8. ROS+OpenCV Lesson
8.1 Install Depth Camera
If the camera module included with your MentorPi system is a monocular type, please consult the following installation procedures for implementation.
Interface indication:
8.2 Color Threshold Adjustment
8.2.1 Enable LAB_Tool
(1) Open the VNC software. Locate and open the “LAB_Tool” on the main interface.
(2) The “Execute File” dialog box will appear. Click “Execute” to proceed.
(3) After entering the software, you can see the interface of LAB_Tool, as shown in the figure below:
If the live feed camera does not appear in the pop-up interface, it means that the camera is not connected successfully. Please check if the camera connection cable is properly connected.
(4) Image display area: the left displays the processed image and the right is the raw image.
If the transmitted image does not display normally, it’s the issue of camera connection. In this case, you need to examine if the wiring is connected properly or reconnect it.
(5) Recognition adjustment area: adjust the color threshold. The function of each button refer to the following table:
Icon Function instruction
The sliders L, A and B are used respectively to adjust the values of the corresponding L, A and B components of the image.
The sliders on the left are the "min" value for each component while the slider on the right are the "max" value for each component.
Add recognizable color.
Click this button to switch between Chinese and English.
Close LAB TOOL.
8.2.2 Adjust Color Threshold
(1) Open LAN tool. Choose the color in the color drop-down list of color recognition area. Take a color “red” as example.
(2) Adjust the “min” values of L, A and B components to “0”, and the “max” values to “225”.
(3) Place the target within the camera’s field of view. Adjust the values of L, A and B component towards the interval representing the target recognition color according to the LAB color space distribution chart.
(4) Adjust the L and B components according to your surroundings. If the red color is light, increase the “min” value of the L component; if it is dark, decrease the “max” value of the component. If the red color tends to be warm, increase the “min” value of the B component; if it tends to be cool, decrease the “max” value of the B component.
L 0~255 Black-white (-L~+L)
A 0~255 green-red(-a ~ +a)
B 0~255 Blue-yellow(-b ~ +b)
(5) Click “Save” button in adjustment area to save the adjustment parameters.
8.2.3 Add New Color
(1) Open LAB tool and click on “Add” button.
(2) Fill in the “name” column with the color name, and click the “OK” button.
(3) Choose the added color in the color drop-down menu.
(4) Place the target within the camera’s field of view, and adjust the threshold by dragging the L, A, and B component sliders until the area of the colored object within the left screen turns white, while the other areas turn black.
the adjustment method of color threshold refers to “8.2.2 Adjust Color Threshold”.
(5) Click “Save” button in recognition adjustment area to save the adjustment parameters of color threshold.
8.3 Color Recognition
This session will use OpenCV to perform red, green, blue recognition and display the recognition result through transmitted image.
Before operations, please prepare one object for each color: red, green, and blue.
8.3.1 Recognition Process
Firstly, obtain the RGB image from the camera. Scale and apply Gaussian blur to the image. Convert the image from RGB to Lab. (For detailed explanations regarding the Lab color space, you can refer to OpenCV Basic Lesson.)
Next, identify the object color in the circle by using color thresholds, followed by masking of the image portion. (Masking is used to hide certain part of the processed image).
Finally, the recognition results are displayed on the live camera feed.
8.3.2 Operation Steps
the entered command should be case sensitive and “Tab” key can be used to complement the key words.
(1) Start MentorPi and connect it to VNC.
(2) Click on to open the command line terminal.
~/.stop_sh
(4) Run the following command to enable the camera node:
(5) Open a new command line terminal. Enter the following command to navigate to the program directory.
cd /home/ubuntu/ros2_ws/src/example/example/color_detect
(6) Enter the command. Press “Enter” to execute the program.
python3 color_detect_demo.py
(7) If you want to exit the game, press “Ctrl+C” in the terminal interface.
Click and enter the command. Press enter to start the app, and wait for the buzzer to beep. Please enter the command in the system path, not in the Docker container.
