11. Large AI Model Courses
11.1 Large Models Basic Courses
11.1.1 Large Language Model Courses
(1) Basic Concept
(2) Features
(3) Working Principle
(4) Application Scenarios
① Text Generation
② Text Classification
③ Machine Translation
④ Question-Answering Systems
To proceed with this section, you will need to register on the appropriate website and obtain the API key for the large model (please refer to the file 11.1.1 Large Language Model Courses -> Large Language Model Deployment).
(1) Environment Configuration
sudo apt install vim
sudo apt install gedit
sudo apt install python3 python3-pip python3-all-dev python3-pyaudio portaudio11-dev libsndfile1
cd ~/large_models/speech_pkg/
jetson_nano 3.6
jetson_orin 3.10
rpi5 3.11
rpi5_docker 3.8
cd jetson_orin/
cp -r speech.so ..
cd ../..
pip3 install .
pip3 install openai -U
(3) Key Configuration
cd ~/large_models
vim config.py
③ Once the file is open, configure the OpenAI and OpenRouter keys by filling in the llm_api_key and vllm_api_key parameters, respectively (you can obtain these keys from the ‘11.1.1 Large Language Model Courses -> Large Language Model Deployment’ course).
(4) Running the Demo Program
python3 openai_llm_demo.py
Before starting this section, make sure you have completed the API key configuration outlined in the file 11.1.1 Large Language Model Courses -> Large Language Model Accessing.
cd large_models/
To proceed with this section, ensure that you have completed the API key configuration as described in the file 11.1.1 Language Model Courses -> Large Language Model Accessing.
cd large_models/
python3 openai_llm_er_demo.py
11.1.2 Large Speech Model Courses
Their advantages include:
① Processing Methods
② Model Complexity
③ Recognition Capability
④Training Data Requirements
② Text-to-Speech (TTS)
(1) Device Overview
① 6-Microphone Circular Array
Introduction:
Features and Specifications:
If you’re using a NVIDIA Jetson device, you can connect via the VNC remote access tool. After logging in, check the upper right corner of the system interface for the speaker icon to confirm successful detection.
② Recording Test
arecord -l
③ Playback Test
aplay test.wav
  • Voice Wake-Up
(1) WonderEcho Pro Wake-Up
Device Check:
To proceed, we need to identify the USB device name assigned to the connected WonderEcho Pro or voice device (hereafter referred to as the voice device). Please follow the steps below carefully.
ll /dev | grep USB
ll /dev | grep USB
Wake-Up Test:
vim wakeup_demo.py
Device Check:
For Jetson users, connect to the Jetson system using the VNC remote access tool. Once connected, check the desktop interface.
Wake-Up Test:
② Press i to enter edit mode.
③ Update the port to match the device port number you previously identified. Comment out the WonderEcho Pro configuration (add # at the beginning of the corresponding line), and uncomment the line using the voice device on line 11 as the input device (see red box in the referenced image).
(3) Brief Program Overview
Importing Required Modules
from speech import awake
port = '/dev/ttyUSB0'
try:  # If a fan is present, it's recommended to turn it off before detection to reduce interference
except:
Main Wake Word Detection Loop
kws.start() # Start detection
print('start...')
Main Program Logic
        if kws.wakeup(): # Wake-up detected
            print('hello hiwonder')
        time.sleep(0.02)
        kws.exit() # Cancel processing
        except:
(4) Extended Functionality
vim wakeup_demo.py
i
python3 wakeup_demo.py
  • Speech Recognition
(2) How It Works
Before proceeding, refer to the course “11.1.1 Large Speech Model Courses -> Large Language Model Deployment” to obtain your API key, and make sure to add it into the configuration file (config).
(4) Experiment Steps
cd large_models/
vim config.py
python3 openai_asr_demo.py
(5) Function Realization
(6) Brief Program Analysis
① Module Import
from speech import speech
② Define ASR Class
(7) Function Extension
vim openai_asr_demo.py
i
  • Speech Synthesis
(1) What is Speech Synthesis?
(2) How It Works
Refer to the course “Large Language Model Deployment” to obtain your API key, and update the configuration file accordingly.
cd large_models/
vim config.py
python3 openai_tts_demo.py
① Module Import
from config import *
② Definition for TTS Class
③ Function Extension
vim openai_tts_demo.py
i
  • Voice Interaction
(2) How It Works
(3) Experiment Steps
① Power on the device and connect to it via MobaXterm (refer to Appendix “5.1 Remote Connection Tools and Instructions” for connection guidance).
ll /dev | grep USB
cd large_models/
vim config.py
⑥ Run the program:
(4) Function Realization
(5) Brief Program Analysis
(1) Module Import
(3) Main Functional Logic
    kws.start()
                if asr_result:
                    tts.tts(response)
            time.sleep(0.02)
            kws.exit()
            except:
        except BaseException as e:
            print(e)
11.1.3 Vision Language Model Courses
(1) Basic Concept
(2) Features
(3) How It Works
① Image Captioning
② Visual Question Answering
③ Image Retrieval
④ Augmented Reality (AR)
⑥ Social Media Interaction
⑦ Medical Imaging Analysis
(1) Experiment Steps
cd large_models/
Run the program:
(2) Function Realization
  • This section requires the configuration of the API key in “11.1.3 Vision Language Module Courses -> Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
cd large_models/
② Run the program:
(3) Function Expansion
Change Pictures:
② Then, input the command:
i
cd large_models/
② Run the program:
④ Run the program:
  • This section requires the configuration of the API key in “ Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
cd large_models/
② Run the program:
python3 openai_vllm_ocr.py
Change Pictures:
i
⑤ Run the program:
11.1.4 Multimodal Model Basic Courses
(1) Basic Concept
(2) Features
(3) How It Works
① Education
② Healthcare
③ Entertainment
④ Advertising and Marketing
ll /dev | grep USB
cd large_models/
vim config.py
vim openai_agent_demo.py
⑤ Run the program:
python3 openai_agent_demo.py
11.2 Multimodal Large Model Applications
11.2.1 Large Model API Key Setup
This section requires registering on the official OpenAI website and obtaining an API key for accessing large language models.
11.2.1.1 OpenAI Account Registration and Deployment
  1. Copy and open the following URL: https://platform.openai.com/docs/overview, then click the Sign Up button in the upper-right corner.
  1. Register and log in using a Google, Microsoft, or Apple account, as prompted.
  1. After logging in, click the Settings button, then go to Billing, and click Payment Methods to add a payment method. The payment is used to purchase tokens.
  1. After completing the preparation steps, click API Keys and create a new key. Follow the prompts to fill in the required information, then save the key for later use.
  1. The creation and deployment of the large model have been completed, and this API will be used in the following sections.
11.2.1.2 OpenRouter Account Registration and Deployment
  1. Copy the URL https://openrouter.ai/ into a browser and open the webpage. Click Sign in and register or sign in using a Google account or another available account.
  1. After logging in, click the icon in the top-right corner, then select Credits to add a payment method.
  1. Create an API key. Go to API Keys, then click Create Key. Follow the prompts to generate a key. Save the API key securely for later use.
11.2.1.3 API Configuration
  1. Click to open a terminal and enter the following command to open the configuration file. Press the i key to enter input mode.
vim /home/ubuntu/ros2_ws/src/large_models/large_models/large_models/config.py
  1. Fill in the obtained Large Model API Key in the corresponding parameter, as shown in the red box in the figure below.
  1. Press Esc, then enter the command and press Enter to save and exit the configuration file.
11.2.2 Version Confirmation
Before starting features, verify that the correct microphone configuration is set in the system.
