10. Large AI Model Courses
10.1 Large Models Basic Courses
10.1.1 Large Language Model Courses
Overview of Large Language Model
(1) Basic Concept
(2) Features
(3) Working Principle
(4) Application Scenarios
① Text Generation
② Text Classification
③ Machine Translation
④ Question-Answering Systems
Large Language Model Deployment
In the future, you can directly go to the 10.2 Deployment of Multimodal Large Model course to learn about machine models. After completing the machine model course, you can then learn the following courses
Large Language Model Accessing
To proceed with this section, you will need to register on the appropriate website and obtain the API key for the large model (please refer to the file 10.1.1 Large Language Model Courses -> Large Language Model Deployment).
(1) Environment Configuration
sudo apt install vim
sudo apt install gedit
sudo apt install python3 python3-pip python3-all-dev python3-pyaudio portaudio34.dev libsndfile1
① In this section, locate the Appendix -> Source Code folder within the same directory as this tutorial document.
② Using the MobaXterm remote connection tool (as outlined in the ‘5.5 Remote Access and File Transfer’ tutorial), drag the folder into the root directory of the main controller. The software installation package can be found in the Appendix -> Remote Access and File Transfer directory.
cd ~/large_models/speech_pkg/
| Type of main controller | Python version |
| jetson_nano | 3.6 |
| jetson_orin | 3.10 |
| rpi5 | 3.11 |
| rpi5_docker | 3.8 |
cd jetson_orin/
cp -r speech.so ..
cd ../..
pip3 install .
pip3 install openai -U
(3) Key Configuration
cd ~/large_models
vim config.py
③ Once the file is open, configure the OpenAI and OpenRouter keys by filling in the llm_api_key and vllm_api_key parameters, respectively (you can obtain these keys from the ‘10.1.1 Large Language Model Courses -> Large Language Model Deployment’ course).
(4) Running the Demo Program
python3 openai_llm_demo.py
Semantic Understanding with Large Language Model
Before starting this section, make sure you have completed the API key configuration outlined in the file 10.1.1 Large Language Model Courses -> Large Language Model Accessing.
cd large_models/
Emotional Perception with Large Language Model
To proceed with this section, ensure that you have completed the API key configuration as described in the file 10.1.1 Language Model Courses -> Large Language Model Accessing.
cd large_models/
python3 openai_llm_er_demo.py
10.1.2 Large Speech Model Courses
Overview of Large Speech Model
Their advantages include:
① Processing Methods
② Model Complexity
③ Recognition Capability
④Training Data Requirements
② Text-to-Speech (TTS)
Voice Device Introduction and Testing
(1) Device Overview
① WonderEchoPro
Introduction:
WonderEcho Pro, also known as the AI Voice Interaction Box, is equipped with a high-performance noise-canceling microphone and a high-fidelity speaker. It utilizes a USB-to-audio module, making it plug-and-play with no drivers required, and is compatible with multiple operating systems for both playback and recording.
Integrating various voice processing technologies, WonderEcho Pro features advanced noise suppression algorithms that effectively filter background noise from the environment. It supports a complete voice interaction process—from wake-up to recognition and response. With its modular design, each functional component (e.g., wake word detection, sound detection, speech recognition, and synthesis) can be developed and tested independently.
Features and Specifications:
Built-in microphone and speaker interface, supporting both audio input and output
Driver-free, plug-and-play functionality compatible with Windows, macOS, Linux, Android, and more
Standard USB 2.0 interface
Control interface: USB
Voice chip model: CL1302
Speaker output: 3.0W per channel (4Ω BTL)
Power supply voltage: 5V
② 6-Microphone Circular Array
Introduction:
② Recording Test
arecord -l
③ Playback Test
aplay test.wav
Voice Wake-Up
(1) WonderEcho Pro Wake-Up
Device Check:
To proceed, we need to identify the USB device name assigned to the connected WonderEcho Pro or Circular Microphone Array (hereafter referred to as the voice device). Please follow the steps below carefully.
ll /dev | grep USB
ll /dev | grep USB
Wake-Up Test:
vim wakeup_demo.py
Device Check:
Wake-Up Test:
② Press i to enter edit mode.
③ Update the port to match the device port number you previously identified. Comment out the WonderEcho Pro configuration (add # at the beginning of the corresponding line), and uncomment the line using the circular microphone array on line 11 as the input device (see red box in the referenced image).
(3) Brief Program Overview
Importing Required Modules
5 6 7 | import os import time from speech import awake |
9 10 | port = '/dev/ttyUSB0' kws = awake.WonderEchoPro(port) |
13 14 15 16 | try: # If a fan is present, it's recommended to turn it off before detection to reduce interference(如果有风扇,检测前推荐关掉减少干扰) os.system('pinctrl FAN_PWM op dh') except: pass |
Main Wake Word Detection Loop
18 19 | kws.start() # Start detection(开始检测) print('start...') |
Main Program Logic
20 21 22 23 24 25 26 27 28 29 30 31 | while True: try: if kws.wakeup(): # Wake-up detected(检测到唤醒) print('hello hiwonder') time.sleep(0.02) except KeyboardInterrupt: kws.exit() # Cancel processing (关闭处理) try: os.system('pinctrl FAN_PWM a0') except: pass break |
(4) Extended Functionality
vim wakeup_demo.py
i
python3 wakeup_demo.py
“Appendix → Firmware Flashing Tool → Creating Firmware for WonderEchoPro”.
Speech Recognition
(2) How It Works
Before proceeding, refer to the course “10.1.1 Large Language Models Courses -> Large Language Models Deployment” to obtain your API key, and make sure to add it into the configuration file (config).
(4) Experiment Steps
cd large_models/
vim config.py
python3 openai_asr_demo.py
(5) Function Realization
(6) Brief Program Analysis
① Module Import
6 | from speech import speech |
② Define ASR Class
11 | asr = speech.RealTimeOpenAIASR() |
13 | asr.update_session(model='whisper-1', language='en', threshold=0.2, prefix_padding_ms=300, silence_duration_ms=800) |
(7) Function Extension
vim openai_asr_demo.py
i
Speech Synthesis
(1) What is Speech Synthesis?
(2) How It Works
Refer to the course “10.1.1 Large Language Models Courses -> Large Language Models Deployment” to obtain your API key, and update the configuration file accordingly.
① Power on the device and connect to it using MobaXterm (refer to the appendix -> Remote Connection Tools and Instructions for detailed guidance).
cd large_models/
vim config.py
python3 openai_tts_demo.py
Upon running the program, it will play an audio message saying “Hello, Can I Help You”, and simultaneously save the audio file with the same content to the following directory: /home/ubuntu/large_models/resources/audio/
① Module Import
5 6 | from config import * from speech import speech |
② Definition for TTS Class
8 9 10 11 | tts = speech.RealTimeOpenAITTS() tts.tts("Hello, Can I help you?") # https://platform.openai.com/docs/guides/text-to-speech tts.tts("Hello, Can I help you?", model="tts-1", voice="onyx", speed=1.0, instructions='Speak in a cheerful and positive tone.') tts.save_audio("Hello, Can I help you?", model="gpt-4o-mini-tts", voice="onyx", speed=1.0, instructions='Speak in a cheerful and positive tone.', audio_format='wav', save_path="./resources/audio/tts_audio.wav") |
③ Function Extension
vim openai_tts_demo.py
i
Voice Interaction
(2) How It Works
(3) Experiment Steps
① Power on the device and connect to it via MobaXterm (refer to Appendix “5.1 Remote Connection Tools and Instructions” for connection guidance).
ll /dev | grep USB
cd large_models/
vim config.py
⑥ Run the program:
(4) Function Realization
(5) Brief Program Analysis
(1) Module Import
5 6 7 8 9 | import os import time from config import * from speech import awake from speech import speech |
11 12 13 | wakeup_audio_path = './resources/audio/en/wakeup.wav' start_audio_path = './resources/audio/en/start_audio.wav' no_voice_audio_path = './resources/audio/en/no_voice.wav' |
(3) Main Functional Logic
33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 | def main(): kws.start() while True: try: if kws.wakeup(): # Wake word detected(检测到唤醒词) speech.play_audio(wakeup_audio_path) # Play wake-up sound(唤醒播放) asr_result = asr.asr() # Start voice recognition(开启录音识别) print('asr_result:', asr_result) if asr_result: # Send the recognition result to the agent for a response(将识别结果传给智能体让他来回答) response = client.llm(asr_result, model='gpt-4o-mini') print('llm response:', response) tts.tts(response) else: speech.play_audio(no_voice_audio_path) time.sleep(0.02) except KeyboardInterrupt: kws.exit() try: os.system('pinctrl FAN_PWM a0') except: pass break except BaseException as e: print(e) |
10.1.3 Vision Language Model Courses
Overview of Vision Language Model
(1) Basic Concept
(2) Features
(3) How It Works
① Image Captioning
② Visual Question Answering
③ Image Retrieval
④ Augmented Reality (AR)
⑥ Social Media Interaction
⑦ Medical Imaging Analysis
Vision Language Model Accessing
This section requires the configuration of the API key in “10.1.1 Large Language Model Courses -> Large Language Model Deployment” before proceeding. Additionally, ensure that the images to be used in this section are imported.
This experiment requires either an Ethernet cable or Wi-Fi connection to ensure the main control device can access the network properly.
(1) Experiment Steps
cd large_models/
Run the program:
(2) Function Realization
Vision Language Model: Object Detection
In this course, we will use a program to transmit an image to the large model for recognition, which will then identify and locate the objects within the image by drawing bounding boxes around them.
cd large_models/
② Run the program:
(3) Function Expansion
Change Pictures:
② Then, input the command:
i
To: image = cv2.imread('./resources/pictures/apples.png')
Vision Language Model: Scene Understanding
In this course, we will use a program to send an image to the large model for recognition and generate a description of the content within the image.
cd large_models/
② Run the program:
④ Run the program:
Vision Language Model: Optical Character Recognition
In this course, we use a program to transmit an image to the large model for recognition, extracting and identifying the text within the image.
cd large_models/
② Run the program:
python3 openai_vllm_ocr.py
Change Pictures:
i
⑤ Run the program:
10.1.4 Multimodal Model Basic Courses
Overview of Multimodal Model
(1) Basic Concept
(2) Features
(3) How It Works
① Education
② Healthcare
③ Entertainment
④ Advertising and Marketing
Agent Behavior Orchestration
The purpose of this course experiment is to obtain data in a specified format returned by the large model based on the prompt words set in the model. During development, you can use the returned data for further tasks.
ll /dev | grep USB
cd large_models/
vim config.py
vim openai_agent_demo.py
⑤ Run the program:
python3 openai_agent_demo.py
When the device responds with “I’m here”. it indicates that the agent has been successfully awakened. To modify the wake word. For the Six-channel Microphone, refer to Voice Wake-Up – 2. 6-Microphone Circular Array for instructions on customizing the wake word. For WonderEcho Pro, refer to Section “Appendix->Firmware Flashing Tool -> WonderEchoPro Firmware Generation”.
10.2 Deployments of Multimodal Large Model
10.2.1 Voice Control with Multimodal Large Model
Brief Overview of Operation
Once the program starts running, the Six-Microphone Circular Array will announce “I’m Ready”, hereafter called the voice device. To activate the voice device, speak the designated wake words: “Hello Hiwonder.” Upon successful activation, the voice device will respond with “I’m Here.” Following activation, the robot can be controlled through voice commands. Example commands include: “Move forward, backward, turn left, turn right, sideways, and then drift.” The voice device will process the instruction, announce the corresponding response, and execute the specified action.
Getting Started
(1) Version Confirmation
Before starting this feature, verify that the correct microphone configuration is set in the system.
① Log in to the machine remotely via NoMachine. Then click the desktop icon
to access the configuration interface.
② First, verify the system language setting.
③ For the Six-Microphone Circular Array, select xf as the microphone type as shown in the figure.
④ After making the appropriate selection, click Save.
⑤ A “Save Success” message will confirm that the configuration has been stored in the system environment.
⑥ Then, click Quit to close the interface.
(2) Configuring the Large Model API-KEY
Open a new command-line terminal and enter the following command to access the configuration file.
vim /home/ubuntu/ros2_ws/src/large_models/large_models/large_models/config.py
Refer to the tutorial under 10.1.1 Large Language Model Courses -> Large Language Model Deployment to obtain the API keys. For the vision language model, acquire the API key from the OpenRouter official website and assign it to the vllm_api_key variable. For the large language model, obtain the API key from the OpenAI official website and assign it to the llm_api_key variable. Ensure that the keys are inserted in the designated positions, as indicated by the red boxes in the reference image.
Enabling and Disabling the Feature
Command input is case-sensitive and space-sensitive.
The robot must be connected to the Internet, either in STA (LAN) mode or AP (direct connection) mode via Ethernet.
(1) Open the command line terminal from the left side of the system interface. In the terminal window, enter the following command and press Enter to stop the auto-start service.
(2) Enter the following command and press Enter to launch the voice control feature.
ros2 launch large_models_examples llm_control_move.launch.py
(3) When the terminal displays output shown in the figure and the Circular Microphone Array announces “I’m ready”, the device has completed initialization. Then, you can say the wake words: “Hello Hiwonder”.
(4) When the terminal displays the corresponding output shown in the figure and the device responds with “I’m here”, it indicates successful activation. The system will begin recording the user’s voice command.
(5) When the terminal displays the next output as the reference image, it shows the recognized speech transcribed by the device.
(6) Upon receiving user input shown in the figure, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command, generate a language response, and execute a corresponding action based on the meaning of the command.
The response is automatically generated by the model. While the semantic content is accurate, the wording and structure may vary due to randomness in language generation.
(7) When the terminal shows the output shown in the figure indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 4 by speaking the wake words again.
(8) To exit the feature, press Ctrl+C in the terminal. If the feature does not shut down immediately, press Ctrl+C multiple times. If it still fails to exit, open a new terminal window and run the following command to terminate all active ROS processes and related programs.
Project Outcome
Once the feature is activated, feel free to give commands in your own words. For instance, “Move forward, backward, turn left, turn right, sideways, and then drift.” The robot will move forward and backward, shift left and right, and then perform a turning drift motion.
Program Brief Analysis
(1) Launch File Analysis
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_control_move.launch.py
① Import Libraries
Import the required modules for operating PuppyPi, including those for control services, large language model integration, and voice processing.
1 2 3 4 5 6 7 8 | import os from ament_index_python.packages import get_package_share_directory from launch_ros.actions import Node from launch.substitutions import LaunchConfiguration from launch import LaunchDescription, LaunchService from launch.launch_description_sources import PythonLaunchDescriptionSource from launch.actions import IncludeLaunchDescription, DeclareLaunchArgument, OpaqueFunction |
os: used for handling file paths and operating system-related functions.
ament_index_python.packages.get_package_share_directory: retrieves the share directory path of ROS 2 package.
launch_ros.actions.Node: used to define ROS 2 nodes.
launch.substitutions.LaunchConfiguration: retrieves parameter values defined in the Launch file.
LaunchDescription, LaunchService: used to define and start the Launch file.
launch_description_sources PythonLaunchDescriptionSource: enables the inclusion of other Launch files.
launch.actions.IncludeLaunchDescription, DeclareLaunchArgument, OpaqueFunction: used to define actions and arguments within the Launch file.
② Definition of the launch_setup Function
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) controller_package_path = get_package_share_directory('controller') large_models_package_path = get_package_share_directory('large_models') controller_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(controller_package_path, 'launch/controller.launch.py')), ) large_models_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ) llm_control_move_node = Node( package='large_models_examples', executable='llm_control_move', output='screen', ) return [mode_arg, controller_launch, large_models_launch, llm_control_move_node, ] |
This function is used to configure and initialize Launch actions.
mode = LaunchConfiguration('mode', default=1) defines a Launch argument named mode with a default value of 1.
mode_arg = DeclareLaunchArgument('mode', default_value=mode) declares the mode argument and includes it in the Launch description.
