and update the model setting. For example, modify it to use the gpt-4o-transcribe model.
i
python3 asr_demo.py
  • Speech Synthesis
(1) What is Speech Synthesis?
(2) How It Works
Refer to the course 12.1.1 Large Language Model Courses to obtain your API key, and update the configuration file accordingly.
cd large_models/
③ Open the configuration file to enter your API Key. After editing, press Esc, type “:wq”, and hit Enter to save and exit:
vim config.py
python3 openai_tts_demo.py
Upon running the program, it will play an audio message saying “Hello, Can I Help You”, and simultaneously save the audio file with the same content to the following directory: /home/ubuntu/large_models/resources/audio/
Module Import
Definition for TTS Class
For intelligent real-time applications, it is recommended to use the gpt-4o-mini-tts model. Other available models include tts-1 and tts-1-hd. tts-1 offers lower latency but with slightly reduced quality compared to tts-1-hd.
① Open the program by entering the command:
vim openai_tts_demo.py
② Press “i” on your keyboard to enter INSERT mode. Locate the line voice=”onyx” and modify it to voice=”nova”.
i
③ Press Esc, then type “:wq” and hit Enter to save and exit.
④ Execute the program with the following command:
  • Voice Interaction
(2) How It Works
(3) Experiment Steps
① Power on the device and connect to it via MobaXterm.
② To check the microphone’s port number, first disconnect the microphone and run the command. Then reconnect the microphone and run the command again to determine the port number
Do not connect any other USB devices during this process.
ll /dev | grep USB
  • After disconnecting the microphone, no USB device should appear.
  • Upon reconnecting the microphone, a USB port (e.g., ttyCH341USB1) will be listed (make sure to note this device name). The device name may vary depending on the main controller.
cd large_models/
④ Open the configuration file to enter your API Key. After editing, press Esc, then type “:wq” and hit Enter to save and exit:
vim config.py
⑥ Run the program:
(4) Function Realization
(5) Brief Program Analysis
Module Import
Definition of Audio File Paths
asr.update_session(model='whisper-1')
client = speech.OpenAIAPI(llm_api_key, llm_base_url)
Main Functional Logic
    kws.start()
                if asr_result:
                    tts.tts(response)
            time.sleep(0.02)
            kws.exit()
            except:
        except BaseException as e:
            print(e)
12.1.3 Vision Language Model Courses
(1) Basic Concept
(2) Features
Powerful Visual-Semantic Understanding: With extensive knowledge accumulated from large-scale visual datasets, VLMs excel at tasks such as object detection, classification, and image captioning.
(3) How It Works
(4) Application Scenarios
Image Captioning
Visual Question Answering
Image Retrieval
Augmented Reality (AR)
Content Creation and Editing
Social Media Interaction
Medical Imaging Analysis
  • This section requires the configuration of the API key in 12.1.1 Large Language Model Courses before proceeding. Additionally, ensure that the images to be used in this section are imported.
(1) Experiment Steps
cd large_models/
② Run the program:
(2) Function Realization
After running the program, the output printed matches our request of “Describe the image.”
  • This section requires the configuration of the API key in “12.1.1 Large Language Model Courses” before proceeding. Additionally, ensure that the images to be used in this section are imported.
cd large_models/
② Run the program:
(3) Function Expansion
Change Pictures
① Click on the path box to navigate to the following directory: “/home/ubuntu/large_models/resources/pictures/
② Then, input the command:
i
④ Change the image recognition path from: ./resources/pictures/test_image_understand.jpeg.
cd large_models/
② Run the program:
① First, drag your image directly into the “~/large_models/resources/pictures/” path using MobaXterm, and rename the image to test.png.
④ Run the program:
cd large_models/
② Run the program:
python3 openai_vllm_ocr.py
Change Pictures
① Drag the image directly into the “~/large_models/resources/pictures/” path using MobaXterm. Here, we can drag in the image named ocr1.png as an example, and let the program recognize the text ‘COME ON’.
i
image = cv2.imread('./resources/pictures/ocr1.png')
⑤ Run the program:
12.1.4 Multimodal Model Basic Courses
(1) Basic Concept
(2) Features
(3) How It Works
Education
Healthcare
Entertainment
Advertising and Marketing
① To check the microphone’s port number, first disconnect the microphone and run the command. Then reconnect the microphone and run the command again to determine the port number
ll /dev | grep USB
cd large_models/
③ Open the configuration file to enter your API Key. After editing, press Esc, then type “:wq” and hit Enter to save and exit:
vim config.py
④ Fill in the detected port number and update the corresponding microphone port settings for either the WonderEcho Pro or the Six-channel Microphone. Uncomment the port you wish to use and comment out the settings for any unused ports.
vim openai_agent_demo.py
⑤ Run the program:
python3 openai_agent_demo.py
① After running the program, the voice device will announce, “I’m ready.” At this point, say “HELLO_HIWONDER” to the device to activate the agent. When the device responds with “I’m here,” it indicates that the agent has been successfully awakened. To modify the wake word. For the Six-channel Microphone, refer to Section 6-Microphone Circular Array for instructions on customizing the wake word. For WonderEcho Pro, refer to Section WonderEcho Pro Firmware Generation
12.2 Multimodal Model Applications
12.2.1 Obtaining and Configuring the Large Model API Key
  • OpenAI Account Registration and Setup
(1) Registration
① Visit the following link to access the OpenAI platform, and sign up.