  1. After remotely logging in via VNC, click the desktop icon to access the configuration interface.
  2. Select the appropriate microphone version configuration according to the hardware.
  1. If using the AI Voice Interaction Box, select WonderEcho Pro as the microphone type, as shown in the figure below.
  1. For the 6-Microphone Array, select xf as the microphone type as shown in the figure.
  2. Click Save.
  3. After the Save Success notification appears, click Apply.
  4. Finally, click Quit to exit the software interface.
11.2.3 Voice Control
11.2.3.1 Experiment Introduction
Once the program starts, the AI Voice Interaction Box / Circular Array Microphone will announce I’m ready. Say the designated wake word Hello Hiwonder to activate the voice device. It will respond with I’m here. Voice commands can then be used to control the robot to perform specific actions. For example, saying “Move forward, backward, left, right, and translate laterally” will prompt the voice device to announce its generated response before executing the actions.
11.2.3.2 Preparation
  • Version Confirmation
Refer to Version Confirmation to ensure the microphone version is correctly configured in the system before running the feature.
  • Configuring Large Model API-KEY
Refer to Large Model API Key Setup to obtain the API key first, then open the command line terminal on the left side of the system interface. Enter the following command to open the configuration file and place the OpenAI and OpenRouter keys in their respective positions.
Press the Esc key, then enter the command and press Enter to save the document.
11.2.3.3 Operation Steps
  • Command inputs must strictly distinguish between uppercase and lowercase letters and spaces.
  • Ensure the robot is connected to a network. Configure it to STA local area network mode, or use AP direct connection mode with an Ethernet cable.
  1. Click the icon on the left side of the system interface to start the command-line terminal. Enter the command and press Enter to close the auto-start service.
  1. Enter the command, then press Enter to run the voice control feature.
ros2 launch large_models_examples llm_control_move.launch.py
  1. When the output shown in the following figure appears on the command line and announces I’m ready, it indicates that the voice device has completed initialization. Then, say the wake word Hello Hiwonder to awaken it.
  1. When the output shown in the following figure appears on the command line and the voice device announces I’m here, it indicates that the voice device has been awakened and activated. Recording of commands begins at this point.
  1. When the output shown in the following figure appears on the command line, it indicates the voice device prints out the recognized voice.
  1. When the output shown in the following figure appears on the command line, it indicates successful invocation of the cloud-based voice large model’s speech recognition service to parse the command audio. The parsing result is in publish_asr_result.
  1. When the output shown in the following figure appears on the command line, it indicates successful invocation of the cloud-based large language model to process the command. It provides a language response via response and designs actions that fit the semantics of the command.
The response is automatically generated, and only the semantic accuracy of the reply is guaranteed. The text arrangement of the reply is random.
  1. When the output shown in the following figure appears on the command line, it indicates that a round of dialogue interaction has ended. Refer to step 4 to awaken the voice device again with the wake word and start a new round of dialogue interaction.
  1. To stop this feature, simply press Ctrl + C in the terminal interface. If stopping fails, try multiple times until it ends. If it still cannot be exited, open a new command-line terminal to run the command to clear the currently started ROS nodes and related programs.
11.2.3.4 Program Outcome
Once the feature is activated, the robot accepts conversational voice commands. For example, saying Move forward, backward, left, right, and translate laterally will cause the robot to translate in those directions.
11.2.3.5 Program Analysis
  • Launch File Analysis
Program path: ros2_ws/src/large_models_examples/large_models_examples/llm_control_move.launch.py
  1. Starting the launch file.
vocal_detect_launch = IncludeLaunchDescription(
        os.path.join(get_package_share_directory('large_models'), 'launch/vocal_detect.launch.py')),
    launch_arguments={'mode': mode,}.items(),
agent_process_launch = IncludeLaunchDescription(
        os.path.join(get_package_share_directory('large_models'), 'launch/agent_process.launch.py')),
    launch_arguments={'camera_topic': camera_topic}.items(),
tts_node_launch = IncludeLaunchDescription(
        os.path.join(get_package_share_directory('large_models'), 'launch/tts_node.launch.py')),
controller_launch: Starts the controller.
vocal_detect_launch: Starts voice detection, passing in the mode parameter.
agent_process_launch: Starts agent processing, passing in the camera topic parameter.
tts_node_launch: Starts the speech synthesis module.
  1. Starting the node.
llm_control_move_node = Node(
    package='large_models_examples',
    executable='llm_control_move',
    parameters=[{
        'interruption': interruption,
Starts the voice-controlled movement node.
  • Python File Analysis
Program path: ros2_ws/src/large_models_examples/large_models_examples/llm_control_move.py
  1. Defining the prompt word template PROMPT.
## Role Task
# You are an intelligent hexapod robot. You can control the moving direction through direction in rad/s, control the rotation direction through rotation in rad/s, and control the number of moving steps through step. You need to generate corresponding commands based on the input content.
## Requirements
# 1. Ensure the speed range is correct:
# Direction: direction ∈ [0, 3.14], 0 is forward, increasing counterclockwise.
# Rotation angle: rotation ∈ [-0.2, 0.2], counterclockwise is positive, clockwise is negative.
# Number of moving steps: step.
# 2. Execute multiple actions sequentially and output an action list containing multiple moving commands.
# 3. When rotating, the step defaults to 4.
# 4. Weave a refined 5 to 10 words, humorous, and endlessly varied feedback message for each action sequence to make the communication process interesting.
# 5. Output the json result directly, do not analyze, and do not output redundant content.
# 6. Format:
#   "action": [[direction_1, rotation_1, step_1], [direction_2, rotation_2, step_2], ...],
#   "response": "xx"
# 7. Strong mathematical calculation ability.
## Special Attention
# - The action key carries a string array of function names arranged in the order of execution. When the corresponding action function cannot be found, the action outputs [].
# - The response key is equipped with a carefully crafted short reply that perfectly matches the above word count and style requirements.
## Task Examples
# Input: Move backward two steps
# Output: {"action": [[3.14, 0.0, 2],], "response": "Walk backward two steps, let's go!"}
# Input: Walk forward two steps, then rotate clockwise
# Output: {"action": [[0.0, 0.0, 2], [0.0, -0.2, 4]], "response": "Walk forward two steps, then rotate clockwise, let's go!"}
# Input: Walk backward two steps, translate left two steps, then rotate counterclockwise
# Output: {"action": [[3.14, 0.0, 2], [1.57, 0.0, 2], [0.0, 0.2, 4]], "response": "Alright"}
  1. Class Initialization
    self.action = []
    self.llm_result = ''
    self.interrupt = False
    self.action_finish = False
    self.declare_parameter('interruption', False)
    self.interruption = self.get_parameter('interruption').value
    self.asr_mode = os.environ.get("ASR_MODE", "online").lower()
    self.controller = ControllerClient()
Initializes the node, sets status variables, and creates publishers for TTS text publishing, as well as subscribers for large model results, TTS playback completion signals, and wake-up signals. It creates service clients for setting the large model and enabling voice, which are used for communication and control.
  1. get_node_state Method
Service callback function used for node status queries.
