2. Basic Course
2.1 FPIOA Experiment
2.1.1 Experiment Overview
This section demonstrates how to use programming to learn about FPIOA and configure physical pins. The FPIOA (Field Programmable IO Array) module is primarily responsible for assigning functions to physical pins (PADs). In a SoC, although many functions are available, the number of pins is limited, so multiple functions may share the same I/O pin. At any given time, each pin can only enable one function, so the appropriate function must be selected and activated through the IOMUX, that is, through the FPIOA.
2.1.2 Preparation
  • Module Connection
  1. Connect the K230 development board to your PC using a Type-C data cable, as shown below:
  1. Double-click to open CanMV IDE K230.
  1. Click the connection button in the lower left corner.
  1. Upon successful connection, the lower left corner of the CanMV IDE will display the icon shown below.
  1. If connection takes more than 10 seconds, it has failed. Click the Cancel button, and a dialog box will appear. Click OK and recheck the connection.
Connection Failure Causes and Solutions:
  • Cable is not a data cable: Some Type-C cables are charging-only cables without data transfer capability. Please use a Type-C cable with data transfer functionality. The factory-supplied cable is a Type-C data cable.
  • Other K230 firmware was flashed: Re-flash the factory firmware, then reconnect.
2.1.3 Program Execution and Download
The K230 program supports two operation modes: online execution and offline execution.
Online Execution:
After connection, drag the program FPIOA.py into CanMV IDE K230. In the code editor, click the run button in the lower left corner to run the program online, as shown below:
Programs run using this method will be lost after disconnecting or powering off, and will not be saved on the development board.
Offline Execution:
  1. After connection, drag the program FPIOA.py into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
  1. Once the file is written, click OK to confirm and complete saving the MicroPython file to the K230 development board.
With this method, the K230 development board will automatically run the MicroPython file upon power-up without connection, enabling offline execution.
2.1.4 Program Outcome
First, the program prints the current function assignment of all pins, prints all functions that pin 0 supports, and prints all pins that support the IIC0_SDA function. Pin 0 is configured as a general-purpose GPIO function, and pin 2 is configured as a general-purpose GPIO function with an initial high-level output.
2.1.5 Program Analysis
  • View Pin Functions
# Print the current function configuration of all pins
fpioa.help()
# Print the detailed configuration of pin 0
fpioa.help(0)
# Print all configurations that support I2C data pin (IIC0_SDA)
fpioa.help(FPIOA.IIC0_SDA, func=True)
  1. fpioa.help(): View the current mapping of all pins.
  2. fpioa.help(0): View the configuration of pin 0.
  3. fpioa.help(FPIOA.IIC0_SDA, func=True): Query configurations that support I2C data pin (IIC0_SDA)
  • Set Pin Functions
# Set pin 0 to general-purpose GPIO0 function
fpioa.set_function(0, FPIOA.GPIO0)
# Set pin 2 to GPIO2 with some additional parameters:
# ie=1: Pin enable (input enable)
# oe=1: Pin enable (output enable)
# pu=0: Disable pull-up resistor
# pd=0: Disable pull-down resistor
# st=1: Set this pin to high level
# ds=7: Drive strength set to maximum value
fpioa.set_function(2, FPIOA.GPIO2, ie=1, oe=1, pu=0, pd=0, st=1, ds=7)
  1. fpioa.set_function(0, FPIOA.GPIO0): Set pin 0 to GPIO0.
  2. fpioa.set_function(2, FPIOA.GPIO2, ie=1, oe=1, pu=0, pd=0, st=1, ds=7): Set pin 2 to GPIO2, enable input/output, disable pull-up/down, initial high level, maximum drive strength.
  • Query Function Correspondence
# Get the pin number currently configured as UART0_TXD function
fpioa.get_pin_num(FPIOA.UART0_TXD)
# Get the current function configuration of pin 0
fpioa.get_pin_func(0)
  1. fpioa.get_pin_num(FPIOA.UART0_TXD): Query which pin corresponds to the UART0_TXD function.
  2. fpioa.get_pin_func(0): Query what function pin 0 is currently configured as.
2.2 GPIO Experiment
2.2.1 Experiment Overview
This section demonstrates how to use programming to explore the GPIO functionality of the K230 board. It covers configuring each pin as either input or output, as well as setting pull-up and pull-down resistors and adjusting drive strength.
