14. Large AI Model Course
14.1 Voice Module Overview and Installation
14.1.1 Introduction to WonderEcho Pro
  • Introduction
WonderEcho Pro, also known as the AI Voice Interaction Box, is equipped with a high-performance noise-canceling microphone and a high-fidelity speaker. Featuring a USB-to-audio module, it offers plug-and-play functionality without the need for drivers and is compatible with multiple systems for both playback and recording.
This device integrates various speech processing modules and uses advanced noise suppression algorithms to effectively filter out background noise, supporting a seamless process from wake-up to speech recognition and interaction. With its modular design, each functional component—such as wake-up, detection, recognition, and synthesis—can be developed and tested independently.
  • Features & Parameters
(1) The device is equipped with an onboard microphone and speaker interface, supporting both audio input and output.
(2) It is driver-free, offering seamless plug-and-play functionality with broad system compatibility, including Windows, macOS, Linux, and Android. The “listen/speak” dual function ensures versatility across various platforms.
(3) It uses a standard USB 2.0 interface.
(4) Control Interface: USB
(5) Voice Chip Model: CI1302
(6) Speaker Output: 3.0W per channel (4Ω BTL)
(7) Power Supply Voltage: 5V
  • Recording and Playback Test
The following steps demonstrate the process using the Raspberry Pi 5, but the connection and testing procedures are equally applicable to other compatible devices, such as Jetson:
(1) Connection Diagram and Testing
For Raspberry Pi, you can establish a remote connection to the system using VNC by following the 2. Set Development Environment -> 2.1 VNC Installation and Connection guide. Once connected, check the top-right corner of the desktop for the microphone and speaker icons, as shown below. If they are present, the connection has been successfully established.
For Jetson-based systems, you can use the Nomachine remote connection tool. Once connected, verify the presence of the speaker icon in the top-right corner of the system.
(2) Recording Test
① Next, open a new command-line terminal and enter the following command to check for the use of the -l (lowercase L) option, and verify that the card number (card) is 0. This is just an example; please ensure to check your actual query results.
arecord -l
② Then, use the following command to start recording, replacing the highlighted card number (in red) with the one obtained from the previous query:
③ A “test.wav” file will be generated in the current folder.
④ You can record for about 5 seconds, then press “Ctrl+C” to stop the recording.
(3) Playback Test
① After completing the recording, you can check if the file was successfully recorded by running the following command in the current directory:
② If “test.wav” appears, the recording was successful. To play the recorded file, use the command below, ensuring you replace the card number with the one obtained from your previous query:
aplay test.wav
14.1.2 WonderEcho Pro Installation
When installing the WonderEcho Pro, make sure the robot’s front faces forward and the WonderEchoPro’s USB port is oriented to the left—aligned with the Raspberry Pi’s USB ports.
14.1.3 Firmware Flashing Method
In this lesson, we will learn how to flash firmware onto the WonderEcho Pro.
  • Flashing the Firmware
(1) Begin by connecting the WonderEcho Pro to your computer using a Type-C data cable.
(2) Open the file “PACK_UPDATE_TOOL.exe” located in Appendix->Firmware Flashing Tool. Select the “CI1302” chip and click “Firmware Upgrade”.
For this example, we will use the “hello hiwonder firmware” (Wake word: “hello hiwonder”).
(3) Select the firmware by locating the “hello hiwonder firmware (Wake word: hello hiwonder).bin” file under the Appendix path.
(4) Identify the correct COM port and select it.
(5) Press the RST button on the WonderEcho Pro to initiate the flashing process. Wait for the process to complete successfully.
  • Testing the Wake Word
After flashing the firmware, follow the steps in Appendix->Serial Port Debugging Tool to install the serial port debugging tool. Then, follow the steps below to test whether the firmware is functioning correctly.
(1) Connect the WonderEcho Pro to your computer’s USB port using a Type-C to USB adapter.
(2) Open the Serial Port Utility, select the connected COM port (including CH340), and set the baud rate to 115200, as shown in the image below.
(3) Say the wake word “hello hiwonder” as configured in the firmware settings. The corresponding flag information will appear on the right side (in hexadecimal format), confirming that the wake word was successfully recognized.
14.1.4 WonderEcho Pro Firmware Development
In this lesson, you’ll learn how to create and flash firmware for the WonderEcho Pro module.
  • Firmware Creation and Flashing
We’ll use “HIWONDER” as an example to demonstrate the firmware creation process. The same procedure also applies to creating firmware with Chinese wake words. Note: English wake words must be entered in all uppercase letters to function properly.
(1) Open the official firmware creation website: https://aiplatform.chipintelli.com/home/index.html; The platform interface is in Chinese. If needed, use your browser’s translation feature to switch to English for easier navigation.
(2) First, visit the ChipIntelli Voice AI Platform by clicking on “Platform Features” in the top menu, and then select “In-depth development of Product Firmware & SDK” under the Product Development section.
(3) You will be prompted to log in.
Currently, registration is only available for mainland China mobile numbers. For international users, we provide a shared account:
Username: 18033085495
Password: hiwonder
After successfully logging in, click “In-depth development of Product Firmware & SDK” again to access the development section.
(4) To create a new product, click the option in the left sidebar. You will be asked to provide a “Product Name” and a “Description”, both of which can be customized. For the other fields, follow the options shown in the red box. Specifically, choose Product Type: 通用 (General) → 智能中控 (Smart Central Control). After completing these steps, click Create.
(5) Next, you will need to set the project language. Since we are configuring for English voice recognition, select English under Language Type. If you were configuring for Chinese recognition, you would select Chinese for both Voice Type and Acoustic Model. Once you’ve selected the appropriate options, click Continue to proceed.
(6) In the firmware configuration interface, you will make some important changes to the settings. Start by enabling the “Echo Cancellation” feature under Algorithm Settings.
(7) Under Hardware Settings, set the oscillator source to Internal RC and disable the Baud Rate Calibration function.
(8) In the UART Print Settings, configure UART1 to Open-Drain Mode, supporting external 5V pull-up.
(9) For Communication UART Settings, set the Baud Rate to 115200 and configure UART0 to Open-Drain Mode, also supporting external 5V pull-up. After adjusting these settings, click Continue to move forward.
(10) The next step involves configuring the command words. You will need to choose a voice output for the wake-up command. For this example, select “Dane – English Male Voice” as the output voice. (If you’re using Chinese as the language, you may choose the voice option “Chengcheng – Standard Boy Ver.1”. The selection between Chinese and English voices is determined by the language settings configured in Step 5.)
(11) Next, upload the command word attachment by locating the file named ‘(hello hiwonder) Command Word Broadcast Protocol List V3_English Template’ and dragging it directly onto the webpage.
If you wish to change the wake word, open the spreadsheet and replace the default wake word HIWONDER with your preferred word. Keep in mind that the English version of the firmware only supports English wake words, and mixed-language wake words are not allowed. Additionally, English wake words must be written in uppercase letters to function properly.
(12) After uploading the file, you will see the command data populated in the table below.
(13) Click “Submit” and wait a few minutes for the firmware generation process to complete. Once finished, click “Download” to obtain your customized firmware.
14.2 Large Models Basic Courses
14.2.1 Large Language Model Courses
(1) Basic Concept
(2) Features
(3) Working Principle
(4) Application Scenarios
① Text Generation
② Text Classification
③ Machine Translation
④ Question-Answering Systems
To proceed with this section, you will need to register on the appropriate website and obtain the API key for the large model (please refer to the file 14.2.1 Large Language Model Courses -> Large Language Model Deployment).
(1) Environment Configuration
sudo apt install vim
sudo apt install gedit
sudo apt install python3 python3-pip python3-all-dev python3-pyaudio portaudio19-dev libsndfile1
cd ~/large_models/speech_pkg/
jetson_nano 3.6
jetson_orin 3.10
rpi5 3.11
rpi5_docker 3.8
cd jetson_orin/
cp -r speech.so ..
cd ../..
pip3 install .
pip3 install openai -U
(3) Key Configuration
cd ~/large_models
vim config.py
③ Once the file is open, configure the OpenAI and OpenRouter keys by filling in the llm_api_key and vllm_api_key parameters, respectively (you can obtain these keys from the ‘14.2.1 Large Language Model Courses -> Large Language Model Deployment’ course).
