12. Large AI Model Courses
12.1 Large Models Basic Courses
12.1.1 Large Language Model Courses
Overview of Large Language Model
(1) Basic Concept
(2) Features
(3) Working Principle
(4) Application Scenarios
① Text Generation
② Text Classification
③ Machine Translation
④ Question-Answering Systems
Large Language Model Deployment
Large Language Model Accessing
To proceed with this section, you will need to register on the appropriate website and obtain the API key for the large model (please refer to the file “12.1.1 Large Language Model Courses -> Large Language Model Deployment”).
(1) Environment Configuration
sudo apt install vim
sudo apt install gedit
sudo apt install python3 python3-pip python3-all-dev python3-pyaudio portaudio11-dev libsndfile1
cd ~/large_models/speech_pkg/
| Type of main controller | Python version |
| jetson_nano | 3.6 |
| jetson_orin | 3.10 |
| rpi5 | 3.11 |
| rpi5_docker | 3.8 |
cd jetson_orin/
cp -r speech.so ..
cd ../..
pip3 install .
pip3 install openai -U
(3) Key Configuration
cd ~/large_models
vim config.py
③ Once the file is open, configure the OpenAI and OpenRouter keys by filling in the llm_api_key and vllm_api_key parameters, respectively (you can obtain these keys from the ‘12.1.1 Large Language Model Courses -> Large Language Model Deployment’ course).
(4) Running the Demo Program
python3 openai_llm_demo.py
Semantic Understanding with Large Language Model
Before starting this section, make sure you have completed the API key configuration outlined in the file 12.1.1 Large Language Model Courses -> Large Language Model Accessing.
cd large_models/
Emotional Perception with Large Language Model
To proceed with this section, ensure that you have completed the API key configuration as described in the file 12.1.1 Language Model Courses -> Large Language Model Accessing.
cd large_models/
python3 openai_llm_er_demo.py
12.1.2 Large Speech Model Courses
Overview of Large Speech Model
Their advantages include:
① Processing Methods
② Model Complexity
③ Recognition Capability
④Training Data Requirements
② Text-to-Speech (TTS)
Voice Device Introduction and Testing
(1) Device Overview
① 6-Microphone Circular Array
Introduction:
Features and Specifications:
② Recording Test
arecord -l
③ Playback Test
aplay test.wav
Voice Wake-Up
(1) WonderEcho Pro Wake-Up
Device Check:
To proceed, we need to identify the USB device name assigned to the connected WonderEcho Pro or voice device (hereafter referred to as the voice device). Please follow the steps below carefully.
ll /dev | grep USB
ll /dev | grep USB
Wake-Up Test:
vim wakeup_demo.py
Device Check:
Wake-Up Test:
② Press i to enter edit mode.
③ Update the port to match the device port number you previously identified. Comment out the WonderEcho Pro configuration (add # at the beginning of the corresponding line), and uncomment the line using the voice device on line 11 as the input device (see red box in the referenced image).
(3) Brief Program Overview
Importing Required Modules
5 6 7 | import os import time from speech import awake |
9 10 | port = '/dev/ttyUSB0' kws = awake.WonderEchoPro(port) |
13 14 15 16 | try: # If a fan is present, it's recommended to turn it off before detection to reduce interference os.system('pinctrl FAN_PWM op dh') except: pass |
Main Wake Word Detection Loop
18 19 | kws.start() # Start detection print('start...') |
Main Program Logic
20 21 22 23 24 25 26 27 28 29 30 31 | while True: try: if kws.wakeup(): # Wake-up detected print('hello hiwonder') time.sleep(0.02) except KeyboardInterrupt: kws.exit() # Cancel processing try: os.system('pinctrl FAN_PWM a0') except: pass break |
(4) Extended Functionality
vim wakeup_demo.py
i
python3 wakeup_demo.py
“Appendix → Firmware Flashing Tool → Creating Firmware for WonderEchoPro”.
Speech Recognition
(2) How It Works
Before proceeding, refer to the course “12.1.1 Large Speech Model Courses -> Large Language Model Deployment” to obtain your API key, and make sure to add it into the configuration file (config).
(4) Experiment Steps
cd large_models/
vim config.py
python3 openai_asr_demo.py
(5) Function Realization
(6) Brief Program Analysis
① Module Import
6 | from speech import speech |
② Define ASR Class
11 | asr = speech.RealTimeOpenAIASR() |
13 | asr.update_session(model='whisper-1', language='en', threshold=0.2, prefix_padding_ms=300, silence_duration_ms=800) |
(7) Function Extension
vim openai_asr_demo.py
i
Speech Synthesis
(1) What is Speech Synthesis?
(2) How It Works
Refer to the course “Large Language Model Deployment” to obtain your API key, and update the configuration file accordingly.
cd large_models/
vim config.py
python3 openai_tts_demo.py
① Module Import
5 6 | from config import * from speech import speech |
② Definition for TTS Class
8 9 10 11 | tts = speech.RealTimeOpenAITTS() tts.tts("Hello, Can I help you?") # https://platform.openai.com/docs/guides/text-to-speech tts.tts("Hello, Can I help you?", model="tts-1", voice="onyx", speed=1.0, instructions='Speak in a cheerful and positive tone.') tts.save_audio("Hello, Can I help you?", model="gpt-4o-mini-tts", voice="onyx", speed=1.0, instructions='Speak in a cheerful and positive tone.', audio_format='wav', save_path="./resources/audio/tts_audio.wav") |
③ Function Extension
vim openai_tts_demo.py
i
Voice Interaction
(2) How It Works
(3) Experiment Steps
① Power on the device and connect to it via MobaXterm (refer to Appendix “5.1 Remote Connection Tools and Instructions” for connection guidance).
ll /dev | grep USB
cd large_models/
vim config.py
⑥ Run the program:
(4) Function Realization
(5) Brief Program Analysis
(1) Module Import
5 6 7 8 9 | import os import time from config import * from speech import awake from speech import speech |
11 12 13 | wakeup_audio_path = './resources/audio/en/wakeup.wav' start_audio_path = './resources/audio/en/start_audio.wav' no_voice_audio_path = './resources/audio/en/no_voice.wav' |
(3) Main Functional Logic
33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 | def main(): kws.start() while True: try: if kws.wakeup(): # Wake word detected(检测到唤醒词) speech.play_audio(wakeup_audio_path) # Play wake-up sound(唤醒播放) asr_result = asr.asr() # Start voice recognition(开启录音识别) print('asr_result:', asr_result) if asr_result: # Send the recognition result to the agent for a response(将识别结果传给智能体让他来回答) response = client.llm(asr_result, model='gpt-4o-mini') print('llm response:', response) tts.tts(response) else: speech.play_audio(no_voice_audio_path) time.sleep(0.02) except KeyboardInterrupt: kws.exit() try: os.system('pinctrl FAN_PWM a0') except: pass break except BaseException as e: print(e) |
12.1.3 Vision Language Model Courses
Overview of Vision Language Model
(1) Basic Concept
(2) Features
(3) How It Works
① Image Captioning
② Visual Question Answering
③ Image Retrieval
④ Augmented Reality (AR)
⑥ Social Media Interaction
⑦ Medical Imaging Analysis
Vision Language Model Accessing
This section requires the configuration of the API key in “Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
This experiment requires either an Ethernet cable or Wi-Fi connection to ensure the main control device can access the network properly.
(1) Experiment Steps
cd large_models/
Run the program:
(2) Function Realization
Vision Language Model: Object Detection
This section requires the configuration of the API key in “12.1.3 Vision Language Module Courses -> Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
In this course, we will use a program to transmit an image to the large model for recognition, which will then identify and locate the objects within the image by drawing bounding boxes around them.
cd large_models/
② Run the program:
(3) Function Expansion
Change Pictures:
② Then, input the command:
i
Vision Language Model: Scene Understanding
In this course, we will use a program to send an image to the large model for recognition and generate a description of the content within the image.
cd large_models/
② Run the program:
④ Run the program:
Vision Language Model: Optical Character Recognition
This section requires the configuration of the API key in “ Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
In this course, we use a program to transmit an image to the large model for recognition, extracting and identifying the text within the image.
cd large_models/
② Run the program:
python3 openai_vllm_ocr.py
Change Pictures:
i
⑤ Run the program:
12.1.4 Multimodal Model Basic Courses
Overview of Multimodal Model
(1) Basic Concept
(2) Features
(3) How It Works
① Education
② Healthcare
③ Entertainment
④ Advertising and Marketing
Agent Behavior Orchestration
The purpose of this course experiment is to obtain data in a specified format returned by the large model based on the prompt words set in the model. During development, you can use the returned data for further tasks.
ll /dev | grep USB
cd large_models/
vim config.py
vim openai_agent_demo.py
⑤ Run the program:
python3 openai_agent_demo.py
12.2 Multimodal Large Model Applications
12.2.1 Large Model API Key Setup
This section requires registering on the official OpenAI website and obtaining an API key for accessing large language models.
12.2.1.1 OpenAI Account Registration and Deployment
Copy and open the following URL: https://platform.openai.com/docs/overview, then click the Sign Up button in the upper-right corner.
Register and log in using a Google, Microsoft, or Apple account, as prompted.
After logging in, click the Settings button, then go to Billing, and click Payment Methods to add a payment method. The payment is used to purchase tokens.
After completing the preparation steps, click API Keys and create a new key. Follow the prompts to fill in the required information, then save the key for later use.
The creation and deployment of the large model have been completed, and this API will be used in the following sections.
12.2.1.2 OpenRouter Account Registration and Deployment
Copy the URL https://openrouter.ai/ into a browser and open the webpage. Click Sign in and register or sign in using a Google account or another available account.
After logging in, click the icon in the top-right corner, then select Credits to add a payment method.
Create an API key. Go to API Keys, then click Create Key. Follow the prompts to generate a key. Save the API key securely for later use.
12.2.1.3 API Configuration
Click
to open a terminal and enter the following command to open the configuration file. Press the i key to enter input mode.
vim /home/ubuntu/ros2_ws/src/large_models/large_models/large_models/config.py
Fill in the obtained Large Model API Key in the corresponding parameter, as shown in the red box in the figure below.
Press Esc, then enter the command and press Enter to save and exit the configuration file.
12.2.2 Version Confirmation
Before starting features, verify that the correct microphone configuration and ASR Mode are set in the system.
After remotely logging in via NoMachine, click the desktop icon
to access the configuration interface.Select the appropriate microphone version configuration according to the hardware.
If using the AI Voice Interaction Box, select WonderEcho Pro as the microphone type, as shown in the figure below.
Set the ASR Mode to online.
Click Save.
After the Save Success notification appears, click Apply.
Finally, click Quit to exit the software.
12.2.3 Voice Control
12.2.3.1 Program Overview
Once the program starts, the voice device will announce I’m ready. Say the designated wake word Hello Hiwonder to activate the voice device, which will respond with I’m here. Then, the robot can be controlled via voice commands to perform corresponding actions, for example: Move forward, backward. The voice device will respond after processing the command and execute the corresponding action.
12.2.3.2 Preparation
Before starting this feature, ensure that the microphone version configuration in the system is correct. For more details, refer to section 12.2.2 Version Confirmation.
Configure the Large Model API Key
Refer to the section 12.2.1 Large Model API Key Setup to set up the large model key.
12.2.3.3 Operation Steps
Command input is case-sensitive and space-sensitive.
The robot must be connected to the Internet, either in STA (LAN) mode or AP direct connection mode via Ethernet.
Click the terminal
on the left side of the system interface to open the command line. Enter the command and press Enter to disable the app auto-start service.
Enter the following command and press Enter to launch the voice control feature.
ros2 launch large_models_examples llm_control_move.launch.py
When the command line displays the output shown below and announces I’m ready, the voice device has completed initialization. At this point, say the wake word Hello Hiwonder.
When the command line shows the output below and the voice device announces I’m here, the voice device has been successfully activated. The system will begin recording your voice command.
When the terminal displays the next output as the reference image, it shows the recognized speech transcribed by the device.
When the command line displays the output shown below, the cloud-based large language model has been successfully invoked. It processes the user’s command, provides a verbal response, and generates actions corresponding to the semantic meaning of the command.
The response is automatically generated by the large model. Only the semantic accuracy of the reply is guaranteed, while the wording and formatting may vary.
When the command line displays the output shown below, the current dialogue session has ended. Refer to Step 4 to reactivate the voice device with the wake word and start a new dialogue session.
To exit the feature, press Ctrl + C in the terminal. If the feature does not shut down immediately, press Ctrl + C multiple times. If it still fails to exit, open a new terminal window and run the following command to terminate all active ROS processes and related programs.
12.2.3.4 Program Outcome
Once the feature is activated, commands can be freely issued, for example: “Move forward, backward.” The robot will then move forward and backward accordingly.
12.2.3.5 Program Analysis
Launch File Analysis
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_control_move.launch.py
Define launch_setup Function
mode = LaunchConfiguration('mode', default=1)
mode_arg = DeclareLaunchArgument('mode', default_value=mode)
large_models_package_path = get_package_share_directory('large_models')
llm_control_move_node = Node(
package='large_models_examples',
executable='llm_control_move',
return [mode_arg,
controller_launch,
large_models_launch,
llm_control_move_node,
This function is used to configure and launch actions in a Launch file.
mode = LaunchConfiguration('mode', default=1): Defines a Launch parameter named mode with a default value of 1.
mode_arg = DeclareLaunchArgument('mode', default_value=mode): Declares the mode parameter and adds it to the Launch description.
controller_path和large_models_package_path: Paths to the shared directories of the controller and large_models packages, which control the robot’s movement.
controller_launch: Uses IncludeLaunchDescription to include the controller.launch.py file from the controller package.
large_models_launch: Uses IncludeLaunchDescription to include the start.launch.py file from the large_models package and passes the mode parameter.
Finally, returns a list containing all Launch actions.
Python File Analysis
The program file is located at: ros2_ws/src/large_models_examples/large_models_examples/llm_control_move.py
1. Define Prompt Template (PROMPT)
PROMPT = '''
**Role
You are an intelligent car that can be controlled via linear velocity on the x and y axes (in meters per second), and angular velocity on the z axis (in radians per second). The movement duration is controlled by t (in seconds).
Your job is to generate a corresponding instruction based on user input.
**Requirements
- Ensure valid velocity ranges:
Linear velocity: x, y ∈ [-1.0, 1.0] (negative values mean reverse direction)
Angular velocity: z ∈ [-1.0, 1.0] (negative: clockwise, positive: counterclockwise)
- Execute multiple actions sequentially, returning a list of movement instructions under the action field.
- Always append a stop command [0.0, 0.0, 0.0, 0.0] at the end to ensure the car halts.
- Default values:
x and y: 0.2
z: 1.0
t: 2.0
- For each action sequence, craft a short (5–10 characters), witty, and endlessly variable response to make interactions fun and engaging.
- Output only the final JSON result. No explanations, no extra output.
- Format:
"action": [[x1, y1, z1, t1], [x2, y2, z2, t2], ..., [0.0, 0.0, 0.0, 0.0]],
"response": "short response"
- Possess strong mathematical reasoning to interpret and compute physical quantities like distance, time, and velocity.
## Special Notes
The "action" key should contain an array of stringified movement instructions in execution order. If no valid command is found, output an empty array [].
The "response" key should contain a creatively written, concise reply that matches the required tone and length.
