11. Large AI Model Course
11.1 Large Models Basic Courses
11.1.1 Large Language Model Courses
Overview of Large Language Model
(1) Basic Concept
(2) Features
(3) Working Principle
(4) Application Scenarios
① Text Generation
② Text Classification
③ Machine Translation
④ Question-Answering Systems
Large Language Model Deployment
Large Language Model Accessing
To proceed with this section, you will need to register on the appropriate website and obtain the API key for the large model (please refer to the file “11.1.1 Large Language Model Courses -> Large Language Model Deployment”).
(1) Environment Configuration
sudo apt install vim
sudo apt install gedit
sudo apt install python3 python3-pip python3-all-dev python3-pyaudio portaudio11-dev libsndfile1
cd ~/large_models/speech_pkg/
| Type of main controller | Python version |
| jetson_nano | 3.6 |
| jetson_orin | 3.10 |
| rpi5 | 3.11 |
| rpi5_docker | 3.8 |
cd jetson_orin/
cp -r speech.so ..
cd ../..
pip3 install .
pip3 install openai -U
(3) Key Configuration
cd ~/large_models
vim config.py
③ Once the file is open, configure the OpenAI and OpenRouter keys by filling in the llm_api_key and vllm_api_key parameters, respectively (you can obtain these keys from the ‘11.1.1 Large Language Model Courses -> Large Language Model Deployment’ course).
(4) Running the Demo Program
python3 openai_llm_demo.py
Semantic Understanding with Large Language Model
Before starting this section, make sure you have completed the API key configuration outlined in the file 11.1.1 Large Language Model Courses -> Large Language Model Accessing.
cd large_models/
Emotional Perception with Large Language Model
To proceed with this section, ensure that you have completed the API key configuration as described in the file 11.1.1 Language Model Courses -> Large Language Model Accessing.
cd large_models/
python3 openai_llm_er_demo.py
11.1.2 Large Speech Model Courses
Overview of Large Speech Model
Their advantages include:
① Processing Methods
② Model Complexity
③ Recognition Capability
④Training Data Requirements
② Text-to-Speech (TTS)
Voice Device Introduction and Testing
(1) Device Overview
① 6-Microphone Circular Array
Introduction:
Features and Specifications:
② Recording Test
arecord -l
③ Playback Test
aplay test.wav
Voice Wake-Up
(1) WonderEcho Pro Wake-Up
Device Check:
To proceed, we need to identify the USB device name assigned to the connected WonderEcho Pro or Circular Microphone Array (hereafter referred to as the voice device). Please follow the steps below carefully.
ll /dev | grep USB
ll /dev | grep USB
Wake-Up Test:
vim wakeup_demo.py
Device Check:
Wake-Up Test:
② Press i to enter edit mode.
③ Update the port to match the device port number you previously identified. Comment out the WonderEcho Pro configuration (add # at the beginning of the corresponding line), and uncomment the line using the circular microphone array on line 11 as the input device (see red box in the referenced image).
(3) Brief Program Overview
Importing Required Modules
5 6 7 | import os import time from speech import awake |
9 10 | port = '/dev/ttyUSB0' kws = awake.WonderEchoPro(port) |
13 14 15 16 | try: # If a fan is present, it's recommended to turn it off before detection to reduce interference(如果有风扇,检测前推荐关掉减少干扰) os.system('pinctrl FAN_PWM op dh') except: pass |
Main Wake Word Detection Loop
18 19 | kws.start() # Start detection(开始检测) print('start...') |
Main Program Logic
20 21 22 23 24 25 26 27 28 29 30 31 | while True: try: if kws.wakeup(): # Wake-up detected(检测到唤醒) print('hello hiwonder') time.sleep(0.02) except KeyboardInterrupt: kws.exit() # Cancel processing (关闭处理) try: os.system('pinctrl FAN_PWM a0') except: pass break |
(4) Extended Functionality
vim wakeup_demo.py
i
python3 wakeup_demo.py
“Appendix → Firmware Flashing Tool → Creating Firmware for WonderEchoPro”.
Speech Recognition
(2) How It Works
Before proceeding, refer to the course “11.1.2 Large Speech Model Courses -> Large Language Models Deployment” to obtain your API key, and make sure to add it into the configuration file (config).
(4) Experiment Steps
cd large_models/
vim config.py
python3 openai_asr_demo.py
(5) Function Realization
(6) Brief Program Analysis
① Module Import
6 | from speech import speech |
② Define ASR Class
11 | asr = speech.RealTimeOpenAIASR() |
13 | asr.update_session(model='whisper-1', language='en', threshold=0.2, prefix_padding_ms=300, silence_duration_ms=800) |
(7) Function Extension
vim openai_asr_demo.py
i
Speech Synthesis
(1) What is Speech Synthesis?
(2) How It Works
Refer to the course “11.1 Large Models Basic Courses ->11.1.1Large Language Models Courses -> Large Language Models Deployment” to obtain your API key, and update the configuration file accordingly.
cd large_models/
vim config.py
python3 openai_tts_demo.py
① Module Import
5 6 | from config import * from speech import speech |
② Definition for TTS Class
8 9 10 11 | tts = speech.RealTimeOpenAITTS() tts.tts("Hello, Can I help you?") # https://platform.openai.com/docs/guides/text-to-speech tts.tts("Hello, Can I help you?", model="tts-1", voice="onyx", speed=1.0, instructions='Speak in a cheerful and positive tone.') tts.save_audio("Hello, Can I help you?", model="gpt-4o-mini-tts", voice="onyx", speed=1.0, instructions='Speak in a cheerful and positive tone.', audio_format='wav', save_path="./resources/audio/tts_audio.wav") |
③ Function Extension
vim openai_tts_demo.py
i
Voice Interaction
(2) How It Works
(3) Experiment Steps
① Power on the device and connect to it via MobaXterm (refer to Appendix “5.1 Remote Connection Tools and Instructions” for connection guidance).
② To check the microphone’s port number, first disconnect the microphone and run the command. Then reconnect the microphone and run the command again to determine the port number.
Note: do not connect any other USB devices during this process
ll /dev | grep USB
cd large_models/
vim config.py
⑥ Run the program:
(4) Function Realization
(5) Brief Program Analysis
(1) Module Import
5 6 7 8 9 | import os import time from config import * from speech import awake from speech import speech |
11 12 13 | wakeup_audio_path = './resources/audio/en/wakeup.wav' start_audio_path = './resources/audio/en/start_audio.wav' no_voice_audio_path = './resources/audio/en/no_voice.wav' |
(3) Main Functional Logic
33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 | def main(): kws.start() while True: try: if kws.wakeup(): # Wake word detected(检测到唤醒词) speech.play_audio(wakeup_audio_path) # Play wake-up sound(唤醒播放) asr_result = asr.asr() # Start voice recognition(开启录音识别) print('asr_result:', asr_result) if asr_result: # Send the recognition result to the agent for a response(将识别结果传给智能体让他来回答) response = client.llm(asr_result, model='gpt-4o-mini') print('llm response:', response) tts.tts(response) else: speech.play_audio(no_voice_audio_path) time.sleep(0.02) except KeyboardInterrupt: kws.exit() try: os.system('pinctrl FAN_PWM a0') except: pass break except BaseException as e: print(e) |
11.1.3 Vision Language Model Courses
Overview of Vision Language Model
(1) Basic Concept
(2) Features
(3) How It Works
① Image Captioning
② Visual Question Answering
③ Image Retrieval
④ Augmented Reality (AR)
⑥ Social Media Interaction
⑦ Medical Imaging Analysis
Vision Language Model Accessing
This section requires the configuration of the API key in “11.1.3 Vision Language Model Accessing -> Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
This experiment requires either an Ethernet cable or Wi-Fi connection to ensure the main control device can access the network properly.
(1) Experiment Steps
cd large_models/
Run the program:
(2) Function Realization
Vision Language Model: Object Detection
This section requires the configuration of the API key in “11.1.3 Vision Language Module Courses -> Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
In this course, we will use a program to transmit an image to the large model for recognition, which will then identify and locate the objects within the image by drawing bounding boxes around them.
cd large_models/
② Run the program:
(3) Function Expansion
Change Pictures:
② Then, input the command:
i
Vision Language Model: Scene Understanding
This section requires the configuration of the API key in “Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
In this course, we will use a program to send an image to the large model for recognition and generate a description of the content within the image.
cd large_models/
② Run the program:
④ Run the program:
Vision Language Model: Optical Character Recognition
This section requires the configuration of the API key in “1.3.2 Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
In this course, we use a program to transmit an image to the large model for recognition, extracting and identifying the text within the image.
cd large_models/
② Run the program:
python3 openai_vllm_ocr.py
Change Pictures:
i
⑤ Run the program:
11.1.4 Multimodal Model Basic Courses
Overview of Multimodal Model
(1) Basic Concept
(2) Features
(3) How It Works
① Education
② Healthcare
③ Entertainment
④ Advertising and Marketing
Agent Behavior Orchestration
The purpose of this course experiment is to obtain data in a specified format returned by the large model based on the prompt words set in the model. During development, you can use the returned data for further tasks.
① To check the microphone’s port number, first disconnect the microphone and run the command. Then reconnect the microphone and run the command again to determine the port number.
Note: do not connect any other USB devices during this process.
ll /dev | grep USB
cd large_models/
vim config.py
vim openai_agent_demo.py
⑤ Run the program:
python3 openai_agent_demo.py
11.2 Multimodal Large Model Applications
11.2.1 Obtain and Configure the Large Model API Key
This section requires registering on the official OpenAI website and obtaining an API key for accessing large language models.
Register and Deploy OpenAI Account
Copy and open the following URL:
Register and log in using a Google, Microsoft, or Apple account, as prompted.
After logging in, click the Settings button, then go to Billing, and click Payment methods to add a payment method. Recharge your account to purchase tokens as needed.
Once your account is set up, go to the API Keys section and click Create new key. Follow the instructions to generate a new API key and save it securely for later use.
The creation and deployment of the large model have been completed, and this API will be used in the following lessons.
Register and Deploy OpenRouter Account
Copy and open the following URL: https://openrouter.ai/ and click “Sign in”, and register or sign in using Google or another available account.
After logging in, click the icon in the top-right corner, then select “Credits” to add a payment method.
Create an API key. Go to “API Keys”, then click “Create Key”. Follow the prompts to generate a key. Save the API key securely for later use.
API Configuration
In the command-line terminal, enter the following command to navigate to the directory where the large model keys are configured.
cd ~/ros2_ws/src/large_models/large_models
Next, open the configuration file with the following command.
vim config.py
Once the file is open, you need to configure the OpenAI and OpenRouter keys by filling them into the parameters llm_api_key and vllm_api_key, respectively.
For example, copy the keys you created in this chapter and paste them into the corresponding fields. Place the cursor between the quotation marks, right-click, and select Paste.
Note: keys from different large models cannot be mixed, otherwise the functions may fail to work properly.
After pasting, enter the following command and press Enter to save the file:
11.2.2 Voice Control
The large model used in this lesson operates online, requiring a stable network connection for the main controller in use. For better stability, it is recommended to use a wired network connection.
Overview
When the program starts, the AI voice box will announce “I’m ready.”
Then, you can say the designated wake word “Hello Hiwonder” to activate the AI Voice Box, and it will respond with “I’m here.” After activation, you can control the ArmPi Ultra by voice. For example, if you say “Servo No. 1 move to 90 degrees,” the terminal will display the recognized speech, the AI Voice Box will announce the generated response after processing, and the robot will execute the corresponding action.
(1) Confirm WonderEcho Pro Firmware
The default wake word for WonderEcho Pro is “Hello Hiwonder.” If you wish to change the wake-up word to “Xiaohuan Xiaohuan,” please refer to the directory: 10. Voice Control Course ->10.2 Firmware Flashing.
If you have previously flashed a different firmware, such as the one using the wake word “Xiaohuan Xiaohuan,” you must use the corresponding wake word.
The examples in this course will assume the default factory wake word: “Hello Hiwonder.”
(2) Configuring the Large Model API-KEY
By default, the program does not include the configuration of the Large Model-related API keys. Before activating features related to the Large AI Model, please refer to the section 11.2.1 Obtain and Configure the Large Model API Key in this document to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
Network Configuration
The large model used in this lesson is an online model, so network access is required before getting started. Please prepare an Ethernet cable to connect the robot to the network, or switch the robot to LAN mode.
The robot must be connected to the Internet during this feature, either in STA (LAN) mode or AP (direct connection) mode via Ethernet. There are two methods available for configuring the network:
To configure the network using the mobile app, you may refer to the tutorial under the directory:1.ArmPi Ultra User Manual->1.4 App Control->1.4.2 Connection Modes Overview.
Connect to the robot via VNC and modify the network configuration files as described in:1.ArmPi Ultra User Manual ->1.6 Development Environment Setup and Configuration >1.6.3 LAN Mode Connection.
Operations
Command input is case-sensitive and space-sensitive.
