7. Multiple Controller UART Communication Course
7.1 Master-Slave Device Communication Principles
7.1.1 Introduction
This section aims to introduce you to detailed information about the master-slave relationship between the WonderMV and different devices (such as STM32, 51 microcontroller, Arduino, and Raspberry Pi) during communication. It helps you understand how WonderMV communicates as a subordinate device with other devices and how other devices control WonderMV as a master device.
Understand the position and function of WonderMV within the entire system. This will facilitate the effective integration of this module, realizing the desired image processing and recognition functions.
In this chapter, WonderMV is typically utilized as a subordinate device. It uses the UART serial port to transmit the information to other devices.
7.1.2 Master-Slave Relationship
In a master-slave control system, WonderMV acts as a subordinate device and other devices such as microcontrollers act as master devices.
  • WonderMV Functions
(1) Image processing and recognition
The intelligent algorithms need specialized vision processors to accelerate the processing. Microcontrollers like the 51 microcontroller or Arduino cannot easily achieve image processing and recognition. The WonderMV vision module is specifically designed to execute image processing and recognition algorithms. It has dedicated intelligent processing hardware units, which can accelerate the processing of results.
(2) Generation of recognition results
WonderMV is responsible for generating visual recognition results. This may include information about detected objects, shapes, colors, and more.
(3) Data encapsulation and communication
WonderMV encapsulates the recognition results into data packets according to a predefined communication protocol, enabling them to be transmitted to the master device.
  • Other Master Devices
(1) Control coordination
The master is responsible for coordinating the entire system, ensuring there are no conflicts in communication and operation between WonderMV and other devices to maintain a stable working state.
(2) Data reception
The master receives the recognition result sent by WonderMV via the UART serial port. It verifies the integrity and accuracy of the received data and parses the data packet for extracting useful information.
(3) Result processing The master device analyzes the relevant results and responds to the information. For example:
① If a 51 microcontroller development board receives recognition information of the red ball from WonderMV, the positional information of the ball will be printed.
② If a LeArm robotic arm receives face recognition information from WonderMV, the specific location of the face will be parsed to control the robotic arm to track the face.
③ If a Tonybot humanoid robot receives waste card recognition information from WonderMV, the recognized waste will be classified. The classification result will be broadcasted.
7.1.3 Hardware Connection
The wiring methods for communication between the WonderMV and other different master devices are as follows.
The wiring for the WonderMV and the Arduino development board.
The wiring for the WonderMV and the STM32 development board.
The wiring for the WonderMV and the ESP32 development board.
The wiring for the WonderMV and the Raspberry Pi.
7.1.4 Data Transmission Format
The default UART serial data transmission format of WonderMV is as follows:
Baud rate Data bits Parity Stop bits
115200 8 None 1
7.1.5 Communication Protocol
Header Function Code Data Length Data Information CRC Checksum
0xAA 0x55 func len data crc
Header: When the header is received, it indicates the presence of data transmission;
Function Code: It indicates the function of an information frame;
Data Length: It indicates the amount of data that follows;
Data Information: It indicates the transmitted data information;
CRC Checksum: Calculate all the data from the function code to the data information to obtain CRC checksum value, and retain only the lower 8 bits.
7.1.6 Note
(1) The host device and the WonderMV can have different power sources, but they must share a common ground when connected to ensure stable communication voltage.
(2) When you wire the devices, ensure that the TX and RX pins of the UART serial port are crossed, otherwise communication will not be possible.
7.2 Color Learning Recognition
7.2.1 K210
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the host device, enabling color acquisition and recognition. The coordinates of the recognized object’s bounding box and the corresponding result will be printed on the terminal. Additionally, the recognition result will be sent to the host device via the UART serial port.
  • Getting Ready
(1) Device Connection
Connect the K210 vision module to a computer with a Type-C data cable.
Power the other master devices with their respective power interfaces, and connect the UART interfaces with DuPont cables.
For example, connect the ESP32 to the PC with a USB data cable. Then, connect the K210 vision module to the ESP32’s serial port with a DuPont cable.
(2) Download and Run K210 Program
① Double-click to open the software.
② Click in the bottom left corner.
③ Select the corresponding serial port number. Check “Advanced Settings”, and select “Mode-3”.
④ Click “OK” and wait for the connection to be completed.
⑤ After the connection is successful, the CanMV IDE displays the icon in the bottom left corner.
⑥ If the connection takes more than 10 seconds, it indicates a connection failure. Click “Cancel”, and a pop-up window shown below appears. Click “OK” and re-check the connection.
Tips for connection failure:
  • The selected serial port number is wrong.
Please unplug other serial ports connected to your PC. Try the above steps again to select the correct serial port number.
  • The cable used for the connection is not a data cable.
Use a Type-C data cable that supports data transmission. A Type-C data cable is included in the package before delivery.
  • Other K210 firmware is flashed.
Reflash the factory firmware, and then proceed with the connection.
There are two ways to run K210 programs: online and offline.
Online operation:
After connecting successfully, drag the program under the same folder as this lesson to the code editor area of CanMV IDE. Click the at the bottom left corner to run the program online.
Programs run in this way will be lost when the connection is disconnected or the device is shut down. They will not be saved on the K210 vision module.
Offline operation:
① After connecting, drag the program under the same directory to the CanMV IDE code editing area. Click “Tools” on the toolbar. Select “Save open script to CanMV Cam (as main.py)”.
② Click “Yes”.
③ Once the writing is successful, a window shown below will appear. Click “OK”. This saves the MicroPython file into the K210 Vision Module.
By downloading in this way, after powering on the K210 Vision Module without connecting, it will run the MicroPython file, enabling offline operation.
(3) Download and Run Master Device Program
Please refer to the relevant tutorial to download and run the master device program.
  • Program Outcome
(1) K210 Vision Module
After downloading the program, place the object to be recognized, such as a red block, within the field of view of the vision module.
① Move the red block into the white box. Only the area within the box is used for color acquisition.
② Click the “K1” button on the module to aim the appearing green box at the object to be captured and recognized. Only the area within the central box is used for color acquisition.
③ Once the object is successfully recognized, the green box will disappear. The recognized red object will be highlighted with a white box and a cross.
If you want to change the color to be recognized, you can restart the K210 module to start a new capture. If you want to capture multiple colors (up to three colors are supported), please access the directory of this program and download or run “multi_color_recognition”. The capture method remains the same as described above.
(2) Mater Device
Upon the program is downloaded, the master device will print the detailed information that is received and parsed. Take the ESP32 as an example.
After downloading the program, the ESP32 will print the coordinates of the bounding box and the detection results in the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the program analysis for the K210 vision module on the transmitter end. For an analysis of the program on the receiver end, please refer to the 6. AI Vision Games -> 6.11 Object Recognition .
(1) Load the vision module to obtain camera images.
Load the image module for image buffering and barcode processing.
Load the time module for calculating video frame rates.
Load the LCD module library for displaying images on an LCD screen.
Load the hw_uart module from the hiwonder library for serial communication.
Load the binascii module for byte processing.
#载入相关模块(load relevant modules)
import sensor, image, time, lcd
from hiwonder import hw_uart
import binascii
(2) Define the serial port transmission object.
#定义串口对象(define serial port object)
serial = hw_uart()
(3) Define a serial port transmission function. It encapsulates the recognized information based on the defined data format and transmits it via the serial port.
def send_data(x,y,w,h,msg):
    0xAA  0x55  功能号(function number)  数据长度(data length)  data  CRC
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.COLOR_RECOGNITION #功能编号(function number)
    Length = 0  #数据长度(data length)
    crc = 0 #校验位(checksum bit)
    data = [] #数据组(dataset)
    #参数都为0(all parameters are set to 0)
    if x==0 and y==0 and w==0 and h ==0:
        #x(小端模式)(little-endian mode)
        low = x & 0xFF #低位(low byte)
        high = x >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #y(小端模式)(little-endian mode)
        low = y & 0xFF #低位(low byte)
        high = y >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
                #w(小端模式)(little-endian mode)
        low = w & 0xFF #低位(low byte)
        high = w >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #h(小端模式)(little-endian mode)
        low = h & 0xFF #低位(low byte)
        high = h >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
        for i in range(len(msg)):
            msg_int = str_2_int(msg[i])
            data.append(msg_int)
    Length += len(data)
    send_buf = [FUNC_num,Length]
    for i in range(len(data)):
        send_buf.append(data[i])
    #进行CRC运算(perform a CRC calculation)
    crc = checksum_crc8(send_buf)
    send_buf.insert(0,START_1) #插入协议头1(insert protocol header 1)
    send_buf.insert(1,START_2) #插入协议头2(insert protocol header 1)
    send_buf.append(crc) #加入CRC校验码(incorporate the CRC checksum)
    print(send_buf) #打印数据(print data)
    serial.send_bytearray(send_buf) #发送数据(send data)
(4) Define the sent data storage variables. The send_x and send_y represent the x and y values of the top-left corner coordinates of the recognition bounding box. The send_msg represents the specific information extracted from the image.
#定义发送数据(define the transmitted data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
(5) Initialize the LCD screen and the camera.
#初始化LCD(initialize LCD)
lcd.init()
#以下是初始化传感器(initialize sensors)
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QVGA)
sensor.skip_frames(time = 100)
sensor.set_auto_gain(False)
sensor.set_auto_whitebal(False)
(6) Define a clock counter for calculating frame rate.
#帧率时钟(frame rate clock)
clock = time.clock()
(7) Define parameters for the bounding box and display the initial bounding box.
#方框参数(box parameters)
r = [(320//2)-(50//2), (240//2)-(50//2), 50, 50]
#显示方框(display box)
for i in range(50):
    img = sensor.snapshot()
    img.draw_rectangle(r)
    lcd.display(img)
(8) Continuously obtain images and perform the average learning for the recognized color within the bounding box.
#开始学习(start learning)
print("Start learning ...")
threshold = [50, 50, 0, 0, 0, 0] # L、A、B 值(L, A, and B values)
for i in range(50):
    hist = img.get_histogram(roi=r) # 获取图像的直方图(obtain the histogram of an image)
    lo = hist.get_percentile(0.01)  # 获取直方图在1%范围内的累积分布函数(根据需要进行调整)!(obtain the cumulative distribution function of the histogram within a 1% range (adjust as needed)!)
    hi = hist.get_percentile(0.99)  # 获取直方图在99%范围内的累积分布函数(根据需要进行调整)!(obtain the cumulative distribution function of the histogram within a 99% range (adjust as needed)!)
    # 将百分位值进行平均。(calculate the average of the percentile values)
    threshold[0] = (threshold[0] + lo.l_value()) // 2
    threshold[1] = (threshold[1] + hi.l_value()) // 2
    threshold[2] = (threshold[2] + lo.a_value()) // 2
    threshold[3] = (threshold[3] + hi.a_value()) // 2
    threshold[4] = (threshold[4] + lo.b_value()) // 2
    threshold[5] = (threshold[5] + hi.b_value()) // 2
    # 在图像中找到颜色块(locate the color block in the image)
    for blob in img.find_blobs([threshold], pixels_threshold=100, area_threshold=100, merge=True, margin=10):
        img.draw_rectangle(blob.rect()) # 在颜色块的位置绘制矩形(draw a rectangle at the location of the color block)
        img.draw_cross(blob.cx(), blob.cy()) # 在颜色块的中心位置绘制十字(draw a cross at the center of the color block)
        img.draw_rectangle(r, color=(0,255,0)) # 在 ROI 区域绘制矩形,标记学习的区域(draw a rectangle in the ROI region to mark the learned region)
    # 在 LCD 屏幕上显示图像(display image on the LCD screen)
    lcd.display(img)
(9) After the learning process is completed, enter the main loop.
#loop
while(True):
(10) Obtain the image from the sensor and perform color recognition.
    #从传感器捕获一张图像(capture an image from the sensor)
(11) Locate the corresponding color threshold area within the recognized image. Once the corresponding color area is detected, enclose it with a bounding box on the image.
    #遍历图像中找到的颜色区块(iterate through the color blocks found in the image)
        #绘制矩形和十字标记(draw a rectangle and cross)
        #将方框数据与消息赋值(assign values to box data and message)
        send_x = blob.x()
        send_y = blob.y()
        send_w = blob.w()
        send_h = blob.h()
        send_msg = 'u'
(12) Upon detecting information, use the send_data() function to transmit the information via the serial port.
    # 当消息标志为 'u' 时,发送数据(注意,即使x、y、w、h数据不变也会进入此条件)(When the message flag is set to 'u', transmit the data (note that this condition is triggered even if the x, y, w, and h data remain unchanged))
    if send_msg == 'u':
        #发送数据(send data)
        send_data(send_x,send_y,send_w,send_h,None)
        send_msg = ""  # 清空消息变量(clear message variables)
    lcd.display(img) #显示在LCD上(display on the LCD)
    print(clock.fps()) #打印帧率(print the frame rate)
(13) Display the image on the LCD screen and print the frame rate.
7.2.2 Arduino UNO
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by Arduino UNO.
  • Game Introduction
Send the learned color data to Arduino UNO via the K210 vision module.
  • Getting Ready
(1) Module Connection
① Connect the K210 vision module to a computer with a Type-C data cable.
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding GND, D6, and D7 pins on the Arduino UNO with a DuPont wire.
(2) Download and Run Program
① Locate and open “color_recognition” program file in the same folder as this lesson.
② In the “Select board” option, select the corresponding Arduino development board and port. Take “Arduino Uno” and “COM8” as an example to demonstrate. The COM port is not unique. You can check the COM port number in the computer’s device manager.
③ Click button to compile the program. After the compilation is completed, click to upload the program into the Arduino development board.
  • Program Outcome
Open the Arduino IDE, the coordinates information of the red block is visible. Select the baud rate to 115200.
The touch screen of K210 vision module has a resolution of 320*240. The origin of its pixel coordinates located at the top left corner of the module, as illustrated in the diagram below:
The x and y represent the pixel coordinates of the red block along the X and Y axes, respectively. The h and w denote the height and width of the block in units of px.
(1) Initialize program
The program begins by initializing the communication through the serial port, with the baud rate set to 115200. This establishes a connection for communication with the K210 controller via the serial port.
  Serial.begin(115200);
  //开启串口接收(enable serial port receiving)
  wk.serial_begin();
The function Wk.serial_begin() is used to initialize the serial communication on the K210, enabling the MCU to establish a connection with the K210 through serial communication.
(2) Loop to obtain the latest color recognition
void loop() {
  //更新消息(updata message)
  wk.update_data();
  //获取消息(obtain message)
  bool rt = wk.recive_box(&result , K210_COLOR_RECOGNITION);
  //若获取到新的消息(if a new message is obtained)
After entering the loop() function, use the wk.update_data() function to continuously obtain the latest color recognition results from the K210 vision module. Then, acquire and parse the data of the latest recognized frame’s structure, storing it in the result variable.
(3) Print result information
If a new result is obtained (rt is true), the serial port will print detailed coordinates and dimensions of the recognition frame.
void loop() {
  wk.update_data();
  if(rt)
    Serial.print("x:");
    Serial.println(result.x);
    Serial.print("y:");
    Serial.println(result.y);
    Serial.print("w:");
    Serial.println(result.w);
    Serial.print("h:");
    Serial.println(result.h);
7.2.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling color learning recognition. The coordinates of the recognized object’s bounding box will be printed on the terminal.
  • Getting Ready
(1) Wiring Instruction
② Connect the ESP32 to the PC with a USB data cable. Then, connect the K210 vision module to the ESP32’s serial port with a 4PIN wire.
Online operation:
Offline operation:
② Click “Yes”.
(3) Download and Run ESP32 Program
① Connect the ESP32 controller to the computer with a USB data cable. Open the Python editor. Drag the programs “WonderK210.py” and “main.py” into the editor interface.
② Select the or click “Connect” in the menu bar to choose the corresponding COM port. Let’s use “COM15” as an example. The COM port is not unique. You can check the COM port number in the computer’s device manager.
To avoid encountering any unexpected anomalies during the flashing process, please strictly follow the operation steps.
In you encounter difficulties in properly reading the COM port or downloading the program, please refer to the “ESP32 Board Firmware Recovery Method” to reflash the firmware.
③ After the connection is established, click or “Run - Download and Run” to download the program into the controller and execute it.
  • Program Outcome
Print the coordinates of the bounding box for the recognized object in the terminal.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games -> 6.1 Color Acquisition and Recognition .
(1) Import Module
Import the time module, the WonderK210 communication class, and the message format classes ( Find_Box_Msg_st, Find_Box_st, and Find_Msg_st) for subsequent usage.
# 载入时间模块(load time module)
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st)
from WonderK210 import WonderK210 , Find_Box_Msg_st , Find_Box_st , Find_Msg_st
(2) Establish Communication
Instantiate the K210 communication class.
# 实例化K210通信类(instantiate K210 communication class)
wk = WonderK210()
Enable the serial port.
# 开启串口(start serial port)
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_color_recognition() searches for specific color in the data and retrieve the received messages.
  # 更新接收消息(update receiving message)
  wk.update_data()
  # 获取接收消息(obtain receiving message)
  ret = wk.find_color_recognition()
If a recognition result is found (ret is not None), the coordinates of the bounding box for the recognized object will be printed. The x and y represent the top-left coordinates of the box in the image, the w denotes the width of the box, and the h represents the height of the box.
  # 若有新消息获取到(if a new message is obtained)
  if ret is not None:
    # 打印消息内容(print message content)
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
  # 延时10ms(delay for 10ms)
  time.sleep_ms(10)
(4) Information Obtaining Function
  # 颜色学习识别 box(color learning recognition box)
  def find_color_recognition(self):
    if True == self.__read_succeed: # 若有新消息(if there is a new message)
      if k210_PACKET_FUNCTION.COLOR_RECOGNITION == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_color_recognition()")
        self.__read_succeed = False
        ret = Find_Box_st()
        ret.function = self.__pk_result.function
        ret.x = (self.__pk_result.data[0] & 0x00FF) | ((self.__pk_result.data[1] << 8 ) & 0xFF00)
        ret.y = (self.__pk_result.data[2] & 0x00FF) | ((self.__pk_result.data[3] << 8 ) & 0xFF00)
        ret.w = (self.__pk_result.data[4] & 0x00FF) | ((self.__pk_result.data[5] << 8 ) & 0xFF00)
        ret.h = (self.__pk_result.data[6] & 0x00FF) | ((self.__pk_result.data[7] << 8 ) & 0xFF00)
        # 清除存储变量(clear storage variables)
        self.__pk_result.data.clear()
        return ret
        return None
      return None
When a new message of the color recognition is received, this function will extract the position information of the recognized color box.
Firstly, it checks if the self.__read_succeed is True. If the message reading is successful, it then verifies if the self.__pk_result.function is the predefined COLOR_RECOGNITION function message. If it is a color recognition message, the following steps are performed:
① Print a message indicating that a color recognition message has been found.
② Set the self.__read_succeed to False, indicating that this message has been successfully processed.
③ Create an object named ret, which is an instance of the Find_Box_st class.
④ Extract the coordinate and dimension information from the color recognition result, and assign them to the corresponding attributes (x, y, w, and h) of the ret object.
⑤ Clear the variable self.__pk_result.data that stores message data.
⑥ Return the ret object containing the extracted recognition result information.
⑦ If a new message is not successfully read or the received message is not a color recognition message, return None.
7.2.4 STM32
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by STM32.
  • Game Introduction
Send the learned color data to STM32 via the K210 vision module.
  • Getting Ready
Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding pins on the STM32 with a DuPont wire.
① Locate and open “RosRobotControllerM4.uvprojx” program file in the same folder as this lesson.
② Click to perform compiling. After the compiling is completed, click to download the program to the STM32 board.
  • Program Outcome
Once the program runs, the STM32 will obtain the coordinates of the learned color from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
(1) Initial Settings
#include "k210_packet.h"
#include "global.h"
The “k210_packet.h” consists of data structure definitions, function declarations, and macros related to the K210. It is used to handle data packets, communication protocols, or device control related to the K210. The file “global.h” contains global constants, variables, and more.
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
Struct BoxData: a structure BoxData is defined. It contains four uint16_t type member variables: x, y, w, and h. These variables represent the position and size of a rectangular box.
//只有方框数据(only includes box data)
typedef struct {
	BoxData box;
}Find_Box_st;
Struct Find_Box_st: a structure Find_Box_st is defined. It contains a variable box of BoxData type. This structure represents a data type that includes only the information of a rectangular box, excluding other message data.
//有方框数据和消息数据(include box data and message data)
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
Struct Find_Box_Msg_st: a structure Find_Box_Msg_st is defined. It contains a variable of type BoxData named box and an array of uint8_t type with a length of 100 named msg. This structure represents a data type that includes both the information of a rectangular box and a message data with a length of 100.
//只有消息数据(only includes message data)
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
Struct Find_Msg_st: a structure Find_Msg_st is defined. It contains a single array of uint8_t type with a length of 100 named msg. This structure represents a data type that includes only the message data with a length of 100 and does not include the information of a rectangular box.
(2) Message Data Processing
* @brief 只有方框数据 的回调处理(callback processing for only including box data)
* @param frame 数据帧(data frame)
* @retval void
static void k210_Box_cb(struct k210_PacketRawFrame *frame)
    Find_Box_st *rec = (Find_Box_st*)frame->data_and_checksum;
	printf("x:%d,y:%d,w:%d,h:%d\n",rec->box.x,rec->box.y,rec->box.w,rec->box.h);
k210_Box_cb: handles data frames that only contain box data. It extracts data of type Find_Box_st from the data frame. It prints the position and size information of the box based on the extracted data.