**Examples
Input: Move forward for 2 seconds, then rotate clockwise for 1 second
Output:
"action": [[0.2, 0.0, 0.0, 2.0], [0.0, 0.0, 1.0, 1.0], [0.0, 0.0, 0.0, 0.0]],
"response": "Full speed ahead, spin and go!"
Input: Move forward 1 meter
Output:
"action": [[0.2, 0.0, 0.0, 5.0], [0.0, 0.0, 0.0, 0.0]],
"response": "Got it!"
2. Class Initialization
class LLMControlMove(Node):
self.action = []
self.llm_result = ''
self.interrupt = False
self.action_finish = False
Set state variables such as action list action, interrupt flag interrupt, and action completion flag action_finish. Create publishers such as TTS text publisher and subscribers such as large model results, TTS playback completion signal, and wake-up signal. Create service clients, such as for configuring the large model or enabling voice for communication and control.
3. Set LLM Model
msg = SetModel.Request()
# msg.model = 'qwen-plus-latest'
msg.model = llm_model
msg.model_type = 'llm'
msg.api_key = api_key
msg.base_url = base_url
msg = SetString.Request()
msg.data = PROMPT
self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT)
4. play_audio_finish_callback Method
msg = SetBool.Request()
msg.data = True
# msg = SetInt32.Request()
# msg.data = 1
The method handles the callback after audio playback and re-enables the voice wake-up functionality.
5. process Method
def process(self):
if self.llm_result:
msg = String()
if 'action' in self.llm_result: # If there is a corresponding behavior returned, extract and process it.
action_list = []
if 'action' in result:
if 'response' in result:
response = result['response']
msg.data = response
for i in action_list:
msg = Twist()
msg.linear.x = float(i[0])
msg.linear.y = float(i[1])
msg.angular.z = float(i[2])
self.mecanum_pub.publish(msg)
time.sleep(i[3])
if self.interrupt:
else: # If there is no corresponding behavior, only respond.
response = self.llm_result
msg.data = response
self.action_finish = True
if self.play_audio_finish and self.action_finish:
# msg.data = 2
The main loop handles instructions from the LLM, parses commands, executes the corresponding actions, and provides voice feedback.
12.2.4 Autonomous Line Following
12.2.4.1 Program Overview
When the program starts, the voice device will announce I’m ready. To activate the voice device, say the designated wake word Hello Hiwonder. Upon successful activation, the voice device will respond with I’m here. Once activated, voice commands can be issued, for example, Follow the black line and stop when you encounter an obstacle. The terminal displays the recognized command, and the voice device provides a processed response. The robot then follows the black line detected by its camera and stops automatically when an obstacle is detected.
12.2.4.2 Preparation
12.2.4.3 Operation Steps
Click the terminal
Enter the following command and press Enter to launch the autonomous line following feature.
ros2 launch large_models_examples llm_visual_patrol.launch.py
When the terminal prints the output shown below, it indicates that the voice device has transcribed the spoken command. In this example, the command spoken is “Follow the black line and stop when you encounter an obstacle.”
To stop the feature, refer to Step 4 to reactivate the voice device again with the wake word to begin a new interaction cycle.
To exit the feature, press Ctrl + C in the terminal. If the feature does not exit immediately, press Ctrl + C multiple times.
12.2.4.4 Program Outcome
Once the feature is activated, feel free to give commands in your own words. For instance, “Follow the black line and stop when you encounter an obstacle.” The robot uses its camera to detect and follow the black line, and it will stop when an obstacle is detected in its path. The system is pre-configured to recognize four line colors: red, blue, green, and black.
12.2.4.5 Program Analysis
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_visual_patrol.launch.py
'debug': 'true',
return [mode_arg,
line_following_node_launch,
llm_visual_patrol_node,
large_models_package_path: Retrieves the shared directory path of the large_models package.
line_following_node_launch: Uses IncludeLaunchDescription to include the line_following_node.launch.py file.
large_models_launch: Uses IncludeLaunchDescription to include the start.launch.py launch file from the large_models package and passes the mode parameter.
llm_vision_pratrol: Defines a ROS2 node from the large_models package that runs the llm_vision_pratrol executable and prints its output to the screen.
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_visual_patrol.py
PROMPT = '''
**Role
You are a smart robot that generates corresponding JSON commands based on user input.
**Requirements
- For every user input, search for matching commands in the action function library and output the corresponding JSON instruction.
- For each action sequence, craft a witty and creative response (10 to 30 characters) to make interactions delightful.
- Directly return the JSON result — do not include any explanations or extra text.
- There are four target colors: red, green, blue, and black.
- Format:
"action": ["xx", "xx"],
"response": "xx"
**Special Notes
The "action" field should contain a list of function names as strings, ordered by execution. If no matching action is found, output an empty list: [].
The "response" field should provide a concise and charming reply, staying within the word and tone guidelines.
**Action Function Library
Follow a line of a given color: line_following('black')
**Example
Input: Follow the red line
Output:
"action": ["line_following('red')"],
"response": "Roger that!"
self.action = []
self.stop = True
# self.llm_result = '{"action": ["line_following(\'black\')"], "response": "ok!"}'
self.enter_client = self.create_client(Trigger, 'line_following/enter')
self.enter_client.wait_for_service()
self.start_client = self.create_client(SetBool, 'line_following/set_running')
self.set_target_client = self.create_client(SetColor, 'line_following/set_color')
Set state variables, including stop flags, LLM processing outputs, and runtime status. Create publishers for TTS text output and subscribers for agent responses, wake-word signals, and audio-playback completion. Service-client requests cover entering tracking mode, updating the running state, and specifying the tracking color, providing the communication and control interface for the system.
3. Set LLM Model
msg.data = PROMPT
init_finish = self.create_client(Trigger, 'line_following/init_finish')
self.send_request(self.enter_client, Trigger.Request())
5. process Method
def process(self):
if self.llm_result:
msg = String()
if 'action' in self.llm_result: # If there is a corresponding action returned, extract and process it(If there is a corresponding behavior returned, extract and process it.)
result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}')+1])
text = result['action']
# Use regular expressions to extract all strings inside parentheses.
pattern = r"line_following\('([^']+)'\)"
# Use re.search to find the matching result
for i in text:
match = re.search(pattern, i)
# Extract the result.
if match:
# Get all argument parts, precisely content inside parentheses.
color = match.group(1)
self.get_logger().info(str(color))
color_msg = SetColor.Request()
color_msg.data = color
self.send_request(self.set_target_client, color_msg)
# Start sorting.
start_msg = SetBool.Request()
start_msg.data = True
self.send_request(self.start_client, start_msg)
msg.data = result['response']
else: # If there is no corresponding action, just respond(If there is no corresponding behavior, only respond.)
msg.data = self.llm_result
msg.data = True
# msg.data = 2
self.stop = False
By continuously monitoring the large model output, the system checks for any instruction that contains the line_following action. Once detected, it uses a regular expression to extract the color parameter and sends it to the line-following module as the target color, then activates the tracking function. If a text response is generated, the system delivers it through TTS for voice feedback. During execution, it coordinates action handling with the completion status of audio playback. After the task is finished, it resets the status flags and re-enables the voice-wake function, ready for the next command.
12.2.5 Color Tracking
12.2.5.1 Program Overview
When the program starts, the voice device will announce I’m ready. To activate the voice device, say the designated wake word Hello Hiwonder. Upon successful activation, the voice device will respond with I’m here. Once activated, voice commands can be issued, for example, “Follow the red object.” The terminal displays the recognized command, and the voice device provides a processed response. The robot then autonomously detects the red object using its camera and starts tracking it.
12.2.5.2 Preparation
12.2.5.3 Operation Steps
Click the terminal
Enter the following command and press Enter to launch the color tracking feature.
ros2 launch large_models_examples llm_color_track.launch.py
After the program has loaded successfully, the camera feed will appear on screen.
When the terminal displays the output shown below, it indicates that the voice device has printed the recognized speech. Now, say the command “Follow the red object.”
Upon successful recognition by the speech recognition service of a cloud-based large speech model, the parsed command will be displayed under the
publish_asr_resultoutput in the terminal.
Then, the robot will detect the red object in its camera feed and begin tracking it in real time.
12.2.5.4 Program Outcome
Once the feature is activated, commands can be freely issued, for example, “Follow the red object.” The robot uses its camera feed to detect and track the red object. Similarly, commands such as “Follow the blue object” or “Follow the green object” can be used to have the robot detect and track objects of the corresponding colors.
12.2.5.5 Program Analysis
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_color_track.launch.py
'debug': 'true',
llm_color_track_node = Node(
executable='llm_color_track',
return [mode_arg,
object_tracking_node_launch,
llm_color_track_node,
objet_sorting_launch: Uses IncludeLaunchDescription to include the object_tracking_node.launch.py file from the large_models package and passes the mode parameter.
llm_color_track_node: Defines a ROS2 node from the large_models package that runs the llm_color_track executable and prints its output to the screen.
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_color_track.py
PROMPT = '''
**Role
You are an intelligent companion robot. Your job is to generate corresponding JSON commands based on the user’s input.
**Requirements
- For every user input, search the action function library for matching commands and return the corresponding JSON instruction.
- Craft a witty, ever-changing, and concise response (between 10 to 30 characters) for each action sequence to make interactions lively and fun.
- Output only the JSON result — do not include explanations or any extra text.
- Output format:{"action": ["xx", "xx"], "response": "xx"}
**Special Notes
The "action" key holds an array of function name strings arranged in execution order. If no match is found, return an empty array [].
The "response" key must contain a cleverly worded, short reply (10–30 characters), adhering to the tone and length guidelines above.
Track an object of a specific color: color_track('red')
**Example
Input: Track a green object
Output:
{"action": ["color_track('green')"], "response": "Got it!"}
self.action = []
self.stop = True
# self.llm_result = '{"action": ["color_track(\'blue\')"], "response": "ok!"}'
self.enter_client = self.create_client(Trigger, 'object_tracking/enter')
self.start_client = self.create_client(SetBool, 'object_tracking/set_running')
self.set_target_client = self.create_client(SetColor, 'object_tracking/set_color')
By initializing state parameters, including the action list, stop flag, LLM processing results, and completion status, a TTS text publisher and subscribers are created to receive agent processing results, voice wake signals, and audio playback completion status. Service client requests are also established for voice wake, node configuration, model setup, prompt settings, and object tracking functions, including entering tracking mode, setting run status, and specifying the target color. Finally, a timer is created to start the initialization process.
3. Set LLM Model
msg.data = PROMPT
init_finish = self.create_client(Trigger, 'object_tracking/init_finish')
5. process Method
def process(self):
if self.llm_result:
msg = String()
pattern = r"color_track\('([^']+)'\)"
# Use re.search to find the matching result.
for i in text:
if match:
# Start sorting.
# msg.data = 1
msg.data = True
self.stop = False
By continuously monitoring the large model output, the system checks for any instruction that contains the color_track action. Once detected, it uses a regular expression to extract the color parameter and sends it to the color-tracking module as the target color, then activates the tracking function. If a text response is generated, the system delivers it through TTS for voice feedback. During execution, it coordinates action handling with the completion status of audio playback. After the task is finished, it resets the status flags and re-enables the voice-wake function, ready for the next command.
12.3 Embodied AI Applications
12.3.1 Large Model API Key Setup
12.3.1.2 OpenRouter Account Registration and Deployment
12.3.1.3 API Configuration
Click
12.3.2 Version Confirmation
Click Save.
Finally, click Quit to exit the software interface.
12.3.3 Real-Time Detection
12.3.3.1 Program Overview
When the program starts, the voice device will announce I’m ready. To activate the voice device, speak the designated wake words: Hello Hiwonder. Upon successful activation, the voice device will respond with I’m here. Then, voice commands can be used to control the robot, for example, Tell me what you saw. The terminal will display the recognized speech, the voice device will respond with a generated reply after processing, and the robot will autonomously analyze the camera feed and describe the content of the scene.
12.3.3.2 Preparation
Before starting this feature, ensure that the microphone version configuration in the system is correct. For more details, refer to section 12.3.2 Version Confirmation.
Refer to the section 12.3.1 Large Model API Key Setup to set up the large model key.
12.3.3.3 Operation Steps
Click the terminal
Enter the following command and press Enter to launch the real-time detection feature.
ros2 launch large_models_examples vllm_with_camera.launch.py
When the command line displays the output shown below, it indicates that the voice device has printed the recognized speech. At this point, user command recording begins. Next, say the command Tell me what you saw, and wait for the large model to process it. When the command line shows the output below, it indicates that the cloud-based speech large model service has successfully processed the audio command, with the recognition result available in
publish_asr_result.
Upon receiving user input shown in the figure, the terminal will display output indicating that the cloud-based large language model has been successfully invoked. The model will interpret the command and generate a language response.
12.3.3.4 Program Outcome
Once the feature is activated, any command can be issued to the robot, for example: Tell me what you saw. The robot will automatically analyze the scene within its camera view, process the information, and describe the current environment in detail.
12.3.4.5 Program Analysis
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_with_camera.launch.py
camera_topic = LaunchConfiguration('camera_topic', default='depth_cam/rgb0/image_raw')
camera_topic_arg = DeclareLaunchArgument('camera_topic', default_value=camera_topic)
launch_arguments={'mode': mode, 'camera_topic': camera_topic}.items(),
vllm_with_camera_node = Node(
parameters=[{"camera_topic": camera_topic}],
return [mode_arg,
camera_topic_arg,
controller_launch,
depth_camera_launch,
vllm_with_camera_node,
depth_camera_launch: Uses IncludeLaunchDescription to include the depth_camera.launch.py Launch file from the large_models package and passes the mode parameter.
controller_launch: Uses IncludeLaunchDescription to include the controller.launch.py launch file from the large_models package and passes the mode parameter.
vllm_with_camera: Defines a ROS2 node from the large_models package that runs the vllm_with_camera executable and prints its output to the screen.
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_with_camera.py
1. Class Initialization
# Initialize variables
self.set_above = False
self.vllm_result = ''
self.bridge = CvBridge()
# Add debug flags
self.image_received = False
self.first_image_time = None
# Declare parameters
self.declare_parameter('camera_topic', '/ascamera/camera_publisher/rgb0/image')
camera_topic = self.get_parameter('camera_topic').value
# Log camera topic information
self.get_logger().info(f'Camera topic: {camera_topic}')
# Create callback group
# Create publishers
# Create subscribers
self.create_subscription(Image, camera_topic, self.image_callback, 1)
# Create clients
# Create initialization timer
Initialize state parameters, including the action list, VLLM processing results, running status, and interrupt flags. Create publishers, such as TTS text and chassis motion control, and subscribers to receive agent processing results, voice wake signals, and audio playback completion status. Set up service client requests for model configuration, voice wake enablement, and prompt setup, then create a timer to start the initialization process.
2. get_node_state Method
Service callback function that returns an empty response, used for querying the node’s status.
3. init_process Method
"""Initialize processing workflow"""
# Set model
msg.model_type = 'vllm'
msg.api_key = stepfun_api_key
msg.model = vllm_model
msg.api_key = vllm_api_key
msg.base_url = vllm_base_url
# Set prompt
msg.data = VLLM_PROMPT
set_servo_position(self.joints_pub, 1.0,
((1, 500), (2, 645), (3, 135), (4, 80), (5, 500), (10, 220)))
# Play startup audio
# Wait for the first image frame before starting processing thread
self.get_logger().info('Waiting for first image...')
threading.Thread(target=self.wait_and_start_process, daemon=True).start()
# Create service
Intelligently select the language model configuration, set up a multilingual visual prompt template, initialize and play the start audio cue, launch the processing thread, create a service indicating initialization completion, and finally output the startup log.
