7. Deep Learning Basic Course
7.1 Machine Learning Introduction
7.1.1 Overview
Artificial Intelligence (AI) is a new technological science focused on the theories, methods, technologies, and applications used to simulate, extend, and augment human intelligence.
AI encompasses various fields such as machine learning, computer vision, natural language processing, and deep learning. Among them, machine learning is a subfield of AI, and deep learning is a specific type of machine learning.
Since its inception, AI has seen rapid development in both theory and technology, with expanding application areas, gradually evolving into an independent discipline.
7.1.2 What Machine Learning is
Machine Learning is the core of AI and the fundamental approach to enabling machine intelligence. It is an interdisciplinary field involving probability theory, statistics, approximation theory, convex analysis, algorithmic complexity, and more.
Deep learning is a subfield of machine learning that focuses on how computers can acquire new knowledge or skills by simulating or replicating human learning behaviors. It also involves reorganizing existing knowledge structures to continuously improve their own performance. From a practical perspective, machine learning involves training models using data and making predictions with those models.
Take AlphaGo as an example—it was the first AI program to defeat a professional human Go player and later a world champion. AlphaGo operates based on deep learning, which involves learning the underlying patterns and hierarchical representations from sample data to gain insights.
7.1.3 Types of Machine Learning
Machine learning is generally classified into supervised learning and unsupervised learning, with the key distinction being whether the dataset’s categories or patterns are known.
Supervised Learning
Supervised learning provides a dataset along with correct labels or answers. The algorithm learns to map inputs to outputs based on this labeled data. This is the most common type of machine learning.
For instance, in image recognition, a large number of images of dogs can be labeled as “dog.” The machine learns to recognize dogs in new images through this data.
Unsupervised Learning
Unsupervised learning involves providing the algorithm with data without labels or known answers. All data is treated equally, and the machine is expected to uncover hidden structures or patterns.
For example, in image classification, if you provide a set of images containing cats and dogs without any labels. The algorithm will analyze the data and automatically group the images into two categories—cat images and dog images—based on similarities.
7.2 Machine Learning Library Introduction
There are many machine learning frameworks available. The most commonly used include PyTorch, TensorFlow, MXNet, and PaddlePaddle.
7.2.1 Pytorch
Torch is an open-source machine learning framework under the BSD License, widely used for its powerful multi-dimensional array operations. PyTorch is a machine learning library based on Torch but offers greater flexibility, supports dynamic computation graphs, and provides a Python interface.
Unlike TensorFlow’s static computation graphs, PyTorch uses dynamic computation graphs, which can be modified in real-time according to the needs of the computation. PyTorch allows developers to accelerate tensor operations using GPUs, build dynamic graphs, and perform automatic differentiation.
7.2.2 TensorFlow
TensorFlow is an open-source machine learning framework designed to simplify the process of building, training, evaluating, and saving neural networks. It enables the implementation of machine learning and deep learning concepts in the simplest way. With its foundation in computational algebra and optimization techniques,
TensorFlow allows for efficient mathematical computations. It can run on a wide range of hardware—from supercomputers to embedded systems—making it highly versatile. TensorFlow supports CPU, GPU, or both simultaneously. Compared to other frameworks, TensorFlow is best suited for industrial deployment, making it highly appropriate for use in production environments.
7.2.3 PaddlePaddle
PaddlePaddle, developed by Baidu, is China’s first open-source, industrial-grade deep learning platform. It integrates a deep learning training and inference framework, a library of foundational models, end-to-end development tools, and a rich suite of supporting components. Built on years of Baidu’s R&D and real-world applications in deep learning, PaddlePaddle is powerful and versatile.
In recent years, deep learning has achieved outstanding performance across many fields such as image recognition, speech recognition, natural language processing, robotics, online advertising, medical diagnostics, and finance.