  1. init_process Method
    msg = SetModel.Request()
    msg.model_type = 'llm'
    if self.asr_mode == "offline":
        msg.model = 'qwen3:0.6b'
        msg.base_url = ollama_host
        msg.model = llm_model
        msg.api_key = api_key
        msg.base_url = base_url
    msg = SetString.Request()
    msg.data = PROMPT
    self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT)
The initialization process completes prompt word configuration, audio playback, service creation, and log output.
  1. send_request Method
The service invocation tool sends service requests and waits for results to return, ensuring service communication completion.
  1. wakeup_callback Method
    if self.llm_result:
        self.interrupt = msg.data
Wake-up signal subscription callback setting the interrupt flag when a wake-up signal is received to interrupt the currently executing action.
  1. llm_result_callback Method
def llm_result_callback(self, msg):
    self.llm_result = msg.data
Receives commands generated by the large model and saves them to the llm_result variable for subsequent processing.
  1. play_audio_finish_callback Method
    msg = SetBool.Request()
    msg.data = True
Processes the callback after voice playback is completed and re-enables the voice wake-up function.
  1. process Method
def process(self):
        if self.llm_result:
            msg = String()
            if 'action' in self.llm_result:  # If there is a corresponding action returned, extract and process it
                action_list = []
                if 'action' in result:
                if 'response' in result:
                    response = result['response']
                msg.data = response
                for i in action_list:
                    if float(i[1]) != 0.0:
                        self.controller.traveling(gait=2, stride=0.0, height=30.0, direction=i[0], rotation=i[1], time=1.0, steps=i[2], relative_height=True, interrupt=True )
                        self.controller.traveling(gait=2, stride=45.0, height=30.0, direction=i[0], rotation=i[1], time=1.0, steps=i[2], relative_height=True, interrupt=True )
                    if self.interrupt:
                        self.controller.traveling(gait=-2, time=1, steps=0)
            else:  # No corresponding action, just answer
                response = self.llm_result
                msg.data = response
            self.action_finish = True
        if self.play_audio_finish and self.action_finish:
The program monitors the large model’s output. Upon recognizing a valid command, it parses the response text. Action commands control the robot’s movement while simultaneous voice feedback is provided. Upon task completion, the wake-up function is re-enabled to await the next command.
11.2.4 Autonomous Line Following
11.2.4.1 Experiment Introduction
Once the program starts, the WonderEcho Pro or 6-microphone array will announce I’m ready. Say the designated wake word Hello Hiwonder to activate the voice device. The device will respond with I’m here. Voice commands can then be used to control the robot to perform specific actions. For example, saying “Follow the black line and stop when encountering obstacles” will prompt the terminal to print out the recognized voice. The device will announce its generated response, recognize the black line captured by the camera, and the robot will stop when it encounters obstacles ahead.
11.2.4.2 Preparation
11.2.4.3 Operation Steps
  1. Enter the command, then press Enter to run the line following feature.
ros2 launch large_models_examples llm_visual_patrol.launch.py
  1. When the output shown in the following figure appears on the command line and broadcasts I’m ready, it indicates that the voice device has completed initialization. Then, say the wake word Hello Hiwonder to awaken it.
  1. When the output shown in the following figure appears on the command line, and the voice device broadcasts I’m here, it indicates that the voice device has been awakened and activated. Recording of commands begins at this point.
  1. When the output shown in the following figure appears on the command line, it indicates that the voice device prints out the recognized voice. Say the command “Follow the black line and stop when encountering obstacles”.
  1. When the output shown in the following figure appears on the command line, it indicates successful invocation of the cloud-based large language model’s speech recognition service to parse the command audio. The parsing result is in publish_asr_result.
11.2.4.4 Program Outcome
Once the feature is activated, the robot accepts conversational voice commands. For example, saying “Follow the black line and stop when encountering obstacles” directs the robot to track the black line via the camera feed and halt when an obstacle is detected ahead. The system is preset to recognize four line colors: red, blue, green, and black.
11.2.4.5 Program Analysis
Program path: ros2_ws/src/large_models_examples/large_models_examples/llm_visual_patrol.launch.py
        'debug': 'true',
        'mode': mode,
        'camera_topic': '/depth_cam/rgb/image_raw'
Starts the line following and large model-related launches.
    parameters=[{
Creates the llm_visual_patrol visual node and configures output to the screen.
Program path: ros2_ws/src/large_models_examples/large_models_examples/llm_visual_patrol.py
## Role Task
# You are an intelligent robot. You need to generate the corresponding json command based on the input content.
## Requirements
# 1. For any content input, the corresponding command must be found in the action function library, and the corresponding json command must be output.
# 2. Weave a refined 10 to 30 words, humorous, and endlessly varied feedback message for each action sequence to make the communication process interesting.
# 3. Output the json result directly, do not analyze, and do not output redundant content.
# 4. There are four colors as targets: red, green, blue, and black.
# 5. Format: {"action": ["xx", "xx"], "response": "xx"}
## Action Function Library
# - Follow lines of different colors: line_following('black')
## Task Examples
# Input: Follow the black line
# Output: {"action": ["line_following('black')"], "response": "Received"}
  1. Class initialization.
    self.action = []
    self.stop = True
    # self.llm_result = '{"action": ["line_following(\'black\')"], "response": "ok!"}'
    self.enter_client = self.create_client(Trigger, 'line_following/enter')
    self.enter_client.wait_for_service()
    self.start_client = self.create_client(SetBool, 'line_following/set_running')
    self.set_target_client = self.create_client(SetColor, 'line_following/set_color')
Initializes the node and sets status variables, including stop flags, LLM processing results, and running status. It creates publishers for TTS text publishing and subscribers for receiving LLM results, voice wake-up signals, and audio playback completion status. It creates a service that clients use to control the wake-up function, set the LLM model, and control the line following module.
Service callback used for node status queries.
    msg.data = PROMPT
    init_finish = self.create_client(Trigger, 'line_following/init_finish')
    self.send_request(self.enter_client, Trigger.Request())
Initialization process completing prompt word configuration, audio playback, service creation, and log output.
Service invocation tool that waits synchronously for service responses.
    if msg.data and self.llm_result:
        self.stop = True
    elif msg.data and not self.stop:
        self.stop = True
Listens for wake-up signals and interrupts the current line following action when a wake-up command is received.
Receives the LLM processing result and saves the result string to llm_result for subsequent processing.
Listens for voice playback completion signals and updates the play_audio_finish status, which is used to synchronize the process.
  1. process Method
def process(self):
        if self.llm_result:
            msg = String()
                result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}')+1])
                    text = result['action']
                    # Use a regular expression to extract all strings in parentheses
                    pattern = r"line_following\('([^']+)'\)"
                    # Use re.search to find matching results
                    for i in text:
                        match = re.search(pattern, i)
                        # Extract the result
                        if match:
                            # Get all parameter parts (content within parentheses)
                            color = match.group(1)
                            self.get_logger().info(str(color))
                            color_msg = SetColor.Request()
                            color_msg.data = color
                            self.send_request(self.set_target_client, color_msg)
                            # Start sorting
                            start_msg = SetBool.Request()
                            start_msg.data = True
                            self.send_request(self.start_client, start_msg)
                    msg.data = result['response']
                msg.data = self.llm_result
            msg.data = True
            if self.interruption:
                msg = SetInt32.Request()
                msg.data = 2
                self.send_request(self.set_mode_client, msg)
            self.stop = False
Processes commands generated by the LLM, parses actions, and controls the robot execution while processing voice feedback.