Controller_path and large_models_package_path represent the shared directory paths for the controller package responsible for robot movement and the large_models package.
controller_launch includes the Launch file controller.launch.py from the controller package using IncludeLaunchDescription.
large_models_launch includes the Launch file start.launch.py from the large_models package using IncludeLaunchDescription and passes the mode argument to it.
The function returns a list of all defined Launch actions.
③ Definition of the generate_launch_description Function
41 42 43 44 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function = launch_setup) ]) |
This function is responsible for generating the complete Launch description.
The launch_setup function is incorporated using OpaqueFunction.
④ Main Program Entry
46 47 48 49 50 51 52 | if __name__ == '__main__': # Create a LaunchDescription object(创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
ld = generate_launch_description() generates the Launch description object.
ls = LaunchService() creates the Launch service object.
ls.include_launch_description(ld) adds the Launch description to the service.
ls.run() starts the service and execute all Launch actions.
(2) Python File Analysis
File Path: ros2_ws/src/large_models_examples/large_models_examples/llm_control_move.py
① Prompt Template Definition
22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 | if os.environ["ASR_LANGUAGE"] == 'Chinese': PROMPT = ''' ##角色任务 你是一辆智能小车,可以通过 x 方向和 y 方向控制线速度,单位m/s,并通过 z 方向控制角速度,单位rad/s,t控制时间单位s。需要根据输入的内容,生成对应的指令。 ##要求 1.确保速度范围正确: 线速度:x, y ∈ [-1.0, 1.0](负值表示反方向) 角速度:z ∈ [-1.0, 1.0](逆时针为正, 顺时针为负) 2.顺序执行多个动作,输出一个 包含多个移动指令的 action 列表,仅在最后一个动作后添加 [0.0, 0.0, 0.0, 0.0] 以确保小车停止。 3.x和y默认为0.2, z默认为1, t默认为2。 4.为每个动作序列编织一句精炼(5至10字)、风趣且变化无穷的反馈信息,让交流过程妙趣横生。 5.直接输出json结果,不要分析,不要输出多余内容。 6.格式: { "action": [[x1, y1, z1, t1], [x2, y2, z2, t2], ..., [0.0, 0.0, 0.0, 0.0]], "response": "xx" } 7.很强的数学计算能力 ##特别注意 - "action"键下承载一个按执行顺序排列的函数名称字符串数组,当找不到对应动作函数时action输出[]。 - "response"键则配以精心构思的简短回复,完美贴合上述字数与风格要求。 ##任务示例 输入:向前移动 2 秒,然后顺时针旋转 1 秒 输出:{"action": [[0.2, 0.0, 0.0, 2.0], [0.0, 0.0, 1.0, 1.0], [0,0, 0.0, 0.0, 0.0]], "response": "前进 2 秒,然后顺时针旋转 1 秒,出发!"} 输入:向前走1米 输出:{"action": [[0.2, 0.0, 0.0, 5.0], [0.0, 0.0, 0.0, 0.0]], "response": "好嘞"} ''' else: PROMPT = ''' **Role You are an intelligent car that can be controlled via linear velocity on the x and y axes (in meters per second), and angular velocity on the z axis (in radians per second). The movement duration is controlled by t (in seconds). Your job is to generate a corresponding instruction based on user input. **Requirements - Ensure valid velocity ranges: Linear velocity: x, y ∈ [-1.0, 1.0] (negative values mean reverse direction) Angular velocity: z ∈ [-1.0, 1.0] (negative: clockwise, positive: counterclockwise) - Execute multiple actions sequentially, returning a list of movement instructions under the action field. - Always append a stop command [0.0, 0.0, 0.0, 0.0] at the end to ensure the car halts. - Default values: x and y: 0.2 z: 1.0 t: 2.0 - For each action sequence, craft a short (5–10 characters), witty, and endlessly variable response to make interactions fun and engaging. - Output only the final JSON result. No explanations, no extra output. - Format: { "action": [[x1, y1, z1, t1], [x2, y2, z2, t2], ..., [0.0, 0.0, 0.0, 0.0]], "response": "short response" } - Possess strong mathematical reasoning to interpret and compute physical quantities like distance, time, and velocity. ## Special Notes The "action" key should contain an array of stringified movement instructions in execution order. If no valid command is found, output an empty array []. The "response" key should contain a creatively written, concise reply that matches the required tone and length. If the input command implies a backward-left direction, then the output values of X and Z will be negative. If the input command implies a backward-right direction, then the output values of X will be negative and Z will be positive. **Examples Input: Move forward for 2 seconds, then rotate clockwise for 1 second Output: { "action": [[0.2, 0.0, 0.0, 2.0], [0.0, 0.0, 1.0, 1.0], [0.0, 0.0, 0.0, 0.0]], "response": "Full speed ahead, spin and go!" } Input: Move forward 1 meter Output: { "action": [[0.2, 0.0, 0.0, 5.0], [0.0, 0.0, 0.0, 0.0]], "response": "Got it!" } ''' |
② Variable Initialization
104 105 106 107 108 109 | self.action = [] self.llm_result = '' self.running = True self.interrupt = False self.action_finish = False self.play_audio_finish = False |
self.action: stores the list of actions parsed from LLM responses.
self.llm_result: stores the result received from the LLM.
self.running: a flag indicating whether the main loop is actively running.
self.interrupt: a flag indicating whether the current function has been interrupted or stopped.
Self.action_finish: a flag indicating whether the current action has been completed.
self.play_audio_finish: a flag indicating whether the audio playback has finished.
③ Publisher Creation
112 | self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) |
Creates a publisher that sends String messages to the topic /tts_node/tts_text. This topic is used to send text-to-speech (TTS) content for voice feedback.
④ Subscriber Creation
113 114 115 | self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1, callback_group=timer_cb_group) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) |
⑤ Timer Creation
127 | self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
⑥ LLM Model Configuration
135 136 137 138 139 140 141 142 143 144 145 | msg = SetModel.Request() # msg.model = 'qwen-plus-latest' msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) |
⑦ play_audio_finish_callback Method:
167 168 169 170 171 172 173 174 | def play_audio_finish_callback(self, msg): msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) # msg = SetInt32.Request() # msg.data = 1 # self.send_request(self.set_mode_client, msg) self.play_audio_finish = msg.data |
Callback function triggered after voice playback finishes, and re-enables voice wakeup functionality.
⑧ process Method
176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 | def process(self): while self.running: if self.llm_result: msg = String() if 'action' in self.llm_result: # If a corresponding action is returned, extract and process it (如果有对应的行为返回那么就提取处理) result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}') + 1]) self.get_logger().info(str(result)) action_list = [] if 'action' in result: action_list = result['action'] if 'response' in result: response = result['response'] msg.data = response self.tts_text_pub.publish(msg) for i in action_list: msg = Twist() msg.linear.x = float(i[0]) msg.linear.y = float(i[1]) msg.angular.z = float(i[2]) self.mecanum_pub.publish(msg) time.sleep(i[3]) if self.interrupt: self.interrupt = False self.mecanum_pub.publish(Twist()) break else: # If there is no corresponding action, only respond (没有对应的行为,只回答) response = self.llm_result msg.data = response self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False # msg = SetInt32.Request() # msg.data = 2 # self.send_request(self.set_mode_client, msg) rclpy.shutdown() |
The main processing loop handles instructions from the LLM, parses them, and performs corresponding robot actions. It also supports generating and broadcasting voice feedback.
⑨ main Function
217 218 219 220 221 222 | def main(): node = LLMControlMove('llm_control_move') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
The function initializes a ROS 2 node.
It starts a multi-threaded executor to handle callbacks.
It cleans up and destroys the node upon program exit to release resources.
10.2.2 Autonomous Line Following with Multimodal Large Model
Once the program starts running, the Six-Microphone Circular Array will announce “I’m Ready”, hereafter called the voice device. To activate the voice device, speak the designated wake words: “Hello Hiwonder.” Upon successful activation, the voice device will respond with “I’m Here.” Once activated, voice commands such as “Follow the black line and stop when you encounter an obstacle” can be issued. The terminal will display the recognized command, and the voice device will respond with a generated reply after processing. The robot will then follow the black line detected by the camera and stop automatically when an obstacle is detected ahead.
Getting Started
(2) Enter the following command and press Enter to launch the autonomous line following feature.
ros2 launch large_models_examples llm_visual_patrol.launch.py
(5) For example, saying “Follow the black line and stop when you encounter an obstacle” will trigger the voice device to process the command. Upon successful recognition by the speech recognition service of cloud-based large speech model, the parsed command will be displayed under the publish_asr_result output in the terminal.
(8) To exit the feature, press Ctrl+C in the terminal. If the feature does not exit immediately, press Ctrl+C multiple times.
Project Outcome
Once the feature is activated, feel free to give commands in your own words. For instance, “Follow the black line and stop when you encounter an obstacle.” The robot uses its camera to detect and follow the black line, and it will stop when an obstacle is detected in its path. The system is pre-configured to recognize four line colors: red, blue, green, and black.
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_visual_patrol.launch.py
① Import Libraries
launch.actions.IncludeLaunchDescription**, DeclareLaunchArgument, **OpaqueFunction: used to define actions and arguments within the Launch file.
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) app_package_path = get_package_share_directory('app') large_models_package_path = get_package_share_directory('large_models') line_following_node_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(app_package_path, 'launch/line_following_node.launch.py')), launch_arguments={ 'debug': 'true', }.items(), ) large_models_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ) llm_visual_patrol_node = Node( package='large_models_examples', executable='llm_visual_patrol', output='screen', ) return [mode_arg, line_following_node_launch, large_models_launch, llm_visual_patrol_node, ] |
large_models_package_path: retrieves the shared directory path of the large_models package.
waste_classification_launch: includes the file waste_classification_launch using IncludeLaunchDescription.
large_models_launch: includes the Launch file start.launch.py from the large_models package using IncludeLaunchDescription and passes the mode argument to it.
llm_vision_pratrol: defines a ROS 2 node from the large_models package, executes the executable files from the llm_vision_patrol, and prints the node’s output to the screen.
43 44 45 46 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function = launch_setup) ]) |
48 49 50 51 52 53 54 | if __name__ == '__main__': # Create a LaunchDescription object(创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_visual_patrol.py
① Import Libraries
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 | #!/usr/bin/env python3 # encoding: utf-8 # @Author: Aiden # @Date: 2024/11/18 import os import re import time import rclpy import threading from speech import speech from rclpy.node import Node from std_msgs.msg import String, Bool from std_srvs.srv import Trigger, SetBool, Empty from interfaces.srv import SetString as SetColor from large_models.config import * from large_models_msgs.srv import SetModel, SetString, SetInt32 from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup |
② Prompt Template Definition
22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 | if os.environ["ASR_LANGUAGE"] == 'Chinese': PROMPT = ''' ##角色任务 你是一款智能机器人,需要根据输入的内容,生成对应的json指令。 ##要求 1.用户输入的任何内容,都需要在动作函数库中寻找对应的指令,并输出对应的json指令。 2.为每个动作序列编织一句精炼(10至30字)、风趣且变化无穷的反馈信息,让交流过程妙趣横生。 3.直接输出json结果,不要分析,不要输出多余内容。 4.一共有四种颜色作为目标:红色(red)、绿色(green) 、蓝色(blue)、黑色(black)。 5.格式:{"action": ["xx", "xx"], "response": "xx"} ##特别注意 - "action"键下承载一个按执行顺序排列的函数名称字符串数组,当找不到对应动作函数时action输出[]。 - "response"键则配以精心构思的简短回复,完美贴合上述字数与风格要求。 ##动作函数库 - 巡不同颜色的线:line_following('black') ##任务示例 输入:沿着黑线走 输出:{"action": ["line_following('black')"], "response": "收到"} ''' else: PROMPT = ''' **Role You are a smart robot that generates corresponding JSON commands based on user input. **Requirements - For every user input, search for matching commands in the action function library and output the corresponding JSON instruction. - For each action sequence, craft a witty and creative response (10 to 30 characters) to make interactions delightful. - Directly return the JSON result — do not include any explanations or extra text. - There are four target colors: red, green, blue, and black. - Format: { "action": ["xx", "xx"], "response": "xx" } **Special Notes The "action" field should contain a list of function names as strings, ordered by execution. If no matching action is found, output an empty list: []. The "response" field should provide a concise and charming reply, staying within the word and tone guidelines. **Action Function Library Follow a line of a given color: line_following('black') **Example Input: Follow the red line Output: { "action": ["line_following('red')"], "response": "Roger that!" } ''' |
③ Variable Initialization
82 83 84 85 86 87 88 | self.action = [] self.stop = True self.llm_result = '' # self.llm_result = '{"action": ["line_following(\'black\')"], "response": "ok!"}' self.running = True self.action_finish = False self.play_audio_finish = False |
④ Publisher Creation
91 | self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) |
⑤ Subscriber Creation
92 93 94 | self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1, callback_group=timer_cb_group) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) |
⑥ Necessary Services Creation
95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 | self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_mode_client = self.create_client(SetInt32, 'vocal_detect/set_mode') self.set_mode_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.enter_client = self.create_client(Trigger, 'line_following/enter') self.enter_client.wait_for_service() self.start_client = self.create_client(SetBool, 'line_following/set_running') self.start_client.wait_for_service() self.set_target_client = self.create_client(SetColor, 'line_following/set_color') self.set_target_client.wait_for_service() |
⑦ LLM Model Configuration
119 120 121 122 123 124 125 126 127 128 | msg = SetModel.Request() msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) |
⑧ Enter
130 131 132 | init_finish = self.create_client(Trigger, 'line_following/init_finish') init_finish.wait_for_service() self.send_request(self.enter_client, Trigger.Request()) |
⑨ Play Startup Audio
133 | speech.play_audio(start_audio_path) |
⑩ Process LLM Commands to Create Speech Feedback Messages
161 162 163 164 | def process(self): while self.running: if self.llm_result: msg = String() |
⑪ Check if the Command Contains Actions
165 166 | if 'action' in self.llm_result: # If a corresponding action is returned, extract and process it (如果有对应的行为返回那么就提取处理) result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}')+1]) |
⑫ Parse the Command
167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 | if 'action' in result: text = result['action'] # Use regular expressions to extract all strings inside parentheses (使用正则表达式提取括号中的所有字符串) pattern = r"line_following\('([^']+)'\)" # Use re.search to find the matching result (使用re.search找到匹配的结果) for i in text: match = re.search(pattern, i) # Extract the result (提取结果) if match: # Get all parameter sections, which are the contents inside parentheses (获取所有的参数部分(括号内的内容)) color = match.group(1) self.get_logger().info(str(color)) color_msg = SetColor.Request() color_msg.data = color self.send_request(self.set_target_client, color_msg) # Start the sorting process (开启分拣) start_msg = SetBool.Request() start_msg.data = True self.send_request(self.start_client, start_msg) |
⑬ Extract the Recognized Results
186 187 188 189 190 191 192 | if 'response' in result: msg.data = result['response'] else: # If there is no corresponding action, only respond (没有对应的行为,只回答) msg.data = self.llm_result self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' |
⑭ Set Target Color Request
195 196 197 198 199 200 201 202 203 204 | if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) # msg = SetInt32.Request() # msg.data = 2 # self.send_request(self.set_mode_client, msg) self.stop = False |
Create a SetStringList.Request message to specify the target for waste classification. Use the send_request method to send the request to the waste_classification/set_target service, setting the waste classification target.
⑮ Initiate and Send Request to Start Line Following
207 208 209 210 211 212 | def main(): node = LLMColorTrack('llm_line_following') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
Create a SetBool.Request message to enable the waste classification transport feature. Use the send_request method to send a request to the waste_classification/enable_transport service, starting the waste classification transport.