8.3.3 Program Outcome
After the game starts, please ensure that there are no other objects containing recognized colors within the field of view of the camera to avoid affecting the implementation effect.
After the game starts, place the target object within the field of view of the camera. When the target object is recognized, it will be circled up in the same color and the color name will be printed in the lower-left corner of the screen. The program supports red, blue and green object recognition.
8.3.4 Program Analysis
The source code of the program is located in: /home/ubuntu/ros2_ws/src/example/example/color_detect/color_detect_demo.py.
  • Basic Configuration
(1) Read color threshold configuration file
Call the get_yaml_ data function to obtain the color threshold configuration file.
(2) Obtain live camera feed
Create a subscription object to read the live camera feed
through the code /ascamera/camera_publisher/rgb0/image', image_callback, 1).
node.create_subscription(Image, '/ascamera/camera_publisher/rgb0/image', image_callback, 1)
  • Image Processing
The “run” function is called for image processing.
def run(img):
    global draw_color
    global color_list
    global detect_color
    img_copy = img.copy()
    img_h, img_w = img.shape[:2]
    frame_lab = cv2.cvtColor(frame_gb, cv2.COLOR_BGR2LAB)  # 将图像转换到LAB空间(convert image to LAB space)
    max_area = 0
    color_area_max = None
    areaMaxContour_max = 0
        frame_mask = cv2.inRange(frame_lab, tuple(lab_data['lab']['Stereo'][i]['min']), tuple(lab_data['lab']['Stereo'][i]['max']))  #对原图像和掩模进行位运算(perform bitwise operation on the original image and the mask)
        eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3)))  #腐蚀(erode)
        dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) #膨胀(dilate)
        contours = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE)[-2]  #找出轮廓(find contours)
        areaMaxContour, area_max = getAreaMaxContour(contours)  #找出最大轮廓(find the largest contour)
            if area_max > max_area:#找最大面积(find the maximum area)
                max_area = area_max
                color_area_max = i
    if max_area > 200:  # 有找到最大面积(the maximum area is found)
        ((centerX, centerY), radius) = cv2.minEnclosingCircle(areaMaxContour_max)  # 获取最小外接圆(obtain the minimum circumscribed circle)
        cv2.circle(img, (centerX, centerY), radius, range_rgb[color_area_max], 2)#画圆(draw circle)
(1) Gaussian blur
Use the cv2.GaussianBlur() function from the cv2 library to apply Gaussian filtering to the image to remove noise.
69
The first parameter frame_resize is the input image.
The second parameter (3, 3) is the size of the Gaussian convolution kernel. The height and width of the kernel must be positive and odd numbers.
The third parameter 3 is the standard deviation of the Gaussian kernel in the horizontal direction.
① Color space conversion
Convert the image from BGR to LAB color space.
② Color detection, erosion and dilation
Perform erosion and dilation operations on the binary image to smooth the contour edges in the image and facilitate the subsequent search for target contours.
frame_mask: the input binary image mask.
cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3)): generates a 3x3 rectangular structural element (kernel) that specifies the shape and size of the erosion operation. cv2.MORPH_RECT specifies the rectangular shape. “eroded”: The binary image mask after erosion.
cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3)): uses the same structural element as erosion for the dilation operation.
③ Get contour with the maximum area
Call the cv2.findContours() function from the cv2 library to find the maximum contour of the target color in the image.
                max_area = area_max
                color_area_max = i
Initialization: contour_area_temp and contour_area_max store the current contour area and the maximum contour area. area_max_contour stores the maximum contour.
Traverse Contours: Traverse each contour c in the contours list.
Calculate Area: Calculate the area of the contour c using cv2.contourArea(c).
Determine Maximum Area: If the current contour area is greater than the known maximum area and greater than the threshold of 50, update the maximum area and maximum contour.
Return Value: The function returns the contour with the maximum area area_max_contour and its corresponding maximum area contour_area_max.
  • Feedback Action
(1) Circle the target object
Call the drawContours() function to draw a bounding box around the target object in the live camera feed.