* @brief 有方框数据和消息数据 的回调处理(callback processing for including box data and message data)
* @retval void
static void k210_Box_Msg_cb(struct k210_PacketRawFrame *frame)
    Find_Box_Msg_st *rec = (Find_Box_Msg_st*)frame->data_and_checksum;
	rec->msg[frame->data_length - 8] = '\0'; //将check位清除(clear check bit)
	printf("msg:%s\n",rec->msg);
k210_Box_Msg_cb: handles data frames that contain both box data and message data.
It extracts data of type Find_Box_Msg_st from the data frame. It prints the position and size information of the box based on the extracted data. It clears the checksum of the message data and then prints the message content.
* @brief 只有消息数据 的回调处理(callback processing for only including message data)
* @retval void
static void k210_Msg_cb(struct k210_PacketRawFrame *frame)
    Find_Msg_st *rec = (Find_Msg_st*)frame->data_and_checksum;
	rec->msg[frame->data_length] = '\0'; //将check位清除(clear check bit)
k210_Msg_cb: handles data frames that only contain message data. It extracts data of type Find_Msg_st from the data frame. It clears the checksum of the message data and then prints the message content. These functions serve as callback functions. When receiving specific types of data frames, these functions are called to process the data within the frames.
(3) Callback Function
//注册回调函数(register callback function)
void k210_packet_handle_init(void)
    k210_packet_register_callback(&k210_packet_controller, K210_COLOR_RECOGNITION, k210_Box_cb); //颜色识别(color recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_BARCODES, k210_Box_Msg_cb); //条形码识别(barcode recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_QRCODES, k210_Box_Msg_cb);	 //二维码识别(QR code recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_APRILTAGS, k210_Box_Msg_cb);//机器码识别(AprilTag recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACE_YOLO, k210_Box_cb); 	 //人脸检测(face detection)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACEFEATURE, k210_Box_cb);  //人脸特征识别(face feature recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACEMASK, k210_Box_Msg_cb); //口罩识别(mask recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_OBJECT, k210_Box_Msg_cb);	 //物体识别(object recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_SELF_LEARNING, k210_Msg_cb);//自主学习分类(autonomous learning and classification)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_DIGITAL, k210_Msg_cb);      //手写数字识别(handwritten number recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACE_RECOGNITION, k210_Box_Msg_cb); //物体识别(object recognition)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_RED_FOLLOW, k210_Box_cb); //红色追踪(red tracking)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_SIGNPOST_FOLLOW, k210_Box_Msg_cb); //路标追踪(road sign tracking)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_DIGITAL_CARD, k210_Box_Msg_cb); //数字卡片识别(number card recognition)
    k210_packet_register_callback(&k210_packet_controller, K210_GARBAGE_SORTING, k210_Box_Msg_cb); //垃圾分类(waste classification)
    k210_packet_register_callback(&k210_packet_controller, K210_COLOR_SORTING, k210_Box_Msg_cb); //多种颜色识别(multiple colors recognition)
Multiple callback functions are registered through the function k210_packet_handle_init. Each callback function corresponds to a different processing program. These callback functions are associated with different functional modules related to the K210. Each module corresponds to a different recognition or data processing task.
Each call to k210_packet_register_callback associates a specific task’s processing function with the K210 controller. For example:
K210_COLOR_RECOGNITION corresponds to the color recognition task and uses the function k210_Box_cb to process the data.
K210_FIND_BARCODES corresponds to the barcode recognition task and uses the function k210_Box_Msg_cb to process the data.
Similar cases exist for other tasks. Take k210_packet_register_callback(&k210_packet_controller, K210_COLOR_RECOGNITION, k210_Box_cb) as an example:
① The k210_packet_register_callback function is used to associate the callback function k210_Box_cb with a specific task type K210_COLOR_RECOGNITION.
&k210_packet_controller is a pointer to the K210 controller. It provides interfaces and methods for handling different tasks.
K210_COLOR_RECOGNITION is a specific function code. It represents the function that K210 needs to perform.
k210_Box_cb is a callback function. It will be called when data associated with the task type K210_COLOR_RECOGNITION is received.
Each callback function receives data frames from the K210 controller and uses specific processing functions based on the task type to handle the data.
7.2.5 Raspberry Pi
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by Raspberry Pi.
  • Game Introduction
Send the learned color data to Raspberry Pi via the K210 vision module.
  • Getting Ready
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding pins on the Raspberry Pi with a DuPont wire.
① Move the program files “main.py” and “WonderK210.py” from the current directory to Raspberry Pi via a USB drive.
② Press “Ctrl+Alt+T” in the Raspberry Pi system to open the command line terminal.
③ In the command line terminal, enter the command to navigate to the directory where the program is located:
cd Desktop/
④ Enter the command to start the program:
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will retrieve the coordinate information of learned color from the K210 vision module and print it in the terminal.
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st),K210识别类型类(k210_PACKET_FUNCTION)
from WonderK210 import WonderK210 , Find_Box_Msg_st , Find_Box_st , Find_Msg_st , k210_PACKET_FUNCTION
Load the K210 communication class (WonderK210), message format class (Find_Box_Msg_st, Find_Box_st, Find_Msg_st), and K210 recognition type class (k210_PACKET_FUNCTION).
(2) Create Object
Instantiate the K210 communication class, and simultaneously activate the serial port.
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Use the function wk.update_dat() to update data. Call the function wk.find_box() to obtain the received message.
When a new message is obtained, the contents related to the target color will be printed.
#loop
    wk.update_data()
    ret = wk.find_box(k210_PACKET_FUNCTION.COLOR_RECOGNITION)
    if ret is not None:
        print("ret.x = {}".format(ret.x))
        print("ret.y = {}".format(ret.y))
        print("ret.w = {}".format(ret.w))
        print("ret.h = {}".format(ret.h))
7.3 Multiple Colors Recognition
7.3.1 K210
  • Game Introduction
In this program, the color thresholds have been predefined. It can directly recognize five colors: red, green, blue, yellow, and purple without the need of capturing. When these five colors are recognized, they will be highlighted in green boxes. The recognized data will be sent to the master device via the serial port.
  • Getting Ready
⑤ Click “OK” and wait for the connection to be completed.
⑥ After the connection is successful, the CanMV IDE displays the icon in the bottom left corner.
⑦ If the connection takes more than 10 seconds, it indicates a connection failure. Click “Cancel”, and a pop-up window shown below appears. Click “OK” and re-check the connection.
There are two ways to run K210 programs: online and offline. Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After running the program, the K210 vision module will select the recognized objects in the color of red, green, blue, yellow, and purple with boxes, as shown below:
(2) Mater Device
(1) Load the hw_uart module from the hiwonder library for serial communication.
import sensor
import image
import lcd
import binascii
serial = hw_uart()
    0xAA  0x55  功能号  数据长度  data  CRC
    START_1 = 0xAA
    START_2 = 0x55
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
            #msg
    if msg != None:
    Length += len(data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
(5) Initialize the LCD screen. Restart the camera module. Set its pixel mode to RGB565 and the image size to QVGA. Disable automatic gain and automatic white balance.
lcd.init()
sensor.reset()
(6) Define a clock object for calculating frame rate.
(7) Set LAB thresholds for recognizing different colors. Store LAB thresholds for five colors. Define a color string for displaying the recognized color name.
# 储存6种颜色的LAB阈值(store the LAB threshold of the six colors)
color_thresholds = [
    (15,80,15,62,15,35), # Red
    (14, 61, -39, -6, 0, 14),  # Green
    (21,50,-7,8,-35,-11), # Blue
    (65, 78, -10, -5, 38, 50),     # Yellow
    (20, 50, 17, 37, -34, -14),      # purple
color_strings = ['Red', 'Green', 'Blue', 'Yellow', 'purple']
(8) Create a color recognition loop:
The program enters an infinite loop, capturing an image in each iteration.
Use the find_blobs method to iterate through all the defined color thresholds and identify color regions in the image.
For each recognized color, draw a rectangle and a cross, display the color name next to it, and send out the recognized data via the UART serial port.
Display the processed image on the LCD screen and print the current frame rate.
#loop
    #用于计算帧率的函数,这里表示开始计时(The function for calculating the frame rate, indicating the start of timing)
    #clock.tick()
    #遍历多种颜色(iterate through multiple colors)
    for color_idx, threshold in enumerate(color_thresholds):
        blobs = img.find_blobs([threshold], pixels_threshold=100, area_threshold=100, merge=True, margin=10)
        #是否找到(whether it is found)
        if blobs:
            area_max = 0
            blob_max = blobs[0]
            #寻找最大的颜色块(find the largest color block)
            for blob in blobs:
                area = blob.w()*blob.h()
                if(area_max < area):
                    blob_max = blob
                    area_max = area
            if area_max < 2000:
            #画方框(draw box)
            img.draw_rectangle(blob_max.rect())
            img.draw_cross(blob_max.cx(), blob_max.cy())
            img.draw_string(blob_max.cx() + 10, blob_max.cy() - 10, color_strings[color_idx], color=(255, 255, 255))
            send_x = blob_max.x()
            send_y = blob_max.y()
            send_w = blob_max.w()
            send_h = blob_max.h()
            #发送数据(send data)
            send_data(send_x,send_y,send_w,send_h,color_strings[color_idx])
    lcd.display(img)
    #print(clock.fps())
7.3.2 Arduino UNO
  • Game Introduction
Send the recognized color data to Arduino UNO via the K210 vision module.
  • Getting Ready
① Locate and open the “5.3.2 find_multi_color.ino” program file in the same folder as this lesson.
  • Program Outcome
Open the Arduino IDE serial monitor, the coordinates information of the recognized block is visible. Select the baud rate to 115200.
The msg represents the color name of the recognized target. If green is recognized, print “Green”. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the block in units of px.
  //分配内存(allocate memory)
  wk = malloc(sizeof(WonderK210));
  //这里不需要再调用初始化串口函数 Serial.begin(115200); 在 serial_begin() 函数里已经初始化了(Since the initialization of the serial port has already been performed within the serial_begin() function, there is no need to call Serial.begin(115200))
  wk->serial_begin();
  result = malloc(sizeof(Find_Box_Msg_st));
void loop() {
  wk.update_data();
(3) Printing result information
void loop() {
  wk.update_data();
  if(rt)
    Serial.print("x:");
    Serial.println(result->x);
    Serial.print("y:");
    Serial.println(result->y);
    Serial.print("w:");
    Serial.println(result->w);
    Serial.print("h:");
    Serial.println(result->h);
    Serial.print("msg:");
    Serial.println(result->msg);
7.3.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling multiple colors recognition. The coordinates of the recognized color and recognition result will be printed on the terminal.
  • Getting Ready
① Download and Run K210 Program
② Double-click to open the software.
③ Click in the bottom left corner.
④ Select the corresponding serial port number. Check “Advanced Settings”, and select “Mode-3”.
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After downloading the program, the ESP32 will print the coordinates of the recognized color and the detection results in the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games -> 6.2 Multiple Colors Recognition .
(1) Import Module
Import the time module, the WonderK210 communication class, and the message format classes (Find_Box_Msg_st, Find_Box_st, and Find_Msg_st) for subsequent usage.
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st), 功能号(function number)(k210_PACKET_FUNCTION)
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function ret = wk.find_box_msg (k210_PACKET_FUNCTION.K210_COLOR_SORTING) searches for target in the data and retrieve the received messages.
#loop
  wk.update_data()
  ret = wk.find_box_msg(k210_PACKET_FUNCTION.K210_COLOR_SORTING)
If a recognition result is found (ret is not None), the recognition result will be printed. The x and y represent the top-left coordinates of the box in the image, the w denotes the width of the box, the h represents the height of the box, and the msg is the recognition result.
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  time.sleep_ms(10)
# 有方框数据和消息数据(there is data for the box and the message)
class Find_Box_Msg_st:
  def __init__(self):
    self.function = 0
    self.x = 0
    self.y = 0
    self.w = 0
    self.h = 0
    self.msg = [0x00] * 200
The class Find_Box_st is defined, which has the following attributes:
function: Represents a specific function or state.
x: Represents the x-coordinate of the box.
y: Represents the y-coordinate of the box.
w: Represents the width of the box.
h: Represents the height of the box.
msg: A list with a length of 200, used to store message data.
7.3.4 STM32
  • Game Introduction
Send the recognized color data to STM32 via the K210 vision module.
  • Getting Ready
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding pins on the STM32 with a DuPont wire.
  • Program Outcome
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
7.3.5 Raspberry Pi
  • Game Introduction
Send the recognized color data to Raspberry Pi via the K210 vision module.
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
#loop
  wk.update_data()
  if ret is not None:
        print("ret.msg = {}".format(ret.msg))
7.4 Barcode Recognition
7.4.1 K210
  • Game Introduction
In this section, the K210 vision module is used to recognize the barcode. If the barcode is recognized, it will be selected with a box. The coordinates of the recognized object’s bounding box and the recognition result will be printed on the terminal. Additionally, the recognition result will be sent to the master device via the serial port.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After running the program, the program will select the recognized barcode with a rectangle box and display the recognized result on the LCD screen.
(2) Mater Device
import sensor, image, time, math, lcd
import binascii
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_BARCODES #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
(5) Initialize the LCD screen. Restart and set up the camera module by setting the pixel mode to RGB565, the image size to QVGA. Skip the first 100 images before program execution. Set the camera to automatically adjust the gain for light sensitivity.
lcd.init()
sensor.reset()
sensor.set_pixformat(sensor.RGB565) #GRAYSCALE
sensor.set_auto_gain(True)
(6) Create a frame rate clock for measuring the frame rate.
(7) Enter the while loop, which continuously recognizes barcodes from camera images.
#loop
(8) Start the timer for frame rate computation.
    clock.tick()
(9) Capture an image from the camera using the snapshot() function. Detect barcodes in the image using the find_barcodes() function from the image module.
    #获取传感器图像(obtain sensor image)
    #计算帧率(calculate frame rate)
    fps = clock.fps()
    #尝试从图像中识别条形码(try to recognize the barcode from the image)
    barcodes = img.find_barcodes()
(10) If a barcode is detected, select the whole barcode region and draw relevant data.
Then, send out the data via UART serial port.
    if barcodes:
        for code in barcodes:
            #绘制矩形(draw rectangle)
            img.draw_rectangle(code.rect(), color=(0, 255, 0))
            send_x = code.x()
            send_y = code.y()
            send_w = code.w()
            send_h = code.h()
            send_msg = code.payload()
    # 当消息标志不为 '' 时,发送数据(When the message flag is not '', transmit the data)
    if send_msg != '':
        send_data(send_x,send_y,send_w,send_h,send_msg)
        send_msg = '' # 清空消息变量(clear message variables)
    #在LCD上显示帧率(display frame rate on the LCD)
    img.draw_string(0, 0, "%2.1ffps" %(fps), color=(0, 60, 128), scale=2.0)
    lcd.display(img)
(11) Display the frame rate and show the processed image on the LCD screen.
    lcd.display(img)
7.4.2 Arduino UNO
  • Game Introduction
  • Getting Ready
① Locate and open the “5.4.2_find_barcodes.ino” program file in the same folder as this lesson.
① Click button to compile the program. After the compilation is completed, click to upload the program into the Arduino development board.
  • Program Outcome
Open the Arduino IDE serial monitor, the recognition result and the coordinates information of the recognized barcode are visible. Select the baud rate to 115200.
The msg represents the content of the recognized target barcode. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
  wk->serial_begin();
void loop() {
  wk.update_data();
void loop() {
  wk.update_data();
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.4.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling barcode recognition. The coordinates of the recognized bounding box for the barcode and the recognition result will be printed on the terminal.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After downloading the program, the ESP32 will print the coordinates of the recognized bounding box of the barcode and the detection result in the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6.AI Vision Games -> 6.3 Barcode Recognition .
(1) Import Module
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_barcodes() searches for barcode in the data and retrieve the received messages.
#loop
  wk.update_data()
  ret = wk.find_barcodes()
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  time.sleep_ms(10)
  # 条形码识别 box msg(barcode recognition box msg)
  def find_barcodes(self):
      if k210_PACKET_FUNCTION.FIND_BARCODES == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_barcodes()")
        ret = Find_Box_Msg_st()
        if self.__pk_result.data_length > 8:
          ret.msg = ''.join(chr(value) for value in self.__pk_result.data[8:])
        return ret
        return None
      return None
This function is used to extract the position information of the recognized barcode frame when a new message is received and the message type is barcode recognition.
Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined COLOR_RECOGNITION function message. If it is a barcode message, the following steps are performed:
① Print a message indicating that a barcode message has been found.
② Set self.__read_succeed to False, indicating that this message has been successfully processed.
④ Extract the coordinate and size information from the barcode recognition result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
⑤ If the length of the message data is greater than 8, convert the remaining part of the data into a string. Assign it to the msg attribute of the ret object.
⑥ Clear the variable self.__pk_result.data that stores the message data.
⑦ Return the ret object that contains the extracted recognition result information.
If a new message is not successfully read or the received message is not a barcode recognition message, None is returned.
7.4.4 STM32
  • Game Introduction
Send the recognized barcode information to STM32 via the K210 vision module.
  • Getting Ready
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized barcode information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
7.4.5 Raspberry Pi
  • Game Introduction
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will retrieve the coordinate information and content of the recognized barcode from the K210 vision module and print it in the terminal.
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st),K210识别类型(K210 recognition class)(k210_PACKET_FUNCTION)
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
When a new message is obtained, the detection result of the recognized barcode will be printed. It includes the position (x, y, w, h) of the barcode and its recognized content.
#loop
    wk.update_data()
    ret = wk.find_box_msg(k210_PACKET_FUNCTION.FIND_BARCODES)
    if ret is not None:
7.5 QR Code Recognition
7.5.1 K210
  • Game Introduction
In this section, the K210 vision module is used to recognize the QR code. If the QR code is recognized, it will be selected with a box and displayed on the vision module. Additionally, the recognition result will be sent to the master device via the UART serial port.
  • Getting Ready
Online operation:
Offline operation:
① Click “Yes”.
② Once the writing is successful, a window shown below will appear. Click “OK”. This saves the MicroPython file into the K210 Vision Module.
  • Program Outcome
After running the program, the K210 vision module will highlight the recognized QR code with a box and display the recognition result on the screen.
(2) Mater Device
import binascii
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_QRCODES #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
(4) Define the sent data storage variables. The send_x and send_y represent the x and y values of the top-left corner coordinates of the bounding box. The send_msg represents the specific information extracted from the image.
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
lcd.init()
sensor.reset()
(7) Enter the while loop to perform image recognition.
#loop
while(True):
    clock.tick()
(10) If a QR code is detected, select the whole QR code region and display relevant data. Then, send out the data via UART serial port.
    #遍历图像中找到的二维码(interate through images to fine QR code)
    for code in img.find_qrcodes():
        #绘制矩形和识别出的信息(draw rectangle and recognized information)
        img.draw_rectangle(code.rect(), color = 127, thickness=3)
        img.draw_string(code.x(),code.y()-20,code.payload(),color=(255,0,0),scale=2)
        send_x = code.x()
        send_y = code.y()
        send_w = code.w()
        send_h = code.h()
    if send_msg != "":
        #发送数据(send data)
        send_msg = ""   # 清空消息变量(clear message variable)
    lcd.display(img)
7.5.2 Arduino UNO
  • Game Introduction
  • Getting Ready
① Locate and open the “5.5.2_find_qrcodes.ino” program file in the same folder as this lesson.
  • Program Outcome
After running the program, the K210 vision module will highlight the recognized QR code with a box. The recognition result will be displayed on its screen.
Open the Arduino IDE serial monitor, the recognition result and the coordinates information of the recognized QR code are visible. Select the baud rate to 115200.
The msg represents the content of the recognized target QR code. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
  wk->serial_begin();
void loop() {
  wk->update_data();
  bool rt = wk->recive_box_msg(result , K210_FIND_QRCODES);
void loop() {
  wk->update_data();
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.5.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling QR code recognition. The coordinates of the recognized bounding box for the QR code and the recognition result will be printed on the terminal.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After downloading the program, the ESP32 will print the coordinates of the recognized bounding box of the QR code and the detection result in the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games -> 6.4 QR code Recognition .
(1) Import Module
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_QR codes() searches for QR code in the data and retrieve the received messages.
  wk.update_data()
  ret = wk.find_qrcodes()
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  time.sleep_ms(10)
        return ret
        return None
      return None
This function is used to extract the position information of the recognized QR code frame when a new message is received and the message type is QR code recognition.
Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined COLOR_RECOGNITION function message. If it is a QR code message, the following steps are performed:
Print a message indicating that a QR code message has been found.
① Set self.__read_succeed to False, indicating that this message has been successfully processed.
② Create an object named ret, which is an instance of the Find_Box_st class.
③ Extract the coordinate and size information from the QR code recognition result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
④ If the length of the message data is greater than 8, convert the remaining part of the data into a string. Assign it to the msg attribute of the ret object.
⑤ Clear the variable self.__pk_result.data that stores the message data.
⑥ Return the ret object that contains the extracted recognition result information.
⑦ If a new message is not successfully read or the received message is not a QR code recognition message, None is returned.
7.5.4 STM32
  • Game Introduction
  • Getting Ready
  • Program Outcome
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
⑤ Each callback function receives data frames from the K210 controller and uses specific processing functions based on the task type to handle the data.
7.5.5 Raspberry Pi
  • Game Introduction
Send the recognized QR code data to Raspberry Pi via the K210 vision module.
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will retrieve the coordinate information and content of the recognized QR code from the K210 vision module and print it in the terminal.
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st),K210识别类型类(K210 recognition class)(k210_PACKET_FUNCTION)
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
When a new message is obtained, the detection result of the recognized QR code will be printed. It includes the position (x, y, w, h) of the QR code and its recognized content.
