5. ROS+OpenCV Course
5.1 Color Threshold Adjustment
5.1.1 Open/Close LAB TOOL
The entered command should be case sensitive, and the “Tab” key can be used to complement key words.
Please strictly follow the operation steps; otherwise, you will fail to open LAB tool.
During the color adjustment process, all steps are executed within the ROS1 environment.
(1) Start the robot and connect it to Nomachine remote connection software.
(2) Click on
to open the ROS1 command line terminal.
(3) Input the command and press Enter to disable app auto-start service.
(4) Input the command and press Enter to enable the camera service node
Depth Camera:
Monocular Camera:
(5) Open a new command-line terminal and input the command to open LAB tool.
python3 /home/ubuntu/software/lab_tool/main.py
(6) Regarding the interface button instructions and usage, you can refer to the following content. If you want to close it, please click on Quit button.
(7) After closing the LAB TOOL, enter a command to restart the app’s auto-start service. Once the service is restarted, the robotic arm will return to its initial position.
If you do not enable app auto-start service for the robot, it will affect the corresponding app functions. Restarting robot can also automatically enable the app auto-start service.
5.1.2 LAB TOOL Interface Layout Instruction
(1) Image display area: the left displays the processed image and the right is the raw image.
If the transmitted image does not display normally, it’s the issue of camera connection. In this case, you need to examine if the wiring is connected properly or reconnect it.
(2) Recognition adjustment area: adjust the color threshold. The function of each button refer to the following table:
| Icon | Function instruction |
The sliders L, A and B are used respectively to adjust the values of the corresponding L, A and B components of the image. The sliders on the left are the "min" value for each component while the slider on the right are the "max" value for each component. |
Choose color to adjust the threshold. |
Delete the currently selected color. |
Add recognizable color. |
Save the adjustment result of the color threshold. |
Click on this button to swap Depth camera/monocular camera. |
Close LAB TOOL. |
5.1.3 Adjust Color Threshold
(1) Open LAN tool. Choose the color in the color drop-down list of color recognition area. Take a color “red” as example.
(2) Adjust the “min” values of L, A and B components to “0”, the “max” values to “225”.
(3) Place the target within the camera’s field of view. Adjust the values of L, A and B component towards the interval representing the target recognition color according to the LAB color space distribution chart.
(4) Adjust the L and B components according to your surroundings. If the red color is light, increase the “min” value of the L component; if it is dark, decrease the “max” value of the component. If the red color tends to be warm, increase the “min” value of the B component; if it tends to be cool, decrease the “max” value of the B component.
| Color component | Value Range | Corresponding Color Intervals |
| L | 0~255 | Black-white (-L~+L) |
| A | 0~255 | green-red(-a ~ +a) |
| B | 0~255 | Blue-yellow(-b ~ +b) |
(5) Click “Save” button in adjustment area to save the adjustment parameters.
5.1.4 Add New Color
(1) Open LAB tool and click on “Add” button.
(2) Fill in the “name” column with the color name, and click the “OK” button.
(3) Choose the added color in the color drop-down menu.
(4) Place the target within the camera’s field of view, and adjust the threshold by dragging the L, A, and B component sliders until the area of the colored object within the left screen turns white, while the other areas turn black.
The adjustment method of color threshold refers to “5.1.3 Adjust Color Threshold”.
(5) Click “Save” button in recognition adjustment area to save the adjustment parameters of color threshold.
After adjusting the color thresholds, press ‘Ctrl+C’ to stop the camera service, then click ‘Close Software’ to close the interface.
5.2 Color Recognition
This session will use OpenCV to perform red, green, blue recognition and display the recognition result through transmitted image. Before operations, please prepare one object of red, green and blue.
5.2.1 Recognition Process
Firstly, obtain the RGB image from the camera. Scale and apply Gaussian blur to the image. Convert the image from RGB to Lab.
Next, identify the object color in the circle by using color thresholds, followed by masking of the image portion. (masking is used to hide certain part of the processed image).
Finally, the recognition results are displayed on the screen.
5.2.2 Operation Steps
The entered command should be case sensitive and “Tab” key can be used to complement the key words.
(1) Start JetRover and connect it to Nomachine.
(2) Click on
to start the command line terminal.
(4) Run the following command to enable the camera node:
Depth camera:
Monocular Camera:
(5) Open a new command line terminal, enter the following command to navigate to the program directory and start the color recognition game:
cd ~/ros2_ws/src/example/example/color_detect && python3 color_detect_demo.py
(6) The program will launch the camera’s image interface. For detailed recognition steps, please refer to section 5.2.3 Program Outcome.
(7) Next, press “Ctrl+C” in the command line terminal interface. If closing fails, please try again repeatedly.
After the game starts, please ensure that there are no other objects containing recognized colors within the field of view of the camera to avoid affecting the implementation effect.
After the game starts, place the target object within the field of view of the camera. When recognizing the target object, it will be circled up in the same color and the color name will be printed in the lower-left corner of the screen. The program supports red, blue and green object recognition.