The meaning of the parameters in the function parentheses is as follows:
img: The target image on which to draw the text.
"Color: " + detect_color: The text string to be drawn, displaying the detected color.
(10, img.shape[0] - 10): The starting position of the text, in pixels, representing the coordinate of the lower left corner.
10 is the x-coordinate of the text, starting from the left edge.
img.shape[0] - 10 is the y-coordinate of the text, indicating the position above the bottom of the image.
cv2.FONT_HERSHEY_SIMPLEX: The font type.
0.65: The size of the text.
draw_color: The color of the text, represented by a BGR format tuple, such as (255, 0, 0) for blue.
The thickness of the text line, representing the pixel width of the border.
8.4 Generate & Recognize QR Code
This lesson is divided into two parts. The first part will introduce you how to learn to create a QR cod. The second part focuses on recognizing the created QR code and then decoding the QR code information through the terminal.
8.4.1 Generate QR Code
  • Process
Finally, generate a QR code image based on the data and display it in a window, and save it in the corresponding path.
  • Operation Steps
the entered command should be case sensitive and the “Tab” key can be used to fill in key words.
~/.stop_sh
(4) Input the command to enable the camera service.
cd ros2_ws/src/example/example/qrcode
python3 qrcode_creater.py
  • Program Outcome
(1) After start the program, it’s necessary to enter characters in the terminal to generate the QR code. Take the input of “hiwonder” as example.
hiwonder
(2) Press “Enter” to display a QR code image containing the input data.
(3) If need to close the program, press “Ctrl+C” in the terminal. If this fails, please try multiple times.
(4) After closing the window, the saved content and its path are printed.
The source code of the program is located in: /home/ubuntu/ros2_ws/src/example/example/qrcode/qrcode_creater.py
(1) Creating QR Code Utility Object
Using the qrcode module to create the necessary object and setting various parameters for the QR code.
    qr = qrcode.QRCode(
        version=1,
        box_size=5,
        border=4)
The parameters of the above function are as follows:
The first parameter version is an integer ranging from 1 to 40, used to control the size of the QR code. If you want the program to automatically determine the size, set this value to None and use the “fit” parameter.
The second parameter error_correction controls the error correction capability of the QR code, with the following options:
ERROR_CORRECT_L: can correct approximately 7% or fewer errors.
ERROR_CORRECT_M: default value, can correct approximately 15% or fewer errors.
ERROR_CORRECT_H: can correct approximately 30% or fewer errors.
The third parameter box_size controls the number of pixels contained in each small box of the QR code.
The fourth parameter border controls the number of boxes included in the border (distance between the QR code and the image boundary), with a default value of 4, which is the minimum value specified by relevant standards.
(2) Generating QR Code
Using the add_data and make functions to retrieve and fill data, and then using the make_image function to generate the image.
    # 添加数据(add data)
    qr.add_data(data)
    # 填充数据(fill data)
    qr.make(fit=True)
    # 生成图片(generate image)
The first parameter fill_color=(0, 0, 0) is the fill color of the image, which is black in this case.
The second parameter back_color=(255, 255, 255) is the background color of the image, which is white in this case.
(3) Displaying Image
Converting the color space of the image using the cvtColor function, and then displaying it on the window using the imshow function.
        cv2.imshow('img', opencv_img)
        k = cv2.waitKey(1)
(3) Saving Image
Using the imwrite function to store the generated QR code image and print relevant information.
The first parameter file_name is the storage path of the image.
The second parameter opencv_img is the image to be stored.
8.4.2 QR Code Recognition
In the previous section, we created a QR code. In this section, we’ll perform content recognition on the QR code.
  • Recognition Process
Firstly, create an instance object for QR code detection. Then, subscribe to an image topic “/ascamera/camera_publisher/rgb0/image” in the node and process the received image message. Use the pyzbar library to decode the QR code in the image, and draw the QR code boundary and decoded data using OpenCV. Display the processed image using OpenCV. Next, you can exit the display window by pressing the key.