#loop
    wk.update_data()
    ret = wk.find_box_msg(k210_PACKET_FUNCTION.FIND_QRCODES)
    if ret is not None:
7.6 AprilTag Recognition
7.6.1 K210
  • Game Introduction
AprilTag is a visual fiducial system, useful for a wide variety of tasks including augmented reality, robotics, and camera calibration. Targets can be created from an ordinary printer. The AprilTag detection software computes the precise 3D position, orientation, and identity of the tags relative to the camera.
For more details about AprilTag, please access the AprilTag official website at https://april.eecs.umich.edu/software/apriltag.html.
In this lesson, the WonderMV will be programmed to box the information of the recognized AprilTag and display it on the screen. Additionally, the recognition result will be sent to the master device via the serial port.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After running the program, the K210 vision module will select the recognized AprilTag with a box.
(2) Mater Device
It prints the coordinates of the AprilTag’s bounding box and the detection results on the terminal. The message “crc ok” indicates that the checksum is correct.
Load the image module for image buffering and AprilTag processing.
import binascii
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_APRILTAGS #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
(4) Define the sent data storage variables. The send_x and send_y represent the x and y values of the top-left corner coordinates of the recognition box. The send_msg represents the specific information extracted from the image.
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
(5) Initialize the LCD screen. Restart the camera module. Set its pixel mode to RGB565 and the image size to QVGA. Skip the first 100 images before program execution. Set the camera to automatically adjust the gain for light sensitivity.
lcd.init()
sensor.reset()
sensor.set_framesize(sensor.QQVGA)
#sensor.set_framesize(sensor.QVGA)
(7) Set a mask to specify the AprilTag that the program will recognize.
#设置机器码掩码(set AprilTag mask)
tag_families = 0
tag_families |= image.TAG16H5   # comment out to disable this family
tag_families |= image.TAG25H7   # comment out to disable this family
tag_families |= image.TAG25H9   # comment out to disable this family
tag_families |= image.TAG36H10  # comment out to disable this family
tag_families |= image.TAG36H11  # comment out to disable this family (default family)
tag_families |= image.ARTOOLKIT # comment out to disable this family
(8) Function for converting the AprilTag name:
Define a function, family_str, to convert the recognized AprilTag into a readable string.
#机器码转换成字符串(convert AprilTag to string)
def family_name(tag):
    if(tag.family() == image.TAG16H5):
        return "TAG16H5"
    if(tag.family() == image.TAG25H7):
        return "TAG25H7"
    if(tag.family() == image.TAG25H9):
        return "TAG25H9"
    if(tag.family() == image.TAG36H10):
        return "TAG36H10"
    if(tag.family() == image.TAG36H11):
        return "TAG36H11"
    if(tag.family() == image.ARTOOLKIT):
        return "ARTOOLKIT"
(9) Enter the while loop to continuously capture images. Recognize AprilTags. The program logic is as follows:
While loop:
① Capture an image during each iteration.
② Use the find_apriltags method to recognize the specified AprilTags.
③ For each recognized AprilTag, draw a bounding box and a cross, and print the name, ID, and rotation angle.
④ Display the processed image on the LCD and print the current frame rate.
#loop
while(True):
    clock.tick()
    #从图像中识别机器码(recognize AprilTag from the image)
    for code in img.find_apriltags(families=tag_families):
        #绘制矩形和十字标记(draw rectangle and cross)
        img.draw_rectangle(code.rect(), color = (255, 0, 0))
        img.draw_cross(code.cx(), code.cy(), color = (0, 255, 0))
        #print_args = (family_name(code), code.id(), (180 * code.rotation()) / math.pi)
        #print("Tag Family %s, Tag ID %d, rotation %f (degrees)" % print_args)
        send_x  = code.x()
        send_y  = code.y()
        send_w  = code.w()
        send_h  = code.h()
        if (code.id()<10):
            send_msg  = '0'+str(code.id())+ str(family_name(code))
            send_msg  = str(code.id())+ str(family_name(code))
        #打印数据(print data)
        #print(send_msg)
    #当消息标志不为 '' 时,发送数据(When the message flag is not '', transmit the data)
    if send_msg != '' :
        #发送数据(send data)
        send_msg = '' # 清空消息变量(clear message variable)
    lcd.display(img)
    print(clock.fps())
7.6.2 Arduino UNO
  • Game Introduction
  • Getting Ready
① Locate and open the “5.6.2_find_apriltags.ino” program file in the same folder as this lesson.
  • Program Outcome
Open the Arduino IDE serial monitor, the recognition result and the coordinates information of the recognized AprilTag are visible. Select the baud rate to 115200.
The msg represents the content of the recognized target AprilTag barcode. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
  wk->serial_begin();
void loop() {
  wk->update_data();
  bool rt = wk->recive_box_msg(result , K210_FIND_APRILTAGS);
void loop() {
  wk->update_data();
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.6.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling AprilTag recognition. The coordinates of the recognized bounding box for the AprilTag and the recognition result will be printed on the terminal.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After downloading the program, the ESP32 will print the coordinates of the recognized bounding box of the AprilTag and the detection result in the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games -> 6.5 AprilTag Recognition .
(1) Import Module
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_apriltags() searches for AprilTag in the data and retrieve the received messages.
  wk.update_data()
  ret = wk.find_apriltags()
If a recognition result is found (ret is not None), the recognition result will be printed. The x and y represent the top-left coordinates of the box in the image, the w denotes the width of the box, the h represents the height of the box, and the msg is the content of the AprilTag.
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  time.sleep_ms(10)
297
298
299
300
301
302
303
305
306
307
308
309
310
311
312
313
314
315
316
317
  # 机器码识别 box msg(AprilTag recognition box msg)
  def find_apriltags(self):
      if k210_PACKET_FUNCTION.FIND_APRILTAGS == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_apriltags()")
        return ret
        return None
      return None
This function is used to extract the position information of the recognized AprilTag frame when a new message is received and the message type is AprilTag recognition.
Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined COLOR_RECOGNITION function message. If it is a AprilTag message, the following steps are performed:
① Print a message indicating that a AprilTag message has been found.
④ Extract the coordinate and size information from the AprilTag recognition result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
⑧ If a new message is not successfully read or the received message is not a AprilTag recognition message, None is returned.
7.6.4 STM32
  • Game Introduction
Send the recognized AprilTag information to STM32 via the K210 vision module.
  • Getting Ready
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized AprilTag information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
It extracts data of type k210_Box_Msg_cb from the data frame. It prints the position and size information of the box based on the extracted data. It clears the checksum of the message data and then prints the message content.
* @retval void
K210_FIND_BARCODES corresponds to the AprilTag recognition task and uses the function k210_Box_Msg_cb to process the data.
k210_Box_cb is a callback function. It will be called when data associated with the task type K210_FIND_RED_FOLLOW is received.
7.6.5 Raspberry Pi
  • Game Introduction
Send the recognized AprilTag data to Raspberry Pi via the K210 vision module.
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will retrieve the coordinate information and content of the recognized AprilTag from the K210 vision module and print it in the terminal.
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(Find_Box_Msg_st , Find_Box_st , Find_Msg_st),K210识别类型类(K210 recognition class)(k210_PACKET_FUNCTION)
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Use the function wk.update_dat() to update data. Call the function wk.find_box_msg() to obtain the received message.
When a new message is obtained, the detection result of the recognized AprilTag will be printed. It includes the position (x, y, w, h) of the AprilTag and its recognized content.
#loop
    wk.update_data()
    ret = wk.find_box_msg(k210_PACKET_FUNCTION.FIND_APRILTAGS)
    if ret is not None:
7.7 Face Detection
7.7.1 K210
  • Game Introduction
This section demonstrates on how to use the K210 vision module to implement face detection and select the identified face with a box. Firstly, the vision module captures an image. Then, the image is checked for the presence of a face. If a face is detected, it is highlighted with a box and displayed on the LCD screen. The detected data is sent to the master device via the serial port.
  • Getting Ready
(1) Device Connection
Power the other master devices with their respective power interfaces, and connect the UART interfaces with DuPont cables.
For example, connect the ESP32 to the PC with a USB data cable. Then, connect the K210 vision module to the ESP32’s serial port with a DuPont cable.
① Double-click to open the software.
② Click in the bottom left corner.
③ Select the corresponding serial port number. Check “Advanced Settings”, and select “Mode-3”.
④ Click “OK” and wait for the connection to be completed.
⑤ After the connection is successful, the CanMV IDE displays the icon in the bottom left corner.
⑥ If the connection takes more than 10 seconds, it indicates a connection failure. Click “Cancel”, and a pop-up window shown below appears. Click “OK” and re-check the connection.
Tips for connection failure:
  • The selected serial port number is wrong.
Please unplug other serial ports connected to your PC. Try the above steps again to select the correct serial port number.
  • The cable used for the connection is not a data cable.
Use a Type-C data cable that supports data transmission. A Type-C data cable is included in the package before delivery.
  • Other K210 firmware is flashed.
Reflash the factory firmware, and then proceed with the connection.
Online operation:
After connecting successfully, drag the program under the same folder as this lesson to the code editor area of CanMV IDE. Click the at the bottom left corner to run the program online.
Programs run in this way will be lost when the connection is disconnected or the device is shut down. They will not be saved on the K210 vision module.
Offline operation:
(1) After connecting, drag the program under the same directory to the CanMV IDE code editing area. Click “Tools” on the toolbar. Select “Save open script to CanMV Cam (as main.py)”.
(2) Click “Yes”.
(3) Once the writing is successful, a window shown below will appear. Click “OK”. This saves the MicroPython file into the K210 Vision Module.
By downloading in this way, after powering on the K210 Vision Module without connecting, it will run the MicroPython file, enabling offline operation.
  • Program Outcome
(1) K210 Vision Module
After running the program, the K210 vision module will highlight the recognized face on its LCD screen.
(2) Mater Device
Upon the program is downloaded, the master device will print the detailed information that is received and parsed. Take the ESP32 as an example.
It prints the coordinates of the recognized face’s bounding box on the terminal. The message “crc ok” indicates that the checksum is correct.
(1) Load the vision module to obtain camera images.
Load the time module for calculating video frame rates.
Load the LCD module library for displaying images on an LCD screen.
Import the KPU library to load and process the model.
(2) Load the binascii module for byte processing.
#载入相关模块(load relevant modules)
import sensor, image, time, lcd
from maix import KPU
from hiwonder import hw_uart
import binascii
Define the serial port transmission object.
#定义串口对象(define serial port object)
serial = hw_uart()
(3) Define a serial port transmission function. It encapsulates the recognized information based on the defined data format and transmits it via the serial port.
def send_data(x,y,w,h,msg):
    0xAA  0x55  功能号(function number)  数据长度(data length)  data  CRC
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_FACE_YOLO #功能编号(function number)
    Length = 0  #数据长度(data length)
    crc = 0 #校验位(checksum bit)
    data = [] #数据组(dataset)
    #参数都为0(all parameters are set to 0)
    if x==0 and y==0 and w==0 and h ==0:
        #x(小端模式)(little-endian mode)
        low = x & 0xFF #低位(low byte)
        high = x >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #y(小端模式)(little-endian mode)
        low = y & 0xFF #低位(low byte)
        high = y >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #w(小端模式)(little-endian mode)
        low = w & 0xFF #低位(low byte)
        high = w >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #h(小端模式)(little-endian mode)
        low = h & 0xFF #低位(low byte)
        high = h >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
        for i in range(len(msg)):
            msg_int = str_2_int(msg[i])
            data.append(msg_int)
    Length += len(data)
    send_buf = [FUNC_num,Length]
    for i in range(len(data)):
        send_buf.append(data[i])
    #进行CRC运算(perform a CRC calculation)
    crc = checksum_crc8(send_buf)
(4) Define the sent data storage variables. The “send_x” and “send_y” represent the x and y values of the top-left corner coordinates of the recognition box. The “send_msg” represents the specific information extracted from the image.
#定义发送数据(define the transmitted data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
#初始化LCD(initialize LCD)
lcd.init()
#以下是初始化传感器(initialize sensors)
sensor.reset()
sensor.skip_frames(time = 100)
#帧率时钟(frame rate clock)
clock = time.clock()
(7) Create an image buffer object to store the captured and processed images from the camera.
#创建图像对象(create image object)
img_obj = image.Image(size=(320,256))
(8) Create the required parameters for the face detection model. These parameters are fixed and cannot be changed.
#创建锚框的尺寸列表,用于目标检测(create the size list of the anchor box to detect target)
anchor = (0.893, 1.463, 0.245, 0.389, 1.55, 2.58, 0.375, 0.594, 3.099, 5.038, 0.057, 0.090, 0.567, 0.904, 0.101, 0.160, 0.159, 0.255)
(9) Create a KPU object and load the corresponding model file from the specified path.
#创建 KPU 模型对象(create KPU model object)
kpu = KPU()
#加载 YOLO 目标检测模型文件(.kmodel 格式)(load YOLO target detection model file in .kmodel format)
kpu.load_kmodel("/sd/KPU/yolo_face_detect/yolo_face_detect.kmodel")
(10) Initialize the YOLO model parameters.
kpu.init_yolo2(anchor, anchor_num=9, img_w=320, img_h=240, net_w=320, net_h=256, layer_w=10, layer_h=8, threshold=0.7, nms_value=0.3, classes=1)
Use the init_yolo2() function to initialize the parameters of the YOLO model. The parameters are shown below:
anchor: A list of anchor box sizes used for object detection.
anchor_num: The number of anchor boxes.
img_w, img_h: The width and height of the input image.
net_w, net_h: The width and height of the model input.
layer_w, layer_h: The width and height of the final model layer.
threshold: The confidence threshold for detecting objects.
nms_value: The IOU threshold for non-maximum suppression.
classes: The number of object classes.
(11) Enter the while loop to recognize images.
    #loop
(12) Start the timer for calculating the frame rate.
        clock.tick()  #计算每秒帧率(calculate the frame rate per second)
(13) Use the snapshot() function to capture an image from the camera. Copy and preprocess the image, and then feed it to the preloaded model for recognition.
        img = sensor.snapshot()  #从相机获取图像(obtain image from camera)
        #将图像数据复制到 img_obj 对象中,以便传递给 KPU 运行(copy the image data to the img_obj object for passing it to the KPU for execution)
        img_obj.draw_image(img, 0, 0)
        img_obj.pix_to_ai()
        #使用 KPU 运行目标检测模型(use KPU to run the target detection model)
        kpu.run_with_output(img_obj)
(14) Retrieve the detection result. If any face is detected, draw a bounding box to highlight the detected face.
        #获取检测结果(obtain detection result)
        dect = kpu.regionlayer_yolo2()
        fps = clock.fps()
        #如果检测到目标(if the target is detected)
        if len(dect) > 0:
            for l in dect :
                #在图像上绘制检测到的目标框(draw the detected target box on the image)
                img.draw_rectangle(l[0],l[1],l[2],l[3], color=(0, 255, 0))
(15) Display the processed image on the LCD screen.
        #在 LCD 上显示处理后的图像(display the processed image on the LCD)
        lcd.display(img)
(16) Capture program errors to destroy relevant processor resources. This prevents device freezing.
#捕获错误并处理(capture and process errors)
    raise e
    #若出现错误,则释放 KPU 资源(If there is an error, release the KPU resource)
    kpu.deinit()
7.7.2 Arduino UNO
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by Arduino UNO.
  • Game Introduction
  • Getting Ready
(1) Module Connection
Connect the K210 vision module to a computer with a Type-C data cable.
Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding GND, D6, and D7 pins on the Arduino UNO with a DuPont wire.
(2) Download and Run Program
① Locate and open the “5.7.2_find_face_yolo.ino” program file in the same folder as this lesson.
② In the “Select board” option, select the corresponding Arduino development board and port. Take “Arduino Uno” and “COM8” as an example to demonstrate. The COM port is not unique. You can check the COM port number in the computer’s device manager.
③ Click button to compile the program. After the compilation is completed, click to upload the program into the Arduino development board.
  • Program Outcome
Open the Arduino IDE serial monitor, the coordinates information of the recognized face is visible. Select the baud rate to 115200.
The touch screen of K210 vision module has a resolution of 320*240. The origin of its pixel coordinates located at the top left corner of the module, as illustrated in the diagram below:
(1) Import Header File
#include "WonderK210.h"
WonderK210.h is a header file that contains declarations, definitions, function prototypes, and other necessary information related to the WonderK210 controller. This header file is used for functions and structure definitions that operate the WonderK210 controller.
(2) Declare Variables
//接收控制器(receive controller)
WonderK210* wk;
//消息存储变量(message storage variable)
Find_Box_st* result;
WonderK210* wk: Declares a pointer named “wk” of type WonderK210. This pointer represents an instance or object of the WonderK210 controller.
Find_Box_st* result: Declares a pointer named “result” of type Find_Box_st. This pointer stores or points to a data structure of type Find_Box_st, which is used to store information about the detected boxes.
(3) Initial Settings
  //开启串口接收(enable serial port receiving)
  wk->serial_begin();
  result = malloc(sizeof(Find_Box_st));
Serial.begin(115200): initializes serial communication. The baud rate is set to 115200.
malloc(sizeof(WonderK210)): allocates the memory with the size of the WonderK210 type, and assigns the address to the wk pointer.
wk->serial_begin(): calls the serial_begin() function via wk pointer to initialize serial communication.
malloc(sizeof(Find_Box_st)): allocates memory of the size of the Find_Box_st type, and the address is assigned to the result pointer.
(4) Loop to obtain the latest information from K210
void loop() {
  //更新消息(updata message)
  wk->update_data();
  //获取消息(obtain message)
  bool rt = wk->recive_box(result , K210_FIND_FACE_YOLO);
After entering the “loop()” function, use the “wk.update_data()” function to continuously obtain the latest recognition results from the K210 vision module. Then, acquire and parse the data of the latest recognized frame’s structure, storing it in the result variable.
(5) Printing result information
If a new result is obtained (rt is true), the serial port will print detailed coordinates and dimensions of the recognition frame.
void loop() {
  wk->update_data();
  //若获取到新的消息(if a new message is obtained)
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.7.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling face detection. The coordinates of the bounding box for the recognized face and the recognition result will be printed on the terminal.
  • Getting Ready
(1) Wiring Instruction
Connect the ESP32 to the PC with a USB data cable. Then, connect the K210 vision module to the ESP32’s serial port with a 4PIN wire.
(2) Download and Run K210 Program
Online operation:
Offline operation:
① After connecting, drag the program under the same directory to the CanMV IDE code editing area. Click “Tools” on the toolbar. Select “Save open script to CanMV Cam (as main.py)”.
② Click “Yes”.
③ Once the writing is successful, a window shown below will appear. Click “OK”. This saves the MicroPython file into the K210 Vision Module.
(3) Download and Run ESP32 Program
① Connect the ESP32 controller to the computer with a USB data cable. Open the Python editor. Drag the programs “WonderK210.py” and “main.py” into the editor interface.
② Select the or click “Connect” in the menu bar to choose the corresponding COM port. Let’s use “COM15” as an example. The COM port is not unique. You can check the COM port number in the computer’s device manager.
To avoid encountering any unexpected anomalies during the flashing process, please strictly follow the operation steps.
In you encounter difficulties in properly reading the COM port or downloading the program, please refer to the “ESP32 Board Firmware Recovery Method” to reflash the firmware.
After the connection is established, click or “Run - Download and Run” to download the program into the controller and execute it.
  • Program Outcome
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games->6.7 Face Detection.
(1) Import Module
# 载入时间模块(load time module)
(2) Establish Communication
Instantiate the K210 communication class.
# 实例化K210通信类(instantiate K210 communication class)
wk = WonderK210()
Enable the serial port.
# 开启串口(start serial port)
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function “wk.find_face_yolo()” searches for face in the data and retrieve the received messages.
#loop
  # 更新接收消息(update receiving message)
  wk.update_data()
  # 获取接收消息(obtain receiving message)
  ret = wk.find_face_yolo()
If a recognition result is found (ret is not None), the recognition result will be printed. The x and y represent the top-left coordinates of the box in the image. The w denotes the width of the box, and the h represents the height of the box.
  if ret is not None:
    # 打印消息内容(print message content)
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
  # 延时10ms(delay for 10ms)
  time.sleep_ms(10)
(4) Information Obtaining Function
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
  # 口罩检测 box msg(mask detection box msg)
  def find_facemask(self):
    if True == self.__read_succeed: # 若有新消息(if there is a new message)
      if k210_PACKET_FUNCTION.FIND_FACEMASK == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_facemask()")
        self.__read_succeed = False
        ret.function = self.__pk_result.function
        ret.x = (self.__pk_result.data[0] & 0x00FF) | ((self.__pk_result.data[1] << 8 ) & 0xFF00)
        ret.y = (self.__pk_result.data[2] & 0x00FF) | ((self.__pk_result.data[3] << 8 ) & 0xFF00)
        ret.w = (self.__pk_result.data[4] & 0x00FF) | ((self.__pk_result.data[5] << 8 ) & 0xFF00)
        ret.h = (self.__pk_result.data[6] & 0x00FF) | ((self.__pk_result.data[7] << 8 ) & 0xFF00)
        # 清除存储变量(clear storage variables)
        self.__pk_result.data.clear()
        return ret
        return None
      return None
This function is used to extract the position information of the recognized face frame when a new message is received and the message type is face detection.
Firstly, it checks if “self.__read_succeed” is True. If the message is successfully read, it checks if “self.__pk_result.function” is a predefined “COLOR_RECOGNITION” function message. If it is a face detection message, the following steps are performed:
Print a message indicating that a face detection message has been found.
Set “self.__read_succeed” to False, indicating that this message has been successfully processed.
Create an object named ret, which is an instance of the “Find_Box_st class”.
Extract the coordinate and size information from the face detection result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
Clear the variable “self.__pk_result.data” that stores the message data.
If a new message is not successfully read or the received message is not a face detection message, None is returned.
7.7.4 STM32
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by STM32.
  • Game Introduction
Send the recognized face information to STM32 via the K210 vision module.
