6. ROS+OpenCV Course
6.1 Color Threshold Adjustment
6.1.1 Open/Close LAB TOOL
  • The entered command should be case sensitive, and the “Tab” key can be used to complement key words.
  • Please strictly follow the operation steps; otherwise, you will fail to open LAB tool.
(1) Start the robot and connect it to Nomachine remote connection software.
(2) Click on to start the command line terminal.
(3) Input the command and press Enter to disable app auto-start service.
(4) Input the command and press Enter to enable the camera node.
(5) Open a new command-line terminal and input the command to open LAB tool.
python3 /home/ubuntu/software/lab_tool/main.py
(6) Regarding the interface button instructions and usage, you can refer to the following content. If you want to close it, please click on and select “Yes” in the popup window.
(6) After closing LAB tool, press “Ctrl+C” to close the terminal, and input the command to restart app auto-start service. After the service is enable, robot arm will restore the initial po
If you do not enable app auto-start service for the robot, it will affect the corresponding app functions. Restarting robot can also automatically enable the app auto-start service.
6.1.2 LAB TOOL Interface Layout Instruction
(1) Image display area: the left displays the processed image and the right is the raw image.
if the transmitted image does not display normally, it’s the issue of camera connection. In this case, you need to examine if the wiring is connected properly or reconnect it.
(2) Recognition adjustment area: adjust the color threshold. The function of each button refer to the following table:
Icon Function instruction
The sliders L, A and B are used respectively to adjust the values of the corresponding L, A and B components of the image.
The sliders on the left are the "**min**" value for each component while the slider on the right are the "max"value for each component.
Add recognizable color.
Close LAB TOOL.
6.1.3 Adjust Color Threshold
(1) Open LAB tool. Choose the color in the color drop-down list of color recognition area. Take a color “red” as example.
(2) Adjust the “min”values of L, A and B components to “0”, the “max”values to “225”.
(3) Place the target within the camera’s field of view. Adjust the values of L, A and B component towards the interval representing the target recognition color according to the LAB color space distribution chart.
Red color is close to “+a”, which indicates that A component needs to be increased. Therefore, keep the “max”value of the A component unchanged and increase its “min”value until the object on the left turns white while other areas turn black.
(4) Adjust the L and B components according to your surroundings. If the red color is light, increase the “min”value of the L component; if it is dark, decrease the “max”value of the component. If the red color tends to be warm, increase the “min” value of the B component; if it tends to be cool, decrease the “max” value of the B component.
Color component Value Range **Corresponding Color Intervals **
L 0~255 Black-white (-L~+L)
A 0~255 green-red(-a ~ +a)
B 0~255 Blue-yellow(-b ~ +b)
(5) Click “Save”button in adjustment area to save the adjustment parameters.
6.1.4 Add New Color
(1) Open LAB tool and click on “Add”button.
(2) Fill in the “name” column with the color name, and click the “OK” button.
(3) Choose the added color in the color drop-down menu.
(4) Place the target within the camera’s field of view, and adjust the threshold by dragging the L, A, and B component sliders until the area of the colored object within the left screen turns white, while the other areas turn black.
the adjustment method of color threshold refers to 6.1.3 Adjust Color Adjustment.
(5) Click “Save”button in recognition adjustment area to save the adjustment parameters of color threshold.
After adjusting the color thresholds, press ‘Ctrl+C’ to stop the camera service, then click ‘Close Software’ to close the interface.
6.2 Color Recognition
This session will use OpenCV to perform red, green, blue recognition and display the recognition result through transmitted image. Before operations, please prepare one object of red, green and blue.
6.2.1 Recognition Process
Firstly, obtain the RGB image from the camera. Scale and apply Gaussian blur to the image. Convert the image from RGB to Lab. (For detailed explanations regarding the Lab color space.
Next, identify the object color in the circle by using color thresholds, followed by masking of the image portion. (masking is used to hide certain part of the processed image).
Finally, the recognition results are displayed on the screen.