7.2.4 MXNet
MXNet is another high-performance deep learning framework that supports multiple programming languages, including Python, C++, Scala, and R. It offers data flow graphs similar to those in Theano and TensorFlow and supports multi-GPU configuration. It also includes high-level components for model building, comparable to those in Lasagne and Blocks, and can run on nearly any hardware platform—including mobile devices.
MXNet is designed to maximize efficiency and flexibility. As an accelerated library, it provides powerful tools for developers to take full advantage of GPUs and cloud computing. MXNet supports distributed deployment via a parameter server and can scale almost linearly across multiple CPUs and GPUs.
7.3 YOLO26 Model
7.3.1 Yolo Model Series Introduction and Comparison
YOLO Series
YOLO26
YOLO26 is the next-generation real-time object detection model introduced by Ultralytics. Built upon the foundation of previous YOLO versions, it features significant optimizations that deliver substantial improvements in both detection speed and accuracy.
Core Features of YOLO26
1. Simplified Architecture: Removes Distribution Focal Loss (DFL) to streamline bounding box regression and enhance export compatibility.
2. End-to-End Inference: Utilizes an NMS-free (Non-Maximum Suppression) design to directly output detection results, significantly reducing latency and deployment complexity.
3. Training Enhancements: Introduces Progressive Loss Balancing (ProgLoss) and Small Target-Aware Label Assignment (STAL) to improve the stability of small object detection.
4. Optimizer Innovations: Utilizes the MuSGD optimizer, which combines the strengths of SGD and Muon to accelerate model convergence.
5. Multi-Task Support: Features a unified framework that supports object detection, instance segmentation, pose estimation, oriented object detection, and image classification.
6. Edge Optimization: Supports FP16/INT8 quantization, enabling low-latency, real-time inference on edge devices such as the NVIDIA Jetson.
7. Performance: Achieves high precision on benchmarks such as COCO, delivering up to a 43% increase in CPU inference speed compared to previous generations.
7.3.2 YOLO26 Model Structure
Components
Convolutional Layer: Feature Extraction
In YOLOv8, the data to be processed is images, which are two-dimensional in computer vision. Accordingly, the convolution is two-dimensional convolution. The purpose of 2D convolution is to extract features from images. To perform 2D convolution, it is necessary to understand the convolution kernel.
The convolution kernel is the unit region over which convolution calculation is performed each time. The unit is pixels, and the convolution sums the pixel values within the region. Typically, convolution is done by sliding the kernel across the image, and the kernel size is manually set.
When performing convolution, depending on the desired effect, the image borders may be padded with zeros or extended by a certain number of pixels, then the convolution results are placed back into the corresponding positions in the image.
For example, a 6×6 image is first expanded to 7×7, then convolved with the kernel, and finally the results are filled back into a blank 6×6 image.
Pooling Layer: Feature Amplification
The pooling layer, also called downsampling layer, is usually used together with convolution layers. After convolution, pooling performs further sampling on the extracted features. Pooling includes various types such as global pooling, average pooling, max pooling, etc., each producing different effects.
Upsampling Layer: Restoring Image Size
Upsampling can be understood as “reverse pooling.” After pooling, the image size shrinks, and upsampling restores the image to its original size. However, only the size is restored, and the pooled features are also modified accordingly.
Batch Normalization Layer: Data Regularization
ReLU Layer: Activation Function
ADD Layer: Tensor Addition
Concat Layer: Tensor Concatenation
Composite Elements
Convolutional Block
Strided Sampling and Concatenation Unit(Focus)
By taking the small patches at position 1 from each large region and concatenating them, a 3×3 image can be formed. The patches at other positions are concatenated in the same way. Ultimately, the original 6×6 image is decomposed into four 3×3 images.
Residual Block
Composite Convolutional Block
In YOLO26, a key feature of the composite convolutional block is its customizable design, allowing convolutional blocks to be configured as needed. This structure also uses two paths whose outputs are merged.