11.2.5 Color Tracking
11.2.5.1 Experiment Introduction
Once the program starts, the WonderEcho Pro or 6-microphone array will announce I’m ready. Say the designated wake word Hello Hiwonder to activate the voice device. The device will respond with I’m here. Voice commands can then be used to control the robot to perform specific actions. For example, saying “Track the red object” will prompt the terminal to print out the recognized voice. The device will announce its generated response. The robot will autonomously recognize the red object captured by the camera and track it.
11.2.5.2 Preparation
11.2.5.3 Operation Steps
  1. Enter the command, then press Enter to run the color tracking feature.
ros2 launch large_models_examples llm_color_track.launch.py
  1. After the program is successfully loaded, the camera screen will appear.
  2. When the output shown in the following figure appears on the command line and the voice device broadcasts I’m here, it indicates that the voice device has been awakened and activated. Recording of commands begins at this point.
  1. When the output shown in the following figure appears on the command line, it indicates that the voice device prints out the recognized voice. Say the command “Track the red object”.
  1. Then, the robot will recognize the red object in front of the camera and track it in real time.
  2. When the output shown in the following figure appears on the command line, it indicates that a round of dialogue interaction has ended. Refer to step 4 to awaken the voice device again with the wake word and start a new round of dialogue interaction.
11.2.5.4 Program Outcome
Once the feature is activated, the robot accepts conversational voice commands. For example, saying “Track the red object” directs the robot to identify and track red objects using the camera feed. Similarly, saying “Track the blue object” or “Track the green object” instructs the robot to recognize and track the corresponding colors.
11.2.5.5 Program Analysis
Program path: ros2_ws/src/large_models_examples/large_models_examples/llm_color_track.launch.py
        'debug': 'true',
        'mode': mode,
Object tracking and large model-related launch files.
llm_color_track_node = Node(
    executable='llm_color_track',
    parameters=[{
Starts the color tracking node and configures output to the screen.
Program path: ros2_ws/src/large_models_examples/large_models_examples/llm_color_track.py
# Role Task
# You are an intelligent companion robot. You need to generate the corresponding json command based on the input content.
## Requirements
# 4. Format: {"action": ["xx", "xx"], "response": "xx"}
## Special Attention:
# - Track objects of different colors: color_track('red')
## Task Examples
# Input: Track the green object
# Output: {"action": ["color_track('green')"], "response": "Received"}
    self.action = []
    self.stop = True
    # self.llm_result = '{"action": ["color_track(\'blue\')"], "response": "ok!"}'
    self.enter_client = self.create_client(Trigger, 'object_tracking/enter')
    self.start_client = self.create_client(SetBool, 'object_tracking/set_running')
    self.set_target_client = self.create_client(SetColor, 'object_tracking/set_color')
Initializes the node and initializes status parameters including the action list, control flags, and LLM processing results. It creates a TTS text publisher and subscribers for receiving LLM processing results, voice wake-up signals, and audio playback completion status. At the same time, it creates service client requests, including setting the LLM model, starting color tracking, and enabling the wake-up function. Finally, it creates a timer to start the initialization process.
    msg.data = PROMPT
    init_finish = self.create_client(Trigger, 'object_tracking/init_finish')
By canceling the timer, it sequentially configures the LLM large language model parameters, sets the prompt word template, waits for the object tracking initialization to complete, and triggers entry into the tracking state. It plays the startup audio while starting the processing thread and creating the initialization completion status service. Finally, it outputs a green log message indicating the system is ready.
Service invocation tool, sending service requests and waiting for results to return to ensure service communication completion.
        self.stop = True
        self.stop = True
When a voice wake-up signal is received, the current action is interrupted to ensure the robot can respond to new voice commands timely.
Assigns the received message to play_audio_finish to determine the audio playback status.
  1. process Method
def process(self):
        if self.llm_result:
            msg = String()
                    pattern = r"color_track\('([^']+)'\)"
                    for i in text:
                        if match:
                            # Start sorting
                msg.data = 2
            msg.data = True
            self.stop = False
The system continuously monitors the large model’s output. When an action command containing color_track is identified, a regular expression extracts the color parameter to set the target color and activate the tracking function. Simultaneously, the TTS module converts the text response into voice feedback. Upon task completion, the status flags reset, and the voice wake-up function is re-enabled to await the next command.
11.3 Embodied AI Applications
11.3.1 Large Model API Key Setup
11.3.1.1 OpenAI Account Registration and Deployment
11.3.1.2 OpenRouter Account Registration and Deployment
11.3.1.3 API Configuration
11.3.2 Version Confirmation
  2. Click Save.
11.3.3 Real-time Detection
11.3.3.1 Experiment Introduction
After the program starts, the voice device announces I’m ready.
Speak the designated wake word Hello Hiwonder to activate the voice device. The voice device will respond with I‘m here. The robot can then be controlled via voice commands. For instance, say “Tell me what you see”. The terminal will print the recognized speech. The voice device will broadcast the generated response after processing. The robot will autonomously recognize the camera feed and describe the visual content.
11.3.3.2 Preparation
  • Large Model API-KEY Configuration
11.3.3.3 Operation Steps
  1. Click the icon on the left side of the system interface to start the command-line terminal. Enter the command and press Enter to stop the auto-start service.
  1. Open the command line, enter the command, and press Enter to run the real-time detection.
ros2 launch large_models_examples vllm_with_camera.launch.py
  1. When the command line displays the following output and announces I’m ready, it indicates that the voice device has completed initialization. Then, say the wake word Hello Hiwonder to awaken it.
  1. When the command line displays the following output and the voice device announces I‘m here, it indicates activation. The command recording process begins at this point.
  1. The following command line output indicates that the voice device has printed the recognized speech.
  1. The following command line output signifies the successful invocation of the cloud-based large language model voice recognition service to parse the command audio. The parsing result is contained in publish_asr_result.
  1. The following command line output indicates a successful call to the cloud-based large language model to process the command and provide a language response named response.
  1. The following command line output indicates the end of a round of dialogue interaction. Refer to step 4 to wake up the voice device with the wake word again to start a new round of dialogue interaction.
  1. To stop this feature, simply press Ctrl + C in the terminal interface. If it fails to stop, try multiple times until it ends.
11.3.3.4 Program Outcome
Once the feature is activated, the robot accepts conversational voice commands. For example, say “Tell me what you see”. The robot automatically recognizes the scene within its line of sight, processes the information, and describes the current scene content.
11.3.3.5 Program Analysis
Program path: ros2_ws/src/large_models_examples/large_models_examples/vllm_with_camera.launch.py
  1. Start Launch File
    launch_arguments={'mode': mode, 'camera_topic': camera_topic}.items(),
Start the files related to chassis control, depth camera, and large models.
  1. Start Node
vllm_with_camera_node = Node(
    parameters=[{"camera_topic": camera_topic}],
Start the vllm_with_camera vision-language control node and configure the camera topic parameters and screen output.
Program source code is located at: ros2_ws/src/large_models_examples/large_models_examples/vllm_with_camera.py
        self.set_above = False
        self.vllm_result = ''
        self.bridge = CvBridge()
        self.declare_parameter('camera_topic', '/depth_cam/rgb/image_raw')
        camera_topic = self.get_parameter('camera_topic').value
        self.create_subscription(Image, camera_topic, self.image_callback, 1)
Initializes the node and sets up variables, including vllm processing results and running status. Creates publishers for TTS text and servo control, and subscribers to receive camera images, large model results, and TTS playback completion signals. Creates service clients for large model settings and voice wake-up functions. Finally, creates a timer to start the initialization process.