2.2.2 Preparation
  • Module Connection
2.2.3 Program Execution and Download
Online Execution:
After connection, drag the program GPIO.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program GPIO.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.2.4 Program Outcome
Pin 2 is configured to output mode with no pull-up/down, drive strength of 7, and outputs both high and low levels.
2.2.5 Program Analysis
from machine import Pin
# Configure pin 2 to output mode with no pull-up/down, drive strength of 7
pin = Pin(2, Pin.OUT, pull=Pin.PULL_NONE, drive=7)
# Set pin 2 to output high level
pin.value(1)
# Set pin 2 to output low level
pin.value(0)
  1. index: Pin number, range is [0, 63].
  2. mode: Pin mode, supports input mode or output mode.
  3. pull: Optional pull-up or pull-down configuration, defaults to Pin.PULL_NONE.
  4. drive: Optional drive-strength configuration, defaults to 7.
  5. value: Set the default output value of the pin.
Mode Parameter Function Description
Pin Mode Pin.IN Set to input mode
Pin.OUT Set to output mode
Pull Up/Down PULL_NONE Disable pull-up/down resistors
PULL_UP Enable pull-up resistor
PULL_DOWN Enable pull-down resistor
Interrupt Trigger IRQ_FALLING Falling edge trigger interrupt
IRQ_RISING Rising edge trigger interrupt
IRQ_LOW_LEVEL Low level trigger interrupt
IRQ_HIGH_LEVEL High level trigger interrupt
IRQ_BOTH Both edges (rising/falling) trigger
2.3 UART Experiment
2.3.1 Experiment Overview
This section uses code to explore the UART features of the K230 development board.
The K230 chip contains a total of five UART modules. UART0 and UART3 are occupied by the system, hence, only UART1, UART2, and UART4 are available. To use them, route their TX and RX pins to the pin headers through the IOMUX.
2.3.2 Preparation
  • Module Connection
  1. Use jumper wires to connect the GND, RX, TX of the USB-to-serial module to the K230’s UART3 interface, then connect the USB-to-serial module to the PC, as shown below.
2.3.3 Program Execution and Download
Online Execution:
After connection, drag the program UART.py into CanMV IDE K230. In the code editor, click the run button in the lower left corner to run the program online, as shown below:
Offline Execution:
  1. After connection, drag the program UART.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.3.4 Program Outcome
Send messages to the K230 development board through the serial port tool assistant. Sending 1 turns the LED on, sending 0 turns the LED off.
2.3.5 Program Analysis
LED_PIN_NUM = 52
UART_ID = UART.UART1 # Can be adjusted according to actual hardware
BAUDRATE = 115200
UART1_TX_PIN = 3  # Can be adjusted according to actual hardware
UART1_RX_PIN = 4
fpioa = FPIOA()
fpioa.set_function(LED_PIN_NUM, getattr(FPIOA, f'GPIO{LED_PIN_NUM}'))
  1. LED_PIN_NUM=52 indicates that blue LED is connected to IO52.
  2. UART_ID=UART.UART1 specifies using UART1; BAUDRATE=115200.
Use FPIOA to remap pin 52 to GPIO52, preparing for subsequent LED control.
led_blue = Pin(LED_PIN_NUM, Pin.OUT)
uart = UART(UART_ID, BAUDRATE)
  1. Pin.OUT sets IO52 to push-pull output.
  2. UART defaults to 8 data bits, no parity, 1 stop bit (8N1).
        data = uart.read(1)
        if data:
            if data == b'1':
                led_blue.value(1) # Turn on LED
                print("Received '1', LED is ON.") # Print feedback message
            elif data == b'0':
                led_blue.value(0) # Turn off LED
               print("Received '0', LED is OFF.") # Print feedback message
uart.read(1) returns a value of type bytes, so comparisons should use b'1' and b'0'.
When b'1' is received, led_blue.value(1) turns the LED on and prints a message.
When b'0' is received, led_blue.value(0) turns the LED off and prints a message.
All other bytes are ignored, and the LED remains in its current state.
2.4 I2C Experiment
2.4.1 Experiment Overview
This section demonstrates how to use programming to explore the I2C functionality of the K230 development board.