The robot must be connected to the Internet, either in STA (LAN) mode or AP (direct connection) mode via Ethernet.
Click on
to launch the command bar, enter the command, and press Enter to disable the auto-start service.Enter the command to disable the auto-start service of the mobile app.
Enter the following command and press Enter to launch the voice control feature.
ros2 launch large_models llm_control_servo.launch.py
When the terminal displays output shown in the figure and the AI voice box announces “I’m ready”, the voice device has completed initialization. Then, you can say the wake words: “Hello Hiwonder”.
When the terminal displays the corresponding output shown in the figure and the device responds with “I’m here”, it indicates successful activation. The system will begin recording your voice command.
You can give commands by following the input prompts shown in the program’s task examples.
Upon successful recognition by the speech recognition service of cloud-based large speech model, the parsed command will be displayed under the publish_asr_result output in the terminal.
Upon receiving user input shown in the figure, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command, generate a language response, and execute a corresponding action based on the meaning of the command.
The response is automatically generated by the model. While the semantic content is accurate, the wording and structure may vary due to randomness in language generation.
When the terminal shows the output shown in the figure indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 4 by speaking the wake words again.
To exit the feature, press Ctrl + C in the terminal. If the feature does not exit immediately, press Ctrl + C multiple times.
Project Outcome
Once the feature is activated, you can phrase your own commands. For example: “Servo No. 1 move to 90 degrees” will control Servo 1 of the ArmPi Ultra to rotate to the 90° position.
Program Brief Analysis
(1) launch File Analysis
① launch_setup Function
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) sdk_package_path = get_package_share_directory('sdk') large_models_package_path = get_package_share_directory('large_models') sdk_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(sdk_package_path, 'launch/armpi_ultra.launch.py')), ) large_models_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ) llm_control_servo_node = Node( package='large_models', executable='llm_control_servo', output='screen', ) return [mode_arg, sdk_launch, large_models_launch, llm_control_servo_node, ] |
Loads the launch/armpi_ultra.launch.py file from the SDK package to start the underlying control services of the robotic arm, such as servo drivers and kinematics computation, providing the necessary hardware support for subsequent control operations. Loads the launch/start.launch.py file from the large_models package to start the services related to the large model. Uses launch_arguments to pass in the mode parameter, which controls the running mode of the large model, such as different interaction logic or feature toggles. Declare the llm_control_servo_node to launch the llm_control_servo executable from the large_models package. Its core function is to convert the outputs of the large model into commands for the robotic arm, completing the closed loop of “Large Model Decision to Arm Action”, with logs displayed on the screen.
② generate_launch_description Function
41 42 43 44 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function = launch_setup) ]) |
Creates and returns a LaunchDescription object, calling launch_setup via OpaqueFunction as the standard entry point for the ROS 2 launch file.
③ Main Function
46 47 48 49 50 51 52 | if __name__ == '__main__': # Create a LaunchDescription object (创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
Creates a LaunchDescription object and a LaunchService service. The launch description is added to the service and executed, enabling the startup of the entire system manually.
(2) Python File Analysis
① Prompt Template Definition
65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 | PROMPT = ''' #Role You are an intelligent robot arm, and you need to generate corresponding instructions based on the input content. ##Requirements and Restrictions 1. According to the input action content, find the corresponding instructions in the action function library and output the corresponding instructions. 2. Weave a concise (10 to 30 words), humorous and continuous feedback information for each action sequence to make the communication process interesting. 3. The top is the positive z-axis, the left is the negative y-axis, and the front is the positive x-axis, in meters 4. The servo numbers are 1, 2, 3, 4, 5, 10, and the rotation range is [-120, 120] degrees. If the range is exceeded, the action returns [] 5. The initial position is [0, 48, -72, -96, 0, -30] 6. Output the json result directly, do not analyze, and do not output redundant content. 7. Format: {"action": ["xx", "xx"], "response": "xx"} ##Structural requirements: - The "action" key stores an array of function names in order. When the corresponding action function cannot be found, action outputs []. - The "response" key is accompanied by a brief response, which perfectly meets the above word count and style requirements, the language type of the user is consistent. - **Special processing**: If the servo running time is not specified, it is fixed to 1 second. If there is no delay or stop between two actions, they are combined ##Action function library - Control the servo to move to the specified position at the specified time: set_position(1, ((1, -120), (2, 90))) - Control the robot to move the specified distance in the specified direction: move(x, y, z) - Delay for a specified time: time.sleep(1) ##Example Input: Servo No. 1 and Servo No. 2 move to -90 degrees and 90 degrees respectively within 2 seconds Output: {"action": ["set_position(2, [[1, -90], [2, 90]])"], "response": "Received, execute immediately"} Input: Servo No. 1 rotates 45 degrees within 1 second Output: {"action": ["set_position(1, [[1, 45]])"], "response": "OK"} Input: Servo No. 6 turns 15 degrees Output: {"action": ["set_position(1, [[6, 15]])"], "response": "OK, Servo No. 6 turns to 15 degrees"} Input: Servo No. 3 turns to 11 degrees, Servo No. 4 turns to 0 degrees, stop for 2 seconds Output: {"action": ["set_position(1, [[3, 11], [4, 0]])", "time.sleep(2)"], "response": "OK"} Input: Servo No. 1 turns 20 degrees, Servo No. 3 turns 45 degrees, stop for 1 second, Servo No. 1 turns 50 degrees, Servo No. 2 turns 0 degrees Output: {"action":["set_position(1, [[1, 20], [3, 45]])", "time.sleep(1)", "set_position(1, [[2, 0]])"], "response": "OK"} Input: Move down 2cm, stop for 1s, Servo 4 turns to 30 degrees, stop for 1s, move forward 3cm Output: {"action":["move(0, 0, -0.02)", "time.sleep(1)", "set_position(1, [[4, 30]])", "time.sleep(1)", "move(0.03, 0, 0)"], "response": "No problem"} ''' |
② Variable Initialization
104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 | class LLMControlServo(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.action = [] self.interrupt = False self.llm_result = '' self.action_finish = False self.play_audio_finish = False # self.llm_result = '{\'action\':[\'set_position(1, [[10, -20]])\'], \'response\':\'好嘞\'}' # self.llm_result = '{\"action\": [\"move(0, 0, -0.05)\"], \"response\": \"坐稳了,准备下移5cm!\"}' self.running = True self.id_dict = {'1': 5, "2": 4, "3": 3, "4": 2, "5": 1, "6": 0} self.current_pulse = [500, 600, 825, 110, 500, 210] self.current_position = [0.1, 0, 0.226] timer_cb_group = ReentrantCallbackGroup() self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1) self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.set_pose_target_client = self.create_client(SetRobotPose, 'kinematics/set_pose_target') self.set_pose_target_client.wait_for_service() self.set_joint_value_target_client = self.create_client(SetJointValue, 'kinematics/set_joint_value_target') self.set_joint_value_target_client.wait_for_service() self.joints_pub = self.create_publisher(ServosPosition, 'servo_controller', 1) # Servo control 舵机控制 self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
Initialize state variables such as the action list action and interrupt flag interrupt, and record the current servo positions and robotic arm pose. Create publishers, such as publisher for TTS text output, and subscribers, such as subscribers for large model results, TTS playback completion signals, and wake-up signals. Create service clients, such as clients for configuring the large model, controlling servos, and managing robotic arm poses to handle communication and control.
③ get_node_state Method
143 144 | def get_node_state(self, request, response): return response |
A service callback that returns an empty response, used to query the node’s status, like confirming initialization completion.
④ init_process Method
146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) # -92 #self.set_position(1.5, [[6, 0], [5, 3], [4, 78], [3, -115], [2, 0], [1, -30]]) #self.set_position(1.5, [[6, 0], [5, 48], [4, -72], [3, -96], [2, 0], [1, -30]]) msg = set_joint_value_target(self.current_pulse) endpoint = self.send_request(self.set_joint_value_target_client, msg) pose_t, pose_r = endpoint.pose.position, endpoint.pose.orientation mat = common.xyz_quat_to_mat([pose_t.x, pose_t.y, pose_t.z], [pose_r.w, pose_r.x, pose_r.y, pose_r.z]) position, rpy = common.mat_to_xyz_euler(mat) self.current_position = [position, rpy] speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT) |
⑤ send_request Method
176 177 178 179 180 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
A general-purpose service call utility that sends a request and blocks until a response is received, ensuring reliable service communication such as configuring the large model or controlling robotic arm poses.
⑥ wakeup_callback Method
182 183 184 185 | def wakeup_callback(self, msg): if self.llm_result: self.get_logger().info('wakeup interrupt') self.interrupt = msg.data |
Subscriber callback for wake-up signals. When a wake-up signal is received such as via voice command, the interrupt flag is set to interrupt the current action.
⑦ llm_result_callbackMethod
187 188 | def llm_result_callback(self, msg): self.llm_result = msg.data |
Subscriber callback for large model results. Receives instructions generated by the large model including action and response and saves them in the llm_result variable for subsequent processing.
⑧ set_position Method
190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 | def set_position(self, duration, positions): msg = ServosPosition() msg.duration = float(duration) position_list = [] for i in positions: position = ServoPosition() position.id = i[0] position.position = float(i[1]) position_list.append(position) if i[0] != 1: self.current_pulse[self.id_dict[str(i[0])]] = 500 + float(i[1])/240*1000 else: self.current_pulse[self.id_dict[str(i[0])]] = 700 + float(i[1])/240*1000 msg.position = position_list msg.position_unit = "deg" self.joints_pub.publish(msg) # self.get_logger().info(f'{self.current_pulse}') |
Publishes servo control messages ServosPosition based on the input time and target position, updates the current servo positions, and synchronizes the robotic arm’s joint states.
⑨ move Method
214 215 216 217 218 219 220 221 222 223 224 225 226 | def move(self, x, y, z): self.current_position[0][0] += x self.current_position[0][1] += y self.current_position[0][2] += z self.get_logger().info(f'{self.current_position}') msg = set_pose_target(self.current_position[0], self.current_position[1][1], [-180.0, 180.0], 1.0) res = self.send_request(self.set_pose_target_client, msg) if res.pulse: servo_data = res.pulse self.get_logger().info(f'{servo_data}') #set_servo_position(self.joints_pub, 1, ((4, servo_data[3]), (3, servo_data[2]), (2, servo_data[1]), (1, servo_data[0]))) set_servo_position(self.joints_pub, 1, ((3, servo_data[3]), (4, servo_data[2]), (5, servo_data[1]), (6, servo_data[0]))) self.current_pulse[:-1] = servo_data |
⑩ play_audio_finish_callback Method
228 229 | def play_audio_finish_callback(self, msg): self.play_audio_finish = msg.data |
Callback function triggered after voice playback finishes. Re-enables voice wakeup functionality.
⑪ process Method
231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 | def process(self): while self.running: if self.llm_result: msg = String() if 'action' in self.llm_result: # If a corresponding action is returned, extract it and proceed with processing. 如果有对应的行为返回那么就提取处理 result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}') + 1]) # self.get_logger().info(str(result)) action_list = [] if 'action' in result: action_list = result['action'] if 'response' in result: response = result['response'] msg.data = response self.tts_text_pub.publish(msg) for i in action_list: if self.interrupt: self.get_logger().info('interrupt') break if 'set_position' in i: eval('self.' + i) elif 'move' in i: eval('self.' + i) else: eval(i) else: # No corresponding action, just respond. 没有对应的行为,只回答 response = self.llm_result msg.data = response self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) rclpy.shutdown() |
Continuously checks llm_result the output from the large model, parses the action list action and the response text response. It publishes the response text to the TTS node for speech playback and sequentially executes the actions, such as set_position to control the servos, move to move the robotic arm, and time.sleep for delays. After completing the actions and speech, the wake-up functionality is re-enabled to await the next command.
⑫ main Function
271 272 273 274 275 276 | def main(): node = LLMControlServo('llm_control_servo') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
Creates an instance of the LLMControlServo node, starts a multi-threaded executor to handle callbacks, runs the node, and manages interrupts such as keyboard termination, ensuring proper resource cleanup.
11.2.3 Color Sorting
Overview
When the program starts, the AI voice box will announce “I’m ready.” Then, you can say the designated wake word “Hello Hiwonder” to activate the AI voice box, and it will respond with “I’m here.” After activation, you can control the ArmPi Ultra by voice. For example, if you say “Take away the red block,” the terminal will display the recognized speech, the AI voice box will announce the generated response after processing, and the robot will execute the corresponding action.
By default, the program does not include the configuration of the Large Model-related API keys. Before activating features related to the Large AI Model, please refer to the section 11.2.1 Obtain and Configure the Large Model API Key” in this document to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
(3) Network Configuration
To configure the network using the mobile app, you may refer to the tutorial under the directory:1.ArmPi Ultra User Manual->1.4. App Control ->1.4.2 Connection Modes Overview.
Connect to the robot via VNC and modify the network configuration files as described in:1. ArmPi Ultra User Manual->1.6 Development Environment Setup and Configuration->1.6.3 LAN Mode Connection.