  • Getting Ready
① Connect the K210 vision module to a computer with a Type-C data cable.
① Locate and open “RosRobotControllerM4.uvprojx” program file in the same folder as this lesson.
② Click to perform compiling. After the compiling is completed, click to download the program to the STM32 board.
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized face information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
(1) Initial Settings
#include "k210_packet.h"
#include "global.h"
The “k210_packet.h” consists of data structure definitions, function declarations, and macros related to the K210. It is used to handle data packets, communication protocols, or device control related to the K210. The file “global.h” contains global constants, variables, and more.
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
Struct “BoxData”: a structure “BoxData” is defined. It contains four uint16_t type member variables: x, y, w, and h. These variables represent the position and size of a rectangular box.
//只有方框数据(only includes box data)
typedef struct {
	BoxData box;
}Find_Box_st;
Struct “Find_Box_st”: a structure “Find_Box_st” is defined. It contains a variable “box” of “BoxData” type. This structure represents a data type that includes only the information of a rectangular box, excluding other message data.
//有方框数据和消息数据(include box data and message data)
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
Struct “Find_Box_Msg_st”: a structure “Find_Box_Msg_st” is defined. It contains a variable of type “BoxData” named “box” and an array of uint8_t type with a length of 100 named “msg”. This structure represents a data type that includes both the information of a rectangular box and a message data with a length of 100.
//只有消息数据(only includes message data)
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
Struct “Find_Msg_st”: a structure “Find_Msg_st” is defined. It contains a single array of uint8_t type with a length of 100 named “msg”. This structure represents a data type that includes only the message data with a length of 100 and does not include the information of a rectangular box.
(2) Message Data Processing
* @brief 只有方框数据 的回调处理(callback processing for only including box data)
* @param frame 数据帧(data frame)
* @retval void
static void k210_Box_cb(struct k210_PacketRawFrame *frame)
    Find_Box_st *rec = (Find_Box_st*)frame->data_and_checksum;
	printf("x:%d,y:%d,w:%d,h:%d\n",rec->box.x,rec->box.y,rec->box.w,rec->box.h);
k210_Box_cb: handles data frames that only contain box data. It extracts data of type “Find_Box_st” from the data frame. It prints the position and size information of the box based on the extracted data.
* @brief 有方框数据和消息数据 的回调处理(callback processing for including box data and message data)
* @retval void
static void k210_Box_Msg_cb(struct k210_PacketRawFrame *frame)
    Find_Box_Msg_st *rec = (Find_Box_Msg_st*)frame->data_and_checksum;
	rec->msg[frame->data_length - 8] = '\0'; //将check位清除(clear check bit)
	printf("msg:%s\n",rec->msg);
It extracts data of type “Find_Box_Msg_st” from the data frame. It prints the position and size information of the box based on the extracted data. It clears the checksum of the message data and then prints the message content.
* @brief 只有消息数据 的回调处理(callback processing for only including message data)
* @retval void
static void k210_Msg_cb(struct k210_PacketRawFrame *frame)
    Find_Msg_st *rec = (Find_Msg_st*)frame->data_and_checksum;
	rec->msg[frame->data_length] = '\0'; //将check位清除(clear check bit)
k210_Msg_cb”: handles data frames that only contain message data. It extracts data of type “Find_Msg_st” from the data frame. It clears the checksum of the message data and then prints the message content. These functions serve as callback functions. When receiving specific types of data frames, these functions are called to process the data within the frames.
(3) Callback Function
//注册回调函数(register callback function)
void k210_packet_handle_init(void)
    k210_packet_register_callback(&k210_packet_controller, K210_COLOR_RECOGNITION, k210_Box_cb); //颜色识别(color recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_BARCODES, k210_Box_Msg_cb); //条形码识别(barcode recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_QRCODES, k210_Box_Msg_cb);	 //二维码识别(QR code recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_APRILTAGS, k210_Box_Msg_cb);//机器码识别(AprilTag recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACE_YOLO, k210_Box_cb); 	 //人脸检测(face detection)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACEFEATURE, k210_Box_cb);  //人脸特征识别(face feature recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACEMASK, k210_Box_Msg_cb); //口罩识别(mask recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_OBJECT, k210_Box_Msg_cb);	 //物体识别(object recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_SELF_LEARNING, k210_Msg_cb);//自主学习分类(autonomous learning and classification)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_DIGITAL, k210_Msg_cb);      //手写数字识别(handwritten number recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACE_RECOGNITION, k210_Box_Msg_cb); //物体识别(object recognition)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_RED_FOLLOW, k210_Box_cb); //红色追踪(red tracking)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_SIGNPOST_FOLLOW, k210_Box_Msg_cb); //路标追踪(road sign tracking)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_DIGITAL_CARD, k210_Box_Msg_cb); //数字卡片识别(number card recognition)
    k210_packet_register_callback(&k210_packet_controller, K210_GARBAGE_SORTING, k210_Box_Msg_cb); //垃圾分类(waste classification)
    k210_packet_register_callback(&k210_packet_controller, K210_COLOR_SORTING, k210_Box_Msg_cb); //多种颜色识别(multiple colors recognition)
Multiple callback functions are registered through the function k210_packet_handle_init. Each callback function corresponds to a different processing program. These callback functions are associated with different functional modules related to the K210. Each module corresponds to a different recognition or data processing task.
Each call to k210_packet_register_callback associates a specific task’s processing function with the K210 controller. For example:
K210_COLOR_RECOGNITION corresponds to the color recognition task and uses the function k210_Box_cb to process the data.
K210_FIND_BARCODES corresponds to the barcode recognition task and uses the function k210_Box_Msg_cb to process the data.
Similar cases exist for other tasks. Take “k210_packet_register_callback(&k210_packet_controller, K210_COLOR_RECOGNITION, k210_Box_cb” as an example:
The k210_packet_register_callback function is used to associate the callback function k210_Box_cb with a specific task type K210_COLOR_RECOGNITION.
&k210_packet_controller is a pointer to the K210 controller. It provides interfaces and methods for handling different tasks.
K210_COLOR_RECOGNITION is a specific function code. It represents the function that K210 needs to perform.
k210_Box_cb is a callback function. It will be called when data associated with the task type K210_COLOR_RECOGNITION is received.
7.7.5 Raspberry Pi
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by Raspberry Pi.
  • Game Introduction
Send the detected face data to Raspberry Pi via the K210 vision module.
  • Getting Ready
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding pins on the Raspberry Pi with a DuPont wire.
① Move the program files “main.py” and “WonderK210.py” from the current directory to Raspberry Pi via a USB drive.
② Press “Ctrl+Alt+T” in the Raspberry Pi system to open the command line terminal.
③ In the command line terminal, enter the command “cd Desktop/” to navigate to the directory where the program is located.
cd Desktop/
④ Enter the command “python3 main.py” to start the program.
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will retrieve the detected face data from the K210 vision module and print it in the terminal.
from WonderK210 import WonderK210 , Find_Box_Msg_st , Find_Box_st , Find_Msg_st , k210_PACKET_FUNCTION
Load the K210 communication class (WonderK210), message format class (Find_Box_Msg_st, Find_Box_st, Find_Msg_st), and K210 recognition type class (k210_PACKET_FUNCTION).
(2) Create Object
Instantiate the K210 communication class, and simultaneously activate the serial port.
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Use the function wk.update_data() to update data. Call the function wk.find_box_msg() to obtain the received message.
When a new message is obtained, the position (x, y, w, h) of detected face will be displayed.
#loop
    wk.update_data()
    ret = wk.find_box(k210_PACKET_FUNCTION.FIND_FACE_YOLO)
    # 若有新消息获取到(if a new message is obtained)
    if ret is not None:
        print("ret.x = {}".format(ret.x))
        print("ret.y = {}".format(ret.y))
        print("ret.w = {}".format(ret.w))
        print("ret.h = {}".format(ret.h))
7.8 Face Recognition
7.8.1 K210
  • Game Introduction
This section implements face recognition using the K210 vision module. Press the K1 button to capture a face image. Then, the vision module learns the facial information from the captured image and registers it. Capture another face image. If the facial information matches a previously learned face, the identified face will be boxed on the display screen. The detected data will be sent to the host device through the serial port.
  • Getting Ready
IMG_256
② Power the other master devices with their respective power interfaces, and connect the UART interfaces with DuPont cables.
③ For example, connect the ESP32 to the PC with a USB data cable. Then, connect the K210 vision module to the ESP32’s serial port with a DuPont cable.
IMG_256
IMG_256 IMG_256
IMG_256
There are two ways to run K210 programs: online and offline.
Online operation:
Offline operation:
② Click “Yes”.
IMG_256
IMG_256
  • Program Outcome
After running the program, the K210 vision module will select the recognized face with a box. If it is an unregistered face, it will be highlighted with a white box. Press K1 button on the vision module to register the face information.
(2) Master Device
After the program is downloaded, aim the vision module at the face to be recognized. Press the K1 button to record the face data. When the face is recognized, the coordinates of the face’s recognition box and Y will be printed on the terminal. If the face is not recognized, the coordinates of the face’s recognition box and N are printed on terminal. The message “crc ok” indicates that the checksum is correct.
Import the gc module for memory management.
Import the KPU library for model loading and processing.
Import the GPIO library for controlling input/output states of pins, reading sensor data, and controlling external devices.
Import the utils library for hardware and system interaction.
Load the hw_uart module from the hiwonder library for serial communication.
import binascii
(2) Define the serial port transmission object.
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
lcd.init()
sensor.reset()
(7) Set the relevant parameters for face recognition and load the model.
Create an image object for feature extraction.
Define the size of face images and the coordinates of keypoints.
Initialize the parameters for the YOLO model and the face recognition model.
# 创建一个64x64的图像对象,设置不拷贝到帧缓存(create a 64x64 image object without copying it to the frame buffer)
feature_img = image.Image(size=(64,64), copy_to_fb=False)
feature_img.pix_to_ai()
# 人脸图片的大小(the size of the face image)
FACE_PIC_SIZE = 64
# 人脸关键点坐标(the coordinates of the ficial keypoints)
dst_point =[(int(38.2946 * FACE_PIC_SIZE / 112), int(51.6963 * FACE_PIC_SIZE / 112)),
            (int(73.5318 * FACE_PIC_SIZE / 112), int(51.5014 * FACE_PIC_SIZE / 112)),
            (int(56.0252 * FACE_PIC_SIZE / 112), int(71.7366 * FACE_PIC_SIZE / 112)),
            (int(41.5493 * FACE_PIC_SIZE / 112), int(92.3655 * FACE_PIC_SIZE / 112)),
            (int(70.7299 * FACE_PIC_SIZE / 112), int(92.2041 * FACE_PIC_SIZE / 112)) ]
# YOLO模型的锚点和参数初始化(initialize YOLO model anchor points and parameters)
anchor = (0.1075, 0.126875, 0.126875, 0.175, 0.1465625, 0.2246875, 0.1953125, 0.25375, 0.2440625, 0.351875, 0.341875, 0.4721875, 0.5078125, 0.6696875, 0.8984375, 1.099687, 2.129062, 2.425937)
kpu = KPU()
kpu.load_kmodel("/sd/KPU/yolo_face_detect/face_detect_320x240.kmodel")
kpu.init_yolo2(anchor, anchor_num=9, img_w=320, img_h=240, net_w=320 , net_h=240 ,layer_w=10 ,layer_h=8, threshold=0.7, nms_value=0.2, classes=1)
# 加载人脸识别模型
ld5_kpu = KPU()
print("ready load model")
ld5_kpu.load_kmodel("/sd/KPU/face_recognization/ld5.kmodel")
# 加载人脸识别模型(load face recognition model)
ld5_kpu = KPU()
fea_kpu.load_kmodel("/sd/KPU/face_recognization/feature_extraction.kmodel")
(8) Face recognition main loop:
In the loop, first capture an image and perform face detection using the KPU model.
For the detected face, perform cropping, resizing, keypoint detection, and feature extraction. Compare the extracted features with the pre-recorded features.
Based on the recognition result, draw corresponding rectangular box and information on the image.
Display the processed image and frame rate information.
    #loop
        # 手动触发垃圾回收(manually trigger waste collection)
        gc.collect()
        # print("mem free:",gc.mem_free())
        # print("heap free:",utils.heap_free())
        #从相机获取图像(obtain image from the camera)
        clock.tick()
        # 获取摄像头拍摄的图像(obtain the captured image from the camera)
        # 使用KPU模型运行人脸检测(use the KPU model to run the face detection)
        kpu.run_with_output(img)
        # 获取人脸检测结果(obtain face detection result)
        # 获取帧率(obtain frame rate)
        fps = clock.fps()
        # 如果有检测到人脸(if a face is detected)
        if len(dect) > 0:
            # 遍历(iterate)
            for l in dect :
312
313
                if recog_flag: # 识别到(if the target is recognized)
329
        lcd.display(img) # 显示图像(display image)
(9) Process errors and release resources.
331
332
333
334
335
336
337
338
#捕获错误并处理(capture errors and handle them)
    raise e
    #若出现错误,则释放 KPU 资源(If there is an error, release KPU resource)
    kpu.deinit()
    ld5_kpu.deinit()
    fea_kpu.deinit()
7.8.2 Arduino UNO
  • Game Introduction
Send the recognized color data to Arduino UNO via the K210 vision module.
  • Getting Ready
① Locate and open the “5.8.2_find_face_recogize.ino” program file in the same folder as this lesson.
  • Program Outcome
Open the “Arduino IDE” serial monitor. The recognition prompt for registered face and the corresponding coordinate information appears. Set the baud rate to 115200.
The msg represents whether the registered face is recognized. The Y indicates the face is recognized; the N means it is not recognized. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
WonderK210* wk;
Find_Box_Msg_st* result;
WonderK210* wk: Declares a pointer named "wk" of type WonderK210. This pointer represents an instance or object of the WonderK210 controller.
Find_Box_st* result: Declares a pointer named "result" of type Find_Box_st. This pointer stores or points to a data structure of type Find_Box_st, which is used to store information about the detected boxes.
  Serial.begin(115200);
  //分配内存(allocate memory)
  wk = malloc(sizeof(WonderK210));
  //这里不需要再调用初始化串口函数 Serial.begin(115200); 在 serial_begin() 函数里已经初始化了(Since the initialization of the serial port has already been performed within the serial_begin() function, there is no need to call Serial.begin(115200))
  wk->serial_begin();
  result = malloc(sizeof(Find_Box_Msg_st));
malloc(sizeof(Find_Box_Msg_st)): allocates memory of the size of the Find_Box_Msg_st type, and the address is assigned to the result pointer.
void loop() {
  wk->update_data();
  bool rt = wk->recive_box_msg(result , K210_FIND_FACE_RECOGNITION);
After entering the loop() function, use the wk.update_data() function to continuously obtain the latest recognition results from the K210 vision module. Then, acquire and parse the data of the latest recognized frame’s structure, storing it in the result variable.
If a new result is obtained (rt is true), the serial port will print the position coordinates, size information, and recognition result of the recognition box’s top-left corner.
  if(rt)
    Serial.print("x:");
    Serial.println(result->x);
    Serial.print("y:");
    Serial.println(result->y);
    Serial.print("w:");
    Serial.println(result->w);
    Serial.print("h:");
    Serial.println(result->h);
    Serial.print("msg:");
    Serial.println(result->msg);
7.8.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling face recognition. The coordinates of the bounding box for the recognized face and the recognition result will be printed on the terminal.
  • Getting Ready
IMG_256
IMG_256 IMG_256
IMG_256
Online operation:
IMG_256
Offline operation:
IMG_256
② Click “Yes”.
IMG_256
IMG_256
IMG_256
In you encounter difficulties in properly reading the COM port or downloading the program, please refer to the ESP32 Board Firmware Recovery Method to reflash the firmware.
(3) After the connection is established, click or “Run - Download and Run” to download the program into the controller and execute it.
  • Program Outcome
After downloading the program, aim the K210 vision module at the target face. Press the “K1” button to record face data. When the recorded face is recognized, the coordinates of the recognized box of the face and Y will be printed in the terminal. When it is not recognized, the coordinates of the recognized box for the current face and N will be printed in the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games->6.8 Face Recognition
(1) Import Module
Import the time module, the WonderK210 communication class, and the message format classes (Find_Box_Msg_st, Find_Box_st, and Find_Msg_st) for subsequent usage.
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_face_recognition() searches for face in the data and retrieve the received messages.
#loop
  wk.update_data()
  ret = wk.find_face_recognition()
If a recognition result is found (ret is not None), the recognition result will be printed. The x and y represent the top-left coordinates of the box in the image. The w denotes the width of the box, the h represents the height of the box, and the msg is the recognition result.
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  time.sleep_ms(10)
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
  # 人脸识别 box msg(face recognition box msg)
  def find_face_recognition(self):
      if k210_PACKET_FUNCTION.FIND_FACE_RECOGNITION == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_face_recognition()")
        return ret
        return None
      return None
This function is used to extract the position information of the recognized face frame when a new message is received and the message type is face recognition.
(1) Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined "COLOR_RECOGNITION" function message. If it is a face recognition message, the following steps are performed:
(2) Print a message indicating that a face recognition message has been found.
(3) Set self.__read_succeed to False, indicating that this message has been successfully processed.
(4) Create an object named ret, which is an instance of the Find_Box_st class.
(5) Extract the coordinate and size information from the barcode recognition result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
(6) If the length of the message data is greater than 8, convert the remaining part of the data into a string. Assign it to the msg attribute of the ret object.
(7) Clear the variable self.__pk_result.data that stores the message data.
(8) Return the ret object that contains the extracted recognition result information.
(9) If a new message is not successfully read or the received message is not a face recognition message, None is returned.
7.8.4 STM32
  • Game Introduction
Send the learned face information to STM32 via the K210 vision module.
  • Getting Ready
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding pins on the STM32 with a DuPont wire.
  • Program Outcome
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
Struct BoxData: a structure BoxData is defined. It contains four uint16_t type member variables: x, y, w, and h. These variables represent the position and size of a rectangular box.
typedef struct {
	BoxData box;
}Find_Box_st;xxxxxxxxxx //只有方框数据(only includes box data)typedef struct {    BoxData box;}Find_Box_st;paste source code here.
Struct Find_Box_st: a structure Find_Box_st is defined. It contains a variable"box" of BoxData type. This structure represents a data type that includes only the information of a rectangular box, excluding other message data.
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
Struct Find_Box_Msg_st: a structure Find_Box_Msg_st is defined. It contains a variable of type BoxData named "box" and an array of uint8_t type with a length of 100 named "msg". This structure represents a data type that includes both the information of a rectangular box and a message data with a length of 100.
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
Struct Find_Msg_st: a structure Find_Msg_st is defined. It contains a single array of uint8_t type with a length of 100 named "msg". This structure represents a data type that includes only the message data with a length of 100 and does not include the information of a rectangular box.
* @retval void
k210_Box_cb: handles data frames that only contain box data. It extracts data of type Find_Box_st from the data frame. It prints the position and size information of the box based on the extracted data.
* @retval void
It extracts data of type Find_Box_Msg_st from the data frame. It prints the position and size information of the box based on the extracted data. It clears the checksum of the message data and then prints the message content.
* @retval void
“k210_Msg_cb”: handles data frames that only contain message data. It extracts data of type Find_Msg_st from the data frame. It clears the checksum of the message data and then prints the message content. These functions serve as callback functions. When receiving specific types of data frames, these functions are called to process the data within the frames.
Similar cases exist for other tasks. Take "k210_packet_register_callback(&k210_packet_controller, K210_COLOR_RECOGNITION, k210_Box_cb" as an example:
① The k210_packet_register_callback function is used to associate the callback function k210_Box_cb with a specific task type K210_COLOR_RECOGNITION.
7.8.5 Raspberry Pi
  • Game Introduction
Use the K210 vision module to recognize the learned face, sending the detection result to the Raspberry Pi.
  • Getting Ready
③ In the command line terminal, enter the command to navigate to the directory where the program is located.
cd Desktop/
④ Enter the command to start the program.
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will retrieve the face data from the K210 vision module and print it in the terminal.
Import the K210 communication class (WonderK210), message format class (Find_Box_Msg_st, Find_Box_st, Find_Msg_st), and K210 recognition type class (k210_PACKET_FUNCTION).
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st),K210识别类型(K210 recognition class)(k210_PACKET_FUNCTION)
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
When a new message is obtained, the position (x, y, w, h) of the recognized face will be displayed. The recognition result will be printed in the terminal.
#loop
    wk.update_data()
    ret = wk.find_box_msg(k210_PACKET_FUNCTION.FIND_FACE_RECOGNITION)
    if ret is not None:
        print("ret.msg = {}".format(ret.msg))
7.9 Face Feature Detection
7.9.1 K210
  • Game Introduction
In this lesson, the K210 vision module will draw the keypoints of the recognized face. Additionally, the recognition result will be sent to the master device via the serial port.
  • Getting Ready
IMG_256
IMG_256
IMG_256 IMG_256
IMG_256
Online operation:
Offline operation:
② Click “Yes”.
IMG_256
IMG_256
  • Program Outcome
After running the program, the K210 vision module will draw the keypoints of the recognized face. The recognition result will be sent to the master device via the UART serial port.
(2) Master Device
After the program is downloaded, aim the K210 vision module at the face to be recognized. When the vision module recognizes facial features, it will display them on the screen and print the coordinates of the face recognition bounding box in the terminal. The message “crc ok” indicates that the checksum is correct.
import binascii
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_FACE_FEATURE #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
lcd.init()
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
(6) Create a frame rate clock for measuring the frame rate.
(7) Set the YOLO object detection model and the facial landmark detection model:
Create a list of anchor sizes for the YOLO model, which is used for object detection.