  • Operation Steps
When entering commands, it is necessary to strictly distinguish between uppercase and lowercase letters, and you can use the “Tab” key to complete keywords.
(2) Input the command and press Enter to disable the app auto-start service.
~/.stop_sh
(3) Run the following command to enable the camera node:
(4) Open a new command line terminal. Enter the following command to navigate to the program directory.
(5) Enter the command. Press “Enter” to open the image.
(6) Open a new terminal and enter the command. Press “Enter” to execute the program.
python3 /home/ubuntu/ros2_ws/src/example/example/qrcode/qrcode_detecter.py
8.4.3 Program Outcome
After starting the game, it will recognize the QR code images appearing in the live camera feed, mark them with a green box, and print out the content of the QR code.
8.4.4 Program Analysis
The source code of the program is located in /home/ubuntu/ros2_ws/src/example/qrcode/qrcode_detecter.py
(1) Create QR code detection object
            decoded_objects = pyzbar.decode(image)
            for obj in decoded_objects:
                points = obj.polygon
                if len(points) > 4:
                    hull = cv2.convexHull(np.array([point for point in points], dtype=np.float32))
                    points = hull.reshape(-1, 2)
                for j in range(len(points)):
                    cv2.line(image, tuple(points[j]), tuple(points[(j+1) % len(points)]), (0, 255, 0), 3)
                x = obj.rect.left
                y = obj.rect.top
                barcode_data = obj.data.decode("utf-8")
                print(barcode_data)
                cv2.putText(image, barcode_data, (x, y - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 255, 0), 2)
            cv2.imshow('image', image)
            if key == ord('q') or key == 27:
decoded_objects is a list of QR code objects obtained by decoding the image using pyzbar.decode(image). Each obj represents a detected QR code.
② Use cv2.line to draw the boundary of the QR code. Connect every two consecutive vertices with a line:
  • image: the image to draw on.
  • tuple(points[j]): the coordinates of the current point.
  • tuple(points[(j+1) % len(points)]): the coordinates of the next point, using (j+1) % len(points) to ensure connection to the first point.
  • (0, 255, 0): line color, green (BGR format).
  • 3: line width.
(2) Get and print the decoded data of the QR code.
                x = obj.rect.left
                y = obj.rect.top
                print(barcode_data)
Use cv2.putText to draw the decoded data on the image:
  • barcode_data: the text to draw.
  • (x, y - 10): the coordinates of the bottom-left corner of the text. Subtract 10 pixels to display the text above the QR code.
  • cv2.FONT_HERSHEY_SIMPLEX: font type.
  • 0.5: font size scale factor.
  • (0, 255, 0): text color, green (BGR format).
  • 2: text line width.
8.5 Autonomous Line Following
This game involves using the camera to detect the specified color, and making the robot follow the pre-laid line.
8.5.1 Recognition Procedure
Subscribe to the camera node’s topic to get the RGB image.
Find the line to be followed in the image and select it. Pick color to get its color threshold and extract its features. Calculate the robot’s offset from the line’s position in the field of view, and control the robot to move along the line. Keep the line in the center of the field of view by continuously correct the robot’s position. Use the lidar to detect the obstacle, enabling the obstacle avoidance.
8.5.2 Operation Steps
~/.stop_sh
(3) Input the command to enable the line following.
(4) Open a new command line terminal. Run the following command to open the camera and select the target line.
(5) Open a new command line terminal again and enter the command. Press “Enter” to execute the line following.
(6) If you want to exit the game, press “Ctrl+C” in the terminal interface.
8.5.3 Program Outcome
After picking the color of the line to be followed, the robot starts to move along the line.
8.5.4 Program Analysis
The source code of the program is located in /home/ubuntu/ros2_ws/src/app/app/line_following.py
it’s necessary to back up the original program file before making any modification to the program. You’re forbidden to modify the original source code file to avoid causing robot malfunctions that may be irreparable due to incorrect parameter modifications!