Operations
Click on
Enter the following command and press Enter to launch the color bolck sorting feature.
ros2 launch large_models llm_object_sorting.launch.py
For instance, when placing a colored block in front of the camera, we can say the command “Take away the red block.”
Upon receiving user input, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command, generate a language response, and execute a corresponding action based on the meaning of the command.
Project Outcome
Once the feature is activated, you can phrase your own commands. For example, saying “Take away the red block” will make the ArmPi Ultra automatically pick up the green block in its field of view and place it on the left side of the robotic arm.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) large_models_package_path = get_package_share_directory('large_models') # Immediately start object_sorting_launch (立即启动 object_sorting_launch) object_sorting_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/object_sorting_node.launch.py')), ) # Start large_models_launch and llm_object_sorting_node after 5 seconds (在5秒后启动 large_models_launch 和 llm_object_sorting_node) delayed_launch = TimerAction( period=5.0, # # Delay time of 5 seconds (延迟时间为5秒) actions=[ IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ), Node( package='large_models', executable='llm_object_sorting', output='screen', ), ] ) return [mode_arg, object_sorting_launch, # Immediate launch (立即启动) delayed_launch, # Launch after 5 seconds (5秒后启动) ] |
First loads the large_models package’s file launch/object_sorting_node.launch.py, which starts the basic nodes for object sorting, such as object recognition, classification logic, and other essential functions, and serves as the foundation of the system. Using TimerAction, it sets a 5-second delay to ensure that the basic nodes are fully initialized before launching dependent components. After the delay, it loads the large_models package’s file launch/start.launch.py to start the large-model service, passing in the mode parameter to control its operating mode. Finally, it starts the llm_object_sorting executable from the large_models package, which acts as a bridge between the large model and the object sorting logic, converting the model’s decisions into sorting action commands, with logs output to the screen.
44 45 46 47 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function=launch_setup) ]) |
③ Main Function
49 50 51 52 53 54 55 | if __name__ == '__main__': # Create a LaunchDescription object (创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 | PROMPT = ''' #Role You are an intelligent robot arm that needs to generate corresponding instructions based on the input content. ##Requirements and Restrictions 1. According to the input action content, find the corresponding instructions in the action function library and output the corresponding instructions. 2. Weave a concise (10 to 30 words), humorous and ever-changing feedback information for the action sequence to make the communication process interesting. 3. Directly output the json result, do not analyze, and do not output redundant content. 4. You can sort three colors of objects: red, green and blue 4. Format: {"action": "xx", "response": "xx"} ##Structural Requirements: - The "action" key carries a function name string array. When the corresponding action function cannot be found, action outputs "". - The "response" key is accompanied by a carefully conceived short reply, which perfectly meets the above word count and style requirements. ##Implementation principles - Before the final output, implement comprehensive verification to ensure that the response is not only formatted and interesting, but also has no omissions from the above specifications. ##Action function library - Pick up objects of different colors: color_sorting('red') ##Example Input: Take away the green block Output: {"action": "color_sorting('green')", "response": "Okay, start sorting green"} Input: Take away the blue block Output: {"action": "color_sorting('blue')", "response": "The blue block goes with you"} Input: Only keep the red, take the others Output: {"action": "color_sorting('blue','green')", "response": "Okay, execute now"} Input: Sorting color blocks Output: {"action": "color_sorting('red', 'blue','green')", "response": "No problem"} ''' |
87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 | class LLMColorSorting(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.action = [] self.llm_result = '' self.action_finish = False self.play_audio_finish = False # self.llm_result = '{"action": "color_sorting(\'blue\', \'red\', \'green\', \'tag_1\')", "response": "ok!"}' self.running = True timer_cb_group = ReentrantCallbackGroup() self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.enter_client = self.create_client(Trigger, 'object_sorting/enter') self.enter_client.wait_for_service() self.start_client = self.create_client(SetBool, 'object_sorting/enable_sorting') self.start_client.wait_for_service() self.set_target_client = self.create_client(SetStringBool, 'object_sorting/set_target') self.set_target_client.wait_for_service() self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
Sets up the node and configures state variables such as the action list and large-model results. Creates publishers for TTS text, subscribers for large-model results, TTS completion signals, and wake-up signals, as well as service clients for large-model configuration and sorting control. Finally, starts the initialization timer.
120 121 | def get_node_state(self, request, response): return response |
123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) self.send_request(self.enter_client, Trigger.Request()) speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT) |
Handles the node initialization process by canceling the timer, configuring large-model parameters such as model type and API keys, sending a request to enter the sorting service, starting the processing thread, and publishing a log to confirm that initialization is complete.
144 145 146 147 148 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
A general-purpose service call utility that sends a request and blocks until a response is received, ensuring reliable service communication such as large-model configuration and sorting control.
150 151 152 | def wakeup_callback(self, msg): if msg.data and self.llm_result: self.send_request(self.enter_client, Trigger.Request()) |
A subscription callback for the wakeup signal. When a wakeup signal is received, it resends the request to enter the sorting service and resets the sorting state.
⑦ llm_result_callback Method
154 155 | def llm_result_callback(self, msg): self.llm_result = msg.data |
⑧ play_audio_finish_callback Method
157 158 | def play_audio_finish_callback(self, msg): self.play_audio_finish = msg.data |
A subscription callback for the TTS completion signal. It sets the play_audio_finish flag to synchronize action execution with speech playback.
⑨ process Method
160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 | def process(self): while self.running: if self.llm_result: msg = String() if 'action' in self.llm_result: # If a corresponding action is returned, extract it and proceed with processing. 如果有对应的行为返回那么就提取处理 result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}') + 1]) # result = json.loads(self.llm_result) if 'action' in result: text = result['action'] # Use regular expressions to extract all strings inside. 使用正则表达式提取括号中的所有字符串 pattern = r"color_sorting\((['\"][^'\"]+['\"](?:\s*,\s*['\"][^'\"]+['\"])*)\)" # Use re.search to find the matching result. 使用re.search找到匹配的结果 match = re.search(pattern, text) # Extract the result. 提取结果 if match: # Retrieve all argument parts (the content inside the parentheses). 获取所有的参数部分(括号内的内容) params = match.group(1) # Use regular expressions to split the string arguments. 使用正则拆分出各个字符串参数 colors = re.findall(r"['\"]([^'\"]+)['\"]", params) self.get_logger().info(str(colors)) color_msg = SetStringBool.Request() for i in ['red', 'green', 'blue', 'tag_1', 'tag_2', 'tag_3']: color_msg.data_str = i if i in colors: color_msg.data_bool = True else: color_msg.data_bool = False self.send_request(self.set_target_client, color_msg) # Enable sorting. 开启分拣 start_msg = SetBool.Request() start_msg.data = True self.send_request(self.start_client, start_msg) if 'response' in result: msg.data = result['response'] else: # No corresponding action, just respond. 没有对应的行为,只回答 msg.data = self.llm_result self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) rclpy.shutdown() |
The main processing loop. It parses the large-model result, extracts color sorting actions such as color_sorting ‘red’, uses regex to determine the target color, sets the sorting goal, and starts the sorting process. It also publishes the TTS response, and once playback is complete, re-enables the wakeup function.
⑩ main Function
209 210 211 212 213 214 | def main(): node = LLMColorSorting('llm_color_sorting') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
The program entry point. It creates an LLMColorSorting instance, starts a multithreaded executor to handle callbacks, runs the node, and cleans up resources.
11.2.4 Waste Sorting
Overview
When the program starts, the AI voice box will announce “I’m ready.” Then, you can say the designated wake word “Hello Hiwonder” to activate the AI voice box, and it will respond with “I’m here.” After activation, you can control the ArmPi Ultra by voice. For example, if you say “Take away the banana peel,” the terminal will display the recognized speech, the AI voice box will announce the generated response after processing, and the robot will execute the corresponding action.
The default wake word for WonderEcho Pro is “Hello Hiwonder.” If you wish to change the wake-up word to “Xiaohuan Xiaohuan,” please refer to the directory: 10.Voice Control Course ->10.2 Firmware Flashing.
By default, the program does not include the configuration of the Large Model-related API keys. Before activating features related to the Large AI Model, please refer to the section “11.2.1 Obtain and Configure the Large Model API Key” in this document to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
To configure the network using the mobile app, you may refer to the tutorial under the directory:ArmPi Ultra User Manual->1.4 App Control ->1.4.2 Connection Modes Overview.
Connect to the robot via VNC and modify the network configuration files as described in:1.ArmPi Ultra User Manual->1.6 Development Environment Setup and Configuration->1.6.3 LAN Mode Connection.
Operations
Click on
Enter the following command and press Enter to launch the waste classification feature.
ros2 launch large_models llm_waste_classification.launch.py
For instance, place the corresponding waste tag in front of the camera and say the command “Take away the banana peel.”
Project Outcome
Once the feature is activated, you can phrase your own commands. For example, saying “Take away the banana peel” will instruct the ArmPi Ultra to automatically pick up the banana-peel trash block within its field of view and place it on the right side of the robotic arm.
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) large_models_package_path = get_package_share_directory('large_models') # Immediately start waste_classification_launch (立即启动 waste_classification_launch) waste_classification_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/waste_classification.launch.py')), ) # Start large_models_launch and llm_waste_classification_node after 5 seconds (在5秒后启动 large_models_launch 和 llm_waste_classification_node) delayed_launch = TimerAction( period=5.0, # Delay time of 5 seconds (延迟时间为5秒) actions=[ IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ), Node( package='large_models', executable='llm_waste_classification', output='screen', ), ] ) return [mode_arg, waste_classification_launch, # Immediate launch (立即启动) delayed_launch, # Launch after 5 seconds (5秒后启动) ] |
It first loads the waste_classification.launch.py file from the large_models package to start the waste classification basic nodes, such as waste recognition and category determination, which serve as the foundational components of the system. Next, it delays the startup of the large model and control nodes using TimerAction with a 5-second delay. This ensures the basic nodes are fully initialized before dependent components are launched. After the delay, it loads the start.launch.py file from the large_models package to start the large model service, passing the mode argument to control its operating mode, such as different classification logic or interaction modes. Finally, it launches the llm_waste_classification executable from the large_models package, which acts as the bridge between the large model and the waste classification logic. It converts the model’s decisions such as waste category determination into specific sorting action commands and outputs logs to the screen.
③ Main Function
62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 | PROMPT = ''' #Role You are an intelligent robot arm that needs to generate corresponding instructions based on the input content. ##Requirements and Restrictions 1. According to the input action content, find the corresponding instructions in the action function library and output the corresponding instructions. 2. Weave a concise (10 to 30 words), humorous and ever-changing feedback information for the action sequence to make the communication process interesting. 3. Garbage is divided into four categories: food waste (food_waste), hazardous waste (hazardous_waste), recyclable waste (recyclable_waste), and other waste (residual_waste). 4. Directly output the json result, do not analyze it, and do not output redundant content. 5. Format: {"action": "xx", "response": "xx"} ##Structural Requirements: - The "action" key carries a function name string array. When the corresponding action function cannot be found, action outputs "". - The "response" key is accompanied by a carefully conceived short reply, which perfectly meets the above word count and style requirements. ##Implementation Principles - Before final output, implement comprehensive verification to ensure that the response is not only formatted in compliance, but also interesting and without missing any of the above specifications. ##Action function library - Sort different garbage: garbage_classification('food_waste') - Stop: garbage_classification('') ##Example Input: Take away the food waste Output: {"action": "garbage_classification('food_waste')", "response": "Got it, I'll clean it up right away"} Input: Take away the banana peel Output: {"action": "garbage_classification('food_waste')", "response": "Okay, banana peels belong to food waste"} Input: Clean up hazardous waste Output: {"action": "garbage_classification('hazardous_waste')", "response": "Hazardous waste must be removed"} Input: Find recyclable waste Output: {"action": "garbage_classification('recyclable_waste')", "response": "This is not a problem for me"} Input: Sort other garbage Output: {"action": "garbage_classification('residual_waste')", "response": "Received, received"} Input: Take away the food waste first, then clean up the hazardous waste Output: {"action": "garbage_classification('food_waste','hazardous_waste')", "response": "Garbage cleanup, execute immediately"} Input: Only recyclable garbage is left, take away everything else Output: {"action": "garbage_classification('food_waste‘,'hazardous_waste',"residual_waste')", "response": "No problem"} ''' |
② Initialization
101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 | class LLMWasteClassification(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.action = [] self.llm_result = '' self.action_finish = False self.play_audio_finish = False # self.llm_result = '{"action": "garbage_classification(\'food_waste\', \'hazardous_waste\', \'residual_waste\', \'recyclable_waste\')", "response": "收到,我马上收拾"}' self.running = True timer_cb_group = ReentrantCallbackGroup() self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.enter_client = self.create_client(Trigger, 'waste_classification/enter') self.enter_client.wait_for_service() self.start_client = self.create_client(SetBool, 'waste_classification/enable_transport') self.start_client.wait_for_service() self.set_target_client = self.create_client(SetStringList, 'waste_classification/set_target') self.set_target_client.wait_for_service() self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
Sets up the node and configures state variables such as the action list and large-model results. Creates publishers for TTS text, subscribers for large-model results, TTS completion signals, and wake-up signals, as well as service clients for large-model configuration and waste classification control. Finally, starts the initialization timer.