Load the YOLO face detection model and the model for detecting the 68 facial keypoints.
kpu = KPU()
#使用 init_yolo2 初始化 YOLO 模型参数(initialize YOLO model parameters using init_yolo2)
#anchor: 锚框的尺寸列表,用于目标检测(list of anchor box sizes for object detection)
#anchor_num: 锚框的数量(number of anchor boxes)
#img_w, img_h: 输入图像的宽度和高度(width and height of the input image)
#net_w, net_h: 模型输入的宽度和高度(width and height of the model input)
#layer_w, layer_h: 模型最终层的宽度和高度(width and height of the final layer of the model)
#threshold: 检测目标的置信度阈值(confidence threshold for detecting objects)
#nms_value: 非最大抑制的 IOU 阈值(IOU threshold for non-maximum suppression)
#classes: 目标类别数量(number of target classes)
lm68_kpu = KPU()
#加载人脸特征检测模型文件(.kmodel 格式)用于进行人脸检测和 68 个关键点的检测(load the facial feature detection model file (.kmodel format) for performing face detection and detection of 68 facial keypoints)
lm68_kpu.load_kmodel("/sd/KPU/face_detect_with_68landmark/landmark68.kmodel")
(8) Enter the while loop to continuously perform facial feature recognition:
The while loop:
① Capture an image and use the YOLO model for face detection.
② For each detected face, expand the bounding box and extract the face image.
③ Resize the face image and use the landmark detection model to extract 68 facial landmarks.
④ Draw the detected landmarks on the image.
⑤ Display the processed image and the frame rate information.
    #loop
        img = sensor.snapshot() #捕获摄像头图像(capture image from the camera)
        try: #捕捉 输入图像错误,防止程序崩溃(capture input image error to prevent the program from crashing)
            kpu.run_with_output(img) #使用KPU模型运行人脸检测(use KPU model to run face detection)
        except ValueError as e:
            print("img input error.")
        dect = kpu.regionlayer_yolo2() #获取检测到的人脸框列表(obtain the l)
        fps = clock.fps() #获取帧率(obtain frame rate)
        if len(dect) > 0:
            #遍历检测到的人脸框(iterate through detected face box)
            for l in dect :
        img.draw_string(0, 0, "%2.1ffps" %(fps), color=(0, 60, 255), scale=2.0)
        #在图像上显示帧率(display the frame rate on the image)
        lcd.display(img) #在LCD上显示图像(display the image on the LCD)
(9) Handle error and release resource.
    raise e
    kpu.deinit()
    lm68_kpu.deinit()
7.9.2 Arduino UNO
  • Game Introduction
  • Getting Ready
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding GND, D6, and D7 pins on the Arduino UNO with a DuPont wire.
① Locate and open the “5.9.2_find_facefeature.ino” program file in the same folder as this lesson.
  • Program Outcome
Open the “Arduino IDE” serial monitor, and the coordinate information of the recognized face is visible. Select the baud rate to 115200.
WonderK210* wk;
  wk->serial_begin();
void loop() {
  wk->update_data();
  bool rt = wk->recive_box(result , K210_FIND_FACEFEATURE);
(5) Print result information
If a new result is obtained (rt is true), the serial port will print the position coordinates and size information of the recognition box’s top-left corner.
void loop() {
  wk->update_data();
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.9.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling face feature recognition. The coordinates of the recognized bounding box for the face feature on the terminal.
  • Getting Ready
IMG_256
IMG_256 IMG_256
IMG_256
Online operation:
IMG_256
Offline operation:
IMG_256
② Click “Yes”.
IMG_256
IMG_256
IMG_256
  • Program Outcome
After downloading the program, aim the K210 vision module at the face to be recognized. When the face feature is detected, the recognition result will be displayed on the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games->6.9 Face Feature Recognition
(1) Import Module
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_facefeature() searches for face feature in the data and retrieve the received messages.
#loop
  wk.update_data()
  ret = wk.find_facefeature()
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
  time.sleep_ms(10)
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
  # 人脸检测 box(face detection box)
  def find_face_yolo(self):
      if k210_PACKET_FUNCTION.FIND_FACE_YOLO == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_face_yolo()")
        ret = Find_Box_st()
        return ret
        return None
      return None
This function is used to extract the position information of the recognized face frame when a new message is received and the message type is face feature recognition.
Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined "COLOR_RECOGNITION" function message. If it is a face feature detection message, the following steps are performed:
Print a message indicating that a face feature detection message has been found.
Extract the coordinate and size information from the face feature detection result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
If a new message is not successfully read or the received message is not a face feature detection message, None is returned.
7.9.4 STM32
  • Game Introduction
Send the recognized face feature information to STM32 via the K210 vision module.
  • Getting Ready
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized face feature information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
Each callback function receives data frames from the K210 controller and uses specific processing functions based on the task type to handle the data.
7.9.5 Raspberry Pi
  • Game Introduction
Send the detected face feature data to Raspberry Pi via the K210 vision module.
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will retrieve the detected face feature information from the K210 vision module and print it in the terminal.
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
When a new message is obtained, the position (x, y, w, h) of the detected face feature will be displayed.
#loop
    wk.update_data()
    ret = wk.find_box(k210_PACKET_FUNCTION.FIND_FACEFEATURE)
    if ret is not None:
7.10 Mask Identification
7.10.1 K210
  • Game Introduction
In this lesson, the vision module will be programmed to detect whether the recognized face is wearing a mask and display the recognition result on the screen. Additionally, the relevant information will be sent to the master device via the serial port.
  • Getting Ready
IMG_256
IMG_256
IMG_256 IMG_256
IMG_256
Online operation:
Offline operation:
② Click “Yes”.
IMG_256
IMG_256
  • Program Outcome
After running the program, the K210 vision module will display the information regarding mask-wearing detection. The relevant information will be sent to the master device.
IMG_256 IMG_256
(2) Master Device
After the program is downloaded, the K210 vision module can recognize whether the face is wearing a mask or not, displaying the detection result on the screen. The relevant information will be printed in the terminal. The message “crc ok” indicates that the checksum is correct.
Load the image module for image buffering and AprilTag processing.
import binascii
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_FACE_MASK #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
(4) Define the sent data storage variables. The send_x and send_y represent the x and y values of the top-left corner coordinates of the recognition box. The send_msg represents the specific information extracted from the image.
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
(5) Initialize the LCD screen. Restart the camera module. Set its pixel mode to RGB565 and the image size to QVGA.
lcd.init()
sensor.reset()
sensor.set_framesize(sensor.QVGA)
sensor.skip_frames(time = 1000)
(7) Create anchor boxes and image object:
Define a list of anchor box sizes for object detection.
Create an image object for processing and displaying the image.
anchor = (0.156250, 0.222548, 0.361328, 0.489583, 0.781250, 0.983133, 1.621094, 1.964286, 3.574219, 3.94000)
#创建图像对象(create KPU model object)
img_obj = image.Image(size=(320,256), copy_to_fb=False)
(8) Initialize the KPU model:
Create a KPU model object.
Load the mask detection model file and initialize it using the YOLO model parameters.
kpu = KPU()
#加载口罩检测模型文件(.kmodel 格式)(load mask detection model file in .kmodel format)
kpu.load_kmodel("/sd/KPU/face_mask_detect/detect_5.kmodel")
kpu.init_yolo2(anchor, anchor_num=5, img_w=320, img_h=240, net_w=320 , net_h=256 ,layer_w=10 ,layer_h=8, threshold=0.7, nms_value=0.4, classes=2)
(9) Enter the while loop to continuously detect face masks:
While loop:
Capture an image, then copy the image to an image object and convert it to KPU format.
Use the KPU model to perform mask detection and obtain the detection results.
Based on the detection results, determine if the face is wearing a mask. Box it in corresponding color and display the result above.
    #loop
        img = sensor.snapshot() #捕获摄像头图像(obtain image from camera)
        #将图像复制到图像对象并转换像素为KPU格式(copy the image to an image object and convert the pixels to KPU format)
        img_obj.draw_image(img, 0,0)
        img_obj.pix_to_ai()
        #运行KPU模型,获取检测结果(run the KPU model and obtain detection result)
(10) Create a KPU object and load the model file from the corresponding path.
kpu = KPU()
(11) Handle error and release resource.
    raise e
    kpu.deinit()
7.10.2 Arduino UNO
  • Game Introduction
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the K210 located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by Arduino UNO.
  • Getting Ready
① Locate and open the “5.10.2_find_facemask.ino” program file in the same folder as this lesson.
  • Program Outcome
IMG_256 IMG_256
Open the “Arduino IDE” serial monitor, the recognition result of mask-wearing status and the coordinates of the recognized face are visible. Select the baud rate to 115200.
企业微信截图_17024624571557
The msg is an abbreviation used to represent the assessment of mask-wearing. “Y” signifies that a mask has been worn, and “N” indicates the absence of a mask. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
WonderK210* wk;
  wk->serial_begin();
void loop() {
  wk->update_data();
  bool rt = wk->recive_box_msg(result , K210_FIND_FACEMASK);
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.10.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling mask identification. The coordinates of the recognized bounding box for the mask will be printed on the terminal.
  • Getting Ready
IMG_256
IMG_256 IMG_256
IMG_256
Online operation:
IMG_256
Offline operation:
IMG_256
② Click “Yes”.
IMG_256
IMG_256
IMG_256
③ After the connection is established, click or “Run - Download and Run” to download the program into the controller and execute it.
  • Program Outcome
After downloading the program, the K210 vision module can identify whether a face is wearing a mask and display the result on the screen. It will print the coordinates of the facial recognition bounding box and the detection result on the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games->6.10 Mask Identification
(1) Import Module
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_facemask() searches for mask in the data and retrieve the received messages.
#loop
  wk.update_data()
  ret = wk.find_facemask()
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  time.sleep_ms(10)
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
        ret = Find_Box_Msg_st()
        if self.__pk_result.data_length > 8:
          ret.msg = ''.join(chr(value) for value in self.__pk_result.data[8:])
        return ret
        return None
      return None
This function is used to extract the position information of the recognized mask frame when a new message is received and the message type is mask recognition.
(1) Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined "COLOR_RECOGNITION" function message. If it is a mask recognition message, the following steps are performed:
(2) Print a message indicating that a mask recognition message has been found.
(5) Extract the coordinate and size information from the mask recognition result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
(9) If a new message is not successfully read or the received message is not a mask recognition message, None is returned.
7.10.4 STM32
  • Game Introduction
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the K210 located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by STM32.
  • Getting Ready
Send the recognized information on the presence of a mask to STM32 via the K210 vision module.
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized information on the presence of a mask from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
7.10.5 Raspberry Pi
  • Game Introduction
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the K210 located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by Raspberry Pi.
  • Getting Ready
Send the recognized object data to Raspberry Pi via the K210 vision module.
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will obtain the detect object information from the K210 vision module and print it in the terminal.
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Use the function wk.update_dat() to update data. Call the function wk.find_box_msg() to obtain the received message.
When a new message is obtained, the position (x, y, w, h) of the detected object will be displayed. The object name will be printed in the terminal.
#loop
    wk.update_data()
    ret = wk.find_box_msg(k210_PACKET_FUNCTION.FIND_FACEMASK)
    if ret is not None:
7.11 Object Detection
7.11.1 K210
  • Game Introduction
In this section, the K210 vision module will be used to detect 20 different objects and highlight them with bounding boxes and labels. Initially, the module captures an image and detects if any of the 20 predefined objects are present. Upon detection, the corresponding object is highlighted with a bounding box and labeled accordingly. Next, the recognition result is displayed on the LCD screen.
  • Getting Ready
(1) Device Connection
IMG_256
① Double-click to open the software.
② Click in the bottom left corner.
③ Select the corresponding serial port number. Check “Advanced Settings”, and select “Mode-3”.
④ Click “OK” and wait for the connection to be completed.
⑤ After the connection is successful, the CanMV IDE displays the icon in the bottom left corner.
⑥ If the connection takes more than 10 seconds, it indicates a connection failure. Click “Cancel”, and a pop-up window shown below appears. Click “OK” and re-check the connection.
Tips for connection failure:
  • The selected serial port number is wrong.
Please unplug other serial ports connected to your PC. Try the above steps again to select the correct serial port number.
  • The cable used for the connection is not a data cable.
Use a Type-C data cable that supports data transmission. A Type-C data cable is included in the package before delivery.
  • Other K210 firmware is flashed.
Reflash the factory firmware, and then proceed with the connection.
Online operation:
After connecting successfully, drag the program under the same folder as this lesson to the code editor area of CanMV IDE. Click the at the bottom left corner to run the program online.
Programs run in this way will be lost when the connection is disconnected or the device is shut down. They will not be saved on the K210 vision module.
Offline operation:
② Click “Yes”.
By downloading in this way, after powering on the K210 Vision Module without connecting, it will run the MicroPython file, enabling offline operation.
  • Program Outcome
(1) K210 Vision Module
After running the program, the K210 vision module will highlight the recognized object with a box and display the object category on its screen.
(2) Master Device
Upon the program is downloaded, the master device will print the detailed information that is received and parsed. Take the ESP32 as an example.
It prints the coordinates of the recognized object’s bounding box and the detection results on the terminal. The message “crc ok” indicates that the checksum is correct.
(1) Load the vision module to obtain camera images.
Load the time module for calculating video frame rates.
Load the LCD module library for displaying images on an LCD screen.
Load the binascii module for byte processing.
#载入相关模块(load relevant modules)
import sensor, image, time, lcd
from maix import KPU
from hiwonder import hw_uart
import binascii
#定义串口对象(define serial port object)
serial = hw_uart()
(3) Define a serial port transmission function. It encapsulates the recognized information based on the defined data format and transmits it via the serial port.
def send_data(x,y,w,h,msg):
    0xAA  0x55  功能号(function number)  数据长度(data length)  data  CRC
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_OBJECT #功能编号(function number)
    Length = 0  #数据长度(data length)
    crc = 0 #校验位(checksum bit)
    data = [] #数据组(dataset)
    #参数都为0(all parameters are set to 0)
    if x==0 and y==0 and w==0 and h ==0:
        #x(小端模式)(little-endian mode)
        low = x & 0xFF #低位(low byte)
        high = x >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #y(小端模式)(little-endian mode)
        low = y & 0xFF #低位(low byte)
        high = y >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #w(小端模式)(little-endian mode)
        low = w & 0xFF #低位(low byte)
        high = w >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #h(小端模式)(little-endian mode)
        low = h & 0xFF #低位(low byte)
        high = h >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
        for i in range(len(msg)):
            msg_int = str_2_int(msg[i])
            data.append(msg_int)
    Length += len(data)
    send_buf = [FUNC_num,Length]
    for i in range(len(data)):
        send_buf.append(data[i])
    #进行CRC运算(perform a CRC calculation)
    crc = checksum_crc8(send_buf)
    send_buf.insert(0,START_1) #插入协议头1(insert protocol header 1)
    send_buf.insert(1,START_2) #插入协议头2(insert protocol header 1)
    send_buf.append(crc) #加入CRC校验码(incorporate the CRC checksum)
    print(send_buf) #打印数据(print data)
    serial.send_bytearray(send_buf) #发送数据(send data)
#定义发送数据(define the transmitted data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
#初始化LCD(initialize LCD)
lcd.init()
#以下是初始化传感器(initialize sensors)
sensor.reset()
sensor.skip_frames(time = 100)
#帧率时钟(frame rate clock)
clock = time.clock()
(7) The model used in this program can recognize 20 kinds of object tags.
#物体名称(object name)
obj_name = ("aeroplane", "bicycle", "bird", "boat", "bottle", "bus", "car", "cat", "chair", "cow", "diningtable", "dog", "horse", "motorbike", "person", "potted", "sheep", "sofa", "train", "tvmonitor")
(8) Create an image buffer object to store the captured and processed images from the camera.
img_obj = image.Image(size=(320,256))
(9) Create the necessary parameters for the object detection model, which are fixed and cannot be changed.
#创建锚框的尺寸列表,用于目标检测(create the size list of the anchor box to detect target)
anchor = (1.3221, 1.73145, 3.19275, 4.00944, 5.05587, 8.09892, 9.47112, 4.84053, 11.2364, 10.0071)
#创建 KPU 模型对象(create KPU model object)
kpu = KPU()
#加载物体检测模型文件(.kmodel 格式)(load object detection model file in .kmodel format)
kpu.load_kmodel("/sd/KPU/voc20_object_detect/voc20_detect.kmodel")
(11) Initialize YOLO model parameters.
kpu.init_yolo2(anchor, anchor_num=5, img_w=320, img_h=240, net_w=320 , net_h=256 ,layer_w=10 ,layer_h=8, threshold=0.7, nms_value=0.2, classes=20)
The function init_yolo2() initializes the YOLO model parameters.
anchor: A list of anchor box sizes used in object detection.
anchor_num: The number of anchor boxes.
img_w, img_h: The width and height of the input image.
net_w, net_h: The width and height of the input model.
layer_w, layer_h: The width and height of the final layer in the model.
threshold: The confidence threshold for detecting objects.
nms_value: The IOU threshold for non-maximum suppression.
classes: The number of target classes.
(12) Enter the while loop to recognize images.
    #loop
(13) Start timing to calculate the following frame rate.
        clock.tick() #计算每秒帧率(calculate the frame rate per second)
(14) Use the snapshot() function to capture an image from the camera. Make a copy of the image, and perform preliminary processing before passing it to the preloaded model for recognition.
        img_obj.pix_to_ai()
        kpu.run_with_output(img_obj)
(15) Obtain the detection result. If any corresponding object is detected, draw a bounding box and label the detected object.
        #计算帧率(calculate frame rate)
        fps = clock.fps()
        #如果检测到目标(if the target is detected)
        if len(dect) > 0:
            #print("dect:",dect)
            #遍历(iterate through)
            for l in dect :
                #绘制检测框(draw detection box)
                img.draw_rectangle(l[0],l[1],l[2],l[3], color=(0, 255, 0))
                img.draw_string(l[0],l[1], obj_name[l[4]], color=(0, 255, 0), scale=1.5)
                #print(type(obj_name[l[4]])) #打印物体名称(print object name)
(16) Display the frame rate information and show the processed image on the LCD screen.
        #在图像上绘制帧率信息(draw the frame rate information)
        img.draw_string(0, 0, "%2.1ffps" %(fps), color=(0, 60, 128), scale=2.0)
(17) The final capture is performed to destroy relevant processor resources in case of program execution errors, preventing device freezing.
#捕获错误并处理(capture and process errors)
    raise e
    #若出现错误,则释放 KPU 资源(If there is an error, release the KPU resource)
    kpu.deinit()
7.11.2 Arduino UNO
  • Game Introduction
  • Getting Ready
(1) Module Connection
(2) Download and Run Program
① Locate and open the “5.11.2_find_object.ino” program file in the same folder as this lesson.
② In the “Select board” option, select the corresponding Arduino development board and port. Take “Arduino Uno” and “COM8” as an example to demonstrate. The COM port is not unique. You can check the COM port number in the computer’s device manager.
③ Click button to compile the program. After the compilation is completed, click to upload the program into the Arduino development board.
  • Program Outcome
Open the “Arduino IDE” serial monitor, the recognition result and the coordinates information of the recognized object are visible. Select the baud rate to 115200.
The touch screen of K210 vision module has a resolution of 320*240. The origin of its pixel coordinates located at the top left corner of the module, as illustrated in the diagram below:
The msg represents the name of the recognized object. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
(1) Import Header File
#include "WonderK210.h"
WonderK210.h is a header file that contains declarations, definitions, function prototypes, and other necessary information related to the WonderK210 controller. This header file is used for functions and structure definitions that operate the WonderK210 controller.
(2) Declare Variables
//接收控制器(receive controller)
WonderK210* wk;
//消息存储变量(message storage variable)
(3) Initial Settings
  //开启串口接收(enable serial port receiving)
  wk->serial_begin();
Serial.begin(115200): initializes serial communication. The baud rate is set to 115200.
malloc(sizeof(WonderK210)): allocates the memory with the size of the WonderK210 type, and assigns the address to the wk pointer.
wk->serial_begin(): calls the serial_begin() function via wk pointer to initialize serial communication.
(4) Loop to obtain the latest information from K210
void loop() {
  //更新消息(updata message)
  wk->update_data();
  //获取消息(obtain message)
  bool rt = wk->recive_box_msg(result , K210_FIND_OBJECT);
(5) Printing result information
void loop() {
  wk->update_data();
  //若获取到新的消息(if a new message is obtained)
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.11.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling object detection. The coordinates of the bounding box for the detected object and the recognition result will be printed on the terminal.
  • Getting Ready
(1) Wiring Instruction
Connect the ESP32 to the PC with a USB data cable. Then, connect the K210 vision module to the ESP32’s serial port with a 4PIN wire.
(2) Download and Run K210 Program
IMG_256
④Click “OK” and wait for the connection to be completed.
IMG_256 IMG_256
IMG_256
Online operation:
IMG_256
Offline operation:
① After connecting, drag the program under the same directory to the CanMV IDE code editing area. Click “Tools” on the toolbar. Select “Save open script to CanMV Cam (as main.py)”.
IMG_256
② Click “Yes”.
IMG_256
③ Once the writing is successful, a window shown below will appear. Click “OK”. This saves the MicroPython file into the K210 Vision Module.
IMG_256
(3) Download and Run ESP32 Program
① Connect the ESP32 controller to the computer with a USB data cable. Open the Python editor. Drag the programs “WonderK210.py” and “main.py” into the editor interface.
② Select the or click “Connect” in the menu bar to choose the corresponding COM port. Let’s use “COM15” as an example. The COM port is not unique. You can check the COM port number in the computer’s device manager.
IMG_256
To avoid encountering any unexpected anomalies during the flashing process, please strictly follow the operation steps.