It sends a request to enable the wake-up feature once audio playback is complete.
5. process Method
def process(self):
"""Main processing loop - display images and handle VLLM results"""
# Create OpenCV window
cv2.namedWindow('image', cv2.WINDOW_NORMAL)
cv2.resizeWindow('image', display_size[0], display_size[1])
# Get image with timeout to avoid blocking indefinitely
image = self.image_queue.get(timeout=0.1)
# Handle VLLM result
if self.vllm_result:
msg = String()
msg.data = self.vllm_result
# Handle audio playback completion
msg.data = True
# Convert color space and resize
bgr_image = cv2.cvtColor(image, cv2.COLOR_RGB2BGR)
display_image = cv2.resize(bgr_image, (display_size[0], display_size[1]))
# Display image
cv2.imshow('image', display_image)
# Set window position, execute only once
if not self.set_above:
self.get_logger().warn(f'Failed to set window always on top: {e}')
self.set_above = True
# Continue loop when queue is empty
self.get_logger().error(f'Error in process loop: {e}')
# Check keyboard input
k = cv2.waitKey(1)
if k == 27 or k == ord('q'): # Press ESC or Q key to quit
self.get_logger().info('User requested quit')
# Cleanup
Continuously retrieve image frames from the image queue and monitor the outputs of the vision-language model. When a valid result is detected, convert it into a speech message and publish it via TTS, coordinating the completion status of visual recognition and voice feedback. After the task is completed, re-enable the voice wake-up function.
6. image_callback Method
"""Image callback function"""
# Convert ROS image to OpenCV format
# Record first received image
if not self.image_received:
self.image_received = True
self.first_image_time = time.time()
self.get_logger().info(f'First image received! Size: {rgb_image.shape}')
# Discard oldest image if queue is full
# Put image into the queue
self.get_logger().error(f'Error in image callback: {e}')
It converts the received ROS image messages to NumPy arrays and stores them in the queue.
12.3.4 Vision Tracking
The large model used in this lesson operates online, requiring a stable network connection for the controller during the operation.
12.3.4.1 Program Overview
When the program starts, the voice device will announce I’m ready. To activate the voice device, speak the designated wake words: Hello Hiwonder. Upon successful activation, the voice device will respond with I’m here. Once activated, voice commands can be issued, for example, Follow the person in white in front. The terminal will display the recognized command, and the voice device will respond with a generated reply after processing and executing corresponding actions.
12.3.4.2 Preparation
12.3.4.3 Operation Steps
Command input is case-sensitive and space-sensitive. The robot must be connected to the Internet, either in STA (LAN) mode or AP direct connection mode via Ethernet.
Click the terminal
Enter the following command and press Enter to launch the vision tracking feature.
ros2 launch large_models_examples vllm_track.launch.py
When the command line displays the output shown below and the device announces “I’m ready,” it indicates that the voice device has completed initialization and the YOLO model has also been initialized. At this point, say the wake word Hello Hiwonder to activate the voice device.
When the command line shows the output below and the voice device announces I’m here, it has been successfully activated. The system will begin recording your voice command.
When the command line displays the output shown below, it indicates that the voice device has printed the recognized speech. At this point, user command recording begins. Next, say the command Follow the person in white in front, and wait for the large model to process it. When the command line shows the output below, it indicates that the cloud-based speech large model service has successfully processed the audio command, with the recognition result available in
publish_asr_result.
When the terminal shows the output shown in the figure, indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 4 by speaking the wake words again.
12.3.4.4 Program Outcome
Once the feature is activated, any command can be issued to the robot, such as “Follow the person in white in front.” The robot will detect the person wearing white in its camera view and stop after reaching a preset distance.
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_track.launch.py
'sim': 'false',
vllm_track_node = Node(
executable='vllm_track',
# rqt
calibrate_rqt_reconfigure_node = Node(
package='rqt_reconfigure',
executable='rqt_reconfigure',
name='calibrate_rqt_reconfigure'
return [mode_arg,
base_launch,
vllm_track_node,
# calibrate_rqt_reconfigure_node,
slam_package_path和large_models_package_path: Retrieves the shared directory path of the slam package and the large_models package.
base_launch: Includes the robot.launch.py file from the slam package and passes the parameters sim, master_name, and robot_name.
large_models_launch: Includes the start.launch.py launch file from the large_models package and passes the node parameter.
llm_track_node: Defines a ROS2 node from the large_models package that runs the vllm_track executable and prints its output to the screen.
calibrate_rqt_reconfigure_node: An rqt_reconfigure node used for debugging.
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_track.py
PROMPT = '''
**Role
You are a smart car with advanced visual recognition capabilities. Your task is to analyze an image sent by the user, perform object detection, and follow the detected object. Finally, return the result strictly following the specified output format.
Step 1: Understand User Instructions
You will receive a sentence. From this sentence, extract the object name to be detected.
Note: Use English for the object value, do not include any objects not explicitly mentioned in the instruction.
Step 2: Understand the Image
You will also receive an image. Locate the target object in the image and return its coordinates as the top-left and bottom-right pixel positions in the form [xmin, ymin, xmax, ymax].
Note: If the object is not found, then "xyxy" should be an empty list: [], only detect and report objects mentioned in the user instruction.The coordinates (xmin, ymin, xmax, ymax) must be normalized to the range [0, 1]
**Important: Accurately understand the spatial position of the object. The "response" must reflect both the user's instruction and the detection result.
**Output Format (strictly follow this format, do not output anything else.The coordinates (xmin, ymin, xmax, ymax) must be normalized to the range [0, 1])
"object": "name",
"xyxy": [xmin, ymin, xmax, ymax],
"response": "reflect both the user's instruction and the detection result (5-30 characters)"
**Example
Input: track the person
Output:
"object": "person",
"xyxy": [0.1, 0.3, 0.4, 0.6],
"response": "I have detected a person in a white T-shirt and will track him now."
self.machine_type = os.environ['MACHINE_TYPE']
self.fps = fps.FPS() # Frame rate counter
# self.vllm_result = '''json{"object":"Red block", "xyxy":[521, 508, 637, 683]}'''
self.data = []
self.start_track = False
#cv2.namedWindow('image', 0)
#cv2.moveWindow('image', 1920 - 640, 0)
#cv2.waitKey(10)
#os.system("wmctrl -r image -b add,above")
self.camear_type = os.environ['DEPTH_CAMERA_TYPE']
self.track = ObjectTracker(use_mouse=False, automatic=True, log=self.get_logger())
self.mecanum_pub = self.create_publisher(Twist, '/controller/cmd_vel', 1) # Chassis control
image_sub = message_filters.Subscriber(self, Image, 'ascamera/camera_publisher/rgb0/image')
depth_sub = message_filters.Subscriber(self, Image, 'ascamera/camera_publisher/depth0/image_raw')
# Synchronize timestamps, allowing a time error of up to 0.03s
sync = message_filters.ApproximateTimeSynchronizer([depth_sub, image_sub], 3, 0.02)
# Define PID parameters
# 0.07, 0, 0.001
self.pid_params = {
'kp1': 0.01, 'ki1': 0.0, 'kd1': 0.00,
'kp2': 0.002, 'ki2': 0.0, 'kd2': 0.0,
# Dynamically declare parameters
for param_name, default_value in self.pid_params.items():
self.declare_parameter(param_name, default_value)
self.pid_params[param_name] = self.get_parameter(param_name).value
# Callback function for dynamic updates
self.add_on_set_parameters_callback(self.on_parameter_update)
By initializing the robot’s chassis type, frame rate monitor, and image queue, publishers for TTS text output and chassis motion control are created, along with subscribers for voice wake-up detection and receiving agent processing results. Service client requests are set up for enabling voice wake-up and configuring models. Message filters synchronize depth and RGB images. PID parameters are configured for precise target tracking control with support for dynamic parameter adjustment, and finally, a timer is created to start the initialization process.
set_servo_position(self.joints_pub, 1, ((10, 200), (5, 500), (4, 220), (3, 100), (2, 665), (1, 500)))
msg.data = PROMPT
time.sleep(1.8)
By removing the timer, a publisher is created. Based on the system’s language setting, the appropriate visual language model configuration is selected, and a dedicated prompt template is set. The stop motion command for the chassis is published, and the start prompt audio is played. At the same time, the processing thread is started, the initialization completion status service is created, and finally, the startup log information is output.
4. process Method
def process(self):
box = ''
if box:
if self.camear_type == 'aurora':
w_ = 640
h_ = 400
w_ = 640
h_ = 480
if os.environ["ASR_LANGUAGE"] == 'Chinese':
box = self.client.data_process(box, w_, h_)
box = [int(box[0] * w_), int(box[1] * h_), int(box[2] * w_), int(box[3] * h_)]
self.track.set_track_target(box, image)
self.start_track = True
speech.play_audio(start_track_audio_path, block=False)
except (ValueError, TypeError) as e:
msg = String()
speech.play_audio(track_fail_audio_path, block=False)
self.get_logger().info(e)
msg.data = True
if self.start_track:
self.data = self.track.track(image, depth_image)
image = self.data[-1]
# self.get_logger().info('twist.linear.x:{}'.format(twist.linear.x))
# self.get_logger().info('twist.angular.z:{}'.format(twist.angular.z))
if 'Acker' in self.machine_type:
steering_angle = common.set_range(twist.angular.z, -math.radians(40), math.radians(40))
if steering_angle != 0:
R = 0.145/math.tan(steering_angle)
self.result_publisher.publish(self.bridge.cv2_to_imgmsg(image, "bgr8"))
self.fps.show_fps(image)
cv2.imshow('image', image)
if key == ord('q') or key == 27: # Press Q or ESC to exit
By continuously retrieving RGB and depth image frames from the image queue, when the visual language model output is detected, the target bounding box coordinates are extracted. After coordinate transformation based on the camera type and language environment, tracking is initiated, and the start prompt sound is played. If parsing fails, a voice feedback is provided via TTS. After performing a kinematic transformation based on the robot type, the control commands are published to the chassis control topic for chassis control, with support for exiting the loop via a button press.
5. multi_callback Method
def multi_callback(self, depth_image, ros_image):
depth_frame = np.ndarray(shape=(depth_image.height, depth_image.width), dtype=np.uint16, buffer=depth_image.data)
bgr_image = np.array(self.bridge.imgmsg_to_cv2(ros_image, "bgr8"), dtype=np.uint8)
self.image_queue.put([bgr_image, depth_frame])
Convert the ROS depth image message into a depth frame in NumPy array format, while using CVBridge to convert the ROS RGB image message into an OpenCV BGR format image. If the image queue is full, first clear the queue, and then insert the processed BGR image and depth frame into the image queue.
12.3.5 Smart Home Assistant
12.3.5.1 Program Overview
When the program starts, the voice device will announce I’m ready. Then, speak the wake word Hello Hiwonder to activate the voice device, which will respond with I’m here. After activation, voice commands can be used to control the robot. For example, issuing the instruction: Go to the kitchen to see if the door is closed, then come back and tell me. Upon receiving a command, the terminal displays the recognized speech content. The voice device then verbally responds with a generated answer, and the robot simultaneously executes the corresponding action.
12.3.5.2 Preparation
Navigation Map Construction
Before enabling this feature, a map must be created in advance. Please refer to 5.1 Mapping Tutorial for detailed instructions on how to build the map.
12.3.5.3 Operation Steps
Click the terminal
Enter the following command and press Enter to launch the smart home assistant feature.
ros2 launch large_models_examples vllm_navigation.launch.py map:=map_01
When the command line displays the following output and announces “I’m ready,” it indicates that the voice device has completed initialization.
Say the wake word Hello Hiwonder.
The voice device will then respond with I’m here, signaling that it has been activated successfully. The system will begin recording your voice command.
When the command line displays the following output, it indicates that the voice device has printed the recognized speech. At this point, the system begins recording the received command. Then, give the command to the robot, for example, Go to the kitchen to see if the door is closed, then come back and tell me, and wait for the large model to process the command. When the command line shows the next output, it indicates that the cloud-based speech large model has successfully processed the voice command and parsed the audio. The parsed result will appear in the
publish_asr_result.
Upon reaching the kitchen, the system will recognize whether the door is closed.
Afterward, the robot will return to the origin position and provide a response about the door’s status, such as The door is closed.
When the terminal shows the output shown in the figure, indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 5 by speaking the wake words again.
12.3.5.4 Program Outcome
Once the feature starts, any command can be issued to the robot, such as Go to the kitchen to see if the door is closed and let me know when you come back. The robot will navigate to the designated location, check if the door is closed, and then return to the starting point to inform of the result.
12.3.5.6 Program Analysis
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_navigation.launch.py
map_name = LaunchConfiguration('map', default='map_01').perform(context)
robot_name = LaunchConfiguration('robot_name', default=os.environ['HOST'])
master_name = LaunchConfiguration('master_name', default=os.environ['MASTER'])
map_name_arg = DeclareLaunchArgument('map', default_value=map_name)
master_name_arg = DeclareLaunchArgument('master_name', default_value=master_name)
robot_name_arg = DeclareLaunchArgument('robot_name', default_value=robot_name)
PythonLaunchDescriptionSource(os.path.join(navigation_package_path, 'launch/navigation.launch.py')),
'sim': 'false',
'map': map_name,
'robot_name': robot_name,
'master_name': master_name,
'use_teb': 'true',
navigation_controller_node = Node(
executable='navigation_controller',
rviz_node = ExecuteProcess(
cmd=['rviz2', 'rviz2', '-d', os.path.join(navigation_package_path, 'rviz/navigation_controller.rviz')],
output='screen'
vllm_navigation_node = Node(
executable='vllm_navigation',
launch_setup: Used to configure and initiate the ROS 2 Launch file actions.
node = LaunchConfiguration('node', default=1): Defines a launch parameter named node, with a default value of 1.
navigation_package_path: Retrieves the shared directory path of the navigation package parigations.
large_model_package_path: Retrieves the shared directory path of the large model package large_model.
navigating_lunch: Uses IncludeLaunchDescription to include the navigation launch file navigation.launch.py, passing parameters like node_name and master_name.
vllm_navigation_node: Defines a ROS 2 node from the large_models_examples package, executing the vllm_navigation executable, and outputting to the screen.
navigating_controller_node: Defines the navigation control node from the large_models_examples package.
The program file is located at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_navigation.py
LLM_PROMPT = '''
**Role
You are a smart navigation vehicle equipped with a camera and speaker. You can move to different places, analyze visual input, and respond by playing audio. Based on user input, you need to generate the corresponding JSON command.
**Requirements
- For any user input, look up corresponding functions from the Action Function Library, and generate the proper JSON output.
- For each action sequence, include a concise (5–20 characters) and witty, varied response to make the interaction lively and engaging.
- Output only the JSON result, no analysis or extra text.
- Output format:
"response": "xx"
**Special Notes
The "action" field contains an ordered list of function names to be executed in sequence. If no matching function is found, return: "action": [].
The "response" field should contain a carefully crafted, short, humorous, and varied message (5–20 characters).
Move to a specified place: move('kitchen')
Return to starting point: move('origin')
Analyze current view: vision('What do you see?')