(4) Running the Demo Program
python3 openai_llm_demo.py
Before starting this section, make sure you have completed the API key configuration outlined in the file 14.2.1 Large Language Model Courses -> Large Language Model Accessing.
cd large_models/
To proceed with this section, ensure that you have completed the API key configuration as described in the file 14.2.1 Language Model Courses -> Large Language Model Accessing.
cd large_models/
python3 openai_llm_er_demo.py
14.2.2 Large Speech Model Courses
Their advantages include:
① Processing Methods
② Model Complexity
③ Recognition Capability
④Training Data Requirements
② Text-to-Speech (TTS)
(1) Device Overview
① 6-Microphone Circular Array
Introduction:
Features and Specifications:
② Recording Test
arecord -l
③ Playback Test
aplay test.wav
  • Voice Wake-Up
(1) WonderEcho Pro Wake-Up
Device Check:
To proceed, we need to identify the USB device name assigned to the connected WonderEcho Pro or Circular Microphone Array (hereafter referred to as the voice device). Please follow the steps below carefully.
ll /dev | grep USB
ll /dev | grep USB
Wake-Up Test:
vim wakeup_demo.py
Device Check:
Wake-Up Test:
② Press i to enter edit mode.
③ Update the port to match the device port number you previously identified. Comment out the WonderEcho Pro configuration (add # at the beginning of the corresponding line), and uncomment the line using the circular microphone array on line 11 as the input device (see red box in the referenced image).
(3) Brief Program Overview
Importing Required Modules
from speech import awake
port = '/dev/ttyUSB0'
try:  # If a fan is present, it's recommended to turn it off before detection to reduce interference(如果有风扇,检测前推荐关掉减少干扰)
except:
Main Wake Word Detection Loop
print('start...')
Main Program Logic
            print('hello hiwonder')
        time.sleep(0.02)
        except:
(4) Extended Functionality
vim wakeup_demo.py
i
python3 wakeup_demo.py
  • Speech Recognition
(2) How It Works
Before proceeding, refer to the course “14.1.2 Large Speech Model Courses -> Large Language Models Deployment” to obtain your API key, and make sure to add it into the configuration file (config).
(4) Experiment Steps
cd large_models/
vim config.py
python3 openai_asr_demo.py
(5) Function Realization
(6) Brief Program Analysis
① Module Import
from speech import speech
② Define ASR Class
(7) Function Extension
vim openai_asr_demo.py
i
  • Speech Synthesis
(1) What is Speech Synthesis?
(2) How It Works
Refer to the course “14.2.1 Large Language Models Courses -> Large Language Models Deployment” to obtain your API key, and update the configuration file accordingly.
cd large_models/
vim config.py
python3 openai_tts_demo.py
① Module Import
from config import *
② Definition for TTS Class
③ Function Extension
vim openai_tts_demo.py
i
  • Voice Interaction
(2) How It Works
(3) Experiment Steps
① Power on the device and connect to it via MobaXterm (refer to Appendix “Remote Connection Tools and Instructions” for connection guidance).
ll /dev | grep USB
cd large_models/
vim config.py
⑥ Run the program:
(4) Function Realization
(5) Brief Program Analysis
(1) Module Import
(3) Main Functional Logic
    kws.start()
                if asr_result:
                    tts.tts(response)
            time.sleep(0.02)
            kws.exit()
            except:
        except BaseException as e:
            print(e)
14.2.3 Vision Language Model Courses
(1) Basic Concept
(2) Features
(3) How It Works
① Image Captioning
② Visual Question Answering
③ Image Retrieval
④ Augmented Reality (AR)
⑥ Social Media Interaction
⑦ Medical Imaging Analysis
  • This section requires the configuration of the API key in “14.2.3 Vision Language Model Accessing -> Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
(1) Experiment Steps
cd large_models/
Run the program:
(2) Function Realization
  • This section requires the configuration of the API key in “14.2.3 Vision Language Module Courses -> Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
cd large_models/
② Run the program:
(3) Function Expansion
Change Pictures:
② Then, input the command:
i
To: image = cv2.imread('./resources/pictures/apples.png')
cd large_models/
② Run the program:
④ Run the program:
cd large_models/
② Run the program:
python3 openai_vllm_ocr.py
Change Pictures:
i
⑤ Run the program:
14.2.4 Multimodal Model Basic Courses
(1) Basic Concept
(2) Features
(3) How It Works
① Education
② Healthcare
③ Entertainment
④ Advertising and Marketing
ll /dev | grep USB
cd large_models/
vim config.py
vim openai_agent_demo.py
⑤ Run the program:
python3 openai_agent_demo.py
14.3 Multimodal Large Model Applications
14.3.1 Obtaining and Configuring the Large Model API Key
  • OpenAI Account Registration and Setup
(1) Registration
① Visit the following link to access the OpenAI platform : https://platform.openai.com/docs/overview
② You can register using your Google, Microsoft, or Apple account as prompted.
③ Once registered, click on the Settings icon, navigate to Billing, and then select Payment Methods to add a payment option. This is required to purchase tokens.
④ After setting up your billing information, go to the API Keys section, click Create New Secret Key, and follow the on-screen instructions. Be sure to save the key for future use.
With these steps completed, you’ve successfully created and deployed your large model API key, which will be used in the upcoming course sessions.
(2) Deploying the API Key
The configuration file of this program is saved in: /home/ubuntu/ros2_ws/src/large_models/large_models/large_models/config.py
① Use the following command and press Enter to navigate to the directory containing the configuration file:
cd /home/ubuntu/ros2_ws/src/large_models/large_models
② Enter the following command to open the configuration file and insert the OpenAI key:
gedit config.py
  • OpenRouter API Configuration
(1) Visit the following link to access the OpenAI platform: https://openrouter.ai/
Click on “Login” and use your Google account or another supported account to register or log in.
(2) After logging in, click on the icon in the top-right corner, select “Credits” and link your payment method.
(3) To create an API key: Navigate to “API Keys” and click “Create Key”. Then follow the prompts to generate your API key, and make sure to save it for future use.
(4) Use the following command and press Enter to navigate to the directory containing the configuration file:
(5) Open the configuration file using the following command, then paste your OpenRouter API key into it:
gedit config.py
14.3.2 Multimodal Large Model: Voice Control
  • Brief Game Instructions
When the program starts, WonderEcho Pro announces “I am ready” and immediately begins monitoring the surrounding environment for sounds.
Say the wake-up word (the wake-up word depends on the firmware flashed, and by default, the wake-up word for our factory firmware is “Hello, Hiwonder”) to activate WonderEcho Pro. It will respond with “I am here”.
You can then control the MentorPi car using voice commands—for example, “Move forward for 2 seconds, then rotate clockwise”. The car converts your spoken commands into text via the large model’s API and processes them accordingly. After processing, the large model’s response is played back aloud, and the corresponding action is executed.
(1) Verifying the WonderEcho Pro Firmware
By default, the wake-up word for the WonderEcho Pro factory firmware is “Hello, Hiwonder”. If you wish to change the wake-up word to “MentorPi”, please refer to the tutorial titled “14.1.3 Firmware Flashing Method” for step-by-step instructions.
If you have previously flashed the device with different firmware—such as the version with the wake word “小幻小幻” or “mentorpi”—you must use the corresponding wake word to activate the device.
For example, if the “小幻小幻” firmware was installed, the correct wake word would be “小幻小幻”; if the “mentorpi” firmware was installed, the wake word would be “mentorpi”.
In the following tutorial, we will use the default factory wake word “Hello, HiWonder” for demonstration purposes.
(2) Obtaining and Configuring the Large Model API Key
By default, the program does not include the configuration of the Large AI Model-related API keys. Before activating features related to the Large AI Model, please refer to the 14.3.1 Obtaining and Configuring Large Model API Keys to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
(3) Network Configuration
The large language model used in this lesson is cloud-based. Before starting, please connect the robot to the internet using an Ethernet cable or switch it to local area network (LAN) mode.
The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet. For detailed instructions on network configuration, please refer to the course 13.Robot Network Configuration>13.1 Network Configuration Instructions.