5.2.4 Program Analysis
The source code of the program is located in /home/ubuntu/ros2_ws/src/example/example/color_detect/color_detect_demo.py
Main Function
Initialize the ROS node, create a color recognition node named color_detect_node, subscribe to the image topic /depth_cam/rgb/image_raw, and set its callback function to image_callback. Start the main function for color recognition using multiple threads. Wait for the node to shut down.
157 158 159 160 161 162 | if __name__ == '__main__': rclpy.init() node = rclpy.create_node('color_detect_node') node.create_subscription(Image, '/depth_cam/rgb/image_raw', image_callback, 1) threading.Thread(target=main, daemon=True).start() rclpy.spin(node) |
Camera Callback Function
Primarily used to read the video stream from the topic and enqueue it to ensure real-time display.
129 130 131 132 133 134 135 136 | def image_callback(ros_image): cv_image = bridge.imgmsg_to_cv2(ros_image, "bgr8") bgr_image = np.array(cv_image, dtype=np.uint8) if image_queue.full(): # Discard the oldest image if the queue is full(如果队列已满,丢弃最旧的图像) image_queue.get() # Put the image into the queue(将图像放入队列) image_queue.put(bgr_image) |
Color Recognition Main Function
This function reads image data from the queue, processes it using the run function for color recognition, and then displays the recognized image using cv2.
138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 | def main(): running = True while running: try: image = image_queue.get(block=True, timeout=1) except queue.Empty: if not running: break else: continue image = run(image) cv2.imshow('image', image) key = cv2.waitKey(1) if key == ord('q') or key == 27: # Press q or esc to exit(按q或者esc退出) break cv2.destroyAllWindows() rclpy.shutdown() |
YAML File Reading Function
28 29 30 31 32 33 34 35 36 37 | def get_yaml_data(yaml_file): yaml_file = open(yaml_file, 'r', encoding='utf-8') file_data = yaml_file.read() yaml_file.close() data = yaml.load(file_data, Loader=yaml.FullLoader) return data lab_data = get_yaml_data("/home/ubuntu/software/lab_tool/lab_config.yaml") |
Maximum Contour Function
This function takes contours detected by OpenCV as input, identifies the largest contour based on size, and returns the contour along with its area.
39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 | # Find out the contour with the maximal area(找出面积最大的轮廓) # The parameter is the list of contour to be compared(参数为要比较的轮廓的列表) def getAreaMaxContour(contours): contour_area_temp = 0 contour_area_max = 0 area_max_contour = None for c in contours: # Iterate through all contours(历遍所有轮廓) contour_area_temp = math.fabs(cv2.contourArea(c)) # Calculate contour area(计算轮廓面积) if contour_area_temp > contour_area_max: contour_area_max = contour_area_temp if contour_area_temp > 50: # Only contours with an area greater than 50 are considered valid, and among them, the contour with the largest area is selected to filter out interference(只有在面积大于50时,最大面积的轮廓才是有效的,以过滤干扰) area_max_contour = c return area_max_contour, contour_area_max # Return the maximal contour(返回最大的轮廓) |
Color Recognition Function
This function compresses the input image to a size of (320, 240) for easier detection, applies Gaussian filtering, and then converts the image to the LAB color space.
60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 | def run(img): global draw_color global color_list global detect_color img_copy = img.copy() img_h, img_w = img.shape[:2] frame_resize = cv2.resize(img_copy, size, interpolation=cv2.INTER_NEAREST) frame_gb = cv2.GaussianBlur(frame_resize, (3, 3), 3) frame_lab = cv2.cvtColor(frame_gb, cv2.COLOR_BGR2LAB) # Convert the image to LAB space(将图像转换到LAB空间) max_area = 0 color_area_max = None areaMaxContour_max = 0 |
The function iterates through a list of colors to identify the color of the largest detected contour.
76 77 78 79 80 81 82 83 84 85 86 | for i in ['red', 'green', 'blue']: frame_mask = cv2.inRange(frame_lab, tuple(lab_data['lab']['Stereo'][i]['min']), tuple(lab_data['lab']['Stereo'][i]['max'])) #Perform bitwise operations on the original image and mask(对原图像和掩模进行位运算) eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) #Corrosion(腐蚀) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) #Dilation(膨胀) contours = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE)[-2] #Find out contour(找出轮廓) areaMaxContour, area_max = getAreaMaxContour(contours) #Find out the contour with the maximal area(找出最大轮廓) if areaMaxContour is not None: if area_max > max_area:#Find the maximal area(找最大面积) max_area = area_max color_area_max = i areaMaxContour_max = areaMaxContour |
Contours with an area smaller than 200 are filtered out. If the area is larger than 200, the function calculates the contour coordinates and draws the detected color’s position on the screen.