138 139 | def get_node_state(self, request, response): return response |
Service callback function that returns an empty response, used to confirm that the node has completed initialization.
141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) self.send_request(self.enter_client, Trigger.Request()) speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT) |
Handles the node initialization process by canceling the timer, configuring large-model parameters such as model type and API keys, sending a request to enter the waste classification service, starting the processing thread, and publishing a log to confirm that initialization is complete.
163 164 165 166 167 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
169 170 171 | def wakeup_callback(self, msg): if msg.data and self.llm_result: self.send_request(self.enter_client, Trigger.Request()) |
A subscription callback for the wakeup signal. When a wakeup signal is received, it resends the request to enter the waste classification service and resets the sorting state.
173 174 | def llm_result_callback(self, msg): self.llm_result = msg.data |
176 177 | def play_audio_finish_callback(self, msg): self.play_audio_finish = msg.data |
⑨ process Method
179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 | def process(self): while self.running: if self.llm_result: msg = String() if 'action' in self.llm_result: # If there is a corresponding action returned, extract and process it (如果有对应的行为返回那么就提取处理) self.get_logger().info(self.llm_result) result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}') + 1]) if 'action' in result: self.get_logger().info(result['action']) text = result['action'] # Use regex to extract all strings within parentheses (使用正则表达式提取括号中的所有字符串) pattern = r"garbage_classification\((['\"][^'\"]+['\"](?:\s*,\s*['\"][^'\"]+['\"])*)\)" # Use re.search to find the match (使用re.search找到匹配的结果) match = re.search(pattern, text) # Extract the result (提取结果) if match: # Get all parameters inside the parentheses (获取所有的参数部分(括号内的内容)) params = match.group(1) # Use regex to split individual string parameters (使用正则拆分出各个字符串参数) objects = re.findall(r"['\"]([^'\"]+)['\"]", params) # self.get_logger().info(str(objects)) # Start recognition (开启识别) msgs = SetStringList.Request() msgs.data = objects res = self.send_request(self.set_target_client, msgs) if res.success: self.get_logger().info('\033[1;32m%s\033[0m' % 'set object success') else: self.get_logger().info('\033[1;32m%s\033[0m' % 'set object fail') start_msg = SetBool.Request() start_msg.data = True # Start sorting (开启分拣) self.send_request(self.start_client, start_msg) if 'response' in result: msg.data = result['response'] else: # If no corresponding action, only respond (没有对应的行为,只回答) msg.data = self.llm_result self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) rclpy.shutdown() |
Main processing loop that parses the large model results, extracts the waste classification action such as garbage_classification(‘food_waste’), uses regular expressions to identify the target waste type, sets the sorting target and starts the sorting process. It then publishes the TTS response and re-enables the wake-up function once execution is complete.
⑩ main Function
229 230 231 232 233 234 | def main(): node = LLMWasteClassification('llm_waste_classification') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
The program entry point. It creates an LLMWasteClassification instance, starts a multithreaded executor to handle callbacks, runs the node, and cleans up resources.
11.2.5 3D Object Sorting
Overview
Then, you can say the designated wake word “Hello Hiwonder” to activate the AI voice box, and it will respond with “I’m here.” After activation, you can control the ArmPi Ultra by voice. For example, if you say “Take the cylinder away,” the terminal will display the recognized speech, the AI voice box will announce the generated response after processing, and the robot will execute the corresponding action.
To configure the network using the mobile app, you may refer to the tutorial under the directory:1. ArmPi Ultra User Manual->1. 4 App Control->1.4.2 Connection Modes Overview.
Operations
Click on
Enter the following command and press Enter to launch the 3D object sorting feature.
ros2 launch large_models llm_3d_object_sorting.launch.py
For example, place the object in front of the camera and say the command “Take the cylinder away.”
Project Outcome
Once the feature is activated, you can phrase your own commands. For example, saying “Take the cylinder away” will make the ArmPi Ultra automatically pick up the cylinder block in its field of view and place it on the left side of the robotic arm.
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) # Get package path (获取包路径) large_models_package_path = get_package_share_directory('large_models') object_sorting_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/3d_object_sorting.launch.py')), ) # Start large_models_launch and llm_3d_object_sorting_node after 5 seconds (在5秒后启动 large_models_launch 和 llm_3d_object_sorting_node) delayed_launch = TimerAction( period=5.0, # Delay time of 5 seconds (延迟时间为5秒) actions=[ IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ), Node( package='large_models', executable='llm_3d_object_sorting', output='screen', ), ] ) return [mode_arg, object_sorting_launch, # Immediate launch (立即启动 object_sorting_launch) delayed_launch, # Delayed launch (启动后延迟的部分) ] |
It first loads the launch/3d_object_sorting.launch.py file from the large_models package to start the core nodes for 3D object sorting, such as 3D object recognition, spatial localization, and category determination, which serve as the system’s foundation and provide object information in three-dimensional space. Delayed startup of the large model and control nodes is achieved by setting a 5-second delay with TimerAction. This ensures that the basic nodes such as the 3D recognition module have completed initialization and are stably outputting data before launching the dependent upper-level components. After that, the system loads the launch/start.launch.py file from the large_models package to start the large model service, passing in the mode parameter to control its operating mode, such as different 3D sorting strategies or interaction methods. Finally, the llm_3d_object_sorting executable from the large_models package is launched. This node acts as the bridge between the large model and the 3D object sorting logic, converting the model’s decisions, such as 3D-based grasping strategies, into specific robotic arm commands, with logs output to the terminal.
③ Main Function
54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 | PROMPT = ''' #Role You are an intelligent robot arm that needs to generate corresponding instructions based on the input content. ##Requirements and Restrictions 1. According to the input action content, find the corresponding instructions in the action function library and output the corresponding instructions. 2. Weave a concise (10 to 30 words), humorous and ever-changing feedback information for the action sequence to make the communication process interesting. 3. Objects are divided into three categories: cylinder, sphere, and cuboid. 4. Directly output the json result, do not analyze it, and do not output redundant content. 5. Format: {"action": "xx", "response": "xx"} ##Structural Requirements: - The "action" key carries a function name string array. When the corresponding action function cannot be found, action outputs "". - The "response" key is accompanied by a carefully conceived short reply, which perfectly meets the above word count and style requirements. ##Implementation Principles - Before final output, implement comprehensive verification to ensure that the response is not only formatted in compliance, but also interesting and without missing any of the above specifications. ##Action function library - Sorting objects: object_sorting('cylinder') ##Example Input: Sorting cylinders Output: {"action": "object_sorting('cylinder')", "response": "OK, start sorting cylinders"} Input: Take the cuboid away Output: {"action": "object_sorting('cuboid')", "response": "The cuboid is gone"} Input: Only keep the sphere and take the others away Output: {"action": "object_sorting('cylinder','cuboid')", "response": "OK, execute now"} Input: Sorting objects Output: {"action": "object_sorting('cylinder', 'cuboid','sphere')", "response": "No problem"} ''' |
② Initialization
86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 | class LLMObjectSorting(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.action = [] self.llm_result = '' self.action_finish = False self.play_audio_finish = False # self.llm_result = '{"action": "object_sorting(\'cylinder\', \'cuboid\', \'sphere\')", "response": "收到,我马上收拾"}' self.running = True timer_cb_group = ReentrantCallbackGroup() self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'vocal_detect/wakeup', self.wakeup_callback, 1) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.enter_client = self.create_client(Trigger, 'shape_recognition/enter') self.enter_client.wait_for_service() self.start_client = self.create_client(SetBool, 'shape_recognition/set_running') self.start_client.wait_for_service() self.set_target_client = self.create_client(SetStringList, 'shape_recognition/set_shape') self.set_target_client.wait_for_service() self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
Sets up the node and configures state variables such as the action list and large-model results. Creates publishers for TTS text, subscribers for large-model results, TTS completion signals, and wake-up signals, as well as service clients for large-model configuration and object sorting control. Finally, starts the initialization timer.
124 125 | def get_node_state(self, request, response): return response |
127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model = llm_model msg.model_type = 'llm' msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) self.send_request(self.enter_client, Trigger.Request()) speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT) |
Handles the node initialization process by canceling the timer, configuring large-model parameters such as model type and API keys, sending a request to enter the object sorting service, starting the processing thread, and publishing a log to confirm that initialization is complete.
150 151 152 153 154 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
156 157 158 | def wakeup_callback(self, msg): if msg.data and self.llm_result: self.send_request(self.enter_client, Trigger.Request()) |
A subscription callback for the wakeup signal. When a wakeup signal is received, it resends the request to enter the object sorting service and resets the sorting state.
160 161 | def llm_result_callback(self, msg): self.llm_result = msg.data |
⑧ Play_audio_finish_callback Method
163 164 | def play_audio_finish_callback(self, msg): self.play_audio_finish = msg.data |
⑨ process Method
166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 | def process(self): while self.running: if self.llm_result: msg = String() if 'action' in self.llm_result: # If there is a corresponding action returned, extract and handle it. 如果有对应的行为返回那么就提取处理 result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}') + 1]) if 'action' in result: text = result['action'] # Use regular expressions to extract all strings inside. 使用正则表达式提取括号中的所有字符串 pattern = r"object_sorting\((['\"][^'\"]+['\"](?:\s*,\s*['\"][^'\"]+['\"])*)\)" # Use re.search to find the matching result. 使用re.search找到匹配的结果 match = re.search(pattern, text) # Extract the result. 提取结果 if match: # Retrieve all argument parts (the content inside the parentheses). 获取所有的参数部分(括号内的内容) params = match.group(1) # Use regular expressions to split the string arguments. 使用正则拆分出各个字符串参数 objects = re.findall(r"['\"]([^'\"]+)['\"]", params) # self.get_logger().info(str(objects)) # Enable recognition. 开启识别 msgs = SetStringList.Request() msgs.data = objects res = self.send_request(self.set_target_client, msgs) if res.success: self.get_logger().info('\033[1;32m%s\033[0m' % 'set object success') else: self.get_logger().info('\033[1;32m%s\033[0m' % 'set object fail') start_msg = SetBool.Request() start_msg.data = True # Enable sorting. 开启分拣 self.send_request(self.start_client, start_msg) if 'response' in result: msg.data = result['response'] else: # No corresponding action, just respond. 没有对应的行为,只回答 msg.data = self.llm_result self.tts_text_pub.publish(msg) self.action_finish = True self.llm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) rclpy.shutdown() |
Main processing loop that parses the large model output, extracts object sorting actions such as object_sorting(‘cylinder’), uses regular expressions to identify the target object type, sets the sorting target and starts the sorting process. It then publishes the TTS response and re-enables the wake-up function once execution is complete.
⑩ main Function
214 215 216 217 218 219 | def main(): node = LLMObjectSorting('llm_object_sorting') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
The program entry point. It creates an LLMObjectSorting instance, starts a multithreaded executor to handle callbacks, runs the node, and cleans up resources.
11.3 Embodied AI Applications
11.3.1 Overview of Embodied Intelligence
Embodied Intelligence represents a key branch of artificial intelligence that emphasizes learning and decision-making through the interaction between a physical entity and its environment. At its core lies the principle that intelligence emerges from the dynamic interplay between an agent’s physical embodiment and its environment. This approach moves beyond the limitations of traditional AI, which often relies solely on static data. Embodied intelligence has found broad applications across industries such as manufacturing, healthcare, service, education, and military.
Multimodal Information Fusion
An important branch of embodied intelligence is multimodal information fusion, which refers to the effective integration of data from different modalities—such as text, images, and speech—to produce a more comprehensive and accurate representation of information. This process is especially critical in artificial intelligence, as real-world data is inherently multimodal. Relying on a single modality often fails to provide sufficient context or detail. Multimodal fusion aims to enhance model performance and robustness by leveraging the complementary strengths of multiple data sources.
Several common approaches to multimodal information fusion include the following:
Early Fusion: Combines data from different modalities at an early stage of processing. This typically occurs at the input level, where raw data is aligned and transformed into a shared space to create a richer, more expressive representation. For example, image and speech data can be concatenated directly and fed into a neural network.
Late Fusion: Integrates data from multiple modalities at intermediate or output stages of the model. This approach allows each modality to be processed independently using specialized algorithms, making it easier to add or replace modalities in the future. For instance, results from image recognition and text analysis can be combined to support final decision-making.
Hybrid Fusion: Leverages both early and late fusion techniques by performing integration at multiple stages. This method takes advantage of modality complementarity and can improve both performance and model robustness.