⑯ main Function
10.2.3 Color Tracking with Multimodal Large Model
Once the program starts running, the Six-Microphone Circular Array will announce “I’m Ready”, hereafter called the voice device. To activate the voice device, speak the designated wake words: “Hello Hiwonder.” Upon successful activation, the voice device will respond with “I’m Here.” Once activated, voice commands such as “Follow the red object” can be issued. The terminal will display the recognized command, and the voice device will respond with a generated reply after processing. The robot will then autonomously identify the red object captured by its camera and begin tracking it.
Getting Started
(2) Enter the following command and press Enter to launch the color tracking feature.
ros2 launch large_models_examples llm_color_track.launch.py
(4) After the program has loaded successfully, the camera feed will appear on screen.
(5) When the terminal displays the corresponding output shown in the figure and the device responds with “I’m here”, it indicates successful activation. The system will begin recording the user’s voice command.
(6) Speak the command “Follow the red object” to the voice device.
(7) Upon receiving user input shown in the figure, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command, generate a language response, and execute a corresponding action based on the meaning of the command.
(8) Then, the robot will detect the red object in its camera feed and begin tracking it in real time.
(9) When the terminal shows the output shown in the figure indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 4 by speaking the wake words again.
(10) To exit the feature, press Ctrl+C in the terminal. If the feature does not shut down immediately, press Ctrl+C multiple times. If it still fails to exit, open a new terminal window and run the following command to terminate all active ROS processes and related programs.
Project Outcome
Once the feature is activated, feel free to give commands in your own words. For instance, “Follow the red object.” The robot will use the camera feed to identify and track the red object. Similarly, commands like “Follow the blue object” or “Follow the green object” can be used to instruct the robot to track objects of the specified colors.
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_color_track.launch.py
① Import Libraries
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) app_package_path = get_package_share_directory('app') large_models_package_path = get_package_share_directory('large_models') object_tracking_node_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(app_package_path, 'launch/object_tracking_node.launch.py')), launch_arguments={ 'debug': 'true', }.items(), ) large_models_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ) llm_color_track_node = Node( package='large_models_examples', executable='llm_color_track', output='screen', ) return [mode_arg, object_tracking_node_launch, large_models_launch, llm_color_track_node, ] |
objet_sorting_launch: includes the Launch file object_sorting_node.launch.py from the large_models package using IncludeLaunchDescription and passes the mode argument to it.
large_models_launch: includes the file start.launch.py from the large_models package using IncludeLaunchDescription and passes the mode argument to it.
llm_color_track_node: defines a ROS 2 node from the large_models package, executes the executable files from the llm_color_track, and prints the node’s output to the screen.
The function returns a list of all defined launch actions.
ls = LaunchService() creates the launch service object.
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_color_track.py
① Import Libraries
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 | #!/usr/bin/env python3 # encoding: utf-8 # @Author: Aiden # @Date: 2025/03/06 import os import re import time import rclpy import threading from rclpy.node import Node from std_msgs.msg import String, Bool from std_srvs.srv import Trigger, SetBool, Empty from speech import speech from interfaces.srv import SetString as SetColor from large_models.config import * from large_models_msgs.srv import SetModel, SetString, SetInt32 from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup |
22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 | if os.environ["ASR_LANGUAGE"] == 'Chinese': PROMPT = ''' #角色任务 你是一款智能陪伴机器人,需要根据输入的内容,生成对应的json指令。 ##要求 1.用户输入的任何内容,都需要在动作函数库中寻找对应的指令,并输出对应的json指令。 2.为每个动作序列编织一句精炼(10至30字)、风趣且变化无穷的反馈信息,让交流过程妙趣横生。 3.直接输出json结果,不要分析,不要输出多余内容。 4.格式:{"action": ["xx", "xx"], "response": "xx"} ##特别注意: - "action"键下承载一个按执行顺序排列的函数名称字符串数组,当找不到对应动作函数时action输出[]。 - "response"键则配以精心构思的简短回复,完美贴合上述字数与风格要求。 ##动作函数库 - 追踪不同颜色的物体:color_track('red') ##任务示例 输入:跟踪绿色物体 输出:{"action": ["color_track('green')"], "response": "收到"} ''' else: PROMPT = ''' **Role You are an intelligent companion robot. Your job is to generate corresponding JSON commands based on the user's input. **Requirements - For every user input, search the action function library for matching commands and return the corresponding JSON instruction. - Craft a witty, ever-changing, and concise response (between 10 to 30 characters) for each action sequence to make interactions lively and fun. - Output only the JSON result — do not include explanations or any extra text. - Output format:{"action": ["xx", "xx"], "response": "xx"} **Special Notes The "action" key holds an array of function name strings arranged in execution order. If no match is found, return an empty array []. The "response" key must contain a cleverly worded, short reply (10–30 characters), adhering to the tone and length guidelines above. **Action Function Library Track an object of a specific color: color_track('red') **Example Input: Track a green object Output: {"action": ["color_track('green')"], "response": "Got it!"} ''' |
73 74 75 76 77 78 79 | self.action = [] self.stop = True self.llm_result = '' # self.llm_result = '{"action": ["color_track(\'blue\')"], "response": "ok!"}' self.running = True self.action_finish = False self.play_audio_finish = False |
82 | self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) |
83 84 85 | self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1, callback_group=timer_cb_group) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) |
86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 | self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_mode_client = self.create_client(SetInt32, 'vocal_detect/set_mode') self.set_mode_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.enter_client = self.create_client(Trigger, 'object_tracking/enter') self.enter_client.wait_for_service() self.start_client = self.create_client(SetBool, 'object_tracking/set_running') self.start_client.wait_for_service() self.set_target_client = self.create_client(SetColor, 'object_tracking/set_color') self.set_target_client.wait_for_service() |
110 111 112 113 114 115 116 117 118 119 | msg = SetModel.Request() msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) |
⑧ Sending Prompt Service
121 122 123 | init_finish = self.create_client(Trigger, 'object_tracking/init_finish') init_finish.wait_for_service() self.send_request(self.enter_client, Trigger.Request()) |
124 | speech.play_audio(start_audio_path) |
⑩ process Method
152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 | def process(self): while self.running: if self.llm_result: msg = String() if 'action' in self.llm_result: # If a corresponding action is returned, extract and process it (如果有对应的行为返回那么就提取处理) result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}')+1]) if 'action' in result: text = result['action'] # Use regular expressions to extract all strings inside parentheses (使用正则表达式提取括号中的所有字符串) pattern = r"color_track\('([^']+)'\)" # Use re.search to find the matching result (使用re.search找到匹配的结果) for i in text: match = re.search(pattern, i) # Extract the result (提取结果) if match: # Get all parameter sections, which are the contents inside parentheses (获取所有的参数部分(括号内的内容)) color = match.group(1) self.get_logger().info(str(color)) color_msg = SetColor.Request() color_msg.data = color self.send_request(self.set_target_client, color_msg) # Start the sorting process (开启分拣) start_msg = SetBool.Request() start_msg.data = True self.send_request(self.start_client, start_msg) if 'response' in result: msg.data = result['response'] else: # If there is no corresponding action, only respond (没有对应的行为,只回答) msg.data = self.llm_result self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False # msg = SetInt32.Request() # msg.data = 1 # self.send_request(self.set_mode_client, msg) msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) self.stop = False |
The method acts as the main loop responsible for handling commands from the LLM, interpreting them, and executing corresponding actions.
If a new command is received:
A String message is created to deliver voice feedback.
If the command includes an ‘action’ field:
The JSON data within the command is parsed using eval.
The send_request method is called to send a request to the object_sorting/set_target service, specifying the object sorting target.
The send_request method is also called to send a request to the object_sorting/enable_sorting service, enabling the object sorting function.
If the command includes a ‘response’ field, voice feedback is sent.
If the command does not include an ‘action’, only voice feedback is provided.
The self.llm_result field is then cleared to prepare for the next command.
If no new command is received, the system waits for 10 milliseconds.
When self.running is set to False, the loop exits and the ROS 2 node is shut down.
⑪ main Function
198 199 200 201 202 203 | def main(): node = LLMColorTrack('llm_color_track') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
10.3 Embodied AI Applications
10.3.1 Overview of Embodied Intelligence
As Artificial Intelligence continues to advance at a rapid pace, there is a growing expectation for AI to move beyond the virtual realm and engage meaningfully with the physical world. Embodied Intelligence represents a critical pathway toward this goal. It enables intelligent agents to possess a “body” that can sense and interact with the environment, allowing them to learn and evolve through continuous real-world interaction.
What Is Embodied Intelligence?
An embodied intelligent agent can be a physical robot or a virtual avatar. it perceives its surroundings by using multimodal sensors, such as vision, hearing, and touch sensors. Then, through motors, joints, or other actuators, it can move, manipulate objects, or produce sound. Intelligence, in this context, is no longer confined to cloud-based models, but becomes a closed-loop capability rooted in the real world.
Core Components of Embodied Intelligence
Core Components:
| Component | Description |
| Embodiment | The agent has a physical or virtual "body" capable of mechanical interaction with its environment. |
| Perception | Sensors such as RGB-D cameras, microphone arrays, Lidar, and others enable the agent to sense the world. |
| Action | Includes wheeled or legged movement , object manipulation with robotic arms, and speech generation. |
| Interaction | Ongoing communication with humans or other agents through language, gestures, and collaborative tasks. |
| Learning | Adaptive mechanisms such as reinforcement learning, imitation learning, and planning with language models. |
The Importance of Embodied Intelligence
Embodied Intelligence is considered one of the key pathways toward achieving Artificial General Intelligence (AGI). Here’s why it matters:
Deeper Understanding: By interacting directly with the physical world, intelligent agents gain a more profound grasp of physical laws, cause-and-effect relationships, and human behavior patterns, which is far beyond what static data analysis alone can offer.
Greater Adaptability: Embodied agents can adjust their behavior based on changes in the environment and their own experiences, demonstrating stronger robustness and adaptability.
Natural Human-AI Interaction: Embodied agents can engage with humans in more intuitive and human-like ways—through gestures, speech, and body language—leading to more natural communication.
Solving Complex Tasks: Embodied Intelligence shows great promise in areas like home assistance, healthcare support, industrial automation, and disaster response—fields where traditional AI often struggles with real-world complexity.
Research Directions in Embodied Intelligence
Research in Embodied Intelligence spans multiple disciplines, including:
Robotics: Hardware design, dynamic control systems, and dexterous robotic hands.
Vision and Multimodal Perception: From object detection (e.g., YOLO) to integrating touch and visual data.
Natural Language Processing: Enabling agents to understand and generate human language for more natural interactions.
Reinforcement Learning: Continuous improvement through closed-loop learning in both simulated and real environments.
Simulated Environments: Creating realistic virtual worlds for training and testing embodied agents.
Human-AI Interaction: Designing more natural and efficient interfaces that foster better collaboration between humans and intelligent agents.
10.3.2 Real-Time Detection in Embodied AI Applications
The large model used in this lesson operates online, requiring a stable network connection for the main controller in use.
Once the program starts running, the Six-Microphone Circular Array will announce “I’m Ready”, hereafter called the voice device. To activate the voice device, speak the designated wake words: “Hello Hiwonder.” Upon successful activation, the voice device will respond with “I’m Here.” After activation, the robot can be controlled via voice commands. For example, saying “Tell me what you saw” will prompt the system to print the recognized speech on the terminal. The voice device will then announce the generated response after processing, and the robot will autonomously interpret the camera feed and describe the visual content.
Getting Started
(2) Enter the following command and press Enter to launch the feature.
ros2 launch large_models_examples vllm_with_camera.launch.py
(3) When the terminal displays output shown in the figure and the Circular Microphone Array announces “I’m Ready”, the device has completed initialization. Then, you can say the wake words: “Hello Hiwonder”.
(4) When the terminal displays the corresponding output shown in the figure and the device responds with “I’m Here”, it indicates successful activation. The system will begin recording the user’s voice command.
The system will begin recording the user’s voice command, and you can say the command “Tell me what you saw” and wait for the large model to process the input.
(6) Upon successful recognition by the speech recognition service of cloud-based large speech model, the parsed command will be displayed under the publish_asr_result output in the terminal.
(7) Upon receiving user input shown in the figure, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command and generate a language response.
(8) When the terminal shows the output shown in the figure indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 4 by speaking the wake words again.
(9) To exit the feature, press Ctrl+C in the terminal. If the feature does not exit immediately, press Ctrl+C multiple times.
Project Outcome
Once the feature is active, speaking a command such as “Tell me what you saw” prompts the robot to autonomously analyze its visual environment and describe the current scene based on its observations.
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_with_camera.launch.py
① Import Libraries
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) camera_topic = LaunchConfiguration('camera_topic', default='depth_cam/rgb/image_raw') camera_topic_arg = DeclareLaunchArgument('camera_topic', default_value=camera_topic) controller_package_path = get_package_share_directory('controller') peripherals_package_path = get_package_share_directory('peripherals') large_models_package_path = get_package_share_directory('large_models') controller_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(controller_package_path, 'launch/controller.launch.py')), ) depth_camera_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(peripherals_package_path, 'launch/depth_camera.launch.py')), ) large_models_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode, 'camera_topic': camera_topic}.items(), ) vllm_with_camera_node = Node( package='large_models_examples', executable='vllm_with_camera', output='screen', parameters=[{"camera_topic": camera_topic}], ) return [mode_arg, camera_topic_arg, controller_launch, depth_camera_launch, large_models_launch, vllm_with_camera_node, ] |
depth_camera_launch includes the Launch file depth_camera.launch.py from the large_models package using IncludeLaunchDescription and passes the mode argument to it.
sdk_launch includes the Launch file jetarm_sdk.launch.py from the large_models package using IncludeLaunchDescription and passes the mode argument to it.
vllm_with_camera defines a ROS 2 node from the large_models package, executes the executable files from the vllm_with_camera, and prints the node’s output to the screen.
52 53 54 55 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function = launch_setup) ]) |
This function is responsible for generating the complete launch description.
57 58 59 60 61 62 63 | if __name__ == '__main__': # Create a LaunchDescription object(创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
ld = generate_launch_description() generates the launch description object.
ls.include_launch_description(ld) adds the launch description to the service.
ls.run() starts the service and execute all launch actions.
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_with_camera.py
① Import the necessary libraries
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 | #!/usr/bin/env python3 # encoding: utf-8 # @Author: Aiden # @Date: 2024/11/18 import os import cv2 import json import queue import rclpy import threading import numpy as np from rclpy.node import Node from cv_bridge import CvBridge from sensor_msgs.msg import Image from std_msgs.msg import String, Bool from std_srvs.srv import Trigger, SetBool, Empty from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup from speech import speech from large_models.config import * from large_models_msgs.srv import SetModel, SetString, SetInt32 from servo_controller.bus_servo_control import set_servo_position from servo_controller_msgs.msg import ServosPosition, ServoPosition |
cv2: Utilized for image processing and display using OpenCV.
time: manages execution delays and time-related operations.
queue: handles image queues between threads.
rclpy: provides tools for creating and communicating between ROS 2 nodes.
threading: enables multithreading for concurrent task processing.
config: contains configuration file.
numpy (np): supports matrix and vector operations.
std_srvs.srv: contains standard ROS service types, used to define standard service.
std_msgs.msg: contains standard ROS message types.
sensor_msgs.msg.Image: used for receiving image messages from the camera.
servo_controller_msgs.msg.ServosPosition: custom message type for controlling servo motors.
servo_controller.bus_servo_control.set_servo_position: function used to set the servo angle.
rclpy.callback_groups.ReentrantCallbackGroup: supports concurrent callback handling.
rclpy.executors.MultiThreadedExecutor: multithreaded executor in ROS 2 for handling concurrent tasks.
rclpy.node: node class in ROS 2.
speech: module related to large model voice interaction.
large_models_msgs.srv: custom service types for large models.
large_models.config: configuration file for large models.