  • Starting and Stopping the Game
  • The input commands must strictly observe case sensitivity and spacing.
  • The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet.
(1) Start the robot and follow the instructions in 2. Remote Tool Installation Connection → 2.4 Docker Introduction & Usage to connect via the VNC remote desktop software. Then, switch to the ROS2 environment and select the appropriate language version as needed.
(2) On the Raspberry Pi desktop, double-click to open the command-line terminal and enter the ROS2 development environment.
(3) Then, input the command to disable the auto-start service:
(4) Then, input the command to start the game:
ros2 launch large_models llm_control_move.launch.py
(5) Once the command line outputs the message below and the device announces “I am ready”, it indicates that the voice device has been initialized. You can now say the wake word, “hello hi wonder”.
(6) When the following output appears in the command line, WonderEcho Pro will announce “I am Here”, indicating that WonderEcho Pro has been successfully activated. At this point, the system will begin recording the user’s command.
(7) You can freely phrase your commands to control the movement of MentorPi, such as saying, “Move forward for 2 seconds, then rotate clockwise”.
(8) When the command line shows the output below, it indicates that the cloud-based large speech model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under “publish_asr_result”.
(9) When the terminal displays the following output, it means the Raspberry Pi has successfully accessed the cloud-based large language model, processed the user’s command, generated a spoken response, and created a corresponding action group based on the command’s intent.
At this point, the robot will execute the actions outlined in the “action” sequence.
The response is automatically generated by the large model, ensuring the accuracy of the meaning, though the wording and structure of the reply may vary.
(10) When the following output appears in the terminal, it indicates that the Raspberry Pi has successfully called the cloud-based voice synthesis service. WonderEcho Pro will then play the audio generated from the “response” in step 9.
(11) Once this output appears, it means the current round of interaction has concluded. You can then say the wake word again to re-activate WonderEcho Pro and begin a new round of dialogue.
(12) To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
  • How It Works
Once the activity starts, you can freely use voice commands to control the MentorPi car to perform actions such as moving forward or backward, and turning left or right—either individually or in sequence. (For the mecanum wheel version, it can also perform lateral movements as well as clockwise and counterclockwise rotations.)
For the rules governing text responses and action design by the large model, please refer to the prompt settings within the program. Detailed instructions can be found in the PROMPT section of /home/ubuntu/ros2_ws/src/large_models/large_models/function_call.py
The actions available in this mode are predefined within the program library and are limited in number. MentorPi’s movements are controlled by calling functions that correspond to action strings designed by the large model. If a command involves an action that is not predefined, the program will be unable to execute it; however, the large model will still recognize the command and provide a response.
  • Brief Program Analysis
The launch file is saved in: /home/ubuntu/ros2_ws/src/large_models/launch/llm_control_move.launch.py
    mode = LaunchConfiguration('mode', default=1)
    mode_arg = DeclareLaunchArgument('mode', default_value=mode)
    machine_type = EnvironmentVariable('MACHINE_TYPE', default_value='default_machine')
    log_machine_type = ExecuteProcess(
        cmd=['echo', 'MACHINE_TYPE is set to: ', machine_type],
        shell=True
    large_models_package_path = get_package_share_directory('large_models')
Read the Chassis Type
Send the corresponding prompt to the large model based on the selected underlying platform.
Motion Control
The controller starts the motion control node, which manages the motors, servos, buzzer, and other components on the expansion board.
Large Model Control Node
The start command launches the large model control node, enabling functions such as speech detection, semantic understanding, task execution, and response playback.
  • Main Control Program Analysis
The source code is located at: /home/ubuntu/ros2_ws/src/large_models/large_models/llm_control_move.py
# encoding: utf-8
# @Author: Aiden
# @Date: 2025/03/06
import json
from std_msgs.msg import String, Bool
from std_srvs.srv import Trigger, SetBool, Empty
from large_models.config import *
from large_models_msgs.srv import SetModel, SetString, SetInt32
from ros_robot_controller_msgs.msg import SetPWMServoState, PWMServoState
Determine whether the input is in Chinese and if the chassis is a mecanum wheel type.
	if os.environ["ASR_LANGUAGE"] == 'Chinese':
    if os.environ["MACHINE_TYPE"] == 'MentorPi_Mecanum':
(1) Library Files Import
The program imports the following modules and libraries to enable functionalities such as ROS2 node creation, message publishing, service calls, threading, and audio playback:
(2) Creates and initializes the ROS2 node
It initializes the ROS2 environment by calling rclpy.init() and creates a node instance by inheriting from the Node class.
	class LLMControlMove(Node):
(3) Initializing Variables
Define the following variables:
action: list of actions
llm_result: string containing the response from the large language model
running: flag indicating the running status
result: parsed result data
	    self.action = []
        self.llm_result = ''
        self.interrupt = False
        self.action_finish = False
(4) Publisher and Subscriber Initialization
tts_text_pub: This publisher publishes text messages to the tts_node/tts_text topic. Sending text to the speech synthesis module: This allows the robot to provide voice feedback to the user.
mecanum_pub: This publisher sends Twist messages to the /controller/cmd_vel topic. The Twist message includes the robot’s linear velocities (x, y) and angular velocity (z) to control its movement.
servo_state_pub: This publisher sends SetPWMServoState messages to the ros_robot_controller/pwm_servo/set_state topic to control the servo motor states.
llm_result_callback: Subscribes to the agent_process/result topic, which contains commands generated by the Large Language Model (LLM).
play_audio_finish_callback: Subscribes to the tts_node/play_finish topic, which notifies the program when voice playback is complete.
(5) Process Action (Process)
Upon receiving a command from the LLM, the script parses the JSON data to identify the action to be performed, such as moving forward or rotating.
	    def process(self):
        machine_type = os.environ.get("MACHINE_TYPE", "")
            if self.llm_result:
                msg = String()
                if 'action' in self.llm_result:  # f a corresponding action is returned, extract and handle it(如果有对应的行为返回那么就提取处理)
                    action_list = []
                    if 'action' in result:
                    if 'response' in result:
                        response = result['response']
                    msg.data = response
14.3.3 Multimodal Large Model: Autonomous Cruise
Once the program starts running and WonderEcho Pro announces “I am ready”.
Say the wake-up word (the wake-up word depends on the firmware flashed, and by default, the wake-up word for our factory firmware is “Hello, HiWonder”) to activate WonderEcho Pro. It will respond with “I am here”.
You can control MentorPi’s line-following function using voice commands, such as “Go along the black line.” MentorPi converts the spoken command to text via the large model’s ASR API, processes it through the large model, After processing, the large model’s TTS system vocalizes the generated response, and the corresponding line-following program is executed.
By default, the wake-up word for the WonderEcho Pro factory firmware is “Hello, Hiwonder”. If you wish to change the wake-up word to “MentorPi”, please refer to the tutorial titled “Firmware Flashing Method” for step-by-step instructions.
In the following tutorial, we will use the default factory wake word “Hello, Hiwonder” for demonstration purposes.
  • Obtaining and Configuring the Large Model API Key
  • Network Configuration
The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet. For detailed instructions on network configuration, please refer to the course 13. Robot Network Configuration->13.1 Network Configuration Instructions
(1) Start the robot and follow the instructions in 2. Set Development Environment → 2.4 Docker Introduction & Usage to connect via the VNC remote desktop software. Then, switch to the ROS2 environment and select the appropriate language version as needed.
ros2 launch large_models llm_visual_patrol.launch.py
(5) When the command line shows the output below, initialization is complete. You can then say the wake-up phrase, “mentorpi”.
(7) You can freely express your commands to control MentorPi’s movements—for example, “Go along the black line”.
(9) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (”response”), as well as designed an action that aligns with the user’s command meaning.
At this point, the robot sends client requests to the “Autonomous Cruise” node to set the color and start the game.
Once the Autonomous Cruise mode is activated, the program will continue running this function. To stop it, press Ctrl+C in the terminal.
(11) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 5) to reactivate the voice device using the wake-up word and begin a new round of interaction.
  • How It Works
Once the game begins, you can freely give commands like “Go along the black line” to control the MentorPi’s autonomous line-following. In this mode, the MentorPi will follow the black line. If it fails to detect the black line for more than 5 seconds or if the system is reawakened, the autonomous cruising task will end, and the system will return to the wake-up state.