The K230 chip integrates 5 I2C hardware modules, supporting standard mode (100 kb/s), fast mode (400 kb/s), and high-speed mode (3.4 Mb/s). The I2C channel output IO can be configured through the IOMUX module.
2.4.2 Preparation
  • Module Connection
2.4.3 Program Execution and Download
Online Execution:
After connection, drag the program IIC.py into CanMV IDE K230. In the code editor, click the run button in the lower left corner to run the program online, as shown below:
Offline Execution:
  1. After connection, drag the program IIC.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.4.4 Program Outcome
When the program runs, it scans and detects all connected devices through the I2C bus and prints out the address of each device.
2.4.5 Program Analysis
from machine import I2C
i2c = I2C(2, scl=11, sda=12, freq=40000)  # Defaults to 100kHz
print(i2c.scan())  # Returns the address of the first responding device, e.g., [59]
print("Hex addresses:", [hex(dev) for dev in i2c.scan()])
  1. Instantiate the I2C interface and use i2c.scan() method to scan slave devices on the current I2C bus.
  2. And print out the scanned addresses in both decimal and hexadecimal format.
2.5 SPI Experiment
2.5.1 Experiment Overview
This section demonstrates how to use programming to explore the SPI configuration functionality of the K230 development board through the IOMUX module.
The K230 board integrates three SPI hardware modules, supporting chip select polarity configuration and adjustable clock rates.
2.5.2 Preparation
  • Module Connection
2.5.3 Program Execution and Download
Online Execution:
After connection, drag the program SPI.py into CanMV IDE K230. In the code editor, click the run button in the lower left corner to run the program online, as shown below:
Offline Execution:
  1. After connection, drag the program SPI.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.5.4 Program Outcome
Use the SPI interface to communicate with external devices. Specifically, the program operates an external SPI flash memory by configuring GPIO pins, such as GD25LQ128, communicates with it through the SPI protocol, and reads the device ID information.
2.5.5 Program Analysis
# Instantiate FPIOA object
a = FPIOA()
Instantiate FPIOA
  • Configure QSPI Function
a = FPIOA()
# Configure GPIO14~17 as QSPI function
a.help(14)
a.set_function(14, a.QSPI0_CS0)
a.help(14)
a.help(15)
a.set_function(15, a.QSPI0_CLK)
a.help(15)
a.help(16)
a.set_function(16, a.QSPI0_D0)
a.help(16)
a.help(17)
a.set_function(17, a.QSPI0_D1)
a.help(17)
  1. Configure GPIO14 to GPIO17 as corresponding QSPI interface functions:
  2. GPIO14 is set to QSPI0_CS0, which is the SPI chip select signal (CS).
  3. GPIO15 is set to QSPI0_CLK, which is the SPI clock signal (CLK).
  4. GPIO16 is set to QSPI0_D0, which is the SPI data line D0(MOSI).
  5. GPIO17 is set to QSPI0_D1, which is the SPI data line D1(MISO).
  • Set SPI Parameters
# Instantiate SPI(1) with parameters: 5MHz, polarity 0, phase 0, 8-bit data width
spi = SPI(1, baudrate=5000000, polarity=0, phase=0, bits=8)
Instantiate an SPI interface through the SPI module with the following parameters:
Set the ID to 1 with a baud rate of 5 MHz, clock polarity 0, clock phase 0, and a data width of 8 bits.
  • Reset SPI Flash and Read Device ID
# Enable GD25LQ128 reset sequence
spi.write(bytes([0x66]))
spi.write(bytes([0x99]))
# Read ID command 0x9F + 3 placeholder bytes, total 4 bytes
write_buf = bytes([0x9F, 0x00, 0x00, 0x00])
read_buf = bytearray(4)
spi.write_readinto(write_buf, read_buf)
print("ID:", read_buf[1:])  # ID is usually in the last 3 bytes
  1. write_buf: Bytes to write, where 0x9F is the command to read the ID, followed by three placeholder bytes 0x00.
  2. read_buf: Used to store data returned from the SPI device (4 bytes).
  3. spi.write_readinto(write_buf, read_buf): Send command and read response, storing the read data.
  • Read Device ID (Alternative Command Format)
write_buf = bytes([0x90, 0x00, 0x00, 0x00])
print("ID:", read_buf[2:4])
  1. 0x90: This is another command for reading the ID, but unlike 0x9F, it returns two bytes of ID data.