Play audio response: play_audio()
**Example
Input: Go to the front desk to see if the door is closed, and then come back and tell me
Output:
"action": ["move('front desk')", "vision('Is the door closed?')", "move("origin")", "play_audio()"],
"response": "On it, reporting soon!"
self.action = []
self.response_text = ''
self.play_delay = False
self.reach_goal = False
# self.create_subscription(Image, 'ascamera/camera_publisher/rgb0/image', self.image_callback, 1)
self.controller = ActionGroupController(self.create_publisher(ServosPosition, 'servo_controller', 1), '/home/ubuntu/software/arm_pc/ActionGroups')
Set up state parameters, including action list, response text, LLM processing results, and navigation target arrival status. Create publishers for TTS text publishing and subscribers for receiving agent processing results, voice wake-up signals, audio playback completion status, and navigation arrival status. At the same time, establish service client requests for voice wake-up, node settings, prompt word configuration, visual content settings, and navigation target point setup. Finally, create a timer to initiate the initialization process.
msg.data = LLM_PROMPT
self.get_logger().info('\033[1;32m%s\033[0m' % LLM_PROMPT)
After disabling the timer, configure the parameters for the large language model, including model type, API key, and base URL. Set up a dedicated prompt word template for the navigation task, wait for the navigation control system to initialize, and play the start prompt audio. At the same time, start the processing thread, create a service for the initialization completion status, and finally output the log information to indicate that the system is ready.
4. move Method
def move(self, position):
self.get_logger().info('position: %s' % str(position))
msg = SetPose2D.Request()
if position not in position_dict:
return False
p = position_dict[position]
msg.data.x = float(p[0])
msg.data.y = float(p[1])
msg.data.roll = p[2]
msg.data.pitch = p[3]
msg.data.yaw = p[4]
self.send_request(self.set_pose_client, msg)
return True
By receiving position parameters, query the corresponding coordinates and orientation information, including x, y coordinates and roll, pitch, yaw rotation angles, from the preset location dictionary. Create a SetPose2D type service request message, populate the data, and then send it to the navigation server, enabling the robot to navigate to the specified preset location.
5. reach_goal_callback Method
def reach_goal_callback(self, msg):
self.get_logger().info('reach goal')
self.reach_goal = msg.data
When the goal arrival status message published by the navigation controller is received, assign the boolean value from the message to the node’s reach_goal status flag and log the reach_goal information. This ensures synchronization of the navigation system’s state update and facilitates the subsequent task decision process.
6. vision Method
def vision(self, query):
self.controller.run_action('horizontal')
msg = SetContent.Request()
if language == 'Chinese':
msg.prompt = VLLM_PROMPT
msg.query = query
self.controller.run_action('init')
return res.message
By receiving the query parameters, the system selects the appropriate visual language model configuration based on the language setting, sets the dedicated visual prompt template and query content, then sends a request to the visual language content service and returns the model’s response message.
7. process Method
def process(self):
first = True
if self.llm_result:
msg = String()
if 'action' in self.llm_result: # If a corresponding action is returned, extract and process it
action = result['action']
for a in action:
if 'move' in a:
res = eval(f'self.{a}')
if res:
while not self.reach_goal:
if self.interrupt:
elif 'vision' in a:
self.response_text = res
self.play_audio()
elif 'play_audio' in a:
eval(f'self.{a}')
if self.interrupt:
else: # If there is no corresponding action, only respond
msg.data = True
By continuously monitoring the output of the large model, when action instructions are detected, the action list and response text are parsed. If there is a movement command, navigation is executed, and the system waits for the target point to be reached while supporting interruption. If there is a visual command, a visual query is executed and the result is recorded. If there is an audio command, the corresponding content is played, and the text response is sent to the TTS module for speech output. If only a text response is provided, it will be relayed as speech feedback. During the process, coordination between action execution and the completion status of speech playback is managed. Once the task is completed, the voice wake-up function is re-enabled, and the system waits for the next command.
12.4 Comprehensive Application of Large AI Models
12.4.1 Preparation
Firmware must be flashed to the AI voice box before running the feature.
First, connect WonderEcho Pro to the computer with a Type-C data cable.
Open PACK_UPDATE_TOOL.exe under 2. Softwares\6. Firmware Flashing Tool, select the CI1302 chip, then click Update.
The following steps use CI1302-English-SingleMic_V00916_UART0_115200_2M.bin as an example. The same procedure also applies to flashing the Chinese wake word firmware.
Click to select the firmware, then locate CI1302-English-SingleMic_V00916_UART0_115200_2M.bin under the Voice Control Basic Lesson (2025)/WonderEcho Pro/05 Appendix path.
Find the corresponding serial port and select it.
Then press the RST button on the voice interaction module to enter flashing mode. Wait until the flashing process is completed successfully.
12.4.2 Large Model API Key Setup
12.4.2.1 OpenAI Account Registration and Deployment
12.4.2.2 OpenRouter Account Registration and Deployment
12.4.2.3 API Configuration
Click
12.4.3 Vision Application with Large AI Models
12.4.3.1 Overview
When the program starts, the voice module announces I’m ready. After saying the wake word, the robot replies I’m here.
Once activated, the robot can be controlled by voice. For example, a command like Follow the black line, stop when an obstacle appears, then turn left, and finally describe what is in front of you can be spoken directly to the robot. The OpenAI ASR API converts the speech into text and passes it to the large model for processing. After the response is generated, the OpenAI API is called again to play it back and carry out the corresponding actions.
12.4.3.2 Preparation
Firmware Flashing
Reference Tutorial: 12.4.1 Preparation
Configure Large Model API-KEY
Reference Tutorial: 12.4.2 Large Model API Key Setup
12.4.3.3 Operation Steps
Open the command line terminal from the left side of the system interface.
In the terminal window, enter the following command and press Enter to stop the auto-start serviceEnter the command to disable the auto-start service of the app.
Then enter the command and press Enter to start the feature.
ros2 launch large_models_examples llm_control_progress.launch.py
When the terminal displays the output shown below and announces I’m ready, the voice device has completed initialization. At this point, say the wake word Hello Hiwonder.
When the terminal displays the corresponding output shown in the figure and the device responds with I’m here, it indicates successful activation. The system will begin recording voice commands.
When the command line displays the output shown in the image below, it indicates that the voice module is printing the recognized speech.
When the command line displays the output shown below, it means a round of conversation has finished.
To exit the feature, press Ctrl + C in the terminal. If the feature does not shut down immediately, press Ctrl + C multiple times. If it still fails, open a new terminal window and run the following command to clear the ROS node.
12.4.3.4 Project Outcome
Once the feature is activated, voice commands can be issued to the robot, enabling it to move, follow lines, and perform real-time detection.
12.4.3.5 Program Analysis
File Path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/function_calling/llm_control_progress.launch.py
1) Import library files.
os: Used for handling file paths and operating system-related functions.
ament_index_python.packages.get_package_share_directory: Retrieves the share directory path of ROS 2 package.
launch_ros.actions.Node: Used to define ROS 2 nodes.
launch.substitutions.LaunchConfiguration: Retrieves parameter values defined in the Launch file.
LaunchDescription,LaunchService: Used to define and start the Launch file.
launch.launch_description_sources.PythonLaunchDescriptionSource: Enables the inclusion of other Launch files.
launch.actions.IncludeLaunchDescription、DeclareLaunchArgument、OpaqueFunction: Used to define actions and arguments within the Launch file.
2) Define launch_setup Function
Declare launch parameters:
function_mode determines whether to start the navigation.
mode: Mode parameter, default value 1.
conf: Confidence level.
debug: Debug mode.
camera_topic: Camera topic, default depth_cam/rgb0/image_raw.
offline: Offline mode.
interruption: Interruption toggle, default False.
function_mode = LaunchConfiguration('function').perform(context)
conf = LaunchConfiguration('conf', default=0.45)
conf_arg = DeclareLaunchArgument('conf', default_value=conf)
debug = LaunchConfiguration('debug', default=False)
interruption = LaunchConfiguration('interruption', default=False)
interruption_arg = DeclareLaunchArgument('interruption', default_value=interruption)
camera_topic = LaunchConfiguration('camera_topic', default='/depth_cam/rgb0/image_raw')
offline = LaunchConfiguration('offline', default='false')
offline_arg = DeclareLaunchArgument('offline', default_value=offline)
Obtain package paths:
Retrieve paths for controller and navigation packages.
map_name: Map name.
robot_name: Robot name.
master_name: Node name.
Include launch.py files using IncludeLaunchDescription.
controller_launch: Chassis controller launch file.
peripherals_package_path: Depth camera launch file.
lidar_node_launch: LiDAR launch file.
navigation_launch: Navigation launch file.
llm_agent_progress_launch: Launch file for voice recognition, LLM processing, speech synthesis, and LLM-based control functions.
lidar_node_launch = IncludeLaunchDescription(
'sim': 'false',
'map': map_name,
'use_teb': 'true',
'sim': 'false',
'map': map_name,
'use_teb': 'true',
llm_agent_progress_launch = IncludeLaunchDescription(
os.path.join(get_package_share_directory('large_models_examples'), 'large_models_examples/function_calling/llm_agent_progress.launch.py')),
Starting Nodes:
line_following_node: Line-following node.
object_tracking_node: Color-tracking node.
navigation_controller_node: Navigation controller node.
rviz_node: Visualization node.
line_following_node = Node(
package='app',
executable='line_following',
# parameters=[{'debug': True}],
object_tracking_node = Node(
package='app',
executable='object_tracking',
output='screen'
3) Define generate_launch_description Function
This function generates a Launch description. The OpaqueFunction is used to add the launch_setup function to the Launch description, allowing the function parameter to be passed.
return LaunchDescription([
'function',
default_value='default',
description='The function to execute'),
4) Main Program Entry
ls = LaunchService()
ls.run()
ld = generate_launch_description() generates the Launch description object.
ls = LaunchService() creates a Launch service object.
ls.include_launch_description(ld) adds the Launch description to the Launch service.
ls.run() starts the Launch service and executes all defined Launch actions.
File Path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/function_calling/llm_control.py
1) tools list
Defines 12 LLM tool functions:
get_pixel_distance: Retrieves depth distance in pixels.
get_obejct_pixel: Identifies an object and gets its pixel position.
get_available_locations: Gets a list of navigable locations.
get_current_location: Retrieves the current location.
describe_current_view: Describes the current view.
move_to_location: Navigates to a specified location.
line_following: Performs color-based line following.
lidar_scan_detect: Detects obstacles using LiDAR.
object_track_detect: Tracks objects.
color_track: Tracks colors.
robot_move_control: Controls robot movement directly.
get_object_box: Retrieves the bounding box of an object.
tools = [
"type": "function",
"function": {
"name": "get_pixel_distance",
"description": "Get depth distance of one or more specified pixel positions",
"parameters": {
"type": "object",
"properties": {
"pixel_position": {
"type": "string",
"description": "JSON string containing one or more pixel coordinate lists",
"required": ["pixel_position"],
"type": "function",
"function": {
"name": "get_obejct_pixel",
"description": "Identify objects and get their pixel positions",
"parameters": {
"type": "object",
"properties": {
"content": {
"type": "string",
"description": "User's question",
"required": ["content"],
"type": "function",
"function": {
"name": "get_available_locations",
"description": "Query and list all predefined locations the robot can navigate to",
"parameters": {
"type": "object",
"properties": {}
"type": "function",
"function": {
"name": "get_current_location",
"description": "Query and get the robot's current precise position and orientation on the map",
"parameters": {
"type": "object",
"properties": {}
"type": "function",
"function": {
"name": "describe_current_view",
"description": "Describe in detail what the robot camera currently sees to answer user's specific questions",
"parameters": {
"type": "object",
"properties": {
"question": {
"type": "string",
"description": "Specific questions about the current view",
"required": ["question"]
{ "type": "function",
"function": {
"name": "move_to_location",
"description": "Move the robot to specified location",
"parameters": {
"type": "object",
"properties": {
"destination": {
"type": "string",
"description": "Target location name",
"enum": ["study_room","bedroom","fruit_supermarket","kitchen","sorting_station_3"]
"required": ["destination"],
"type": "function",
"function": {
"name": "line_following",
"description": "Command robot to follow line of specified color",
"parameters": {
"type": "object",
"properties": {
"color": {
"type": "string",
"description": "Color to follow",
"enum": ["red", "green", "blue", "black", "yellow"]
"required": ["color"]
"type": "function",
"function": {
"name": "lidar_scan_detect",
"description": "Obstacle detection during line following based on LiDAR scan",
"parameters": {
"type": "object",
"properties": {
"scan_detect": {
"type": "string",
"description": "Obstacle detection result",
"required": ["scan_detect"],
"type": "function",
"function": {
"name": "object_track_detect",
"description": "Object tracking command, note that only when the robot is sure to track the object, and no need to specify a specific color. Need to get the target object position in the image line pixel square.",
"parameters": {
"type": "object",
"properties": {
"box": {
"type": "string",
"description": "Return the position of the target in the frame as a bounding box, such as [xmin, ymin, xmax, ymax]",
"required": ["box"]
"type": "function",
"function": {
"name": "color_track",
"description": "Command robot to track object of specified color",
"parameters": {
"type": "object",
"properties": {
"color": {
"type": "string",
"description": "Color of object to track",
"type": "function",
"function": {
"name": "robot_move_control",
"description": "Move robot with specified linear speed and angular speed for a certain time, it takes 8s to rotate 90°",
"parameters": {
"type": "object",
"properties": {
"linear_x": {
"type": "number",
"description": "Linear velocity in X direction",
"linear_y": {
"type": "number",
"description": "Linear velocity in Y direction",
"angular_z": {
"type": "number",
"description": "Angular velocity in Z direction",
"duration": {
"type": "number",
"description": "Movement duration",
"required": ["linear_x", "linear_y", "angular_z", "duration"]
"type": "function",
"function": {
"name": "get_object_box",
"description": "Command robot to track specific target object",
"parameters": {
"type": "object",
"properties": {
"obj_track": {
"type": "string",
"required": ["obj_track"]
2) Location Dictionary
Stores locations and their corresponding coordinates using a dictionary.
position_dict = {
"study_room": [1.2, -0.8, 0.0, 0.0, 80.0],
"bedroom": [1.38, 0.50, 0.0, 0.0, 10.0],
"fruit_supermarket": [3.02, -0.49, 0.0, 0.0, -90.0],
"kitchen": [0.05, 0.0, 0.0, 0.0, 0.0],
"sorting_station_3": [1.15, 0.1, 0.0, 0.0, 0.0],
3) Prompt Templates
Defines the LLM roles and workflow.
content_string = textwrap.dedent("""
# Role setting
You are a real interactive robot, need to execute tasks according to user instructions,
and interact with users in a friendly way, just like chatting with friends.
## Workflow
1. **Task Planning:** Before starting a task, you need to break it down and plan it.
The steps will be presented in a numbered format, with each number representing an independent step.
2. **Tool Usage:** Before each tool is used, you need to provide an explanation, no more than 20 words,
describing the feedback in a humorous and varied way to make the communication process more engaging.
3. **Feedback Processing:** After the tool is used, you need to follow up with a commentary on the feedback results,
no more than 20 words, describing the feedback in a humorous and varied way to make the communication process more engaging.
4. **Task Completion:** After all task steps have been completed, provide a summary explanation, no more than 40 words.
Object detection prompts.
PROMPT = '''
As an image recognition expert, your capability is to accurately locate objects in images sent by users through object detection, and output the final results according to the "Output Format".
## 1. Understand User Instructions
I will give you a sentence. You need to make the best decision based on my words and extract the "object name" from the decision. **The name corresponding to the object must be in English**, **do not output objects that are not mentioned**.