② You can register using your Google, Microsoft, or Apple account as prompted.
③ Once registered, click on the Settings icon, navigate to Billing, and then select Payment Methods to add a payment option. This is required to purchase tokens.
④ After setting up your billing information, go to the API Keys section, click Create New Secret Key, and follow the on-screen instructions. Be sure to save the key for future use.
With these steps completed, you’ve successfully created and deployed your large model API key, which will be used in the upcoming course sessions.
(2) Deploying the API Key
The configuration file for this program is located at: /home/pi/embodied_intelligence/common/config.py
① Use the following command and press Enter to navigate to the directory containing the configuration file:
cd embodied_intelligence/common
② Enter the following command to open the configuration file and insert the OpenAI key:
gedit config.py
  • OpenRouter API Configuration
① Visit the following link to access the OpenAI platform: https://openrouter.ai/
Click on “Sign in” and use your Google account or another supported account to register or log in.
② After logging in, click on the icon in the top-right corner, select “Credits,” and link your payment method.
③ To create an API key: Navigate to “API Keys” and click “Create Key.” Then follow the prompts to generate your API key, and make sure to save it for future use.
④ Use the following command and press Enter to navigate to the directory containing the configuration file:
⑤ Open the configuration file using the following command, then paste your OpenRouter API key into it:
gedit config.py
12.2.2 Multimodal Model: Voice Control
  • Brief Game Instructions
Once the program starts running and WonderEcho Pro announces “I am ready.”
Say the wake-up word (the wake-up word depends on the firmware flashed, and by default, the wake-up word for our factory firmware is “Hello, HiWonder”) to activate WonderEcho Pro. It will respond with “I am here.”
You can then control TonyPi using voice commands. For example, saying “Hello, please move forward two steps” will prompt WonderEcho Pro to announce the response generated after processing and execute the corresponding action.
(1) Verifying the WonderEcho Pro Firmware
By default, the wake-up word for the WonderEcho Pro factory firmware is “Hello, HiWonder.” If you wish to change the wake-up word to “TonyPi,” please refer to the tutorial titled 6 AI Voice Interaction Course → 6.1 Introduction to WonderEcho Pro and Installation → 6.1.3 Firmware Flashing Method for step-by-step instructions.
(2) Obtaining and Configuring the Large Model API Key
By default, the program does not include the configuration of the Large AI Model-related API keys. Before activating features related to the Large AI Model, please refer to the section 12.2.1 Obtaining and Configuring Large Model API Keys to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
(3) Network Configuration
The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet. For detailed instructions on network configuration, please refer to the course 14. Robot Network Configuration .
  • Starting and Stopping the Game
  • The input commands must strictly observe case sensitivity and spacing.
  • The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet.
(1) Power on the robot and remotely connect to the Raspberry Pi desktop via VNC.
(2) Double-click the “Terminator” icon on the Raspberry Pi desktop to open the command-line terminal.
(3) Execute the following command to disable the app auto-start service.
sudo systemctl stop tonypi.service
(4) Enter the command and press the Enter key to navigate to the directory where the game program is stored:
cd embodied_intelligence/multimodal_large_models_course
(5) Enter the command and press the Enter key to start the game:
python3 main.py
(6) When the following output appears in the command line, it indicates that WonderEcho Pro has completed initialization and will announce “I am ready.” At this point, you can say the wake word, “hello hiwonder.”
(7) When the following output appears in the command line, WonderEcho Pro will announce “I am Here,” indicating that WonderEcho Pro has been successfully activated. At this point, the system will begin recording the user’s command.
You can freely phrase your commands to control the movement of TonyPi, such as saying, “Go forward and greet me.”
(8) When the following output appears in the command line, it indicates that WonderEcho Pro has finished recording the user’s command audio and is processing it. The parsed result will be shown in the asr_result.
(9) When the following output appears, it means that the Raspberry Pi has successfully called the cloud-based large language model to process the user’s command, providing a verbal response under response and generating an action group action that aligns with the semantics of the user’s command.
At this point, the robot will execute the actions outlined in the action sequence.
The response is automatically generated by the large model, ensuring the accuracy of the meaning, though the wording and structure of the reply may vary.
(10) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 4) to reactivate the voice device using the wake-up word and begin a new round of interaction.
(11) To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
(12) Execute the following command to enable the app auto-start service.
sudo systemctl restart tonypi.service
  • How It Works
Once the game is activated, we can freely give commands to control TonyPi, instructing it to perform the following actions either individually or in sequence.