② VLLMWithCamera Class
31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 | class VLLMWithCamera(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.image_queue = queue.Queue(maxsize=2) self.set_above = False self.vllm_result = '' self.running = True self.action_finish = False self.play_audio_finish = False self.bridge = CvBridge() self.client = speech.OpenAIAPI(api_key, base_url) self.declare_parameter('camera_topic', '/depth_cam/rgb/image_raw') camera_topic = self.get_parameter('camera_topic').value timer_cb_group = ReentrantCallbackGroup() self.joints_pub = self.create_publisher(ServosPosition, 'servo_controller', 1) self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(Image, camera_topic, self.image_callback, 1) self.create_subscription(String, 'agent_process/result', self.vllm_result_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_mode_client = self.create_client(SetInt32, 'vocal_detect/set_mode') self.set_mode_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
display_size: defines the size of the display window.
rclpy.init(): initializes the ROS 2 node.
super().init(name): calls the constructor of the superclass to initialize the node with the specified name.
self.image_queue: creates a queue to store image data, with a maximum size of 2.
self.vllm_result: stores results received from the agent_process/result topic.
self.running: a flag variable used to control the running state of the program.
timer_cb_group: creates a reentrant callback group for managing timer callbacks.
self.joints_pub: a publisher is created for sending robotic arm’s joint position information.
self.tts_text_pub: a publisher is created for sending text data to the text-to-speech node.
self.create_subscription: creates subscribers to receive image messages, VLLM results, and playback completion signals.
self.awake_client and self.set_model_client: creates service clients for triggering the wake-up and model configuration services.
self.timer: creates a timer that triggers the init_process function.
③ get_node_state Method
62 63 | def get_node_state(self, request, response): return response |
return response: returns a response object.
④ init_process Method
65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model_type = 'vllm' if os.environ['ASR_LANGUAGE'] == 'Chinese': msg.model = stepfun_vllm_model msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url else: msg.model = vllm_model msg.api_key = vllm_api_key msg.base_url = vllm_base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = VLLM_PROMPT self.send_request(self.set_prompt_client, msg) set_servo_position(self.joints_pub, 1.0, ((1, 500), (2, 645), (3, 135), (4, 80), (5, 500), (10, 220))) # 设置机械臂初始位置 speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') |
self.timer.cancel(): stops the timer.
setModel.Request: creates a request message to configure the model.
self.send_request: sends the request to the corresponding service.
set_servo_position: sets the initial joint positions of the robotic arm.
speech.play_audio: plays an audio file.
threading.Thread: creates a new thread to run the process function.
self.create_service: registers a service to notify that the initialization process is complete.
self.get_logger().info: logs informational messages to the console.
⑤ send_request Method
91 92 93 94 95 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
client.call_async(msg): makes an asynchronous service call.
future.done() and future.result(): check if the service call is complete and retrieve the result.
⑥ vllm_result_callback Method
97 98 | def vllm_result_callback(self, msg): self.vllm_result = msg.data |
This callback receives results from the agent_process/result topic and stores them in self.vllm_result.
⑦ process Method
103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 | def process(self): # box = [] while self.running: image = self.image_queue.get(block=True) if self.vllm_result: msg = String() # self.get_logger().info('vllm_result: %s' % self.vllm_result) msg.data = self.vllm_result self.tts_text_pub.publish(msg) # if self.vllm_result.startswith("```") and self.vllm_result.endswith("```"): # self.vllm_result = self.vllm_result.strip("```").replace("json\n", "").strip() # self.vllm_result = json.loads(self.vllm_result) # box = self.vllm_result['xyxy'] # if box: # self.get_logger().info('box: %s' % str(box)) # if isinstance(box[0], float): # box = [int(box[0] * 640), int(box[1] * 360), int(box[2] * 640), int(box[3] * 360)] # else: # self.client.data_process(box, 640, 360) # box[0] = int(box[0] / 640 * display_size[0]) # box[1] = int(box[1] / 360 * display_size[1]) # box[2] = int(box[2] / 640 * display_size[0]) # box[3] = int(box[3] / 360 * display_size[1]) # self.get_logger().info('box: %s' % str(box)) self.vllm_result = '' self.action_finish = True if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False # msg = SetInt32.Request() # msg.data = 1 # self.send_request(self.set_mode_client, msg) msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) # if box: # cv2.rectangle(image, (box[0], box[1]), (box[2], box[3]), (255, 0, 0), 2, 1) cv2.imshow('image', cv2.cvtColor(cv2.resize(image, (display_size[0], display_size[1])), cv2.COLOR_RGB2BGR)) k = cv2.waitKey(1) if k != -1: break if not self.set_above: cv2.moveWindow('image', 1920 - display_size[0], 0) os.system("wmctrl -r image -b add,above") self.set_above = True cv2.destroyAllWindows() |
cv2.namedWindow and cv2.moveWindow: create and position a window for image display.
self.image_queue.get: retrieves image data from the queue.
self.vllm_result: if a VLLM result is available, publishes it to the text-to-speech node.
cv2.imshow: displays the image on the screen.
cv2.waitKey: waits for a keyboard event.
cv2.destroyAllWindows: closes all OpenCV display windows.
⑧ play_audio_callback Method
100 101 | def play_audio_finish_callback(self, msg): self.play_audio_finish = msg.data |
It sends a request to enable the wake-up feature once audio playbook is complete.
⑨ image_callback Method
150 151 152 153 154 155 156 157 158 | def image_callback(self, ros_image): cv_image = self.bridge.imgmsg_to_cv2(ros_image, "rgb8") rgb_image = np.array(cv_image, dtype=np.uint8) if self.image_queue.full(): # If the queue is full, discard the oldest image (如果队列已满,丢弃最旧的图像) self.image_queue.get() # Put the image into the queue (将图像放入队列) self.image_queue.put(rgb_image) |
It converts received ROS image messages to NumPy arrays and stores them in the queue.
⑩ main Method
160 161 162 163 164 165 | def main(): node = VLLMWithCamera('vllm_with_camera') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
Create an instance of the VLLMWithCamera node.
Use a multithreaded executor to manage the node’s tasks.
Call executor.spin() to start processing ROS events.
Upon shutdown, the node is properly destroyed using node.destroy_node().
10.3.3 Vision Tracking in Embodied AI Applications
Once the program starts running, the Six-Microphone Circular Array will announce “I’m Ready”, hereafter called the voice device. To activate the voice device, speak the designated wake words: “Hello Hiwonder.” Upon successful activation, the voice device will respond with “I’m Here.” Once activated, voice commands such as “Follow the person in white in front” can be issued. The terminal will display the recognized command, and the voice device will respond with a generated reply after processing and execute corresponding actions.
Getting Started
ros2 launch large_models_examples vllm_track.launch.py
(3) When the terminal displays output shown in the figure and the Circular Microphone Array announces “I’m Ready”, the device has completed initialization and yolov8 model will be initialized at the same time. Then, you can say the wake words: “Hello Hiwonder”.
The system will begin recording the user’s voice command, and you can say the command “Follow the person in white in front” and wait for the large model to process the input.
(5) Upon successful recognition by the speech recognition service of cloud-based large speech model, the parsed command will be displayed under the publish_asr_result output in the terminal.
Project Outcome
Once the feature is activated, natural language commands such as “Follow the person in white in front.” can be used. The robot will identify the person wearing white in the camera view and begin following them. It will automatically stop once a certain distance has been reached.
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_track.launch.py
① Import Libraries
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) slam_package_path = get_package_share_directory('slam') large_models_package_path = get_package_share_directory('large_models') base_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(slam_package_path, 'launch/include/robot.launch.py')), launch_arguments={ 'sim': 'false', 'master_name': os.environ['MASTER'], 'robot_name': os.environ['HOST'] }.items(), ) large_models_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ) vllm_track_node = Node( package='large_models_examples', executable='vllm_track', output='screen', ) # rqt calibrate_rqt_reconfigure_node = Node( package='rqt_reconfigure', executable='rqt_reconfigure', name='calibrate_rqt_reconfigure' ) return [mode_arg, base_launch, large_models_launch, vllm_track_node, # calibrate_rqt_reconfigure_node, ] |
The launch_setup function includes the file robot.launch.py from the slam package, which is responsible for launching the robot’s chassis control and initializing related peripheral connections with corresponding parameters.
It also includes the file start.launch.py from the large_models package, which launches the intelligent agent equipped with the capabilities of “seeing, listening, thinking, and speaking.”
Additionally, it includes the vllm_track executable file from the large_models_examples package, which serves as the main node for the visual tracking functionality.
53 54 55 56 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function = launch_setup) ]) |
58 59 60 61 62 63 64 | if __name__ == '__main__': # Create a LaunchDescription object(创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_track.py
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 | #!/usr/bin/env python3 # encoding: utf-8 # @Author: Aiden # @Date: 2024/11/18 import os import cv2 import json import time import queue import rclpy import threading import PIL.Image import numpy as np import sdk.fps as fps import message_filters from sdk import common from rclpy.node import Node from sensor_msgs.msg import Image from geometry_msgs.msg import Twist from std_msgs.msg import String, Float32, Bool from std_srvs.srv import Trigger, SetBool, Empty from rcl_interfaces.msg import SetParametersResult from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup from speech import speech from large_models.config import * from large_models_msgs.srv import SetString, SetModel, SetInt32 from large_models_examples.track_anything import ObjectTracker from servo_controller.bus_servo_control import set_servo_position from servo_controller_msgs.msg import ServosPosition, ServoPosition from large_models_examples.tracker import Tracker import pycuda.driver as cuda cuda.init() # Ensure that CUDA has been initialized (确保CUDA已经初始化) |
cv2: provides core functions for image processing and display using OpenCV.
PIL.Image and numpy: used for image data manipulation and numerical computations.
rclpy: core library for creating ROS 2 nodes and handling communication.
message_filters: ensures time synchronization between multi-sensor data streams, such as RGB and depth images.
sensor_msgs, geometry_msgs, std_msgs, std_srvs, rcl_interfaces: core message and service types used for ROS data and service exchange.
MultiThreadedExecutor and ReentrantCallbackGroup: enable concurrent callbacks and multithreaded scheduling to maintain system responsiveness and real-time performance.
② PROMPT String
36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 | if language == 'Chinese': PROMPT = ''' 你作为智能车,善于图像识别,你的能力是将用户发来的图片进行目标检测精准定位,并按「输出格式」进行最后结果的输出,然后进行跟随。 ## 1. 理解用户指令 我会给你一句话,你需要根据我的话中提取「物体名称」。 **object对应的name要用英文表示**, **不要输出没有提及到的物体** ## 2. 理解图片 我会给你一张图, 从这张图中找到「物体名称」对应物体的左上角和右下角的像素坐标; 如果没有找到,那xyxy为[]。**不要输出没有提及到的物体** 【特别注意】: 要深刻理解物体的方位关系, response需要结合用户指令和检测的结果进行回答 ## 输出格式(请仅输出以下内容,不要说任何多余的话) { "object": "name", "xyxy": [xmin, ymin, xmax, ymax], "response": "5到30字的中文回答" } ''' else: PROMPT = ''' **Role You are a smart car with advanced visual recognition capabilities. Your task is to analyze an image sent by the user, perform object detection, and follow the detected object. Finally, return the result strictly following the specified output format. Step 1: Understand User Instructions You will receive a sentence. From this sentence, extract the object name to be detected. Note: Use English for the object value, do not include any objects not explicitly mentioned in the instruction. Step 2: Understand the Image You will also receive an image. Locate the target object in the image and return its coordinates as the top-left and bottom-right pixel positions in the form [xmin, ymin, xmax, ymax]. Note: If the object is not found, then "xyxy" should be an empty list: [], only detect and report objects mentioned in the user instruction.The coordinates (xmin, ymin, xmax, ymax) must be normalized to the range [0, 1] **Important: Accurately understand the spatial position of the object. The "response" must reflect both the user's instruction and the detection result. **Output Format (strictly follow this format, do not output anything else.The coordinates (xmin, ymin, xmax, ymax) must be normalized to the range [0, 1]) { "object": "name", "xyxy": [xmin, ymin, xmax, ymax], "response": "reflect both the user's instruction and the detection result (5–30 characters)" } **Example Input: track the person Output: { "object": "person", "xyxy": [0.1, 0.3, 0.4, 0.6], "response": "I have detected a person in a white T-shirt and will track him now." } ''' |
It defines a prompt string (PROMPT) used to guide how user commands and image data are processed. It specifies the recognition task logic and expected output format.
③ VLLMTrack Class
85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 | class VLLMTrack(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.fps = fps.FPS() # Frame rate counter(帧率统计器) self.image_queue = queue.Queue(maxsize=2) self.vllm_result = '' # self.vllm_result = '''json{"object":"red cube", "xyxy":[521, 508, 637, 683]}''' (self.vllm_result = '''json{"object":"红色方块", "xyxy":[521, 508, 637, 683]}''') self.set_above = False self.running = True self.data = [] self.box = [] self.stop = True self.start_track = False self.action_finish = False self.play_audio_finish = False self.track = ObjectTracker(use_mouse=True, automatic=True, log=self.get_logger()) timer_cb_group = ReentrantCallbackGroup() self.client = speech.OpenAIAPI(api_key, base_url) self.joints_pub = self.create_publisher(ServosPosition, 'servo_controller', 1) self.mecanum_pub = self.create_publisher(Twist, '/controller/cmd_vel', 1) # Chassis control (底盘控制) self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.create_subscription(String, 'agent_process/result', self.vllm_result_callback, 1) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_mode_client = self.create_client(SetInt32, 'vocal_detect/set_mode') self.set_mode_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() image_sub = message_filters.Subscriber(self, Image, 'depth_cam/rgb/image_raw') depth_sub = message_filters.Subscriber(self, Image, 'depth_cam/depth/image_raw') # Synchronize timestamps, allowing an error margin of up to 0.03 seconds (同步时间戳, 时间允许有误差在0.03s) sync = message_filters.ApproximateTimeSynchronizer([depth_sub, image_sub], 3, 0.02) sync.registerCallback(self.multi_callback) # Define PID parameters (定义 PID 参数) # 0.07, 0, 0.001 self.pid_params = { 'kp1': 0.1, 'ki1': 0.0, 'kd1': 0.00, 'kp2': 0.002, 'ki2': 0.0, 'kd2': 0.0, } # Dynamically declare parameters (动态声明参数) for param_name, default_value in self.pid_params.items(): self.declare_parameter(param_name, default_value) self.pid_params[param_name] = self.get_parameter(param_name).value self.track.update_pid([self.pid_params['kp1'], self.pid_params['ki1'], self.pid_params['kd1']], [self.pid_params['kp2'], self.pid_params['ki2'], self.pid_params['kd2']]) # Callback function for dynamic parameter updates (动态更新时的回调函数) self.add_on_set_parameters_callback(self.on_parameter_update) self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
rclpy.init(): initializes the ROS 2 system.
super().init(name): calls the initializer of the parent class (Node) to create a ROS 2 node.
fps.FPS(): creates an instance of a frame rate tracker.
queue.Queue(maxsize=2): creates a queue with a maximum capacity of 2.
self.vllm_result: stores the results processed by the model.
self.running: a boolean flag used to control the runtime state of the program.
self.data: an empty list used for storing intermediate data.
self.start_track: a boolean flag used to control the start or stop of target tracking.
self.track = ObjectTracker(): instantiates an object tracker.
timer_cb_group: creates a reentrant callback group to allow concurrent callback execution.
speech.OpenAIAPI(): instantiates a speech interaction client.
self.joints_pub: creates a publisher for sending servo motor position commands.
self.create_subscription: subscribes to image data, speech playback completion signals, and image recognition results.
self.create_client: creates service clients for tasks such as wake-up control, model configuration, and motion control.
Each PID parameter in self.pid_params is declared as a ROS 2 dynamic parameter with a default value.