6.2.2 Operation Steps
the entered command should be case sensitive and “Tab” key can be used to complement the key words.
(1) Start JetAuto and connect it to Nomachine.
(4) Run the following command to enable the camera node:
(5) Open a new command line terminal, enter the following command to navigate to the program directory and start the color recognition game:
cd ~/ros2_ws/src/example/example/color_detect && python3 color_detect_demo.py
(6) Next, press “Ctrl+C” in the command line terminal interface. If closing fails, please try again repeatedly.
6.2.3 Program Outcome
After the game starts, please ensure that there are no other objects containing recognized colors within the field of view of the camera to avoid affecting the implementation effect.
After the game starts, place the target object within the field of view of the camera. When recognizing the target object, it will be circled up in the same color and the color name will be printed in the lower-left corner of the screen. The program supports red, blue and green object recognition.
6.2.4 Program Analysis
The source code of the program is located in
/home/ubuntu/ros2/_ws/src/example/example/color_detect/color_detect_demo.py
  • Main Function
(1) Main Function
Initialize the ROS node, create a color recognition node named color_detect_node, subscribe to the image topic /depth_cam/rgb/image_raw, and set its callback function to image_callback. Start the main function for color recognition using multiple threads. Wait for the node to shut down.
    node = rclpy.create_node('color_detect_node')
    node.create_subscription(Image, '/depth_cam/rgb/image_raw', image_callback, 1)
    threading.Thread(target=main, daemon=True).start()
    rclpy.spin(node)
  • Image Processing
(1) Camera Callback Function
Primarily used to read the video stream from the topic and enqueue it to ensure real-time display.
    if image_queue.full():
        # If the queue is full, remove the oldest image(如果队列已满,丢弃最旧的图像)
        image_queue.get()
    image_queue.put(bgr_image)
(2) Color Recognition Main Function
This function reads image data from the queue, processes it using the run function for color recognition, and then displays the recognized image using cv2.
    running = True
    while running:
            image = image_queue.get(block=True, timeout=1)
            if not running:
        image = run(image)
        cv2.imshow('image', image)
        if key == ord('q') or key == 27:  # Press Q or Esc to quit(按q或者esc退出)
(3) YAML File Reading Function
def get_yaml_data(yaml_file):
    yaml_file = open(yaml_file, 'r', encoding='utf-8')
    file_data = yaml_file.read()
    yaml_file.close()
    data = yaml.load(file_data, Loader=yaml.FullLoader)
    return data
(4) Maximum Contour Function
This function takes contours detected by OpenCV as input, identifies the largest contour based on size, and returns the contour along with its area.
# Find out the contour with the maximal area(找出面积最大的轮廓)
# The parameter is the list of contour to be compared(参数为要比较的轮廓的列表)
    contour_area_temp = 0
    contour_area_max = 0
    area_max_contour = None
    for c in contours:  # Iterate through all contours(历遍所有轮廓)
        contour_area_temp = math.fabs(cv2.contourArea(c))  # Calculate contour area(计算轮廓面积)
            if contour_area_temp > 50:  # Only contours with an area greater than 50 are considered valid, and among them, the contour with the largest area is selected to filter out interference(只有在面积大于50时,最大面积的轮廓才是有效的,以过滤干扰)
                area_max_contour = c
    return area_max_contour, contour_area_max  # Return the maximal contour(返回最大的轮廓)
(5) Color Recognition Function
This function compresses the input image to a size of (320, 240) for easier detection, applies Gaussian filtering, and then converts the image to the LAB color space.
def run(img):
    global draw_color
    global color_list
    global detect_color
    img_copy = img.copy()
    img_h, img_w = img.shape[:2]
    frame_lab = cv2.cvtColor(frame_gb, cv2.COLOR_BGR2LAB)  # Convert the image to LAB space(将图像转换到LAB空间)
    max_area = 0
    color_area_max = None
    areaMaxContour_max = 0
The function iterates through a list of colors to identify the color of the largest detected contour.