  2. write_buf: Bytes to write, where 0x90 is the command to read the ID, followed by three placeholder bytes 0x00.
  3. read_buf: Stores the returned 4 bytes of data.
  4. spi.write_readinto(write_buf, read_buf): Send command and read response, storing the read data in read_buf.
2.6 PWM Experiment
2.6.1 Experiment Overview
This section demonstrates how to use programming to explore the PWM functionality of the K230 development board.
The K230 contains two PWM hardware modules, each with three output channels. The output frequency of each module is adjustable, but all three channels share the same clock, while the duty cycle can be set independently. As a result, channels 0, 1, and 2 share the same output frequency, and channels 3, 4, and 5 share another output frequency.
2.6.2 Preparation
  • Module Connection
2.6.3 Program Execution and Download
Online Execution:
After connection, drag the program PWM.py into CanMV IDE K230. In the code editor, click the run button in the lower left corner to run the program online, as shown below:
Offline Execution:
  1. After connection, drag the program PWM.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.6.4 Program Outcome
The buzzer will emit sounds at different frequencies in sequence, starting with low frequency, then gradually increasing, from 200 Hz to 1000 Hz, producing progressively higher-pitched sounds.
2.6.5 Program Analysis
  • Configure PWM1 Function
from machine import Pin, PWM
from machine import FPIOA
fpioa = FPIOA()
fpioa.set_function(43, FPIOA.PWM1)
  1. fpioa = FPIOA() creates an FPIOA object for configuring pin functions.
  2. fpioa.set_function(43, FPIOA.PWM1) configures pin 43 as PWM1 function, outputting the PWM signal to this pin to control the buzzer.
  3. Beep = PWM(1, 200, 50, enable=True) controls PWM1 channel.
  • Buzzer PWM Object
Beep = PWM(1)      # Create PWM channel 1 object
Beep.freq(200)     # Set frequency to 200Hz
Beep.duty(50)      # 50% duty cycle, buzzer sounds
  1. Beep = PWM(1) specifies PWM output channel as channel 1.
  2. Beep.freq(200) sets the PWM output frequency to 200 Hz, meaning the buzzer vibrates 200 times per second.
  3. Beep.duty(50) sets the duty cycle to 50%, meaning the signal’s high level time and low level time each account for 50%.
  • Change Buzzer Frequency
Beep.freq(400)
Beep.freq(600)
Beep.freq(800)
Beep.freq(1000)
Beep.duty(0)
  1. Beep.freq(400) sets the buzzer frequency to 400 Hz. The buzzer emits a sound at 400 Hz frequency, and time.sleep(1) pauses for 1 second.
  2. Next, the frequency is set to 400 Hz, 600 Hz, 800 Hz, and 1000 Hz respectively, pausing 1 second after each setting so users can hear different frequency buzzes.
  3. Finally, Beep.duty(0) disables PWM output, which stops the buzzer from sounding.
2.7 ADC Experiment
2.7.1 Experiment Overview
This section demonstrates how to use programming to explore the ADC functionality of the K230 development board, including reading sample values and voltages through the ADC interface.
The K230 integrates an ADC hardware module with six channels, a 12-bit sampling resolution ranging from 0 to 4095, and a maximum sampling rate of 1 MHz.
2.7.2 Preparation
  • Module Connection
2.7.3 Program Execution and Download
Online Execution:
After connection, drag the program ADC.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program ADC.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.7.4 Program Outcome
The serial terminal displays the measured sampling values and voltage values from ADC channel 0.
2.7.5 Program Analysis
from machine import ADC
# Instantiate ADC channel 0
adc = ADC(0)
# Get the sampling value of ADC channel 0
print(adc.read_u16())
# Get the voltage value of ADC channel 0
print(adc.read_uv(), "uV")
  1. from machine import used to control the on-chip ADC analog-to-digital converter.
  2. The adc.read_u16() function reads the ADC value with 12-bit precision, returning a value from 0 to 4095. Channels 0 and 1 have a range of 0 to 3.6 V, while channels 2 and 3 have a range of 0 to 1.8 V.