Composite Residual Convolutional Block
The composite residual convolutional block modifies the composite convolutional block by replacing the 2𝑥 convolutional blocks with 𝑥 residual blocks. In YOLO26, this block is also customizable, allowing residual blocks to be tailored according to specific requirements.
Composite Pooling Block
7.3.3 YOLO26 Workflow
This section explains the model’s processing flow using the concepts of prior boxes, predicted boxes, and anchor boxes.
Prior Box
Predicted Box
Predicted boxes are generated by the model as output and do not require manual input. When the first batch of training data is fed into the model, the predicted boxes are automatically created. The center points of predicted boxes tend to be located in areas where similar objects frequently appear.
Anchor Box
Project Process
7.4 YOLO26 Model Training
7.4.1 Image Collection and Labeling
Training a YOLO model requires a substantial dataset. Therefore, data collection and annotation must be performed first to prepare for subsequent model training.
Image Collection
Power on the robot and establish a connection via VNC remote desktop software.
Click the desktop icon
to open a terminal.
Enter the command to launch the depth camera service.
Open a new terminal window and execute the following command to create a directory for storing the dataset.
mkdir -p ~/my_data
Execute the command to launch the image collection utility.
The save number displayed in the upper-left corner indicates the current image ID or the index of the saved image. The existing represents the total number of images saved so far.
Click Select and modify the destination path to the newly created directory.
Once the target directory is selected, click Choose.
Place the target object within the field of view of the camera. Click the Save (space) button or press the Spacebar to capture and save the current frame.
After clicking Save (space) or pressing the Spacebar, a JPEGImages folder will automatically be generated inside the /home/ubuntu/my_data directory to store the captured images.
To enhance model robustness, capture the target object from various distances, rotational angles, and tilt angles.
Once image collection is complete, click the Quit button to close the utility.
Open a terminal and run the command to verify the saved images.
cd ~/my_data/JPEGImages && ls
Press the key combination Ctrl + C in all open terminal windows to terminate the processes. This completes the image collection workflow.
Image Labeling
Image annotation is a critical step following data collection. Annotating the dataset defines ground truth boundaries and object classes, enabling the model to learn prominent features and generalize effectively to new, unseen images.
Terminal commands are strictly case-sensitive. The Tab key can be used for keyword auto-completion.
Open a terminal and execute the command to launch the annotation software.
python3 ~/software/roLabelImg/roLabelImg.py
In the software interface, click File in the top-left corner, select Open Dir, navigate to the image repository directory, and click Choose.
Click File in the top-left corner and select Change default saved Annotation dir to update the destination path to the Annotations directory inside the my_data folder.
Click View in the top-left corner and select Advanced Mode to enable the oriented bounding box function for rotated annotations.
Use the following shortcuts for efficient labeling. Press E to create a rotated bounding box, D for the next image, and A for the previous image. For adjustments, use C for a minor clockwise rotation, X for a minor counterclockwise rotation, V for a major clockwise rotation, and Z for a major counterclockwise rotation. Click the Save icon on the left panel after completing each image.
The C and X keys must be used to rotate and precisely align the bounding box with the contours of the object. Improper alignment will degrade downstream detection accuracy.
Assign a class name to the target object in the dialog box. After entering the class name, click OK to save the label.
Press the D key to proceed to the next image. Once all images are labeled, click the close icon in the top-right corner of the window to exit the software.
7.4.2 Data Format Conversion
Before proceeding with this section, image collection and annotation must be completed. For detailed instructions, refer to 7.4.1 Image Collection and Labeling.
Before feeding the dataset into the YOLO26 model for training, defining the object classes and converting the annotation files into the required format is mandatory.
Format Conversion
Before starting this section, image collection and annotation must be completed.
Open a new terminal and run the command to view the configuration file. If the file does not exist, it can be created directly using this command.
gedit ~/my_data/classes.names
Write the designated class name, left, into the text file. If dealing with multiple distinct classes, enter each class name on a separate line.