## 2. Understand the Image
I will give you an image. Analyze the image and identify all recognizable objects within it.
For each identified object, calculate the center point coordinates of the object. **Do not output objects that are not mentioned**.
【Special Note】: Deeply understand the positional relationships of objects.
## Output Format (Please only output the following content, do not say any extra words)
"object": name_1,
"center_xy": [center_x_1, center_y_1]
"object": name_2,
"center_xy": [center_x_2, center_y_2]
Object tracking prompts.
OBJ_TRACK_PROMPT = '''
As an intelligent vehicle, skilled in image recognition, your capability is to accurately locate objects in images sent by users through object detection, output the final results according to the "Output Format", and then perform tracking.
I will give you a sentence. You need to extract the "object name" from my words. **The name corresponding to the object must be in English**, **do not output objects that are not mentioned**.
I will give you an image. From this image, find the pixel coordinates of the top-left and bottom-right corners of the object corresponding to the "object name". If not found, then xyxy should be []. **Do not output objects that are not mentioned**.
【Special Note】: Deeply understand the positional relationships of objects. The response needs to combine the user's instruction and the detection results.
"object": "name",
4) Log Colors
class LogColors:
RESET = '\033[0m'
BOLD = '\033[1m'
YELLOW = '\033[93m'
BLUE = '\033[94m'
GREEN = '\033[92m'
CYAN = '\033[96m'
5) Initialization Configuration
self.initialize_variables() # Initialization of variables
self.setup_ros_components() # Setup of ROS components
self.setup_services_and_clients() # Setup of services and clients
self.setup_subs_and_pubs() # Setup of subscribers and publishers
self.setup_timers() # Setup of timers
Initializes variables.
def initialize_variables(self):
"""Initialize all class variables"""
self.language = os.environ.get('ASR_LANGUAGE')
self.tools = []
self.current_pose = None
self.saved_pose = None
self.obstacle_detected = False
self.action = []
self.is_task_running = False
self.cb_group = ReentrantCallbackGroup()
# Lock
self.draw_lock = threading.Lock()
self.draw_flag = False
# Line following related variables
self.line_following_count = 0
self.line_following_start = True
self.current_left = 0.0
self.current_right = 0.0
# Object tracking related variables
self.track_box_p1 = None
self.track_box_p2 = None
self.object_detect_box = False
self.get_box_flag = False
self.box = None
# Image queue
self.image_pair_queue = queue.Queue(maxsize=2)
6) Vision Perception Module
Image Synchronization: Uses message_filters to synchronize RGB and depth images, with a queue size of 2.
def image_sync_callback(self, ros_image, ros_depth_image):
"""Synchronized image callback"""
bgr_image = self.bridge.imgmsg_to_cv2(ros_image, "bgr8")
depth_image = np.ndarray(
shape=(ros_depth_image.height, ros_depth_image.width),
dtype=np.uint16,
buffer=ros_depth_image.data
if self.image_pair_queue.full():
self.image_pair_queue.get()
self.image_pair_queue.put((bgr_image, depth_image))
self.get_logger().error(f"Image sync error: {str(e)}")
Depth Measurement: Computes the average depth within a 5×5 ROI, filtering out anomalies.
def get_pixel_distance(self, pixel_coords_list):
"""Get pixel distance"""
_, depth_image = self.image_pair_queue.get()
distances = []
for pixel_xy in pixel_coords_list:
x, y = pixel_xy
roi = [y, y + 5, x, x + 5]
img_h, img_w = depth_image.shape[:2]
if roi[0] < 0: roi[0] = 0
if roi[1] > img_h: roi[1] = img_h
if roi[2] < 0: roi[2] = 0
if roi[3] > img_w: roi[3] = img_w
roi_distance = depth_image[roi[0]:roi[1], roi[2]:roi[3]]
valid_distances = roi_distance[np.logical_and(roi_distance > 0, roi_distance < 30000)]
if len(valid_distances) > 0:
distance = round(float(np.mean(valid_distances) / 1000.0), 3)
distance = 0.0
distances.append(distance)
return str(distances)
self.get_logger().error(f"Get pixel distance error: {str(e)}")
return "[]"
Object Detection: Uses the vision LLM qwen-vl-max-latest for object detection and extracts JSON results.
def get_obejct_pixel(self, user_query):
"""Get object pixel position"""
rgb_image, _ = self.image_pair_queue.get()
vllm_result_str = self.client.vllm(user_query, rgb_image, prompt=PROMPT, model='qwen-vl-max-latest')
# Extract JSON part
if "```json" in vllm_result_str:
json_part = vllm_result_str.split("```json")[1].split("```")[0]
detected_objects = json.loads(json_part.strip())
return str(detected_objects)
self.get_logger().error(f"Get object pixel error: {str(e)}")
return "[]"
7) Navigation Module
Performs location-based navigation.
def move_to_location(self, destination):
"""Move to specified location"""
if destination not in position_dict:
return f"Move failed: Unknown destination '{destination}'."
p = position_dict[destination]
msg.data.yaw = p[4]
self.get_logger().info(f"Navigation goal '{destination}' sent. Waiting for arrival...")
# Wait for reaching goal
if self.reach_goal:
return f"Arrived at {destination}"
return f"Timeout, failed to reach {destination}"
8) Main Processing Loop
Retrieves tools from self.tools, executes them, and publishes the results.
def process(self):
"""Main processing loop"""
if self.tools:
tool_id, tool_name, args_dict = self.tools
res = None
if tool_name == 'get_obejct_pixel':
content = args_dict.get('content')
if content:
res = self.get_obejct_pixel(content)
elif tool_name == 'get_pixel_distance':
position_str = args_dict.get('pixel_position')
if position_str:
positions_list = ast.literal_eval(position_str)
if (isinstance(positions_list, list) and
all(isinstance(p, list) and len(p) == 2 for p in positions_list)):
res = self.get_pixel_distance(positions_list)
elif tool_name == 'move_to_location':
destination = args_dict.get('destination')
if destination:
res = self.move_to_location(destination)
elif tool_name == 'describe_current_view':
question = args_dict.get('question')
if question:
res = self.describe_current_view(question)
elif tool_name == 'get_available_locations':
res = self.get_available_locations()
elif tool_name == 'get_current_location':
res = self.get_current_location()
elif tool_name == 'line_following':
color = args_dict.get('color')
if color:
res = self.line_following(color)
elif tool_name == 'color_track':
if color:
res = self.color_track(color)
elif tool_name == 'object_track_detect':
box = args_dict.get('box')
if box:
res = self.object_track_detect(box)
elif tool_name == 'lidar_scan_detect':
scan_detect = args_dict.get('scan_detect')
if scan_detect:
res = self.lidar_scan_detect(scan_detect)
elif tool_name == 'robot_move_control':
if all(k in args_dict for k in ["linear_x", "linear_y", "angular_z", "duration"]):
res = self.robot_move_control(
linear_x=args_dict['linear_x'],
linear_y=args_dict['linear_y'],
angular_z=args_dict['angular_z'],
duration=args_dict['duration']
elif tool_name == 'get_object_box':
obj_track = args_dict.get('obj_track')
if obj_track:
res = self.get_object_box(obj_track)
if res is not None:
self.tools_result_pub.publish(Tools(id=tool_id, name=tool_name, data=res))
self.get_logger().error(f"Tool {tool_name} execution error: {str(e)}")
res = f"The tool execution error: {str(e)}"
self.tools = []
time.sleep(0.02)
9) Display Thread
Visualizes RGB and depth images and draws tracking boxes.
def display_thread(self):
"""Show thread"""
rgb_image, depth_image = self.image_pair_queue.get(block=True, timeout=1)
result_image = rgb_image.copy()
sim_depth_image = np.clip(depth_image, 0, 2000).astype(np.float64)
sim_depth_image = sim_depth_image / 2000.0 * 255.0
depth_color_map = cv2.applyColorMap(sim_depth_image.astype(np.uint8), cv2.COLORMAP_JET)
with self.draw_lock:
if self.draw_flag:
# Object tracking drawing
if self.start_track and self.track_box_p1 is not None and self.track_box_p2 is not None:
cv2.rectangle(result_image, self.track_box_p1, self.track_box_p2, (0, 255, 0), 2)
result_image = np.concatenate([result_image, depth_color_map, ], axis=1)
cv2.imshow("result_image", result_image)
self.get_logger().error(f"Display thread error: {str(e)}")
10) Object Tracking Thread
Uses CUDA acceleration for tracking and publishes velocity commands.
def object_track_thread(self):
"""Object tracking thread"""
# Create new CUDA context in current thread
dev = cuda.Device(0)
ctx = dev.make_context()
model_path = os.path.split(os.path.realpath(__file__))[0]
back_exam_engine_path = os.path.join(model_path, "../resources/models/nanotrack_backbone_exam.engine")
back_temp_engine_path = os.path.join(model_path, "../resources/models/nanotrack_backbone_temp.engine")
head_engine_path = os.path.join(model_path, "../resources/models/nanotrack_head.engine")
tracker = Tracker(back_exam_engine_path, back_temp_engine_path, head_engine_path)
image, depth_image = self.image_pair_queue.get(block=True)
img_h, img_w, _ = image.shape
if self.box is not None and len(self.box) > 0 and self.object_detect_box:
# Convert to [x, y, width, height] format
box_wh = [self.box[0], self.box[1], self.box[2] - self.box[0], self.box[3] - self.box[1]]
self.track.set_track_target(tracker, box_wh, image)
self.box = []
if self.start_track and self.is_task_running:
self.data = self.track.track(tracker, image, depth_image)
self.track_box_p1 = self.data[2]
self.track_box_p2 = self.data[3]
self.track_box_p1 = (max(0, self.track_box_p1[0]), min(img_w-1, self.track_box_p1[1]))
self.track_box_p2 = (max(0, self.track_box_p2[0]), min(img_h-1, self.track_box_p2[1]))
if isinstance(self.data[0], (int, float)) and isinstance(self.data[1], (int, float)):
twist.linear.x, twist.angular.z = float(self.data[0]), float(self.data[1])
if twist.angular.z < -math.radians(40):
twist.angular.z = -math.radians(40)
elif twist.angular.z > math.radians(40):
twist.angular.z = math.radians(40)
steering_angle = twist.angular.z
R = 0.145 / math.tan(steering_angle)
twist.angular.z = twist.linear.x / R
self.cmd_vel_pub.publish(twist)
self.get_logger().warn(f"Invalid track data: {self.data[0]}, {self.data[1]}")
self.get_logger().error(f"Object track thread error: {str(e)}")
# Ensure context is properly released
ctx.pop()
11) def main() Function
Create the node, run with a multithreaded executor, and finally destroy the node.
node = LLMControlMove('llm_control')
12.5 Offline Large AI Model Applications
12.5.1 Preparation
Change the ASR Mode to offline.
Then, click Save.
A Save Success message will confirm that the configuration has been stored in the system environment.
Then, click Quit to close the interface.
12.5.2 Offline Large AI Model Basic Course
12.5.2.1 Speech-to-Text Test
Working Principle
This section demonstrates offline real-time speech recognition using sherpa-onnx. Audio is captured from the voice module via sounddevice in 100 ms chunks. Recognition is performed locally using a pre-trained transducer model with encoder, decoder, and joiner components. Endpoint detection is used to determine when speech ends based on trailing silence duration and utterance length. Once an endpoint is detected, the final recognition result is output and the recognition stream is reset. The process is handled in a streaming manner, updating intermediate results every 100 ms and displaying them in real time on the terminal.
Reference Tutorial: 12.5.1 Preparation.
Operation Steps
1) Open the command line terminal
from the left sidebar. Disable the app auto-start service and navigate to the ~/third_party/sherpa-onnx directory.
cd ~/third_party/sherpa-onnx
2) Run the command to start the speech-to-text test.
python3 python-api-examples/speech-recognition-from-microphone-with-endpoint-detection.py \
--encoder ./sherpa-onnx-streaming-zipformer-zh-xlarge-int8-2025-06-30/encoder.int8.onnx \
--decoder ./sherpa-onnx-streaming-zipformer-zh-xlarge-int8-2025-06-30/decoder.onnx \
--joiner ./sherpa-onnx-streaming-zipformer-zh-xlarge-int8-2025-06-30/joiner.int8.onnx \
--tokens ./sherpa-onnx-streaming-zipformer-zh-xlarge-int8-2025-06-30/tokens.txt
3) When the prompt below appears, the voice module is ready to receive audio input.
4) If text starts appearing as shown, the voice module is working properly.
5) If no text is displayed, adjust the audio settings:
Open the dropdown ① and select Settings.
Go to Sound, set Output Device to Speakers-USB Audio Device and Input to Analog Input-XFM-DP-V0.0.18, and close the settings after making the changes.
File Path: /home/ubuntu/third_party/sherpa-onnx/python-api-examples/speech-recognition-from-microphone-with-endpoint-detection.py.
import argparse
from pathlib import Path
import sounddevice as sd
except ImportError:
print("Please install sounddevice first. You can use")
print()
print(" pip install sounddevice")
print()
print("to install it")
sys.exit(-1)
import sherpa_onnx
2) def assert_file_exists(filename: str)
Checks whether a model file exists using Path. If the file is missing, a download link is provided.
def assert_file_exists(filename: str):
assert Path(filename).is_file(), (
f"{filename} does not exist!\n"
"Please refer to "
"https://k2-fsa.github.io/sherpa/onnx/pretrained_models/index.html to download it"
3) def get_args()
Parameter categories:
Required parameters: --tokens, --encoder, --decoder, and --joiner, all specifying the paths to the model files.
Optional parameters:
--decoding-method: Decoding method, default is greedy_search.
--provider: Compute backend, options include cpu, cuda, and coreml.
--hotwords-file: Hotword file to improve recognition of specific terms.
--hotwords-score: Weight for hotwords.
--blank-penalty: Penalty for blank symbols.
--hr-lexicon, --hr-rule-fsts: Homophone replacement related.
def get_args():
parser = argparse.ArgumentParser(
formatter_class=argparse.ArgumentDefaultsHelpFormatter
parser.add_argument(
"--tokens",
type=str,
required=True,
help="Path to tokens.txt",
"--encoder",
type=str,
required=True,
help="Path to the encoder model",
"--decoder",
type=str,
required=True,
help="Path to the decoder model",
"--joiner",
type=str,
required=True,
help="Path to the joiner model",
"--decoding-method",
type=str,
default="greedy_search",
help="Valid values are greedy_search and modified_beam_search",
"--provider",
type=str,
default="cpu",
help="Valid values: cpu, cuda, coreml",
"--hotwords-file",
type=str,
default="",
help="""
The file containing hotwords, one words/phrases per line, and for each
phrase the bpe/cjkchar are separated by a space. For example:
▁HE LL O ▁WORLD
"--hotwords-score",
type=float,
default=1.5,
help="""
The hotword score of each token for biasing word/phrase. Used only if
--hotwords-file is given.
"--blank-penalty",
type=float,
default=0.0,
help="""
The penalty applied on blank symbol during decoding.
Note: It is a positive value that would be applied to logits like
this `logits[:, 0] -= blank_penalty` (suppose logits.shape is
[batch_size, vocab] and blank id is 0).
"--hr-lexicon",
type=str,
default="",
help="If not empty, it is the lexicon.txt for homophone replacer",
"--hr-rule-fsts",
type=str,
default="",
help="If not empty, it is the replace.fst for homophone replacer",
return parser.parse_args()
4) def create_recognizer(args)
Function to create the recognizer.