  3. The adc.read_uv() function reads the ADC voltage, returning a value from 0 to 1.8 volts. Channels 0 and 1 actually have a range of 0 to 3.6 volts, while channels 2 and 3 have a range of 0 to 1.8 volts.
2.8 RTC Experiment
2.8.1 Experiment Overview
This section demonstrates how to use programming to explore the RTC (Real-Time Clock) module of the K230 development board, allowing you to set and retrieve the current system time.
The K230 provides an RTC (Real-Time Clock) class module that you can use to set and get the current system time.
2.8.2 Preparation
  • Module Connection
2.8.3 Program Execution and Download
Online Execution:
After connection, drag the program RTC.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program RTC.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.8.4 Program Outcome
Running the code, you can see the terminal prints the current RTC time information.
2.8.5 Program Analysis
from machine import RTC
# Instantiate RTC
rtc = RTC()
# Get current time
print(rtc.datetime())
# Set current time
rtc.init((2024, 2, 28, 2, 23, 59, 0, 0))
  1. Instantiate rtc = RTC() for convenient access to RTC functions
  2. Call the datetime() method to get the current system time, returns format by year, month, day, weekday, hour, minute, second, microsecond.
  3. Call the init() method to update and set the current time. The tuple parameter passed in includes year, month, date, weekday, hour, minute, second, and microsecond.
2.9 WDT Experiment
2.9.1 Experiment Overview
This section demonstrates how to use programming to explore the WDT (Watchdog Timer) auto-reset functionality of the K230 development board.
The K230 integrates two WDT (Watchdog Timer) hardware modules designed to ensure that the system can automatically restart if an application crashes and becomes unrecoverable. Once started, the WDT will automatically reset the system after a timeout if it is not periodically “fed” during operation. The K230 also provides an RTC (Real-Time Clock) module, allowing you to set and retrieve the current system time.
2.9.2 Preparation
  • Module Connection
2.9.3 Program Execution and Download
Online Execution:
After connection, drag the program WDT.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program WDT.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.9.4 Program Outcome
When the code runs, the serial terminal prints three messages at three-second intervals before the system automatically restarts, and the IDE connection is disconnected.
2.9.5 Program Analysis
from machine import WDT
wdt = WDT(1,3)
for i in range(3):
    print(i)
    wdt.feed()
  1. The wdt = WDT(id, timeout) function takes two parameters: id, which specifies the watchdog number, and timeout, which sets the timeout in seconds. In this example, the watchdog ID is set to 1 and the timeout is set to 3 seconds.
Create a watchdog object. The K230 has two watchdogs: Watchdog 0 for CPU0 (small core 800 MHz) and Watchdog 1 for CPU1 (big core 1.6 GHz). Since CanMV RTOS only uses CPU1, only Watchdog 1 is available.
  1. Call the wdt1.feed() method to reset the WDT timer and prevent a timeout reset. If wdt1.feed() is no longer called, the timeout will trigger a system reset.
2.10 TIMER Experiment
2.10.1 Experiment Overview
This section demonstrates how to use programming to explore the timer functionality of the K230 development board.
The K230 contains 6 Timer hardware modules, with a minimum timing period of 1us.
2.10.2 Preparation
  • Module Connection
2.10.3 Program Execution and Download
Online Execution:
After connection, drag the program TIMER.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program TIMER.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.10.4 Program Outcome
Use the timer to make the blue LED blink once per second periodically.
2.10.5 Program Analysis
  • Initialize LED Pin
# Initialize GPIO52 as general-purpose GPIO output
fpioa = FPIOA()
fpioa.set_function(52, FPIOA.GPIO52)
LED = Pin(52, Pin.OUT)
  1. The pin multiplexing configuration FPIOA().set_function(52, FPIOA.GPIO52) sets IO52 as a GPIO pin for LED use.
  2. LED = Pin(52, Pin.OUT) initializes the pin in push-pull output mode, and the voltage level can later be controlled using LED.value().