Feature-Level Fusion: Involves extracting features from each modality and mapping them into a unified feature vector, which is then passed to a classifier for decision-making. Fusion occurs during the feature extraction phase, enabling the model to learn correlations across modalities.
Decision-Level Fusion: Merges outputs from individual modality-specific decisions to produce the final outcome. This technique offers strong noise resistance and places fewer demands on sensor types or quality, though it may result in some loss of information.
Deep Fusion: Takes place during feature extraction, where multimodal data is blended in the feature space to generate fused features that can compensate for missing or weak signals from any single modality. These fused features are then used for classification or regression tasks during prediction.
Multimodal information fusion holds not only theoretical significance but also substantial practical value. It has been widely applied in fields such as autonomous driving, medical image analysis, and human-computer interaction, where it has significantly improved system performance and reliability.
11.3.2 Obtain and Configure the Large Model API Key
This section requires registering on the official OpenAI website and obtaining an API key for accessing large language models.
Register and Deploy OpenAI Account
Copy and open the following URL: https://platform.openai.com/docs/overview
Register and log in using a Google, Microsoft, or Apple account, as prompted.
After logging in, click the Settings button, then go to Billing, and click Payment methods to add a payment method. Recharge your account to purchase tokens as needed.
Once your account is set up, go to the API Keys section and click Create new key. Follow the instructions to generate a new API key and save it securely for later use.
The creation and deployment of the large model have been completed, and this API will be used in the following lessons.
Register and Deploy OpenRouter Account
Copy and open the following URL: https://openrouter.ai/ and click “Sign in”, and register or sign in using Google or another available account.
After logging in, click the icon in the top-right corner, then select “Credits” to add a payment method.
Create an API key. Go to “API Keys”, then click “Create Key”. Follow the prompts to generate a key. Save the API key securely for later use.
API Configuration
In the command-line terminal, enter the following command to navigate to the directory where the large model keys are configured.
cd ~/ros2_ws/src/large_models/large_models
Next, open the configuration file with the following command.
vim config.py
Once the file is open, you need to configure the OpenAI and OpenRouter keys by filling them into the parameters llm_api_key and vllm_api_key, respectively.
For example, copy the keys you created in this chapter and paste them into the corresponding fields. Place the cursor between the quotation marks, right-click, and select Paste.
Note: keys from different large models cannot be mixed, otherwise the functions may fail to work properly.
After pasting, press Esc, then enter the following command and press Enter to save the file:
11.3.3 Real-time Detection
The large model used in this lesson operates online, requiring a stable network connection for the main controller in use. For better stability, it is recommended to use a wired network connection.
Overview
When the program starts, the AI voice box announces “I’m ready.”
Then, you can say the wake word “Hello Hiwonder” to activate the AI voice box, which will respond with “I’m here.” Once activated, you can control the ArmPi Ultra using voice commands. For example, you can say “What do you see.” After receiving the command, the terminal will print the recognized image content, and the AI voice box will speak out the generated response.
(1) Confirm WonderEcho Pro Firmware
The default wake word for WonderEcho Pro is “Hello Hiwonder.” If you wish to change the wake-up word to “Xiaohuan Xiaohuan,” please refer to the directory: 10. Voice Control Course->10.2 Firmware Flashing.
If you have previously flashed a different firmware, such as the one using the wake word “Xiaohuan Xiaohuan,” you must use the corresponding wake word.
The examples in this course will assume the default factory wake word: “Hello Hiwonder.”
(2) Configuring the Large Model API-KEY
The large model used in this lesson is an online model, so network access is required before getting started. Please prepare an Ethernet cable to connect the robot to the network, or switch the robot to LAN mode.
The robot must be connected to the Internet during this feature, either in STA (LAN) mode or AP (direct connection) mode via Ethernet. There are two methods available for configuring the network:
To configure the network using the mobile app, you may refer to the tutorial under the directory:1. ArmPi Ultra User Manual->1.4 App Control->1.4.2 Connection Modes Overview.
Connect to the robot via VNC and modify the network configuration files as described in:1. ArmPi Ultra User Manual ->1.6 Development Environment Setup and Configuration ->1.6.3 LAN Mode Connection.
Operations
Double-click on
to launch the command bar, enter the command, and press Enter to disable the auto-start service.Enter the command to disable the auto-start service of the mobile app.
Enter the following command and press Enter to launch the real-time detection feature.
ros2 launch large_models vllm_with_camera.launch.py
When the terminal displays output shown in the figure and the AI voice box announces “I’m ready”, the voice device has completed initialization. Then, you can say the wake words: “Hello Hiwonder”.
For example, place the object you want to identify in front of the camera and say the command “What do you see.”
The response is automatically generated by the model. While the semantic content is accurate, the wording and structure may vary due to randomness in language generation.
When the terminal shows the output shown in the figure indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 4 by speaking the wake words again.
To exit the feature, press Ctrl + C in the terminal. If the feature does not exit immediately, press Ctrl + C multiple times.
Project Outcome
Once the feature is activated, you can phrase your own commands. For example, when you say “What do you see” to ArmPi Ultra, it will automatically analyze the scene within its field of view, think about what it sees, and describe the scene content in detail.
Program Brief Analysis
(1) launch File Analysis
① Defining the launch_setup Function
9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) peripherals_package_path = get_package_share_directory('peripherals') sdk_package_path = get_package_share_directory('sdk') large_models_package_path = get_package_share_directory('large_models') # Launch depth_camera_launch (启动 depth_camera_launch) depth_camera_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(peripherals_package_path, 'launch/depth_camera.launch.py')), ) # Start sdk_launch and large_models_launch after 5 seconds (在5秒后启动 sdk_launch 和 large_models_launch) delayed_launch = TimerAction( period=5.0, # Delay time of 5 seconds (延迟时间为5秒) actions=[ IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(sdk_package_path, 'launch/armpi_ultra.launch.py')), ), IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ), ] ) vllm_with_camera_node = Node( package='large_models', executable='vllm_with_camera', output='screen', ) return [depth_camera_launch, # Immediate launch (立即启动 depth_camera_launch) delayed_launch, # Delayed launch for sdk_launch and large_models_launch (启动延迟后的 sdk_launch 和 large_models_launch) vllm_with_camera_node, ] |
First, loads the peripherals package’s launch/depth_camera.launch.py file to start the depth camera node, which provides RGB images and depth data as the foundation for visual input. Next, delays the startup of core services by 5 seconds using TimerAction. This ensures the depth camera has fully initialized and is stably outputting data before dependent components are launched. Then, loads the sdk package’s launch/armpi_ultra.launch.py file to start the ArmPi Ultra’s low-level control services such as servo drivers and kinematics, providing hardware support for subsequent motion execution. After that, loads the large_models package’s launch/start.launch.py file to start the large model service, passing the mode parameter to control its operation, such as different reasoning logic and interaction modes. Finally, starts the Vision-Language Large Model node by declaring vllm_with_camera_node and launching the vllm_with_camera executable from the large_models package. Its core function is to combine depth camera data with large model capabilities, such as visual question answering and scene understanding, to realize the closed loop of “visual input to large model decision to robotic arm interaction.” Logs will be output to the terminal.
② generate_launch_description Function
50 51 52 53 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function=launch_setup) ]) |
Creates and returns a LaunchDescription object, calling launch_setup via OpaqueFunction as the standard entry point for the ROS 2 launch file.
③ Main Function
55 56 57 58 59 60 61 | if __name__ == '__main__': # Create a LaunchDescription object (创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
Creates a LaunchDescription object and a LaunchService service. The launch description is added to the service and executed, enabling the startup of the entire system manually.
Python File Analysis
① Import the Necessary Libraries
4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 | import cv2 import time import queue import rclpy import threading import numpy as np import os from rclpy.node import Node from sensor_msgs.msg import Image from std_msgs.msg import String, Bool from std_srvs.srv import Trigger, SetBool, Empty from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup from speech import speech from large_models.config import * from large_models_msgs.srv import SetString, SetModel from servo_controller.bus_servo_control import set_servo_position from servo_controller_msgs.msg import ServosPosition from cv_bridge import CvBridge |
servo_controller_msgs.msg.ServosPosition: custom message type for controlling servo motors.
servo_controller.bus_servo_control.set_servo_position**:** function used to set the servo angle.
speech: module related to large model voice interaction.
large_models_msgs.srv: custom service types for large models.
large_models.config: configuration file for large models.
② VLLMWithCamera Class
32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 | class VLLMWithCamera(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.image_queue = queue.Queue(maxsize=2) self.vllm_result = '' self.running = True self.bridge = CvBridge() timer_cb_group = ReentrantCallbackGroup() self.joints_pub = self.create_publisher(ServosPosition, 'servo_controller', 1) self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(Image, 'depth_cam/rgb/image_raw', self.image_callback, 1) self.create_subscription(String, 'agent_process/result', self.vllm_result_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_callback, 1, callback_group=timer_cb_group) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
Initializes the node and sets up core components, creating an image queue image_queue to cache camera frames and defining state variables such as vllm_result to store outputs from the large model. Initializes ROS communication, including publishers for servo control and TTS text, subscribers for RGB images, large model results, and TTS playback completion signals, and service clients for configuring the large model, wake-up control, etc. Starts the initialization timer, which triggers init_process to complete the remaining setup.
③ get_node_state Method
54 55 | def get_node_state(self, request, response): return response |
④ init_process Method
57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model_type = 'vllm' if os.environ['ASR_LANGUAGE'] == 'Chinese': msg.model = stepfun_vllm_model msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url else: msg.model = vllm_model msg.api_key = vllm_api_key msg.base_url = vllm_base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) set_servo_position(self.joints_pub, 1.0, ((6, 500), (5, 600), (4, 825), (3, 233), (2, 500), (1, 300))) speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') |
Node initialization workflow that cancels the initialization timer, configures large model parameters by selecting the model and API keys based on language settings, and sets up prompts. Resets the robotic arm servos to their default positions, plays the startup audio, and starts the main processing thread process. Creates the initialization-complete service and outputs a startup log.
⑤ send_request Method
79 80 81 82 83 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
A general service call utility that sends a request and blocks until the result is returned, ensuring service communication is complete, such as configuring the large model, enabling wake-up.
⑥ vllm_result_callback Method
85 86 | def vllm_result_callback(self, msg): self.vllm_result = msg.data |
Subscriber callback for large model results, receives model outputs and saves them to vllm_result for subsequent processing.
⑦ process Method
88 89 90 91 92 93 94 95 96 97 98 | def process(self): while self.running: image = self.image_queue.get(block=True) if self.vllm_result: msg = String() msg.data = self.vllm_result self.tts_text_pub.publish(msg) self.vllm_result = '' cv2.imshow('image', image) cv2.waitKey(1) cv2.destroyAllWindows() |
The main processing loop that fetches camera frames from the queue and displays them, while monitoring large model results in real time. When a model result is received, it is published to the TTS node for voice playback, and the result cache is cleared. The loop runs until the node stops, and finally closes the image window.
⑧ play_audio_callback Method
100 101 102 103 104 | def play_audio_callback(self, msg): if msg.data: msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) |
TTS playback completion callback that re-enables the wake-up functionality and waits for the next command input.
⑨ image_callback Method
106 107 108 109 110 111 112 113 114 115 | def image_callback(self, ros_image): try: cv_image = self.bridge.imgmsg_to_cv2(ros_image, desired_encoding='bgr8') except Exception as e: self.get_logger().error(f"图像转换出错:{e}") return if self.image_queue.full(): self.image_queue.get() self.image_queue.put(cv_image) |
RGB image subscriber callback that converts ROS image messages into OpenCV format and stores them in the image queue. The oldest frame is discarded if the queue is full.
⑩ main Function
116 117 118 119 120 121 | def main(): node = VLLMWithCamera('vllm_with_camera') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
The program entry point. It creates an VLLMWithCamera instance, starts a multithreaded executor to handle callbacks, runs the node, and cleans up resources.
11.3.4 Vision Tracking
Overview
Then, you can say the designated wake word “Hello Hiwonder” to activate the AI voice box, and it will respond with “I’m here.” After activation, you can control the ArmPi Ultra by voice. For example, if you say “Follow the purple ball,” the terminal will display the recognized speech, the AI voice box will announce the generated response after processing, and the robot will execute the corresponding action.
The default wake word for WonderEcho Pro is “Hello Hiwonder.” If you wish to change the wake-up word to “Xiaohuan Xiaohuan,” please refer to the directory: 10. Voice Control Course ->10.2 Firmware Flashing.
By default, the program does not include the configuration of the Large Model-related API keys. Before activating features related to the Large AI Model, please refer to the section “11.3.2 Obtain and Configure the Large Model API Key” in this document to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
Note: The large model used in this lesson is an online model, so network access is required before getting started. Please prepare an Ethernet cable to connect the robot to the network, or switch the robot to LAN mode.
Connect to the robot via VNC and modify the network configuration files as described in:1. ArmPi Ultra User Manual \6. Development Environment Setup and Configuration \6.3 LAN Mode Connection.