NO. Actions NO. Actions
1 Stand: stand() 10 Twist: twist()
2 Move a step forward: forward() 11 Chest thump celebration: celebrate()
3 Step backwards: back() 12 Squat: squat()
4 Move left by one step: move_left() 13 Kick right foot: right_shot()
5 Move right by one step: move_right() 14 Kick left foot: left_shot()
6 Turn left by one step: turn_left() 15 Sit-ups: sit_ups()
7 Turn right by one step: turn_right() 16 Wing Chun fist: wing_chun()
8 Bow: bow() 17 Fall and Get Up: stand_up()
9 Wave to Greet: wave() 18
  • Brief Program Analysis
Library Files Import
import os, sys
sys.path.append(os.path.abspath(os.path.join(os.path.dirname(__file__), '..')))
import action
from common.config import *
Module Initialization
kws = awake.WonderEchoPro('/dev/ttyUSB0')
if language == 'Chinese':
    asr = speech.RealTimeASR()
    tts = speech.RealTimeTTS()
    asr.update_session(model=asr_model, language='en')
client = speech.OpenAIAPI(api_key, base_url)
action.init()
Set Prompt Words
    PROMPT = '''
#角色
你是一款智能陪伴机器人,专注机器人动作规划,解析人类指令并以幽默方式描述即将展开的行动序列,为交互增添无限趣味。
##要求
1.用户输入的任何内容,都需要在动作函数库中寻找对应的指令,并输出对应的json指令。
2.为每个动作序列编织一句精炼(10至30字)、风趣且变化无穷的反馈信息,让交流过程妙趣横生。
3.直接输出json结果,不要分析,不要输出多余内容。
4.格式:{"action": ["xx", "xx"], "response": "xx"}
    PROMPT = '''
**Role**
You are an intelligent companion robot specializing in robot action planning. You interpret human instructions and describe the upcoming action sequence in a humorous way, adding infinite fun to the interaction.
**Requirements**
1. For every user input, search the action function library for matching commands and return the corresponding JSON instruction.
2. Craft a witty, ever-changing, and concise response (between 10 to 30 characters) for each action sequence to make interactions lively and fun.
3. Output only the JSON result — no explanations or extra text.
4. Output format: {"action": ["xx", "xx"], "response": "xx"}
Set the prompt words based on the system’s language, for both Chinese and English versions.
Wake Word Detection
if kws.wakeup():  # Wake word detected(检测到唤醒词)
Call kws.wakeup() to detect the wake word. Once detected, play the wake-up sound effect using speech.play_audio(wakeup_audio_path).
Recording and Recognition
asr_result = asr.asr()  # Start voice recognition(开启录音识别)
Use asr.asr() for recording and speech recognition. The recognized result will then be printed to the terminal using print().
Interaction with the Intelligent Agent
result = client.llm(asr_result, prompt=PROMPT, model=llm_model)
print('llm_result:', result)
Pass the recognition result to the intelligent agent with client.llm(asr_result, prompt=PROMPT, model=llm_model) to obtain a reply and corresponding action instructions.
Speech Synthesis and Action Execution
tts.tts(response)
if action_list is not None:
    for a in action_list:
        eval(f'action.{a}')
If a response is received, and action instructions are available, first synthesize and announce the speech using tts.tts(response), then iterate through and execute the action instructions.
12.2.3 Multimodal Model: Ball Tracking and Shooting
Once the program starts running and WonderEcho Pro announces “I am ready”.
Say the wake-up word (the wake-up word depends on the firmware flashed, and by default, the wake-up word for our factory firmware is “Hello, Hiwonder”) to activate WonderEcho Pro. It will respond with “I am here”.
You can then control TonyPi using voice commands. For example, saying “kick the red ball ahead” will prompt WonderEcho Pro to announce the response generated after processing and execute the corresponding action.
By default, the wake-up word for the WonderEcho Pro factory firmware is “Hello, HiWonder.”. If you wish to change the wake-up word to “TonyPi”, please refer to the tutorial titled 6 AI Voice Interaction Course → 6.1 Introduction to WonderEcho Pro and Installation → 6.1.3 Firmware Flashing Method for step-by-step instructions.
python3 main.py
You can freely organize your language and issue commands to control TonyPi to start tracking and kicking the ball, such as “kick the red ball ahead.”
(10) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 5) to reactivate the voice device using the wake-up word and begin a new round of interaction.
  • How It Works
Once the feature is activated, you can issue commands in your own words, such as “kick the red ball ahead,” to control TonyPi. It will automatically track any ball within its line of sight and perform the kicking action.
  • Function Expansion
(1) Changing the Color of the Tracked Ball
① By default, the program is set to track a red ball. It includes preset color thresholds for red, green, blue, black, and white. You can modify the commands as needed to control TonyPi to track balls of different colors.
② For example, to track a blue ball, follow the steps and then issue the command, “kick the blue ball ahead.” (Feel free to rephrase the command in your own way, as long as the meaning remains the same.)
Here is a terminal screenshot of the entire voice interaction process.
When issuing commands, describe the color of the tracked ball in a straightforward manner without adding unnecessary modifiers. For example, when tracking a blue ball, simply use the term “blue” rather than descriptors like “sky blue” or “lake blue.” Using such modifiers could confuse the model, leading to incorrect parameters in the action functions and causing the program to fail in tracking the ball due to the inability to find the correct color configuration.
(2) Change Action
① The large language model supports chaining multiple actions into a single command. You can refer to the table below to combine the ball-tracking and kicking function with the actions introduced in the previous section.