  • Create Timer Callback Task
# Timer callback, toggle LED state
def led_toggle(timer):
    global led_state
    led_state = not led_state
    LED.value(1 if led_state else 0)
  1. Define toggle variable global led_state.
  2. Toggle variable state led_state = not led_state.
  3. Set LED level state.
  • Create Software Timer
# Create software timer, 1Hz period, repeatedly call led_toggle
tim = Timer(-1)
tim.init(freq=1, mode=Timer.PERIODIC, callback=led_toggle)
  1. Timer creation tim = Timer(-1).
  2. Select “virtual” software timer (-1). init(freq=1, mode=Timer.PERIODIC, callback=led_toggle).
  3. Set a 1 Hz period in periodic mode, so that led_toggle is automatically called every second.
2.11 FFT Experiment
2.11.1 Experiment Overview
This section demonstrates how to use programming to explore the FFT functionality of the K230 development board.
The FFT (Fast Fourier Transform) module can perform a Fourier transform on input data and return the corresponding frequency amplitudes. By using FFT, a time-domain signal can be converted into the frequency domain, which helps analyze the signal’s frequency components.
2.11.2 Preparation
  • Module Connection
  2. Double-click to open CanMV IDE K230.
  3. Click the connection button in the lower left corner.
2.11.3 Program Execution and Download
Online Execution:
After connection, drag the program FFT.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program FFT.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.11.4 Program Outcome
From the last two printed outputs, the original signal can be accurately inferred in terms of which sine wave frequencies it consists of and their respective amplitudes, confirming the effectiveness of the FFT algorithm.
2.11.5 Program Analysis
from machine import FFT
import array
from ulab import numpy as np
PI = 3.14159265358979323846264338327950288419716939937510
rx = []
def input_data():
    for i in range(64):
        data0 = 10 * math.cos(2 * PI * i / 64)
        data1 = 20 * math.cos(2 * 2 * PI * i / 64)
        data2 = 30 * math.cos(3 * 2 * PI * i / 64)
        data3 = 0.2 * math.cos(4 * 2 * PI * i / 64)
        data4 = 1000 * math.cos(5 * 2 * PI * i / 64)
        rx.append(int(data0 + data1 + data2 + data3 + data4))
input_data()  # Initialize data for FFT, list type
print(rx)
data = np.array(rx, dtype=np.uint16)  # Convert list data to array
print(data)
fft1 = FFT(data, 64, 0x555)  # Create an FFT object, number of points is 64, offset is 0x555
res = fft1.run()  # Get the FFT transformed data
print(res)
res = fft1.amplitude(res)  # Get the amplitude of each frequency point
print(res)
res = fft1.freq(64, 38400)  # Get the frequency values of all frequency points
print(res)
  • Import Modules
import array
  1. machine.FFT: Import the core FFT processing module.
  2. array, math: Used for array operations and mathematical calculations.
  3. ulab.numpy as np: Import the ulab library.
  • Generate Test Signal
def input_data():
    for i in range(64):
  1. This function generates 64 data points using a for loop to simulate a sampling process. At each iteration, it calculates the values of five cosine waves with different frequencies and amplitudes and sums them together.
  2. rx.append(): Stores the sum (rounded) of these five waveforms in the list rx. Ultimately, rx contains composite waveform data of 64 points.
  • Data Preparation
print(rx)
print(data)
The FFT module requires data in this format for efficient computation. dtype=np.uint16 specifies that the data type of each element in the array is a 16-bit unsigned integer.
  • FFT Calculation and Result Retrieval
print(res)
print(res)
print(res)
  1. fft1 = FFT(data, 64, 0x555): Create an FFT object.
  2. data: Input signal data.
  3. 64: Number of FFT points, must match the number of input data points.
  4. 0x555: An offset. In signal processing, a DC bias may be added to the original signal to mitigate the impact of the 0Hz DC component on observation or subsequent processing, for this reason.
  5. res = fft1.run(): Execute the FFT transform. The resulting complex values are stored in res.
  6. print(res): Print the raw output of the FFT transform. res = fft1.amplitude(res): Calculate the amplitude. This function takes the complex results from the run() method and computes the magnitude for each frequency component.
  7. res = fft1.freq(64, 38400): Calculate the frequencies. This function computes the actual physical frequency corresponding to each amplitude point based on the number of FFT points (64) and the sampling rate (38400 Hz).
2.12 SHA256 Encryption Experiment
2.12.1 Experiment Overview
This section demonstrates the SHA256 functionality of the K230 development board through programming.
The K230 has a built-in SHA256 acceleration unit, supporting efficient SHA256 hash calculation through the uhashlib module.