        frame_mask = cv2.inRange(frame_lab, tuple(lab_data['lab']['Stereo'][i]['min']), tuple(lab_data['lab']['Stereo'][i]['max']))  #Perform bitwise operations on the original image and mask(对原图像和掩模进行位运算)
        eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3)))  #Corrosion(腐蚀)
        dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) #Dilation(膨胀)
        contours = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE)[-2]  #Find out contours(找出轮廓)
        areaMaxContour, area_max = getAreaMaxContour(contours)  #Find out the contour with the maximum area(找出最大轮廓)
            if area_max > max_area:#Find the maximal area(找最大面积)
                max_area = area_max
                color_area_max = i
Contours with an area smaller than 200 are filtered out. If the area is larger than 200, the function calculates the contour coordinates and draws the detected color’s position on the screen.
    if max_area > 200:  # The maximum area is found(有找到最大面积)
        ((centerX, centerY), radius) = cv2.minEnclosingCircle(areaMaxContour_max)  # Get the minimum circumcircle(获取最小外接圆)
        cv2.circle(img, (centerX, centerY), radius, range_rgb[color_area_max], 2)#Draw circle(画圆)
        if color_area_max == 'red':  #Red is the maximal area(红色最大)
            color = 1
        elif color_area_max == 'green':  #Green is the maximal area(绿色最大)
            color = 2
        elif color_area_max == 'blue':  #Blue is the maximal area(蓝色最大)
            color = 3
            color = 0
        color_list.append(color)
        if len(color_list) == 3:  #Multiple judgement(多次判断)
            # Take average value(取平均值)
            color = int(round(np.mean(np.array(color_list))))
            color_list = []
            if color == 1:
                detect_color = 'red'
                draw_color = range_rgb["red"]
            elif color == 2:
                detect_color = 'green'
                draw_color = range_rgb["green"]
            elif color == 3:
                detect_color = 'blue'
                draw_color = range_rgb["blue"]
                detect_color = 'None'
                draw_color = range_rgb["black"]
    return img
image_queue = queue.Queue(2)
6.3 Generate & Recognize QR Code
This lesson is divided into two parts. The first part will introduce you how to learn to create a QR code, while the second part focuses on recognizing the created QR code and then decoding the QR code information through the terminal.
6.3.1 Generate QR Code
  • Process
Finally, generate a QR CODE image based on the data and display it in a window, and save it in the corresponding path.
  • Operation Steps
the entered command should be case sensitive and the “Tab” key can be used to fill in key words.
(1) Start the robot and connect it to Nomachine.
(4) Input the command to access the program directory and start the QR code creation program. After start the program, it’s necessary to enter characters in the terminal to generate the QR code. Take the input of “ubuntu” as example.
cd ~/ros2_ws/src/example/example/qrcode && python3 qrcode_creater.py
Press “Enter”to display a QR code image containing the input data.
(5) If need to close the program, press “Esc” or “q” on the qr code window.
(6) Back to the command line terminal. If the following content prompts, indicating the qr card is successfully generated than saved.
(7) Next, we click on on the left side of the system interface, then click to open the file manager, and navigate to the directory highlighted in the red box in the screenshot below. Here, you can see that the generated QR code has been exported to the host system.
(8) Drag the image to your PC desktop using the NoMachine tool’s drag-and-drop feature. Then, you can print it out or transfer it to your mobile phone’s photo album.
The source code of this program is located at:
/home/ubuntu/ros2_ws/src/example/example/qrcode/qrcode_creater.py
(1) Creating QR Code Utility Object
Using the qrcode module to create the necessary object and setting various parameters for the QR code.
qr = qrcode.QRCode(
    version=1,
    box_size=5,
    border=4)
The parameters of the above function are as follows:
The first parameter “version” is an integer ranging from 1 to 40, used to control the size of the QR code. If you want the program to automatically determine the size, set this value to None and use the “fit” parameter.
