2. Arduino Development
2.1 Getting Started
2.1.1 Wiring Instruction
This section illustrates connecting a 4-pin cable to the SDA and SCL ports on the Arduino expansion board. Refer to the diagram below.
If you do not have an Arduino expansion board, use a Dupont wire to directly connect to the Arduino development board, just as below:
If the battery is not connected to the cables, do not connect the cable ends directly together. Doing so may cause a short circuit and damage the system.
You can install the Arduino IDE on a PC. Download path: “Appendix→ Arduino Installation Package.” For more information, please refer to the relevant tutorials.
2.2 Test Case
Program to display the values detected by the accelerometer sensor in the terminal window.
2.2.1 Program Download
For the Arduino and UNO development board equipped with the expansion board, use a USB cable to connect them to the computer. You can open Arduino IDE, click “File → NewFile → New,” and import the program located in the same directory as this tutorial.
Remember to select the correct development board and port. The ports shown below are for reference only. Then compile and upload the program.
After the code is uploaded, click
to open the serial monitor, set the baud rate to 9600 to observe the output.
2.2.2 Project Outcome
The data on the serial monitor change continuously when the accelerometer is adjusted manually. Along the sensor’s X, Y, and Z axes, ax, ay, and az represent multiples of gravitational acceleration; gx, gy, and gz represent angular velocity; and GX and GY represent tilt angles along the X and Y axes.
2.2.3 Program Brief Analysis
Import Libraries
#include <MPU6050.h> //Include the MPU6050 library
#include <I2Cdev.h> //Include the I2C communication library
Define variables
MPU6050 accelgyro;
int16_t ax, ay, az; //Get 3-axis acceleration values from the sensor
int16_t gx, gy, gz; //Get the sensor's 3-axis tilt angles
float ax0, ay0, az0; //Store filtered acceleration values
float gx0, gy0, gz0; //Store filtered tilt angles
float ax1, ay1, az1; //Store calibrated acceleration values
float gx1, gy1, gz1; //Store calibrated angular velocity values
float dx;
float dx;
/* Store deviation values of tilt angles and acceleration */
int ax_offset, ay_offset, az_offset, gx_offset, gy_offset, gz_offset;
float radianY; //Record tilt angle along the X axis
float radianY; //Record tilt angle along the Y axis
float radianZ; //Record tilt angle along the z axis
float radianX_last; //Final X-axis tilt angle
float radianY_last; //Final Y-axis tilt angle
Define the variables required for calculations.
Update tilt sensor data
void update_mpu6050()
static uint32_t timer_u;
if (timer_u < millis())
timer_u = millis() + 20;
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
ax0 = ((float)(ax)) * 0.3 + ax0 * 0.7; //Apply filtering to the read values
ay0 = ((float)(ay)) * 0.3 + ay0 * 0.7;
az0 = ((float)(az)) * 0.3 + az0 * 0.7;
ax1 = (ax0 - ax_offset) / 8192.0; // Calibrate and convert to g-force multiples
ay1 = (ay0 - ay_offset) / 8192.0;
az1 = (az0 - az_offset) / 8192.0;
gx0 = ((float)(gx)) * 0.3 + gx0 * 0.7;//Filter the read angular velocity values
gy0 = ((float)(gy)) * 0.3 + gy0 * 0.7;
gz0 = ((float)(gz)) * 0.3 + gz0 * 0.7;
gx1 = (gx0 - gx_offset); //Calibrate angular velocity
gy1 = (gy0 - gy_offset);
gz1 = (gz0 - gz_offset);
// Compute X-axis tilt angle using complementary filter
radianX = atan2(ay1, az1);
radianX = radianX * 180.0 / 3.1415926;
float radian_temp = (float)(gx1) / 16.4 * 0.02;
radianX_last = 0.8 * (radianX_last + radian_temp) + (-radianX) * 0.2;
// Compute Y-xis tilt angle using complementary filter
radianY = atan2(ax1, az1);
radianY = radianY * 180.0 / 3.1415926;
radian_temp = (float)(gy1) / 16.4 * 0.01;
radianY_last = 0.8 * (radianY_last + radian_temp) + (-radianY) * 0.2;
Print data
void print_data()
static uint32_t timer_p;
static uint32_t timer_printlog;
Serial.print("ax:"); Serial.print(ax1);
Serial.print(", ay:"); Serial.print(ay1);
Serial.print(", az:"); Serial.print(az1);
Serial.print(", gx:"); Serial.print(gx1);
Serial.print(", gy:"); Serial.print(gy1);
Serial.print(", gz:"); Serial.print(gz1);
Serial.print(", GX:"); Serial.print(radianX_last);
Serial.print(", GY:"); Serial.print(radianY_last);
timer_p = millis() + 500;
Serial Port Initialization
void setup()
Serial.begin(9600);
//MPU6050 Configuration
Wire.begin();
accelgyro.initialize();
accelgyro.setFullScaleGyroRange(3); //Set the full-scale gyroscope range
accelgyro.setFullScaleAccelRange(1); //Set the full-scale accelerometer range
delay(200);
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz); //Obtain current axis data for calibration
ax_offset = ax; //Calibrated X-axis acceleration data
ay_offset = ay; //Calibrated Y-axis acceleration data
az_offset = az - 8192; //Calibrated Z-axis acceleration data
gx_offset = gx; // X-axis calibrated angular velocity data
gy_offset = gy; // Y-axis calibrated angular velocity data
gz_offset = gz; // Z-axis calibrated angular velocity data
delay(1500);
Loop Process
void setup()
update_mpu6050:
print_data();
delay(500);