2.12.2 Preparation
  • Module Connection
2.12.3 Program Execution and Download
Online Execution:
After connection, drag the program SHA256.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program SHA256.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.12.4 Program Outcome
Calling update() twice produces the correct SHA256 hash value, matching the expected result. This code verifies that uhashlib.sha256() supports updating the message data multiple times before computing the hash in a single step.
2.12.5 Program Analysis
import uhashlib
print('###################### SHA256 Test ##############################')
print('********************** Test-1: Only Call update() Once ******************')
# Initialize sha256 object
obj = uhashlib.sha256()
# Input message
msg = b'\x45\x11\x01\x25\x0e\xc6\xf2\x66\x52\x24\x9d\x59\xdc\x97\x4b\x73\x61\xd5\x71\xa8\x10\x1c\xdf\xd3\x6a\xba\x3b\x58\x54\xd3\xae\x08\x6b\x5f\xdd\x45\x97\x72\x1b\x66\xe3\xc0\xdc\x5d\x8c\x60\x6d\x96\x57\xd0\xe3\x23\x28\x3a\x52\x17\xd1\xf5\x3f\x2f\x28\x4f\x57\xb8'
# Standard hash value
dgst0 = b'\x1a\xaa\xf9\x28\x5a\xf9\x45\xb8\xa9\x7c\xf1\x4f\x86\x9b\x18\x90\x14\xc3\x84\xf3\xc7\xc2\xb7\xd2\xdf\x8a\x97\x13\xbf\xfe\x0b\xf1'
# Update message to hardware IP
obj.update(msg)
# Calculate hash value
dgst = obj.digest()
print(dgst0 == dgst)
# print(binascii.hexlify(dgst))
print('********************** Test-2: Call update() Twice ******************')
dgst0 = b'\x93\x6a\x18\x5c\xaa\xa2\x66\xbb\x9c\xbe\x98\x1e\x9e\x05\xcb\x78\xcd\x73\x2b\x0b\x32\x80\xeb\x94\x44\x12\xbb\x6f\x8f\x8f\x07\xaf'
# Update message to hardware multiple times
obj.update(b'hello')
obj.update(b'world')
dgst = obj.digest()
  • First update() Call
# Input message
obj.update(msg)
dgst = obj.digest()
  1. A SHA256 hash object obj is created.
  2. Calling obj.digest() computes the hash value of the message.
  3. It is then compared with the expected hash value dgst0 to verify consistency.
  • Second update() Call
dgst = obj.digest()
  1. Recreate a SHA256 hash object.
  2. Call digest() to obtain the hash value.
  3. Compare it with the expected hash value dgst0.
2.13 AES Encryption Experiment
2.13.1 Experiment Overview
This section demonstrates the AES encryption and decryption operations on the K230 development board through programming.
The K230 has a built-in encryption/decryption algorithm accelerator, supporting AES algorithm encryption and decryption operations.
2.13.2 Preparation
  • Module Connection
2.13.3 Program Execution and Download
Online Execution:
After connection, drag the program AES_GCM.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program AES_GCM.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.13.4 Program Outcome
The program uses the AES algorithm to encrypt plaintext and handles AES’s data length requirements through padding and unpadding. The correctness of the AES encryption and decryption process is verified through the complete encryption and decryption operations.
2.13.5 Program Analysis
  • Data Padding and Unpadding
def pad(data):
    n = 16 - (len(data) % 16)
    return data + bytes([0]*n)
def unpad(data):
    # Simply remove trailing 0s, not suitable for all scenarios, for example purposes
    return data.rstrip(b'\x00')
  1. The AES encryption algorithm requires that the length of input data must be a multiple of 16 bytes, so when the plaintext length is not a multiple of 16, padding is required.
  2. n = 16 - (len(data) % 16) calculates how many bytes need to be added to make the data length a multiple of 16.
  3. data + bytes([0]*n) adds n 0x00 bytes to the end of the plaintext data, making the length comply with AES algorithm requirements.
  4. During decryption, the decrypted data may contain padding bytes (0x00) at the end of the original data. The unpad function is used to remove these extra bytes and restore the original data. rstrip(b'\x00') removes all 0x00 bytes at the end of the data, which is the reverse operation of padding.