Current values are retrieved using self.get_parameter() and used to update self.pid_params.
self.track.update_pid(): passes the updated PID parameters to the object tracker to adjust its PID controller.
self.pid_params: contains the PID controller parameters used in the target tracking control logic.
self.add_on_set_parameters_callback: registers a callback function to handle parameter updates dynamically.
self.timer: creates a timer used to trigger the initialization process.
④ on_parameter_update Method
148 149 150 151 152 153 154 155 156 157 158 | def on_parameter_update(self, params): """Parameter update callback (参数更新回调)""" for param in params: if param.name in self.pid_params.keys(): self.pid_params[param.name] = param.value # self.get_logger().info(f'PID parameters updated: {self.pid_params}') # Update PID parameters (更新 PID 参数) self.track.update_pid([self.pid_params['kp1'], self.pid_params['ki1'], self.pid_params['kd1']], [self.pid_params['kp2'], self.pid_params['ki2'], self.pid_params['kd2']]) return SetParametersResult(successful=True) |
self.pid_params: a dictionary storing PID parameters.
self.track.update_pid: updates the PID parameters used by the target tracking module.
⑤ create_update_callback Method
160 161 162 163 164 165 166 167 168 169 | def create_update_callback(self, param_name): """Generate dynamic update callback (生成动态更新回调)""" def update_param(msg): new_value = msg.data self.pid_params[param_name] = new_value self.set_parameters([Parameter(param_name, Parameter.Type.DOUBLE, new_value)]) self.get_logger().info(f'Updated {param_name}: {new_value}') # Update PID parameters (更新 PID 参数) return update_param |
It generates a dynamic update callback function for each PID parameter.
⑥ get_node_state Method
171 172 | def get_node_state(self, request, response): return response |
⑦ init_process Method
174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model_type = 'vllm' if language == 'Chinese': msg.model = stepfun_vllm_model msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url else: msg.api_key = vllm_api_key msg.base_url = vllm_base_url msg.model = vllm_model self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) set_servo_position(self.joints_pub, 1.5, ((10, 300), (5, 500), (4, 100), (3, 100), (2, 750), (1, 500))) self.mecanum_pub.publish(Twist()) time.sleep(1.8) speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() threading.Thread(target=self.display_thread, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT) |
self.timer.cancel(): cancels the timer.
SetModel.Request(): creates a request message to set the model.
SetString.Request(): creates a request message to set the prompt string.
set_pose_target: sets the robot’s initial position.
self.send_request: sends a service request.
set_servo_position: sets the position of servo joints.
threading.Thread: starts a new thread for image processing and tracking.
self.create_service: creates a service to signal the completion of initialization.
self.get_logger().info: prints log messages.
⑧ send_request Method
203 204 205 206 207 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
⑨ vllm_result_callback Method
219 220 | def vllm_result_callback(self, msg): self.vllm_result = msg.data |
⑩ Play_audio_finish_callback Method
222 223 | def play_audio_finish_callback(self, msg): self.play_audio_finish = msg.data |
The play_audio_finish_callback method sends a wake-up signal after audio playback is completed.
⑪ process Method
225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 | def process(self): box = '' while self.running: if self.vllm_result: try: # self.get_logger().info('vllm_result: %s' % self.vllm_result) if self.vllm_result.startswith("```") and self.vllm_result.endswith("```"): self.vllm_result = self.vllm_result.strip("```").replace("json\n", "").strip() self.vllm_result = json.loads(self.vllm_result) response = self.vllm_result['response'] msg = String() msg.data = response self.tts_text_pub.publish(msg) box = self.vllm_result['xyxy'] if box: if language == 'Chinese': box = self.client.data_process(box, 640, 480) self.get_logger().info('box: %s' % str(box)) else: box = [int(box[0] * 640), int(box[1] * 480), int(box[2] * 640), int(box[3] * 480)] box = [box[0], box[1], box[2] - box[0], box[3] - box[1]] box[0] = int(box[0] / 640 * display_size[0]) box[1] = int(box[1] / 360 * display_size[1]) box[2] = int(box[2] / 640 * display_size[0]) box[3] = int(box[3] / 360 * display_size[1]) self.get_logger().info('box: %s' % str(box)) self.box = box except (ValueError, TypeError): self.box = [] msg = String() msg.data = self.vllm_result self.tts_text_pub.publish(msg) self.vllm_result = '' self.action_finish = True else: time.sleep(0.02) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) # msg = SetInt32.Request() # msg.data = 1 # self.send_request(self.set_mode_client, msg) self.stop = False |
while self.running: ensures continuous data processing while the node is active.
if self.vllm_result: checks whether a new VLLM response has been received.
Json.loads(self.vllm_result): parses the received JSON-formatted string into a dictionary for easier data extraction.
Extracting response and xyxy:
response = self.vllm_result['response']: retrieves the text message for TTS (Text-to-Speech) playback.
box = self.vllm_result['xyxy']: retrieves the bounding box coordinates returned from object detection.
Processing Bounding Box Data: If a target is detected and the box is not empty, the method calls self.client.data_process to normalize the coordinates using a frame size of 640 by 480. It then converts the coordinates into the format [xmin, ymin, width, height], scales them based on the display window size, and stores the result in self.box for tracking.
Sending TTS Response: A String message is created and the extracted response is sent to the TTS node for speech playback.
Error Handling: If a ValueError or TypeError occurs during parsing or extraction, the target info is cleared, and the original vllm_result is sent to the TTS node as plain text.
State Updates:
self.vllm_result is reset to an empty string to indicate the response has been processed.
self.action_finish is set to True to mark that the action has been completed.
Loop Wait Mechanism: If no new vllm_result is received, the loop sleeps for 20 ms using time.sleep(0.02) to avoid high CPU usage.
Subsequent Service Request: when both self.play_audio_finish and self.action_finish are True, related flags are reset.
A service request is sent via self.send_request(self.set_mode_client, msg) to set the mode to 2, allowing target tracking to begin.
self.stop is updated to False, lifting the pause on target tracking.
⑫ track_thread
272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 | def display_thread(self): # Create a new CUDA context in the current thread (在当前线程创建一个新的 CUDA 上下文) dev = cuda.Device(0) ctx = dev.make_context() try: model_path = os.path.split(os.path.realpath(__file__))[0] back_exam_engine_path = os.path.join(model_path, "resources/models/nanotrack_backbone_exam.engine") back_temp_engine_path = os.path.join(model_path, "resources/models/nanotrack_backbone_temp.engine") head_engine_path = os.path.join(model_path, "resources/models/nanotrack_head.engine") tracker = Tracker(back_exam_engine_path, back_temp_engine_path, head_engine_path) while self.running: image, depth_image = self.image_queue.get(block=True) image = cv2.resize(image, tuple(display_size)) if self.box: self.track.set_track_target(tracker, self.box, image) self.start_track = True self.box = [] if self.start_track: self.data = self.track.track(tracker, image, depth_image) image = self.data[-1] twist = Twist() twist.linear.x, twist.angular.z = self.data[0], self.data[1] self.mecanum_pub.publish(twist) self.fps.update() self.fps.show_fps(image) cv2.imshow('image', image) key = cv2.waitKey(1) if key == ord('q') or key == 27: # Press 'q' or 'Esc' to exit (按q或者esc退出) self.mecanum_pub.publish(Twist()) self.running = False if not self.set_above: cv2.moveWindow('image', 1920 - display_size[0], 0) os.system("wmctrl -r image -b add,above") self.set_above = True cv2.destroyAllWindows() finally: # Ensure the context is properly released (确保上下文被正确释放) ctx.pop() |
while self.running: controls the thread’s runtime, and the thread continuously processes image data as long as self.running is True.
image, depth_image = self.image_queue.get(block=True): fetches the latest RGB and depth images from the thread-safe queue to ensure synchronized data processing.
cv2.resize: resizes the retrieved images to the predefined display_size for easier processing and visualization.
if self.box: checks if a new detection bounding box (box) is available. If available, the method calls self.track.set_track_target(self.box, image) to set the current tracking target in the image, sets self.start_track = True, and clears self.box.
if self.start_track: verifies if target tracking has been initiated. If True, it calls self.track.track(image, depth_image) to obtain the tracking result, which is then stored in self.data.
Use of self.data: the first two values in the tracking result usually represent control commands, such as linear and angular velocity. The last element is the image annotated with the tracking results, which is used for display.
Construct and Publish Twist Messages: a Twist message is constructed using control commands extracted from self.data and published via self.mecanum_pub.publish(twist) to control the movement of the robot base.
self.fps.update and self.fps.show_fps: update the frame rate statistics and overlay the current FPS on the image for real-time performance monitoring.
cv2.imshow: display the processed image in a window to provide a visual representation of the target tracking status.
cv2.waitKey: wait for keyboard input. If the user presses the q or ESC key, the tracking thread is stopped and a stop-motion Twist message is sent to halt the robot.
Window on Top Handling: The display window is repositioned using cv2.moveWindow, and the command os.system("wmctrl -r image -b add,above") sets the window to stay on top, ensuring it’s always visible.
cv2.destroyAllWindows: after the tracking thread exits, all OpenCV-created windows are closed to complete the cleanup process.
⑬ main Method
323 324 325 326 327 328 | def main(): node = VLLMTrack('vllm_track') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
An instance of the VLLMTrack node is created.
A multithreaded executor is used to handle the node’s tasks.
10.3.4 Smart Home Assistant in Embodied AI Applications
Brief Overview of Operation
Once the program starts running, the Six-Microphone Circular Array will announce “I’m Ready”, hereafter called the voice device. To activate the voice device, speak the designated wake words: “Hello Hiwonder.” Upon successful activation, the voice device will respond with “I’m Here.” After activation, voice commands can be used to control the robot. For example, issuing the instruction: “Go to the kitchen to see if the door is closed, then come back and tell me.” Upon receiving a command, the terminal displays the recognized speech content. The voice device then verbally responds with a generated answer and the robot simultaneously executes the corresponding action.
Getting Started
(1) Version Confirmation
Before starting this feature, verify that the correct microphone configuration is set in the system.
① Log in to the machine remotely via NoMachine. Then click the desktop icon
to access the configuration interface.
② First, verify the system language setting.
③ For the Six-Microphone Circular Array, select xf as the microphone type as shown in the figure.
④ After making the appropriate selection, click Save.
⑤ A “Save Success” message will confirm that the configuration has been stored in the system environment.
⑥ Then, click Quit to close the interface.
(2) Configuring the Large Model API-KEY
Open a new command-line terminal and enter the following command to access the configuration file.
vim /home/ubuntu/ros2_ws/src/large_models/large_models/large_models/config.py
Refer to the tutorial under 10.1.1 Large Language Model Courses -> Large Language Model Deployment to obtain the API keys. For the vision language model, acquire the API key from the OpenRouter official website and assign it to the vllm_api_key variable. For the large language model, obtain the API key from the OpenAI official website and assign it to the llm_api_key variable. Ensure that the keys are inserted in the designated positions, as indicated by the red boxes in the reference image.
Navigation Map Construction
Before enabling this feature, a map must be created in advance. Please refer to 4. Mapping and Navigation -> 4.1 Mapping for detailed instructions on how to build the map.
Enabling and Disabling the Feature
Command input is case-sensitive and space-sensitive.
The robot must be connected to the Internet, either in STA (LAN) mode or AP (direct connection) mode via Ethernet.
(1) Open the command line terminal from the left side of the system interface. In the terminal window, enter the following command and press Enter to stop the auto-start service
ros2 launch large_models_examples vllm_navigation.launch.py map:=map_01
(3) Once rviz is launched with the map, click on the 2D Pose Estimate icon to initialize the robot’s position and orientation based on its actual location on the map.
(4) When the command line displays the output shown below and the system announces “I’m Ready,” it indicates that the voice device has been successfully initialized. Then, you can say the wake word “hello hiwonder” to activate the device.
(5) When the terminal displays the corresponding output shown in the figure and the device responds with “I’m Here”, it indicates successful activation.
Speak a command such as “Go to the kitchen to see if the door is closed, then will come to tell me.” The voice device will capture the speech, and the large language model will process the command.
The response is automatically generated by the model. While the semantic content is accurate, the wording and structure may vary due to randomness in language generation.
(8) The robot will move to the designated “kitchen” location as defined in the program, detect whether the door is closed.
(9) Then return to the original position and state whether “the door is closed.”
(10) When the terminal shows the output shown in the figure indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 5 by speaking the wake words again.
(11) To exit the feature, press Ctrl+C in the terminal. If the feature does not exit immediately, press Ctrl+C multiple times.
Project Outcome
Once the program and map are fully loaded, you may speak a command such as: “Go to the kitchen to see if the door is closed and let me know when you come back.” The robot will navigate to the predefined “kitchen” location, verify the door status, then return to the starting point and report the outcome.
Modifying Navigation Locations
To change the robot’s navigation targets, modify the relevant parameters in the following file:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_navigation.py
(1) Begin by launching the program and displaying the map in rviz following step 4 above. Then, click on “2D Goal Pose” in the rviz interface to set the desired navigation target on the map.
(2) Return to the terminal to view the published goal parameters. Once you obtain the target coordinates, you can fill in the x and y values and related parameters accordingly.
Locate the corresponding section of the code shown below, and fill in your target location parameters after the appropriate location name.
The positions of different navigation targets in the program are relative to the robot’s starting point during the map-building process. The five parameters represent:
x: position on the x-axis (meters)
y: position on the y-axis (meters)
roll: rotation around the x-axis (degrees)
pitch: rotation around the y-axis (degrees)
yaw: rotation around the z-axis (degrees)
Taking “kitchen” as an example, if the robot’s target position is set to [1.45, -0.29, 0.0, 0.0, 0.0], it means that the robot will navigate to the “kitchen” location on the map.
To modify the robot’s target orientation:
The retrieved quaternion has been printed as Orientation (0, 0, -0.379167, 0.925328) = Angle: -0.777791 in radians. Convert this quaternion to Euler angles (roll, pitch, yaw), and the result is approximately roll ≈ 0°, pitch ≈ 0°, and yaw ≈ −44.56°, or converting the radian value directly to degrees gives −44.58°.
The final modified target position for “kitchen” is [1.45, -0.29, 0.0, 0.0, −44.58].
Program Brief Analysis
(1) Launch File Analysis
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_navigation.launch.py
① Import Libraries
1 2 3 4 5 6 7 8 9 | import os from ament_index_python.packages import get_package_share_directory from launch_ros.actions import Node from launch_ros.actions import PushRosNamespace from launch import LaunchDescription, LaunchService from launch.substitutions import LaunchConfiguration from launch.launch_description_sources import PythonLaunchDescriptionSource from launch.actions import DeclareLaunchArgument, IncludeLaunchDescription, GroupAction, OpaqueFunction, TimerAction, ExecuteProcess |
os: used for handling file paths and operating system-related functions.
ament_index_python.packages.get_package_share_directory: retrieves the share directory path of ROS 2 package.
launch_ros.actions.Node: used to define ROS 2 nodes.
LaunchDescription, LaunchService: used to define and start the Launch file.
launch_description_sources PythonLaunchDescriptionSource: enables the inclusion of other Launch files.
launch.actions.IncludeLaunchDescription, DeclareLaunchArgument, OpaqueFunction: used to define actions and arguments within the Launch file.