② Here’s an example of a multi-action command: Follow the tutorial steps accordingly. When prompted, you may say: “Take two steps forward, kick the blue ball, then bow.” (Feel free to rephrase the command in your own way, as long as the meaning remains the same.)
import os, sys
import action
action.init()
Set Prompt Words
    PROMPT = '''
#角色
##要求
##特别注意:
- "action"键下承载一个按执行顺序排列的函数名称字符串数组,当找不到对应动作函数时action输出[]。
- "response"键则配以精心构思的简短回复,完美贴合上述字数与风格要求。
- 特殊处理:对于特定函数"kick_ball","athletics_perform"其参数需精确包裹于双引号中。
##动作函数库
- 站立:stand()
- 前进一步:forward()
- 后退一步:back()
- 向左平移一步:move_left()
- 向右平移一步:move_right()
- 向左转动一步:turn_left()
- 向右转动一步:turn_right()
- 鞠躬:bow()
- 挥手打招呼:wave()
- 扭腰:twist()
- 捶胸庆祝:celebrate()
- 下蹲:squat()
- 踢右脚:right_shot()
- 踢左脚:left_shot()
- 仰卧起坐:sit_ups()
- 佛山叶问的咏春拳:wing_chun()
- 摔倒了站起来:stand_up()
- 沿着黑色的线走并跨过障碍:athletics_perform()
- 踢不同颜色的足球:kick_ball('red')
    PROMPT = '''
**Role**
**Requirements**
**Special Notes**
- The "action" key holds an array of function name strings arranged in execution order. If no match is found, return an empty array `[]`.
- The "response" key must contain a cleverly worded, short reply (10–30 characters), adhering to the tone and length guidelines above.
- For specific functions like "kick_ball" and "athletics_perform", parameters must be enclosed in double quotes.
**Action Function Library**
- Stand: stand()
- Forward one step: forward()
- Back one step: back()
- Move left one step: move_left()
- Move right one step: move_right()
- Turn left one step: turn_left()
- Turn right one step: turn_right()
- Bow: bow()
- Wave hello: wave()
- Twist: twist()
- Celebrate: celebrate()
- Squat: squat()
- Right shot: right_shot()
- Left shot: left_shot()
- Sit-ups: sit_ups()
- Wing Chun (like Yip Man): wing_chun()
- Stand up after falling: stand_up()
- Athletics performance (follow black line and cross obstacles): athletics_perform()
- Kick a ball of a specific color: kick_ball('red')
Wake Word Detection
tts.tts(response)
        eval(f'action.{a}')
12.2.4 Multimodal Model: Autonomous Cruise
This feature allows TonyPi to navigate autonomously. In cruise mode, it recognizes different colors and performs corresponding actions such as line following, step climbing, and hurdle crossing.
You can then control TonyPi using voice commands. For example, saying “Start athletics performance” will prompt WonderEcho Pro to announce the response generated after processing and execute the corresponding action.
python3 main.py
(6) When the following output appears in the command line, it indicates that WonderEcho Pro has completed initialization and will announce “I am ready”. At this point, you can say the wake word, “hello hiwonder”.
(7) When the following output appears in the command line, WonderEcho Pro will announce “I am Here”, indicating that WonderEcho Pro has been successfully activated. At this point, the system will begin recording the user’s command.
You can freely organize your language and issue commands to control TonyPi to start tracking and kicking the ball, such as “Start athletics performance”.
(8) When the command line shows the output below, it indicates that the cloud-based voice large model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under asr_result.
(9) When the terminal displays the following output, it means the Raspberry Pi has successfully accessed the cloud-based large language model, processed the user’s command, generated a spoken response, and created a corresponding action group based on the command’s intent.
  • The response is automatically generated by the large model, ensuring the accuracy of the meaning, though the wording and structure of the reply may vary.
  • Once the Autonomous Cruise mode is activated, the program will continue running this function. To stop it, press Ctrl+C in the terminal.
(10) To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
(11) Execute the following command to enable the app auto-start service.
  • How It Works
Once the mode is activated, you can give commands such as “Start athletics performance” to control TonyPi in Autonomous Cruise mode. In this mode, TonyPi will follow a black line, climb steps when it detects a red line, and hurdle over blue obstacles.
(1) Change the Triggered Color
① In the Autonomous Cruise mode, three behaviors are pre-set: line following, hurdling, and step climbing. The program also includes predefined color thresholds for red, green, blue, black, and white. You can modify the program to control TonyPi to follow lines other than black, or to trigger the step climbing action when detecting lines other than red, or activate the hurdling action when encountering objects that are not blue.
② Double-click the “Terminator” icon on the Raspberry Pi desktop to open the command-line terminal.
③ Enter the command and press the Enter key to navigate to the directory where the game program is stored:
④ Run the following command to open the program file:
vim functions/athletics_perform.py
⑤ The program includes preset color thresholds for red, green, blue, black, and white (i.e., red, green, blue, black, white).
If you want to change the line-following color, please locate the section of code marked as ① in the image below and modify the corresponding values.
To change the color used for hurdle-crossing detection, refer to the code marked as ②.
To modify the color used for stair-climbing detection, edit the code at position ③.
⑥ Below is a screenshot example showing how to configure the robot to:
Follow white lines for autonomous navigation,
Perform hurdle-crossing when encountering green obstacles, and
Execute stair-climbing when detecting blue lines.
⑦ After making the changes, press the “Esc” key on your keyboard and enter the following command to save and exit:
⑧ Enter the command and press the Enter key to start the game:
python3 main.py
(2) Change Action
① The large model supports chaining multiple actions in sequence. You may refer to the table below to combine the TonyPi executable actions covered in the previous section with the “Autonomous Cruise” function.