  • Program Outcome
After downloading the program, the K210 vision module will perform the object detection and display the recognized result on the screen. It will also print the coordinates of the object recognition bounding box and the detection outcome on the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games->6.11 Object Recognition
(1) Import Module
# 载入时间模块(load time module)
(2) Establish Communication
Instantiate the K210 communication class.
# 实例化K210通信类(instantiate K210 communication class)
wk = WonderK210()
Enable the serial port.
# 开启串口(start serial port)
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_object() searches for object in the data and retrieve the received messages.
#loop
  # 更新接收消息(update receiving message)
  wk.update_data()
  # 获取接收消息(obtain receiving message)
  ret = wk.find_object()
  if ret is not None:
    # 打印消息内容(print message content)
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  # 延时10ms(delay for 10ms)
  time.sleep_ms(10)
(4) Information Obtaining Function
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
  # 物体识别 box msg(object recognition box msg)
  def find_object(self):
    if True == self.__read_succeed: # 若有新消息(if there is a new message)
      if k210_PACKET_FUNCTION.FIND_OBJECT == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_object()")
        self.__read_succeed = False
        ret.function = self.__pk_result.function
        ret.x = (self.__pk_result.data[0] & 0x00FF) | ((self.__pk_result.data[1] << 8 ) & 0xFF00)
        ret.y = (self.__pk_result.data[2] & 0x00FF) | ((self.__pk_result.data[3] << 8 ) & 0xFF00)
        ret.w = (self.__pk_result.data[4] & 0x00FF) | ((self.__pk_result.data[5] << 8 ) & 0xFF00)
        ret.h = (self.__pk_result.data[6] & 0x00FF) | ((self.__pk_result.data[7] << 8 ) & 0xFF00)
        # 清除存储变量(clear storage variables)
        self.__pk_result.data.clear()
        return ret
        return None
      return None
This function is used to extract the position information of the recognized object frame when a new message is received and the message type is object detection.
(1) Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined "COLOR_RECOGNITION" function message. If it is a object detection message, the following steps are performed:
(2) Print a message indicating that a object detection message has been found.
(5) Extract the coordinate and size information from the object detection result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
(9) If a new message is not successfully read or the received message is not a object detection message, None is returned.
7.11.4 STM32
  • Game Introduction
  • Getting Ready
Send the recognized object information to STM32 via the K210 vision module.
① Connect the K210 vision module to a computer with a Type-C data cable.
① Locate and open “RosRobotControllerM4.uvprojx” program file in the same folder as this lesson.
② Click to perform compiling. After the compiling is completed, click to download the program to the STM32 board.
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized object information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
(1) Initial Settings
#include "k210_packet.h"
#include "global.h"
The “k210_packet.h” consists of data structure definitions, function declarations, and macros related to the K210. It is used to handle data packets, communication protocols, or device control related to the K210. The file “global.h” contains global constants, variables, and more.
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
7.11.5 Raspberry Pi
  • Game Introduction
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
#loop
    wk.update_data()
    ret = wk.find_box_msg(k210_PACKET_FUNCTION.FIND_OBJECT)
    if ret is not None:
7.12 Autonomous Learning and Classification
7.12.1 K210
  • Game Introduction
This program performs self learning classification via KPU neural network. The game needs to capture multiple images of an object, extract the common features from these images, and train the vision module to recognize and classify the object. Then, the similarity between the current image captured by the module and the recorded images is compared. Based on the degree of similarity, the module determines the corresponding class and prints the relevant class name.
  • Getting Ready
IMG_256
IMG_256
IMG_256 IMG_256
IMG_256
Online operation:
Offline operation:
② Click “Yes”.
IMG_256
IMG_256
  • Program Outcome
After the program runs, it enters the image initialization mode.
Press the “K2” button to enter the training mode. Continue to press the “K2” to capture images. Each press captures one image, and a total of 5 images need to be captured per group. You can capture 3 groups in total.
For the subsequent two groups, you can follow the same steps. Long-press the “K2” button can reset.
IMG_256 IMG_256 IMG_256
(2) Master Device
After the program is downloaded, the vision module can perform self learning classification and print the detection result on the terminal. The message “crc ok” indicates that the checksum is correct.
Import the board for obtaining the development board or device information.
Import the fm for managing pin allocations and allowing mapping hardware signals or functions to specific pins.
Import the utils to provide function for hardware and system interactions.
#导入所需的库(import the required libraries)
import lcd
import sensor
from maix import GPIO
from board import board_info
from fpioa_manager import fm
from image import Image
from hiwonder import hw_uart , hw_key
import binascii
serial = hw_uart()
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_SELF_LEARNING #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
(4) Define state and event. Create enumerations for STATE and EVENT to manage the different states and triggered events of the state machine.
############################## define state and func begin ##############################
# 定义状态枚举类 STATE,用于标识状态(Define the enumeration class STATE to identify states)
class STATE(object):
    IDLE = 0          # 空闲状态(idle state)
    INIT = 1          # 初始化状态(initial state)
    TRAIN_CLASS_1 = 2 # 训练类别 1 状态(training state for class 1)
    TRAIN_CLASS_2 = 3 # 训练类别 2 状态(training state for class 2)
    TRAIN_CLASS_3 = 4 # 训练类别 3 状态(training state for class 3)
    CLASSIFY = 5      # 分类状态(classification state)
    STATE_MAX = 6     # 状态的最大值(the maximum value for state)
# 定义事件枚举类 EVENT,用于标识事件(define the enumeration class EVENT to identify events)
class EVENT(object):
    POWER_ON = 0            # 上电事件(power-on event)
    BOOT_KEY = 1            # 按下启动键事件(boot button press event)
    BOOT_KEY_LONG_PRESS = 2 # 长按启动键事件(boot button long press event)
    EVENT_NEXT_MODE = 3     # 切换到下一个模式事件(switch to the next mode event)
    EVENT_MAX = 4           # 事件的最大值(the maximum value for event)
(5) The state machine logic is as follows:
Define a StateMachine class to handle actions and state transitions in different states.
The state machine includes functions for handling states and events, and a list of state transitions.
# 定义状态机类 StateMachine(Define state machine class StateMachine)
class StateMachine(object):
    def __init__(self, state_handlers, event_handlers, transitions):
        # 初始状态为IDLE(initial state is IDLE)
        self.previous_state = STATE.IDLE
        self.current_state = STATE.IDLE
        # 存储状态处理函数、事件处理函数和状态转换的列表(Store lists of state handle function, event handle function, and state transition)
        self.state_handlers = state_handlers
        self.event_handlers = event_handlers
        self.transitions = transitions
    # 重置状态机(reset state machine)
    def reset(self):
    def get_next_state(self, cur_state, cur_event):
    def enter_state_action(self, state, event):
    发送event。根据当前状态和event,查找下一个状态,然后执行对应的action。(Send an event. Find the next state based on the current state and event, then execute the corresponding action)
        param event: 要发送的event(the event to be sent)
    def emit_event(self, event):
(6) State actions and event responses:
For each state, enter, execute, and exit actions have been defined.
Response actions have been defined for specific events, such as button press and long press.
282
# 进入空闲状态时的动作(the action performed upon entering the idle state)
def enter_state_idle(self, state, event):
    print("enter state: idle")
# 退出空闲状态时的动作(the action performed upon exiting the idle state)
def exit_state_idle(self, state, event):
    print("exit state: idle")
(7) State transition logic:
State transitions are triggered by states and events. For example, the transition from the initialization state to the training state is triggered by a specific event, such as a button press.
496
497
498
499
500
501
502
503
# 过渡表(transition table)
transitions = [
    [STATE.IDLE, STATE.INIT, EVENT.POWER_ON],
    [STATE.INIT, STATE.TRAIN_CLASS_1, EVENT.EVENT_NEXT_MODE],
    [STATE.TRAIN_CLASS_1, STATE.TRAIN_CLASS_2, EVENT.EVENT_NEXT_MODE],
    [STATE.TRAIN_CLASS_2, STATE.TRAIN_CLASS_3, EVENT.EVENT_NEXT_MODE],
    [STATE.TRAIN_CLASS_3, STATE.CLASSIFY, EVENT.EVENT_NEXT_MODE]
(8) Main loop and button logic:
A main loop has been implemented. It includes detecting the button state and executing the corresponding state machine actions.
Button actions, such as short press or long press, are handled based on the current state of the state machine.
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
    btn_ticks_cur = time.ticks_ms()
    delta = time.ticks_diff(btn_ticks_cur, btn_ticks_prev)
    btn_ticks_prev = btn_ticks_cur
    # 检测引脚状态以检测按键动作(detect pins state to detect button action)
    if boot_gpio.key_scan(2) == 1:
        boot_btn.key_down(delta)
        boot_btn.key_up(delta)
    # 根据状态执行不同的循环函数(execute different loop functions based on the state)
    if state_machine.current_state == STATE.INIT:
        loop_init()
    elif state_machine.current_state == STATE.CLASSIFY:
        loop_classify()
    elif state_machine.current_state == STATE.TRAIN_CLASS_1 \
            or state_machine.current_state == STATE.TRAIN_CLASS_2 \
            or state_machine.current_state == STATE.TRAIN_CLASS_3:
        loop_capture()
(9) Create a KPU object and load the model file from the corresponding path.
666
667
668
669
# 初始化KPU模型(initialize the KPU model)
kpu = KPU()
kpu.load_kmodel("/sd/KPU/self_learn_classifier/mb-0.25.kmodel")
(10) Initialize YOLO model parameters.
Loop processing for specific states:
Specific loop processing functions have been defined for different states, such as initialization, training, and classification.
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
################################# define Button begin #################################
# 未启用 state machine 的主循环,所以这里将需要循环执行的函数放在while True里(The function that needs to be executed in a loop can be placed within a while True loop since there is no state machine's main loop enabled)
def loop_init():
    if state_machine.current_state != STATE.INIT:
        return
    # 在初始阶段绘制图像(draw image at the initial stage)
    img_init.draw_rectangle(0, 0, lcd.width(), lcd.height(), color=(0, 0, 255), fill=True, thickness=2)
    img_init.draw_string(65, 90, "Self Learning Demo", color=(255, 255, 255), scale=2)
    img_init.draw_string(5, 210, "Short press:  next", color=(255, 255, 255), scale=1)
    img_init.draw_string(5, 225, "Long press:    restart", color=(255, 255, 255), scale=1)
    lcd.display(img_init)
605
606
607
608
609
610
611
612
613
#分类阶段的循环函数(the loop function of the classification stage)
def loop_classify():
    global central_msg, bottom_msg,send_msg
    scores = []
    feature = kpu.run_with_output(img, get_feature=True)
    high = 0
    index = 0
7.12.2 Arduino UNO
  • Game Introduction
  • Getting Ready
① Locate and open the “5.12.2_find_self_learning.ino” program file in the same folder as this lesson.
  • Program Outcome
Open the “Arduino IDE” serial monitor. The number of the self-learning target (the content of msg) can be checked. Select the baud rate to 115200.
WonderK210* wk;
Find_Msg_st* result;
  wk->serial_begin();
  result = malloc(sizeof(Find_Msg_st));
malloc(sizeof((Find_Msg_st)): allocates memory of the size of the Find_Msg_st type, and the address is assigned to the result pointer.
void loop() {
  wk->update_data();
  bool rt = wk->recive_msg(result , K210_FIND_SELF_LEARNING);
(5) Print Result Information
If a new result is obtained (rt is true), the serial port will print the recognition result.
  if(rt)
7.12.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling self learning classification. The recognition result will be printed on the terminal.
  • Getting Ready
IMG_256
IMG_256 IMG_256
IMG_256
There are two ways to run K210 programs: online and offline.
(2) Online operation:
IMG_256
Offline operation:
IMG_256
② Click “Yes”.
IMG_256
IMG_256
IMG_256
  • Program Outcome
After downloading the program, the K210 vision module will perform self learning classification and display the detection result in the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games->6.12 Autonomous Learning and Classification
(1) Import Module
from WonderK210 import WonderK210 , Find_Box_Msg_st , Find_Box_st , Find_Msg_st
wk = WonderK210()
wk.serial_begin()
(3) Main Function
Enter a while loop to continuously update and receive messages. The function wk.find_self_learning() searches for target in the data and retrieve the received messages.
#loop
  wk.update_data()
  ret = wk.find_self_learning()
  if ret is not None:
    print(ret.msg)
  time.sleep_ms(10)
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
  # 自主学习识别 msg(autonomous learning and recognition msg)
  def find_self_learning(self):
      if k210_PACKET_FUNCTION.FIND_SELF_LEARNING == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_self_learning()")
        ret = Find_Msg_st()
        if self.__pk_result.data_length > 0:
          ret.msg = ''.join(chr(value) for value in self.__pk_result.data[:])
        return ret
        return None
      return Nonexxxxxxxxxx
This function is used to extract the position information of the recognized self learning classification target when a new message is received and the message type is self learning classification.
① Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined "COLOR_RECOGNITION" function message. If it is a self learning classification message, the following steps are performed:
② Print a message indicating that a self learning classification message has been found.
③ Set self.__read_succeed to False, indicating that this message has been successfully processed.
④ Create an object named ret, which is an instance of the Find_Box_st class.
⑤ Extract the coordinate and size information from the self learning classification result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
⑥ If the length of the message data is greater than 8, convert the remaining part of the data into a string. Assign it to the msg attribute of the ret object.
⑦ Clear the variable self.__pk_result.data that stores the message data.
⑧ Return the ret object that contains the extracted recognition result information.
⑨ If a new message is not successfully read or the received message is not a self learning classification message, None is returned.
7.12.4 STM32
  • Game Introduction
  • Getting Ready
Send the recognized object classification information to STM32 via the K210 vision module.
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized object classification information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
//有方框数据和消息数据(include box data and message data)
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
//只有消息数据(only includes message data)
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
(2) Message Data Processing
* @brief 只有方框数据 的回调处理(callback processing for only including box data)
* @param frame 数据帧(data frame)
* @retval void
static void k210_Box_cb(struct k210_PacketRawFrame *frame)
    Find_Box_st *rec = (Find_Box_st*)frame->data_and_checksum;
	printf("x:%d,y:%d,w:%d,h:%d\n",rec->box.x,rec->box.y,rec->box.w,rec->box.h);
* @brief 有方框数据和消息数据 的回调处理(callback processing for including box data and message data)
* @retval void
static void k210_Box_Msg_cb(struct k210_PacketRawFrame *frame)
    Find_Box_Msg_st *rec = (Find_Box_Msg_st*)frame->data_and_checksum;
	rec->msg[frame->data_length - 8] = '\0'; //将check位清除(clear check bit)
	printf("msg:%s\n",rec->msg);
* @brief 只有消息数据 的回调处理(callback processing for only including message data)
* @retval void
static void k210_Msg_cb(struct k210_PacketRawFrame *frame)
    Find_Msg_st *rec = (Find_Msg_st*)frame->data_and_checksum;
	rec->msg[frame->data_length] = '\0'; //将check位清除(clear check bit)
(3) Callback Function
//注册回调函数(register callback function)
void k210_packet_handle_init(void)
    k210_packet_register_callback(&k210_packet_controller, K210_COLOR_RECOGNITION, k210_Box_cb); //颜色识别(color recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_BARCODES, k210_Box_Msg_cb); //条形码识别(barcode recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_QRCODES, k210_Box_Msg_cb);	 //二维码识别(QR code recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_APRILTAGS, k210_Box_Msg_cb);//机器码识别(AprilTag recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACE_YOLO, k210_Box_cb); 	 //人脸检测(face detection)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACEFEATURE, k210_Box_cb);  //人脸特征识别(face feature recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACEMASK, k210_Box_Msg_cb); //口罩识别(mask recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_OBJECT, k210_Box_Msg_cb);	 //物体识别(object recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_SELF_LEARNING, k210_Msg_cb);//自主学习分类(autonomous learning and classification)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_DIGITAL, k210_Msg_cb);      //手写数字识别(handwritten number recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACE_RECOGNITION, k210_Box_Msg_cb); //物体识别(object recognition)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_RED_FOLLOW, k210_Box_cb); //红色追踪(red tracking)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_SIGNPOST_FOLLOW, k210_Box_Msg_cb); //路标追踪(road sign tracking)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_DIGITAL_CARD, k210_Box_Msg_cb); //数字卡片识别(number card recognition)
    k210_packet_register_callback(&k210_packet_controller, K210_GARBAGE_SORTING, k210_Box_Msg_cb); //垃圾分类(waste classification)
    k210_packet_register_callback(&k210_packet_controller, K210_COLOR_SORTING, k210_Box_Msg_cb); //多种颜色识别(multiple colors recognition)
Multiple callback functions are registered through the function k210_packet_handle_init. Each callback function corresponds to a different processing program. These callback functions are associated with different functional modules related to the K210. Each module corresponds to a different recognition or data processing task.
Each call to k210_packet_register_callback associates a specific task’s processing function with the K210 controller. For example:
K210_COLOR_RECOGNITION corresponds to the color recognition task and uses the function k210_Box_cb to process the data.
K210_FIND_BARCODES corresponds to the barcode recognition task and uses the function k210_Box_Msg_cb to process the data.
&k210_packet_controller is a pointer to the K210 controller. It provides interfaces and methods for handling different tasks.
K210_COLOR_RECOGNITION is a specific function code. It represents the function that K210 needs to perform.
k210_Box_cb is a callback function. It will be called when data associated with the task type K210_COLOR_RECOGNITION is received.
7.12.5 Raspberry Pi
  • Game Introduction
Send the recognition result of the self learning classification to Raspberry Pi via the K210 vision module.
  • Getting Ready
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding pins on the Raspberry Pi with a DuPont wire.
① Move the program files “main.py” and “WonderK210.py” from the current directory to Raspberry Pi via a USB drive.
② Press “Ctrl+Alt+T” in the Raspberry Pi system to open the command line terminal.
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will obtain the detection result of the self learning classification and print it in the terminal.
from WonderK210 import WonderK210 , Find_Box_Msg_st , Find_Box_st , Find_Msg_st , k210_PACKET_FUNCTION
(2) Create Object
Instantiate the K210 communication class, and simultaneously activate the serial port.
wk = WonderK210()
wk.serial_begin()
7.13 Handwritten Number Recognition
7.13.1 K210
  • Game Introduction
(1) This program uses the WonderMV vision module to recognize the handwritten numbers 0 to 9, and display the recognition result on the screen. Then, the recognized data is sent to the host device through the serial port.
  • Getting Ready
② Power the other master devices with their respective power interfaces, and connect the UART interfaces with DuPont cables.
③ For example, connect the ESP32 to the PC with a USB data cable. Then, connect the K210 vision module to the ESP32’s serial port with a DuPont cable.
Online operation:
Offline operation:
② Click “Yes”.
④ By downloading in this way, after powering on the K210 Vision Module without connecting, it will run the MicroPython file, enabling offline operation.
  • Program Outcome
① After running the program, you can write a number (0 to 9) on a piece of white paper. Once the number is recognized, the recognition result will be displayed on the screen.
(2) Mater Device
① Upon the program is downloaded, the master device will print the detailed information that is received and parsed. Take the ESP32 as an example.
② After the program is downloaded, the K210 vision module can recognize the handwritten number and display the detection result on the screen. The relevant information is printed in the terminal. The message “crc ok” indicates that the checksum is correct.
① Load the image module for image buffering and AprilTag processing.
② Load the time module for calculating video frame rates.
③ Load the LCD module library for displaying images on an LCD screen.
④ Load the KPU library for loading and processing the model.
⑤ Load the hw_uart module from the hiwonder library for serial communication.
import gc
import binascii
serial = hw_uart()paste source code here.
(2) Define the serial port transmission object.
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_DIGITAL #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
(4) Define the sent data storage variables. The “send_x” and “send_y” represent the x and y values of the top-left corner coordinates of the recognition box. The “send_msg” represents the specific information extracted from the image.
#send_x = 0
#send_y = 0
#send_w = 0
#send_h = 0
send_msg = ""
lcd.init()
sensor.reset()
sensor.set_windowing((224, 224))
(7) Initialize the KPU model:
① Create the KPU model object.
② Load the model file for number detection. It is used for recognizing handwritten numbers.
kpu = KPU()
#加载检测模型文件(.kmodel 格式)(load detection model file in .kmodel format)
kpu.load_kmodel("/sd/KPU/mnist/uint8_mnist_cnn_model.kmodel")
(8) Enter the while loop to perform number detection. The program logic is as follows:
While loop:
  • Capture an image from the camera.
  • Process the captured image, converting it to grayscale, resizing, inverting colors, and stretching contrast. This meet the input requirements of the model.
  • Convert the processed image to the AI format and perform number detection using the KPU model.
  • The detection result is the index of the number category and the confidence score.
  • If the recognized number is 1 or 5 and the confidence score is above a set threshold, such as 0.999, the recognized number will be displayed on the image.
  • Display the processed image and frame rate information.
    #loop
        # 进行垃圾回收以释放内存(perform waste collection to free up memory)
        gc.collect()
        # 从摄像头传感器捕获图像(capture an image from the vision module)
② Image processing:
        # 将图像调整大小为特定尺寸(112x112)(adjust the image to a specific size (112x112))
        img_mnist2=img_mnist1.resize(112,112)
        # 反转图像的颜色(invert the colors of the image)
        img_mnist2.invert()
        # 对图像应用对比度拉伸以增强图像特征(apply contrast stretching to the image to enhance image features)
        img_mnist2.strech_char(1)
        # 将处理后的图像转换为AI格式(convert the processed image to AI format)
        img_mnist2.pix_to_ai()
        # 在处理后的图像上运行AI模型并获取输出列表(run the AI model on the processed image and obtain the output list)
        out = kpu.run_with_output(img_mnist2, getlist=True)
        # 在输出列表中找到最大值及其索引(find the maximum value and its index in the output list)
        max_mnist = max(out)
③ Recognized number processing:
        index_mnist = out.index(max_mnist)
        send_msg = str(index_mnist) #转换数据(convert data)
        send_data(0,0,0,0,send_msg) #发送数据(send data)
        # 对最大值应用Sigmoid函数以获得置信度分数(apply the Sigmoid function to the maximum value to obtain a confidence score)
        score = KPU.sigmoid(max_mnist)
        # 检查识别出的数字是否为1或5(check if the recognized number is 1 or 5)
        if index_mnist == 1:
            if score > 0.999:
④ Display the recognition result:
        # 在LCD屏幕上显示图像(display the processed image on the LCD)
        lcd.display(img)
(9) Process errors and release resources:
    raise e
    kpu.deinit()
7.13.2 Arduino UNO
  • Game Introduction
Send the recognized color data to Arduino UNO via the K210 vision module.