First, some preset parameters such as color threshold ratio, stop threshold, and angle swing range are defined through the initialization function. These parameters can affect the final recognition effect. Then, the color picker object is defined and the additional lidar obstacle avoidance function is set. Next, the LineFollower class is implemented, which mainly includes the image preprocessing function and the logic judgment of line following.
  • Set related parameters of the initialization function “init__(self, name)”
The LineFollowingNode class is used as the starting point of the program, and some basic parameters are defined in the initialization function. The color threshold ratio, stop threshold, and angle swing range need to be noted. All the relevant parameters and definitions are in the “LineFollowingNode” class, as shown in the figure below:
        self.name = name
        self.set_callback = False
        self.is_running = False
        self.color_picker = None
        self.follower = None
        self.pid = pid.PID(0.005, 0.001, 0.0)
        self.empty = 0
        self.stop = False
        self.threshold = 0.5
        self.stop_threshold = 0.4
        self.lock = threading.RLock()
        self.image_sub = None
        self.lidar_sub = None
        self.image_height = None
        self.image_width = None
        self.bridge = CvBridge()
        #self.camera_type = os.environ['DEPTH_CAMERA_TYPE']
  • Set threshold ratio parameter “self.threshold”:
The self.threshold parameter sets the weight ratio of color processing to binary image during the color picking. It is called through the initialization function of the LineFollower class, as shown in the figure below:
The above initialization function calls the self.threshold parameter, which sets the minimum and maximum color ranges of the target_color for subsequent binary processing. To achieve better recognition and processing results, the parameters can be kept at default.
  • Set stop threshold “self.stop_threshold”:
The self.stop_threshold judges when the robot should stop. As shown in the figure below:
298
299
                self.stop = True
The above code determines when the car should stop. min_dist_left and min_dist_right calculate the distances from the robot to the left and right sides. When these two distances are less than the set stop threshold parameter, self.stop is set to True to stop the robot.
  • Set angle swing range “self.scan_angle”:
The self.scan_angle is the swing angle of the robot during line following, with a range within 45 degrees. This angle parameter can achieve better line following effects while having a good scanning range. Increasing this parameter will increase the swing amplitude of the robot. Decreasing this parameter will decrease the swing amplitude of the robot. However, the recognition effect may not be optimal.
  • Define color picker “set_target_color_srv_callback”:
The color picker is the tool for color picking in the app. It is defined using the set_target_color_srv_callback function, as shown in the figure below:
        with self.lock:
            self.pid = pid.PID(0.00, 0.001, 0.0)
        response.message = "exit"
The self.color_picker is the definition of the picker. In the ColorPicker function, req.data is the position of the picked point. 20 is the length of the sent data frame. The function returns the feedback information of the set point.
  • Radar obstacle avoidance function “lidar_callback”:
In the process of autonomous line following, there is also a lidar obstacle avoidance function. It is implemented in the “lidar_callback” function, as shown in the figure below:
        # 数据大小 = 扫描角度/每扫描一次增加的角度(data size= scanning angle/ the increased angle per scan)
        if self.lidar_type != 'G4':
            left_ranges = lidar_data.ranges[:max_index]  # 左半边数据(left data)
            right_ranges = lidar_data.ranges[::-1][:max_index]  # 右半边数据(right data)
        elif self.lidar_type == 'G4':
            left_ranges = lidar_data.ranges[min_index:max_index][::-1]  # 左半边数据 (the left data)
            right_ranges = lidar_data.ranges[::-1][min_index:max_index][::-1]  # 右半边数据 (the right data)
This is the setting of the radar scanning range. The scanning range should be set according to different lidar types. The parameters can be kept at default.
284
285
286
        # 根据设定取数据(Get data according to settings)
        angle = self.scan_angle / 2
The left and right point cloud data range processing: angle is the boundary line of the scanning range; angle_index is the point cloud data coordinate processing; angle_increment is the point cloud angle increment of the lidar scanning; left_range and right_range are the point cloud data of the left and right parts. The parameters can be kept at default.