Key settings:
Model type: Transducer (encoder, decoder, joiner).
Sample rate: 16 kHz, used internally by the model.
Feature dimension: 80 for Mel spectrogram features.
Endpoint detection: Enabled.
Rule 1: Trailing silence ≥ 2.4 s.
Rule 2: Trailing silence ≥ 1.2 s.
Rule 3: Utterance length ≥ 300, currently disabled.
def create_recognizer(args):
assert_file_exists(args.encoder)
assert_file_exists(args.decoder)
assert_file_exists(args.joiner)
assert_file_exists(args.tokens)
# Please replace the model files if needed.
# See https://k2-fsa.github.io/sherpa/onnx/pretrained_models/index.html
# for download links.
recognizer = sherpa_onnx.OnlineRecognizer.from_transducer(
tokens=args.tokens,
encoder=args.encoder,
decoder=args.decoder,
joiner=args.joiner,
num_threads=1,
sample_rate=16000,
feature_dim=80,
enable_endpoint_detection=True,
rule1_min_trailing_silence=2.4,
rule2_min_trailing_silence=1.2,
rule3_min_utterance_length=300, # it essentially disables this rule
decoding_method=args.decoding_method,
provider=args.provider,
hotwords_file=args.hotwords_file,
hotwords_score=args.hotwords_score,
blank_penalty=args.blank_penalty,
hr_rule_fsts=args.hr_rule_fsts,
hr_lexicon=args.hr_lexicon,
return recognizer
5) def main()
Parses parameters and detects devices.
args = get_args()
devices = sd.query_devices()
if len(devices) == 0:
print("No microphone devices found")
sys.exit(0)
print(devices)
Creates the recognizer and display objects, then starts the audio capture loop.
recognizer = create_recognizer(args)
print("Started! Please speak")
Starts the audio capture loop at 48 kHz, reading 100 ms of audio each time, which equals 4800 samples.
sample_rate = 48000
samples_per_read = int(0.1 * sample_rate) # 0.1 second = 100 mspy
Feeds audio into the recognition stream for decoding.
stream = recognizer.create_stream()
display = sherpa_onnx.Display()
The audio capture loop runs at 48 kHz, reading 100 ms of audio at a time, which is 4800 samples. The data is fed into the recognition stream for decoding, endpoints are checked to obtain results, and intermediate outputs are displayed in real time. When an endpoint is detected, the current sentence is finalized and the recognition stream is reset.
with sd.InputStream(channels=1, dtype="float32", samplerate=sample_rate) as s:
samples, _ = s.read(samples_per_read) # a blocking read
samples = samples.reshape(-1)
stream.accept_waveform(sample_rate, samples)
while recognizer.is_ready(stream):
recognizer.decode_stream(stream)
is_endpoint = recognizer.is_endpoint(stream)
result = recognizer.get_result(stream)
display.update_text(result)
display.display()
if is_endpoint:
if result:
display.finalize_current_sentence()
display.display()
recognizer.reset(stream)
12.5.2.2 Text-to-Speech Test
Working Principle
The system uses a client-server setup, where the client communicates with the local Ollama service through an API to convert text into speech offline.
Operation Steps
from the left sidebar, enter the command to disable the app auto-start service.
2) Enter the command to start the offline large AI model server.
ollama serve
3) Right-click and select Split Vertically to open a second terminal.
4) Enter the command to run the text-to-speech program.
cd ~/large_models
python3 offline_tts_demo.py
5) After running the program, the output appears as shown below, and the voice module plays Hello, what can I help you.
File Path: /home/ubuntu/large_models/offline_tts_demo.py.
1) Import modules.
from config import *
from speech import speech
import sherpa_onnx
2) Initialize configuration.
Set the volume.
speech.set_volume(80)
Set the language to English.
language = 'Chinese'
Model path.
sherpa_onnx_path = os.path.join(Path.home(), 'third_party/sherpa-onnx')
offline_tts = 'matcha-icefall-zh-baker'
model_path = f'{sherpa_onnx_path}/{offline_tts}'
tts = speech.OfflineRealTimeTTS(
provider="cuda",
debug=1,
matcha_acoustic_model=os.path.join(model_path, 'model-steps-3.onnx'),
matcha_vocoder=os.path.join(sherpa_onnx_path, 'vocos-22khz-univ.onnx'),
matcha_lexicon=os.path.join(model_path, 'lexicon.txt'),
matcha_tokens=os.path.join(model_path, 'tokens.txt'),
tts_rule_fsts=f'{model_path}/phone.fst,{model_path}/date.fst,{model_path}/number.fst',
sherpa = sherpa_onnx
4) English Model
Configure parameters using VITS.
offline_tts = 'vits-ljs'
provider="cuda",
debug=1,
vits_model=os.path.join(model_path, f'{offline_tts}.onnx'),
vits_lexicon=os.path.join(model_path, 'lexicon.txt'),
vits_tokens=os.path.join(model_path, 'tokens.txt'),
5) Example
tts.tts('Hello, what can I help you', block=True)
12.5.2.3 Large AI Model Invocation
Working Principle
Uses a client-server architecture. The client communicates with the local Ollama service via API. By defining roles and tasks, the model interprets the context and generates structured outputs in the required format, leveraging its ability to follow instructions and produce structured responses.
Operation Steps
ollama serve
4) Enter the command to launch the demo script for large-model calls.
cd ~/large_models
python3 offline_llm_demo.py
5) Once the script is running, the terminal shows the output as illustrated.
File Path: /home/ubuntu/large_models/offline_llm_demo.py.
1) The prompt template.
PROMPT = '''
##Role Task
You are an intelligent robot car that can control the linear velocity in the x and y directions (in m/s), the angular velocity in the z direction (in rad/s), and time (t) in seconds. Based on the input, generate the corresponding commands.
##Requirements
1. Ensure the speed range is correct:
Linear velocity: x, y ∈ [-1.0, 1.0] (negative values represent reverse direction)
Angular velocity: z ∈ [-1.0, 1.0] (counterclockwise is positive, clockwise is negative)
2. Execute multiple actions sequentially and output an action list containing multiple movement commands. Add [0.0, 0.0, 0.0, 0.0] only after the last action to ensure the robot stops.
3. x and y default to 0.2, z defaults to 1, t defaults to 2.
4. For each action sequence, craft a concise (5 to 10 words), witty, and endlessly varied feedback message to make the interaction fun.
5. Output the json result directly without analysis or additional content.
6. Format:
"action": [[x1, y1, z1, t1], [x2, y2, z2, t2], ..., [0.0, 0.0, 0.0, 0.0]],
"response": "xx"
7. Strong mathematical computation ability.
8. Note that drifting involves movement, rotation, and combination, requiring precise calculation, for example [0.0, -0.2, 1.0, 2.0].
##Notes
- The "action" key contains an array of function name strings ordered by execution sequence. If the corresponding action function is not found, the action will output [].
- The "response" key contains a carefully crafted short reply that perfectly fits the above word count and style requirements.
##Example Task
Input: Move forward for 2 seconds, then rotate clockwise for 1 second.
Output: {"action": [[0.2, 0.0, 0.0, 2.0], [0.0, 0.0, -1.0, 1.0], [0, 0, 0.0, 0.0]], "response": "Move forward for 2 seconds, then rotate clockwise for 1 second, go!"}
Input: Move forward 1 meter.
Output: {"action": [[0.2, 0.0, 0.0, 5.0], [0.0, 0.0, 0.0, 0.0]], "response": "OK."}
2) The message format used in Chat API mode.
params = {"model": 'qwen3:1.7b',
"messages": [
"role": "system",
"content": PROMPT
"role": "user",
"content": user_input
3) Sending a request to the local ollama server.
client.llm_origin(params)
12.5.2.4 Semantic Understanding
Working Principle
The system uses a client–server setup to interact with the local ollama service. The model processes a prepared text passage and generates a concise semantic summary.
Operation Steps
ollama serve
4) Enter the command to run the program.
cd ~/large_models
python3 offline_llm_nlu_demo.py
12.5.2.5 Emotion Perception
Working Principle
The system uses a client–server setup to communicate with the local ollama service. The model receives short emotion-related descriptions and generates its interpretation, allowing an evaluation of its ability to recognize emotional cues.
Operation Steps
ollama serve
cd ~/large_models
python3 offline_llm_er_demo.py
File Path: /home/ubuntu/large_models/offline_llm_er_demo.py.
1) Initialize the API client.
client = speech.OllamaAPI(ollama_host)
2) Send the emotion-related prompt to the ollama server.
messages = [{"role": "user", "content": 'Annoying'}]
assistant_output = client.llm_multi_turn(messages, model='qwen3:1.7b')
3) Store the dialogue history from the previous turn.
messages.append({"role": "assistant", "content": assistant_output})
4) Proceed to the next turn.
Call llm_multi_turn again with the full conversation history included.
messages.append({"role": "user", "content": 'Laughing'})
12.5.2.6 Recording Test
Working Principle
Operation Steps
2) Enter the command to start the streaming ASR server.
python3 third_party/sherpa-onnx/python-api-examples/streaming_server.py \
--tokens=third_party/sherpa-onnx/sherpa-onnx-streaming-zipformer-zh-xlarge-int8-2025-06-30/tokens.txt \
--encoder=third_party/sherpa-onnx/sherpa-onnx-streaming-zipformer-zh-xlarge-int8-2025-06-30/encoder.int8.onnx \
--decoder=third_party/sherpa-onnx/sherpa-onnx-streaming-zipformer-zh-xlarge-int8-2025-06-30/decoder.onnx \
--joiner=third_party/sherpa-onnx/sherpa-onnx-streaming-zipformer-zh-xlarge-int8-2025-06-30/joiner.int8.onnx \
--doc-root=third_party/sherpa-onnx/python-api-examples/web
4) Enter the command to launch the audio-recording program.
cd ~/large_models
python3 offline_asr_demo.py
5) Once Recording······ appears, the module has started capturing audio and speech input can be provided. The recognized text will be printed in the terminal, as shown in the figure.
6) The recorded audio can be played from the path ~/large_models/resources/audio.
cd ~/large_models/resources/audio
aplay test_recording.wav
Streaming ASR server script path: /home/ubuntu/third_party/sherpa-onnx/python-api-examples/streaming_server.py.
Audio recording script path: /home/ubuntu/large_models/offline_asr_demo.py.
Audio file path: /home/ubuntu/large_models/resources/audio/test_recording.wav.
Streaming ASR Server streaming_server.py Program Analysis:
Client → WebSocket → Receive audio → Recognition stream → Queue → Batch processing → Recognizer decoding → Return results → Client.
1) Import modules.
import argparse
import asyncio
import http
import json
import logging
import socket
import ssl
from concurrent.futures import ThreadPoolExecutor
from datetime import datetime
from typing import List, Optional, Tuple
import sherpa_onnx
import websockets
from http_server import HttpServer
2) Configure the logging system.
Logs include timestamps and filenames, output to both file and console.
def setup_logger(
log_filename: str,
log_level: str = "info",
use_console: bool = True,
) -> None:
"""Setup log level.
Args:
log_filename:
The filename to save the log.
log_level:
The log level to use, e.g., "debug", "info", "warning", "error",
"critical"
use_console:
True to also print logs to console.
now = datetime.now()
date_time = now.strftime("%Y-%m-%d-%H-%M-%S")
formatter = "%(asctime)s %(levelname)s [%(filename)s:%(lineno)d] %(message)s"
log_filename = f"{log_filename}-{date_time}.txt"
Path(log_filename).parent.mkdir(parents=True, exist_ok=True)
level = logging.ERROR
if log_level == "debug":
level = logging.DEBUG
elif log_level == "info":
level = logging.INFO
elif log_level == "warning":
level = logging.WARNING
elif log_level == "critical":
level = logging.CRITICAL
logging.basicConfig(
filename=log_filename,
format=formatter,
level=level,
filemode="w",
if use_console:
console = logging.StreamHandler()
console.setLevel(level)
console.setFormatter(logging.Formatter(formatter))
logging.getLogger("").addHandler(console)
3) Model parameters.
def add_model_args(parser: argparse.ArgumentParser):
"--encoder",
type=str,
help="Path to the transducer encoder model",
"--decoder",
type=str,
help="Path to the transducer decoder model.",
"--joiner",
type=str,
help="Path to the transducer joiner model.",
"--zipformer2-ctc",
type=str,
help="Path to the model file from zipformer2 ctc",
"--wenet-ctc",
type=str,
help="Path to the model.onnx from WeNet",
"--paraformer-encoder",
type=str,
help="Path to the paraformer encoder model",
"--paraformer-decoder",
type=str,
help="Path to the paraformer decoder model.",
"--tokens",
type=str,
required=True,
"--sample-rate",
type=int,
default=16000,
help="Sample rate of the data used to train the model. "
"Caution: If your input sound files have a different sampling rate, "
"we will do resampling inside",
"--feat-dim",
type=int,
default=80,
help="Feature dimension of the model",
"--provider",
type=str,
default="cpu",
4) Decoding parameters.
def add_decoding_args(parser: argparse.ArgumentParser):
type=str,
help="""Decoding method to use. Current supported methods are:
- greedy_search
- modified_beam_search
add_modified_beam_search_args(parser)
5) Endpoint detection parameters.
def add_endpointing_args(parser: argparse.ArgumentParser):
"--use-endpoint",
type=int,
default=1,
help="1 to enable endpoiting. 0 to disable it",
"--rule1-min-trailing-silence",
type=float,
default=2.4,
help="""This endpointing rule1 requires duration of trailing silence
in seconds) to be >= this value""",
"--rule2-min-trailing-silence",
type=float,
default=1.2,
help="""This endpointing rule2 requires duration of trailing silence in
seconds) to be >= this value.""",
"--rule3-min-utterance-length",
type=float,
default=20,
help="""This endpointing rule3 requires utterance-length (in seconds)
6) Server parameters.
"--port",
type=int,
default=6006,
help="The server will listen on this port",
"--nn-pool-size",
type=int,
default=1,
help="Number of threads for NN computation and decoding.",
"--max-batch-size",
type=int,
default=3,
help="""Max batch size for computation. Note if there are not enough
requests in the queue, it will wait for max_wait_ms time. After that,
even if there are not enough requests, it still sends the
available requests in the queue for computation.
"--max-wait-ms",
type=float,
default=10,
help="""Max time in millisecond to wait to build batches for inference.
If there are not enough requests in the stream queue to build a batch
of max_batch_size, it waits up to this time before fetching available
requests for computation.
"--max-message-size",
type=int,
default=(1 << 20),
help="""Max message size in bytes.
The max size per message cannot exceed this limit.
"--max-queue-size",
type=int,
default=32,
help="Max number of messages in the queue for each connection.",
"--max-active-connections",
type=int,
default=200,
help="""Maximum number of active connections. The server will refuse
to accept new connections once the current number of active connections
equals to this limit.
"--num-threads",
type=int,
default=2,
help="Number of threads to run the neural network model",
"--certificate",
type=str,
help="""Path to the X.509 certificate. You need it only if you want to
use a secure websocket connection, i.e., use wss:// instead of ws://.
You can use ./web/generate-certificate.py
to generate the certificate `cert.pem`.
Note ./web/generate-certificate.py will generate three files but you
only need to pass the generated cert.pem to this option.
"--doc-root",
type=str,
default="./python-api-examples/web",
help="Path to the web root",
7) Create the recognizer.