For the rules governing text responses and action design by the large model, please refer to the prompt settings within the program. Detailed instructions can be found in the PROMPT section of /home/ubuntu/ros2_ws/src/large_models/large_models/llm_visual_patrol.py
    The launch file for this program is located at:
    The launch file is saved in: /home/ubuntu/ros2_ws/src/large_models/launch/llm_visual_patrol.launch.py
                'debug': 'true',
            package='large_models',
(1) Line Following Control
The line_following_node launches the line-following module.
(2) Large Model Control Node
    The source code is located at: /home/ubuntu/ros2_ws/src/large_models/large_models/llm_visual_patrol.py
    import re
    import ast
    from large_models_msgs.srv import SetModel,SetString
    from ros_robot_controller_msgs.msg import RGBState,RGBStates, SetPWMServoState, PWMServoState
	class FunctionCall(Node):
	    self.action = []
        self.result = ''
        self.sonar_rgb_pub = self.create_publisher(RGBStates, 'sonar_controller/set_rgb', 10)
        self.rgb_pub = self.create_publisher(RGBStates, 'ros_robot_controller/set_rgb', 10)
(5) Determine whether the input is in Chinese
    PROMPT = '''
(6) Send Prompt
The PROMPT variable defines the prompt sent to the LLM. The LLM parses user input and generates JSON-formatted output containing actions and responses.
# Role
You are an intelligent vision Mecanum wheel car that needs to generate corresponding JSON instructions based on input commands.
## Requirements and Constraints
1. Based on the input action description, find the corresponding command in the action function library and output the matching instruction.
2. Craft a concise (10-30 words), witty and varied feedback message for each action sequence to make the interaction more engaging.
3. Output only the JSON result directly - no analysis or extra content.
4. Format: {'action':['xx', "xx"], 'response':'xx'}
## Structure Requirements:
- The `"action"` key contains an array of function name strings in execution order. Output [] when no matching action is found.
- The `"response"` key contains a carefully crafted short reply that perfectly matches the word count and style requirements.
### Task Examples:
Input: Follow the black line forward...
Output: {"action":["line_following('black')"],"response":"Tracking black line, smooth sailing ahead!"}
Input: Follow the red line at your feet, march forward bravely.
Output: {"action":["line_following('red')"], "response":"Red line tracking activated, walking the red carpet like a star!"}
(7) init_process Method
① Sets the LLM prompt (PROMPT) and stops the mecanum wheeled robot. Play the Startup Audio. Launches a new thread to run the process method. Creates a ROS 2 service ~/init_finish to signal node initialization completion.
② Iterates through the action list, invoking corresponding ROS 2 services based on each action type.
③ For the “line_following” action, extracts color information and calls the related service to start line tracking.
④ After completing all actions, resets the interrupt flag, clears the llm_result variable, and re-enables voice wake-up.
        msg = SetString.Request()
        msg.data = PROMPT
        self.set_prompt_client.call_async(msg)
        #self.send_request(self.set_prompt_client, msg)
(8) Main Function
Main Function Execution
    node = FunctionCall('function_call')
        rclpy.spin(node)
        print('shutdown')
    main()
  • Large Model Line-Following Logic Analysis
(1) Large Model Interaction Logic Analysis
The configuration file of this program is saved in: /home/ubuntu/ros2_ws/src/app/app/line_following.py
Used to receive target color information from the large model. The large model sends the target color name to this node by calling the ~/set_large_model_target_color service.
291
292
294
295
296
297
298
299
300
301
302
303
        with self.lock:
            self.follower = None
            if x == -1 and y == -1:
                self.color_picker = None
(2) Image_callback Callback Function
① Target Loss Detection When deflection_angle is None, it means the target line is not detected. The follower.lost_target_count counter is incremented. If large_model_tracking is True and the lost count exceeds a predefined threshold, the target is considered lost, triggering a timer to stop the robot after a delay.
② Target Reacquisition Detection When deflection_angle is not None, the target line has been reacquired. The follower.lost_target_count counter is reset, and any active target loss timer is canceled.
③ Motion Control Robot movement is adjusted based on the PID controller output only when deflection_angle is valid, is_running is True, and no obstacles are detected.
(3) Automatic Stop Mechanism
① The start_stop_timer method creates a timer that calls the stop_after_lose method after 5 seconds.
② The stop_after_lose method stops the robot’s movement and sets the is_running flag to False, thereby stopping the line-following process.
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
    def start_stop_timer(self):
        """启动5秒停止计时器"""
        if self.target_lost_timer is None:
            self.target_lost_timer = threading.Timer(5.0, self.stop_after_lose)
            self.target_lost_timer.start()
            self.target_lost = True
            self.get_logger().warn("5秒计时器已启动")
    def stop_after_lose(self):
        """Handling after target is lost for more than 5 seconds(目标丢失超过5秒后的处理)s"""
        with self.lock:
            if self.large_model_tracking:
                self.get_logger().warn("目标丢失超过5秒,停止移动")
                self.is_running = False
                self.target_lost_timer = None
                self.target_lost = False
(4) Wake-up Stop
Upon detecting a voice wake-up signal, the robot will stop only if large_model_tracking is set to True. This ensures that the stop command triggered by the voice wake-up signal is executed solely when line-following is active under the large model’s control.
499
500
501
502
503
504
505
506
507
508
509
510
511
512
        """Callback function for the /vocal_detect/wakeup topic."""
        if msg.data:
            self.get_logger().info("Wake-up detected, exiting large model tracking.")
            with self.lock:
                    self.large_model_tracking = False
                    self.mecanum_pub.publish(Twist())  # Stop the robot
                    if self.target_lost_timer is not None:
                        self.target_lost_timer.cancel()
                    self.get_logger().info("Large model tracking stopped.")
14.3.4 Multimodal Large Model: Color Tracking
You can control MentorPi’s color tracking function using voice commands, such as “Track the red blocks”. MentorPi converts the spoken command to text via the large model’s ASR API, processes it through the large model, After processing, the large model’s API system vocalizes the generated response, and the corresponding line-following program is executed.
By default, the wake-up word for the WonderEcho Pro factory firmware is “Hello, Hiwonder”. If you wish to change the wake-up word to “MentorPi”, please refer to the tutorial titled 14.1.3 Firmware Flashing Method for step-by-step instructions.
By default, the program does not include the configuration of the Large AI Model-related API keys. Before activating features related to the Large AI Model, please refer to the section 14.3.1 Obtaining and Configuring Large Model API Keys to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet. For detailed instructions on network configuration, please refer to the course 13. Robot Network Configuration -> 13.1 Network Configuration Instructions.
(1) Start the robot and follow the instructions in 2.Remote Tool Installation Connection → 2.4 Docker Container Introduction and Entry to connect via the VNC remote desktop software. Then, switch to the ROS2 environment and select the appropriate language version as needed.
(2) Power on the robot and remotely connect to the Raspberry Pi desktop via VNC.
(3) On the Raspberry Pi desktop, double-click to open the command-line terminal and enter the ROS2 development environment.
(4) Then, input the command to disable the auto-start service:
(5) Then, input the command to start the game:
ros2 launch large_models llm_color_track.launch.py
(6) When the command line shows the output below, initialization is complete. You can then say the wake-up phrase, “mentorpi”.
(7) When the following output appears in the command line, WonderEcho Pro will announce “I am Here”, indicating that WonderEcho Pro has been successfully activated. At this point, the system will begin recording the user’s command.
(8) You can freely phrase your commands to control the movement of MentorPi, such as saying, “Track the red blocks”.
(9) When the command line shows the output below, it indicates that the cloud-based large speech model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under “publish_asr_result”.
(10) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (”response”), as well as designed an action that aligns with the user’s command meaning.
At this stage, the robot sends a client request to the “Color Tracking” node to set the target color and initiate the tracking mode.
(11) When the following output appears in the terminal, it indicates that the Raspberry Pi has successfully called the cloud-based voice synthesis service. WonderEcho Pro will then play the audio generated from the “response” in step 9.
Once the Color Tracking mode is activated, the program will continue running this function. To stop it, press Ctrl+C in the terminal.
(12) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step (5) to reactivate the voice device using the wake-up word and begin a new round of interaction.
(13) To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
  • How It Works
After the mode is activated, you can freely give voice commands such as “Track the red blocks” to control MentorPi’s autonomous tracking. In this mode, MentorPi will follow the red color blocks.
If the red blocks are not detected for more than 5 seconds or the system is reawakened, the color tracking task will exit and return to the wake-up state.
The launch file is saved in: /home/ubuntu/ros2_ws/src/large_models/launch/llm_color_track.launch.py
            'debug': 'true',
    llm_color_track_node = Node(
        executable='llm_color_track',
(1) Color Tracking Control
The object_tracking_node is responsible for managing object color tracking.
Response Playback
The source code is located at: /home/ubuntu/ros2_ws/src/large_models/large_models/llm_color_track.py
import re
import ast
	    self.action = []
        self.result = ''
    PROMPT = '''
(6) Send Prompt
    PROMPT = '''
# Role
You are an intelligent visual omni-directional wheeled robot that needs to generate corresponding JSON commands based on the input content.
## Requirements and Limitations
1. Based on the input action content, find the corresponding command in the action function library and output the corresponding command.
2. Craft a concise (10 to 30 words), witty, and ever-changing feedback message to make the interaction lively and interesting.
3. Directly output the JSON result without analysis or any additional content.
4. Format: {'action': ['xx', 'xx'], 'response': 'xx'}
- The `"action"` key should contain an array of function name strings in the order of execution. If no corresponding action function is found, the action should output an empty array `[]`.
- The `"response"` key should be paired with a carefully crafted brief reply that fits the above word count and style requirements.
## Action Function Library
- Track a red object: object_tracking('red')
### Task Examples:
Input: Track a red object
Output: {"action": ["object_tracking('red')"], "response": "Locking onto the red target, tracking with ease!"}
Input: Track the color of leaves
Output: {"action": ["object_tracking('green')"], "response": "Locking onto the green target, tracking with ease!"}
Input: Track the color of the ocean
Output: {"action": ["object_tracking('blue')"], "response": "Locking onto the blue target, tracking with ease!"}
For the line_following action, extracts color information and calls the related service to start line tracking.
        msg.data = PROMPT
  • Main Function
        rclpy.spin(node)
        print('shutdown')
    main()
  • Large Model object-tracking Logic Analysis
The configuration file of this program is saved in: /home/ubuntu/ros2_ws/src/app/app/object_tracking.py
Function: Used to receive target color information from the large model. The large model sends the target color name to this node by calling the ~/set_large_model_target_color service.
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
    def set_large_model_target_color_srv_callback(self, request, response):
        self.get_logger().info('\033[1;32m%s\033[0m' % "set_large_model_target_color")
        with self.lock:
            color_name = request.data
            self.get_logger().info(f"请求的颜色名称: {color_name}")
            self.tracker = None  # Reset the tracker
            self.large_model_tracking = True
                # 确定使用哪个相机类型:如果当前相机类型是 'ascamera',则使用 'Stereo',否则使用 'Mono'
                camera_type = 'Stereo' if self.camera_type == 'ascamera' else 'Mono'
                # 将相机类型传递给 ObjectTracker 类
                self.tracker = ObjectTracker(None, self, color_name, True)
                    temp = self.tracker.lab_data['lab'][camera_type][color_name]
                    self.get_logger().info(f"成功读取 颜色配置: self.lab_data['lab'][{camera_type}][{color_name}]")
                except KeyError as e:
                    self.get_logger().error(f"读取 颜色配置失败: {e}")
                    raise
                response.message = "set_large_model_target_color"
                response.success = False
                response.message = str(e)
                self.get_logger().error(f"设置目标颜色时发生错误: {e}")
If the tracker exists, its __call__ method is invoked to process the image and publish motion control commands based on the results.
If is_running is True, the motion control commands are published. Otherwise, the output of the PID controller is cleared.
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
        # 将ros格式(rgb)转为opencv的rgb格式(convert RGB format of ROS to that of OpenCV)
        result_image = np.copy(rgb_image)  # 显示结果用的画面(the image used for display the result)
        with self.lock:
            # 颜色拾取器和识别追踪互斥, 如果拾取器存在就开始拾取(color picker and object tracking are mutually exclusive. If the color picker exists, start picking colors)
            if self.color_picker is not None:  # 拾取器存在(color pick exists)
                if target_color is not None:
                    self.tracker = ObjectTracker(target_color, self)
                if self.tracker is not None:
                        result_image, twist = self.tracker(rgb_image, result_image, self.threshold)
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
        with self.lock:
            if self.target_lost_timer is None and self.large_model_tracking:
                self.get_logger().warn("启动停止定时器... (Starting stop timer...)")
        """Stops the robot after the target is lost for a specified duration."""
        with self.lock:
            if self.large_model_tracking and self.target_lost:
                self.get_logger().warn("目标丢失超过5秒,停止移动 (Target lost for more than 5 seconds, stopping movement)")
(4) Wake-up Stop
Upon detecting a voice wake-up signal, the robot will stop only if large_model_tracking is set to True. This ensures that the stop command triggered by the voice wake-up signal is executed solely when color tracking is active under the large model’s control.
459
460
461
462
463
464
465
466
467
468
469
470
471
472
        if msg.data:
            with self.lock:
                    self.tracker = None
14.4 Embodied AI Applications
14.4.1 Embodied AI Applications in Real-Time Detection
In this lesson, we will learn how to leverage a large model to analyze real-world scenes in real time and implement an interactive real-time detection activity.
By running this activity, we can freely express commands, allowing MentorPi to recognize the current scene, analyze it, and verbally report the analysis results.
By default, the program does not include the configuration of the Large AI Model-related API keys. Before activating features related to the Large AI Model, please refer to the section “14.3.1 Obtaining and Configuring Large Model API Keys” to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet. For detailed instructions on network configuration, please refer to the course 13.Network Configuration Courses->13.1 Network Configuration Instructions.
  • Turn Off Cooling Fan
(1) Click in the top-left corner to open the terminal.
(2) Type the command and press Enter to turn off the Raspberry Pi’s cooling fan, minimizing noise interference during recording.
pinctrl FAN_PWM op dh
(1) Start the robot and follow the instructions in 2. Set Development Enviroment → 2.4 Docker Introduction & Usage to connect via the VNC remote desktop software. Then, switch to the ROS2 environment and select the appropriate language version as needed.
(2) Click the icon in the top-left corner to open the terminal and enter the ROS2 development environment.
(4) Enter the command to launch the corresponding game.
ros2 launch large_models vllm_with_camera.launch.py
(5) Once the command line outputs the message below and the device announces “I am ready”, it indicates that the voice device has been initialized. You can now say the wake word, “hello Hiwonder”.
(6) When the following output appears in the command line, MentorPi will announce “I am Here”, indicating that WonderEcho Pro has been successfully activated. At this point, the system will begin recording the user’s command.
(7) You can freely phrase your commands to control the movement of MentorPi, such as saying, “Describe what you saw”.
(8) When the command line displays the output shown below, it indicates that WonderEcho Pro has printed the recognized speech.
(10) When the command line displays the output shown below, it indicates that the cloud-based large language model has been successfully called to process the user’s command and provide a verbal response labeled as “response”.
(11) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step (4) to reactivate the voice device using the wake-up word and begin a new round of interaction.
(13) Click the icon in the top-left corner to open the terminal.
(14) Type the command and press Enter to turn on the Raspberry Pi cooling fan.
pinctrl FAN_PWM op dl
  • How It Works
Once the feature is activated, you can freely phrase your commands, such as saying, “Describe what you saw” MentorPi will automatically recognize the scene within its field of view and provide a detailed description of the current surroundings.
(1) Analysis of launch File
The program is saved at:/home/ubuntu/ros2_ws/src/large_models/launch/vllm_with_camera.launch.py
① Library Files Import
    vllm_with_camera_node = Node(
ament_index_python.packages.get_package_share_directory: Used to obtain the shared directory path of a ROS2 package.
launch_ros.actions.Node: Used to define a ROS2 node
launch.substitutions.LaunchConfiguration: Used to retrieve parameter configurations from a Launch file.