  • Getting Ready
① Locate and open the “5.13.2_find_digital.ino” program file in the same folder as this lesson.
  • Program Outcome
(1) After running the program, you can write a number (0 to 9) on a piece of white paper. Once the number is recognized, the recognition result will be displayed on the screen.
(2) Open the “Arduino IDE” serial monitor to see the content of the recognized number, which is the content of msg. Select the baud rate to 115200.
(3) The touch screen of K210 vision module has a resolution of 320*240. The origin of its pixel coordinates located at the top left corner of the module, as illustrated in the diagram below:
(4) The msg represents the content of the recognized target QR code. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
WonderK210* wk;
WonderK210* wk: Declares a pointer named “wk” of type WonderK210. This pointer represents an instance or object of the WonderK210 controller.
Find_Box_st* result: Declares a pointer named “result” of type Find_Box_st. This pointer stores or points to a data structure of type Find_Box_st, which is used to store information about the detected boxes.
  Serial.begin(115200);
  //分配内存(allocate memory)
  wk = malloc(sizeof(WonderK210));
  wk->serial_begin();
malloc(sizeof((Find_Msg_st)): allocates memory of the size of the Find_Msg_st type, and the address is assigned to the result pointer. (4) Loop to obtain the latest information from K210
void loop() {
  wk.update_data();
  bool rt = wk->recive_msg(result , K210_FIND_DIGITAL);
After entering the “loop()” function, use the “wk.update_data()” function to continuously obtain the latest recognition results from the K210 vision module. Then, acquire and parse the data of the latest recognized frame’s structure, storing it in the result variable.
  if(rt)
    Serial.print("msg:");
    Serial.println(result->msg);
① If a new result is obtained (rt is true), the serial port will print the recognition result.
7.13.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling handwritten number recognition. The recognition result will be printed on the terminal.
  • Getting Ready
② Connect the ESP32 to the PC with a USB data cable. Then, connect the K210 vision module to the ESP32’s serial port with a 4PIN wire.
Online operation:
Offline operation:
① Click “Yes”.
② Once the writing is successful, a window shown below will appear. Click “OK”. This saves the MicroPython file into the K210 Vision Module.
③ By downloading in this way, after powering on the K210 Vision Module without connecting, it will run the MicroPython file, enabling offline operation.
  • To avoid encountering any unexpected anomalies during the flashing process, please strictly follow the operation steps.
  • In you encounter difficulties in properly reading the COM port or downloading the program, please refer to the “ESP32 Board Firmware Recovery Method” to reflash the firmware.
  • Program Outcome
After downloading the program, the K210 vision module will recognize the handwritten number and print the recognition result on the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
(1) Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 6. AI Vision Games->6.13 Handwritten Number Recognition
(2) Import Module
Import the time module, the WonderK210 communication class, and the message format classes (Find_Box_Msg_st, Find_Box_st, and Find_Msg_st) for subsequent usage.
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st)
(3) Establish Communication
① Instantiate the K210 communication class.
wk = WonderK210()
② Enable the serial port.
wk.serial_begin()
(4) Main Function
① Enter a while loop to continuously update and receive messages. The function wk.find_digital() searches for target in the data and retrieve the received messages.
  wk.update_data()
  ret = wk.find_digital()
② If a recognition result is found (ret is not None), the recognition result will be printed.
  # 若有新消息获取到(if a new message is obtained)
  if ret is not None:
    print(ret.msg)
  time.sleep_ms(10)
(5) Information Obtaining Function
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
  # 数字识别 msg(number recognition msg)
  def find_digital(self):
      if k210_PACKET_FUNCTION.FIND_DIGITAL == self.__pk_result.function: # 是否为该功能消息(if it is the function message)
        print("find_digital()")
        ret = Find_Msg_st()
        return ret
        return None
      return None
① This function is used to extract the position information of the recognized handwritten number frame when a new message is received and the message type is handwritten number recognition.
② Firstly, it checks if self.__read_succeed is True. If the message is successfully read, it checks if self.__pk_result.function is a predefined COLOR_RECOGNITION function message. If it is a handwritten number recognition message, the following steps are performed:
  • Print a message indicating that a handwritten number recognition message has been found.
  • Set self.__read_succeed to False, indicating that this message has been successfully processed.
  • Create an object named ret, which is an instance of the Find_Box_st class.
  • Extract the coordinate and size information from the handwritten number recognition result. Assign them to the corresponding attributes (x, y, w, h) of the ret object.
  • If the length of the message data is greater than 8, convert the remaining part of the data into a string. Assign it to the msg attribute of the ret object.
  • Clear the variable self.__pk_result.data that stores the message data.
  • Return the ret object that contains the extracted recognition result information.
  • If a new message is not successfully read or the received message is not a handwritten number recognition message, None is returned.
7.13.4 STM32
  • Game Introduction
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by STM32.
  • Game Introduction
Send the recognized handwritten number information to STM32 via the K210 vision module.
  • Getting Ready
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding pins on the STM32 with a DuPont wire.
  • Program Outcome
(1) Once the program runs, the STM32 will obtain the recognized handwritten number information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
① The “k210_packet.h” consists of data structure definitions, function declarations, and macros related to the K210. It is used to handle data packets, communication protocols, or device control related to the K210. The file “global.h” contains global constants, variables, and more.
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
② Struct “BoxData”: a structure “BoxData” is defined. It contains four uint16_t type member variables: x, y, w, and h. These variables represent the position and size of a rectangular box.
//只有方框数据(only includes box data)
typedef struct {
	BoxData box;
}Find_Box_st;
③ Struct “Find_Box_st”: a structure “Find_Box_st” is defined. It contains a variable “box” of “BoxData” type. This structure represents a data type that includes only the information of a rectangular box, excluding other message data.
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
④ Struct “Find_Box_Msg_st”: a structure “Find_Box_Msg_st” is defined. It contains a variable of type “BoxData” named “box” and an array of uint8_t type with a length of 100 named “msg”. This structure represents a data type that includes both the information of a rectangular box and a message data with a length of 100.
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
⑤ Struct “Find_Msg_st”: a structure “Find_Msg_st” is defined. It contains a single array of uint8_t type with a length of 100 named “msg”. This structure represents a data type that includes only the message data with a length of 100 and does not include the information of a rectangular box.
* @retval void
k210_Box_cb: handles data frames that only contain box data. It extracts data of type Find_Box_st from the data frame. It prints the position and size information of the box based on the extracted data.
* @retval void
② It extracts data of type Find_Box_Msg_st from the data frame. It prints the position and size information of the box based on the extracted data. It clears the checksum of the message data and then prints the message content.
* @retval void
“k210_Msg_cb”: handles data frames that only contain message data. It extracts data of type Find_Msg_st from the data frame. It clears the checksum of the message data and then prints the message content. These functions serve as callback functions. When receiving specific types of data frames, these functions are called to process the data within the frames.
① Multiple callback functions are registered through the function k210_packet_handle_init. Each callback function corresponds to a different processing program. These callback functions are associated with different functional modules related to the K210. Each module corresponds to a different recognition or data processing task.
② Each call to k210_packet_register_callback associates a specific task’s processing function with the K210 controller. For example:
  • K210_COLOR_RECOGNITION corresponds to the color recognition task and uses the function k210_Box_cb to process the data.
  • K210_FIND_BARCODES corresponds to the barcode recognition task and uses the function k210_Box_Msg_cb to process the data.
  • Similar cases exist for other tasks. Take “k210_packet_register_callback(&k210_packet_controller, K210_COLOR_RECOGNITION, k210_Box_cb” as an example:
  • The k210_packet_register_callback function is used to associate the callback function k210_Box_cb with a specific task type K210_COLOR_RECOGNITION.
  • &k210_packet_controller is a pointer to the K210 controller. It provides interfaces and methods for handling different tasks.
  • K210_COLOR_RECOGNITION is a specific function code. It represents the function that K210 needs to perform.
  • k210_Box_cb is a callback function. It will be called when data associated with the task type K210_COLOR_RECOGNITION is received.
  • Each callback function receives data frames from the K210 controller and uses specific processing functions based on the task type to handle the data.
7.13.5 Raspberry Pi
  • Game Introduction
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by Raspberry Pi.
  • Game Introduction
Send the recognized information of the handwritten number to Raspberry Pi via the K210 vision module.
  • Getting Ready
③ In the command line terminal, enter the command to navigate to the directory where the program is located.
cd Desktop/
④ Enter the command to start the program.
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will obtain the recognition result of the handwritten number and print it in the terminal.
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st),K210识别类型(K210 recognition class)(k210_PACKET_FUNCTION)
① Load the K210 communication class (WonderK210), message format class (Find_Box_Msg_st, Find_Box_st, Find_Msg_st), and K210 recognition type class (k210_PACKET_FUNCTION).
(2) Create Object
① Instantiate the K210 communication class, and simultaneously activate the serial port.
wk = WonderK210()
wk.serial_begin()
(3) Main Function
① Use the function wk.update_dat() to update data. Call the function wk.find_msg() to obtain the received message.
② When a new message is obtained, the detection result of the handwritten number will be printed.
#loop
    wk.update_data()
    ret = wk.find_msg(k210_PACKET_FUNCTION.FIND_DIGITAL)
    if ret is not None:
        print("ret.msg = {}".format(ret.msg))
7.14 Red Ball Tracking
7.14.1 K210
  • Game Introduction
In this program, a red threshold is already set, and the recognition for the red ball can be directly performed. When red is detected, it will be highlighted with a bounding box. The recognized data will be sent to the host device through the serial port.
  • Getting Ready
① Download and Run K210 Program
② Double-click to open the software.
③ Click in the bottom left corner.
④ Select the corresponding serial port number. Check “Advanced Settings”, and select “Mode-3”.
⑤ Click “OK” and wait for the connection to be completed.
⑥ After the connection is successful, the CanMV IDE displays the icon in the bottom left corner.
⑦ If the connection takes more than 10 seconds, it indicates a connection failure. Click “Cancel”, and a pop-up window shown below appears. Click “OK” and re-check the connection.
Online operation:
① After connecting successfully, drag the program under the same folder as this lesson to the code editor area of CanMV IDE. Click the at the bottom left corner to run the program online.
Offline operation:
① Click “Yes”.
  • Program Outcome
① After running the program, the K210 vision module will highlight the recognized red object with a box, as shown below:
(2) Mater Device
② It prints the coordinates of the red ball’s bounding box and the detection results on the terminal. The message “crc ok” indicates that the checksum is correct.
④ Import the KPU library for model loading and processing.
⑥ Load the binascii module for byte processing.
import sensor
import image
import lcd
import binascii
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_RED_FOLLOW #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
(5) Initialize the LCD screen and the vision module.
lcd.init()
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QVGA)
sensor.set_auto_gain(False)
sensor.set_auto_whitebal(False)
(6) Create a frame rate clock for measuring the frame rate.
(7) Define parameters for the bounding box.
#方框参数(box parameters)
r = [(320//2)-(50//2), (240//2)-(50//2), 50, 50]
(8) Set the color threshold for red recognition.
color_thresholds = [
    (20,80,20,62,20,35), # Red
(9) Enter the main loop.
#loop
(10) Capture sensor image for subsequent color recognition.
    #从传感器捕获一张图像(capture an image from the vision module)
    img = sensor.snapshot()
(11) Search for the corresponding color threshold region in the recognized image. Once the corresponding color region is detected, enclose the largest area of the identified color with a bounding box on the image and send the recognition information via UART serial port.
    for color_idx, threshold in enumerate(color_thresholds):
        #遍历图像中找到的颜色区块(iterate through the image to find the color block)
        blobs = img.find_blobs([threshold], pixels_threshold=100, area_threshold=100, merge=True, margin=10)
        #是否找到(whether it is found)
        if blobs:
            area_max = 0
            blob_max = blobs[0]
            #寻找最大的颜色块(find the maximum color block)
            for blob in blobs:
                area = blob.w()*blob.h()
                if(area_max < area):
                    blob_max = blob
                    area_max = area
            if area_max < 200: # 限制识别到的方框大小(limit the size of the recognized box)
            #画方框(draw box)
            img.draw_rectangle(blob_max.rect())
            img.draw_cross(blob_max.cx(), blob_max.cy())
            img.draw_string(blob_max.cx() + 10, blob_max.cy() - 10, 'Red', color=(255, 255, 255))
            #将方框数据与消息赋值(assign values to box data and message)
            send_x = blob_max.x()
            send_y = blob_max.y()
            send_w = blob_max.w()
            send_h = blob_max.h()
            #发送数据(send data)
            send_data(send_x,send_y,send_w,send_h,None)
(12) Display the image on the LCD.
    lcd.display(img)
7.14.2 Arduino UNO
  • Game Introduction
For the instructions on downloading the program to K210 and analyzing the K210-related code, please refer to the “K210” located in the same directory as this tutorial. This lesson only analyzes the data transmitted by K210 and received by Arduino UNO.
  • Game Introduction
  • Getting Ready
② Connect the GND, RX, and TX pins of the K210’s UART interface to the corresponding GND, D6, and D7 pins on the Arduino UNO with a DuPont wire.
① Locate and open the “5.14.2_find_red_follow.ino” program file in the same folder as this lesson.
  • Program Outcome
(2) Open the “Arduino IDE” serial monitor to view the coordinate information of the recognized red ball. Select the baud rate to 115200.
(4) The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
WonderK210* wk;
Find_Box_st* result;
  //这里不需要再调用初始化串口函数 Serial.begin(115200); 在 serial_begin() 函数里已经初始化了(Since the initialization of the serial port has already been performed within the serial_begin() function, there is no need to call Serial.begin(115200))
  wk->serial_begin();
  result = malloc(sizeof(Find_Box_st));
malloc(sizeof(Find_Box_st): allocates memory of the size of the Find_Box_st type, and the address is assigned to the result pointer. (4) Loop to obtain the latest information from K210
void loop() {
  wk->update_data();
  bool rt = wk->recive_box(result , K210_FIND_RED_FOLLOW);
① After entering the “loop()” function, use the “wk.update_data()” function to continuously obtain the latest recognition results from the K210 vision module. Then, acquire and parse the data of the latest recognized frame’s structure, storing it in the result variable.
void loop() {
  wk->update_data();
  if(rt)
    Serial.print("x:");
    Serial.println(result->x);
    Serial.print("y:");
    Serial.println(result->y);
    Serial.print("w:");
    Serial.println(result->w);
    Serial.print("h:");
    Serial.println(result->h);
① If a new result is obtained (rt is true), the serial port will print the position coordinates and size information of the recognition box’s top-left corner.
7.14.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling the red ball tracking function. The coordinates of the recognized bounding box for the red ball will be printed on the terminal.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
③ After the connection is established, click or “Run - Download and Run” to download the program into the controller and execute it.
  • Program Outcome
After downloading the program, the K210 vision module will track the red ball and print the detected bounding box coordinates for the red ball on the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
(1) Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 7.14 Red Ball Tracking
(2) Import Module
① Import the time module, the WonderK210 communication class, and the message format classes (Find_Box_Msg_st, Find_Box_st, and Find_Msg_st) for subsequent usage.
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st , Find_Box_st , Find_Msg_st),功能号(function number)(k210_PACKET_FUNCTION)
wk = WonderK210()
wk.serial_begin()
(4) Main Function
① Enter a while loop to continuously update and receive messages. The function wk.find_box(k210_PACKET_FUNCTION.K210_FIND_RED_FOLLOW) searches for the target in the data and retrieve the received messages.
  wk.update_data()
  ret = wk.find_box(k210_PACKET_FUNCTION.K210_FIND_RED_FOLLOW)
② If a recognition result is found (ret is not None), the recognition result will be printed. The x and y represent the top-left coordinates of the box in the image, the w denotes the width of the box, and the h represents the height of the box.
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
  time.sleep_ms(10)
# 只有方框数据(only contains box data)
class Find_Box_st:
  def __init__(self):
    self.function = 0
    self.x = 0
    self.y = 0
    self.w = 0
    self.h = 0
The class Find_Box_st is defined with the following attributes:
  • function: Represents a certain function or state.
  • x: Represents the x-coordinate of the box.
  • y: Represents the y-coordinate of the box.
  • w: Represents the width of the box.
  • h: Represents the height of the box.
7.14.4 STM32
  • Game Introduction
  • Game Introduction
Send the information on the tracked red ball to STM32 via the K210 vision module.
  • Getting Ready
  • Program Outcome
Once the program runs, the STM32 will obtain the information on the tracked red ball from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
7.14.5 Raspberry Pi
  • Game Introduction
  • Game Introduction
Send the tracked red ball data to Raspberry Pi via the K210 vision module.
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will obtain the coordinate information of the tracked red ball from the K210 vision module and print it in the terminal.
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
① Use the function wk.update_dat() to update data. Call the function wk.find_box() to obtain the received message.
② When a new message is obtained, the position (x, y, w, h) of the recognized red ball will be displayed.
#loop
    wk.update_data()
    if ret is not None:
        print("ret.x = {}".format(ret.x))
        print("ret.y = {}".format(ret.y))
        print("ret.w = {}".format(ret.w))
        print("ret.h = {}".format(ret.h))
7.15 Road Sign Recognition
7.15.1 K210
  • Game Introduction
This section implements the detection of traffic cards and traffic lights via the K210 vision module. It selects and annotates the detected image regions, sending the recognized information to the host via the UART serial port.
  • Getting Ready
(1) Device Connection
① Double-click to open the software.
② Click in the bottom left corner.
③ Select the corresponding serial port number. Check “Advanced Settings”, and select “Mode-3”.
④ Click “OK” and wait for the connection to be completed.
⑤ After the connection is successful, the CanMV IDE displays the icon in the bottom left corner.
⑥ If the connection takes more than 10 seconds, it indicates a connection failure. Click “Cancel”, and a pop-up window shown below appears. Click “OK” and re-check the connection.
Tips for connection failure:
  • The selected serial port number is wrong.
Please unplug other serial ports connected to your PC. Try the above steps again to select the correct serial port number.
  • The cable used for the connection is not a data cable.
Use a Type-C data cable that supports data transmission. A Type-C data cable is included in the package before delivery.
  • Other K210 firmware is flashed.
Reflash the factory firmware, and then proceed with the connection.
Online operation:
Programs run in this way will be lost when the connection is disconnected or the device is shut down. They will not be saved on the K210 vision module.
Offline operation:
② Click “Yes”.
  • Program Outcome
(1) K210 Vision Module
After running the program, the K210 vision module will highlight the recognized road sign or the traffic light region with a box. The recognition result will be displayed on the screen.
(2) Mater Device
After running the program, the K210 vision module will highlight the recognized road sign or the traffic light region with a box. The detection result will be printed on the terminal. The message “crc ok” indicates that the checksum is correct.
(1) Load the vision module to obtain camera images.
③ Import the math module for various mathematical operations.
④ Load the LCD module library for displaying images on an LCD screen.
⑤ Import the gc module for cleaning up memory.
⑥ Load the hw_uart module from the hiwonder library for serial communication.
⑦ Load the binascii module for byte processing.
#载入相关模块(load relevant modules)
import sensor, image, time, lcd, gc
from maix import KPU
import binascii
#定义串口对象(define serial port object)
serial = hw_uart()
(3) Define a serial port transmission function. It encapsulates the recognized information based on the defined data format and transmits it via the serial port.
def send_data(x,y,w,h,msg):
    0xAA  0x55  功能号(function number)  数据长度(data length)  data  CRC
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_SIGNPOST_FOLLOW #功能编号(function number)
    Length = 0  #数据长度(data length)
    crc = 0 #校验位(checksum bit)
    data = [] #数据组(dataset)
    #参数都为0(all parameters are set to 0)
    if x==0 and y==0 and w==0 and h ==0:
        #x(小端模式)(little-endian mode)
        low = x & 0xFF #低位(low byte)
        high = x >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #y(小端模式)(little-endian mode)
        low = y & 0xFF #低位(low byte)
        high = y >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #w(小端模式)(little-endian mode)
        low = w & 0xFF #低位(low byte)
        high = w >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
        #h(小端模式)(little-endian mode)
        low = h & 0xFF #低位(low byte)
        high = h >> 8& 0xFF #高位(high byte)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
        for i in range(len(msg)):
            msg_int = str_2_int(msg[i])
            data.append(msg_int)
    Length += len(data)
    send_buf = [FUNC_num,Length]
    for i in range(len(data)):
        send_buf.append(data[i])
    #进行CRC运算(perform a CRC calculation)
    crc = checksum_crc8(send_buf)
#定义发送数据(define the transmitted data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
#初始化LCD(initialize LCD)
lcd.init()
#以下是初始化传感器(initialize sensors)
sensor.reset()
sensor.skip_frames(time = 100)
#帧率时钟(frame rate clock)
clock = time.clock()
(7) Define object labels.
labels = ["redblock", "straight", "left", "right", "round", "park", "stop", "redlight", "yellowlight", "greenlight"]
(8) Create an image object.
img_obj = image.Image(size=(320,240))
(9) Create a parameter table for object detection (unmodifiable).
anchor = (2.16, 1.62, 2.09, 2.03, 2.53, 2.56, 2.97, 3.06, 3.75, 3.84)
(10) Create a KPU object and load the corresponding model.