  • AES Encryption
crypto = ucryptolib.aes(aes[0].key, 1, aes[0].iv)
ct = crypto.encrypt(pt_padded)
print('Ciphertext:', ct)
Encryption is performed by initializing ucryptolib.aes with a key, using ECB mode as the encryption mode, and an initialization vector iv. The method crypto.encrypt(pt_padded) encrypts the padded plaintext and returns the ciphertext ct.
  • Decryption and Verification
crypto_dec = ucryptolib.aes(aes[0].key, 1, aes[0].iv)
pt_dec_padded = crypto_dec.decrypt(ct)
pt_dec = unpad(pt_dec_padded)
print('Decrypted plaintext:', pt_dec)
print('Does it match:', pt_dec == pt)
  1. Decryption is performed using the decrypt method. The decrypted data includes padding bytes, which are removed using unpad. A decrypter object is created with ucryptolib.aes(aes[0].key, 1, aes[0].iv), using the same key, ECB mode, and initialization vector as during encryption.
  2. crypto_dec.decrypt(ct) decrypts the ciphertext ct and returns the decrypted data pt_dec_padded. At this point, the data length may be a multiple of 16 but still includes the padding bytes.
  3. unpad(pt_dec_padded) removes the 0x00 padding bytes at the end of the decrypted data to obtain the original plaintext pt_dec.
  4. pt_dec == pt is used to verify whether the decrypted data is the same as the original plaintext. If they are the same, it indicates that the encryption and decryption process was successful and outputs True; otherwise, outputs False.
2.14 Multi-threading Experiment
2.14.1 Experiment Overview
This section covers learning the multithreading functionality of the K230 development board through programming.
2.14.2 Preparation
  • Module Connection
2.14.3 Program Execution and Download
Online Execution:
After connection, drag the program thread.py into CanMV IDE K230.
Offline Execution:
  1. After connection, drag the program thread.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.14.4 Program Outcome
There are two threads running in parallel, each printing a message once every second in its own loop.
Thread 1 prints hello 1 every second, and thread 2 prints hello 2 every second.
2.14.5 Program Analysis
  • Import Modules
import _thread # Import thread module
Import thread module and time module
  • Create Thread Function
# Thread function
def func(name):
        print("hello {}".format(name))
_thread.start_new_thread(func,("1",)) # Start thread 1, parameter must be a tuple
_thread.start_new_thread(func,("2",)) # Start thread 2, parameter must be a tuple
  1. _thread.start_new_thread(func, ("1",)): This line of code starts a new thread, calling the func function.
  2. func() receives a parameter name and enters an infinite loop.
  3. In each loop, print("hello {}".format(name)) outputs a message displaying the value corresponding to name, e.g., hello 1 or hello 2.
2.15 File Read/Write
2.15.1 Experiment Overview
This section demonstrates how to use the K230 development board to perform file read and write operations in MicroPython.
2.15.2 Preparation
  • Module Connection
2.15.3 Program Execution and Download
Online Execution:
After connection, drag the program File_read_and_write.py into CanMV IDE K230. In the code editor, click the run button in the lower left corner to run the program online, as shown below:
Offline Execution:
  1. After connection, drag the program File_read_and_write.py from this section’s directory into the CanMV IDE K230 code editor, click Tools in the toolbar, and select Save open script to CanMV Board (as main.py) as shown below:
  1. Then click Yes.
2.15.4 Program Outcome
After running the code, the file content is printed on the serial terminal. Then, open the CanMV drive and navigate to the sdcard directory to find the newly created data_log.txt file, which contains the text that was written, hello hiwonder. Besides .txt files, any file extension can be used, such as .json, .csv, or even files without an extension.
2.15.5 Program Analysis
  • Write File Operation
file_path = '/sdcard/data_log.txt'
# Write file, use with structure to automatically manage file closing
with open(file_path, 'w') as f:
    f.write('hello hiwonder')
Define the file path and use the open function to open the file at the specified path in write mode w. If the file does not exist, it will be created automatically. If the file already exists, write mode w will clear its contents and overwrite it.
  • Read File Operation
# Read file, use with structure to avoid forgetting to close
with open(file_path, 'r') as f:
    content = f.read()
    print(content)
This line of code opens the file again using the open function, this time in read mode 'r'. The f.read() method reads all the text from the file as a single string and stores it in the variable content, which is then printed.