Service callback for querying node status.
    msg.model_type = 'vllm'
        msg.api_key = stepfun_api_key
        msg.model = vllm_model
        msg.api_key = vllm_api_key
        msg.base_url = vllm_base_url
    msg.data = VLLM_PROMPT
    set_servo_position(self.joints_pub, 1.0,
                       ((19, 500), (20, 720), (21, 130), (22, 150), (23, 500), (24, 700)))  # Set the initial position of the robotic arm
The initialization process starts after the node. It configures large model parameters and the initial position of the robotic arm, and starts the core processing thread.
Service call tool. Send service requests and wait for the results to return to ensure complete service communication.
  1. vllm_result_callback Method
def vllm_result_callback(self, msg):
    self.vllm_result = msg.data
Receives the commands generated by the large model and saves them to the vllm_result variable for subsequent processing.
Assigns the received boolean message to self.play_audio_finish to determine the audio playback status.
  1. process Method
def process(self):
    # box = []
        if self.vllm_result:
            msg = String()
            msg.data = self.vllm_result
            msg.data = True
        cv2.imshow('image', cv2.cvtColor(cv2.resize(image, (display_size[0], display_size[1])), cv2.COLOR_RGB2BGR))
        k = cv2.waitKey(1)
        if k != -1:
        if not self.set_above:
            self.set_above = True
Loops to get images from the image queue and detect the vision-language model output. When a valid result is recognized, convert it into a voice message and publish it through TTS. Re-enables the voice wake-up function after the task is completed.
  1. image_callback Method
Converts the received ROS image message to OpenCV format and stores it in the queue.
11.3.4 Visual Tracking
11.3.4.1 Experiment Introduction
Speak the designated wake word Hello Hiwonder to activate the voice device. The voice device will respond with I‘m here. The robot can then be controlled via voice commands. For instance, say “Follow the person in white clothes ahead”. The terminal will print the recognized speech. The voice device will broadcast the generated response after processing and execute the corresponding action.
11.3.4.2 Preparation
11.3.4.3 Operation Steps
  1. Click to open a command-line terminal, enter the command, and press Enter to stop the auto-start service.
  1. Enter the command and press Enter to run the visual tracking feature.
ros2 launch large_models_examples vllm_track.launch.py
  1. The following command line output indicates a successful call to the cloud-based large language model to process the command, provide a language response named response, and design actions that conform to the semantics of the command. The response is automatically generated, and only the semantic accuracy of the reply is guaranteed. The text arrangement of the reply is random.
11.3.4.4 Program Outcome
Once the feature is activated, the robot accepts conversational voice commands. For example, say “Follow the person in white clothes ahead”. The robot will identify the person in white clothes in the frame and stop after reaching a certain distance.
11.3.4.5 Program Analysis
Program path: ros2_ws/src/large_models_examples/large_models_examples/vllm_track.launch.py
        'sim': 'false',
Starts the robot base startup file and the large model-related startup file.
  1. Start Node
vllm_track_node = Node(
    executable='vllm_track',
Starts the vllm_track vision-language tracking node and configures screen output.
Program source code is located at: ros2_ws/src/large_models_examples/large_models_examples/vllm_track.py
  1. Define Prompt Template
As an intelligent hexapod robot proficient in image recognition, the capability involves performing precise object detection and localization on received images, outputting the final results according to the Output Format, and then executing tracking.
## 1. Understand Commands
A text command will be provided. Extract the object name from the statement. **The name corresponding to the object must be expressed in English.** **Do not output unmentioned objects.**
## 2. Understand Images
An image will be provided. Locate the top-left and bottom-right pixel coordinates of the target corresponding to the object name in this image. If the target is not found, set xyxy to []. **Do not output unmentioned objects.**
[Special Attention]: Deeply understand the spatial orientation of the objects. The response must integrate the received command and the detection results for the answer.
## Output Format. Please output only the following content and avoid any redundant text.
    "object": "name",
    "xyxy": [xmin, ymin, xmax, ymax],
    "response": "Chinese response of 5 to 30 characters"
    self.fps = fps.FPS() # Frame rate counter
    self.data = []
    self.box = []
    self.stop = True
    self.start_track = False
    self.track = ObjectTracker(use_mouse=True, automatic=True, log=self.get_logger())
    self.cmv_pub = self.create_publisher(Twist, '/controller/cmd_vel', 1)  # Chassis control
    image_sub = message_filters.Subscriber(self, Image, 'depth_cam/rgb/image_raw')
    depth_sub = message_filters.Subscriber(self, Image, 'depth_cam/depth/image_raw')
    # Synchronize timestamps, allowing a time error of 0.03s
    sync = message_filters.ApproximateTimeSynchronizer([depth_sub, image_sub], 3, 0.02)
    # Define PID parameters
    # 0.07, 0, 0.001
    self.pid_params = {
        'kp1': 0.1, 'ki1': 0.0, 'kd1': 0.00,
        'kp2': 0.002, 'ki2': 0.0, 'kd2': 0.0,
    # Dynamically declare parameters
    for param_name, default_value in self.pid_params.items():
        self.declare_parameter(param_name, default_value)
        self.pid_params[param_name] = self.get_parameter(param_name).value
    # Callback function for dynamic updating
    self.add_on_set_parameters_callback(self.on_parameter_update)
Initializes the node, creates publishers for TTS text and chassis motion control, and creates subscribers for TTS playback completion signals, large model processing results, wake-up signals, and camera images. Creates service clients for voice wake-up and large model settings, and finally creates a timer to start the initialization process.
  1. on_parameter_update Method
def on_parameter_update(self, params):
    """Parameter update callback"""
    for param in params:
        if param.name in self.pid_params.keys():
            self.pid_params[param.name] = param.value
    # self.get_logger().info(f'PID parameters updated: {self.pid_params}')
    # Update PID parameters
    return SetParametersResult(successful=True)
Supports modifying PID parameters at runtime to adjust tracking accuracy without restarting the node.
  1. create_update_callback Method
def create_update_callback(self, param_name):
    """Generate dynamic update callback"""
    def update_param(msg):
        new_value = msg.data
        self.pid_params[param_name] = new_value
        self.set_parameters([Parameter(param_name, Parameter.Type.DOUBLE, new_value)])
        self.get_logger().info(f'Updated {param_name}: {new_value}')
    return update_param
Generates a dynamic update callback function for each PID parameter.
    if language == 'Chinese':
    msg.data = PROMPT
    set_servo_position(self.joints_pub, 1.5, ((24, 700), (23, 500), (22, 100), (21, 100), (20, 750), (19, 500)))
    self.cmv_pub.publish(Twist())
    time.sleep(1.8)
    threading.Thread(target=self.display_thread, daemon=True).start()
Completes the configuration after the node starts, including large model parameters, the initial position of the robotic arm, and startup audio.
Service call tool, sending service requests and waiting for the results to return to ensure complete service communication.
    if msg.data and self.vllm_result:
        self.track.stop()
        self.stop = True
        self.track.stop()
        self.stop = True
Responds to the wake-up signal to implement interrupt control during the tracking process.