87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 | if max_area > 200: # The maximum area is found(有找到最大面积) ((centerX, centerY), radius) = cv2.minEnclosingCircle(areaMaxContour_max) # Get the minimum circumcircle(获取最小外接圆) centerX = int(common.val_map(centerX, 0, size[0], 0, img_w)) centerY = int(common.val_map(centerY, 0, size[1], 0, img_h)) radius = int(common.val_map(radius, 0, size[0], 0, img_w)) cv2.circle(img, (centerX, centerY), radius, range_rgb[color_area_max], 2)#Draw circle(画圆) if color_area_max == 'red': #Red is the maximal area(红色最大) color = 1 elif color_area_max == 'green': #Green is the maximal area(绿色最大) color = 2 elif color_area_max == 'blue': #Blue is the maximal area(蓝色最大) color = 3 else: color = 0 color_list.append(color) if len(color_list) == 3: #Multiple judgement(多次判断) # Take average value(取平均值) color = int(round(np.mean(np.array(color_list)))) color_list = [] if color == 1: detect_color = 'red' draw_color = range_rgb["red"] elif color == 2: detect_color = 'green' draw_color = range_rgb["green"] elif color == 3: detect_color = 'blue' draw_color = range_rgb["blue"] else: detect_color = 'None' draw_color = range_rgb["black"] else: detect_color = 'None' draw_color = range_rgb["black"] cv2.putText(img, "Color: " + detect_color, (10, img.shape[0] - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.65, draw_color, 2) return img |
5.3 Generate & Recognize QR Code
This lesson is divided into two parts. The first part will introduce you how to learn to create a QR code, while the second part focuses on recognizing the created QR code and then decoding the QR code information through the terminal.
5.3.1 Generate QR Code
Process
Finally, generate a QR CODE image based on the data and display it in a window, and save it in the corresponding path.
Operation Steps
The entered command should be case sensitive and the “Tab” key can be used to fill in key words.
(2) Click on
to start the ROS2 command line terminal.
(4) Input the command to access the program directory and start the QR code creation program.
cd ~/ros2_ws/src/example/example/qrcode && python3 qrcode_creater.py
After start the program, it’s necessary to enter characters in the terminal to generate the QR code. Take the input of “ubuntu” as example.
Press “Enter” to display a QR code image containing the input data.
(5) Next, press the “ESC” key or “q” key to exit the QR code interface.
(6) When you return to the command-line terminal and see the prompt shown in the image below, it means the QR code has been successfully saved.
(7) Click
on the taskbar on the left side of the system interface, open the file manager, and navigate to the directory highlighted in the red box in the image below. There, you’ll find the generated QR code saved to the host system.
(8) Use the NoMachine tool to drag and drop the image onto your PC desktop. From there, you can print it or transfer it to your mobile phone’s photo gallery.
The source code of this program is located at: /home/ubuntu/ros2_ws/src/example/example/qrcode/qrcode_creater.py
Creating QR Code Utility Object
Using the qrcode module to create the necessary object and setting various parameters for the QR code.
19 20 21 22 23 | qr = qrcode.QRCode( version=1, error_correction=qrcode.constants.ERROR_CORRECT_H, box_size=5, border=4) |
The parameters of the above function are as follows:
The first parameter version is an integer ranging from 1 to 40, used to control the size of the QR code. If you want the program to automatically determine the size, set this value to None and use the fit parameter.
The second parameter error_correction controls the error correction capability of the QR code, with the following options:
① ERROR_CORRECT_L: can correct approximately 7% or fewer errors.
② ERROR_CORRECT_M: default value, can correct approximately 15% or fewer errors.
③ ERROR_CORRECT_H: can correct approximately 30% or fewer errors.
The third parameter box_size controls the number of pixels contained in each small box of the QR code.
The fourth parameter border controls the number of boxes included in the border (distance between the QR code and the image boundary), with a default value of 4, which is the minimum value specified by relevant standards.
Generating QR Code
Using the add_data and make functions to retrieve and fill data, and then using the make_image function to generate the image.
24 25 26 27 28 29 30 | # Add data(添加数据) qr.add_data(data) # Fill data(填充数据) qr.make(fit=True) # Generate image(生成图片) img = qr.make_image(fill_color=(0, 0, 0), back_color=(255, 255, 255)) opencv_img = cv2.cvtColor(np.asarray(img), cv2.COLOR_RGB2BGR) |
The first parameter fill_color=(0, 0, 0) is the fill color of the image, which is black in this case.
The second parameter back_color=(255, 255, 255) is the background color of the image, which is white in this case.
Displaying Image
Converting the color space of the image using the cvtColor function, and then displaying it on the window using the imshow function.
31 32 33 34 35 | while True: cv2.imshow('img', opencv_img) k = cv2.waitKey(1) if k != -1: break |
Saving Image
Using the imwrite function to store the generated QR code image and printing relevant information.
32 33 | cv2.imwrite(file_name, opencv_img) print('save', data, file_name) |
The first parameter file_name is the storage path of the image.
The second parameter opencv_img is the image to be stored.