The class name added here must exactly match the label defined in the “roLabelImg” annotation software.
After editing, press Ctrl + S to save the changes and close the editor.
Return to the terminal window, execute the format conversion command, and press Enter.
python3 ~/third_party_ros2/yolo/xml2yolo_obb.py --data ~/my_data --yaml ~/my_data/data.yaml
The parameters utilized in the command are defined below.
(1) my_data: Represents the custom annotated dataset folder. The specified directory path must match the actual location.
(2) data.yaml: Defines the data structural configuration for the dataset conversion. As indicated by the command, the output file will be saved inside the my_data directory.
7.4.3 Model Training
Following the format conversion, the next phase is model training. Ensure that the formatted dataset is fully prepared by referencing section 7.4.2 Data Format Conversion.
Model Training
Start the robot and connect it to the VNC remote control software.
on the system desktop to open a command line terminal.Run the following command to navigate to the designated workspace directory.
cd ~/third_party_ros2/yolo/yolo26
Execute the training command to begin the optimization process.
python3 train.py --img 640 --batch 64 --epochs 300 --data ~/my_data/data.yaml --weights yolo26n.pt
Within the training arguments:
–img specifies the input resolution.
–batch defines the batch size per iteration.
–epochs determines the total training cycles.
–data points to the dataset configuration path.
–weights designates the initial pre-trained weights file.
These configuration parameters can be modified based on specific project requirements. Increasing the number of epochs generally enhances model accuracy and reliability, though it extends total computation time.
Once model training concludes, the output directory path will be displayed in the terminal. The weights and evaluation results for this session are saved in the /home/ubuntu/runs/detect/train3 directory.
The exact generation path varies depending on prior runs. The latest output folder can be located within the “runs/detect/train” directory.
7.4.4 Object Detection
A custom deployment model is obtained after extensive training cycles. To review the comprehensive workflow, refer to sections 7.4.1 Image Collection and Labeling through 7.4.3 Model Training.
Operation Steps
to open a terminal window, then run the command to stop the default background application service.
Execute the following command to copy the newly trained best.pt file to the ~/third_party_ros2/yolo directory. The target source folder name may vary based on the training iteration and should be adjusted accordingly.
cp ~/runs/detect/train3/weights/best.pt ~/third_party_ros2/yolo
Open the launch file using the text editor command.
gedit ~/ros2_ws/src/example/example/yolo_detect/yolo_detect_demo.launch.py
Locate the CLASSES_NAMES_DEFAULT parameter and insert the trained class name, left, enclosed in double quotation marks. Save the file and close the editor.
Launch the object detection node using the provided command.
ros2 launch example yolo_detect_demo.launch.py model_name:=best
Detection Results
Place a target road sign within the camera field of view. When successfully detected, a bounding box will frame the target on the video stream, accompanied by its class label and the inference confidence score.
7.5 Waste Classification Card Model
Product names and reference directory paths mentioned throughout this documentation are subject to change depending on the actual hardware version and configuration.
Training on the embedded robot controller board is discouraged when handling larger datasets due to RAM constraints and I/O hardware limitations. Utilizing a desktop or laptop equipped with a dedicated graphics card is highly recommended. The core training workflow remains identical, requiring only the deployment of the corresponding software environment.
This section serves as a direct reference guide for training custom deep learning models.
7.5.1 Preparation
Prepare a workstation or laptop computer. Ensure a wireless network card and standard peripherals are available if a desktop computer is utilized.
Install and launch the VNC remote desktop client based on the procedures detailed in previous chapters.
7.5.2 Model Deployment
Execute the command to terminate the app service.
Launch the trash classification object detection pipeline.
ros2 launch example yolo_detect_demo.launch.py model_name:=best_garbage_26
Detection Results
Place a waste classification card within the camera’s field of view. Upon recognition, a bounding box will highlight the object in the preview window, displaying the identified class name and its associated detection confidence score.