The second parameter “error_correction” controls the error correction capability of the QR code, with the following options:
① ERROR_CORRECT_L: can correct approximately 7% or fewer errors.
② ERROR_CORRECT_M: default value, can correct approximately 15% or fewer errors.
③ ERROR_CORRECT_H: can correct approximately 30% or fewer errors.
The third parameter “box_size” controls the number of pixels contained in each small box of the QR code.
The fourth parameter “border” controls the number of boxes included in the border (distance between the QR code and the image boundary), with a default value of 4, which is the minimum value specified by relevant standards.
(2) Generating QR Code
Using the “add_data” and “make” functions to retrieve and fill data, and then using the “make_image” function to generate the image.
# Add data(添加数据)
qr.add_data(data)
# Fill data(填充数据)
qr.make(fit=True)
# Generate image(生成图片)
The parameters of the “make_image” function are as follows:
The first parameter “fill_color=(0, 0, 0)” is the fill color of the image, which is black in this case.
The second parameter “back_color=(255, 255, 255)” is the background color of the image, which is white in this case.
(3) Displaying Image
Converting the color space of the image using the “cvtColor” function, and then displaying it on the window using the “imshow” function.
    cv2.imshow('img', opencv_img)
    k = cv2.waitKey(1)
    if k != -1:
(4) Saving Image
Using the “imwrite” function to store the generated QR code image and printing relevant information.
The parameters of the “imwrite” function are as follows:
The first parameter “file_name” is the storage path of the image.
The second parameter “opencv_img” is the image to be stored.
6.3.2 QR Code Recognition
In the previous section, we created a QR code. In this section, we’ll perform content recognition on the QR code.
  • Recognition Process
Firstly, create an instance object for QR code detection, and pass in the required network structure and model weight files for detection.
Then, obtain the camera’s feedback image and perform detection.
Finally, once the QR code is recognized, it will be framed, and the content of the QR code will be printed.
The source code for this program is located at: /home/ubuntu/ros2_ws/src/example/example/qrcode/qrcode_detecter.py
  • QR Code Recognition Steps
When entering commands, it is necessary to strictly distinguish between uppercase and lowercase letters, and you can use the “Tab” key to complete keywords.
(1) Start the robot and connect it to the remote control software Nomachine.
(2) Click on on the system desktop to start the command line terminal.
(3) Enter the command to disable the automatic startup service of the app:
(4) Enter the command to start the camera node:
(5) Open a new ROS2 command line terminal, enter the command to switch to the program directory, and start the QR code recognition program:
cd ~/ros2_ws/src/example/example/qrcode && python3 qrcode_detecter.py
To close this game, press “Ctrl+C” in the terminal interface. If closing fails, please try again repeatedly.
  • Program Outcome
After starting the game, it will recognize the QR code images appearing in the feedback screen, mark them with a red box, and print out the content of the QR code.
The source code of this program is saved in /home/ubuntu/ros2_ws/src/example/example/qrcode/qrcode_detecter.py
(1) Main Function
Initialize the QRCodeDetectNode and set the node name as “qrcode_detect”. Wait for the ROS node to close, and if it closes, unregister the current node.
    node = QRCodeDetectNode('qrcode_detect')
        rclpy.spin(node)
        print('shutdown')
        print('shutdown finish')
    main()
(2) QRCodeDetectNode Class
Initialize the node and define parameters, then start the self.main function.
① Parameters:
self.running: Whether the detection is enabled
self.model_path: Model path
self.image_queue: Image queue
self.image_sub: Subscription to read camera feedback images
self.qcd: Initialization of the QR code detection
class QRCodeDetectNode(Node):
        self.bridge = CvBridge()
        self.model_path = os.path.join(os.path.abspath(os.path.split(os.path.realpath(__file__))[0]), 'model/detector.tflite')
        self.qcd = cv2.QRCodeDetector()
② Functions:
The camera callback function reads the camera feedback image and places it in the queue self.image_queue for automatic update and discarding of expired images.