Operations
Command input is case-sensitive and space-sensitive.
The robot must be connected to the Internet, either in STA (LAN) mode or AP (direct connection) mode via Ethernet.
Double-click on
Enter the following command and press Enter to launch the vision tracking feature.
ros2 launch large_models vllm_track.launch.py
When the terminal displays the corresponding output shown in the figure and the device responds with “I’m here”, it indicates successful activation. The system will begin recording your voice command.
Upon successful recognition by the speech recognition service of cloud-based large speech model, the parsed command will be displayed under the publish_asr_result output in the terminal.
Upon receiving user input shown in the figure, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command, generate a language response, and execute a corresponding action based on the meaning of the command.
Project Outcome
Once the feature is activated, you can phrase your own commands. For example, saying “Follow the purple ball” will make the ArmPi Ultra’s robotic arm automatically track the purple ball within its field of view. The ball will be highlighted on the screen, and tracking will stop once it is positioned at the center of the frame.
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) peripherals_package_path = get_package_share_directory('peripherals') sdk_package_path = get_package_share_directory('sdk') large_models_package_path = get_package_share_directory('large_models') # Immediately launch depth_camera_launch (立即启动 depth_camera_launch) depth_camera_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(peripherals_package_path, 'launch/depth_camera.launch.py')), ) # Launch sdk_launch, large_models_launch, vllm_track_node, and calibrate_rqt_reconfigure_node after 5 seconds (在5秒后启动 sdk_launch、large_models_launch、vllm_track_node 和 calibrate_rqt_reconfigure_node) delayed_launch = TimerAction( period=5.0, # Delay time of 5 seconds (延迟时间为5秒) actions=[ IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(sdk_package_path, 'launch/armpi_ultra.launch.py')), ), IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ), Node( package='large_models', executable='vllm_track', output='screen', ), ] ) return [mode_arg, depth_camera_launch, # Immediate launch (立即启动) delayed_launch, # Launch other components after 5 seconds (5秒后启动其他部分) ] |
Starts the depth camera by loading the peripherals package’s launch/depth_camera.launch.py file. This launches the depth camera node, providing RGB images and depth data as the foundational input for visual tracking. Delays the startup of the core services and tracking node by setting a 5-second TimerAction. This ensures that the depth camera has completed initialization and is outputting stable data before launching the dependent core components. Then loads the sdk package’s launch/armpi_ultra.launch.py file to start the ArmPi Ultra’s low-level control services, such as servo drivers and kinematics computation, providing hardware support for target tracking and manipulation. After that, loads the large_models package’s launch/start.launch.py file to start the large model service, passing the mode parameter to control its operating mode, such as different target recognition logic or tracking strategies. Launches the vllm_track executable from the large_models package as the core visual tracking node. It combines depth camera data with the large model’s capabilities to perform target tracking, including real-time localization and dynamic following, with logs displayed on the screen.
③ Main Function
(2) Python File Analysis
5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 | import cv2 import json import time import queue import rclpy import threading import PIL.Image import numpy as np import sdk.fps as fps from sdk import common from cv_bridge import CvBridge from rclpy.node import Node from sensor_msgs.msg import Image from std_msgs.msg import String, Float32, Bool from std_srvs.srv import Trigger, SetBool, Empty from rcl_interfaces.msg import SetParametersResult from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup from speech import speech from large_models.config import * from large_models_msgs.srv import SetString, SetModel from large_models.track_anything import ObjectTracker from kinematics_msgs.srv import SetRobotPose, SetJointValue from kinematics.kinematics_control import set_pose_target, set_joint_value_target from servo_controller.bus_servo_control import set_servo_position from servo_controller_msgs.msg import ServosPosition, ServoPosition |
PIL.Image: Part of the Pillow library, used for handling image files.
sdk.fps as fps: Used to calculate and display the frame rate (FPS).
from kinematics_msgs.srv import SetRobotPose: Imports the service type for setting the robot’s pose.
from kinematics.kinematics_control import set_pose_target: Imports the function to set the target pose.
large_models.track_anything: A class used for object tracking.
② PROMPT String
48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 | PROMPT = ''' **Role: You are an expert in image recognition who precisely detects and locates objects in images. **Task: 1.Instruction Parsing: You will receive a sentence from the user. Extract only the relevant "object name" mentioned in the sentence. The object name must be in English. Note: Do not output any object that is not mentioned. 2.Image Analysis: You will be provided with an image. Locate the object corresponding to the extracted "object name" in the image. Determine its bounding box by finding the pixel coordinates of the object's top-left and bottom-right corners. Note: Only output the bounding box for the mentioned object. 3.Orientation Awareness: Ensure you fully understand the spatial orientation of the object in the image. **Output Format(Your final output must be a single JSON object with the following structure. The coordinates (xmin, ymin, xmax, ymax) must be normalized to the range [0, 1]): { "object": "object_name_in_English", "xyxy": [xmin, ymin, xmax, ymax] } **Output Example: { "object": "red", "xyxy": [0.1, 0.3, 0.4, 0.6] } **Important Instructions: Do not include any additional text, explanations, or thought processes. Output only the final JSON result as specified above. Do not output any extra keys or comments. ''' |
Defines a prompt string (PROMPT) used to guide how user commands and image data are processed. It specifies the recognition task logic and expected output format.
③ VLLMTrack Class
87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 | class VLLMTrack(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.fps = fps.FPS() # Frame rate counter (帧率统计器) self.image_queue = queue.Queue(maxsize=2) self.vllm_result = '' # self.vllm_result = '''json{"object":"红色方块", "xyxy":[521, 508, 637, 683]}''' self.running = True self.bridge = CvBridge() self.data = [] self.start_track = False self.action_finish = False self.play_audio_finish = False self.language = os.environ["ASR_LANGUAGE"] self.track = ObjectTracker() timer_cb_group = ReentrantCallbackGroup() self.client = speech.OpenAIAPI(api_key, base_url) self.joints_pub = self.create_publisher(ServosPosition, 'servo_controller', 1) self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(Image, 'depth_cam/rgb/image_raw', self.image_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.create_subscription(String, 'agent_process/result', self.vllm_result_callback, 1) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.ik_client = self.create_client(SetRobotPose, 'kinematics/set_pose_target') self.ik_client.wait_for_service() self.fk_client = self.create_client(SetJointValue, 'kinematics/set_joint_value_target') self.fk_client.wait_for_service() # Define PID parameters (定义 PID 参数) # 0.07, 0, 0.001 self.pid_params = { 'kp1': 0.065, 'ki1': 0.0, 'kd1': 0.001, 'kp2': 0.00004, 'ki2': 0.0, 'kd2': 0.0, 'kp3': 0.05, 'ki3': 0.0, 'kd3': 0.0 } # Dynamically declare parameters (动态声明参数) for param_name, default_value in self.pid_params.items(): self.declare_parameter(param_name, default_value) self.pid_params[param_name] = self.get_parameter(param_name).value self.track.update_pid([self.pid_params['kp1'], self.pid_params['ki1'], self.pid_params['kd1']], [self.pid_params['kp2'], self.pid_params['ki2'], self.pid_params['kd2']], [self.pid_params['kp3'], self.pid_params['ki3'], self.pid_params['kd3']]) # Callback function for dynamic parameter updates (动态更新时的回调函数) self.add_on_set_parameters_callback(self.on_parameter_update) self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
Initializes the node, sets up state variables such as the image queue and tracking status, configures ROS communication components, including publishers, subscribers, and service clients, initializes PID parameters and the object tracker, and starts the initialization timer.
④ on_parameter_update Method
144 145 146 147 148 149 150 151 152 153 154 155 | def on_parameter_update(self, params): """参数更新回调""" for param in params: if param.name in self.pid_params.keys(): self.pid_params[param.name] = param.value self.get_logger().info(f'PID parameters updated: {self.pid_params}') # Update PID parameters (更新 PID 参数) self.track.update_pid([self.pid_params['kp1'], self.pid_params['ki1'], self.pid_params['kd1']], [self.pid_params['kp2'], self.pid_params['ki2'], self.pid_params['kd2']], [self.pid_params['kp3'], self.pid_params['ki3'], self.pid_params['kd3']]) return SetParametersResult(successful=True) |
Callback for parameter updates. Dynamically updates PID parameters and synchronizes them to the tracker when they are modified.
⑤ create_update_callback Method
157 158 159 160 161 162 163 164 165 166 | def create_update_callback(self, param_name): """Generate dynamic update callback (生成动态更新回调)""" def update_param(msg): new_value = msg.data self.pid_params[param_name] = new_value self.set_parameters([Parameter(param_name, Parameter.Type.DOUBLE, new_value)]) self.get_logger().info(f'Updated {param_name}: {new_value}') # Update PID parameters (更新 PID 参数) return update_param |
Generates a dynamic update callback for specific PID parameters to allow real-time tuning.
⑥ get_node_state Method
168 169 | def get_node_state(self, request, response): return response |
Service callback that returns the node status, used for confirming initialization completion.
⑦ init_process Method
171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model_type = 'vllm' if self.language == 'Chinese': msg.model = stepfun_vllm_model msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url else: msg.api_key = vllm_api_key msg.base_url = vllm_base_url msg.model = vllm_model self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) z = 0.15 msg = set_pose_target([0.137, 0.0, z], 30, [-90.0, 90.0], 1.0) res = self.send_request(self.ik_client, msg) if res.pulse: servo_data = res.pulse # self.get_logger().info(str(servo_data)) set_servo_position(self.joints_pub, 1.5, ((1, 300), (2, 500), (3, servo_data[3]), (4, servo_data[2]), (5, servo_data[1]), (6, servo_data[0]))) time.sleep(1.8) self.track.set_init_param(servo_data[3], servo_data[0], z) speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() threading.Thread(target=self.track_thread, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') |
Node initialization procedure that configures large model parameters, moves the robotic arm to its initial pose, plays the startup audio, starts the main processing and tracking threads, and creates the initialization complete service.
⑧ send_request Method
205 206 207 208 209 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
A general service call utility that sends a request and blocks until the result is returned.
⑨ wakeup_callback Method
211 212 213 214 215 216 217 218 219 | def wakeup_callback(self, msg): if msg.data and self.vllm_result: self.get_logger().info('wakeup interrupt') self.track.stop() self.stop = True elif msg.data and not self.stop: self.get_logger().info('wakeup interrupt') self.track.stop() self.stop = True |
Subscriber callback for wakeup signals, handles interrupt signals, and stops object tracking.
⑩ vllm_result_callback Method
221 222 | def vllm_result_callback(self, msg): self.vllm_result = msg.data |
Subscriber callback for large model outputs, receiving object coordinate information.
⑪ play_audio_finish_callback Method
224 225 | def play_audio_finish_callback(self, msg): self.play_audio_finish = msg.data |
Callback for TTS playback completion signals, updating the audio playback status.
⑫ process Method
227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 | def process(self): box = '' while self.running: image = self.image_queue.get(block=True) if self.vllm_result: try: self.vllm_result = json.loads(self.vllm_result) box = self.vllm_result['xyxy'] box = self.client.data_process(box, 640, 400) box = [box[0], box[1], box[2] - box[0], box[3] - box[1]] self.get_logger().info('box: %s' % str(box)) self.track.set_track_target(box, image) self.start_track = True speech.play_audio(start_track_audio_path, block=False) except (ValueError, TypeError) as e: self.start_track = False msg = String() msg.data = self.vllm_result self.tts_text_pub.publish(msg) # speech.play_audio(track_fail_audio_path, block=False) # self.get_logger().info(e) self.vllm_result = '' msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) if self.start_track: self.data = self.track.track(image) self.fps.update() self.fps.show_fps(image) cv2.imshow('image', image) cv2.waitKey(1) cv2.destroyAllWindows() |
The main processing loop that retrieves camera images from the queue, parses large model results to obtain object bounding boxes, initiates object tracking, and displays images in real time.
⑬ track_thread Method
261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 | def track_thread(self): while self.running: if self.data: y, z, joint4 = self.data[0], self.data[1], self.data[2] if z > 0.23 or joint4 >= 391: msg = set_pose_target([0.167, 0.0, z], 0.0, [-180.0, 180.0], 1.0) res = self.send_request(self.ik_client, msg) if res.pulse: servo_data = res.pulse set_servo_position(self.joints_pub, 0.0, ( (1, 500), (2, 500), (3, servo_data[3]), (4, servo_data[2]), (5, servo_data[1]), (6, int(y)))) else: set_servo_position(self.joints_pub, 0.02, ((6, int(y)),)) else: set_servo_position(self.joints_pub, 0.0, ((6, y), (3, joint4))) self.data = [] else: time.sleep(0.01) |
Tracking control thread that uses target tracking data such as position and orientation to control the robotic arm servos, achieving object following.
