1. Acceleration Sensor Manual
1.1 Acceleration Sensor Description
1.1.1 Acceleration Sensor Introduction
The acceleration sensor is widely applicable for making devices such as handheld gaming controllers, 3D remote controllers, portable navigation systems, and similar equipment.
1.1.2 Working Principle
It primarily uses the MPU6050 component. It also integrates a 3-axis MEMS gyroscope, a 3-axis MEMS accelerometer, and an expandable Digital Motion Processor (DMP).
The acceleration features three 16-bit ADCs for both the gyroscope and accelerometer to convert measured analog signals into digital outputs. For precise tracking of fast and slow motion, its measurement range is adjustable.
The gyroscope supports ±250/±500/±1000/±2000°/s (dps), and the accelerometer supports ±2/±4/±8/±16g.
1.2 Notice
  1. Do not exceed the rated voltage range during use.
  2. Handle with care during use.
1.3 Specifications
For more information, you may refer to “Acceleration sensor schematic
1.3.1 Pin Instruction
Pin Instruction
5V Power Input
GND Ground
SDA SDA
SCL SCL
1.3.2 Specifications
AccelerationSensor
Parameter
Specification
Power Supply
DC 5V
Data Interface
I2C bus with a maximum clock frequency of 400 kHz
Connector Type
5264-4AW
Measurement Range
±2,±4,±8,±16g
Indicator Light (PWR) Description
The PWR LED lights up when powered.
Product Dimensions
50mmx20mm
Modular installation, compatible with Lego series.
1.4 Project Outcome
The MPU6050 sensor measures acceleration along three axes, converts the analog values into digital data, and outputs them via the IIC bus. When the device is rotated, the acceleration value changes on the corresponding axis and is shown on the serial monitor.