Receives the processing results of the large model and stores them in self.vllm_result for subsequent processing.
  1. process Method
def process(self):
    box = ''
                # self.get_logger().info('vllm_result: %s' % self.vllm_result)
                if self.vllm_result.startswith("```") and self.vllm_result.endswith("```"):
                    self.vllm_result = self.vllm_result.strip("```").replace("json\n", "").strip()
                response = self.vllm_result['response']
                msg = String()
                msg.data = response
                if box:
                        box = self.client.data_process(box, 640, 400)
                        self.get_logger().info('box: %s' % str(box))
                        box = [int(box[0] * 640), int(box[1] * 400), int(box[2] * 640), int(box[3] * 400)]
                    box[0] = int(box[0] / 640 * display_size[0])
                    box[1] = int(box[1] / 400 * display_size[1])
                    box[2] = int(box[2] / 640 * display_size[0])
                    box[3] = int(box[3] / 400 * display_size[1])
                    self.box = box
            except (ValueError, TypeError):
                self.box = []
                msg = String()
            time.sleep(0.02)
            msg.data = True
            self.stop = False
When the vision-language model output is detected, parse the detection result and extract the target bounding box coordinates. Convert the coordinate format based on the language environment. If the TTS playback is complete and the action processing is finished, reset the status and call the wake-up service.
  1. display_thread Method
def display_thread(self):
    # Create a new CUDA context in the current thread
    dev = cuda.Device(0)
    ctx = dev.make_context()
        model_path = os.path.split(os.path.realpath(__file__))[0]
        back_exam_engine_path = os.path.join(model_path, "resources/models/nanotrack_backbone_exam.engine")
        back_temp_engine_path = os.path.join(model_path, "resources/models/nanotrack_backbone_temp.engine")
        head_engine_path = os.path.join(model_path, "resources/models/nanotrack_head.engine")
        tracker = Tracker(back_exam_engine_path, back_temp_engine_path, head_engine_path)
            image = cv2.resize(image, tuple(display_size))
            if self.box:
                self.track.set_track_target(tracker, self.box, image)
                self.start_track = True
                self.box = []
            if self.start_track:
                self.data = self.track.track(tracker, image, depth_image)
                image = self.data[-1]
                self.cmv_pub.publish(twist)
            self.fps.show_fps(image)
            cv2.imshow('image', image)
            if key == ord('q') or key == 27:  # Press q or esc to exit
        # Ensure the context is properly released
        ctx.pop()
Initializes the tracker, processes camera images, executes object tracking, and controls chassis motion.
  1. multi_callback Method
def multi_callback(self, depth_image, ros_image):
    depth_frame = np.ndarray(shape=(depth_image.height, depth_image.width), dtype=np.uint16, buffer=depth_image.data)
    rgb_image = np.ndarray(shape=(ros_image.height, ros_image.width, 3), dtype=np.uint8, buffer=ros_image.data)  # Convert the custom image message into an image
    # bgr_image = cv2.cvtColor(rgb_image, cv2.COLOR_RGB2BGR)
    self.image_queue.put([rgb_image, depth_frame])
Receives the camera’s depth and RGB images, convert the formats, and store them in the image queue.
11.3.5 Smart Home Assistant
11.3.5.1 Experiment Introduction
Speak the designated wake word Hello Hiwonder to activate the voice device. It will respond with I‘m here. After activation, the robot can be controlled via voice commands. For instance, issue the command “Go to the front desk to see if the main door is closed, and then come back to report.” The terminal will print the recognized speech. The voice device will broadcast the generated response after processing and synchronously execute the corresponding action.
11.3.5.2 Preparation
  • Navigation Map Construction
Before enabling the function, a map needs to be established first. Refer to 5. Mapping and Navigation Course / 1 Mapping Tutorial for detailed information.
11.3.5.3 Operation Steps
Command inputs must strictly distinguish between uppercase and lowercase letters and spaces. Ensure the robot is connected to a network. Configure it to STA local area network mode, or use AP direct connection mode with an Ethernet cable.
  1. Click the icon on the left side of the system interface to open a command-line terminal. Enter the command, and press Enter to stop the auto-start service.
  1. Enter the command and press Enter to run the smart home assistant feature.
ros2 launch large_models_examples vllm_navigation.launch.py map:=map_01
  1. After opening the rviz map, click the 2D Pose Estimate icon to set the initial position of the robot.
  2. When the command line displays the following output and announces I’m ready, it indicates that the voice device has completed initialization. Then, say the wake word Hello Hiwonder to awaken it.
  1. The robot arrives at the front desk and identifies the status of the door.
  2. The robot returns to the starting point and replies whether the door is closed. For example, “The door is open. Please remember to close it properly to ensure security and privacy.”
  3. The following command line output indicates the end of a round of dialogue interaction. Refer to step 5 to wake up the voice device with the wake word again to start a new round of dialogue interaction.
11.3.5.4 Program Outcome
Once the feature is activated, the robot accepts conversational voice commands. For example, say “Go to the front desk to see if the main door is closed, and then come back to report.” The robot navigates to the set front desk location, checks whether the main door is closed, and then returns to the origin point to report the result.
11.3.5.6 Program Analysis
Program path: ros2_ws/src/large_models_examples/large_models_examples/vllm_navigation.launch.py
    PythonLaunchDescriptionSource(os.path.join(navigation_package_path, 'launch/navigation.launch.py')),
        'sim': 'false',
        'map': map_name,
        'robot_name': robot_name,
        'master_name': master_name,
        'use_teb': 'true',
Starts the files related to the navigation system and large models.
  1. Start Node
navigation_controller_node = Node(
    executable='navigation_controller',
rviz_node = ExecuteProcess(
        cmd=['rviz2', 'rviz2', '-d', os.path.join(navigation_package_path, 'rviz/navigation_controller.rviz')],
        output='screen'
vllm_navigation_node = Node(
    executable='vllm_navigation',
Starts the navigation control node, RViz visualization, and large model navigation node.
Program path: ros2_ws/src/large_models_examples/large_models_examples/vllm_navigation.py
## Role Task
The system acts as an intelligent hexapod robot equipped with a camera and a speaker capable of answering questions via audio playback. Corresponding JSON commands must be generated based on the input content.
## Requirements
1. Any input content must be matched with corresponding commands in the action function library and the corresponding JSON commands must be output.
2. Craft a concise 5 to 20 words humorous and highly varied feedback message for each action sequence to make the interaction engaging.
3. Output the JSON result directly without any analysis or redundant content.
## Special Notes
- The "action" key holds an array of function name strings arranged in execution order. When no corresponding action function is found the action outputs [].
- The "response" key is paired with a carefully crafted short reply that perfectly fits the above word count and style requirements.
- Move to a specified location: move('Kitchen')
- Return to the starting point: move('Starting point')
- Detect the visual frame: vision('What do you see')
- Play audio: play_audio()
## Task Example
Input: Go to the Zoo and find what animals are there, then come back to tell me.
Output: {"action": ["move('Zoo')""vision('what animal exist')", "move("starting point")", "play_audio()"], "response": "Copy that"}
    self.action = []
    self.response_text = ''
    self.play_delay = False
    self.reach_goal = False
    # self.create_subscription(Image, 'depth_cam/rgb/image_raw', self.image_callback, 1)
    self.agc = ActionGroupController(self.create_publisher(ServosPosition, 'servo_controller', 1), '/home/ubuntu/software/actionset_editor/ActionGroups')
Initializes the node and sets variables, including action lists, response texts, LLM processing results, and navigation target arrival states. Creates publishers for TTS text and subscribers for receiving LLM processing results, voice wake-up signals, audio playback completion states, and navigation arrival states. Establishes service clients for voice wake-up, large model settings, prompt configurations, and navigation target point settings. Finally, creates a timer to start the initialization process.
    msg.data = LLM_PROMPT
    self.get_logger().info('\033[1;32m%s\033[0m' % LLM_PROMPT)
Completes the configuration after the node starts, including large model parameters, prompt loading, and startup audio playback.
Receives and processes wake-up signals for interrupt judgment during subsequent action execution.
Receives the command results parsed by the large model and stores them in self.llm_result for subsequent processing.
  1. move Method
def move(self, position):
    self.get_logger().info('position: %s' % str(position))
    msg = SetPose2D.Request()
    p = position_dict[position]
    msg.data.x = float(p[0])
    msg.data.y = float(p[1])
    msg.data.roll = p[2]
    msg.data.pitch = p[3]
    msg.data.yaw = p[4]
    self.send_request(self.set_pose_client, msg)
Receives position parameters to query the corresponding coordinate and posture information, including x and y coordinates as well as roll, pitch, and yaw rotation angles. Creates a SetPose2D type service request message, fills in the data, and sends it to the navigation server to implement the robot’s navigation to the specified preset position.
  1. play_audio Method
def play_audio(self):
    msg = String()
    msg.data = self.response_text
    self.get_logger().info(f'{self.response_text}')
Publishes the feedback text to the TTS topic for voice broadcasting.
  1. reach_goal_callback Method
def reach_goal_callback(self, msg):
    self.get_logger().info('reach goal')
    self.reach_goal = msg.data
Receive the target arrival status message published by the navigation controller to mark the completion of the navigation action.
  1. vision Method
def vision(self, query):
    msg = SetContent.Request()
    msg.prompt = VLLM_PROMPT
    msg.query = query
    return res.message
Executes the visual detection task, sending visual query commands to the large model to obtain detection results.
  1. process Method
def process(self):
    first = True
        if self.llm_result:
            msg = String()
            if 'action' in self.llm_result: # Extract and process if there is a corresponding action returned
                    action = result['action']
                    for a in action:
                        if 'move' in a:
                            eval(f'self.{a}')
                            while not self.reach_goal:
                                if self.interrupt:
                        elif 'vision' in a:
                            res = eval(f'self.{a}')
                            self.response_text = res
                        elif 'play_audio' in a:
                            eval(f'self.{a}')
                        if self.interrupt:
            else: # No corresponding action, answer only
            msg.data = True
Detects the large model output and parses the action list and response text. If there is a movement command, execute navigation and wait to reach the target point, supporting interrupt mechanisms. If there is a visual command, execute a visual query and record the result. If there is an audio command, send the text response to the TTS module for voice broadcasting. If there is only a text response, only provide voice feedback. Finally, re-enable the voice wake-up function after the task is completed and wait for the next command.
11.3.6 Intelligent Transport
11.3.6.1 Experiment Introduction
Speak the designated wake word Hello Hiwonder to activate the voice device. It will respond with I‘m here. After activation, the robot can be controlled via voice commands. For instance, issue the command “Put the red block into the blue box”. The terminal will print the recognized speech. The voice device will broadcast the generated response after processing and synchronously execute the corresponding action.
11.3.6.2 Preparation
  • Pick and Place Calibration
Before enabling intelligent transport, adjust the picking deviation first. If the robotic arm fails to pick up the color block during the application, refer to this step for pick calibration. The specific steps are as follows:
  1. Click the icon on the left side of the system interface to open a command-line terminal. Enter the command and press Enter to stop the app auto-start service:
  1. Enter the command to start calibrating the picking position:
ros2 launch large_models_examples automatic_pick.launch.py debug:=pick
  1. The robotic arm will perform a picking calibration action and place the block at the claw’s picking location. Wait until the robotic arm returns to its original posture. Then, press the left mouse button on the screen and drag to select the target object. After the frame accurately recognizes the block, start the target position picking calibration. The robot will automatically calibrate the recognized object.
  2. The place calibration step is the same as the pick calibration step. Run the following program for place calibration:
ros2 launch large_models_examples automatic_pick.launch.py debug:=place
Before enabling the function, a map needs to be established first by referring to 5. Mapping and Navigation Course / 1 Mapping Tutorial.
11.3.6.3 Operation Steps
  1. If a map is not yet available, refer to 5. Mapping and Navigation Course / 5.1 Mapping Tutorial to build a map first.
  2. Enter the command and press Enter to run the intelligent transport feature.
ros2 launch large_models_examples vllm_navigation_transport.launch.py map:=map_01
  1. When the command line displays the following output and the voice device announces I‘m here, it indicates activation. The command recording process begins at this point. The command spoken is recorded at this moment. Proceed to speak the command “Put the red block into the blue box”, and then wait for the large model’s recognition.
  1. The robot will first navigate to the red block to pick it up.
  2. Next, it will navigate to the blue box and place the block inside it.
  3. The following command line output indicates the end of a round of dialogue interaction. Refer to step 6 to wake up the voice device with the wake word again to start a new round of dialogue interaction.
11.3.6.4 Program Outcome
Once the feature is activated, the robot accepts conversational voice commands. For example, say “Put the red block into the blue box”. The robot will first navigate to the red block to pick it up, then proceed to the blue box navigation point and place the block into it.
11.3.6.5 Navigation Position Modification
To modify the navigation position in the program, edit the file: ros2_ws/src/large_models_examples/large_models_examples/navigation_transport/vllm_navigation_transport.py
  1. Start the program to open the rviz map display, and then set the navigation target position by clicking 2D Goal Pose on the map.
  2. Return to the command terminal to view the published target position parameters:
Find the part of the program shown in the following figure, and fill in the desired target location parameters behind the corresponding location names:
The different positions in the program express the relative position of the target navigation point with respect to the map origin, which is the starting point of the robot during mapping.
The 5 parameters represent respectively:
x coordinate in meters
y coordinate in meters
roll angle rotating around the x-axis in degrees
pitch angle rotating around the y-axis in degrees
yaw angle rotating around the z-axis in degrees
For example, converting the quaternion with x=0.0, y=0.0, z=-0.5677173914973032, and w=0.8232235197025761 to Euler angles roll, pitch, and yaw yields roll ≈ 0°, pitch ≈ 0°, and yaw ≈ -69.3°.
11.3.6.6 Program Analysis
Program path: ros2_ws/src/large_models_examples/large_models_examples/navigation_transport/vllm_navigation_transport.launch.py
navigation_controller_launch = IncludeLaunchDescription(
    PythonLaunchDescriptionSource(os.path.join(navigation_package_path, 'large_models_examples/navigation_transport/navigation_transport.launch.py')),
        'map': map_name,
        'debug': 'false',
Starts the files related to navigation handling and large models.
  1. Start Node
vllm_navigation_transport_node = Node(
    executable='vllm_navigation_transport',
Starts the large model navigation handling node.
Program path: ros2_ws/src/large_models_examples/large_models_examples/navigation_transport/vllm_navigation_transport.py
LLM_PROMPT = '''
# Role Task
As a language expert, profound comprehension of commands is required.