292
294
295
296
297
298
299
300
301
302
303
        # 取左右最近的距离(Take the nearest distance left and right)
        if len(min_dist_left_) > 1 and len(min_dist_right_) > 1:
                self.stop = True
                if self.count > 5:
                    self.stop = False
This part judges the distance between the scanned point cloud data and obstacles. When the distance is less than the stop threshold, “self.stop” is set to True to stop the robot. Otherwise, the logic judgment is performed every 5 frames of data “self.cout > 5”.
  • LineFollower class:
LineFollower” is a class that contains the visual line following results and mainly focuses on the image preprocessing function and the logic judgment of line following.
  • LineFollower initialization function:
In the program file, find the LineFollower class, whose initialization function includes the image preprocessing: color space conversion, Gaussian blur noise reduction, binarization, erosion and dilation, as shown in the figure below.
            img_lab = cv2.cvtColor(blob, cv2.COLOR_RGB2LAB)  # rgb转lab(convert rgb into lab)
            img_blur = cv2.GaussianBlur(img_lab, (3, 3), 3)  # 高斯模糊去噪(perform Gaussian filtering to reduce noise)
            mask = cv2.inRange(img_blur, tuple(target_color[1]), tuple(target_color[2]))  # 二值化(image binarization)
            eroded = cv2.erode(mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3)))  # 腐蚀(corrode)
            dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3)))  # 膨胀(dilate)
The cvtColor color space conversion converts the RGB image to the LAB image to reduce the interference of light. Gaussian blur noise reduction reduces the noise on the image.
(3,3) is the size of the noise convolution kernel, which can be kept at default. cv2.inRange is the binarization of the image, which presents the line following trajectory in black and white image. The erosion and dilation eliminate the spots of the selected image to obtain a clearer line following trajectory. If the recognition result is not ideal, the parameters of erosion and convolution can be appropriately increased. For specific parameter modification range, please refer to the relevant OpenCV lesson.
  • Change the style of the center point drawing:
                cv2.circle(result_image, (int(line_center_x), int(line_center_y)), 5, (0, 0, 255),
                           -1)  # 画出中心点(draw the center point)
                centroid_sum += line_center_x * roi[-1]
line_center_x and line_center_y are the coordinates of the calculated center point.
cv2.circle is the circle drawing function of OpenCV. The parameter 5 is the radius of the circle. Increasing this value will increase the radius of the circle. (0, 0, 255) represents the BGR ratio, representing the color of the drawn line, which is green. If it is changed to “(255, 0, 0)”, the color of the drawn line will be changed to red. -1 represents a solid center point.
  • Line following logic judgment:
The initialization function of LineFollower returns the line angle calculated, as shown in the figure below:
        center_pos = centroid_sum / self.weight_sum  # 按比重计算中心点(calculate the center point according to the ratio)
        deflection_angle = -math.atan((center_pos - (w / 2.0)) / (h / 2.0))  # 计算线角度(calculate the line angle)
        return result_image, deflection_angle
The defection_angle is the calculated line following angle. math.atan is the arctangent function; center_pos is the position of the specified line’s center point; (w/2.0)/(h/2.0) represents the center point of the image.
8.6 Color Tracking
In this lesson, let’s use OpenCV to track a red color block with the pan-tilt and display the recognition results through the live camera feed.
Before starting the game, please prepare a red block.
8.6.1 Recognition Procedure
First, subscribe to the topic messages published by the color recognition node to obtain color information. Obtain the RGB image from the camera and resize it. Apply Gaussian blur to the image and convert the color space from RGB to Lab.
Then, perform color recognition on the objects in the circle using color thresholding. Apply masking to parts of the image. Masking is used to globally or locally mask the processed image using selected images, graphics, or objects.
Afterward, perform opening and closing operations on the object images. Next, outline the largest object with a circle.
Opening operation: erode the image and then dilate it. It is used to eliminate small objects, smooth the shape boundary, and not change its area. It can remove small grain noise and break the adhesion between objects.
Erosion: Eliminate the boundary points of the object, causing the boundary to shrink inward, and can remove objects smaller than the structural element.