LaunchDescription, LaunchService: Used to define and launch a Launch file.
launch_description_sources PythonLaunchDescriptionSource: Used to include other Launch files.
launch.actions.IncludeLaunchDescription, DeclareLaunchArgument, OpaqueFunction: Used to define actions and parameters within a Launch file.
② Define launch_setup Function
    return [controller_launch,
            depth_camera_launch,
            large_models_launch,
            vllm_with_camera_node,
mode = LaunchConfiguration('mode', default=1): Defines a Launch parameter named mode, with a default value of 1.
sdk_launch: Uses IncludeLaunchDescription to include the MentorPi_sdk.launch.py launch file from the large_models package, passing the mode parameter.
large_models_launch: Uses IncludeLaunchDescription to include the start.launch.py Launch file from the large_models package, passing the mode parameter.
③ Define generate_launch_description function:
    return LaunchDescription([
④ Main program entry:
    # Create a LaunchDescription object(创建一个LaunchDescription对象)
    ls = LaunchService()
    ls.run()
ld = generate_launch_description(): Generates a Launch description object.
ls = LaunchService(): Creates a Launch service object.
ls.include_launch_description(ld): Adds the Launch description to the Launch service.
ls.run(): Starts the Launch service, executing all the defined Launch actions.
(2) Analysis of Python Files
The source code is located at:/home/ubuntu/ros2_ws/src/large_models/large_models/vllm_with_camera.py
① Feature Package Import
import queue
cv2: Used for image processing and display with OpenCV.
json: Used for handling JSON-formatted data.
sdk.fps as fps: Used to calculate and display the frame rate (FPS).
speech: Module related to large model voice interaction
large_models_msgs.srv: Custom service type for large models.
large_models.config: Configuration file for large models.
② VLLMWithCamera Class
class VLLMWithCamera(Node):
        self.vllm_result = ''
        self.bridge = CvBridge()
        self.create_subscription(Image, 'ascamera/camera_publisher/rgb0/image', self.image_callback, 1)
        self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_callback, 1, callback_group=timer_cb_group)
self.vllm_result: Stores the result received from the agent_process/result topic.
self.tts_text_pub: Creates a publisher to send text to the speech synthesis node.
self.create_subscription: Creates subscribers to receive image data, VLLM results, and speech playback completion signals.
self.awake_client and self.set_model_client: Create clients to call the wake-up and model setting services.
③ get_node_state Method
return response: Returns the response object.
④ init_process Method
        msg = SetModel.Request()
        msg.model = vllm_model
        msg.model_type = 'vllm'
            msg.api_key = stepfun_api_key
            msg.api_key = vllm_api_key
            msg.base_url = vllm_base_url
SetModel.Request: Creates a request message to set the model.
SetString.Request: Defines the request message for setting the prompt string.
set_pose_target: Sets the robot’s initial pose.
Self.send_request: Sends a service request.
speech.play_audio: Plays an audio clip.
threading.Thread: Starts a new thread for image processing and tracking.
⑤ Send_request Method
Client.call_async(msg): Asynchronously calls a service.
future.done() and future.result(): Check if the service call has completed and retrieve the result.
⑥ vllm_result_callback method:
    def vllm_result_callback(self, msg):
        self.vllm_result = msg.data
Receives results from the agent_process/result topic and stores them in self.vllm_result.
⑦ process Method
    def process(self):
        cv2.namedWindow('image', cv2.WINDOW_NORMAL)
        cv2.waitKey(10)
            height, width = image.shape[:2]
            cv2.resizeWindow('image', width, height)
            if self.vllm_result:
                msg = String()
                msg.data = self.vllm_result
            cv2.imshow('image', image)
            cv2.waitKey(1)
self.image_queue.get: Retrieves image data from the queue.
self.vllm_result: If there is a VLLM result, it is published to the speech synthesis node.
Cv2.imshow: Displays the image.
⑧ Play_audio_finish_callback Method:
    def play_audio_callback(self, msg):
        if msg.data:
            msg = SetBool.Request()
            msg.data = True
When the speech playback is complete, sends a request to enable the wake-up function.
⑨ image_callback method
Converts received ROS image messages into NumPy arrays and stores them in the queue.
⑩ Main Method
    node = VLLMWithCamera('vllm_with_camera')
Creates an instance of the VLLMWithCamera node.
Uses a multithreaded executor to handle node tasks.
Calls executor.spin() to start processing ROS events.
Destroys the node when finished by calling node.destroy_node().
14.4.2 Embodied AI Applications in Smart Home Assistant
Once activated, you can control MentorPi using voice commands—for example, Go to the zoo to see what animals are there, then come back and tell me. After the command is issued, the terminal will display the recognized speech, while the “AI Voice Interaction Box” will verbally respond with the AI-generated answer and execute the corresponding actions simultaneously.
By default, the program does not include the configuration of the Large AI Model-related API keys. Before activating features related to the Large AI Model, please refer to the 14.3.1 Obtaining and Configuring the Large Model API Key to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet. For detailed instructions on network configuration, please refer to the course 13. Network Configuration Courses->13.1 Network Configuration Instructions.
(1) Click the icon in the top-left corner to open the terminal.
Mapping
Refer to 6. Mapping Lesson ->6.4 slam_toolbox Mapping Algorithm to pre-build and save the map in advance.
(1) Start the robot and follow the instructions in 2. Set Development → 2.4 Docker Introduction & Usage to connect via the VNC remote desktop software. Then, switch to the ROS2 environment and select the appropriate language version as needed.
(2) Double-click to launch the command bar. Enter the command and press Enter to disable the auto-start service.
(3) Execute the following command to disable the app auto-start service.
(4) Type the command and press Enter to launch the voice control mode. The program will then start navigation.
ros2 launch large_models vllm_navigation.launch.py
(5) When the command line shows the output below, initialization is complete. You can then say the wake-up phrase, “Hello Hiwonder”.
(6) When the command line shows the output below and the device announces “I am here”, it means the voice device has been successfully activated. At this point, the system will begin recording the user’s command.
(7) When the command line displays the output shown below, it indicates that WonderEcho Pro has printed the recognized speech.
(8) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (”response”), as well as designed an action that aligns with the user’s command meaning.
(9) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 4) to reactivate the voice device using the wake-up word and begin a new round of interaction.
(10) To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
(11) Type the command and press Enter to turn on the Raspberry Pi cooling fan.
(12) Enter the command and press the Enter key to start the game:
sudo systemctl enable start_node.service
  • How It Works
Once activated, you can freely give commands like: “Go to the zoo to see what animals are there, then come back and tell me”. The robot will navigate to the designated zoo location, count the animal models present, and return to the starting point to report its findings.
  • Modifying Navigation Positions
To update the navigation waypoints in the program, edit the following file: ros2_ws/src/large_models/large_models/vllm_navigation.py
(1) First, refer to Starting and Stopping the Game->Step (4) to launch the program and open the RViz map visualization. Use the 2D Goal Pose tool to set the desired navigation target directly on the map.
(2) Then, switch back to the terminal to view the published target position parameters. Enter these parameter values into the program accordingly.
Each set of five numbers corresponds to:
x coordinate (meters)
y coordinate (meters)
roll angle (rotation around the x-axis, in degrees)
pitch angle (rotation around the y-axis, in degrees)
yaw angle (rotation around the z-axis, in degrees) Use the map’s coordinate system as a reference to fill in the x and y values. Next, convert the quaternion value, for example:
Quaternion(x=0.0, y=0.0, z=-0.5677, w=0.8232) to Euler angles (roll, pitch, yaw), which would be approximately: roll ≈ 0°, pitch ≈ 0°, yaw ≈ -69.3°.
The program is saved at: /home/ubuntu/ros2_ws/src/large_models/launch/vllm_with_camera.launch.py
os: Used for handling file paths and operating system-related functionalities.
launch.actions.IncludeLaunchDescription,DeclareLaunchArgument, OpaqueFunction: Used to define actions and parameters within a Launch file.
    ls.run()
The program is saved at:/home/ubuntu/ros2_ws/src/large_models/large_models/vllm_navigation.py
import re
import json
from large_models_msgs.srv import SetModel, SetContent, SetString, SetInt32
from interfaces.srv import SetPose2D
speech: Modules related to large model voice interaction.