The main function begins by performing QR code detection. It checks the self.running parameter to determine whether to start detection. If True, it reads image data from the self.image_queue queue, inputs it into the initialized recognition model self.qcd, and finally prints the recognition results and draws recognition boxes based on the output data.
            ret_qr, decoded_info, points, _ = self.qcd.detectAndDecodeMulti(image)
            if ret_qr:
                for s, p in zip(decoded_info, points):
                    if s:
                        print(s)
                        color = (0, 255, 0)
                        color = (0, 0, 255)
                    image = cv2.polylines(image, [p.astype(int)], True, color, 8)
            if key == ord('q') or key == 27:  # Put the image into the queue(将图像放入队列)
6.4 Autonomous Line Following
6.4.1 Recognition Procedure
First, obtain the RGB image from the camera and resize it. Apply Gaussian blur to the image and convert the color space from RGB to Lab.
Then, perform color recognition on the objects in the circle using color thresholding. Apply masking to parts of the image. (Masking is used to globally or locally mask the processed image using selected images, graphics, or objects).
Afterward, perform opening and closing operations on the object images. Finally, outline the largest object with a circle.
Opening operation: First, erode the image and then dilate it. Purpose: Used to eliminate small objects, smooth the shape boundary, and not change its area. It can remove small grain noise and break the adhesion between objects.
Erosion: Eliminate the boundary points of the object, causing the boundary to shrink inward, and can remove objects smaller than the structural element.
Dilation: Expand the boundary points of the object, merge all background points in contact with the object into the object, and expand the boundary outward.
Finally, feedback the recognition results on the feedback screen.
6.4.2 Autonomous Line Following Operation
The input command should be case sensitive, and keywords can be complemented using “Tab” key.
(4) Run the command to enable the camera node
(5) Open a command line terminal, enter the command to navigate to the program directory, and start the line-following game:
(6) Then, in the current command line terminal, enter the command to navigate to the program directory and start the line-following game:
(7) Click on the position of the line in the image to select the corresponding color of the track line, and you can start line following by color picking.
(8) If you need to close this function, you need to return to the command line terminal and enter the command to stop it.
If you need to close this game, press “Ctrl+C” in the terminal. If fail to close, please try multiple times.
6.4.3 Program Analysis
  • Launch Analysis:
The program file corresponding to this section of the course document is located at: /home/ubuntu/ros2_ws/src/app/launch/scripts/line_following_node.launch.py
(1) Read the Storage Path
Use get_package_share_directory to obtain the package path.
(2) Launch
        IncludeLaunchDescription(
            condition=IfCondition(debug),
        Node(
            package='app',
            executable='line_following',
controller_launch: Start motion control launch.
depth_camera_launch: Start depth camera launch.
lidar_launch: Start lidar launch.
(3) Node
line_following_node: Start line following node.
        Node(
            package='app',
  • Source Code Analysis:
/home/ubuntu/ros2_ws/src/app/app/line_following.py
It’s necessary to back up the original program file before making any modification to the program. You’re forbidden to modify the original source code file to avoid causing robot malfunctions that may be irreparable due to incorrect parameter modifications!
Then, the color picker object is defined (used in the game to pick colors), along with the setting of additional Lidar obstacle avoidance functionality. Next is the implementation of the LineFollower class, which mainly includes functions for image preprocessing and logic for line following.
  • Function:
(1) Main: Initiate line following node.
378
379
380
381
382
    node = LineFollowingNode('line_following')
    rclpy.spin(node)
(2) Class:LineFollower.
class LineFollower:
(3)Init: Set the line-following color and ROI list.
    def __init__(self, color, node):
        self.node = node
        self.target_lab, self.target_rgb = color
        self.rois = ((0.90, 0.92, 0, 1, 0.7), (0.78, 0.80, 0, 1, 0.2), (0.66, 0.68, 0, 1, 0.1))
        self.weight_sum = 1.0
(4) get_area_max_contour:Get the contour with the maximum area.