Dilation: Expand the boundary points of the object, merge all background points in contact with the object into the object, and expand the boundary outward. Then, feedback the recognition results on the feedback screen.
After matching the target color, the center position of the target image is obtained.
Finally, by publishing a corresponding topic message, the servo is controlled to rotate, so that the pan-tile servo can follow the target movement.
8.6.2 Operation Steps
  • The input command should be case sensitive, and keywords can be complemented using Tab key.
  • This game is only applicable to 2D pan-tilt monocular camera version.
(1) Start the robot and connect it to the remote control software VNC.
(2) Click on on the system desktop to open the command line terminal.
(3) Run the command to stop the automatic startup service of the app.
~/.stop_sh
(4) Enter the command to start the game.
(5) If you want to exit the game, press “Ctrl+C” in the terminal interface.
8.6.3 Program Outcome
Note: After starting the game, please ensure that there are no other objects containing the recognized color in the field of view of the camera, as this may affect the affect the program outcome.
After starting the program, place the target object within the camera’s field of view. Once the target object is recognized, it will be highlighted with a circle and the pan-tilt will track it.
8.6.4 Program Analysis
The source code of the program is located at: /home/ubuntu/ros2_ws/src/example/example/color_track/color_track_node.py
  • Main function
    node = ColorTrackNode('color_track')
    main()
  • pwm_controller
    def pwm_controller(self,position_data):
        pwm_list = []
        msg = SetPWMServoState()
        msg.duration = 0.2
        for i in range(len(position_data)):
            pos = PWMServoState()
            pos.id = [i+1]
            pos.position = [int(position_data[i])]
            pwm_list.append(pos)
        msg.state = pwm_list
        self.pwm_pub.publish(msg)
Construct a PWM signal based on the position data received, and publish it to the robot controller.
  • Set color threshold
        msg_red = ColorDetect()
        msg_red.color_name = request.data
        msg.data = [msg_red]
        if res.success:
            self.get_logger().info('\033[1;32m%s\033[0m' % 'start_track_%s'%msg_red.color_name)
            self.get_logger().info('\033[1;32m%s\033[0m' % 'track_fail')
Set the color threshold. Set the color detection parameters based on the request and publish them.
  • Adjust the position of servo
            if self.center is not None and self.start:
                t1 = time.time()
                self.pid_y.SetPoint = self.center.width / 2
                self.pid_y.update(self.center.width - self.center.x)
                self.y_dis -= self.pid_y.output
                if self.y_dis < 800:
                    self.y_dis = 800
                if self.y_dis > 1900:
                    self.y_dis = 1900
                self.pid_z.SetPoint = self.center.height / 2
                self.pid_z.update(self.center.y)
                self.z_dis -= self.pid_z.output
                if self.z_dis > 1900:
                    self.z_dis = 1900
                if self.z_dis < 800:
                    self.z_dis = 800
                self.pwm_controller([self.z_dis, self.y_dis])
                t2 = time.time()
                t = t2 - t1
Check if the color has been detected. If detected, set it to True and record the current time (t1) to control the frequency of the loop execution.
PID control: two PID controllers, pid_y and pid_z, are used to adjust the position of the pan-tilt in the horizontal (y-axis) and vertical (z-axis) directions.
Position limitation: Limit the adjusted position values self.y_dis and self.z_dis. Send the adjusted position values to the pan-tilt to control it to move to the new position.
8.7 Chassis Tracking
In this lesson, OpenCV is used to recognize a target-colored block and control the robot chassis to track it.
Before starting this activity, please prepare a color block of any color.
8.7.1 Program Introduction
The program first subscribes to the ROS2 image node image_raw to receive the video feed. By clicking on the image, the user selects the target area, allowing the system to capture and record the color range for target identification. Once the target color is identified, OpenCV calculates the coordinates of its center. The system then determines the offset between this point and the center of the image frame. This offset is passed to a PID controller, which uses predefined parameters to calculate the appropriate movement speed for the chassis. Finally, the control data is published through the chassis control node topic, enabling the robot to track and follow the target accurately.