⑭ image_callback Method
281 282 283 284 285 286 287 288 289 290 | def image_callback(self, ros_image): try: cv_image = self.bridge.imgmsg_to_cv2(ros_image, desired_encoding='bgr8') except Exception as e: self.get_logger().error(f"图像转换出错:{e}") return if self.image_queue.full(): self.image_queue.get() self.image_queue.put(cv_image) |
⑮ main Function
292 293 294 295 296 297 | def main(): node = VLLMTrack('vllm_track') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
Node entry point that creates an instance of VLLMTrack, starts a multithreaded executor to handle callbacks, runs the node, and cleans up resources.
11.3.5 Intelligent Transport
Overview
Then, you can say the wake word “Hello Hiwonder” to activate the AI voice box, which will respond with “I’m here.” Once activated, you can control the ArmPi Ultra using voice commands. For example, you can say “Please put the blue square on the right side of the red square.” Upon receiving a command, the terminal displays the recognized speech content. The voice device then verbally responds with a generated answer and the robot simultaneously executes the corresponding action.
The default wake word for WonderEcho Pro is “Hello Hiwonder.” If you wish to change the wake-up word to “Xiaohuan Xiaohuan,” please refer to the directory: 11. Voice Control Course \1. Basic Voice Lesson \02 Firmware Flashing.
(3) Network Configuration
Connect to the robot via VNC and modify the network configuration files as described in:1. ArmPi Ultra User Manual->1.6 Development Environment Setup and Configuration ->1.6.3 LAN Mode Connection.
Operations
Double-click on
Enter the following command and press Enter to launch the intelligent transport feature.
ros2 launch large_models vllm_object_transport.launch.py
When the command line shows the output as illustrated below and the AI voice box announces “I’m ready,” it indicates that the box has completed initialization. At the same time, the YOLOv8 model is also initialized. You can now say the wake word “Hello Hiwonder.”
You can give commands by following the input prompts shown in the program’s task examples.
For example, place the object in front of the camera and say the command “Place the red block to the right of the green ball.”
Project Outcome
Once the feature starts, you can phrase your own commands. For example, “Place the red block to the right of the green ball.” The ArmPi Ultra robotic arm will automatically recognize the colored blocks within its field of view, highlight them on the screen, and place them in the specified positions according to our instructions.
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) peripherals_package_path = get_package_share_directory('peripherals') sdk_package_path = get_package_share_directory('sdk') large_models_package_path = get_package_share_directory('large_models') # Immediately launch depth_camera_launch (立即启动 depth_camera_launch) depth_camera_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(peripherals_package_path, 'launch/depth_camera.launch.py')), ) # Launch sdk_launch, large_models_launch, object_transport_node, and vllm_object_transport_node after 5 seconds (在5秒后启动 sdk_launch、large_models_launch、object_transport_node 和 vllm_object_transport_node) delayed_launch = TimerAction( period=5.0, # Delay time of 5 seconds (延迟时间为5秒) actions=[ IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(sdk_package_path, 'launch/armpi_ultra.launch.py')), ), IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ), Node( package='large_models', executable='object_transport', output='screen', ), Node( package='large_models', executable='vllm_object_transport', output='screen', ), ] ) return [mode_arg, depth_camera_launch, # Immediate launch (立即启动) delayed_launch, # Launch other components after 5 seconds (5秒后启动其他部分) ] |
Starts the depth camera by loading the peripherals package’s launch/depth_camera.launch.py file. This launches the depth camera node, providing RGB images and depth data as the foundational visual input for object recognition and localization. Delays the startup of the core services and transporting node by setting a 5-second TimerAction. This ensures that the depth camera has completed initialization and is outputting stable data before launching the dependent core components. Then loads the sdk package’s launch/armpi_ultra.launch.py file to start the ArmPi Ultra’s low-level control services, such as servo drivers and kinematics computation, providing hardware support for object grasping and manipulation tasks. After that, loads the large_models package’s launch/start.launch.py file to start the large model service, passing the mode parameter to control its operating mode, such as different object recognition logic or transport decision strategies. Launches the object_transport executable in the large_models package as the core node for object transportation, responsible for executing the specific transport logic, such as path planning and grasp control. Launches the vllm_object_transport executable in the large_models package, serving as the bridge between the large model and the transport logic. It leverages visual data and large model capabilities to enable intelligent decision-making, such as identifying target objects and determining transport destinations, with logs output to the screen.
55 56 57 58 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function=launch_setup) ]) |
③ Main Function
60 61 62 63 64 65 66 | if __name__ == '__main__': # Create a LaunchDescription object (创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 | import cv2 import math import json import time import queue import rclpy import threading import numpy as np from rclpy.node import Node from std_msgs.msg import String, Float32, Bool from std_srvs.srv import Trigger, SetBool, Empty from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup from speech import speech from large_models.config import * from large_models_msgs.srv import SetString, SetModel, SetBox, SetContent |
② PROMPT String
118 119 120 121 122 123 124 | ##Requirements and Restrictions 1. According to the input content, find the corresponding instructions in the function library and output the corresponding instructions. 2. Multiple actions need to be put in a list 3. Transportation is divided into two stages: picking up and putting down 4. Directly output data in json format, do not analyze, and do not output redundant content. 5. When restoring, if there is a move action in the instruction, then the move instruction needs to be returned, otherwise it returns "" 6. Format: {"action": "xx"} |
Defines prompt string (PROMPT) used to guide how user commands and image data are processed. It specifies the recognition task logic and expected output format.
③ VLLMObjectTransport Class
210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 | class VLLMObjectTransport(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.llm_result = '' # self.vllm_result = '''json{"object":"香蕉","xyxy":[243, 441, 842, 552], "response": "香蕉"}''' self.running = True self.transport_finished = True self.lock = threading.RLock() self.client = speech.OpenAIAPI(api_key, base_url) self.language = os.environ["ASR_LANGUAGE"] self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.asr_pub = self.create_publisher(String, '/vocal_detect/asr_result', 1) self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'object_transport/transport_finished', self.transport_finished_callback, 1) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.set_vllm_content_client = self.create_client(SetContent, 'agent_process/set_vllm_content') self.set_vllm_content_client.wait_for_service() self.record_chat_client = self.create_client(SetBool, 'agent_process/record_chat') self.record_chat_client.wait_for_service() self.get_chat_client = self.create_client(Trigger, 'agent_process/get_chat') self.get_chat_client.wait_for_service() self.clear_chat_client = self.create_client(Empty, 'agent_process/clear_chat') self.clear_chat_client.wait_for_service() self.enter_client = self.create_client(Trigger, 'object_transport/enter') self.enter_client.wait_for_service() self.start_client = self.create_client(SetBool, 'object_transport/enable_transport') self.start_client.wait_for_service() self.set_pick_client = self.create_client(SetBox, 'object_transport/set_pick_position') self.set_pick_client.wait_for_service() self.set_place_client = self.create_client(SetBox, 'object_transport/set_place_position') self.set_place_client.wait_for_service() self.record_position_client = self.create_client(SetBox, 'object_transport/record_position') self.record_position_client.wait_for_service() timer_cb_group = ReentrantCallbackGroup() self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
Initializes the node, sets up state variables such as the action list and transporting status, configures ROS communication components, including publishers, subscribers, and service clients, and starts the initialization timer.
④ get_node_state Method
258 259 | def get_node_state(self, request, response): return response |
⑤ init_process Method
261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model_type = 'llm' msg.model = llm_model msg.api_key = api_key msg.base_url = base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = LLM_PROMPT self.send_request(self.set_prompt_client, msg) msg = Empty.Request() self.send_request(self.clear_chat_client, msg) init_finish = self.create_client(Empty, 'object_transport/init_finish') init_finish.wait_for_service() self.send_request(self.enter_client, Trigger.Request()) speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') self.get_logger().info('\033[1;32m%s\033[0m' % LLM_PROMPT) |
Handles the node initialization workflow, configures LLM parameters and prompts, clears chat history, starts the processing thread, plays the startup audio, and outputs the initialization log.
⑥ send_request Method
287 288 289 290 291 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
A general-purpose service call utility that sends a service request and blocks until a response is received, ensuring service communication is completed.
⑦ llm_result_callback Method
293 294 | def llm_result_callback(self, msg): self.llm_result = msg.data |
Subscribes to the LLM output results and saves them to the llm_result variable for subsequent processing.
⑧ remember_position Method
296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 | def remember_position(self): msg = SetContent.Request() if self.language == 'Chinese': msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url msg.model = stepfun_vllm_model else: msg.api_key = vllm_api_key msg.base_url = vllm_base_url msg.model = vllm_model msg.prompt = VLLM_PROMPT2 vllm_result = self.send_request(self.set_vllm_content_client, msg) self.get_logger().info(f'vllm_result: {vllm_result}') message = vllm_result.message if message.startswith("```") and message.endswith("```"): message = message.strip("```").replace("json\n", "").strip() initial_position = json.loads(message) # self.get_logger().info(f'initial_position: {initial_position}') for i in initial_position: msg = SetBox.Request() msg.label = i xyxy = initial_position[i] msg.box = self.client.data_process(xyxy, 640, 400) self.send_request(self.record_position_client, msg) msg = SetBool.Request() msg.data = True self.send_request(self.start_client, msg) msg = SetBool.Request() msg.data = True self.send_request(self.record_chat_client, msg) |
Uses the visual LLM with VLLM_PROMPT2 to identify the initial positions of objects in the image, parses the results, records them in the object transport node, and initiates the position recording process.
⑨ recovery Method
329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 | def recovery(self, text): if not text: msg = Trigger.Request() res = self.send_request(self.get_chat_client, msg) # self.get_logger().info(str(res.message)) text = res.message.rsplit(",", 1)[0] if "," in res.message else res.message msg = SetBool.Request() msg.data = False self.send_request(self.record_chat_client, msg) msg = Empty.Request() self.send_request(self.clear_chat_client, msg) msg = String() if self.language == 'Chinese': msg.data = '{}, 只需要放回去的步骤'.format(text) else: msg.data = '{}, only the steps for putting it back'.format(text) self.get_logger().info('\033[1;32m%s\033[0m' % msg.data) self.asr_pub.publish(msg) |
Handles the “restore” command by querying the LLM for the necessary recovery action steps, publishes the instructions to the ASR results topic, and triggers the subsequent recovery workflow.
⑩ object_restore Method
348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 | def object_restore(self, query): msg = SetContent.Request() if self.language == 'Chinese': msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url msg.model = stepfun_vllm_model else: msg.api_key = vllm_api_key msg.base_url = vllm_base_url msg.model = vllm_model msg.prompt = VLLM_PROMPT1 msg.query = query vllm_result = self.send_request(self.set_vllm_content_client, msg) self.get_logger().info(f'vllm_result: {vllm_result}') message = vllm_result.message if message.startswith("```") and message.endswith("```"): message = message.strip("```").replace("json\n", "").strip() position = json.loads(message) msg = SetBox.Request() msg.label = position['pick']['object'] xyxy = position['pick']['xyxy'] if self.language == 'Chinese': msg.box = self.client.data_process(xyxy, 640, 400) else: msg.box = [int(xyxy[0] * 640), int(xyxy[1] * 400), int(xyxy[2] * 640), int(xyxy[3] * 400)] self.send_request(self.set_pick_client, msg) msg = SetBox.Request() msg.label = position['pick']['object'] self.send_request(self.set_place_client, msg) # self.get_logger().info(f'msg: {msg}') # Enable sorting. 开启分拣 msg = SetBool.Request() msg.data = True self.send_request(self.start_client, msg) self.transport_finished = False msg = Empty.Request() self.send_request(self.clear_chat_client, msg) msg = String() msg.data = position['response'] self.tts_text_pub.publish(msg) |
Handles the “Return to initial position” command by using the visual LLM with VLLM_PROMPT1 to determine the target object positions, sets the pick-and-place parameters, and initiates object transport.
⑪ get_object_position Method
393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 | def get_object_position(self, query, offset=None): msg = SetContent.Request() if self.language == 'Chinese': msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url msg.model = stepfun_vllm_model else: msg.api_key = vllm_api_key msg.base_url = vllm_base_url msg.model = vllm_model msg.prompt = VLLM_PROMPT1 msg.query = query vllm_result = self.send_request(self.set_vllm_content_client, msg) self.get_logger().info(f'vllm_result: {vllm_result}') message = vllm_result.message if message.startswith("```") and message.endswith("```"): message = message.strip("```").replace("json\n", "").strip() position = json.loads(message) # self.get_logger().info(f'position: {position}') # msg.label = label xyxy = position['pick']['xyxy'] # self.get_logger().info(f'pick xyxy: {xyxy}') if xyxy: msg = SetBox.Request() msg.box = self.client.data_process(xyxy, 640, 400) # msg.box = position['pick']['xyxy'] self.send_request(self.set_pick_client, msg) xyxy = position['place']['xyxy'] # self.get_logger().info(f'place xyxy: {xyxy}') if xyxy: msg = SetBox.Request() # msg.label = label if self.language == 'Chinese': msg.box = self.client.data_process(xyxy, 640, 400) else: msg.box = [int(xyxy[0] * 640), int(xyxy[1] * 400), int(xyxy[2] * 640), int(xyxy[3] * 400)] msg.offset = offset self.send_request(self.set_place_client, msg) # Enable sorting. 开启分拣 msg = SetBool.Request() msg.data = True self.send_request(self.start_client, msg) self.transport_finished = False msg = String() msg.data = position['response'] self.tts_text_pub.publish(msg) |
Based on user queries and offsets, calls the visual LLM with VLLM_PROMPT1 to obtain the object’s pick-and-place positions, sets them in the transport node, and starts the transport workflow.