        Get the contour of the largest area(获取最大面积对应的轮廓)
        :param contours:
        :param threshold:
        :return:
        if len(contour_area) > 0:
            return max_c_a
        return None
(5) Call:Perform color recognition, identify based on the set color, and provide feedback on the recognized image and angle.
    def __call__(self, image, result_image, threshold, color=None, use_color_picker=True):
        centroid_sum = 0
        h, w = image.shape[:2]
        if use_color_picker:
            min_color = [int(self.target_lab[0] - 50 * threshold * 2),
                         int(self.target_lab[1] - 50 * threshold),
                         int(self.target_lab[2] - 50 * threshold)]
            max_color = [int(self.target_lab[0] + 50 * threshold * 2),
                         int(self.target_lab[1] + 50 * threshold),
                         int(self.target_lab[2] + 50 * threshold)]
            target_color = self.target_lab, min_color, max_color
            lowerb = tuple(target_color[1])
            upperb = tuple(target_color[2])
            lowerb = tuple(color['min'])
            upperb = tuple(color['max'])
        for roi in self.rois:
            blob = image[int(roi[0]*h):int(roi[1]*h), int(roi[2]*w):int(roi[3]*w)]  # Intercept roi(截取roi)
            img_lab = cv2.cvtColor(blob, cv2.COLOR_RGB2LAB)  # Convert rgb into lab(rgb转lab)
            img_blur = cv2.GaussianBlur(img_lab, (3, 3), 3)  # Perform Gaussian filtering to reduce noise(高斯模糊去噪)
            mask = cv2.inRange(img_blur, lowerb, upperb)  # Image binarization(二值化)
            eroded = cv2.erode(mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3)))  # Corrode(腐蚀)
            dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3)))  # Dilate(膨胀)
            # cv2.imshow('section:{}:{}'.format(roi[0], roi[1]), cv2.cvtColor(dilated, cv2.COLOR_GRAY2BGR))
            contours = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_TC89_L1)[-2]  # Find the contour(找轮廓)
            max_contour_area = self.get_area_max_contour(contours, 30)  # Get the contour corresponding to the largest contour(获取最大面积对应轮廓)
                rect = cv2.minAreaRect(max_contour_area[0])  # Minimum circumscribed rectangle(最小外接矩形)
                box = np.intp(cv2.boxPoints(rect))  # Four corners(四个角)
                for j in range(4):
                    box[j, 1] = box[j, 1] + int(roi[0]*h)
                cv2.drawContours(result_image, [box], -1, (0, 255, 255), 2)  # Draw the rectangle composed of four points(画出四个点组成的矩形)
(6) LineFollowingNode:
(7) Init:Initialize the required parameters for the program, call the base node, camera node, and start services such as enter, exit, start, set color, get color, set threshold, etc.
        self.name = name
        self.color = ''
        self.set_above = False
        self.set_callback = False
        self.is_running = False
        self.color_picker = None
        self.follower = None
        self.empty = 0
        self.stop = False
        self.threshold = 0.5
        self.stop_threshold = 0.4
        self.lock = threading.RLock()
        self.image_sub = None
        self.lidar_sub = None
        self.image_height = None
        self.image_width = None
        self.use_color_picker = True
(8) get_node_state:Set the status of the current node.