Instantiate the recognizer according to the specified parameters.
def create_recognizer(args) -> sherpa_onnx.OnlineRecognizer:
if args.encoder:
tokens=args.tokens,
joiner=args.joiner,
num_threads=args.num_threads,
sample_rate=args.sample_rate,
feature_dim=args.feat_dim,
max_active_paths=args.num_active_paths,
enable_endpoint_detection=args.use_endpoint != 0,
rule1_min_trailing_silence=args.rule1_min_trailing_silence,
rule2_min_trailing_silence=args.rule2_min_trailing_silence,
rule3_min_utterance_length=args.rule3_min_utterance_length,
modeling_unit=args.modeling_unit,
bpe_vocab=args.bpe_vocab
elif args.paraformer_encoder:
recognizer = sherpa_onnx.OnlineRecognizer.from_paraformer(
tokens=args.tokens,
encoder=args.paraformer_encoder,
decoder=args.paraformer_decoder,
elif args.zipformer2_ctc:
recognizer = sherpa_onnx.OnlineRecognizer.from_zipformer2_ctc(
tokens=args.tokens,
model=args.zipformer2_ctc,
elif args.wenet_ctc:
recognizer = sherpa_onnx.OnlineRecognizer.from_wenet_ctc(
tokens=args.tokens,
model=args.wenet_ctc,
raise ValueError("Please provide a model")
return recognizer
8) Core class class StreamingServer(object)
Initialization includes self.recognizer as the recognizer instance, self.nn_pool as the thread pool for neural network computation, self.max_queue_size as the asynchronous queue for streaming, and self.http_server as the HTTP server.
def __init__(
self,
recognizer: sherpa_onnx.OnlineRecognizer,
nn_pool_size: int,
max_wait_ms: float,
max_batch_size: int,
max_message_size: int,
max_queue_size: int,
max_active_connections: int,
doc_root: str,
certificate: Optional[str] = None,
Args:
recognizer:
An instance of online recognizer.
nn_pool_size:
Number of threads for the thread pool that is responsible for
neural network computation and decoding.
max_wait_ms:
Max wait time in milliseconds in order to build a batch of
`batch_size`.
max_batch_size:
Max batch size for inference.
max_message_size:
Max size in bytes per message.
max_queue_size:
Max number of active connections. Once number of active client
equals to this limit, the server refuses to accept new connections.
beam_search_params:
Dictionary containing all the parameters for beam search.
online_endpoint_config:
Config for endpointing.
doc_root:
Path to the directory where files like index.html for the HTTP
server locate.
certificate:
Optional. If not None, it will use secure websocket.
You can use ./web/generate-certificate.py to generate
it (the default generated filename is `cert.pem`).
self.recognizer = recognizer
self.certificate = certificate
self.http_server = HttpServer(doc_root)
self.nn_pool_size = nn_pool_size
self.nn_pool = ThreadPoolExecutor(
max_workers=nn_pool_size,
thread_name_prefix="nn",
self.stream_queue = asyncio.Queue()
self.max_wait_ms = max_wait_ms
self.max_batch_size = max_batch_size
self.max_message_size = max_message_size
self.max_queue_size = max_queue_size
self.max_active_connections = max_active_connections
self.current_active_connections = 0
self.sample_rate = int(recognizer.config.feat_config.sampling_rate)
9) Streaming tasks.
Extract streams from the queue, process them in batches, and decode using the recognizer.
async def stream_consumer_task(self):
"""This function extracts streams from the queue, batches them up, sends
them to the neural network model for computation and decoding.
if self.stream_queue.empty():
await asyncio.sleep(self.max_wait_ms / 1000)
batch = []
while len(batch) < self.max_batch_size:
item = self.stream_queue.get_nowait()
assert self.recognizer.is_ready(item[0])
batch.append(item)
except asyncio.QueueEmpty:
stream_list = [b[0] for b in batch]
future_list = [b[1] for b in batch]
loop = asyncio.get_running_loop()
await loop.run_in_executor(
self.nn_pool,
self.recognizer.decode_streams,
stream_list,
for f in future_list:
self.stream_queue.task_done()
f.set_result(None)
10) Connection handling.
Receive audio data, feed it into the recognition stream, perform batch decoding, return results, handle endpoint detection and segmentation, and process padding at the end of the connection.
async def handle_connection(
self,
socket: websockets.WebSocketServerProtocol,
"""Receive audio samples from the client, process it, and send
decoding result back to the client.
Args:
socket:
The socket for communicating with the client.
await self.handle_connection_impl(socket)
except websockets.exceptions.ConnectionClosedError:
logging.info(f"{socket.remote_address} disconnected")
# Decrement so that it can accept new connections
self.current_active_connections -= 1
logging.info(
f"Disconnected: {socket.remote_address}. "
f"Number of connections: {self.current_active_connections}/{self.max_active_connections}" # noqa
async def handle_connection_impl(
self,
Args:
socket:
logging.info(
f"Connected: {socket.remote_address}. "
stream = self.recognizer.create_stream()
segment = 0
samples = await self.recv_audio_samples(socket)
if samples is None:
# TODO(fangjun): At present, we assume the sampling rate
# of the received audio samples equal to --sample-rate
stream.accept_waveform(sample_rate=self.sample_rate, waveform=samples)
while self.recognizer.is_ready(stream):
await self.compute_and_decode(stream)
result = self.recognizer.get_result(stream)
message = {
"text": result,
"segment": segment,
if self.recognizer.is_endpoint(stream):
self.recognizer.reset(stream)
segment += 1
await socket.send(json.dumps(message))
tail_padding = np.zeros(int(self.sample_rate * 0.3)).astype(np.float32)
stream.accept_waveform(sample_rate=self.sample_rate, waveform=tail_padding)
stream.input_finished()
message = {
"text": result,
"segment": segment,
11) Server connection.
Launch the WebSocket server.
async def run(self, port: int):
tasks = []
for i in range(self.nn_pool_size):
tasks.append(asyncio.create_task(self.stream_consumer_task()))
if self.certificate:
logging.info(f"Using certificate: {self.certificate}")
ssl_context = ssl.SSLContext(ssl.PROTOCOL_TLS_SERVER)
ssl_context.load_cert_chain(self.certificate)
ssl_context = None
logging.info("No certificate provided")
async with websockets.serve(
self.handle_connection,
host="",
port=port,
max_size=self.max_message_size,
max_queue=self.max_queue_size,
process_request=self.process_request,
ssl=ssl_context,
ip_list = ["localhost"]
if ssl_context:
ip_list += ["0.0.0.0", "127.0.0.1"]
ip_list.append(socket.gethostbyname(socket.gethostname()))
proto = "http://" if ssl_context is None else "https://"
s = "Please visit one of the following addresses:\n\n"
for p in ip_list:
s += " " + proto + p + f":{port}" "\n"
if not ssl_context:
s += "\nSince you are not providing a certificate, you cannot "
s += "use your microphone from within the browser using "
s += "public IP addresses. Only localhost can be used."
s += "You also cannot use 0.0.0.0 or 127.0.0.1"
logging.info(s)
await asyncio.Future() # run forever
await asyncio.gather(*tasks) # not reachable
12) def main()
Parse parameters.
args = get_args()
logging.info(vars(args))
Validate parameters.
check_args(args)
Create the server.
port = args.port
nn_pool_size = args.nn_pool_size
max_batch_size = args.max_batch_size
max_wait_ms = args.max_wait_ms
max_message_size = args.max_message_size
max_queue_size = args.max_queue_size
max_active_connections = args.max_active_connections
certificate = args.certificate
doc_root = args.doc_root
if certificate and not Path(certificate).is_file():
raise ValueError(f"{certificate} does not exist")
if not Path(doc_root).is_dir():
raise ValueError(f"Directory {doc_root} does not exist")
server = StreamingServer(
recognizer=recognizer,
nn_pool_size=nn_pool_size,
max_batch_size=max_batch_size,
max_wait_ms=max_wait_ms,
max_message_size=max_message_size,
max_queue_size=max_queue_size,
max_active_connections=max_active_connections,
certificate=certificate,
doc_root=doc_root,
Run the server.
asyncio.run(server.run(port))
Create the offline real-time ASR client instance:
1) Instantiate the client.
asr = speech.OfflineRealTimeASR()
2) Perform speech recognition.
Call asr.asr() to recognize the recorded audio file at ./resources/audio/test_recording.wav. The resulting text is printed to the terminal.
print(asr.asr('./resources/audio/test_recording.wav'))
12.5.3 Offline Large AI Model for Voice Control
12.5.3.1 Overview
When the program starts, the voice device announces I’m ready. Say the wake word Hello Hiwonder to activate the voice device, which responds with I’m here. After activation, the robot can be controlled via voice commands to perform corresponding actions, such as Move forward for one second, then turn left for one second, and finally move backward for one second. The device will then announce the AI-generated response and execute the requested actions.
12.5.3.2 Preparation
Version Confirmation
12.5.3.3 Operation Steps
Command input is case-sensitive and space-sensitive.
In the terminal window, enter the following command and press Enter to stop the auto-start service.Enter the command to disable the auto-start service of the app.
Enter the following command and press Enter to launch the voice control feature.
ros2 launch large_models_examples llm_control_move.launch.py
When the terminal displays the next output as the reference image, it shows the recognized speech transcribed by the voice device.
Upon successful recognition by the speech recognition service of a cloud-based large speech model, the parsed command will be displayed under the
publish_asr_resultoutput in the terminal.
The response is automatically generated by the large model. Only the semantic accuracy of the reply is guaranteed, while the wording and formatting may vary.
When the terminal shows the output shown in the figure indicating the end of one interaction cycle, the system is ready for the next round. To initiate another interaction, repeat step 4 by speaking the wake words again.
To exit the feature, press Ctrl + C in the terminal. If the feature does not shut down immediately, press Ctrl + C multiple times. If it still fails to exit, open a new terminal window and run the following command to clear the ROS node.
12.5.3.4 Project Outcome
Once the feature is started, voice commands can be issued to the robot, for example: Move forward for one second, then turn left for one second, and finally move backward for one second. The robot will then move forward for one second, turn left for one second, and finally move backward for one second.
12.5.3.5 Program Analysis
Launch File Analysis
File Path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_control_move.launch.py
asr_mode is read from the environment variable ASR_MODE, defaulting to online and converted to lowercase.
mode = LaunchConfiguration('mode', default=1)
mode_arg = DeclareLaunchArgument('mode', default_value=mode)
camera_topic = LaunchConfiguration('camera_topic', default='depth_cam/rgb0/image_raw')
camera_topic_arg = DeclareLaunchArgument('camera_topic', default_value=camera_topic)
asr_mode = os.environ.get("ASR_MODE", "online").lower()
Retrieve paths for controller and large_models packages.
large_models_package_path = get_package_share_directory('large_models')
vocal_detect_launch is the launch file for voice detection, with the mode parameter passed in.
agent_process_launch is the launch file for agent processing, with the camera_topic parameter passed in.
tts_node_launch is the launch file for the TTS node.
vocal_detect_launch = IncludeLaunchDescription(
os.path.join(get_package_share_directory('large_models'), 'launch/vocal_detect.launch.py')),
launch_arguments={'mode': mode,}.items(),
agent_process_launch = IncludeLaunchDescription(
os.path.join(get_package_share_directory('large_models'), 'launch/agent_process.launch.py')),
launch_arguments={'camera_topic': camera_topic}.items(),
tts_node_launch = IncludeLaunchDescription(
os.path.join(get_package_share_directory('large_models'), 'launch/tts_node.launch.py')),
Delayed launch configuration:
In offline mode, vocal_detect_launch and agent_process_launch are delayed by 10 seconds, while in online mode they are delayed by 1 second, and tts_node_launch starts immediately.
time_interval = 10.0 if asr_mode == 'offline' else 1.0
large_models_launch = GroupAction(
actions=[
tts_node_launch,
TimerAction(
period=time_interval, actions=[
vocal_detect_launch,
TimerAction(period=time_interval, actions=[
agent_process_launch,
Conditional node selection:
online mode: start the llm_control_move node.
offline mode: start the llm_control_move_offline node.
if asr_mode == 'online':
llm_control_move_node = Node(
package='large_models_examples',
executable='llm_control_move',
parameters=[{
'interruption': interruption,
executable='llm_control_move_offline',
parameters=[{
This function generates the Launch description and adds the launch_setup function to it using OpaqueFunction.
ls.run()
Python File Analysis
File Path:
ros2_ws/src/large_models_examples/large_models_examples/llm_control_move_offline.py
1) Prompt template.
PROMPT = '''
##Role Task
You are an intelligent robot car responsible for parsing user movement instructions and extracting actions and parameters.
##Action Function Library
- "move(direction, distance, duration)"
- direction (Direction): 'forward', 'backward', 'turn_left', 'turn_right', 'shift_left', 'shift_right', 'stop'
- distance (Distance, in meters): A number. If the user does not specify distance, it is set to 0.
- duration (Time, in seconds): A number. If the user does not specify time, it is set to 0.
##Requirements
1. Parse the user’s intent and generate an action list containing one or more move function calls.
2. **Strictly follow**: If the user command includes **time** (e.g., "move forward for 3 seconds"), the **distance parameter must be 0**, and the duration will be the corresponding time.
3. **Strictly follow**: If the user command includes **distance** (e.g., "move forward 1 meter"), the **duration parameter must be 0**, and the distance will be the corresponding distance.
4. Directly output the JSON result without analysis.
5. Format: {"action": ["move('forward', 1, 0)"], "response": "Alright, moving forward 1 meter"}
6. After each action, a stop action must be included to stop the robot: "move('forward', 1, 0)"
##Example Task
Input: Move forward for 2 seconds, then turn left for 1 second.
Output: {"action": ["move('forward', 0, 2)", "move('turn_left', 0, 1)", "move('stop', 0, 1)"], "response": "Got it, executing!"}
Output: {"action": ["move('forward', 1, 0)", "move('stop', 0, 1)"], "response": "Alright, let's go!"}
2) Variable Initialization
Initializes member variables.
self.action: list of actions.
self.llm_result: result returned by the LLM.
self.running: running flag.
self.interrupt: interrupt flag.
self.action_finish: action completed flag.
self.play_audio_finish: audio playback completed flag.
interruption: whether interruption is enabled.
self.interruption: value of the interruption parameter.
self.asr_mode: current system voice mode.
self.action = []
self.llm_result = ''
self.interrupt = False
self.action_finish = False
self.declare_parameter('interruption', False)
self.interruption = self.get_parameter('interruption').value
self.declare_parameter('offline', 'false')
self.asr_mode = os.environ.get("ASR_MODE", "online").lower()
A reentrant callback group is created to allow callbacks to call other callbacks.
ROS2 communication:
Publishers include self.tts_text_pub, which publishes TTS text, and self.mecanum_pub, which publishes chassis control.
Subscribers include agent_process/result which receives LLM results, vocal_detect/wakeup which receives wake signals, and tts_node/play_finish which receives the playback completion status.
Service Clients include self.set_model_client for setting the model, self.awake_client for setting the wake state, self.set_mode_client for setting the mode, and self.set_prompt_clien for setting the prompt.
# self.awake_client.wait_for_service()
# self.set_mode_client.wait_for_service()
Create timer:
A timer is created to repeatedly call a callback function through the callback group.
