1. Getting Started Guide
After getting Jetson Orin Nano board, you can first review Chapter 2& Chapter 3 to set up the development environment for Jetson Orin Nano board. After that, selectively choose chapters for further study. Below will outline the content of each chapter:
In “2. Conifiguration Guide”, the detailed instructions on how to flash the image is provided. If you are using the official initial image provided by NAVDIA, you can use “SDK Manager Tool” to flash it. Since Jetson Orin Nano board comes pre-installed with JetPack, there is no need to flash it again and only the system image needs to be flashed. Additionally, you can also use the “SD card+Reader” or “solid-state drive (SSD)+hard drive enclosure” methods to flash the image we provide.
After installing the system image, power on Jetson Orin Nano and configure the network. You can connect via SSH for remote access and file transfer, or use remote desktop software for visual operations. Additionally, this chapter provides instructions on using USB drives, setting up automatic mounting at startup, and backing up and expanding the NVMe system.
This section focuses on the fundamentals of Python programming.
This chapter covers the basic pf hardware control for Jetson Orin Nano, including the use of CPIO, UART, and I2C.
6. OpenCV Computer Vision Course:
This chapter focuses on the fundamentals of OpenCV, including basic learning and applications.
This chapter includes instructions for camera installation and usage, as well as an introduction to programs based on Mediapipe.
This chapter covers the installation and testing of TensorFlow and PyTorch, and the application of YOLOv5, including training object detection models and using TensorRT to accelerate your YOLOv5 model.
This chapter includes the installation of ROS1 and basic examples of ROS1 usage.
10. ROS2 Basics Lesson Course:
This chapter includes the installation of ROS2 and basic examples of ROS2 usage.
