3. LiDAR Course
3.1 Introduction
3.1.1 Overview
LiDAR is a high-precision, high-speed remote sensing technology essential for mapping, autonomous driving, environmental perception, and robotic navigation. This document outlines LiDAR’s principles, key components, operation, applications, advantages, and future trends.
LiDAR plays a critical role in autonomous driving and intelligent transportation, enabling real-time detection of obstacles, pedestrians, and vehicles while providing precise distance and positional information. In robotic navigation and environmental perception, LiDAR provides accurate maps and detailed information about the surrounding environment. Additionally, LiDAR is widely used in 3D modeling and mapping, security monitoring, and remote sensing surveys.
3.1.2 LiDAR Components and Classification
LiDAR consists of a laser emitter, receiver and photodetector, scanning mechanism, and angle resolution system. The laser emitter generates laser beams, the receiver and photodetector capture the reflected signals, the scanning mechanism scans the surrounding environment, and the angle resolution system determines the positions of target objects.
Based on the scanning method, LiDAR can be functionally classified into the following types:
Rotating LiDAR: Rotating LiDAR achieves full scanning in the horizontal direction by rotating the emitter or scanning mechanism. It typically provides high scanning speed and measurement accuracy, which are widely used in autonomous driving, 3D environmental modeling, and mapping.
Solid-State LiDAR: Solid-State LiDAR uses a solid-state laser emitter and requires no rotating components. It is typically more compact, lightweight, and energy-efficient, making it suitable for applications such as mobile devices, drones, and robots.
Mechanical LiDAR: Mechanical LiDAR uses mechanical components to achieve laser beam scanning, such as rotating mirrors or rotating prisms. It usually has a longer measurement range and higher measurement accuracy but a slower scanning speed. Mechanical LiDAR is widely used in fields such as terrain measurement, building scanning, and navigation.
Phase-Modulated LiDAR: Phase-Modulated LiDAR measures the distance between the target object and the radar by changing the phase of the laser beam. It usually features high measurement accuracy and a large measurement range, and is widely used in fields such as map making, surveying, and industrial applications.
Flash LiDAR: Flash LiDAR uses a single short high-power laser pulse to illuminate the entire scene at once, and the reflected light signals are captured by a receiver array. It offers the advantages of high speed and high resolution, making it suitable for applications such as rapid scene capture and motion tracking.
3.1.3 Switch the LiDAR Version
The robot can be equipped with various types of LiDAR, such as A1 and G4. To check the current LiDAR model or make a selection, follow the steps below:
  1. Confirm the LiDAR version of the robot
The platform uses the MS200 LiDAR by default, which connects to the intelligent processor through a USB (URAT conversion) interface. It provides precise position information, supports a detection range of up to 15 m, and enables functions such as obstacle avoidance, following, SLAM, and navigation.
  1. Power on the robot and connect it using a remote desktop tool. For detailed connection instructions, refer to the section 1.7.2 AP Mode Connection Steps in the user manual.
  1. After the connection is complete, double-click the Tool icon on the desktop.
  1. Click the dropdown button on the LiDAR tab, select the LiDAR model that matches your robot, such as G4, then click Save and Apply.
  1. A popup, as shown below, will appear. The robot’s auto-start service will restart, and the LiDAR model will be set according to the selected option.
  1. After the reboot is complete, click Quit.
  1. Once the switch is finished, click the command line terminal icon on the left side of the system desktop to confirm the LiDAR version.
3.2 Working Principle and Distance Measurement Methods
3.2.1 LiDAR Distance Measurement
There are two common methods for LiDAR to determine the distance to a target: triangulation and time-of-flight (TOF).
For TOF, as illustrated below, the LiDAR emits light toward the object, which reflects directly back to the LiDAR. The LiDAR calculates the time taken for the light to return and multiplies it by the speed of light to determine the distance between the object and the LiDAR.
For triangulation, as shown below, during manufacturing, the LiDAR is adjusted so that the light does not directly hit the object but strikes at a fixed angle. This angle is preset and does not change during operation. Using trigonometric calculations with this angle, the distance from the object to the LiDAR can be determined.
3.2.2 LiDAR Performance
As illustrated below, the LiDAR emits light that illuminates the surface of an object. When the LiDAR receives the light reflected from the object, it marks the outline of the object at the positions where the light struck.
3.3 Radar obstacle avoidance
The robot will detect the distance between objects directly in front and its body, and will turn left or right to avoid obstacles based on the set distance. If no obstacles are encountered, it will continue moving forward.
There are two ways to enable this feature. The first is through the mobile app, and the second is by using commands after connecting to the system remotely.
For instructions on using the mobile app, refer to the section 1.5 App Installation and Connection in the user manual to view the related course.
  1. Start the robot and connect it to the remote control software NoMachine. For connection instructions, please refer to the section 1.7.2 AP Mode Connection Steps in the user manual.
  3. Stop the app auto-start service by entering the following command and pressing Enter:
  4. Enter the following command and press Enter to start the robot’s auto-start program:
    ros2 launch app LiDAR_node.launch.py debug:=true
  5. Open another command line terminal, enter the command, and press Enter to access the LiDAR feature:
    ros2 service call /LiDAR_app/enter std_srvs/srv/Trigger {}
  1. Then enter the command in the current command line terminal and press Enter to enable the LiDAR obstacle avoidance feature:
ros2 service call /LiDAR_app/set_running interfaces/srv/SetInt64 "{data: 1}"
  1. To stop the current function, enter the command in the current terminal and press Enter.
ros2 service call /LiDAR_app/set_running interfaces/srv/SetInt64 "{data: 0}"
  1. To exit the feature completely, press Ctrl+C in the terminal used in steps 4 or 5.
3.4 LiDAR Following
The robot detects the distance to objects directly in front of it. If an object comes too close, the robot will turn to avoid the obstacle.
  1. Enter the command and press Enter to start the local services for the app features and chassis control.
  1. Open another command line terminal, enter the command, and press Enter to access the LiDAR feature:
ros2 service call /LiDAR_app/set_running interfaces/srv/SetInt64 "{data: 2}"
3.5 LiDAR Guarding
This feature is only available for robots with a mecanum wheel chassis.
ros2 service call /LiDAR_app/set_running interfaces/srv/SetInt64 "{data: 3}"