(9) Main:Read the image and use the mouse to pick colors.
            cv2.imshow("image", cv2.resize(result, (display_size[0], display_size[1])))
                self.set_callback = True
                # Set callback function for mouse clicking event(设置鼠标点击事件的回调函数)
                cv2.setMouseCallback("image", self.mouse_callback)
            k = cv2.waitKey(1)
            if k != -1:
            if self.debug and not self.set_above:
                self.set_above = True
(10) mouse_callback:Mouse color picking callback function, obtains the pixel coordinates of the current mouse position.
            msg = SetPoint.Request()
                msg.data.x = x / self.image_width
                msg.data.y = y / self.image_height
(11) enter_srv_callback:Enter autonomous line-following service, read data from the camera and lidar, and initialize actions.
        with self.lock:
            self.color = ''
            self.stop = False
            self.empty = 0
            if self.image_sub is None:
                self.image_sub = self.create_subscription(Image, '/depth_cam/rgb/image_raw', self.image_callback, 1)  # Subscribe to the camera(摄像头订阅)
            if self.lidar_sub is None:
                self.lidar_sub = self.create_subscription(LaserScan, '/scan_raw', self.lidar_callback, qos)  # Subscribe to Lidar data(订阅雷达数据)
            set_servo_position(self.joints_pub, 1, ((1, 500), (9, 500)))
        response.message = "enter"
(12) exit_srv_callback:Exit autonomous line-following service, close various reading nodes, reset PID, and stop line following.
        with self.lock:
        response.message = "exit"
(13) set_target_color_srv_callback:Set line-following color service.
        with self.lock:
            if x == -1 and y == -1:
(14) get_target_color_srv_callback:Set up autonomous line-following game.
    def get_target_color_srv_callback(self, request, response):
        self.get_logger().info('\033[1;32m%s\033[0m' % "get_target_color")
        response.success = False
        response.message = "get_target_color"
        with self.lock:
            if self.follower is not None:
                rgb = self.follower.target_rgb
                response.message = "{},{},{}".format(int(rgb[0]), int(rgb[1]), int(rgb[2]))
(15) set_threshold_srv_callback:Set color threshold service.
    def set_threshold_srv_callback(self, request, response):
        self.get_logger().info('\033[1;32m%s\033[0m' % "set threshold")
        with self.lock:
            self.threshold = request.data
            response.message = "set_threshold"
(16) lidar_callback:Lidar callback function, reorganizes and collates the data read, and determines whether to stop moving forward.
282
284
285
286
287
288
289
290
291
292
294
295
296
297
298
299
300
301
302
303
305
306
307
308
309
310
311
312
        # Data size= scanning angle/ the increased angle per scan(数据大小 = 扫描角度/每扫描一次增加的角度)
        if self.lidar_type != 'G4':
            left_ranges = lidar_data.ranges[:max_index]  # The left data(左半边数据)
            right_ranges = lidar_data.ranges[::-1][:max_index]  # The right data(右半边数据)
        elif self.lidar_type == 'G4':
            left_ranges = lidar_data.ranges[min_index:max_index][::-1]  # The left data(左半边数据)
            right_ranges = lidar_data.ranges[::-1][min_index:max_index][::-1]  # The right data(右半边数据)
        # Get data according to settings(根据设定取数据)
        angle = self.scan_angle / 2
        # Take the nearest distance left and right(取左右最近的距离)
                self.stop = True
                if self.count > 5:
                    self.stop = False
(17) image_callback:Camera callback function, invokes the color picker based on the read data, and moves the robot according to the recognized line using PID control.
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
        result_image = np.copy(rgb_image)  #  The image used to display the result(显示结果用的画面)
        with self.lock:
            if self.use_color_picker:
                # Color picker and line recognition are exclusive. If there is color picker, start picking(颜色拾取器和识别巡线互斥, 如果拾取器存在就开始拾取)
                if self.color_picker is not None:  # Color picker exists(拾取器存在)
                        if target_color is not None:
                            self.follower = LineFollower(target_color, self)
                    twist.linear.x = 0.15
                            result_image, deflection_angle = self.follower(rgb_image, result_image, self.threshold)
                            if deflection_angle is not None and self.is_running and not self.stop:
                                self.pid.update(deflection_angle)
                                steering_angle = common.set_range(-self.pid.output, -math.radians(150/1000*240), math.radians(150/1000*240))
                                if steering_angle != 0:
                                    R = 0.213/math.tan(steering_angle)
                            elif self.stop:
                                self.pid.clear()