② Definition of the launch_setup Function
11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 | def launch_setup(context): slam_package_path = get_package_share_directory('slam') navigation_package_path = get_package_share_directory('navigation') large_models_package_path = get_package_share_directory('large_models') mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) map_name = LaunchConfiguration('map', default='map_01').perform(context) robot_name = LaunchConfiguration('robot_name', default=os.environ['HOST']) master_name = LaunchConfiguration('master_name', default=os.environ['MASTER']) map_name_arg = DeclareLaunchArgument('map', default_value=map_name) master_name_arg = DeclareLaunchArgument('master_name', default_value=master_name) robot_name_arg = DeclareLaunchArgument('robot_name', default_value=robot_name) navigation_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource(os.path.join(navigation_package_path, 'launch/navigation.launch.py')), launch_arguments={ 'sim': 'false', 'map': map_name, 'robot_name': robot_name, 'master_name': master_name, 'use_teb': 'true', }.items(), ) navigation_controller_node = Node( package='large_models_examples', executable='navigation_controller', output='screen', parameters=[{'map_frame': 'map', 'nav_goal': '/nav_goal'}] ) rviz_node = ExecuteProcess( cmd=['rviz2', 'rviz2', '-d', os.path.join(navigation_package_path, 'rviz/navigation_controller.rviz')], output='screen' ) large_models_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ) vllm_navigation_node = Node( package='large_models_examples', executable='vllm_navigation', output='screen', ) return [ mode_arg, map_name_arg, master_name_arg, robot_name_arg, navigation_launch, navigation_controller_node, rviz_node, large_models_launch, vllm_navigation_node ] |
This function is used to configure and initialize launch actions.
mode = LaunchConfiguration('mode', default=1) defines a Launch argument named mode with a default value of 1.
mode_arg = DeclareLaunchArgument('mode', default_value=mode) declares the mode argument and includes it in the Launch description.
navigation_package_path, large_models_package_path: retrieves the shared directory path of the navigation and large_models package.
navigation_launch: includes the file robot.launch.py and the file bringup.launch.py using IncludeLaunchDescription.
large_models_launch: includes the Launch file start.launch.py from the large_models package using IncludeLaunchDescription and passes the mode argument to it.
vllm_navigation_node: defines a ROS 2 node from the large_models_examples package, executes the executable files from the vllm_navigation.py, and prints the node’s output to the screen.
navigation_controller_node: defines a ROS 2 node from the large_models_examples package, executes the executable files from the navigation_controller.py to enable navigation control.
rviz_node: defines a ROS 2 node from the navigation package, executes the navigation_controller.rviz files to enable the displaying of navigation control.
The function returns a list of all defined Launch actions.
③ Definition of the generate_launch_description Function
73 74 75 76 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function = launch_setup) ]) |
This function is responsible for generating the complete Launch description.
The launch_setup function is incorporated using OpaqueFunction.
④ Main Program Entry
78 79 80 81 82 83 84 | if __name__ == '__main__': # Create a LaunchDescription object(创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
ld = generate_launch_description() generates the Launch description object.
ls = LaunchService() creates the Launch service object.
ls.include_launch_description(ld) adds the Launch description to the service.
ls.run() starts the service and execute all Launch actions.
(2) Python File Analysis
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_navigation.py
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 | #!/usr/bin/env python3 # encoding: utf-8 # @Author: Aiden # @Date: 2024/11/18 import os import re import time import json import rclpy import threading from speech import speech from rclpy.node import Node from sensor_msgs.msg import Image from std_msgs.msg import String, Bool from std_srvs.srv import Trigger, SetBool, Empty from large_models.config import * from large_models_msgs.srv import SetModel, SetContent, SetString, SetInt32 from interfaces.srv import SetPose2D from rclpy.executors import MultiThreadedExecutor from servo_controller_msgs.msg import ServosPosition from rclpy.callback_groups import ReentrantCallbackGroup from servo_controller.action_group_controller import ActionGroupController |
json: used for handling data in JSON format.
speech: handles modules related to large model voice interaction.
Large_models.config: configuration file for large models.
② PROMPT String
26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 | else: position_dict = {"kitchen": [2.8, -2.8, 0.0, 0.0, 0.0], #xyzrpy, m,deg "front desk": [2.8, -2.7, 0.0, 0.0, 0.0], "bedroom": [0.0, 0.0, 0.0, 0.0, 0.0], "zoo": [1.3, 0.37, 0.0, 0.0, 0.0], "space base": [1.58, -0.74, 0.0, 0.0, -48.0], "football field": [0.32, -0.65, 0.0, 0.0, -90.0], "origin": [0.0, 0.0, 0.0, 0.0, 0.0], "home": [0.1, 0.4, 0.0, 0.0, 0.0] } LLM_PROMPT = ''' **Role You are a smart navigation vehicle equipped with a camera and speaker. You can move to different places, analyze visual input, and respond by playing audio. Based on user input, you need to generate the corresponding JSON command. **Requirements - For any user input, look up corresponding functions from the Action Function Library, and generate the proper JSON output. - For each action sequence, include a concise (5–20 characters) and witty, varied response to make the interaction lively and engaging. - Output only the JSON result, no analysis or extra text. - Output format: { "action": ["xx", "xx"], "response": "xx" } **Special Notes The "action" field contains an ordered list of function names to be executed in sequence. If no matching function is found, return: "action": []. The "response" field should contain a carefully crafted, short, humorous, and varied message (5–20 characters). **Action Function Library Move to a specified place: move('kitchen') Return to starting point: move('origin') Analyze current view: vision('What do you see?') Play audio response: play_audio() **Example Input: Go to the front desk to see if the door is closed, and then come back and tell me Output: { "action": ["move('front desk')", "vision('Is the door closed?')", "move("origin")", "play_audio()"], "response": "On it, reporting soon!" } ''' |
③ VLLMNavigation Class
114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 | class VLLMNavigation(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.action = [] self.response_text = '' self.llm_result = '' self.play_audio_finish = False # self.llm_result = '{\'action\':[\'move(\"前台\")\', \'vision(\"大门有没有关\")\', \'move(\"原点\")\', \'play_audio()\'], \'response\':\'马上!\'}' self.running = True self.play_delay = False self.reach_goal = False self.interrupt = False timer_cb_group = ReentrantCallbackGroup() self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) # self.create_subscription(Image, 'depth_cam/rgb/image_raw', self.image_callback, 1) self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.create_subscription(Bool, 'navigation_controller/reach_goal', self.reach_goal_callback, 1) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_mode_client = self.create_client(SetInt32, 'vocal_detect/set_mode') self.set_mode_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.set_vllm_content_client = self.create_client(SetContent, 'agent_process/set_vllm_content') self.set_vllm_content_client.wait_for_service() self.set_pose_client = self.create_client(SetPose2D, 'navigation_controller/set_pose') self.set_pose_client.wait_for_service() self.controller = ActionGroupController(self.create_publisher(ServosPosition, 'servo_controller', 1), '/home/ubuntu/software/arm_pc/ActionGroups') self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
④ get_node_state Method
153 154 | def get_node_state(self, request, response): return response |
⑤ init_process Method
156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = LLM_PROMPT self.send_request(self.set_prompt_client, msg) init_finish = self.create_client(Empty, 'navigation_controller/init_finish') init_finish.wait_for_service() speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') self.get_logger().info('\033[1;32m%s\033[0m' % LLM_PROMPT) |
SetModel.Request(): creates a request message to set the LLM model.
SetModel.Request: creates a request for SetModel service.
msg.model_type = 'llm': specifies the model type as ‘llm’.
self.send_request(self.set_model_client, msg): sends the model configuration request through the set_model_client.
SetString.Request: creates a request message to set the prompt string.
self.send_request(self.set_prompt_client,msg): sends the model configuration request through the set_prompt_client.
Empty.Request: request message used to clear the current conversation history.
self.send_request(self.clear_chat_client, msg): sends the request through the clear_chat_client to reset chat context.
self.create_client(Empty, 'object_transport/init_finish'): creates a service client for calling the object_transport/init_finish endpoint.
init_finish.wait_for_service(): waits for the init_finish service to become available.
self.send_request(self.enter_client, Trigger.Request()): sends a Trigger request through the enter_client to initiate the process.
speech.play_audio: plays an audio cue.
threading.Thread: launches the main logic in a new thread.
⑥ send_request Method
178 179 180 181 182 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
⑦ llm_result_callback Method
188 189 | def llm_result_callback(self, msg): self.llm_result = msg.data |
This callback receives results from the agent_process/result topic and stores them in self.llm_result.
⑧ wakeup_callback Method
184 185 186 | def wakeup_callback(self, msg): self.get_logger().info('wakeup interrupt') self.interrupt = msg.data |
This method is invoked when the user activates the system via voice to receive and process the wake-up signal from the vocal_detect/wakeup topic.
⑨ move(self, position) Method
191 192 193 194 195 196 197 198 199 200 201 202 203 | def move(self, position): self.get_logger().info('position: %s' % str(position)) msg = SetPose2D.Request() if position not in position_dict: return False p = position_dict[position] msg.data.x = float(p[0]) msg.data.y = float(p[1]) msg.data.roll = p[2] msg.data.pitch = p[3] msg.data.yaw = p[4] self.send_request(self.set_pose_client, msg) return True |
Parameter receiving: receives a location name, such as “kitchen”.
Position Lookup p = position_dict[position] : retrieves the corresponding coordinate and position data from the position_dict dictionary.
Message Construction: creates a SetPose2D.Request() message and sets the values for x, y coordinates, and roll, pitch, yaw angles.
Service Invocation self.send_request(self.set_pose_client, msg): sends the request to the navigation controller using set_pose_client.
This method enables the robot to navigate between predefined locations, serving as a fundamental function for spatial movement tasks.
⑩ play_audio(self) Method
205 206 207 208 209 210 211 212 213 214 | def play_audio(self): msg = String() msg.data = self.response_text self.get_logger().info(f'{self.response_text}') while not self.play_audio_finish: time.sleep(0.1) self.play_audio_finish = False self.tts_text_pub.publish(msg) self.response_text = '' # time.sleep(20) |
This method plays the text content stored in self.response_text.
Message Creation msg = String(): initializes a String type message.
Logging msg.data = self.response_text: logs the content to be played.
Waiting while not self.play_audio_finish: enters a loop that waits for the previous audio playback to complete.
State Reset self.play_audio_finish = False: resets the playback status with self.play_audio_finish = False.
Publishing Self.tts_text_pub.publish(msg): publishes the message to the tts_text_pub topic to trigger text-to-speech conversion.
self.response_text = '': clears self.response_text.
This method enables the robot to deliver voice feedback, allowing it to communicate with the user through speech.
⑪ reach_goal_callback(self, msg) Method
216 217 218 | def reach_goal_callback(self, msg): self.get_logger().info('reach goal') self.reach_goal = msg.data |
Parameter Receiving: receives a Boolean message indicating whether the robot has reached its destination.
State Update: updates the internal navigation status by assigning the message data to self.reach_goal.
This callback handles feedback from the navigation controller and informs the system when the robot completes a movement task.
⑫ vision(self, query) Method
220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 | def vision(self, query): self.controller.run_action('horizontal') msg = SetContent.Request() if language == 'Chinese': msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url msg.model = stepfun_vllm_model else: msg.api_key = vllm_api_key msg.base_url = vllm_base_url msg.model = vllm_model msg.prompt = VLLM_PROMPT msg.query = query self.get_logger().info('vision: %s' % query) res = self.send_request(self.set_vllm_content_client, msg) self.controller.run_action('init') return res.message |
This method processes visual queries using the Vision-Language Large Model (VLLM).
Parameter Receiving: accepts a query string, such as “What do you see?”.
Message Construction: creates a SetContent.Request() message containing the API key, base URL, model name, prompt string, and query content.
Service Invocation: sends the request to the vision-language large model service via set_vllm_content_client.
Response Return: returns the response message from the VLLM.
This method equips the robot with visual perception capabilities, allowing it to understand and describe its visual surroundings.
⑬ play_audio_finish_callback(self, msg) Method
238 239 240 241 242 243 244 245 | def play_audio_finish_callback(self, msg): # msg = SetBool.Request() # msg.data = True # self.send_request(self.awake_client, msg) # msg = SetInt32.Request() # msg.data = 1 # self.send_request(self.set_mode_client, msg) self.play_audio_finish = msg.data |
This method handles the callback notification indicating the completion of audio playback.
① Parameter Receiving: receives a Boolean message that indicates whether audio playback is complete.
② State Update: updates the playback status by assigning the message data to self.play_audio_finish.
③ Wake-up Configuration: constructs a SetBool.Request() message to enable the wake-up function.
④ Mode Configuration: constructs a SetInt32.Request() message to set the interaction mode to 1.
This method handles post-playback processing and prepares the system for the next user command, supporting continuous interaction.
⑭ process Method
247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 | def process(self): first = True while self.running: if self.llm_result: self.interrupt = False msg = String() if 'action' in self.llm_result: # If a corresponding action is returned, extract and process it (如果有对应的行为返回那么就提取处理) result = json.loads(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}')+1]) if 'response' in result: msg.data = result['response'] self.tts_text_pub.publish(msg) if 'action' in result: action = result['action'] self.get_logger().info(f'vllm action: {action}') for a in action: if 'move' in a: self.reach_goal = False res = eval(f'self.{a}') if res: while not self.reach_goal: if self.interrupt: self.get_logger().info('interrupt') break # self.get_logger().info('waiting for reach goal') time.sleep(0.01) elif 'vision' in a: res = eval(f'self.{a}') self.response_text = res self.get_logger().info(f'vllm response: {res}') elif 'play_audio' in a: eval(f'self.{a}') while not self.play_audio_finish: time.sleep(1) if self.interrupt: self.get_logger().info('interrupt') break else: # If there is no corresponding action, only respond (没有对应的行为,只回答) msg.data = self.llm_result self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) # msg = SetInt32.Request() # msg.data = 2 # self.send_request(self.set_mode_client, msg) rclpy.shutdown() |
Check LLM Result:
if self.llm_result: check whether self.llm_result contains content. If not empty, it indicates that a new result from the LLM needs to be processed. Otherwise, the system enters a short sleep to wait for new results.
Check for Action Commands:
if 'action' in self.llm_result: if the returned result contains the “action” field, it means that in addition to the response text, there are action commands to execute.
Extract and Parse JSON Data:
result = json.loads(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}')+1]): use string search to locate the start and end of the JSON section, and parse it into a dictionary using json.loads to extract fields such as “response” and “action”.
Handle Text Response and Execute Actions:
If the parsed result contains “response”, assign the content to a message and publish it to the tts_text_pub topic to trigger TTS playback.
If “action” is present, iterate through the action list:
a. Move command: If the action string contains “move”, first set self.reach_goal to False, call the corresponding move function using eval to execute dynamically, and then loop until self.reach_goal becomes True, which indicats that the robot has reached the goal. During this period, monitor self.interrupt to allow interruption.
b. Vision detection: If “vision” is present, execute the corresponding vision function, assign the returned result to self.response_text, and log the result.
c. Audio playback: If “play_audio” is present, directly call the corresponding audio playback function.
Interrupt Check:
During each action execution, continuously monitor the self.interrupt flag. If an interrupt is triggered while waiting or executing an action, the current action is interrupted and the corresponding loop is exited in time.
Mark as Complete and Switch Mode:
Regardless of whether actions are included, after processing the current LLM result, set self.action_finish to True and clear self.llm_result. Later in the loop, when both self.play_audio_finish and self.action_finish are True, reset these two flags and send a mode-switch request via set_mode_client, entering the next state. Finally, when self.running becomes False, the loop exits and the ROS system is shut down.
⑮ main Method
301 302 303 304 305 306 307 308 309 | def main(): node = VLLMNavigation('vllm_navigation') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() if __name__ == "__main__": main() |
Create an instance of the VLLMObjectTransport node.