② The following is an example of chaining actions before and after autonomous cruise. Execute the actions in the specified sequence. During the autonomous navigation phase, you can issue the command: “Please step back and start the athletic performance.” (Feel free to rephrase the command in your own way, as long as the meaning remains the same.)
import os, sys
import action
action.init()
Set Prompt Words
    PROMPT = '''
#角色
##要求
##特别注意:
##动作函数库
- 站立:stand()
- 前进一步:forward()
- 后退一步:back()
- 鞠躬:bow()
- 挥手打招呼:wave()
- 扭腰:twist()
- 捶胸庆祝:celebrate()
- 下蹲:squat()
- 踢右脚:right_shot()
- 踢左脚:left_shot()
- 仰卧起坐:sit_ups()
- 摔倒了站起来:stand_up()
    PROMPT = '''
**Role**
**Requirements**
**Special Notes**
- Stand: stand()
- Bow: bow()
- Twist: twist()
- Squat: squat()
Wake Word Detection
Use kws.detect() to start wake word detection. Once the wake word is detected, call kws.stop() to stop detection, and then play the wake-up sound using speech.play_audio(wakeup_audio_path).
tts.tts(response)
        eval(f'action.{a}')
12.3 Embodied AI Applications
12.3.1 Embodied AI Applications in Real-Time Detection
KWS (Keyword Spotting) is used to detect whether the user has spoken a specific wake word. By integrating KWS with ASR (Automatic Speech Recognition), the system enables more comprehensive speech recognition capabilities.
Once the wake word is detected, ASR processes the audio signal and converts it into text. After detecting the wake word, the system records the user’s voice for further recognition.
Upon recognizing the speech, the system retrieves an image from the image queue and passes both the recognition result and the image to the agent for response generation.
Finally, TTS (Text-to-Speech) converts the agent’s generated text into speech, saving it as an audio file for playback.
By default, the wake-up word for the WonderEcho Pro factory firmware is “Hello, HiWonder”. If you wish to change the wake-up word to “TonyPi”, please refer to the tutorial titled 6 AI Voice Interaction Course → 6.1 Introduction to WonderEcho Pro and Installation → 6.1.3 Firmware Flashing Method for step-by-step instructions.
(1) Open the Terminator on the desktop and enter the command to disable the auto-start service for the mobile app.
(2) Navigate to the program directory:
cd embodied_intelligence/embodied_intelligence_course
(3) Then, input the command to start the game:
python3 vllm_with_camera.py
(4) When the terminal displays the following output, the program has successfully started.
(5) Once running, say the wake word “hello hiwonder” to activate the large model, and the robot will respond with the message, “I am Here”. You can then give the robot commands, such as “Describe what you saw.” Upon successfully recognizing the command, the terminal will display the corresponding text, and the robot will announce it via voice.
(6) To exit this feature, simply press “Ctrl+C” in the terminal.
(7) Execute the following command to enable the app auto-start service.
  • How It Works
Once successfully awakened, the robot will announce, “I am Here”. You can then give the command, “Describe what you saw”. The robot will analyze the current image feed, detect the content, and display the text on the terminal while also announcing it via voice.
If no command is given after awakening, the robot will respond with, “Sorry, would you please repeat again”. Once a command is issued, the recognized sentence will appear on the terminal, allowing you to confirm that the robot has received the instruction.
The configuration file for this program is located at: /home/pi/embodied_intelligence/embodied_intelligence_course/vllm_with_camera.py
Feature Package Import
import os, sys
import queue
import action
os: System-related operations.
time: Controls delay functions.
config: Configuration files.
speech: Modules for large model speech interaction.
Wake Word Detection
def vllm_thread():
    pid = None
    kws.start()
    while running:
        if kws.wakeup(): # Wake word has been detected (检测到唤醒词)
            speech.play_audio(wakeup_audio_path)  # Play wake-up audio (唤醒播放)
            asr_result = asr.asr()  # Start recording and speech recognition (开启录音识别)
The functions are as follows:
if kws.wakeup(): Detects whether the wake word has been triggered. The wake word serves as the key trigger that transitions the device from sleep mode to a state where it is waiting for user commands.
speech.play_audio(wakeup_audio_path): Plays the wake-up audio file, signaling to the user that the device is now in standby mode.
asr_result = asr.asr(): Proceeds to the next step if the audio is successfully recorded and recognized.
print('asr_result:', asr_result): Outputs the recognized speech result to the terminal.
asr_result = client.vllm(asr_result, image, prompt='', model=vllm_model): Sends the recognized text and image to the agent for processing.
Action Handling
if asr_result:
    image = image_queue.get(block=True)
    # Pass the recognition result to the agent for it to generate a response (将识别结果传给智能体让他来回答)
    response = asr_result
    print('vision_result:', response)
    print('tts...')
    tts.tts(response)
print('vision_result:', response): Displays the agent’s response in the terminal.
tts.tts(response): Converts the agent’s response into audio and plays it through the WonderEcho Pro.
12.3.2 Embodied AI Applications in Smart Home Assistant
python3 vllm_dietitianl.py
(6) At this stage, you can speak to the robot with a command like: “I want to get some red fruits. Could you give me some suggestions?”
(7) Upon successfully recognizing the command, the terminal will display the corresponding text, and the robot will announce it via voice.
(8) To exit this feature, simply press “Ctrl+C” in the terminal.
(9) Execute the following command to enable the app auto-start service.