② Modifying Navigation Positions
	    position_dict = {"kitchen": [3.56647, -2.01839, 0.0, -0.190172, 0.981751], #xyzrpy, m,deg
                     "front desk": [1.93939, 1.06236, 0.0, 0.0, 0.399843],
                     "bedroom": [3.14153, -0.321892, 0.0, 0.0, 0.0733996],
                     "zoo": [1.3, 0.37, 0.0, 0.0, 0.0],
                     "space base": [1.58, -0.74, 0.0, 0.0, -48.0],
                     "football field": [0.32, -0.65, 0.0, 0.0, -90.0],
                     "origin": [0.0, 0.0, 0.0, 0.0, 0.0],
                     "home": [0.1, 0.4, 0.0, 0.0, 0.0]
③ LLM_PROMPT character string
	**Role
You are a smart navigation vehicle equipped with a camera and speaker. You can move to different places, analyze visual input, and respond by playing audio. Based on user input, you need to generate the corresponding JSON command.
**Requirements
- For any user input, look up corresponding functions from the Action Function Library, and generate the proper JSON output.
- For each action sequence, include a concise (5–20 characters) and witty, varied response to make the interaction lively and engaging.
- Output only the JSON result, no analysis or extra text.
- Output format:
  "action": ["xx", "xx"],
  "response": "xx"
**Special Notes
The "action" field contains an ordered list of function names to be executed in sequence. If no matching function is found, return: "action": [].
The "response" field should contain a carefully crafted, short, humorous, and varied message (5–20 characters).
**Action Function Library
Move to a specified place: move('kitchen')
Return to starting point: move('origin')
Analyze current view: vision('What do you see?')
Play audio response: play_audio()
**Example
Input: Go to the front desk to see if the door is closed, and then come back and tell me
Output:
  "action": ["move('front desk')", "vision('Is the door closed?')", "move("origin")", "play_audio()"],
  "response": "On it, reporting soon!"
④ VLLM_PROMPT character string
	    VLLM_PROMPT = '''
As my robot butler, you should carefully observe the surrounding situation and give considerate and humane responses to the instructions given. Do not ask questions in return. The number of words should be between 20 and 40.
⑤ VLLMObjectTransport Class
	class VLLMNavigation(Node):
        self.action = []
        self.response_text = ''
        #self.llm_result = '{\'action\':[\'move(\"厨房\")\', \'vision(\"大门有没有关\")\', \'move(\"原点\")\', \'play_audio()\'], \'response\':\'马上!\'}'
        self.play_delay = False
        self.reach_goal = False
self.llm_result: Stores the results returned by the LLM (Large Language Model).
self.running: control the running status of the program
self.transport_finished: Marks whether the transportation task has been completed.
self.client: The voice API client, used for interacting with voice services.
self.tts_text_pub: ROS topic publisher for sending Text-to-Speech (TTS) text.
self.tts_text_pub: ROS topic publisher for sending Automatic Speech Recognition (ASR) results.
self.create_subscription: Subscribes to LLM results
⑥ get_node_state Method
⑦ init_process Method
        msg.model = llm_model
        msg.model_type = 'llm'
        msg.api_key = api_key
        msg.base_url = base_url
        msg.data = LLM_PROMPT
⑧ Send_request Method
⑨ llm_result_callback method:
	    def llm_result_callback(self, msg):
        self.llm_result = msg.data
⑩ wakeup_callback method
        self.interrupt = msg.data
Receives and processes wake-up signals from the vocal_detect/wakeup topic. This method is triggered when the user wakes up the system using voice commands.
⑪ def move(self, position): method
        self.get_logger().info('position: %s' % str(position))
        msg = SetPose2D.Request()
        p = position_dict[position]
        msg.data.x = float(p[0])
        msg.data.y = float(p[1])
        msg.data.roll = p[2]
        msg.data.pitch = p[3]
        msg.data.yaw = p[4]
        self.send_request(self.set_pose_client, msg)
Parameter Reception: Receives a location name (e.g., “zoo”, “supermarket”, etc.)
Position Lookup: Retrieves the corresponding coordinates and orientation data from the position_dict dictionary using p = position_dict[position].
Message Construction: Creates a SetPose2D.Request() message and sets the x and y coordinates, as well as the roll, pitch, and yaw angles.
Service Call: Sends the location request to the navigation controller by calling self.send_request(self.set_pose_client, msg) through the set_pose_client.
This sequence enables the robot to navigate between predefined locations, forming the core functionality for spatial movement tasks.
⑫ play_audio(self) Method:
	    def play_audio(self):
        msg = String()
        msg.data = self.response_text
        self.get_logger().info(f'{self.response_text}')
Plays the text stored in self.response_text as audio. Sends a wake-up signal once audio playback is completed.
⑬ reach_goal_callback(self, msg) method
Parameter Reception: Receives a boolean message indicating whether the target has been reached.
Status Update: Assigns the message data to the self.reach_goal variable.
This allows the system to receive feedback from the navigation controller and update the robot’s navigation status, enabling it to know when the movement task is complete.
⑭ vision(self, query) Method:
	    def vision(self, query):
        msg = SetContent.Request()
        msg.prompt = VLLM_PROMPT
        msg.query = query
        return res.message
Processes visual queries using the Vision Language Model (VLLM).
Parameter Reception: Accepts a query string, such as “What do you see?
Service Call: Sends a request to the VLLM service via set_vllm_content_client.
Result Return: Returns the response message from the Vision Language Model.
⑮ play_audio_finish_callback(self, msg) Method:
        # msg = SetBool.Request()
        # msg.data = True
        # self.send_request(self.awake_client, msg)
        # msg = SetInt32.Request()
        # msg.data = 1
Handles the callback notification for audio playback completion
⑯ process Method
	    def process(self):
        first = True
            if self.llm_result:
                msg = String()
                if 'action' in self.llm_result: # 如果有对应的行为返回那么就提取处理
                        msg.data = result['response']
                        action = result['action']
                        for a in action:
                            if 'move' in a:
                                eval(f'self.{a}')
                                while not self.reach_goal:
                                    if self.interrupt:
                            elif 'vision' in a:
                                res = eval(f'self.{a}')
                                self.response_text = res
                            elif 'play_audio' in a:
                                eval(f'self.{a}')
                            if self.interrupt:
                else: # 没有对应的行为,只回答
                    msg.data = self.llm_result
                self.action_finish = True
Check LLM result; if self.llm_result: Check whether self.llm_result contains any content. If it is not empty, it indicates there is a new LLM result to process; otherwise, enter a short sleep to wait for new results.
Check whether the result contains an action command:; if ‘action’ in self.llm_result: If the returned result contains the “action” field, it indicates that, in addition to the reply text, there are action commands that need to be executed.
Extract and Parse JSON Data: Locate the start and end positions of the JSON segment within the string using string search methods, then parse it into a dictionary with json.loads. Extract data such as “response” and “action” from the dictionary.
Handle Text Replies and Action Execution:
If “response” is present in the parsed result, assign its content to a message and publish it on the tts_text_pub topic to trigger TTS playback.
Movement Commands
If the action string contains “move”, first set self.reach_goal to False, then call the corresponding movement function (executed dynamically using eval).
Enter a loop to wait until self.reach_goal becomes True (indicating the robot has reached its target).
During this wait, monitor self.interrupt to support interruption.
Vision Detection
If “vision” is included, execute the corresponding vision function, assign its return value to self.response_text, and log the result.
Play the Audio
If it contains “play_audio”, directly call the corresponding audio playback function.
Interrupt Check: Continuously monitor the self.interrupt flag throughout the execution of each action. If an interrupt is triggered during waiting or action execution, promptly stop the current action and exit the corresponding loop.
Mark Completion and Switch Mode: After processing the current LLM result—regardless of whether it includes an action—set self.action_finish to True and clear self.llm_result. ater in the loop, once both self.play_audio_finish and self.action_finish are True, reset these flags and send a mode-switch request via set_mode_client to transition to the next state.
Finally, when self.running is set to False, exit the loop and shut down the ROS system.
⑰ Main Method
290
291
292
294
295
    node = VLLMNavigation('vllm_navigation')
Create an instance of the VLLMObjectTransport ROS 2 node.