File Path: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/navigation_controller.py
① Import the necessary libraries
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 | #!/usr/bin/env python3 # encoding: utf-8 # @data:2022/11/18 # @author:aiden # Navigation transport(导航搬运) import math import rclpy import numpy as np from rclpy.node import Node import sdk.common as common from std_msgs.msg import Bool from std_srvs.srv import Trigger, Empty from rclpy.duration import Duration from interfaces.srv import SetPose2D from geometry_msgs.msg import PoseStamped from rcl_interfaces.srv import GetParameters from rclpy.executors import MultiThreadedExecutor from visualization_msgs.msg import Marker, MarkerArray from rclpy.callback_groups import ReentrantCallbackGroup from nav2_simple_commander.robot_navigator import BasicNavigator, TaskResult |
math: used for angle conversion, e.g., math.radians(data.roll), to convert degrees to radians.
rclpy: provides tools for creating and communicating between ROS 2 nodes.
rclpy.node.Node: base class for ROS 2 nodes.
rclpy.duration.Duration: handles ROS 2 time and duration, used for navigation timeout calculation, for example, Duration.from_msg(feedback.navigation_time) > Duration(seconds=600.0).
rclpy.callback_groups.ReentrantCallbackGroup: supports concurrent callback handling.
nav2_simple_commander.robot_navigator: provides navigation functionality encapsulation.
std_msgs.msg.Bool: message type for boolean values.
std_srvs.srv.Trigger, Empty: standard service types, used to create services like self.create_service(Empty, '~/init_finish', self.get_node_state).
interfaces.srv.SetPose2D: custom service type for setting navigation goal poses, for instance, self.create_service(SetPose2D, '~/set_pose', self.move_srv_callback).
geometry_msgs.msg.PoseStamped: pose message with timestamp.
rcl_interfaces.srv.GetParameters: parameter service type.
visualization_msgs.msg.Marker, MarkerArray: messages for visualization markers.
sdk.common: custom SDK utility functions.
numpy (np): supports matrix and vector operations.
② NavigationController Class
22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 | class NavigationController(Node): markerArray = MarkerArray() def __init__(self, name): rclpy.init() super().__init__(name, allow_undeclared_parameters=True, automatically_declare_parameters_from_overrides=True) self.goal_pose = PoseStamped() self.navigator = BasicNavigator() self.map_frame = 'map'#self.get_parameter('map_frame').value self.nav_goal = '/nav_goal'#self.get_parameter('nav_goal').value timer_cb_group = ReentrantCallbackGroup() self.goal_pub = self.create_publisher(PoseStamped, '/goal_pose', 1) self.nav_pub = self.create_publisher(PoseStamped, self.nav_goal, 1) self.mark_pub = self.create_publisher(MarkerArray, 'path_point', 1) self.reach_pub = self.create_publisher(Bool, '~/reach_goal', 1) self.create_subscription(PoseStamped, self.nav_goal, self.goal_callback, 1, callback_group=timer_cb_group) self.create_service(SetPose2D, '~/set_pose', self.move_srv_callback) self.navigator.waitUntilNav2Active() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') |
super()._init_(name): call the parent Node class constructor to create a ROS 2 node.
self.create_subscription: subscribe to navigation goal poses.
self.create_client: create service clients.
self.timer: create a timer.
self.goal_pose: store the navigation goal pose.
self.navigator: navigator object.
self.map_frame: name of the map coordinate frame.
self.nav_goal: topic name for navigation goals.
self.goal_pub: publisher for goal poses.
self.nav_pub: publisher for navigation goals.
self.mark_pub: publisher for markers.
self.reach_pub: publisher for goal-reached messages.
self.create_service: create service servers.
③ send_request Method
52 53 54 55 56 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
This method creates a loop to continuously check if the service call is complete.
rclpy.ok(): ensures the ROS 2 system is still running.
future.done(): checks whether the service call has completed.
future.result(): retrieves the result of the service call.
Once the service call completes and the result is valid, return the result.
④ move_srv_callback Method
58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 | def move_srv_callback(self, request, response): self.get_logger().info('start navigaiton pick') marker_Array = MarkerArray() marker = Marker() marker.header.frame_id = self.map_frame marker.action = Marker.DELETEALL marker_Array.markers.append(marker) self.mark_pub.publish(marker_Array) markerArray = MarkerArray() pose = PoseStamped() pose.header.frame_id = self.map_frame pose.header.stamp = self.navigator.get_clock().now().to_msg() data = request.data q = common.rpy2qua(math.radians(data.roll), math.radians(data.pitch), math.radians(data.yaw)) pose.pose.position.x = data.x pose.pose.position.y = data.y pose.pose.orientation = q # Mark the point with number to display(用数字标记来显示点) marker = Marker() marker.header.frame_id = self.map_frame marker.type = marker.MESH_RESOURCE marker.mesh_resource = "package://example/resource/flag.dae" marker.action = marker.ADD # Size(大小) marker.scale.x = 0.08 marker.scale.y = 0.08 marker.scale.z = 0.2 # Color(颜色) color = list(np.random.choice(range(256), size=3)) marker.color.a = 1.0 marker.color.r = color[0] / 255.0 marker.color.g = color[1] / 255.0 marker.color.b = color[2] / 255.0 # marker.lifetime = rospy.Duration(10) # Display time. If not set, it will be kept by default(显示时间,没有设置默认一直保留) # Position posture(位置姿态) marker.pose.position.x = pose.pose.position.x marker.pose.position.y = pose.pose.position.y marker.pose.orientation = pose.pose.orientation markerArray.markers.append(marker) self.mark_pub.publish(markerArray) self.nav_pub.publish(pose) response.success = True response.message = "navigation pick" return response |
This is the callback function for the ~/set_pose service. It is used to receive external requests to set a new navigation goal and to visualize the target point in visualization tools, for example, RViz.
Clear Existing Markers
Create a MarkerArray object named marker_Array. Construct a Marker object and set its action to DELETEALL.
Add this Marker to marker_Array.markers and publish it via self.mark_pub to clear any previously existing markers.
Construct a New Navigation Goal (PoseStamped)
pose = PoseStamped(): create a PoseStamped message object named pose.
pose.header.frame_id = self.map_frame: set its coordinate frame to self.map_frame (”map”).
Fill pose.header.stamp with the current timestamp.
data = request.data: extract position data x, y and Euler angles roll, pitch, yaw from the request.
q = common.rpy2qua(): since ROS requires orientation in quaternion form, convert the Euler angles using the common.rpy2qua function after converting to radians, and assign the result to pose.pose.orientation.
Construct and Display Goal Marker
Create another MarkerArray object named markerArray for displaying the new goal.
marker = Marker(): create a Marker object.
header.frame_id = self.map_frame: set the coordinate system
marker.mesh_resource = "package://example/resource/flag.dae": set the mesh resource to “package://example/resource/flag.dae”, a 3D model representing the goal position.
marker.action = marker.ADD: indicate that this is a new marker to add.
Set the marker’s scale and transparency (alpha = 1.0).
Generate three random RGB color values using numpy, and normalize them by dividing by 255.
Set the marker’s position and orientation to match those in pose.
Add the Marker to markerArray.markers and publish it using self.mark_pub, then the goal point appears in RViz.
Publish Navigation Goal
self.nav_pub.publish(pose): publish the constructed pose message to the /nav_goal topic so other nodes or internal callbacks like goal_callback can receive the new goal.
Return Service Response
Set response.success = True and response.message = "navigation pick" to indicate the service call succeeded, then return the response.
⑤ goal_callback Method
110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 | def goal_callback(self, msg): # Obtain the navigation point to be published(获取要发布的导航点) self.get_logger().info('\033[1;32m%s\033[0m' % str(msg)) self.navigator.goToPose(msg) i = 0 # feedback = self.navigator.getFeedback() # total_time = Duration.from_msg(feedback.estimated_time_remaining).nanosecond / 1e9 # self.get_logger().info('\033[1;32m%s\033[0m' % 'total_time') while not self.navigator.isTaskComplete(): i = i + 1 feedback = self.navigator.getFeedback() # self.get_logger().info(f'{feedback.navigation_time} {feedback.estimated_time_remaining}') if feedback and i % 5 == 0: # self.get_logger().info( # 'Estimated time of arrival: ' # + '{0:.0f}'.format( # Duration.from_msg(feedback.estimated_time_remaining).nanoseconds # / 1e9 # ) # + ' seconds.' # ) # Some navigation timeout to demo cancellation if Duration.from_msg(feedback.navigation_time) > Duration(seconds=600.0): self.get_logger().info('\033[1;32m%s\033[0m' % 'timeout...') self.navigator.cancelTask() # Some navigation request change to demo preemption # if Duration.from_msg(feedback.navigation_time) > Duration(seconds=36.0): # self.get_logger().info('\033[1;32m%s\033[0m' % 'preempt...') # self.goal_pub.publish(self.goal_pose) # self.get_logger().info('\033[1;32m%s\033[0m' % 'feedback') # Do something depending on the return code result = self.navigator.getResult() if result == TaskResult.SUCCEEDED: self.get_logger().info('Goal succeeded!') msg = Bool() msg.data = True self.reach_pub.publish(msg) elif result == TaskResult.CANCELED: self.get_logger().info('Goal was canceled!') elif result == TaskResult.FAILED: self.get_logger().info('Goal failed!') else: self.get_logger().info('Goal has an invalid return status!') |
Receives and processes a navigation goal message, triggering the robot to navigate and monitoring task status in real time. It handles timeout and preemption, and publishes feedback based on the final result.
Receive and Log the Goal
At the beginning of the function, log the received goal message.
Start the Navigation Task
Call self.navigator.goToPose(msg) to pass the received goal to the navigator and initiate the robot move towards the goal point.
Real-Time Navigation Monitoring
Enter a while loop to continuously check whether the task is complete.
Use a counter i to throttle the frequency of feedback checking, for example, check every 5 iterations.
feedback = self.navigator.getFeedback(): get current navigation feedback.
Timeout Handling:
If feedback.navigation_time exceeds 600 seconds, consider the task timed out and log “timeout…”, and call self.navigator.cancelTask() to cancel the navigation.
Preemption Handling:
If the navigation time exceeds 36 seconds, log “preempt…” and re-publish the goal via self.goal_pub with self.goal_pose. This is often used in demo settings or to support task preemption or switching.
Result Handling After Task Completion
When self.navigator.isTaskComplete() returns True, exit the loop and retrieve the final result using result = self.navigator.getResult().
Determine Final Outcome
If the task succeeded (TaskResult.SUCCEEDED), log “Goal succeeded!” and publish a Bool message with value True to notify other nodes that the goal was reached.
If the task was canceled or failed, log “Goal was canceled!” or “Goal failed!” respectively.
If the result has an unknown status, log “Goal has an invalid return status!”.
This function implements a full navigation task workflow: receiving the goal, initiating navigation, monitoring progress, handling timeouts or preemption, and publishing results based on the outcome.
10.3.5 Intelligent Transport in Embodied AI Applications
The large model used in this lesson operates online, requiring a stable network connection for the main controller in use.
Once the program starts running, the Six-Microphone Circular Array will announce “I’m Ready”, hereafter called the voice device. To activate the voice device, speak the designated wake words: “Hello Hiwonder.” Upon successful activation, the voice device will respond with “I’m Here.” After activation, voice commands can be used to control the robot. For example, issuing the instruction “Put the red cube in the blue box.” Upon receiving a command, the terminal displays the recognized speech content. The voice device then verbally responds with a generated answer and the robot simultaneously executes the corresponding action.
Getting Started
Grasp and Placement Calibration
Before starting the intelligent handling process, you need to adjust the grasping behavior to ensure accurate performance. If the robotic arm fails to pick up the colored blocks during the demo or operation, you can follow the steps below to perform grasp calibration. This allows you to adjust the pickup area using program commands.
(1) Open a new command-line terminal and run the following command to stop the auto-start service of the app:
(2) To begin grasp calibration, enter the following command:
ros2 launch large_models_examples automatic_pick.launch.py debug:=pick
(3) Wait until the program finishes loading and you hear the voice prompt “I’m Ready.”
(4) The robotic arm will perform a calibration grasping action and place the object at the gripper’s pickup location. Once the robotic arm returns to its original posture, use the mouse to left-click and drag a bounding box around the target object on the screen. Once the object is correctly identified, the system will automatically calibrate the pickup position for that specific target.
(5) The calibration process for placing objects is the same as for grasping. To begin placement calibration, run the following command:
ros2 launch large_models_examples automatic_pick.launch.py debug:=place
Before enabling this feature, a map must be created in advance. Please refer to 4. Mapping & Navigation Course -> Mapping for detailed instructions on how to build the map.
(2) If the map is not yet created, refer to section “4. Navigation Map Construction”. To save the map for the first time, it is necessary to compile the SLAM package. For future mapping and saving tasks, recompilation is not required.
Navigate to the ros2_ws workspace:
cd ros2_ws
Compile the SLAM package:
colcon build --event-handlers console_direct+ --cmake-args -DCMAKE_BUILD_TYPE=Release --symlink-install --packages-select slam
Refresh the environment variables:
source ~/.zshrc
(3) Enter the command and press Enter to start the feature.
ros2 launch large_models_examples vllm_navigation_transport.launch.py map:=map_01
(4) After opening the map in RViz, click the “2D Pose Estimate” icon to set the robot’s initial position.
(5) When the terminal displays output shown in the figure and the Circular Microphone Array announces “I’m Ready”, the device has completed initialization and yolov8 model will be initialized at the same time. Then, you can say the wake words: “Hello Hiwonder”.
(6) When the terminal displays the corresponding output shown in the figure and the device responds with “I’m Here”, it indicates successful activation.
Speak a command such as “Put the red cube in the blue box.” The voice device will capture the speech, and the large language model will process the command.
(7) When the terminal displays the next output as the reference image, it shows the recognized speech transcribed by the device.
(8) Upon successful recognition by the speech recognition service of cloud-based large speech model, the parsed command will be displayed under the publish_asr_result output in the terminal.
(9) Upon receiving user input shown in the figure, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command, generate a language response, and execute a corresponding action based on the meaning of the command.
(10) To grasp the block, the robot will first navigate to the “red cube” location preset in the program.
(11) Then, it will go to the “blue box” location preset to place the block into the container.
(12) When the terminal shows the output shown in the figure indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 4 by speaking the wake words to activate the voice device again, then issue a new command.
(13) To exit the feature, press Ctrl+C in the terminal. If the feature does not exit immediately, press Ctrl+C multiple times.
Project Outcome
Once the feature is started, you can give natural language commands, such as “Put the red cube in the blue box.” The robot will first go to the reception area to grasp the block, then proceed to the kitchen to place the block into the box.
In the program, different positions are expressed as coordinates relative to the map origin, which corresponds to the robot’s starting point during the map-building process. The five parameters represent:
x coordinate (unit: meters)
y coordinate (unit: meters)
roll angle (rotation around the x-axis, in degrees)
pitch angle (rotation around the y-axis, in degrees)
yaw angle (rotation around the z-axis, in degrees)
Take “blue cube” as an example. Enter the coordinates shown in the figure below:
[0.0, 0.45, 0.0, 0.0, 90.0] indicates the robot’s target position for reaching the “blue cube”.
To modify the robot’s orientation, convert the printed quaternion Quaternion(x=0.0, y=0.0, z=-0.5677173914973032, w=0.8232235197025761) into Euler angles (roll, pitch, yaw). The conversion results are approximately roll ≈ 0°, pitch ≈ 0°, and yaw ≈ -69.3°.
The final modified target position for “blue cube” is [0.996, -0.872, 0.0, 0.0, -69.3]
① Import Libraries
launch.substitutions.LaunchConfiguration: retrieves parameter values defined in the Launch file.
11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 | def launch_setup(context): slam_package_path = get_package_share_directory('slam') large_models_examples_package_path = get_package_share_directory('large_models_examples') large_models_package_path = get_package_share_directory('large_models') mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) map_name = LaunchConfiguration('map', default='map_01').perform(context) robot_name = LaunchConfiguration('robot_name', default=os.environ['HOST']) master_name = LaunchConfiguration('master_name', default=os.environ['MASTER']) map_name_arg = DeclareLaunchArgument('map', default_value=map_name) master_name_arg = DeclareLaunchArgument('master_name', default_value=master_name) robot_name_arg = DeclareLaunchArgument('robot_name', default_value=robot_name) navigation_controller_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource(os.path.join(large_models_examples_package_path, 'large_models_examples/navigation_transport/navigation_transport.launch.py')), launch_arguments={ 'map': map_name, 'debug': 'false', 'robot_name': robot_name, 'master_name': master_name, }.items(), ) large_models_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ) vllm_navigation_transport_node = Node( package='large_models_examples', executable='vllm_navigation_transport', output='screen', ) return [ mode_arg, map_name_arg, master_name_arg, robot_name_arg, navigation_controller_launch, large_models_launch, vllm_navigation_transport_node ] |
This function includes the file navigation_transport.launch.py from the large_models_examples package, which launches the navigation-to-goal functionality.
vllm_navigation_transport_node: defines a ROS 2 node from the large_models package, executes the executable files from vllm_navigation_transport, and prints the node’s output to the screen.