  • How It Works
Once successfully awakened, TonyPi responds to your commands instantly—not only with clear voice feedback, but also by performing corresponding actions in real time. For example, if you say, “I want to get some red fruits. Could you give me some suggestions?”, TonyPi will reply, “You can have the apple on the right, it’s red,” while simultaneously raising its right arm to point at the apple.
The configuration file for this program is located at: /home/pi/embodied_intelligence/embodied_intelligence_course/vllm_dietitianl.py
import os, sys
import json
import action
import queue
cv2: OpenCV image processing library.
time: used for delay
queue: Manages information flow using queues.
threading: Supports multithreaded task execution.
speech: Provides speech processing capabilities for large language models.
Wake Word Detection
def vllm_thread():
    kws.start()
    while running:
        if kws.wakeup(): # Wake word has been detected(检测到唤醒词)
            asr_result = asr.asr()  # Start recording and recognition (开启录音识别)
The meaning of the functions is as follows:
asr_result = asr.asr(): Records and transcribes the spoken input through speech recognition.
Agent Result Processing
    print('thinking...')
    # Pass the recognition result to the agent for it to respond(将识别结果传给智能体让他来回答)
    response = client.vllm(asr_result, image, prompt=prompt, model=vllm_model)
    res_dict = json.loads(response)
    response = res_dict['response']
    a = str(res_dict['position'])
    print('tts...')
    tts.tts(response)
    eval(f'action.{a}')
    print(e)
res_dict = json.loads(response): Parses the location information from the response.
eval(f'action.{a}'): Executes the specified action.
tts.tts(response): Uses TTS to convert the large model’s response into audio.
Main program:
    global running
    cap = cv2.VideoCapture(-1)
    while running:
            ret, image = cap.read()
            if ret:
                if not image_queue.empty():
                        image_queue.get_nowait()
                    image_queue.put_nowait(image)
                except queue.Full:
                cv2.imshow('track', image)
                cv2.waitKey(1)
            except:
    cap.release()
cap = cv2.VideoCapture(-1): Captures video from the default camera.
cv2.imshow(): Displays the camera feed.
cv2.release(): Releases the camera resource.
cv2.destroyAllWindows(): Closes all video windows.
try/except block: Handles keyboard interrupt signals.
12.3.3 Embodied AI Applications Pose Detection
python3 llm_sensor.py
(4) The program is running successfully when the robot says “I am ready” and the corresponding message is displayed in the terminal.
(5) Once running, say the wake word “hello hiwonder” to activate the large model, and the robot will respond with the message, “I am Here.” You can then give the robot commands, such as “Are you standing or lying down now?” Upon successfully recognizing the command, the terminal will display the corresponding text, and the robot will announce it via voice.
  • How It Works
Once TonyPi recognizes a command, it responds promptly with both voice feedback and corresponding actions. For instance, when asked “Are you standing or lying down now?”, it replies, “I’m standing tall!” If given the command “Lie down”, it responds with “Time to hit the deck!”, while simultaneously performing the lying-down motion.
The configuration file for this program is located at: /home/pi/embodied_intelligence/embodied_intelligence_course/llm_sensor.py
import os, sys
import action
Action: action group control library
Wake Word Detection
    speech.play_audio(wakeup_audio_path)  # Play wake-up audio(唤醒播放)
    asr_result = asr.asr()  # Start recording and speech recognition(开启录音识别)
asr_result = asr.asr(): Starts recording and transcribes the audio input.
if asr_result: If audio content is successfully recognized, proceed to large model processing.
if language == 'Chinese': If the system language is set to Chinese, it will use Chinese large language model for processing; otherwise, it will default to the OpenAI model.
result = client.llm_origin(params).choices[0].message.content.strip(): Invokes the llm_origin method with the specified params to obtain an initial response, which is then stored in the result variable for further handling.
Speech Processing and Synthesis
if 'action' in result:  # If a corresponding action is returned, extract and handle it(如果有对应的行为返回那么就提取处理)
    result = eval(result[result.find('{'):result.find('}') + 1])
    if 'response' in result:
        response = result['response']
else:  # If there's no corresponding action, just reply with the answer(没有对应的行为,只回答)
    response = result
result = eval(result[result.find('{'):result.find('}') + 1]): Uses the eval function to parse the JSON-formatted string and extract the action and response elements.
Actions
If action_list is not empty, it indicates that there are actions to be performed. If response is not empty, the system first converts the response text to speech using Text-to-Speech (TTS) for audio feedback. The system then iterates over the action_list, executing each action by calling the corresponding function and processing the result.
Recalling the Agent
If the action returns a non-empty result, the agent is called again to retrieve feedback related to the action. The result is then parsed to extract the actions and response.
Action Execution and Feedback
if actions:
    for a in actions:
        eval(f'action.{a}')
    if response != '':
        tts.tts(response)
        speech.play_audio(error_audio_path)
If new actions are extracted, iterate through and execute each one. If no new actions are found, play the feedback based on the response, or play an error sound if the response is invalid.
12.3.4 Embodied AI Applications in Temperature Reporting
After the speech is recognized, the program will invoke the corresponding function based on the result returned by the large model. Finally, TTS (Text-to-Speech) converts the agent’s generated text into speech, saving it as an audio file for playback.
(4) Once running, say the wake word “hello hiwonder” to activate the large model, and the robot will respond with the message, “I am Here.”