3) def wakeup_callback(self, msg) Wakeup Callback Method
The interrupt flag is set when an LLM result is available.
if self.llm_result:
self.interrupt = msg.data
4) def llm_result_callback(self, msg) LLM Result Callback Method
Stores the result returned by the LLM.
def llm_result_callback(self, msg):
self.llm_result = msg.data
5) def play_audio_finish_callback(self, msg) Audio Playback Completion Callback Method
Enables the wake function and sets the completion flag after audio playback finishes.
msg = SetBool.Request()
msg.data = True
# msg = SetInt32.Request()
# msg.data = 1
6) def parse_action(self, action_str) Action Parsing Method
Extracts parameters from the move() function using regular expressions, parses direction, distance, and duration, and returns the parsed result. Returns None, 0, 0 if parsing fails.
def parse_action(self, action_str):
Helper function to parse strings in the format "move('direction', distance, duration)".
Uses regular expressions to extract parameters for more robust handling.
# Match the content inside move(...)
match = re.search(r"move\((.*)\)", action_str)
if not match:
return None, 0, 0
# Extract the parameter string, e.g., "'forward', 5, 0"
params_str = match.group(1)
# Split parameters
params = [p.strip() for p in params_str.split(',')]
# Extract and convert types
direction = params[0].strip("'\"") # Remove quotes from the string parameter
distance = float(params[1])
duration = float(params[2])
return direction, distance, duration
7) def process(self)
Define speeds.
DEFAULT_LINEAR_SPEED = 0.2 # m/s
DEFAULT_ANGULAR_SPEED = 1.0 # rad/s
Loop through and execute the action sequence.
if self.llm_result:
msg = String()
If no corresponding action is returned, only respond without performing any action.
response = self.llm_result
msg.data = response
If actions are returned, extract and process them, checking the LLM result.
if 'action' in self.llm_result:
Parse the JSON to extract action and response.
action_list = []
if 'action' in result:
if 'response' in result:
response = result['response']
Publish the TTS response.
msg.data = response
Execute the action sequence by parsing each action string.
for action_str in action_list:
direction, distance, duration = self.parse_action(action_str)
if direction is None:
continue # Parsing failed, skip this action
twist_msg = Twist()
final_duration = 0
Set speed based on direction.
if direction == 'forward':
twist_msg.linear.x = DEFAULT_LINEAR_SPEED
elif direction == 'backward':
twist_msg.linear.x = -DEFAULT_LINEAR_SPEED
elif direction == 'shift_left':
twist_msg.linear.y = DEFAULT_LINEAR_SPEED
elif direction == 'shift_right':
twist_msg.linear.y = -DEFAULT_LINEAR_SPEED
elif direction == 'turn_left':
twist_msg.angular.z = DEFAULT_ANGULAR_SPEED
elif direction == 'turn_right':
twist_msg.angular.z = -DEFAULT_ANGULAR_SPEED
Calculate the duration by prioritizing distance. If no distance is provided, use the specified duration by default.
if distance > 0:
# Prefer using distance to calculate duration
final_duration = distance / (DEFAULT_LINEAR_SPEED if 'turn' not in direction else DEFAULT_ANGULAR_SPEED)
# Otherwise use the specified duration
final_duration = duration
Publish velocity command and wait.
if final_duration > 0:
self.get_logger().info(f"Action: {direction}, Publishing velocity, Duration: {final_duration:.2f}s")
self.mecanum_pub.publish(twist_msg)
time.sleep(final_duration)
Check interrupt flag. After all actions are completed, publish stop command.
if self.interrupt:
# self.get_logger().info("Action sequence interrupted.")
break # Exit the for loop
Handle completion flag and mode switch.
self.action_finish = True
The synchronization mechanism ensures that audio playback and action execution are completed before proceeding. Mode management controls speech detection behavior by setting mode value 2 when interruption is enabled. The state is reset for the next interaction.
if self.play_audio_finish and self.action_finish:
if self.interruption:
msg.data = 2
self.send_request(self.set_mode_client, msg)
8) Main function def main()
node = LLMControlMove('llm_control_move')
12.5.4 Offline Large AI Model for Autonomous Line Following
12.5.4.1 Overview
When the program starts, the voice device announces I’m ready. Say the wake word Hello Hiwonder to activate the voice device, which responds with I’m here. Now, the robot can be controlled by voice commands. For example, Follow the black line and stop when you meet an obstacle. The terminal will display the recognized speech, while the voice device will announce the response generated after processing. The robot will also detect the black line captured by the camera. When the robot encounters an obstacle ahead, it will stop.
12.5.4.2 Preparation
12.5.4.3 Operation Steps
Open the command line terminal from the left side of the system interface.
Enter the following command and press Enter to launch the autonomous line following feature.
ros2 launch large_models_examples llm_visual_patrol.launch.py
When the terminal displays the output shown below and announces I’m ready, the voice device has completed initialization. At this point, say the wake word Hello Hiwonder.
When the terminal displays the corresponding output shown in the figure and the device responds with I’m here, it indicates successful activation. The system will begin recording voice commands.
When the terminal prints the output shown below, it indicates that the voice device has transcribed the spoken command. In this example, the command spoken is Follow the black line and stop when you encounter an obstacle.
The robot then follows the black line and stops when it encounters an obstacle.
To exit the feature, press Ctrl + C in the terminal. If the feature does not shut down immediately, press Ctrl + C multiple times. If it still fails to exit, open a new terminal window and run the following command to terminate all active ROS processes and related programs.
12.5.4.4 Project Outcome
Once the feature is activated, feel free to give commands in your own words. For instance, Follow the black line and stop when you encounter an obstacle. The robot uses its camera to detect and follow the black line, and it will stop when an obstacle is detected in its path. The system is pre-configured to recognize four line colors: red, blue, green, and black.
12.5.4.5 Program Analysis
File Path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_visual_patrol.launch.py
1) Import library files.
from launch.actions import GroupAction,TimerAction
os: Used for handling file paths and operating system-related functions.
ament_index_python.packages.get_package_share_directory: Retrieves the share directory path of ROS 2 package.
launch_ros.actions.Node: Used to define ROS 2 nodes.
launch.substitutions.LaunchConfiguration: Retrieves parameter values defined in the Launch file.
LaunchDescription, LaunchService: Used to define and start the Launch file.
PythonLaunchDescriptionSource: Enables the inclusion of other Launch files.
launch.actions.IncludeLaunchDescription、DeclareLaunchArgument、OpaqueFunction: Used to define actions and arguments within the Launch file.
launch.actions.GroupAction、TimerAction: Action group and delayed startup.
2) Define the launch_setup Function
Declare launch parameters:
mode: Mode parameter, default value 1.
camera_topic: Camera topic, default depth_cam/rgb0/image_raw.
interruption: Interruption toggle, default False.
interruption = LaunchConfiguration('interruption', default=False)
interruption_arg = DeclareLaunchArgument('interruption', default_value=interruption)
Obtain package paths:
Retrieve paths for app and large_models packages.
Include launch.py files using IncludeLaunchDescription.
line_following_node_launch: Line tracking node.
'debug': 'true',
actions=[
tts_node_launch,
TimerAction(
Start the llm_visual_patrol_node node.
parameters=[{
3) Define generate_launch_description Function
return LaunchDescription([
4) Main Program Entry
ls = LaunchService()
ls.run()
ld = generate_launch_description() generates the Launch description object.
ls = LaunchService() creates a Launch service object.
ls.include_launch_description(ld) adds the Launch description to the Launch service.
ls.run() starts the Launch service and executes all defined Launch actions.
File Path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_visual_patrol.py
1) Prompt template.
PROMPT = '''
**Role
You are a smart robot that generates corresponding JSON commands based on user input.
**Requirements
- For every user input, search for matching commands in the action function library and output the corresponding JSON instruction.
- For each action sequence, craft a witty and creative response (10 to 30 characters) to make interactions delightful.
- Directly return the JSON result — do not include any explanations or extra text.
- There are four target colors: red, green, blue, and black.
- Format:
"action": ["xx", "xx"],
"response": "xx"
**Special Notes
The "action" field should contain a list of function names as strings, ordered by execution. If no matching action is found, output an empty list: [].
The "response" field should provide a concise and charming reply, staying within the word and tone guidelines.
**Action Function Library
Follow a line of a given color: line_following('black')
**Example
Input: Follow the black line
Output:
"action": ["line_following('black')"],
"response": "Roger that!"
self.stop controls whether to stop the current action, with True indicating that the action should be stopped.
self.asr_mode: Reads the value of speech mode ASR_MODE from the environment variable, defaulting to online.
self.action = []
self.stop = True
# self.llm_result = '{"action": ["line_following(\'black\')"], "response": "ok!"}'
ROS2 communication:
Publisher: self.tts_text_pub publishes TTS text.
Service clients: self.set_model_client for setting the model, self.awake_client for setting the wake-up, self.set_mode_client for setting the mode, self.set_prompt_clien for setting the prompt, self.enter_client for entering line-following mode, self.start_client for starting or stopping the line-following, and self.set_target_client for setting the target color.
self.enter_client = self.create_client(Trigger, 'line_following/enter')
self.enter_client.wait_for_service()
self.start_client = self.create_client(SetBool, 'line_following/set_running')
self.set_target_client = self.create_client(SetColor, 'line_following/set_color')
3) def init_process(self) Initialization
Cancel the timer.
Configure the LLM model:
Create a SetModel.Request() message object.
msg = SetModel.Request()
Set the model type to llm.
msg.model_type = 'llm'
Select the model and configuration based on self.asr_mode.
if self.asr_mode == 'offline':
msg.model = 'qwen3:0.6b'
msg.base_url = ollama_host
msg.model = llm_model
msg.api_key = api_key
msg.base_url = base_url
Synchronously call the agent_process/set_model service via self.send_request.
Set the prompt:
Create a SetString.Request() message.
msg = SetString.Request()
Set msg.data to the module-level variable PROMPT, using the ASR_LANGUAGE environment variable to determine whether it is in English or another language.
msg.data = PROMPT
Call the agent_process/set_prompt service to pass the prompt to the LLM agent.
Initialize the line-following feature:
Create a temporary client to check if the line_following/init_finish service is ready.
init_finish = self.create_client(Trigger, 'line_following/init_finish')
Ensure the line-following node is fully initialized.
Call the line_following/enter service to enter line-following mode.
self.send_request(self.enter_client, Trigger.Request())
Play the start audio.
Start the main processing thread.
Create the initialization completion service. Output logging information.
self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT)
4) def wakeup_callback(self, msg) Wakeup Callback Method
Wakeup interrupt handling: when receiving a wakeup signal, interrupt the current action and re-enter line-following mode.
if msg.data and self.llm_result:
self.stop = True
elif msg.data and not self.stop:
self.stop = True
5) def llm_result_callback(self, msg) LLM Result Callback Method
6) def llm_result_callback(self, msg) LLM Result Callback Method
7) def process(self) Main Processing Loop Method
Run continuously until self.running is set to false.
Check if there is an LLM result.
if self.llm_result:
Create a TTS message object.
msg = String()
If the string does not contain action, only respond via voice.
msg.data = self.llm_result
If an action is present, extract and process it.
Parse the JSON result.
result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}')+1])
Check if result contains action.
Get the action list, define a regular expression to match the format line_following('color').
text = result['action']
# Use a regular expression to extract all strings inside parentheses
pattern = r"line_following\('([^']+)'\)"
# Use re.search to find matches
Iterate over the action list:
Perform regex matching for each action string.
for i in text:
match = re.search(pattern, i)
Extract the color parameter and log the result.
# Extract the result
if match:
# Get the parameter part, which is the content inside parentheses
color = match.group(1)
self.get_logger().info(str(color))
Set the target color.
color_msg = SetColor.Request()
color_msg.data = color
self.send_request(self.set_target_client, color_msg)
Start line-following.
start_msg = SetBool.Request()
start_msg.data = True
self.send_request(self.start_client, start_msg)
Response text processing.
msg.data = result['response']
Publish the TTS response and reset the state.
Idle wait.
Wakeup mechanism recovery.
msg.data = True
msg.data = 2
self.stop = False
Loop end and cleanup.
node = LLMControlMove('llm_line_following')
12.5.5 Offline Large AI Model for Color Tracking
12.5.5.1 Overview
When the program starts, the voice device announces I’m ready. Say the wake word Hello Hiwonder to activate the voice device, which responds with I’m here. Then you can use voice commands to control robot such as Track a red object. The terminal will display the recognized command, and the voice device will respond with a generated reply after processing. The robot will then autonomously identify the red object captured by its camera and begin tracking it.
12.5.5.2 Preparation
12.5.5.3 Operation Steps
Enter the following command and press Enter to launch the color tracking feature.
ros2 launch large_models_examples llm_color_track.launch.py
After the program has loaded successfully, the camera feed will appear on screen.
When the terminal prints the output shown below, it indicates that the voice device has transcribed the spoken command. In this example, the command spoken is Track a red object.
Then, the robot will detect the red object in its camera feed and begin tracking it in real time.
12.5.5.4 Project Outcome
Once the feature is activated, feel free to give commands in your own words. For instance, Track a red object. The robot will use the camera feed to identify and track the red object. Similarly, commands like “Track a blue object” or “Track a green object” can be used to instruct the robot to track objects of the specified colors.
12.5.5.5 Program Analysis
File Path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_color_track.launch.py
2) Define launch_setup Function
object_tracking_node_launch: Color-tracking node.
'debug': 'true',
actions=[
tts_node_launch,
TimerAction(
Start the llm_color_track_node node.
llm_color_track_node = Node(
executable='llm_color_track',
parameters=[
ls.run()
File Path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_color_track.py
1) Prompt template.
PROMPT = '''
**Role
You are an intelligent companion robot. Your job is to generate corresponding JSON commands based on the user’s input.
**Requirements
- For every user input, search the action function library for matching commands and return the corresponding JSON instruction.
- Craft a witty, ever-changing, and concise response (between 10 to 30 characters) for each action sequence to make interactions lively and fun.
- Output only the JSON result — do not include explanations or any extra text.
- Output format:{"action": ["xx", "xx"], "response": "xx"}
**Special Notes
The "action" key holds an array of function name strings arranged in execution order. If no match is found, return an empty array [].
The "response" key must contain a cleverly worded, short reply (10–30 characters), adhering to the tone and length guidelines above.
Track an object of a specific color: color_track('red')
**Example
Input: Track a green object
Output:
{"action": ["color_track('green')"], "response": "Got it!"}
self.action = []
self.stop = True
ROS2 communication:
Service clients: self.set_model_client for setting the model, self.awake_client for setting the wake-up, self.set_mode_client for setting the mode, self.set_prompt_clien for setting the prompt, self.enter_client for entering color tracking mode, self.start_client for starting or stopping the mode, and self.set_target_client for setting the target color.
self.enter_client = self.create_client(Trigger, 'object_tracking/enter')
self.start_client = self.create_client(SetBool, 'object_tracking/set_running')
self.set_target_client = self.create_client(SetColor, 'object_tracking/set_color')
3) def init_process(self) Initialization Configuration
Cancel the timer.
Set the prompt:
msg.data = PROMPT
Create a temporary client to check if the object_tracking/init_finish service is ready.
init_finish = self.create_client(Trigger, 'object_tracking/init_finish')
Ensure the color tracking node is fully initialized.
Call the object_tracking/enter service to enter line-following mode.
self.stop = True
self.stop = True
6) def play_audio_finish_callback(self, msg) Audio Playback Completion Callback Method
if self.llm_result:
msg = String()
for i in text:
if match:
Start color tracking.
Idle wait.
msg.data = True
msg.data = 2
self.stop = False
node = LLMControlMove('llm_color_track')