⑫ transport_finished_callback Method
443 444 | def transport_finished_callback(self, msg): self.transport_finished = msg.data |
Subscribes to the object transport completion signal and updates the transport_finished status to synchronize action execution.
⑬ process Method
446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 | def process(self): action_list = [] action_finish = False while self.running: if self.llm_result: try: self.get_logger().info(f'llm_result: {self.llm_result}') if 'action' in self.llm_result: # If a corresponding action is returned, extract and process it (如果有对应的行为返回那么就提取处理) if self.llm_result.startswith("```") and self.llm_result.endswith("```"): self.llm_result = self.llm_result.strip("```").replace("json\n", "").strip() action_list = json.loads(self.llm_result)['action'] action_finish = False else: action_finish = True except BaseException as e: print(e) self.llm_result = '' else: if action_list: # self.get_logger().info(f'{self.transport_finished}') if self.transport_finished: action = action_list[0] if 'remember' in action: # Remember (记住) self.remember_position() elif 'recovery' in action: # Recovery (恢复) self.recovery(action[0]) elif 'pick' in action: # Pick (抓取) self.get_object_position(action[0]) elif 'place' in action: # Place (放置) self.get_object_position(action[0], action[-1]) elif 'pick_and_place' in action: # Place on a target (放置在某个上面) self.get_object_position(action[0], action[-1]) elif 'restore' in action: # Restore (还原某一个) self.object_restore(action[0]) del action_list[0] if not action_list: action_finish = True else: time.sleep(0.1) else: time.sleep(0.02) if action_finish: action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) rclpy.shutdown() |
The main processing loop parses the action list returned by the LLM such as remembering positions, recovery, picking, placing, etc., sequentially calls the corresponding functions such as remember_position and recovery, and re-enables the wake-up feature after completion.
⑭ main Function
494 495 496 497 498 499 | def main(): node = VLLMObjectTransport('vllm_object_transport') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
The entry point of the node. It creates an VLLMObjectTransport instance, starts a multithreaded executor to handle callbacks, runs the node, and cleans up resources.
11.3.5 Smart Home Assistant
Overview
Then, you can say the wake word “Hello Hiwonder” to activate the AI voice box, which will respond with “I’m here.” Once activated, you can control the ArmPi Ultra using voice commands. For example, you can say “Please bring me the ketchup.” Upon receiving a command, the terminal displays the recognized speech content. The voice device then verbally responds with a generated answer and the robot simultaneously executes the corresponding action.
By default, the program does not include the configuration of the Large Model-related API keys. Before activating features related to the Large AI Model, please refer to the section 11.2.1 Obtain and Configure the Large Model API Key in this document to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
Connect to the robot via VNC and modify the network configuration files as described in:1. ArmPi Ultra User Manual->1.6 Development Environment Setup and Configuration->1.6.3 LAN Mode Connection.
Operations
Double-click on
Enter the following command and press Enter to launch the smart home assistant feature.
ros2 launch large_models vllm_dietitianl.launch.py
You can speak the command according to the prompts displayed by the program, for example, “Give me the ketchup”.
Upon receiving user input, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command, generate a language response, and execute a corresponding action based on the meaning of the command.
Project Outcome
Once the feature is started, you can phrase your own commands. For example, saying “Please bring me the ketchup” will prompt the ArmPi Ultra robotic arm to automatically identify objects within its field of view, highlight the ketchup in the camera feed, and place it in the designated location according to your instructions.
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 | def launch_setup(context): mode = LaunchConfiguration('mode', default=1) mode_arg = DeclareLaunchArgument('mode', default_value=mode) peripherals_package_path = get_package_share_directory('peripherals') sdk_package_path = get_package_share_directory('sdk') large_models_package_path = get_package_share_directory('large_models') # Immediately start depth_camera_launch (立即启动 depth_camera_launch) depth_camera_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(peripherals_package_path, 'launch/depth_camera.launch.py')), ) control_launch = IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(sdk_package_path, 'launch/armpi_ultra.launch.py')), ) # Launch sdk_launch, large_models_launch, intelligent_grasp_node, and vllm_dietitianl_node after 5 seconds (在5秒后启动 sdk_launch、large_models_launch、intelligent_grasp_node 和 vllm_dietitianl_node) delayed_launch = TimerAction( period=5.0, # Delay time of 5 seconds (延迟时间为5秒) actions=[ IncludeLaunchDescription( PythonLaunchDescriptionSource( os.path.join(large_models_package_path, 'launch/start.launch.py')), launch_arguments={'mode': mode}.items(), ), Node( package='large_models', executable='intelligent_grasp', output='screen', ), Node( package='large_models', executable='vllm_dietitianl', output='screen', ), ] ) return [mode_arg, depth_camera_launch, # Immediately start (立即启动) control_launch, delayed_launch, # Launch other parts after 5 seconds (5秒后启动其他部分) ] |
Starts the depth camera by loading the peripherals package’s launch/depth_camera.launch.py file. This launches the depth camera node, providing RGB images and depth data as the foundational visual input for object recognition, positioning, and nutritional analysis. Delays the startup of the core services and the feature’s node by setting a 5-second TimerAction. This ensures that the depth camera has completed initialization and is outputting stable data before launching the dependent core components. Then loads the sdk package’s launch/armpi_ultra.launch.py file to start the ArmPi Ultra’s low-level control services, such as servo drivers and kinematics computation, providing hardware support for intelligent grasping actions. After that, loads the large_models package’s launch/start.launch.py file to start the large model service, passing the mode parameter to control its operation, such as different grasping decision logic or nutrition analysis precision. Launches the intelligent_grasp executable in the large_models package as the core node for intelligent grasping, responsible for executing vision-based precise grasping logic such as target localization and grasp pose planning. Launches the vllm_dietitian executable in the large_models package, which integrates visual data with large model capabilities to perform nutrition analysis of objects, such as identifying food items and analyzing calories or components, with logs output to the screen.
57 58 59 60 | def generate_launch_description(): return LaunchDescription([ OpaqueFunction(function=launch_setup) ]) |
③ Main Function
62 63 64 65 66 67 68 | if __name__ == '__main__': # Create a LaunchDescription object (创建一个LaunchDescription对象) ld = generate_launch_description() ls = LaunchService() ls.include_launch_description(ld) ls.run() |
5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 | import os import cv2 import math import json import time import queue import rclpy import threading import numpy as np from rclpy.node import Node from std_msgs.msg import String, Float32, Bool from std_srvs.srv import Trigger, SetBool, Empty from rclpy.executors import MultiThreadedExecutor from rclpy.callback_groups import ReentrantCallbackGroup from speech import speech from large_models.config import * from large_models_msgs.srv import SetString, SetModel, SetBox |
② PROMPT String
44 45 46 47 48 49 50 51 52 53 54 55 56 | **Task: 1. Instruction Understanding You will receive a sentence from the user. → Extract the object name based on the user's intent. → The object name must be in English. → You can only handle one object at a time. → Do not include any unmentioned objects. 2. Image Analysis You will receive an image. → Find the bounding box (top-left and bottom-right pixel coordinates) for the object mentioned. → Coordinates should be normalized to [0, 1]. → Focus on accurate detection and orientation. |
③ VLLMDietitianl Class
73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 | class VLLMDietitianl(Node): def __init__(self, name): rclpy.init() super().__init__(name) self.vllm_result = '' # self.vllm_result = '''json{"object":"香蕉","xyxy":[243, 441, 842, 552], "response": "香蕉"}''' self.running = True self.action_finish = False self.play_audio_finish = False self.lock = threading.RLock() self.language = os.environ["ASR_LANGUAGE"] self.client = speech.OpenAIAPI(api_key, base_url) timer_cb_group = ReentrantCallbackGroup() self.tts_text_pub = self.create_publisher(String, 'tts_node/tts_text', 1) self.create_subscription(String, 'agent_process/result', self.llm_result_callback, 1) self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_finish_callback, 1, callback_group=timer_cb_group) self.awake_client = self.create_client(SetBool, 'vocal_detect/enable_wakeup') self.awake_client.wait_for_service() self.set_model_client = self.create_client(SetModel, 'agent_process/set_model') self.set_model_client.wait_for_service() self.set_prompt_client = self.create_client(SetString, 'agent_process/set_prompt') self.set_prompt_client.wait_for_service() self.enter_client = self.create_client(Trigger, 'intelligent_grasp/enter') self.enter_client.wait_for_service() self.start_client = self.create_client(SetBool, 'intelligent_grasp/enable_transport') self.start_client.wait_for_service() self.set_target_client = self.create_client(SetBox, 'intelligent_grasp/set_target') self.set_target_client.wait_for_service() self.timer = self.create_timer(0.0, self.init_process, callback_group=timer_cb_group) |
Initializes the node, configures state variables such as large model results and action completion flags, sets up ROS communication components including publishers, subscribers, and service clients, and starts the initialization timer.
109 110 | def get_node_state(self, request, response): return response |
112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 | def init_process(self): self.timer.cancel() msg = SetModel.Request() msg.model_type = 'vllm' if self.language == 'Chinese': msg.model = stepfun_vllm_model msg.api_key = stepfun_api_key msg.base_url = stepfun_base_url else: msg.model = vllm_model msg.api_key = vllm_api_key msg.base_url = vllm_base_url self.send_request(self.set_model_client, msg) msg = SetString.Request() msg.data = PROMPT self.send_request(self.set_prompt_client, msg) # init_finish = self.create_client(Empty, 'intelligent_grasp/init_finish') # init_finish.wait_for_service() self.send_request(self.enter_client, Trigger.Request()) speech.play_audio(start_audio_path) threading.Thread(target=self.process, daemon=True).start() self.create_service(Empty, '~/init_finish', self.get_node_state) self.get_logger().info('\033[1;32m%s\033[0m' % 'start') self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT) |
Node initialization process that configures large model parameters by selecting models and API keys according to the language environment, sets prompts, sends a request to enter the intelligent grasping service, plays startup audio, launches the main processing thread, and outputs initialization logs.
140 141 142 143 144 | def send_request(self, client, msg): future = client.call_async(msg) while rclpy.ok(): if future.done() and future.result(): return future.result() |
General service call utility that sends a service request and blocks until a response is received, ensuring service communication is complete, such as configuring the large model or controlling grasping.
146 147 | def llm_result_callback(self, msg): self.vllm_result = msg.data |
Subscriber callback for large model results, receiving object information including name, coordinates, and responses, and saving it to vllm_result for processing.
⑧ play_audio_finish_callback Method
149 150 | def play_audio_finish_callback(self, msg): self.play_audio_finish = msg.data |
Subscriber callback for TTS playback completion signals, updating audio playback status to synchronize action execution with voice feedback.
⑨ process Method
152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 | def process(self): while self.running: if self.vllm_result: try: if self.vllm_result.startswith("```") and self.vllm_result.endswith("```"): self.vllm_result = self.vllm_result.strip("```").replace("json\n", "").strip() self.vllm_result = json.loads(self.vllm_result) box = self.vllm_result['xyxy'] box = self.client.data_process(box, 640, 400) label = self.vllm_result['object'] response = self.vllm_result['response'] self.get_logger().info(f'label: {label} box: {box}') msg = SetBox.Request() msg.label = label msg.box = box self.send_request(self.set_target_client, msg) # Enable sorting. 开启分拣 msg = SetBool.Request() msg.data = True self.send_request(self.start_client, msg) time.sleep(2) msg = String() msg.data = response self.tts_text_pub.publish(msg) except BaseException as e: msg = String() msg.data = self.vllm_result self.tts_text_pub.publish(msg) self.get_logger().info(f'error: {e}') self.action_finish = True self.vllm_result = '' else: time.sleep(0.01) if self.play_audio_finish and self.action_finish: self.play_audio_finish = False self.action_finish = False msg = SetBool.Request() msg.data = True self.send_request(self.awake_client, msg) rclpy.shutdown() |
Main processing loop that parses large model results, extracts object names and coordinates, sets grasp targets, and initiates intelligent grasping. Publishes TTS responses and, upon completion, re-enables the wake-up function to await the next command.
⑩ main Function
194 195 196 197 198 199 | def main(): node = VLLMDietitianl('vllm_dietitianl') executor = MultiThreadedExecutor() executor.add_node(node) executor.spin() node.destroy_node() |
Node entry point that creates an instance of VLLMDietitianl, starts a multithreaded executor to handle callbacks, runs the node, and cleans up resources.