(5) At this stage, you can issue a command to the robot, such as “What is the temperature in Sydney?”. Once the robot successfully recognizes the command, the corresponding text will be displayed on the terminal and read aloud.
  • How It Works
After a successful wake-up, the robot will announce “I am here”. You can then issue a command, and the terminal will display the corresponding text, which will also be read aloud. You can rephrase it as needed, for example: “Is the weather in [City] ideal for outdoor activities today?”
import os, sys
import action
Wake Word Detection
    response = result
Actions
Recalling the Agent
if actions:
    for a in actions:
        eval(f'action.{a}')
    if response != '':
        tts.tts(response)
12.3.5 Embodied AI Applications in Object Transport
python3 vllm_transport.py
(4) Once the robot announces “I am ready” and the terminal displays the corresponding content, it indicates that the system is running successfully. A feedback screen will also appear.
(5) Once running, say the wake word “hello hiwonder” to activate the large model, and the robot will respond with the message, “I am Here.” You can then give the robot commands, such as “Place the red block to the right of the green block.” Upon successfully recognizing the command, the terminal will display the corresponding text, and the robot will announce it via voice.
  • How It Works
After a successful wake-up, the robot will announce “I am here”. You can then issue a command, and the terminal will display the corresponding text, which will also be read aloud. For example: “Place the red block to the right of the green block”, and the response would be: “Let’s move the red block to the right of the green block!”. Activate the camera to identify the corresponding colored blocks. First, pick up the red block, then place it to the right of the green block.
After a successful wake-up, if no command is given, the robot will respond with “Sorry, would you please repeat again?”. Once a command is issued and successfully recognized, the recognition result will be displayed on the terminal (as shown below), allowing you to confirm whether the robot has received the command.
import os, sys
sys.path.append(os.path.abspath(os.path.join(os.path.dirname(__file__), "..")))
import queue
import action
Several modules are imported here, including os for system operations, cv2 for image processing, time for time management, and queue for handling queues, among others.
The action, speech, and awake modules are custom or third-party libraries designed for controlling hardware devices, speech processing, and related functions.
Set Prompt Words
if language == "Chinese":
    llm_prompt = '''
# 角色任务
作为具身智能运输机器人,你的任务是按照指定的规则和操作方法搬运物体。你需要根据物
体的相对位置决定搬运顺序,并遵循一系列的搬运逻辑和操作步骤。
## 理解相对位置:
你需要理解物体之间的相对位置关系,包括上下、左右,旁边等。
## 搬运逻辑和操作步骤:
1. 在执行搬运任务前,确认物体的相对位置,确保搬运顺序和操作符合实际情况。
2. 根据物体的位置关系,决定搬运顺序。如果目标物体在其他物体下面,需要先搬起上面的物放到一旁,再搬运目标物体。
3. 如果目标物体位于其他物体的上方或旁边,可以直接搬运。
4. 如果直接要求放置位置,而且前面没有搬起过物体,那么要先要搬起物体
5. 在放置物体时,需要遵循指定的方位(如上方、左边、右边,旁边)。
## 可用函数与操作:
* 搬起目标物体:pick_up('red')
* 搬起在其他物体上面的目标物体:pick_up_on('red')
* 将目标物体放到随机位置或旁边:place_random()
* 将目标物体放置到指定物体的指定方位:place_on('blue', 'left')
##示例任务与回应:
任务:将绿色海绵放下。
回应:{"action": ["place_random()"], "response": "绿色海绵,咱们换个地方"}
任务:将绿色海绵放到红色海绵右边。
回应:{"action": ["pick_up('green')","place_on('red', 'right')"], "response": "来活了,兄弟们"}
任务:红色海绵在绿色海绵上面,将绿色海绵放到红色海绵左边。
回应:{"action": ["pick_up_on('red')", "place_random()", "pick_up('green')", "place_on('red', 'left')"], "response": "来活了,兄弟们"}
任务:红色海绵在绿色海绵上面,将红色海绵放到绿色海绵右边。
回应:{"action": ["pick_up_on('red')", "place_on('green', 'right')"], "response": "看我表演"}
任务:绿色海绵在红色海绵上面,将绿色海绵搬到红色海绵左边。
回应:{"action": ["pick_up_on('green')", "place_on('red', 'left')"], "response": "这可难不倒我"}
任务:绿色海绵在红色海绵上面,将绿色海绵搬到红色海绵右边。
回应:{"action": ["pick_up_on('green')", "place_on('red', 'right')"], "response": "这可难不倒我"}
任务:绿色海绵在红色海绵左边,将红色海绵放到绿色海绵上面。
回应:{"action": ["pick_up('red')", "place_on('green', 'top')"], "response": "红色海绵,咱们飞到绿色海绵上吧"}
任务:红色海绵在绿色海绵右边,将绿色海绵放到红色海绵上面。
回应:{"action": ["pick_up('green')", "place_on('red', 'top')"], "response": "开始执行任务,绿色海绵放到红色海绵上"}
任务:红色海绵在绿色海绵上面,将绿色海绵放到红色海绵上面。
回应:{"action": ["pick_up_on('red')", "place_random()", "pick_up('green')", "place_on('red', 'top')"], "response": "来活了,兄弟们"}
    vllm_prompt = '''
描述图片中带颜色海绵方块在三维空间上相互之间的位置关系, 用上面,下面,左边,右边等方位词来描述, 请用最简洁的文字回复
    llm_prompt = '''
**Role
You are an embodied intelligent transportation robot. Your task is to move objects based on specific rules and procedures. You must determine the order of operations according to the relative positions of the objects and follow a series of handling logic and action steps.