## Skill Details
* Analyze commands to treat one pick and one place as a single action.
* Possess strong logical reasoning to understand object modifiers.
* Accurately extract the target objects for picking and placing.
 ## Requirements and Restrictions
1. Find and output the corresponding commands from the function library based on the input content.
2. Multiple actions must be placed in a list.
3. Craft a concise 10 to 30 word humorous and highly varied feedback message for the action sequence to make the interaction engaging.
4. Handling is divided into two phases: moving to the destination to pick up the object and moving to the target point to place it down.
5. Movement is required between picking and placing. If the movement destination is not specified, the move action is not executed by default.
6. Locations are limited to the following: blue block, blue box, red block, red box, green block, green box, and origin.
7. Output the JSON format data directly without any analysis or redundant content.
8. Only cubes with red, green, or blue colors are considered blocks. Do not recognize the ground. The response must not output terms like task completed.
9. Format: {"action":"xx", "response":"xx"}
## Available Functions and Operations
* Pick up the object: pick('红色方块')
* Place on the specified object: place('红色盒子')
* Move to the specified position: move('原点')
## Examples
Input: 将红色方块放到对应颜色的盒子里
Output: {"action": ["move('红色方块')","pick('红色方块')", "move('红色盒子')", "place('红色盒子')"], "response": "好的,马上就是办"}
Input: 将蓝色方块放到蓝色的盒子里
Output: {"action": ["move('蓝色方块')","pick('蓝色方块')", "move('蓝色盒子')", "place('蓝色盒子')"], "response": "好的,开始执行任务"}
    VLLM_PROMPT = '''
As an image recognition expert, the capability involves performing precise object detection and localization on received images, and outputting the final results according to the Output Format.
A text command will be provided. Make the optimal decision based on the command and extract the object name from the decision. **The name corresponding to the object must be expressed in English.** **Do not output unmentioned objects.**
An image will be provided. Determine if the target corresponding to the object name in this image has a graspable area. If so, output the top-left and bottom-right pixel coordinates. **Do not output unmentioned objects.**
[Special Attention]: Deeply understand the spatial orientation between objects.
    "object": name,
    self.action = []
    self.transport_action_finish = False
    self.create_subscription(Image, 'automatic_pick/image_result', self.image_callback, 1)
    self.create_subscription(Bool, 'automatic_pick/action_finish', self.action_finish_callback, 1)
    # self.set_target_client = self.create_client(SetPoint, 'automatic_pick/set_target_color')
    # self.set_target_client.wait_for_service()
    self.set_box_client = self.create_client(SetBox, 'automatic_pick/set_box')
    self.set_box_client.wait_for_service()
    self.set_pick_client = self.create_client(Trigger, 'automatic_pick/pick')
    self.set_pick_client.wait_for_service()
    self.set_place_client = self.create_client(Trigger, 'automatic_pick/place')
    self.set_place_client.wait_for_service()
Initializes the node and defines variables such as action status and large model results. Creates publishers for TTS text and subscribers for images, large model processing results, wake-up signals, voice playback completion signals, navigation target arrival signals, and pick/place action completion signals. Creates service clients for wake-up enablement, large model settings, prompt settings, navigation target point settings, and pick/place commands. Finally, triggers the initialization process through a timer.
Responds to the wake-up signal and marks the current action to be interrupted.
Receives the action sequence and feedback text parsed by the large model and stores them in self.llm_result.
  1. move Method
    if position in position_dict:
        msg.data.yaw = p[4]
        return True
        return False
Receives the target arrival status message published by the navigation controller to mark the completion of the navigation action.
  1. action_finish_callback Method
def action_finish_callback(self, msg):
    self.get_logger().info('action finish')
    self.transport_action_finish = msg.data
Receives the completion signal for picking or placing and marks the end of a single pick or place action.
  1. get_object_position Method
def get_object_position(self, query, image):
    msg.query = query
    msg.image = self.bridge.cv2_to_imgmsg(image, "bgr8")
    self.get_logger().info('send image')
    vllm_result = res.message
    self.get_logger().info('vllm_result: %s' % vllm_result)
    if 'object' in vllm_result:
        if vllm_result.startswith("```") and vllm_result.endswith("```"):
            vllm_result = vllm_result.strip("```").replace("json\n", "").strip()
        # self.get_logger().info('vllm_result: %s' % vllm_result)
        vllm_result = json.loads(vllm_result[vllm_result.find('{'):vllm_result.find('}')+1])
        box = vllm_result['xyxy']
        h, w = image.shape[:2]
            box = self.client.data_process(box, w, h)
            box = [int(box[0] * w), int(box[1] * h), int(box[2] * w), int(box[3] * h)]
        cv2.rectangle(image, (box[0], box[1]), (box[2], box[3]), (255, 0, 0), 2, 1)
        return box
        msg = String()
        msg.data = str(vllm_result)
        self.tts_text_pub.publish(vllm_result)
        return []
Utilizes the large model for visual positioning to obtain the coordinates of the target object’s picking area.
  1. pick Method
def pick(self, query):
    self.send_request(self.set_pick_client, Trigger.Request())
    box = self.get_object_position(query, image)
    if box:
        msg = SetBox.Request()
        msg.x_min = box[0]
        msg.y_min = box[1]
        msg.x_max = box[2]
        msg.y_max = box[3]
        self.send_request(self.set_box_client, msg)
Triggers the pick action while acquiring the visual positioning coordinates of the target object to be used for picking.
  1. place Method
def place(self, query):
    self.get_logger().info('place: %s' % query)
    self.send_request(self.set_place_client, Trigger.Request())
    h, _ = image.shape[:2]
    image = image[:int(h*0.7), :] #0:300
    if box:
        msg.x_min = box[0]
        msg.y_min = box[1]
        msg.x_max = box[2]
        msg.y_max = box[3]
Triggers the placement action while acquiring the visual positioning coordinates of the placement target to be used for placement.
  1. process Method
def process(self):
        if self.llm_result:
            msg = String()
            if 'action' in self.llm_result: # Extract and process if there is a corresponding behavior return
                    for a in action:
                        if 'move' in a:
                            if res:
                                    # if self.interrupt:
                                        # self.get_logger().info('interrupt')
                                        # break
                                self.get_logger().info('cannot move to %s' % a)
                        elif 'pick' in a or 'place' in a:
                            time.sleep(3.0)
                            eval(f'self.{a}')
                            while not self.transport_action_finish:
                                    # break
                            # break
            else: # No corresponding behavior, only answer
            msg.data = True
            # msg = SetInt32.Request()
            # msg.data = 2
Processes the large model output results and parses actions and response texts. Publishes the response text for voice synthesis. For each action, such as move, pick, and place, call the corresponding method and wait for the action to complete. If both audio playback and actions are completed, reset the status and call the wake-up service to allow receiving commands again.
Receives image results, converts them to OpenCV format, and stores them in the image queue.
11.3.6.7 Deviation Adjustment
If inaccuracies occur during picking, modify the parameters in the source code for adjustment. The source code is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/navigation_transport/automatic_pick.py
  1. If the robot camera version is a depth camera, modify the deviations of the x, y, and z axes at this location for adjustment.
  1. If the robot camera version is a monocular camera, depth values cannot be obtained. Therefore, the action group at this location needs to be modified for adjustment. The specific action group to be modified can be added to the upper computer software and run first to facilitate viewing the effect.