5.3.2 QR Code Recognition
In the previous section, we created a QR code. In this section, we’ll perform content recognition on the QR code.
Recognition Process
Firstly, create an instance object for QR code detection, and pass in the required network structure and model weight files for detection.
Then, obtain the camera’s feedback image and perform detection.
Finally, once the QR code is recognized, it will be framed, and the content of the QR code will be printed.
The source code for this program is located at: /home/ubuntu/ros2_ws/src/example/example/qrcode/qrcode_detecter.py
QR Code Recognition Steps
When entering commands, it is necessary to strictly distinguish between uppercase and lowercase letters, and you can use the “Tab” key to complete keywords.
(1) Start the robot and connect it to the remote control software NoMachine.
(2) Click on
on the system desktop to start the ROS2 command line terminal.
(3) Enter the command to disable the automatic startup service of the app:
(5) Enter the command to start the camera node:
(6) Open a new ROS2 command line terminal, enter the command to switch to the program directory, and start the QR code recognition program:
cd ~/ros2_ws/src/example/example/qrcode && python3 qrcode_detecter.py
To close this game, press “Ctrl+C” in the terminal interface. If closing fails, please try again repeatedly.
Program Outcome
After starting the game, it will recognize the QR code images appearing in the feedback screen, mark them with a red box, and print out the content of the QR code.
The source code of this program is saved in /home/ubuntu/ros2_ws/src/example/example/qrcode/qrcode_creater.py
Main Function
Initialize the QRCodeDetectNode and set the node name as qrcode_detect. Wait for the ROS node to close, and if it closes, unregister the current node.
60 61 62 63 64 65 66 67 68 69 | def main(): node = QRCodeDetectNode('qrcode_detect') try: rclpy.spin(node) except KeyboardInterrupt: node.destroy_node() rclpy.shutdown() print('shutdown') finally: print('shutdown finish') |
QRCodeDetectNode Class
Initialize the node and define parameters, then start the self.main function.
(1) Parameters:
self.running: Whether the detection is enabled
self.model_path: Model path
self.image_queue: Image queue
self.image_sub: Subscription to read camera feedback images
self.qcd: Initialization of the QR code detection
13 14 15 16 17 18 19 20 21 22 23 | class QRCodeDetectNode(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.running = True self.bridge = CvBridge() self.model_path = os.path.join(os.path.abspath(os.path.split(os.path.realpath(__file__))[0]), 'model/detector.tflite') self.image_queue = queue.Queue(maxsize=2) self.image_sub = self.create_subscription(Image, '/depth_cam/rgb/image_raw', self.image_callback, 1) self.qcd = cv2.QRCodeDetector() threading.Thread(target=self.main, daemon=True).start() |
(2) Functions:
The camera callback function reads the camera feedback image and places it in the queue self.image_queue for automatic update and discarding of expired images.
25 26 27 28 29 30 31 32 | def image_callback(self, ros_image): cv_image = self.bridge.imgmsg_to_cv2(ros_image, "bgr8") bgr_image = np.array(cv_image, dtype=np.uint8) if self.image_queue.full(): # If the queue is full, discard the oldest image(如果队列已满,丢弃最旧的图像) self.image_queue.get() # Put the image into the queue(将图像放入队列) self.image_queue.put(bgr_image) |
The main function mainly starts QR code detection. It checks whether detection is enabled based on the parameter self.running. If it is True, it reads the image data from the self.image_queue queue, inputs it into the initialized recognition model self.qcd, and finally prints the recognition content and draws the recognition box based on the output data.
34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 | def main(self): while self.running: try: image = self.image_queue.get(block=True, timeout=1) except queue.Empty: if not self.running: break else: continue ret_qr, decoded_info, points, _ = self.qcd.detectAndDecodeMulti(image) if ret_qr: for s, p in zip(decoded_info, points): if s: print(s) color = (0, 255, 0) else: color = (0, 0, 255) image = cv2.polylines(image, [p.astype(int)], True, color, 8) cv2.imshow('image', image) key = cv2.waitKey(1) if key == ord('q') or key == 27: # Press q or esc to exit(按q或者esc退出) break cv2.destroyAllWindows() rclpy.shutdown() |
5.4 Autonomous Line Following
5.4.1 Recognition Procedure
First, obtain the RGB image from the camera and resize it. Apply Gaussian blur to the image and convert the color space from RGB to Lab.
Then, perform color recognition on the objects in the circle using color thresholding. Apply masking to parts of the image. (Masking is used to globally or locally mask the processed image using selected images, graphics, or objects).
Afterward, perform opening and closing operations on the object images. Finally, outline the largest object with a circle.
Opening operation: First, erode the image and then dilate it. Purpose: Used to eliminate small objects, smooth the shape boundary, and not change its area. It can remove small grain noise and break the adhesion between objects.
Erosion: Eliminate the boundary points of the object, causing the boundary to shrink inward, and can remove objects smaller than the structural element.