**Understanding Relative Positions:
You need to understand spatial relationships between objects, including terms like above, below, left of, right of, and next to.
**Transport Logic and Action Steps:
1 Before executing any task, identify the relative positions of all objects to ensure the sequence of operations matches the actual layout.
2 If the target object is beneath another object, you must first move the object(s) on top to another location before handling the target object.
3 If the target object is on top of or beside another object, you may proceed to move it directly.
4 If you're directly instructed to place an object somewhere without first picking anything up, you must pick it up first.
5 When placing objects, always follow the specified direction (e.g., top, left, right).
**Available Functions:
Pick up a target object: pick_up('red')
Pick up a target object that is on top of another object: pick_up_on('red')
Place the object in a random or adjacent location: place_random()
Place the object in a specified direction relative to another object: place_on('blue', 'left')
**Example:
Task: Put down the green sponge.
Response: {"action": ["place_random()"], "response": "Let's move the green sponge somewhere else."}
Task: Place the green sponge to the right of the red sponge.
Response: {"action": ["pick_up('green')","place_on('red', 'right')"], "response": "Got a task, let's go!"}
Task: The red sponge is on top of the green sponge. Move the green sponge to the left of the red sponge.
Response: {"action": ["pick_up_on('red')", "place_random()", "pick_up('green')", "place_on('red', 'left')"], "response": "Got a task, let's go!"}
Task: The red sponge is on top of the green sponge. Move the red sponge to the right of the green sponge.
Response: {"action": ["pick_up_on('red')", "place_on('green', 'right')"], "response": "Watch me work!"}
Task: The green sponge is on top of the red sponge. Move the green sponge to the left of the red sponge.
Response: {"action": ["pick_up_on('green')", "place_on('red', 'left')"], "response": "That's easy for me!"}
Task: The green sponge is on top of the red sponge. Move the green sponge to the right of the red sponge.
Response: {"action": ["pick_up_on('green')", "place_on('red', 'right')"], "response": "That's easy for me!"}
Task: The green sponge is to the left of the red sponge. Move the red sponge on top of the green sponge.
Response: {"action": ["pick_up('red')", "place_on('green', 'top')"], "response": "Red sponge, let's fly up to the green sponge!"}
Task: The red sponge is to the right of the green sponge. Move the green sponge on top of the red sponge.
Response: {"action": ["pick_up('green')", "place_on('red', 'top')"], "response": "Starting the mission, green sponge on top of red!"}
Task: The red sponge is on top of the green sponge. Move the green sponge on top of the red sponge.
Response: {"action": ["pick_up_on('red')", "place_random()", "pick_up('green')", "place_on('red', 'top')"], "response": "Got a task, let's go!"}
    vllm_prompt = '''
Describe the positional relationship between the colored sponge blocks in the picture in three-dimensional space, using directional words such as above, below, left, and right.Please describe in the shortest possible sentence
Based on the system’s language settings, configure the prompt words and select the appropriate large model for either the Chinese or English version.
Initialization
action.ctl.set_pwm_servo_pulse(1, 1000, 500)
action.ctl.set_pwm_servo_pulse(2, 1500, 500)
action.AGC.runActionGroup("stand")
kws = awake.WonderEchoPro("/dev/ttyUSB0")
    asr.update_session(model=asr_model, language="en")
    client = speech.OpenAIAPI(vllm_api_key, vllm_base_url)
Configure the head pan-tilt servo and execute the “stand” action group to position the robot in a standing state.
Initialize the serial device number for WonderEcho Pro, then select the appropriate large model and language version (Chinese or English) according to the system language.
Set the volume of WonderEcho Pro to 80 and play the “I am ready” audio.
Large Model Processing
Wake Word Detection
    print("asr_result:", asr_result)
if kws.wakeup(): Detects whether the wake word has been triggered. After detecting the wake word, the system will enter the recording and recognition phase:
asr_result = asr.asr(): Initiates audio recording and recognition, and records the speech content.
    result = client.vllm(asr_result, image, prompt=vllm_prompt, model=vllm_model)
    # Pass the recognition result to the agent for it to respond (将识别结果传给智能体让他来回答)
    print("vision_result:", result)
    print("question:", result + "," + asr_result)
If speech is recognized, capture the latest image frame. Pass both the latest image frame and the wake word to the vision language model, and retrieve the model’s response.
result = client.llm(result + asr_result, prompt=llm_prompt, model=llm_model)
action_list, response = None, []
if "action" in result:  # If a corresponding action is returned, extract and process it (如果有对应的行为返回那么就提取处理)
    result = eval(result[result.find("{"):result.find("}") + 1])
        action_list = result["action"]
    if "response" in result:
        response = result["response"]
    response = result
result = client.llm(result + asr_result, prompt=llm_prompt, model=llm_model): Combines the response from the Vision Language Model with the speech recognition result and sends them as a request to the large language model.
Main program
    global running
    while running:
            if stop_camera:
                if ret:
                    except queue.Full:
                    cv2.imshow("track", image)
                    cv2.waitKey(1)
            kws.exit()
                os.system("pinctrl FAN_PWM a0")
            except:
    cap.release()