The function returns a list of all defined launch actions.
58 59 60 61 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function = launch_setup) ]) |
This function is responsible for generating the complete launch description.
63 64 65 66 67 68 69 | if __name__ == '__main__': # Create a LaunchDescription object(创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
ld = generate_launch_description() generates the launch description object.
ls = LaunchService() creates the launch service object.
ls.include_launch_description(ld) adds the launch description to the service.
ls.run() starts the service and execute all launch actions.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 | #!/usr/bin/env python3 # encoding: utf-8 # @Author: Aiden # @Date: 2024/11/18 import re import cv2 import time import json import rclpy import queue import threading import numpy as np from speech import speech from rclpy.node import Node from cv_bridge import CvBridge from sensor_msgs.msg import Image from std_msgs.msg import String, Bool from std_srvs.srv import Trigger, SetBool, Empty from large_models.config import * from large_models_msgs.srv import SetModel, SetContent, SetString, SetInt32 from interfaces.srv import SetPose2D, SetPoint, SetBox from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup |
cv2: utilized for image processing and display using OpenCV.
time: manages execution delays and time-related operations.
queue: handles image queues between threads.
threading: enables multithreading for concurrent task processing.
std_srvs.srv: contains standard ROS service types, used to define standard service.
std_msgs.msg: contains standard ROS message types.
rclpy.executors.MultiThreadedExecutor: multithreaded executor in ROS 2 for handling concurrent tasks.
rclpy.node: node class in ROS 2.
speech: module related to large model voice interaction.
large_models_msgs.srv: custom service types for large models.
large_models.config: configuration file for large models.
② PROMPT String
82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 | else: position_dict = { "green cube": [0.0, 0.45, 0.0, 0.0, 90.0], "red box": [1.2, 0.55, 0.0, 0.0, 0.0], "red cube": [0.25, 0.35, 0.0, 0.0, 90.0], "green box": [1.2, -0.9, 0.0, 0.0, -62.0], "blue cube": [0.0, 0.5, 0.0, 0.0, -180.0], "blue box": [-0.2, -0.75, 0.0, 0.0, -90.0], "origin": [0.0, 0.0, 0.0, 0.0, 0.0]} LLM_PROMPT = ''' You are a language expert who precisely interprets user commands. **Skills - Treat each pick-and-place as one composite action. - Strong logical reasoning; understand object descriptors. - Accurately decompose which objects to pick and which to place. **Requirements & Constraints - Map the user's request to the available functions and output those calls. - Bundle multiple actions into a JSON array. - Add a concise (10–30 characters), witty, ever-changing feedback message for the sequence. - Each transport has two phases: move to the pick location, then move to the place location. - If no move target is specified, omit the move call. - Valid locations: blue cube, blue box, red cube, red box, green cube, green box, origin. - Only cubes with red, green, or blue faces count as "cubes"; ignore the ground. - Don't include any extra text (e.g. "task complete"). - Output only this JSON structure: {"action":"xx", "response":"xx"} **Available Functions - pick('red cube') - place('red box') - move('origin') **Example Input: Put the red cube into its matching box Output: {"action": ["move('red cube')", "pick('red cube')", "move('red box')", "place('red box')"], "response": "Right away—on the move!"} Input: Put the blue cube into the blue box Output: {"action": ["move('blue cube')","pick('blue cube')", "move('blue box')", "place('blue box')"], "response": "OK, start the task"} ''' VLLM_PROMPT = ''' You are an image‐recognition specialist. Your task is to detect and precisely localize specified objects in user‐provided images, then produce the final result in the exact format below. 1. Parse User Instruction I will give you a sentence describing which object to find. Extract and output only the object name mentioned (in English). Do not include any unmentioned objects. 2. Analyze the Image I will provide an image. For the specified object, determine if there is a graspable region. If found, output its bounding box as pixel coordinates: top-left (xmin, ymin) and bottom-right (xmax, ymax). Ignore any objects not mentioned. Pay close attention to spatial relationships between objects. **Output Format (strictly follow this format, do not output anything else.The coordinates (xmin, ymin, xmax, ymax) must be normalized to the range [0, 1]) { "object": "name", "xyxy": [xmin, ymin, xmax, ymax] } **Example Input: red box Output: { "object": "red box", "xyxy": [0.1, 0.3, 0.4, 0.6] } ''' |
It defines three prompt strings (PROMPT) used to guide how user commands and image data are processed. It specifies the recognition task logic and expected output format.
③ VLLMObjectTransport Class
152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 | class VLLMNavigation(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.action = [] self.response_text = '' self.llm_result = '' self.action_finish = False self.transport_action_finish = False self.play_audio_finish = False # self.llm_result = '{\'action\':[\'move(\"前台\")\', \'vision(\"大门有没有关\")\', \'move(\"原点\")\', \'play_audio()\'], \'response\':\'马上!\'}' self.running = True self.reach_goal = False self.interrupt = False self.bridge = CvBridge() self.image_queue = queue.Queue(maxsize=2) timer_cb_group = ReentrantCallbackGroup() self.client = speech.OpenAIAPI(api_key, base_url) self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(Image, 'automatic_pick/image_result', self.image_callback, 1) self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.create_subscription(Bool, 'navigation_controller/reach_goal', self.reach_goal_callback, 1) self.create_subscription(Bool, 'automatic_pick/action_finish', self.action_finish_callback, 1) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_mode_client = self.create_client(SetInt32, 'vocal_detect/set_mode') self.set_mode_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.set_vllm_content_client = self.create_client(SetContent, 'agent_process/set_vllm_content') self.set_vllm_content_client.wait_for_service() self.set_pose_client = self.create_client(SetPose2D, 'navigation_controller/set_pose') self.set_pose_client.wait_for_service() # self.set_target_client = self.create_client(SetPoint, 'automatic_pick/set_target_color') # self.set_target_client.wait_for_service() self.set_box_client = self.create_client(SetBox, 'automatic_pick/set_box') self.set_box_client.wait_for_service() self.set_pick_client = self.create_client(Trigger, 'automatic_pick/pick') self.set_pick_client.wait_for_service() self.set_place_client = self.create_client(Trigger, 'automatic_pick/place') self.set_place_client.wait_for_service() self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
rclpy.init(): initializes the ROS 2 system.
super().init(name): calls the initializer of the parent class (Node) to create a ROS 2 node.
self.llm_result: stores results returned from LLM.
self.running: used to control the runtime state of the program.
self.transport_finished: indicates whether the transport task has been completed.
self.tts_text_pub: publishes TTS (Text-to-Speech) text to a ROS topic.
self.create_subscription: subscribes to LLM results and the transport completion status.
self.lock: threading lock used for synchronization in multi-threaded operations.
self.client: speech API client used to communicate with the voice service.
self.tts_text_pub: publishes TTS messages to a ROS topic.
self.asr_pub: publishes speech recognition results to a ROS topic.
self.create_subscription: subscribes to LLM result and transport status topics.
self.create_client: creates multiple service clients for calling various functionalities.
self.timer: creates a timer used to trigger the initialization process.
200 201 | def get_node_state(self, request, response): return response |
return response: returns a response object.
203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = LLM_PROMPT self.send_request(self.set_prompt_client, msg) init_finish = self.create_client(Empty, 'navigation_controller/init_finish') init_finish.wait_for_service() speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') |
self.timer.cancel(): cancels the timer.
SetModel.Request: creates a request message to set the LLM model.
SetModel.Request(): creates a request for SetModel service.
self.create_service: creates a service to signal the completion of initialization.
self.get_logger().info: prints log messages.
224 225 226 227 228 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
client.call_async(msg): makes an asynchronous service call.
future.done() and future.result(): check if the service call is complete and retrieve the result.
⑦ vllm_result_callback Method
233 234 | def llm_result_callback(self, msg): self.llm_result = msg.data |
⑧ get_object_position Method
259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 | def get_object_position(self, query, image): msg = SetContent.Request() if language == 'Chinese': msg.model = stepfun_vllm_model msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url else: msg.api_key = vllm_api_key msg.base_url = vllm_base_url msg.model = vllm_model msg.prompt = VLLM_PROMPT msg.query = query msg.image = self.bridge.cv2_to_imgmsg(image, "bgr8") self.get_logger().info('vision: %s' % query) self.get_logger().info('send image') res = self.send_request(self.set_vllm_content_client, msg) vllm_result = res.message self.get_logger().info('vllm_result: %s' % vllm_result) if 'object' in vllm_result: if vllm_result.startswith("```") and vllm_result.endswith("```"): vllm_result = vllm_result.strip("```").replace("json\n", "").strip() # self.get_logger().info('vllm_result: %s' % vllm_result) vllm_result = json.loads(vllm_result[vllm_result.find('{'):vllm_result.find('}')+1]) box = vllm_result['xyxy'] if box: h, w = image.shape[:2] if language == 'Chinese': box = self.client.data_process(box, w, h) self.get_logger().info('box: %s' % str(box)) else: box = [int(box[0] * w), int(box[1] * h), int(box[2] * w), int(box[3] * h)] cv2.rectangle(image, (box[0], box[1]), (box[2], box[3]), (255, 0, 0), 2, 1) return box else: msg = String() msg.data = vllm_result self.tts_text_pub.publish(vllm_result) return [] |
query: a query request.
image: the input image data.
offset: offset of the placement position.
SetContent.Request: request message used to set the LLM content.
self.send_request: sends the service request.
res.message: extracts the message content from the service response.
if 'object' in vllm_result: checks whether the result contains object-related information.
if vllm_result.startswith(" ``") and vllm_result.endswith("```"): checks the message format.
**vllm_result.strip(”").replace("json\n", "").strip()**: cleans up the message content, removes the code block markers (), strips the “json\n” prefix, trims leading and trailing whitespace, and extracts a pure JSON string.
json.loads(message): parses the cleaned JSON string into a Python dictionary.
vllm_result.message: extracts the message the response.
box = self.client.data_process(box, w, h): processes the bounding box for the placement position.
self.tts_text_pub.publish(msg): publishes the final message.
⑨ pick Method
299 300 301 302 303 304 305 306 307 308 309 | def pick(self, query): self.send_request(self.set_pick_client, Trigger.Request()) image = self.image_queue.get(block=True) box = self.get_object_position(query, image) if box: msg = SetBox.Request() msg.x_min = box[0] msg.y_min = box[1] msg.x_max = box[2] msg.y_max = box[3] self.send_request(self.set_box_client, msg) |
Trigger Pick Preparation
self.send_request(self.set_pick_client, Trigger.Request()): sends a trigger request to the pick service, which may cause the robotic arm to enter pick-ready status.
Acquire Image
image = self.image_queue.get(block=True): retrieves the latest image from the image queue.
block=True: means the method will wait until an image is available before proceeding.
Detect Target Object
box = self.get_object_position(query, image): calls the get_object_position method to detect the object based on the query and input image, returning bounding box coordinates.
Handle Detection Result
if box: checks whether the object was successfully detected. If successful, the bounding box data is recorded for further processing.
Create Bounding Box Request
msg = SetBox.Request(): creates a request to set the bounding box coordinates.
Set the bounding box coordinates:
msg.x_min = box[0]
msg.y_min = box[1]
msg.x_max = box[2]
msg.y_max = box[3]
Send Bounding Box to Pick Node
self.log_info("Step 5: Sending bounding box to automatic_pick node"): logs the operation of sending the bounding box.
self.send_request(self.set_box_client, msg): sends the bounding box request to the pick node so it knows where the object is located for grasping.
⑩ place Method
311 312 313 314 315 316 317 318 319 320 321 322 323 324 | def place(self, query): self.get_logger().info('place: %s' % query) self.send_request(self.set_place_client, Trigger.Request()) image = self.image_queue.get(block=True) h, _ = image.shape[:2] image = image[:int(h*0.7), :] box = self.get_object_position(query, image) if box: msg = SetBox.Request() msg.x_min = box[0] msg.y_min = box[1] msg.x_max = box[2] msg.y_max = box[3] self.send_request(self.set_box_client, msg) |
The logic and structure are analogous to the pick method.
⑪ transport_finished_callback Method
255 256 257 | def action_finish_callback(self, msg): self.get_logger().info('action finish') self.transport_action_finish = msg.data |
This method handles updates on the transport status.
⑫ process Method
329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 | def process(self): while self.running: if self.llm_result: self.interrupt = False msg = String() if 'action' in self.llm_result: # If a corresponding action is returned, extract and process it (如果有对应的行为返回那么就提取处理) result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}')+1]) if 'response' in result: msg.data = result['response'] self.tts_text_pub.publish(msg) if 'action' in result: action = result['action'] self.get_logger().info(f'vllm action: {action}') for a in action: if 'move' in a: self.reach_goal = False res = eval(f'self.{a}') if res: while not self.reach_goal: # if self.interrupt: # self.get_logger().info('interrupt') # break # self.get_logger().info('waiting for reach goal') time.sleep(0.01) else: self.get_logger().info('cannot move to %s' % a) break elif 'pick' in a or 'place' in a: time.sleep(3.0) eval(f'self.{a}') self.transport_action_finish = False while not self.transport_action_finish: # if self.interrupt: # self.get_logger().info('interrupt') # break time.sleep(0.01) # if self.interrupt: # self.get_logger().info('interrupt') # break else: # If there is no corresponding action, only respond (没有对应的行为,只回答) msg.data = self.llm_result self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) # msg = SetInt32.Request() # msg.data = 2 # self.send_request(self.set_mode_client, msg) rclpy.shutdown() |
while self.running: this loop keeps running as long as self.running is set to True.
if self.vllm_result: checks whether self.vllm_result is empty, which is the result from vllm model.
self.interrupt = False: resets the interrupt flag.
if 'action' in self.llm_result: checks if the result contains an action command.
result = eval(self.llm_result[...]): parses the JSON result.
if 'response' in result: checks if the result includes a response message.
msg.data = result['response']: set response text.
self.tts_text_pub.publish(msg): publishes the response text.
if 'action' in result: checks whether the result contains an action list.
action = result['action']: retrieves the action list.
if 'move' in a: checks whether it is a move action.
self.reach_goal = False: resets the “goal reached” flag.
eval(f'self.{a}'): executes the move command.
while not self.reach_goal: waits until the target is reached.
elif 'pick' in a or 'place' in a: checks whether it is a pick or place action.
eval(f'self.{a}'): executes the pick or place command.
self.transport_action_finish = False: resets the transport action completion flag.
while not self.transport_action_finish: waits until the action is completed.
Interrupt Handling if self.interrupt: checks whether the process has been interrupted.
No action response handling else: # No corresponding action found, only respond: handling process when no action is found.
Finish Handlling self.action_finish = True: marks the action as completed.
Waiting Handling else: time.sleep(0.01): short sleep.
Mode Switching if self.play_audio_finish and self.action_finish: checks if both audio playback and action execution are complete.
Shutdown Handling rclpy.shutdown(): shut down the ROS 2 system.
for a in action: iterates over the action list and execute each action.
⑬ main Method
396 397 398 399 400 401 402 403 404 | def main(): node = VLLMNavigation('vllm_navigation') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() if __name__ == "__main__": main() |
A multithreaded executor is used to handle the node’s tasks.
Call executor.spin() to start processing ROS events.
Upon shutdown, the node is properly destroyed using node.destroy_node().