  • FAQ
(1) Launching RVIZ on the Virtual Machine
If the game is lagging or performing poorly, you can display RVIZ on the virtual machine as follows. Refer to the instructions in 6. Mapping Lesson -> 6.4.2 Mapping Operation Steps for placing the necessary files in the virtual machine under:
Enter the following command and press Enter to initiate smart home assistant game:
ros2 launch large_models vllm_navigation_virtual.launch.py
(2) Click in the top-left corner to open the terminal.
(3) Input the command below to launch the rviz tool to display the navigation process:
14.4.3 Embodied AI Applications in Vision Tracking
In this lesson, we will learn how to leverage a large model to analyze real-world scenes in real time and implement an interactive real-time detection activity. Note: The large language model used in this lesson is cloud-based. Before starting, please connect the robot to the internet using an Ethernet cable or switch it to local area network (LAN) mode.
After activation, you can interact with MentorPi using voice commands. You can then control MentorPi with your voice. For example, say “Track the purple ball.” The terminal will display the recognized voice command, and the voice device will announce the generated response after processing, then execute the corresponding action.
(4) Turn Off Cooling Fan
① Click in the top-left corner to open the terminal.
② Type the command and press Enter to turn off the Raspberry Pi’s cooling fan, minimizing noise interference during recording.
(3) Enter the command to launch the corresponding game.
ros2 launch large_models vllm_track.launch.py
(4) Open a new command-line terminal to execute the following command and access the live camera feed:
rqt
(5) Choose the corresponding topic.
(6) Once the command line outputs the message below and the device announces “I am ready”, it indicates that the voice device has been initialized. You can now say the wake word, “Hello Hiwonder”.
(7) When the following output appears in the command line, MentorPi will announce “I am Here”, indicating that MentorPi has been successfully activated. At this point, the system will begin recording the user’s command.
(8) You can freely phrase your commands to control the movement of MentorPi, such as saying, “Track the purple ball”.
(9) When the command line displays the output shown below, it indicates that MentorPi has printed the recognized speech.
(10) When the command line shows the output below, it indicates that the cloud-based voice large model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under “publish_asr_result”.
(11) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (”response”), as well as designed an action that aligns with the user’s command meaning.
(12) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 4) to reactivate the voice device using the wake-up word and begin a new round of interaction.
(15) Enter the command and press the Enter key to start the game:
  • How It Works
Once the feature is activated, we can freely organize our commands, for example: “Track the purple ball”. This will control the MentorPi robot car to automatically track the purple ball within its field of view, highlight the ball in the frame, and stop tracking when the ball is positioned at the center of the screen.
The program is saved at: /home/ubuntu/ros2_ws/src/large_models/launch/vllm_track.launch.py
            'sim': 'false',
    vllm_track_node = Node(
        executable='vllm_track',
        name='vllm_track',
    # rqt
    calibrate_rqt_reconfigure_node = Node(
        package='rqt_reconfigure',
        executable='rqt_reconfigure',
        name='calibrate_rqt_reconfigure'
vllm_track_node:Defines a ROS2 node from the large_models package that executes the vllm_track executable, and prints its output to the screen.
③ Main program entry:
59
    ls.run()
The source code is located at:/home/ubuntu/ros2_ws/src/large_models/large_models/vllm_track.py
import json
import queue
import sdk.fps as fps
import message_filters
from sdk import common
from std_msgs.msg import String, Float32, Bool
from rcl_interfaces.msg import SetParametersResult
from speech import speech
from large_models_msgs.srv import SetString, SetModel
from large_models.track_anything import ObjectTracker
② PROMPT Character String
A prompt string (PROMPT) is defined to guide the processing of user commands and image data, specifying the rules and output format for the recognition task.
③ VLLMTrack Class
class VLLMTrack(Node):
        self.machine_type = os.environ['MACHINE_TYPE']
        self.fps = fps.FPS() # 帧率统计器(frame rate counter)
        # self.vllm_result = '''json{"object":"红色方块", "xyxy":[521, 508, 637, 683]}'''
        self.data = []
        self.start_track = False
        #cv2.namedWindow('image', 0)
        #cv2.moveWindow('image', 1920 - 640, 0)
        #cv2.waitKey(10)
        #os.system("wmctrl -r image -b add,above")
        self.track = ObjectTracker(use_mouse=False, automatic=True, log=self.get_logger())
        self.mecanum_pub = self.create_publisher(Twist, '/controller/cmd_vel', 1)  # Chassis control(底盘控制)
        image_sub = message_filters.Subscriber(self, Image, 'ascamera/camera_publisher/rgb0/image')
        depth_sub = message_filters.Subscriber(self, Image, 'ascamera/camera_publisher/depth0/image_raw')
self.vllm_result is used to store the processed results. self.running: A boolean variable used to control the program’s running state. self.data: An empty list used to store data. self.start_track: A boolean variable used to control the start or stop of target tracking.
self.track = ObjectTracker(): Instantiates an object tracker.
self.tts_text_pub: Creates a publisher for publishing text to the text-to-speech synthesis node. self.track.update_pid(): Passes the updated PID parameters to the object tracker (self.track) to adjust the tracker’s PID controller.
self.pid_params: PID controller parameters used in the control logic of the object tracker.
④ On_parameter_update Method
    def on_parameter_update(self, params):
        """Parameter update callback(参数更新回调)"""
        for param in params:
            if param.name in self.pid_params.keys():
                self.pid_params[param.name] = param.value
        # self.get_logger().info(f'PID parameters updated: {self.pid_params}')
        # Update PID parameter (更新 PID 参数)
        return SetParametersResult(successful=True)
self.pid_params: A dictionary used to store PID parameters.
self.track.update_pid: Updates the PID parameters for the target tracking module.
⑤ create_update_callback Method
    def create_update_callback(self, param_name):
        """Generate dynamic update callback(生成动态更新回调)"""
        def update_param(msg):
            new_value = msg.data
            self.pid_params[param_name] = new_value
            self.set_parameters([Parameter(param_name, Parameter.Type.DOUBLE, new_value)])
            self.get_logger().info(f'Updated {param_name}: {new_value}')
Generates a dynamic update callback function for each PID parameter.
        msg.data = PROMPT
        time.sleep(1.8)
⑨ vllm_result_callback method:
⑩ play_audio_finish_callback method
        if msg.data:
            msg.data = True
⑪ process Method
    def process(self):
        box = ''
                    if box:
                            box = self.client.data_process(box, 640, 480)
                            box = [int(box[0] * 640), int(box[1] * 480), int(box[2] * 640), int(box[3] * 480)]
                    self.track.set_track_target(box, image)
                    self.start_track = True
                    speech.play_audio(start_track_audio_path, block=False)
                except (ValueError, TypeError) as e:
                    msg = String()
                    speech.play_audio(track_fail_audio_path, block=False)
                    self.get_logger().info(e)
                msg.data = True
            if self.start_track:
                self.data = self.track.track(image, depth_image)
                image = self.data[-1]
                # self.get_logger().info('twist.linear.x:{}'.format(twist.linear.x))
                # self.get_logger().info('twist.angular.z:{}'.format(twist.angular.z))
                if self.machine_type == 'MentorPi_Acker':
                    steering_angle = common.set_range(twist.angular.z, -math.radians(322/2000*180), math.radians(322/2000*180))
                    if steering_angle != 0:
                        R = 0.145/math.tan(steering_angle)
Image data is retrieved from the image_queue.get queue. The recognition results are then received via the vllm_result subscriber. These results are parsed using json.load and processed accordingly. Finally, the track.set_track_target function is called to set the tracking target.
speech.play_audio(start_track_audio_path, block=False): Plays an audio file to indicate that target tracking has started.
self.send_request(self.awake_client, msg): Sends a service request via awake_client to enable voice wake-up functionality.
⑫ Multi_callback Method
Converts received RGB image messages into NumPy arrays and stores them in the queue.
⑬ Main Method
    node = VLLMTrack('vllm_track')
Creates an instance of the VLLMTrack node. Uses a multithreaded executor to handle node tasks. Calls executor.spin() to start processing ROS events. Destroys the node when finished by calling node.destroy_node().