8.7.2 Operation Steps
Commands are case-sensitive, so please enter them exactly as required. You may use the Tab key to auto-complete keywords for convenience.
(1) Start the robot, and access the robot system using the VNC remote control software by referring the instructions in 2. Remote Tool Installation and Container Access-> 2.1 VNC Installation and Connection
(2) Click-on to launch the command-line terminal.
(3) Run the following command to disable the app auto-start service.
(4) Enter the command below to initiate the game.
ros2 launch app object_tracking_node.launch.py debug:=true
(5) Click to open a new terminal, then enter the following command to launch the camera. Once the live camera feed appears, click on the target area to select and capture its color.
ros2 service call /object_tracking/enter std_srvs/srv/Trigger {}
(6) Enter the following command to start tracking.
ros2 service call /object_tracking/set_running std_srvs/srv/SetBool data:\\ true
(7) To exit this mode, press Ctrl+C in the terminal. If it doesn’t close successfully, please try again multiple times.
After finishing this activity, you can start the mobile app service either by entering a command or by restarting the robot. If the mobile app service is not activated, app-related features will not function properly. (Note: The mobile app service will start automatically after a robot reboot.)
(8) Click and enter the command. Press enter to start the app, and wait for the buzzer to beep. Please enter the command in the system path, not in the Docker container.
8.7.3 Program Outcome
After starting the game, please ensure that no other objects containing the target color are within the camera’s field of view, as this may interfere with proper recognition and tracking.
Once the game starts, place the target object within the camera’s view. When the object is detected, it will be marked with a circle, and the robot will begin tracking it accordingly.
8.7.4 Program Analysis
Based on the observed behavior, review and organize the program’s logical flow as shown in the diagram below.
The source code for this program is located inside the Docker container at: /home/ubuntu/ros2_ws/src/app/app/object_tracking.py
(1) The main function is responsible for displaying the image, handling mouse events, and publishing chassis movement commands.
            cv2.imshow("result", result)
                self.set_callback = True
                # 设置鼠标点击事件的回调函数(Set a callback function for mouse click event)
                cv2.setMouseCallback("result", self.mouse_callback)
            k = cv2.waitKey(1)
            if k != -1:
(2) Pid calculates the data of the chassis motion
        if circle is not None:
            self.lost_target_count = 0  # 重置丢失计数器,因为找到了目标
            (x, y), r = circle
            x = x / self.pro_size[0] * w
            y = y / self.pro_size[1] * h
            r = r / self.pro_size[0] * w
            cv2.circle(result_image, (self.x_stop, self.y_stop), 5, (255, 255, 0), -1)
            if self.set_status == False:
                result_image = cv2.circle(result_image, (int(x), int(y)), int(r), (self.target_rgb[0],
        self.target_rgb[1],
        self.target_rgb[2]), 2)
                result_image = cv2.circle(result_image, (int(x), int(y)), int(r), self.range_rgb[self.set_color], 2)
            vx = 0
            vw = 0
            if abs(y - self.y_stop) > 20:
                self.pid_dist.update(y - self.y_stop)
                twist.linear.x = common.set_range(self.pid_dist.output, -0.45, 0.45)
                self.pid_dist.clear()
            if abs(x - self.x_stop) > 20:
                self.pid_yaw.update(x - self.x_stop)
                if self.machine_type == 'MentorPi_Acker':
                    steering_angle = common.set_range(-self.pid_yaw.output, -math.radians(40),
                                                       math.radians(40))
                    if steering_angle != 0:
                        R = 0.145 / math.tan(steering_angle)
                        twist.angular.z = -twist.linear.x / R
                    twist.angular.z = common.set_range(self.pid_yaw.output, -2, 2)
                self.pid_yaw.clear()
            return result_image, twist  # Target Found return twist
The received position data is used to calculate the offset from the target. A PID controller then computes the appropriate linear and angular velocities for the chassis, which are continuously published in a loop within the main function.