Dilation: Expand the boundary points of the object, merge all background points in contact with the object into the object, and expand the boundary outward.
Finally, feedback the recognition results on the feedback screen.
5.4.2 Autonomous Line Following Operation
(2) Click on
on the system desktop to start the command line terminal.
(4) Run the command to enable the camera node
(5) Create a new command line terminal, enter the command to navigate to the program directory, and start the line-following game:
(6) Then, in the current command line terminal, enter the command to navigate to the program directory and start the line-following game:
(7) Click on the position of the line in the image to select the corresponding color of the track line, and you can start line following by color picking.
(8) If you need to close this function, you need to return to the command line terminal and enter the command to stop it.
5.4.3 Program Analysis
Launch Analysis
The program file corresponding to this section of the course document is located at: /home/ubuntu/ros2_ws/src/app/launch/line_following_node.launch.py
Read the Storage Path
14 15 16 17 18 19 | if compiled == 'True': controller_package_path = get_package_share_directory('controller') peripherals_package_path = get_package_share_directory('peripherals') else: controller_package_path = '/home/ubuntu/ros2_ws/src/driver/controller' peripherals_package_path = '/home/ubuntu/ros2_ws/src/peripherals' |
Use get_package_share_directory to obtain the package path.
Launch
20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 | line_following_node = GroupAction([ IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(peripherals_package_path, 'launch/lidar.launch.py')), condition=IfCondition(debug), ), IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(peripherals_package_path, 'launch/depth_camera.launch.py')), condition=IfCondition(debug), ), IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(controller_package_path, 'launch/controller.launch.py')), condition=IfCondition(debug), ), |
controller_launch: Start motion control launch.
depth_camera_launch: Start depth camera launch.
lidar_launch: Start lidar launch.
line_following_node: Start line following node.
39 40 41 42 43 44 45 | Node( package='app', executable='line_following', output='screen', parameters=[{'debug': debug}], ), ]) |
Source Code Analysis
The program file corresponding to this section of the course document is located at: /home/ubuntu/ros2_ws/src/app/app/line_following.py
It’s necessary to back up the original program file before making any modification to the program. You’re forbidden to modify the original source code file to avoid causing robot malfunctions that may be irreparable due to incorrect parameter modifications!
Then, the color picker object is defined (used in the gameplay to pick colors), along with the setting of additional Lidar obstacle avoidance functionality. Next is the implementation of the LineFollower class, which mainly includes functions for image preprocessing and logic for line following.
(1) Function:
① Main:
389 390 391 392 393 | def main(): node = LineFollowingNode('line_following') rclpy.spin(node) node.destroy_node() rclpy.shutdown() |
Initiate line following node.
(2) Class:
LineFollower:
27 | class LineFollower: |
28 29 30 31 32 33 34 35 | def __init__(self, color, node): self.node = node self.target_lab, self.target_rgb = color if os.environ['DEPTH_CAMERA_TYPE'] == 'Dabai': self.rois = ((0.9, 0.95, 0, 1, 0.7), (0.8, 0.85, 0, 1, 0.2), (0.7, 0.75, 0, 1, 0.1)) else: self.rois = ((0.81, 0.83, 0, 1, 0.7), (0.69, 0.71, 0, 1, 0.2), (0.57, 0.59, 0, 1, 0.1)) self.weight_sum = 1.0 |
Set the line-following color and ROI list.
get_area_max_contour:
38 39 40 41 42 43 44 45 46 47 48 49 50 | def get_area_max_contour(contours, threshold=100): ''' Get the contour of the largest area(获取最大面积对应的轮廓) :param contours: :param threshold: :return: ''' contour_area = zip(contours, tuple(map(lambda c: math.fabs(cv2.contourArea(c)), contours))) contour_area = tuple(filter(lambda c_a: c_a[1] > threshold, contour_area)) if len(contour_area) > 0: max_c_a = max(contour_area, key=lambda c_a: c_a[1]) return max_c_a return None |
Get the contour with the maximum area.
Call:
52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 | def __call__(self, image, result_image, threshold, color=None, use_color_picker=True): centroid_sum = 0 h, w = image.shape[:2] if use_color_picker: min_color = [int(self.target_lab[0] - 50 * threshold * 2), int(self.target_lab[1] - 50 * threshold), int(self.target_lab[2] - 50 * threshold)] max_color = [int(self.target_lab[0] + 50 * threshold * 2), int(self.target_lab[1] + 50 * threshold), int(self.target_lab[2] + 50 * threshold)] target_color = self.target_lab, min_color, max_color lowerb = tuple(target_color[1]) upperb = tuple(target_color[2]) else: lowerb = tuple(color['min']) upperb = tuple(color['max']) for roi in self.rois: blob = image[int(roi[0]*h):int(roi[1]*h), int(roi[2]*w):int(roi[3]*w)] # Intercept roi(截取roi) img_lab = cv2.cvtColor(blob, cv2.COLOR_RGB2LAB) # Convert rgb into lab(rgb转lab) img_blur = cv2.GaussianBlur(img_lab, (3, 3), 3) # Perform Gaussian filtering to reduce noise(高斯模糊去噪) # mask = cv2.inRange(img_blur, tuple(target_color[1]), tuple(target_color[2])) # Image binarization(二值化) mask = cv2.inRange(img_blur, lowerb, upperb) # Image binarization(二值化) eroded = cv2.erode(mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) # Corrode(腐蚀) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) # Dilate(膨胀) # cv2.imshow('section:{}:{}'.format(roi[0], roi[1]), cv2.cvtColor(dilated, cv2.COLOR_GRAY2BGR)) contours = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_TC89_L1)[-2] # Find the contour(找轮廓) max_contour_area = self.get_area_max_contour(contours, 30) # Get the contour corresponding to the largest contour(获取最大面积对应轮廓) if max_contour_area is not None: rect = cv2.minAreaRect(max_contour_area[0]) # Minimum circumscribed rectangle(最小外接矩形) box = np.intp(cv2.boxPoints(rect)) # Four corners(四个角) for j in range(4): box[j, 1] = box[j, 1] + int(roi[0]*h) cv2.drawContours(result_image, [box], -1, (0, 255, 255), 2) # Draw the rectangle composed of four points(画出四个点组成的矩形) # Acquire the diagonal points of the rectangle(获取矩形对角点) pt1_x, pt1_y = box[0, 0], box[0, 1] pt3_x, pt3_y = box[2, 0], box[2, 1] # Center point of the line(线的中心点) line_center_x, line_center_y = (pt1_x + pt3_x) / 2, (pt1_y + pt3_y) / 2 cv2.circle(result_image, (int(line_center_x), int(line_center_y)), 5, (0, 0, 255), -1) # Draw the center point(画出中心点) centroid_sum += line_center_x * roi[-1] if centroid_sum == 0: return result_image, None center_pos = centroid_sum / self.weight_sum # Calculate the center point according to the ratio(按比重计算中心点) deflection_angle = -math.atan((center_pos - (w / 2.0)) / (h / 2.0)) # 计算线角度(calculate the line angle) return result_image, deflection_angle |
Perform color recognition, identify based on the set color, and provide feedback on the recognized image and angle.
LineFollowingNode:
100 | class LineFollowingNode(Node): |
101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 | def __init__(self, name): rclpy.init() super().__init__(name, allow_undeclared_parameters=True, automatically_declare_parameters_from_overrides=True) self.name = name self.color = '' self.camera_type = 'Stereo' self.set_above = False self.set_callback = False self.is_running = False self.color_picker = None self.follower = None self.scan_angle = math.radians(45) self.pid = pid.PID(0.01, 0.0, 0.0) self.empty = 0 self.count = 0 self.stop = False self.threshold = 0.5 self.stop_threshold = 0.4 self.lock = threading.RLock() self.image_sub = None self.lidar_sub = None self.image_height = None self.image_width = None self.bridge = CvBridge() self.use_color_picker = True self.lab_data = common.get_yaml_data("/home/ubuntu/software/lab_tool/lab_config.yaml") self.image_queue = queue.Queue(2) self.lidar_type = os.environ.get('LIDAR_TYPE') self.machine_type = os.environ.get('MACHINE_TYPE') self.mecanum_pub = self.create_publisher(Twist, '/controller/cmd_vel', 1) # Chassis control(底盘控制) self.result_publisher = self.create_publisher(Image, '~/image_result', 1) # Publish the image processing result(图像处理结果发布) self.create_service(Trigger, '~/enter', self.enter_srv_callback) # Enter the game (进入玩法) self.create_service(Trigger, '~/exit', self.exit_srv_callback) # Exit the game(退出玩法) self.create_service(SetBool, '~/set_running', self.set_running_srv_callback) # Start the game(开启玩法) self.set_color_srv = self.create_service(SetString, '~/set_color', self.set_color_srv_callback) self.create_service(SetPoint, '~/set_target_color', self.set_target_color_srv_callback) # Set the color(设置颜色) self.create_service(Trigger, '~/get_target_color', self.get_target_color_srv_callback) # Get the color(获取颜色) self.create_service(SetFloat64, '~/set_threshold', self.set_threshold_srv_callback) # Set the threshold(设置阈值) self.joints_pub = self.create_publisher(ServosPosition, 'servo_controller', 1) Heart(self, self.name + '/heartbeat', 5, lambda _: self.exit_srv_callback(request=Trigger.Request(), response=Trigger.Response())) # Heartbeat package(心跳包) self.debug = self.get_parameter('debug').value if self.debug: threading.Thread(target=self.main, daemon=True).start() self.create_service(Trigger, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') |
Initialize the required parameters for the program, call the base node, camera node, and start services such as enter, exit, start, set color, get color, set threshold, etc.
get_node_state:
148 149 150 | def get_node_state(self, request, response): response.success = True return response |
Set the status of the current node.
Main:
152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 | def main(self): while True: try: image = self.image_queue.get(block=True, timeout=1) except queue.Empty: continue result = cv2.cvtColor(image, cv2.COLOR_RGB2BGR) cv2.imshow("image", cv2.resize(result, (display_size[0], display_size[1]))) if self.debug and not self.set_callback: self.set_callback = True # Set callback function for mouse clicking event(设置鼠标点击事件的回调函数) cv2.setMouseCallback("image", self.mouse_callback) k = cv2.waitKey(1) if k != -1: break if self.debug and not self.set_above: cv2.moveWindow('image', 1920 - display_size[0], 0) os.system("wmctrl -r image -b add,above") self.set_above = True self.mecanum_pub.publish(Twist()) rclpy.shutdown() |
Read the image and use the mouse to pick colors.
mouse_callback:
175 176 177 178 179 180 181 182 | def mouse_callback(self, event, x, y, flags, param): if event == cv2.EVENT_LBUTTONDOWN: self.get_logger().info("x:{} y{}".format(x, y)) msg = SetPoint.Request() if self.image_height is not None and self.image_width is not None: msg.data.x = x / self.image_width msg.data.y = y / self.image_height self.set_target_color_srv_callback(msg, SetPoint.Response()) |
Mouse color picking callback function, obtains the pixel coordinates of the current mouse position.
enter_srv_callback:
184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 | def enter_srv_callback(self, request, response): self.get_logger().info('\033[1;32m%s\033[0m' % "line following enter") with self.lock: self.color = '' self.stop = False self.is_running = False self.color_picker = None self.pid = pid.PID(1.1, 0.0, 0.0) self.follower = None self.threshold = 0.5 self.empty = 0 if self.image_sub is None: self.image_sub = self.create_subscription(Image, '/depth_cam/rgb/image_raw', self.image_callback, 1) # Subscribe to the camera(摄像头订阅) if self.lidar_sub is None: qos = QoSProfile(depth=1, reliability=QoSReliabilityPolicy.BEST_EFFORT) self.lidar_sub = self.create_subscription(LaserScan, '/scan_raw', self.lidar_callback, qos) # Subscribe to Lidar data(订阅雷达数据) set_servo_position(self.joints_pub, 1, ((10, 300), (5, 500), (4, 210), (3, 40), (2, 665), (1, 500))) self.mecanum_pub.publish(Twist()) response.success = True response.message = "enter" return response |
Enter autonomous line-following service, read data from the camera and lidar, and initialize actions.
exit_srv_callback:
206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 | def exit_srv_callback(self, request, response): self.get_logger().info('\033[1;32m%s\033[0m' % "line following exit") try: if self.image_sub is not None: self.destroy_subscription(self.image_sub) self.image_sub = None if self.lidar_sub is not None: self.destroy_subscription(self.lidar_sub) self.lidar_sub = None except Exception as e: self.get_logger().error(str(e)) with self.lock: self.is_running = False self.color_picker = None self.pid = pid.PID(0.01, 0.0, 0.0) self.follower = None self.threshold = 0.5 self.mecanum_pub.publish(Twist()) response.success = True response.message = "exit" return response |
Exit autonomous line-following service, close various reading nodes, reset PID, and stop line following.
set_target_color_srv_callback:
228 229 230 231 232 233 234 235 236 237 238 239 240 241 | def set_target_color_srv_callback(self, request, response): self.get_logger().info('\033[1;32m%s\033[0m' % "set_target_color") with self.lock: self.use_color_picker = True x, y = request.data.x, request.data.y self.follower = None if x == -1 and y == -1: self.color_picker = None else: self.color_picker = ColorPicker(request.data, 5) self.mecanum_pub.publish(Twist()) response.success = True response.message = "set_target_color" return response |
Set line-following color service.
get_target_color_srv_callback:
243 244 245 246 247 248 249 250 251 252 | def get_target_color_srv_callback(self, request, response): self.get_logger().info('\033[1;32m%s\033[0m' % "get_target_color") response.success = False response.message = "get_target_color" with self.lock: if self.follower is not None: response.success = True rgb = self.follower.target_rgb response.message = "{},{},{}".format(int(rgb[0]), int(rgb[1]), int(rgb[2])) return response |
Set up autonomous line-following gameplay.
set_threshold_srv_callback:
254 255 256 257 258 259 260 261 262 263 | def set_running_srv_callback(self, request, response): self.get_logger().info('\033[1;32m%s\033[0m' % "set_running") with self.lock: self.is_running = request.data self.empty = 0 if not self.is_running: self.mecanum_pub.publish(Twist()) response.success = True response.message = "set_running" return response |
Set color threshold service.
lidar_callback:
282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 | def lidar_callback(self, lidar_data): # Data size= scanning angle/ the increased angle per scan(数据大小 = 扫描角度/每扫描一次增加的角度) if self.lidar_type != 'G4': min_index = int(math.radians(MAX_SCAN_ANGLE / 2.0) / lidar_data.angle_increment) max_index = int(math.radians(MAX_SCAN_ANGLE / 2.0) / lidar_data.angle_increment) left_ranges = lidar_data.ranges[:max_index] # Left data(左半边数据) right_ranges = lidar_data.ranges[::-1][:max_index] # Right data(右半边数据) elif self.lidar_type == 'G4': min_index = int(math.radians((360 - MAX_SCAN_ANGLE) / 2.0) / lidar_data.angle_increment) max_index = int(math.radians(180) / lidar_data.angle_increment) left_ranges = lidar_data.ranges[min_index:max_index][::-1] # Left data(左半边数据) right_ranges = lidar_data.ranges[::-1][min_index:max_index][::-1] # The right data(右半边数据) # Get data according to settings(根据设定取数据) angle = self.scan_angle / 2 angle_index = int(angle / lidar_data.angle_increment + 0.50) left_range, right_range = np.array(left_ranges[:angle_index]), np.array(right_ranges[:angle_index]) left_nonzero = left_range.nonzero() right_nonzero = right_range.nonzero() left_nonan = np.isfinite(left_range[left_nonzero]) right_nonan = np.isfinite(right_range[right_nonzero]) # Take the nearest distance left and right(取左右最近的距离) min_dist_left_ = left_range[left_nonzero][left_nonan] min_dist_right_ = right_range[right_nonzero][right_nonan] if len(min_dist_left_) > 0 and len(min_dist_right_) > 0: min_dist_left = min_dist_left_.min() min_dist_right = min_dist_right_.min() if min_dist_left < self.stop_threshold or min_dist_right < self.stop_threshold: self.stop = True else: self.count += 1 if self.count > 5: self.count = 0 self.stop = False |
Lidar callback function, reorganizes and collates the data read, and determines whether to stop moving forward.
image_callback:
318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 | def image_callback(self, ros_image): cv_image = self.bridge.imgmsg_to_cv2(ros_image, "rgb8") rgb_image = np.array(cv_image, dtype=np.uint8) self.image_height, self.image_width = rgb_image.shape[:2] result_image = np.copy(rgb_image) # The image used to display the result(显示结果用的画面) with self.lock: if self.use_color_picker: # Color picker and line recognition are exclusive. If there is color picker, start picking(颜色拾取器和识别巡线互斥, 如果拾取器存在就开始拾取) if self.color_picker is not None: # 拾取器存在(color picker exists) try: target_color, result_image = self.color_picker(rgb_image, result_image) if target_color is not None: self.color_picker = None self.follower = LineFollower(target_color, self) self.get_logger().info("target color: {}".format(target_color)) except Exception as e: self.get_logger().error(str(e)) else: twist = Twist() twist.linear.x = 0.15 if self.follower is not None: try: result_image, deflection_angle = self.follower(rgb_image, result_image, self.threshold) if deflection_angle is not None and self.is_running and not self.stop: self.pid.update(deflection_angle) if self.machine_type == 'JetRover_Acker': steering_angle = common.set_range(-self.pid.output, -math.radians(150/1000*240), math.radians(150/1000*240)) if steering_angle != 0: R = 0.213/math.tan(steering_angle) twist.angular.z = twist.linear.x/R else: twist.angular.z = common.set_range(-self.pid.output, -1.0, 1.0) self.mecanum_pub.publish(twist) elif self.stop: self.mecanum_pub.publish(Twist()) else: self.pid.clear() except Exception as e: self.get_logger().error(str(e)) else: twist = Twist() if self.color in common.range_rgb: twist.linear.x = 0.15 self.follower = LineFollower([None, common.range_rgb[self.color]], self) result_image, deflection_angle = self.follower(rgb_image, result_image, self.threshold, self.lab_data['lab'][self.camera_type][self.color], False) if deflection_angle is not None and self.is_running and not self.stop: self.pid.update(deflection_angle) if self.machine_type == 'JetRover_Acker': steering_angle = common.set_range(-self.pid.output, -math.radians(150/1000*240), math.radians(150/1000*240)) if steering_angle != 0: R = 0.213/math.tan(steering_angle) twist.angular.z = twist.linear.x/R else: twist.angular.z = common.set_range(-self.pid.output, -1.0, 1.0) self.mecanum_pub.publish(twist) elif self.stop: self.mecanum_pub.publish(Twist()) else: self.pid.clear() else: self.mecanum_pub.publish(twist) if self.debug: if self.image_queue.full(): # If the queue is full, discard the oldest image(如果队列已满,丢弃最旧的图像) self.image_queue.get() # Put the image into the queue(将图像放入队列) self.image_queue.put(result_image) else: self.result_publisher.publish(self.bridge.cv2_to_imgmsg(result_image, "rgb8")) |
Camera callback function, invokes the color picker based on the read data, and moves the robot according to the recognized line using PID control.