#创建 KPU 模型对象(create KPU model object)
kpu = KPU()
#加载物体检测模型文件(.kmodel 格式)(loadobject detection model file in .kmodel format)
kpu.load_kmodel('/sd/KPU/signpost_card/signpost_card.kmodel')
#使用 init_yolo2 初始化 YOLO 模型参数(initialize YOLO model parameters using init_yolo2)
#anchor: 锚框的尺寸列表,用于目标检测(list of anchor box sizes for object detection)
#anchor_num: 锚框的数量(number of anchor boxes)
#img_w, img_h: 输入图像的宽度和高度(width and height of the input image)
#net_w, net_h: 模型输入的宽度和高度(width and height of the model input)
#layer_w, layer_h: 模型最终层的宽度和高度(width and height of the final layer of the model)
#threshold: 检测目标的置信度阈值(confidence threshold for detecting objects)
#nms_value: 非最大抑制的 IOU 阈值(IOU threshold for non-maximum suppression)
#classes: 目标类别数量(number of target classes)
kpu.init_yolo2(anchor, anchor_num=(int)(len(anchor)/2), img_w=320, img_h=240, net_w=320 , net_h=240 ,layer_w=10 ,layer_h=8, threshold=0.85, nms_value=0.3, classes=len(labels))
(11) Enter a while loop.
    #loop
(12) Retrieve and process the image obtained from the camera.
(13) Detect target regions in the image. If detected, highlight the corresponding areas with boxes, draw labels, and transmit the data via UART.
        #运行KPU模型,获取检测结果(Run the KPU model and obtain detection result)
        kpu.run_with_output(img)
        dect = kpu.regionlayer_yolo2()
        #计算帧率(calculate frame rate)
        fps = clock.fps()
        #如果检测到目标(if the target is detected)
        if len(dect) > 0:
            #print("dect:",dect)
            #遍历(interate through)
            for l in dect :
                #绘制检测框(draw detection box)
                img.draw_rectangle(l[0],l[1],l[2],l[3], color=(0, 255, 0))
                img.draw_string(l[0],l[1], labels[l[4]], color=(0, 255, 0), scale=1.5)
                #print(type(obj_name[l[4]])) #打印物体名称(print object name)
                send_x = l[0]
                send_y = l[1]
                send_w = l[2]
                send_h = l[3]
                send_msg = labels[l[4]]
            #发送数据(send data)
            send_data(send_x,send_y,send_w,send_h,send_msg)
        #在图像上绘制帧率信息(display the frame rate on the image)
        img.draw_string(0, 0, "%2.1ffps" %(fps), color=(0, 60, 128), scale=2.0)
        lcd.display(img) #在LCD上显示图像(display the image on the LCD)
(14) Display the processed image on the LCD screen.
7.15.2 Arduino UNO
  • Game Introduction
  • Game Introduction
  • Getting Ready
(1) Module Connection
(2) Download and Run Program
① Locate and open the “5.15.2_find_signpost_follow.ino” program file in the same folder as this lesson.
② In the “Select board” option, select the corresponding Arduino development board and port. Take “Arduino Uno” and “COM8” as an example to demonstrate. The COM port is not unique. You can check the COM port number in the computer’s device manager.
③ Click button to compile the program. After the compilation is completed, click to upload the program into the Arduino development board.
  • Program Outcome
(1) After running the program, the K210 vision module will highlight the recognized road sign or the traffic light region with a box. The recognition result will be displayed on the screen.
(2) Open the “Arduino IDE” serial monitor to view the name of the traffic card and its coordinates information. Select the baud rate to 115200.
(4) The msg represents the name of the road sign. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
(1) Import Header File
#include "WonderK210.h"
WonderK210.h is a header file that contains declarations, definitions, function prototypes, and other necessary information related to the WonderK210 controller. This header file is used for functions and structure definitions that operate the WonderK210 controller.
(2) Declare Variables
//接收控制器(receive controller)
WonderK210* wk;
//消息存储变量(message storage variable)
Find_Box_Msg_st* result;
Find_Box_st* result: Declares a pointer named “result” of type Find_Box_st. This pointer stores or points to a data structure of type Find_Box_st, which is used to store information about the detected boxes. (3) Initial Settings
  //开启串口接收(enable serial port receiving)
  wk->serial_begin();
  result = malloc(sizeof(Find_Box_Msg_st));
Serial.begin(115200): initializes serial communication. The baud rate is set to 115200.
malloc(sizeof(WonderK210)): allocates the memory with the size of the WonderK210 type, and assigns the address to the wk pointer.
wk->serial_begin(): calls the serial_begin() function via wk pointer to initialize serial communication.
malloc(sizeof(Find_Box_Msg_st)): allocates memory of the size of the Find_Box_Msg_st type, and the address is assigned to the result pointer.
void loop() {
  //更新消息(updata message)
  wk->update_data();
  //获取消息(obtain message)
  bool rt = wk->recive_box_msg(result , K210_FIND_SIGNPOST_FOLLOW);
(5) Printing result information
 //若获取到新的消息(if a new message is obtained)
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
If a new result is obtained (rt is true), the serial port will print the position coordinates, size information, and recognition result of the recognition box’s top-left corner.
7.15.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling Road Sign recognition. The coordinates of the recognized box for the road sign will be printed on the terminal.
  • Getting Ready
(1) Wiring Instruction
(2) Download and Run K210 Program
Online operation:
Offline operation:
① After connecting, drag the program under the same directory to the CanMV IDE code editing area. Click “Tools” on the toolbar. Select “Save open script to CanMV Cam (as main.py)”.
② Click “Yes”.
③ Once the writing is successful, a window shown below will appear. Click “OK”. This saves the MicroPython file into the K210 Vision Module.
(3) Download and Run ESP32 Program
① Connect the ESP32 controller to the computer with a USB data cable. Open the Python editor. Drag the programs “WonderK210.py” and “main.py” into the editor interface.
② Select the or click “Connect” in the menu bar to choose the corresponding COM port. Let’s use “COM15” as an example. The COM port is not unique. You can check the COM port number in the computer’s device manager.
  • Program Outcome
After downloading the program, the K210 vision module will detect the road sign and print the identification result on the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
(1) Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 7.15 Road Sign Recognition
(2) Import Module
# 载入时间模块(load time module)
# 载入K210通信类(load K210 communication class)(WonderK210),消息格式类(message format class)(Find_Box_Msg_st, Find_Box_st, Find_Msg_st),功能号(function number)(k210_PACKET_FUNCTION)
from WonderK210 import WonderK210 , Find_Box_Msg_st , Find_Box_st , Find_Msg_st,k210_PACKET_FUNCTION
# 实例化K210通信类(instantiate K210 communication class)
wk = WonderK210()
# 开启串口(start serial port)
wk.serial_begin()
(4) Main Function
① Enter a while loop to continuously update and receive messages. The function wk.find_box_msg(k210_PACKET_FUNCTION.K210_FIND_SIGNPOST_FOLLOW) searches for the target in the data and retrieve the received messages.
  # 更新接收消息(update receiving message)
  wk.update_data()
  # 获取接收消息(obtain receiving message)
  ret = wk.find_box_msg(k210_PACKET_FUNCTION.K210_FIND_SIGNPOST_FOLLOW)
② If a recognition result is found (ret is not None), the recognition result will be printed. The x and y represent the top-left coordinates of the box in the image. The w denotes the width of the box, the h represents the height of the box, and the msg is the recognition result.
  if ret is not None:
    # 打印消息内容(print message content)
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  # 延时10ms(delay for 10ms)
  time.sleep_ms(10)
# 有方框数据和消息数据(there is data for the box and the message)
class Find_Box_Msg_st:
  def __init__(self):
    self.function = 0
    self.x = 0
    self.y = 0
    self.w = 0
    self.h = 0
    self.msg = [0x00] * 200
  • msg: is a list with a length of 200. It is used to store message data.
7.15.4 STM32
  • Game Introduction
  • Game Introduction
Send the recognized road sign information to STM32 via the K210 vision module.
  • Getting Ready
① Connect the K210 vision module to a computer with a Type-C data cable.
① Locate and open “RosRobotControllerM4.uvprojx” program file in the same folder as this lesson.
② Click to perform compiling. After the compiling is completed, click to download the program to the STM32 board.
  • Program Outcome
(1) Once the program runs, the STM32 will obtain the recognized road sign information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
(1) Initial Settings
#include "k210_packet.h"
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
7.15.5 Raspberry Pi
  • Game Introduction
  • Game Introduction
Send the recognized road sign data to Raspberry Pi via the K210 vision module.
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will obtain the recognized road sign information from the K210 vision module and print it in the terminal.
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
① Use the function wk.update_dat() to update data. Call the function wk.find_box_msg() to obtain the received message.
② When a new message is obtained, the recognition result of the detected road sign will be printed.
#loop
    wk.update_data()
    if ret is not None:
7.16 Number Card Recognition
7.16.1 K210
  • Game Introduction
This section uses the K210 vision module to recognize number cards. It selects and annotates the detected image regions, sending the recognized information to the host via the UART serial port.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After running the program, the K210 vision module will highlight the recognized number card region with a box. The recognition result will be displayed on its screen.
(2) Mater Device
It prints the coordinates of the number card’s bounding box and the detection results on the terminal. The message “crc ok” indicates that the checksum is correct.
import gc
from hiwonder import hw_uart
import binascii
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.FIND_DIGITAL_CARD #功能编号(function number)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
#msg
    if msg != None:
    Length += len(data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
lcd.init()
sensor.reset()
sensor.skip_frames(time = 1000)
(7) Create a KPU object and load the corresponding model.
kpu = KPU()
kpu.load_kmodel('/sd/KPU/find_digital_card/find_digital_card.kmodel')
(8) Define object labels.
labels = ["1", "2", "3", "4", "5"] #类名称(class name)
anchor = (2.25, 2.16, 2.78, 2.69, 3.31, 3.22, 3.72, 3.66, 4.19, 4.16)
kpu = KPU()
# 从sd或flash加载模型(load model from sd or flash)
kpu.init_yolo2(anchor, anchor_num=(int)(len(anchor)/2), img_w=320, img_h=240, net_w=320 , net_h=240 ,layer_w=10 ,layer_h=8, threshold=0.9, nms_value=0.3, classes=len(labels))
(10) Initialize model.
    while(True):
(13) Process the image to recognize number card.
(14) Detect target regions in the image. If detected, highlight the corresponding areas with boxes, draw labels, and transmit the data via UART.
        if len(dect) > 0:
            for l in dect :
                send_x = l[0]
                send_y = l[1]
                send_w = l[2]
                send_h = l[3]
                send_data(send_x,send_y,send_w,send_h,labels[l[4]]) #发送数据(send data)
                a = img.draw_rectangle(l[0],l[1],l[2],l[3],color=(0,255,0))
                info = "%s  %.1f" % (labels[l[4]], l[5])
                a = img.draw_string(l[0],l[1],info,color=(255,0,0),scale=2.0)
                #print(info)
                del info
(15) Display the processed image on the LCD screen.
        lcd.display(img)
7.16.2 Arduino UNO
  • Game Introduction
  • Game Introduction
  • Getting Ready
① Locate and open the “5.16.2_find_digital_card.ino” program file in the same folder as this lesson.
  • Program Outcome
(2) Open the “Arduino IDE” serial monitor to view the recognition result and the coordinate information of the recognized number card are visible. Select the baud rate to 115200.
(4) The msg represents the name of the recognized number card. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
WonderK210* wk;
  wk->serial_begin();
malloc(sizeof(Find_Box_Msg_st)): allocates memory of the size of the Find_Box_Msg_st type, and the address is assigned to the result pointer. (4) Loop to obtain the latest information from K210
void loop() {
  wk->update_data();
  bool rt = wk->recive_box_msg(result , K210_FIND_DIGITAL_CARD);
(5) Print result information
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.16.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling number card recognition. The recognition result will be printed on the terminal.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
  • After the connection is established, click or “Run - Download and Run” to download the program into the controller and execute it.
  • Program Outcome
After downloading the program, the K210 vision module will detect the number card and print the identification result on the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
(1) Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 7. Multiple Controller UART Communication Course->7.16 Number Card Recognition
(2) Import Module
wk = WonderK210()
wk.serial_begin()
(4) Main Function
  wk.update_data()
  ret = wk.find_box_msg(k210_PACKET_FUNCTION.K210_FIND_DIGITAL_CARD)
② If a recognition result is found (ret is not None), the recognition result will be printed. The x and y represent the top-left coordinates of the box in the image, the w denotes the width of the box, the h represents the height of the box, and the msg is the recognition result.
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  time.sleep_ms(10)
  def __init__(self):
    self.function = 0
    self.x = 0
    self.y = 0
    self.w = 0
    self.h = 0
7.16.4 STM32
  • Game Introduction
  • Game Introduction
Send the recognized number card information to STM32 via the K210 vision module.
  • Getting Ready
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized number card information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
* @retval void
* @retval void
* @retval void
7.16.5 Raspberry Pi
  • Game Introduction
  • Game Introduction
Send the recognized number card data to Raspberry Pi via the K210 vision module.
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will obtain the recognized number card information from the K210 vision module and print it in the terminal.
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
② When a new message is obtained, the recognition result of the detected number card will be printed.
#loop
    wk.update_data()
    if ret is not None:
7.17 Waste Classification
7.17.1 K210
  • Game Introduction
This section implements the detection of waste cards via the K210 vision module. It selects and annotates the detected image regions, sending the recognized information to the host via the UART serial port.
  • Getting Ready
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After running the program, the K210 vision module will highlight the recognized waste card region with a box. The recognition result will be displayed on its screen.
(2) Mater Device
It prints the coordinates of the waste card’s bounding box and the detection results on the terminal. The message “crc ok” indicates that the checksum is correct.
import gc
import binascii
serial = hw_uart()
    START_1 = 0xAA
    START_2 = 0x55
    FUNC_num = FuncTag.GARBAGE_SORTING #功能编号(function number)
        #x(小端模式)
        low = x & 0xFF #低位
        data.append(low)
        data.append(high)
        #y(小端模式)
        low = y & 0xFF #低位
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
        data.append(low)
        data.append(high)
    #msg
    if msg != None:
    Length += len(data)
send_x = 0
send_y = 0
send_w = 0
send_h = 0
send_msg = ""
lcd.init()
sensor.reset()
kpu = KPU()
kpu.load_kmodel('/sd/KPU/garbage_sorting/garbage_sorting.kmodel')
labels = ["oral_bottle", "color_pen", "battery", "brush", "plastic_bottle", "umbrella", "banana_peel", "ketchup", "bone", "chopstick", "plate", "cigarette_end"]
anchor = (1.38, 1.41, 2.00, 2.03, 2.78, 2.81, 3.72, 3.66, 5.66, 5.47)
(10) Initialize the model.
kpu.init_yolo2(anchor, anchor_num=(int)(len(anchor)/2), img_w=320, img_h=240, net_w=320 , net_h=240 ,layer_w=10 ,layer_h=8, threshold=0.6, nms_value=0.3, classes=len(labels))
    while(True):
(13) Process the image to recognize the waste card.
        if len(dect) > 0:
            for l in dect :
                send_x = l[0]
                send_y = l[1]
                send_w = l[2]
                send_h = l[3]
                #print(info)
                del info
        #img.draw_string(0, 0, "%2.1ffps" %(fps),color=(0,60,255),scale=2.0)
        lcd.display(img)
7.17.2 Arduino UNO
  • Game Introduction
  • Game Introduction
  • Getting Ready
① Locate and open the “5.17.2_garbage_sorting.ino” program file in the same folder as this lesson.
  • Program Outcome
Open the “Arduino IDE” serial monitor, and the name of the recognized waste card and its coordinates information are visible. Select the baud rate to 115200.
(4) The msg represents the name of the recognized waste card. The x and y represent the pixel coordinates of the target’s center along the X and Y axes, respectively. The h and w denote the height and width of the target’s center in units of px.
WonderK210* wk;
  wk->serial_begin();
void loop() {
  wk->update_data();
  bool rt = wk->recive_box_msg(result , K210_GARBAGE_SORTING);
  if(rt)
    Serial.print("x:");
    Serial.print("y:");
    Serial.print("w:");
    Serial.print("h:");
7.17.3 ESP32
  • Game Introduction
In this section, program the K120 vision module to establish serial communication with the ESP32, enabling waste classification. The coordinates of the recognized bounding box for the waste card and the recognition result will be printed on the terminal.
  • Getting Ready
There are two ways to run K210 programs: online and offline.
Online operation:
Offline operation:
② Click “Yes”.
  • Program Outcome
After downloading the program, the K210 vision module will detect the waste card and print the recognition result on the terminal. Additionally, the message “crc ok” indicates that the checksum is correct.
(1) Let’s focus on the ESP32 program analysis on the receiver end. For an analysis of the K210 program on the transmitted end, please refer to the 7.17 Waste Classification
(2) Import Module
wk = WonderK210()
wk.serial_begin().
(4) Main Function
  wk.update_data()
  ret = wk.find_box_msg(k210_PACKET_FUNCTION.K210_GARBAGE_SORTING)
  if ret is not None:
    print(ret.x)
    print(ret.y)
    print(ret.w)
    print(ret.h)
    print(ret.msg)
  time.sleep_ms(10)
  def __init__(self):
    self.function = 0
    self.x = 0
    self.y = 0
    self.w = 0
    self.h = 0
7.17.4 STM32
  • Game Introduction
  • Game Introduction
Send the recognized waste card information to STM32 via the K210 vision module.
  • Getting Ready
  • Program Outcome
Once the program runs, the STM32 will obtain the recognized waste card information from the K210 vision module. After running the program, open the located in Appendix->Serial Port Utility to view the printed information.
#include "global.h"
typedef struct {
	uint16_t  x;
	uint16_t  y;
	uint16_t  w;
	uint16_t  h;
}BoxData;
typedef struct {
	BoxData box;
}Find_Box_st;
//有方框数据和消息数据(include box data and message data)
typedef struct {
	BoxData box;
	uint8_t msg[100];
}Find_Box_Msg_st;
//只有消息数据(only includes message data)
typedef struct {
	uint8_t msg[100];
}Find_Msg_st;
(2) Message Data Processing
* @brief 只有方框数据 的回调处理(callback processing for only including box data)
* @param frame 数据帧(data frame)
* @retval void
static void k210_Box_cb(struct k210_PacketRawFrame *frame)
    Find_Box_st *rec = (Find_Box_st*)frame->data_and_checksum;
	printf("x:%d,y:%d,w:%d,h:%d\n",rec->box.x,rec->box.y,rec->box.w,rec->box.h);
* @brief 有方框数据和消息数据 的回调处理(callback processing for including box data and message data)
* @retval void
static void k210_Box_Msg_cb(struct k210_PacketRawFrame *frame)
    Find_Box_Msg_st *rec = (Find_Box_Msg_st*)frame->data_and_checksum;
	rec->msg[frame->data_length - 8] = '\0'; //将check位清除(clear check bit)
	printf("msg:%s\n",rec->msg);
* @brief 只有消息数据 的回调处理(callback processing for only including message data)
* @retval void
static void k210_Msg_cb(struct k210_PacketRawFrame *frame)
    Find_Msg_st *rec = (Find_Msg_st*)frame->data_and_checksum;
	rec->msg[frame->data_length] = '\0'; //将check位清除(clear check bit)
(3) Callback Function
//注册回调函数(register callback function)
void k210_packet_handle_init(void)
    k210_packet_register_callback(&k210_packet_controller, K210_COLOR_RECOGNITION, k210_Box_cb); //颜色识别(color recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_BARCODES, k210_Box_Msg_cb); //条形码识别(barcode recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_QRCODES, k210_Box_Msg_cb);	 //二维码识别(QR code recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_APRILTAGS, k210_Box_Msg_cb);//机器码识别(AprilTag recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACE_YOLO, k210_Box_cb); 	 //人脸检测(face detection)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACEFEATURE, k210_Box_cb);  //人脸特征识别(face feature recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACEMASK, k210_Box_Msg_cb); //口罩识别(mask recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_OBJECT, k210_Box_Msg_cb);	 //物体识别(object recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_SELF_LEARNING, k210_Msg_cb);//自主学习分类(autonomous learning and classification)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_DIGITAL, k210_Msg_cb);      //手写数字识别(handwritten number recognition)
	k210_packet_register_callback(&k210_packet_controller, K210_FIND_FACE_RECOGNITION, k210_Box_Msg_cb); //物体识别(object recognition)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_RED_FOLLOW, k210_Box_cb); //红色追踪(red tracking)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_SIGNPOST_FOLLOW, k210_Box_Msg_cb); //路标追踪(road sign tracking)
    k210_packet_register_callback(&k210_packet_controller, K210_FIND_DIGITAL_CARD, k210_Box_Msg_cb); //数字卡片识别(number card recognition)
    k210_packet_register_callback(&k210_packet_controller, K210_GARBAGE_SORTING, k210_Box_Msg_cb); //垃圾分类(waste classification)
    k210_packet_register_callback(&k210_packet_controller, K210_COLOR_SORTING, k210_Box_Msg_cb); //多种颜色识别(multiple colors recognition)
7.17.5 Raspberry Pi
  • Game Introduction
  • Game Introduction
Send the recognized waste card information to Raspberry Pi via the K210 vision module.
  • Getting Ready
cd Desktop/
python3 main.py
  • Program Outcome
Once the program is started, the Raspberry Pi will obtain the recognized waste card information from the K210 vision module and print it in the terminal.
(2) Create Object
wk = WonderK210()
wk.serial_begin()
(3) Main Function
② When a new message is obtained, the detection result of the recognized waste card will be printed.
#loop
    wk.update_data()
    if ret is not None:
